Author: goodell
Date: 2011-01-20 16:08:49 -0600 (Thu, 20 Jan 2011)
New Revision: 7782
Added:
mpich2/trunk/src/mpl/include/mpl_utlist.h
Modified:
mpich2/trunk/src/mpl/configure.in
Log:
add a tweaked version of utlist.h as mpl_utlist.h
This should reduce the amount of time we spend coding, reviewing,
and testing ad hoc linked-list implementations throughout MPICH2.
It should also improve readability in code that uses it.
Partially reviewed by balaji at .
Modified: mpich2/trunk/src/mpl/configure.in
--- mpich2/trunk/src/mpl/configure.in 2011-01-20 22:08:46 UTC (rev 7781)
+++ mpich2/trunk/src/mpl/configure.in 2011-01-20 22:08:49 UTC (rev 7782)
@@ -35,6 +35,17 @@
PAC_C_MACRO_VA_ARGS
+# check for compiler support for the __typeof() extension
+AC_CACHE_CHECK([whether the compiler supports __typeof(variable)],
+ [pac_cv_have__typeof],
+[AC_COMPILE_IFELSE([AC_LANG_PROGRAM([[]],[[double foo = 0.0; __typeof(foo) bar = 1.0;]])],
+ [pac_cv_have___typeof=yes],
+ [pac_cv_have___typeof=no])]
+if test "$pac_cv_have__typeof" = "yes" ; then
+ AC_DEFINE([HAVE___TYPEOF],[1],[defined if the C compiler supports __typeof(variable)])
+fi
dnl Check if the necessary headers are available
AC_CHECK_HEADERS(stdio.h stdlib.h string.h stdarg.h ctype.h)
Added: mpich2/trunk/src/mpl/include/mpl_utlist.h
--- mpich2/trunk/src/mpl/include/mpl_utlist.h (rev 0)
+++ mpich2/trunk/src/mpl/include/mpl_utlist.h 2011-01-20 22:08:49 UTC (rev 7782)
@@ -0,0 +1,501 @@
+/* MPICH2 notes:
+ * - The file name has been changed to avoid conflicts with any system-installed
+ * "utlist.h" header files.
+ * - some configure-time checking for __typeof() support was added
+ * - intentionally omitted from "mpl.h" in order to require using code to opt-in
+ * [goodell@ 2010-12-20] */
+Copyright (c) 2007-2010, Troy D. Hanson http://uthash.sourceforge.net
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are met:
+ * Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
+IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER
+OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef UTLIST_H
+#define UTLIST_H
+#define UTLIST_VERSION 1.9.1
+ * This file contains macros to manipulate singly and doubly-linked lists.
+ * 1. LL_ macros: singly-linked lists.
+ * 2. DL_ macros: doubly-linked lists.
+ * 3. CDL_ macros: circular doubly-linked lists.
+ * To use singly-linked lists, your structure must have a "next" pointer.
+ * To use doubly-linked lists, your structure must "prev" and "next" pointers.
+ * Either way, the pointer to the head of the list must be initialized to NULL.
+ * ----------------.EXAMPLE -------------------------
+ * struct item {
+ * int id;
+ * struct item *prev, *next;
+ * struct item *list = NULL:
+ * int main() {
+ * struct item *item;
+ * ... allocate and populate item ...
+ * DL_APPEND(list, item);
+ * For doubly-linked lists, the append and delete macros are O(1)
+ * For singly-linked lists, append and delete are O(n) but prepend is O(1)
+ * The sort macro is O(n log(n)) for all types of single/double/circular lists.
+#ifdef MPL_HAVE___TYPEOF /* MPICH2 modification */
+/* These macros use decltype or the earlier __typeof GNU extension.
