[MPICH2-dev] An issue with MPI_type_struct and MPI_Isend
Ezhov, Dmitry
dmitry.ezhov at intel.com
Thu Dec 7 08:26:09 CST 2006
Dear Sirs,
We are having a problem using MPI_Type_struct and MPI_Isend in one of
applications.
We got the following error message (in case of 2 MPI processes):
Assertion failed in file gen_segment.c at line 615: cur_elmp->curcount
>= 0
[cli_1]: aborting job:
internal ABORT - process 1
>= 0
[cli_0]: aborting job:
internal ABORT - process 0
We created a simple test that reproduces the problem. This test is in
the attached file.
The issue was reproduced both with mpich2-1.0.3 and mpich2-1.0.4p1.
Please note: if you decrease a value of EL_COUNT to 1130 then the test
will work OK.
Do you know anything about this problem?
Thank you in advance.
Best regards.
Dmitry Ezhov
Software Engeneer,
Intel SSG/DPD/Parallel Solution Lab,
Russia, Sarov.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20061207/944b72d1/attachment.htm>
Desc: issue.c
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20061207/944b72d1/attachment.obj>
More information about the mpich2-dev
