[mpich2-dev] tests which assume that the implementation supports truncated messages
Rajeev Thakur thakur at mcs.anl.gov
Tue Apr 1 18:18:19 CDT 2008
> Would it make sense to change these tests to be more
> portable? Could they be made to trigger a different sort of
> error, perhaps one checked in the HAVE_ERROR_CHECKING
> portions of the top-level receive code?
It can't be checked in the HAVE_ERROR_CHECKING portions of the top-level
receive code because the size of the matching send is not known at that
time.
Rajeev
> -----Original Message-----
> From: owner-mpich2-dev at mcs.anl.gov
> [mailto:owner-mpich2-dev at mcs.anl.gov] On Behalf Of David Gingold
> Sent: Tuesday, April 01, 2008 3:44 PM
> To: mpich2-dev at mcs.anl.gov
> Subject: [mpich2-dev] tests which assume that the
> MPICH2 folks --
> Some of the tests that come with MPICH2 assume that the MPI
> implementation supports truncated messages (i.e.
> point-to-point operations with more data sent than received).
> It looks like the tests are using this as a way to determine
> whether errors can be returned in the receive status.
> Our MPI implementation doesn't support truncation. It's not
> required by the standard, and dispensing with it simplified
> our code and improved performance.
> -dg
> David Gingold
> Principal Software Engineer
> SiCortex
> Three Clock Tower Place, Suite 210
> Maynard MA 01754
> (978) 897-0214 x224
More information about the mpich2-dev mailing list
