[MPICH2-dev] Why cannot i run "mpdboot" correctly
Rajeev Thakur
thakur at mcs.anl.gov
Mon Dec 3 23:11:53 CST 2007
Can the computing nodes ssh each other without a password? If it still does
not work, there is probably some problem with the networking environment on
the machines. To debug, you can use the mpdcheck utility as described in the
installation guide.
Rajeev
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.
gov] On Behalf Of yh sun
Sent: Monday, December 03, 2007 8:52 PM
To: mpich2-dev at mcs.anl.gov
Subject: [MPICH2-dev] Why cannot i run "mpdboot" correctly
hi everyone,
I have installed Mpich2 by running commands "./configure; make ;
make install"
According to the install guide.pdf , i am doing the next step to
configure it.
I am trying the step "Start the daemons on (some of) the hosts
in the file mpd.hosts".
When I run the command
"mpdboot -n 9 -f mpd.hosts"
The result shows that
"mpdboot_chemical.sccas.cn
(handle_mpd_output 385): failed to handshake with mpd on node-0-2.local;
recvd output="
My cluster has 9 nodes-- 1 fronted node, 8 computing nodes from
node-0-1 to node-0-8.
And my "mpd.hosts" file is like this
node-0-1.local
node-0-2.local
node-0-3.local
node-0-4.local
node-0-5.local
node-0-6.local
node-0-7.local
node-0-8.local
And I am sure that I can ssh all the computing nodes from fronted
node without entering password.
so what is the problem with command "mpdboot"?
Thanks
Regards
Yanh. Sun
Yanh. Sun
Super Computing Center, Chinese Network Information Center, Chinese
Academy of Sciences
mailbox 349,Beijing, 100080
tel: 010-58812101
More information about the mpich2-dev
