[MPICH2-dev] Two mpich2-1.0.3/mpiexec issues
Rusty Lusk
lusk at mcs.anl.gov
Thu Apr 20 09:47:02 CDT 2006
Hi Dmitry,
Thanks for pointing these problems out. The first one was already
fixed in our development version. It may be that we have already fixed
the second one as well, but I would like to make sure. Can you send me
an example invocation of mpiexec that illustrates the problem, so that
we can attempt to reproduce it?
Rusty Lusk
Subject: [MPICH2-dev] Two mpich2-1.0.3/mpiexec issues
Date: Wed, 19 Apr 2006 15:46:55 +0400
> Dear Sirs,
> The first issue is that mpiexec fails when it is used with -genv option:
> mpd_uncaught_except_tb handling:
> exceptions.KeyError: key genv not found in parm db
> I guess the failure occurs because of another key value is used in line
> #535 of the mpiexec.py module:
> parmdb['genv'][args[argidx+1]] = args[argidx+2]
> I tried to correct this issue by changing 'genv' to '-genv' and after it
> mpiexec works properly with -genv option.
> What do you thing about this correction?
> The second issue is that mpiexec fails when -genvlist option is used
> with two or more -host options (for example, using configfile):
> exceptions.AttributeError: 'list' object has no attribute 'split'
> I guess this failure happens due to -genvlist parameters parsing section
> (mpiexec.py, start line #656) executes each time the handle_local_argset
> procedure is called. The first call (i.e. the first parsing section
> execution) converts -genvlist option parameters from string into list,
> but the second one tries to convert obtained list into list again using
> string splitting method. And this operation results in raising
> AttributeError exception.
> How do you think, whether I'm right in assumption that the issue could
> be probably fixed by moving parameters parsing section before calling
> the aforementioned procedure in order to execute this section only once,
> for example, to line #269? At least, I tried to do it and got the
> workable mpiexec.py module properly working with -genvlist option
> together with configfile or many -host options.
> What is your opinion about these two issues?
> Thank you in advance.
> Best regards.
> Dmitry Ezhov
> Software Engeneer,
> Intel SSG/DPD/Parallel Solution Lab,
> Russia, Sarov.
More information about the mpich2-dev
