[MPICH2-dev] Problems starting up MPD as root user
    Rusty Lusk
    lusk at mcs.anl.gov
    Mon Jan 29 12:31:25 CST 2007
It looks to me like you have the contents of mpd.hosts in mpd.conf.
The mpd.conf file contains options, and the secret word.
Rusty Lusk
On Jan 29, 2007, at 11:33 AMJanuary, nanday at csmail.cs.siu.edu wrote:
> Hi
> We have a 9 node linux cluster and I had installed MPICH2 few
> months ago on it.
> We have several users and each have their own MPD running right
> now, but now as
> part of our application we are developing we need to use MPD under
> root
> environment. So I created .mpd.conf file under /root directory and
> mpd.hosts
> file there as well, but I get this error when I try mpd & command.
> ***********************************ERROR******************************
> bash-3.00# mpd &
> [2] 20461
> bash-3.00#  (get_parms_from_rcfile 1168): line in mpd conf is not
> key=val pair;
> line=:athena.cs.siu.edu
>  (get_parms_from_rcfile 1168): line in mpd conf is not key=val pair;
> line=:oscarnode1.cs.siu.edu
> line=:oscarnode2.cs.siu.edu
> line=:oscarnode3.cs.siu.edu
> line=:oscarnode4.cs.siu.edu
> line=:oscarnode5.cs.siu.edu
> line=:oscarnode6.cs.siu.edu
> line=:oscarnode7.cs.siu.edu
> line=:oscarnode8.cs.siu.edu
> An mpd is already running with console at /tmp/mpd2.console_root on
> athena.cs.siu.edu.
> Start mpd with the -n option for a second mpd on same host.
> bash-3.00#
> *********************************ERROR********************************
> it says an mpd is already running under root, but when I try
> mpdtrace or any
> other mpd command I get the exact same error as above. Does anyone
> have any
> suggestions on this? Thanks!
> -Nanda
> This message was sent using Endymion MailMan.
> http://www.endymion.com/products/mailman/
More information about the mpich2-dev
