[MPICH2-dev] problem with multithreaded version of MPI_Comm_split() in mpich2-1.03
Ryzhykh, Alexey
alexey.ryzhykh at intel.com
Mon Jun 26 07:35:13 CDT 2006
I am working at Intel Parallel System & Applications group
I used mpich2-1.03 with sock device to run some MPI multithreaded
application.
Mpich2-10.3 was built to support MPI_THREAD_MULTIPLE level.
The application creates the communicator for each thread by means of
MPI_Comm_split() function.
This communicator is needed in order to MPI messages on one thread don't
intersect with messages on other thread.
But sometimes I see that the field context_id is the same for different
thread communicators.
I created the test (see enclosed file test.tgz) to demonstrate the
problem. But this test uses internal mpich2-1.03 definitions to check
the value of context_id.
Sometimes it fails as below:
nthreads=32
nthreads=32
[0] context_id=184 i=6 j=12
[1] context_id=184 i=6 j=12
test failed, number of errors is 1
The failure shows that context_id is the same for different
communicators.
I have prepared the simple fix of this bug. See in attachment enclosed
file commutil.c.diff
I believe that the bug is be fixed after applying this patch to the
source file mpich2-1.0.3/src/mpi/comm/commutil.c
With best regards,
Alexey Ryzhykh,
Intel, Sarov
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060626/7f453415/attachment.htm>
Type: application/x-compressed
Desc: test.tgz
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060626/7f453415/attachment.bin>
Desc: commutil.c.diff
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060626/7f453415/attachment.obj>
More information about the mpich2-dev