+ As decltype is only available in newer compilers (VS2010 or gcc 4.3+
+ when compiling c++ code), this code uses whatever method is needed
+ or, for VS2008 where neither is available, uses casting workarounds. */
+#ifdef _MSC_VER /* MS compiler */
+#if _MSC_VER >= 1600 && defined(__cplusplus) /* VS2010 or newer in C++ mode */
+#define LDECLTYPE(x) decltype(x)
+#else /* VS2008 or older (or VS2010 in C mode) */
+#define NO_DECLTYPE
+#define LDECLTYPE(x) char*
+#endif
+#else /* GNU, Sun and other compilers */
+#define LDECLTYPE(x) __typeof(x)
+#endif
+#else /* !MPL_HAVE___TYPEOF */
+#endif /* !MPL_HAVE___TYPEOF */
+/* for VS2008 we use some workarounds to get around the lack of decltype,
+ * namely, we always reassign our tmp variable to the list head if we need
+ * to dereference its prev/next pointers, and save/restore the real head.*/
+#ifdef NO_DECLTYPE
+#define _SV(elt,list) _tmp = (char*)(list); {char **_alias = (char**)&(list); *_alias = (elt); }
+#define _NEXT(elt,list) ((char*)((list)->next))
+#define _NEXTASGN(elt,list,to) { char **_alias = (char**)&((list)->next); *_alias=(char*)(to); }
+#define _PREV(elt,list) ((char*)((list)->prev))
+#define _PREVASGN(elt,list,to) { char **_alias = (char**)&((list)->prev); *_alias=(char*)(to); }
+#define _RS(list) { char **_alias = (char**)&(list); *_alias=_tmp; }
+#define _CASTASGN(a,b) { char **_alias = (char**)&(a); *_alias=(char*)(b); }
+#else
+#define _NEXT(elt,list) ((elt)->next)
+#define _NEXTASGN(elt,list,to) ((elt)->next)=(to)
+#define _PREV(elt,list) ((elt)->prev)
+#define _PREVASGN(elt,list,to) ((elt)->prev)=(to)
+#define _RS(list)
+#define _CASTASGN(a,b) (a)=(b)
+#endif
+ * The sort macro is an adaptation of Simon Tatham's O(n log(n)) mergesort *
+ * Unwieldy variable names used here to avoid shadowing passed-in variables. *
+#define LL_SORT(list, cmp) \
+do { \
+ LDECLTYPE(list) _ls_p; \
+ LDECLTYPE(list) _ls_q; \
+ LDECLTYPE(list) _ls_e; \
+ LDECLTYPE(list) _ls_tail; \
+ LDECLTYPE(list) _ls_oldhead; \
+ LDECLTYPE(list) _tmp; \
+ int _ls_insize, _ls_nmerges, _ls_psize, _ls_qsize, _ls_i, _ls_looping; \
+ if (list) { \
+ _ls_insize = 1; \
+ _ls_looping = 1; \
+ while (_ls_looping) { \
+ _CASTASGN(_ls_p,list); \
+ _CASTASGN(_ls_oldhead,list); \
+ list = NULL; \
+ _ls_tail = NULL; \
+ _ls_nmerges = 0; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ for (_ls_i = 0; _ls_i < _ls_insize; _ls_i++) { \
+ _ls_psize++; \
+ _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list); \
+ if (!_ls_q) break; \
+ _ls_qsize = _ls_insize; \
+ while (_ls_psize > 0 || (_ls_qsize > 0 && _ls_q)) { \
+ if (_ls_psize == 0) { \
+ _ls_e = _ls_q; _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list); _ls_qsize--; \
+ } else if (_ls_qsize == 0 || !_ls_q) { \
+ _ls_e = _ls_p; _SV(_ls_p,list); _ls_p = _NEXT(_ls_p,list); _RS(list); _ls_psize--; \
+ } else if (cmp(_ls_p,_ls_q) <= 0) { \
+ } else { \
+ if (_ls_tail) { \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_ls_e); _RS(list); \
+ } else { \
+ _CASTASGN(list,_ls_e); \
+ _ls_tail = _ls_e; \
+ _ls_p = _ls_q; \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,NULL); _RS(list); \
+ if (_ls_nmerges <= 1) { \
+ _ls_looping=0; \
+ _ls_insize *= 2; \
+ } else _tmp=NULL; /* quiet gcc unused variable warning */ \
+} while (0)
+#define DL_SORT(list, cmp) \
+do { \
+ if (list) { \
+ _ls_insize = 1; \
+ list = NULL; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ _ls_psize++; \
+ } else { \
+ if (_ls_tail) { \
+ } else { \
+ _SV(_ls_e,list); _PREVASGN(_ls_e,list,_ls_tail); _RS(list); \
+ _ls_p = _ls_q; \
+ _CASTASGN(list->prev, _ls_tail); \
+ _ls_looping=0; \
+} while (0)
+#define CDL_SORT(list, cmp) \
+do { \
+ LDECLTYPE(list) _tmp2; \
+ if (list) { \
+ _ls_insize = 1; \
+ list = NULL; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ _ls_psize++; \
+ _SV(_ls_q,list); \
+ if (_NEXT(_ls_q,list) == _ls_oldhead) { \
+ _ls_q = NULL; \
+ } else { \
+ _ls_q = _NEXT(_ls_q,list); \
+ _RS(list); \
+ if (_ls_q == _ls_oldhead) { _ls_q = NULL; } \
