[MPICH2-dev] Why cannot i run "mpdboot" correctly
yh sun yanh.sun at gmail.com
Mon Dec 3 20:51:39 CST 2007
hi everyone,
    I have installed Mpich2 by running commands "./configure; make ; make
install"
    According to the install guide.pdf , i am doing the next step to
configure it.
    I am trying the step "Start the daemons on (some of) the hosts in the
file mpd.hosts".
    When I run the command
                                   "mpdboot -n 9 -f mpd.hosts"
    The result shows that
                         "mpdboot_chemical.sccas.cn (handle_mpd_output 385):
failed to handshake with mpd on node-0-2.local; recvd output="
   My cluster has 9 nodes-- 1 fronted node, 8 computing nodes from node-0-1
to node-0-8.
   And my "mpd.hosts" file is like this
        node-0-1.local
        node-0-2.local
        node-0-3.local
        node-0-4.local
        node-0-5.local
        node-0-6.local
        node-0-7.local
        node-0-8.local
  And I am sure that I can ssh all the computing nodes from fronted node
without entering password.
   so what is the problem with command "mpdboot"?
   Thanks
   Regards
   Yanh. Sun
Yanh. Sun
Super Computing Center, Chinese Network Information Center, Chinese Academy
of Sciences
mailbox 349,Beijing, 100080
tel: 010-58812101
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20071204/37191c4a/attachment.htm>
More information about the mpich2-dev mailing list
