[mpich2-dev] Re: [MPICH2-dev] implementing MPID_Wtick()
William Gropp
wgropp at uiuc.edu
Fri Apr 18 10:09:14 CDT 2008
You are absolutely correct. I'll add a check for this after the
setup_device is run.
Bill
On Apr 10, 2008, at 9:08 AM, David Gingold wrote:
> On Apr 10, 2008, at 9:59 AM, William Gropp wrote:
>> Hmm. That should work. You do have to set the timer type with --
>> enable-timer-type=device ; if you want to force it, try setting
>> timer_type=device in your setup script.
> I am configuring with --enable-timer-type=device; that much works.
> But adding this:
> export MPID_DEVICE_TIMER_TYPE="long long"
> to my setup_device script seems to have no effect; mpichtimer.h
> still ends up with "long" as the type.
> It looks like setup_device is sourced after MPID_DEVICE_TIMER_TYPE
> is referenced in the top-level configure.in. Could that be my
> trouble?
> -dg
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080418/deacf61a/attachment.htm>
More information about the mpich2-dev
