[MPICH2-dev] problem with multithreaded version of MPI_Comm_split() in mpich2-1.03
Rajeev Thakur thakur at mcs.anl.gov
Mon Jun 26 10:21:19 CDT 2006
Alexey,
           I had found this problem, but applied the fix in a different
place (below)
        if (mask_in_use || comm_ptr->context_id > lowestContextId) {
            memset( local_mask, 0, MAX_CONTEXT_MASK * sizeof(int) );
            own_mask        = 0;            <----------------------------
            if (comm_ptr->context_id < lowestContextId) {
                lowestContextId = comm_ptr->context_id;
But your test hangs with this fix for nthreads > 4 (on a single machine).
I added your fix as well, but even then it hangs for nthreads > 4.
So I will have to look into it some more. Thanks for pointing out the
problem.
Rajeev
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Ryzhykh, Alexey
Sent: Monday, June 26, 2006 7:35 AM
To: mpich2-dev at mcs.anl.gov
Cc: Voronov, German; Supalov, Alexander
Subject: [MPICH2-dev] problem with multithreaded version of MPI_Comm_split()
in mpich2-1.03
I am working at Intel Parallel System & Applications group
I used mpich2-1.03 with sock device to run some MPI multithreaded
application.
Mpich2-10.3 was built to support MPI_THREAD_MULTIPLE level.
The application creates the communicator for each thread by means of
MPI_Comm_split() function.
This communicator is needed in order to MPI messages on one thread don't
intersect with messages on other thread.
But sometimes I see that the field context_id  is the same for different
thread communicators.
I created the test (see enclosed file test.tgz) to demonstrate the problem.
But this test  uses internal mpich2-1.03  definitions to check the value of
context_id.
Sometimes it fails as below:
nthreads=32
nthreads=32
[0] context_id=184 i=6 j=12
[1] context_id=184 i=6 j=12
 test failed, number of errors is 1
The failure shows that context_id is the same for different communicators.
I have prepared the simple fix of this bug. See in attachment enclosed file
commutil.c.diff
I believe that the bug is be fixed  after applying this patch to the source
file  mpich2-1.0.3/src/mpi/comm/commutil.c
With best regards,
Alexey Ryzhykh,
Intel, Sarov
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060626/eec36d70/attachment.htm>
More information about the mpich2-dev mailing list
