[MPICH2-dev] Re: MPICH2 1.0.5-rc1 PGI 64-bit compilers
William Gropp gropp at mcs.anl.gov
Fri Dec 1 03:14:23 CST 2006
Thanks for your report.  Here's an answer to one of your questions:
On Nov 29, 2006, at 8:05 PM, Larry Baker wrote:
> An question: If you have no C const (#ifdef HAVE_NO_C_CONST), why
> not just #define const as nothing?  Or, use CONST where you would
> normally use const and either #define CONST or #define CONST
> const?  It would cut down on the number of #ifdef/#else/#endif's,
> the number of lines of code, and reduce the chance of improperly
> nested or mispositioned preprocessor conditionals.
This was old code that hadn't been updated.  In looking at it, and
checking for where the various CPP names might be defined, I found
that most of this was obsolete, and I cleaned up most of this code.
Bill
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20061201/52bfebf1/attachment.htm>
More information about the mpich2-dev mailing list
