[MPICH2 Req #3045] [MPICH2-dev] An issue with MPI_type_struct and MPI_Isend
Rajeev Thakur thakur at mcs.anl.gov
Mon Dec 11 09:37:56 CST 2006
Dmitry,
           The new release should be out today hopefully.
Rajeev
  _____
From: Ezhov, Dmitry [mailto:dmitry.ezhov at intel.com]
Sent: Monday, December 11, 2006 6:09 AM
To: Rajeev Thakur; mpich2-dev at mcs.anl.gov
Cc: Supalov, Alexander; Voronov, German; Ryzhykh, Alexey; Derbunovich,
Andrey; Cohn, Evan; Michaud, Joseph; mpich2-maint at mcs.anl.gov
Subject: RE: [MPICH2 Req #3045] [MPICH2-dev] An issue with MPI_type_struct
and MPI_Isend
Dear Rajeev,
Thank you.
Would it be possible to provide us with the fix in order to incorporate it
into our future builds?
Best regards.
Dmitry Ezhov
Software Engeneer,
Intel SSG/ESSD/Cluster Software & Technologies Lab,
Russia, Sarov.
  _____
Sent: Saturday, December 09, 2006 8:41 AM
To: Ezhov, Dmitry; mpich2-dev at mcs.anl.gov
and MPI_Isend
Thanks for the bug report. Rob has fixed it. The fix will appear in the
upcoming 1.0.5 release.
Rajeev
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Ezhov, Dmitry
Sent: Thursday, December 07, 2006 8:26 AM
To: mpich2-dev at mcs.anl.gov
Subject: [MPICH2 Req #3045] [MPICH2-dev] An issue with MPI_type_struct and
MPI_Isend
Dear Sirs,
We are having a problem using MPI_Type_struct and MPI_Isend in one of
applications.
We got the following error message (in case of 2 MPI processes):
Assertion failed in file gen_segment.c at line 615: cur_elmp->curcount >= 0
[cli_1]: aborting job:
internal ABORT - process 1
[cli_0]: aborting job:
internal ABORT - process 0
We created a simple test that reproduces the problem. This test is in the
attached file.
The issue was reproduced both with mpich2-1.0.3 and mpich2-1.0.4p1.
Please note: if you decrease a value of EL_COUNT to 1130 then the test will
work OK.
Do you know anything about this problem?
Thank you in advance.
Best regards.
Dmitry Ezhov
Software Engeneer,
Intel SSG/DPD/Parallel Solution Lab,
Russia, Sarov.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20061211/83e3a39c/attachment.htm>
More information about the mpich2-dev mailing list
