[mpich2-dev] MPI_Aint testcase development
Michael Blocksome blocksom at us.ibm.com
Mon Mar 10 15:15:01 CDT 2008
I'd like to start a discussion about MPI_Aint testcase development.
IBM is running the following test suites as each new internal development
builds become available:
1. Intelanl2006
2. SKAMPI5
3. POKMPISYS
4. POKMPIFVT
What is missing from this list are *targeted* tests for the MPI_Aint
problem. The only known test (to my knowledge) that hits the problem is
the b_eff_io program .. yet even this test was not written specifically to
the MPI_Aint problem.
Digging through my inbox, I found this from a summary email sent by Bryan
Hartlen (IBM) on 2/19:
ROMIO issue:
The Plan
1) Both IBM and ANL agree that the best way to proceed is to use what was
originally called option B (recasting)
2) Both IBM and ANL agree that IBM will assume the lead for implementing
the change (making the change(s) as required, testing and releasing)
3) Both IBM and ANL agree that IBM's effort above would benefit from any
test case development that ANL would be willing to provide.
4) Both IBM and ANL agree that IBM's scheduled release for this work in
the V1R2 release cycle (May 16) is acceptable.
5) Both IBM and ANL would like DOE's agreement that this plan above is
sufficient to remove the ROMIO issue as a gate to starting 500T acceptance
In regards to item #3, is ANL able to write testcase code for this
problem, given your knowledge and understanding of the code paths
involved?  Specifically, what code paths should we consider for test case
development?
Let's discuss on this mailing list the targeted tests that need to be
developed in order to fully test the solution to the MPI_Aint problem.
Thanks!
Michael Blocksome
Blue Gene Messaging Team Lead
Advanced Systems SW Development
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080310/e6f51a9d/attachment.htm>
More information about the mpich2-dev mailing list
