[MPICH2 Req #3045] [MPICH2-dev] An issue with MPI_type_struct and MPI_Isend
Rajeev Thakur thakur at mcs.anl.gov
Fri Dec 8 23:41:18 CST 2006
Thanks for the bug report. Rob has fixed it. The fix will appear in the
upcoming 1.0.5 release.
Rajeev
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Ezhov, Dmitry
Sent: Thursday, December 07, 2006 8:26 AM
To: mpich2-dev at mcs.anl.gov
Cc: Supalov, Alexander; Voronov, German; Ryzhykh, Alexey; Derbunovich,
Andrey; Cohn, Evan; Michaud, Joseph; mpich2-maint at mcs.anl.gov
Subject: [MPICH2 Req #3045] [MPICH2-dev] An issue with MPI_type_struct and
MPI_Isend
Dear Sirs,
We are having a problem using MPI_Type_struct and MPI_Isend in one of
applications.
We got the following error message (in case of 2 MPI processes):
Assertion failed in file gen_segment.c at line 615: cur_elmp->curcount >= 0
[cli_1]: aborting job:
internal ABORT - process 1
[cli_0]: aborting job:
internal ABORT - process 0
We created a simple test that reproduces the problem. This test is in the
attached file.
The issue was reproduced both with mpich2-1.0.3 and mpich2-1.0.4p1.
Please note: if you decrease a value of EL_COUNT to 1130 then the test will
work OK.
Do you know anything about this problem?
Thank you in advance.
Best regards.
Dmitry Ezhov
Software Engeneer,
Intel SSG/DPD/Parallel Solution Lab,
Russia, Sarov.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20061208/906f9408/attachment.htm>
More information about the mpich2-dev mailing list