+ if (_ls_p == _ls_oldhead) { _ls_p = NULL; } \
+ } else { \
+ if (_ls_tail) { \
+ } else { \
+ _ls_p = _ls_q; \
+ _CASTASGN(list->prev,_ls_tail); \
+ _CASTASGN(_tmp2,list); \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_tmp2); _RS(list); \
+ _ls_looping=0; \
+} while (0)
+ * singly linked list macros (non-circular) *
+#define LL_PREPEND(head,add) \
+do { \
+ (add)->next = head; \
+ head = add; \
+} while (0)
+#define LL_APPEND(head,add) \
+do { \
+ LDECLTYPE(head) _tmp; \
+ (add)->next=NULL; \
+ if (head) { \
+ _tmp = head; \
+ while (_tmp->next) { _tmp = _tmp->next; } \
+ _tmp->next=(add); \
+ } else { \
+ (head)=(add); \
+} while (0)
+#define LL_DELETE(head,del) \
+do { \
+ if ((head) == (del)) { \
+ (head)=(head)->next; \
+ } else { \
+ _tmp = head; \
+ while (_tmp->next && (_tmp->next != (del))) { \
+ _tmp = _tmp->next; \
+ if (_tmp->next) { \
+ _tmp->next = ((del)->next); \
+} while (0)
+/* Here are VS2008 replacements for LL_APPEND and LL_DELETE */
+#define LL_APPEND_VS2008(head,add) \
+do { \
+ if (head) { \
+ (add)->next = head; /* use add->next as a temp variable */ \
+ while ((add)->next->next) { (add)->next = (add)->next->next; } \
+ (add)->next->next=(add); \
+ } else { \
+ (head)=(add); \
+} while (0)
+#define LL_DELETE_VS2008(head,del) \
+do { \
+ } else { \
+ char *_tmp = (char*)(head); \
+ while (head->next && (head->next != (del))) { \
+ head = head->next; \
+ if (head->next) { \
+ head->next = ((del)->next); \
+ char **_head_alias = (char**)&(head); \
+ *_head_alias = _tmp; \
+} while (0)
+#ifdef NO_DECLTYPE
+#undef LL_APPEND
+#define LL_APPEND LL_APPEND_VS2008
+#undef LL_DELETE
+#define LL_DELETE LL_DELETE_VS2008
+#endif
+/* end VS2008 replacements */
+#define LL_FOREACH(head,el) \
+ for(el=head;el;el=el->next)
+#define LL_FOREACH_SAFE(head,el,tmp) \
+ for((el)=(head);(el) && (tmp = (el)->next, 1); (el) = tmp)
+#define LL_SEARCH_SCALAR(head,out,field,val) \
+do { \
+ LL_FOREACH(head,out) { \
+ if ((out)->field == (val)) break; \
+} while(0)
+#define LL_SEARCH(head,out,elt,cmp) \
+do { \
+ if ((cmp(out,elt))==0) break; \
+} while(0)
+ * doubly linked list macros (non-circular) *
+#define DL_PREPEND(head,add) \
+do { \
+ if (head) { \
+ (add)->prev = (head)->prev; \
+ (head)->prev = (add); \
+ } else { \
+ (add)->prev = (add); \
+ (head) = (add); \
+} while (0)
+#define DL_APPEND(head,add) \
+do { \
+ if (head) { \
+ (head)->prev->next = (add); \
+ (add)->next = NULL; \
+ } else { \
+ (head)=(add); \
+ (head)->prev = (head); \
+ (head)->next = NULL; \
+} while (0);
+#define DL_DELETE(head,del) \
+do { \
+ if ((del)->prev == (del)) { \
+ (head)=NULL; \
+ } else if ((del)==(head)) { \
+ (del)->next->prev = (del)->prev; \
+ (head) = (del)->next; \
+ } else { \
+ (del)->prev->next = (del)->next; \
+ if ((del)->next) { \
+ } else { \
+ (head)->prev = (del)->prev; \
+} while (0);
+#define DL_FOREACH(head,el) \
+/* this version is safe for deleting the elements during iteration */
+#define DL_FOREACH_SAFE(head,el,tmp) \
+/* these are identical to their singly-linked list counterparts */
+#define DL_SEARCH_SCALAR LL_SEARCH_SCALAR
+#define DL_SEARCH LL_SEARCH
+ * circular doubly linked list macros *
+#define CDL_PREPEND(head,add) \
+do { \
+ if (head) { \
+ (add)->next = (head); \
+ (add)->prev->next = (add); \
+ } else { \
+ (add)->next = (add); \
+(head)=(add); \
+} while (0)
+#define CDL_DELETE(head,del) \
+do { \
+ if ( ((head)==(del)) && ((head)->next == (head))) { \
+ (head) = 0L; \
+ } else { \
+ if ((del) == (head)) (head)=(del)->next; \
+} while (0);
+#define CDL_FOREACH(head,el) \
+ for(el=head;el;el=(el->next==head ? 0L : el->next))
+#define CDL_FOREACH_SAFE(head,el,tmp1,tmp2) \
+ for((el)=(head), ((tmp1)=(head)?((head)->prev):NULL); \
+ (el) && ((tmp2)=(el)->next, 1); \
+ ((el) = (((el)==(tmp1)) ? 0L : (tmp2))))
+#define CDL_SEARCH_SCALAR(head,out,field,val) \
+do { \
+ CDL_FOREACH(head,out) { \
+} while(0)
+#define CDL_SEARCH(head,out,elt,cmp) \
+do { \
+} while(0)
+#endif /* UTLIST_H */
