[mpich2-commits] r7783 - mpich2/trunk/src/mpi/comm
goodell at mcs.anl.gov
Thu Jan 20 16:08:52 CST 2011
Author: goodell
Date: 2011-01-20 16:08:51 -0600 (Thu, 20 Jan 2011)
New Revision: 7783
Modified:
mpich2/trunk/src/mpi/comm/commutil.c
Log:
add a default collops initialization facility
This is needed to provide always-set collops functions for the nonblocking
collective operations.
Reviewed by balaji at .
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:08:49 UTC (rev 7782)
+++ mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:08:51 UTC (rev 7783)
@@ -195,11 +195,145 @@
return mpi_errno;
+/* holds default collop "vtables" for _intracomms_, where
+ * default[hierarchy_kind] is the pointer to the collop struct for that
+ * hierarchy kind */
+static struct MPID_Collops *default_collops[MPID_HIERARCHY_SIZE] = {NULL};
+/* default for intercomms */
+static struct MPID_Collops *ic_default_collops = NULL;
+#undef FUNCNAME
+#define FUNCNAME cleanup_default_collops
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+static int cleanup_default_collops(void *unused) {
+ int i;
+ for (i = 0; i < MPID_HIERARCHY_SIZE; ++i) {
+ if (default_collops[i]) {
+ MPIU_Assert(default_collops[i]->ref_count >= 1);
+ if (--default_collops[i]->ref_count == 0)
+ MPIU_Free(default_collops[i]);
+ default_collops[i] = NULL;
+ if (ic_default_collops) {
+ MPIU_Assert(ic_default_collops->ref_count >= 1);
+ if (--ic_default_collops->ref_count == 0)
+ MPIU_Free(ic_default_collops);
+ return MPI_SUCCESS;
+#undef FUNCNAME
+#define FUNCNAME init_default_collops
+#undef FCNAME
+static int init_default_collops(void)
+ int mpi_errno = MPI_SUCCESS;
+ int i;
+ struct MPID_Collops *ops = NULL;
+ MPIU_CHKPMEM_DECL(MPID_HIERARCHY_SIZE+1);
+ /* first initialize the intracomms */
+ MPIU_CHKPMEM_CALLOC(ops, struct MPID_Collops *, sizeof(struct MPID_Collops), mpi_errno, "default intracomm collops");
+ ops->ref_count = 1; /* force existence until finalize time */
+ /* intracomm default defaults... */
+ /* TODO add other fns here as they are added */
+ /* override defaults, such as for SMP */
+ switch (i) {
+ case MPID_HIERARCHY_FLAT:
+ break;
+ case MPID_HIERARCHY_PARENT:
+ break;
+ case MPID_HIERARCHY_NODE:
+ break;
+ case MPID_HIERARCHY_NODE_ROOTS:
+ break;
+ default:
+ MPIU_Assertp(FALSE);
+ break;
+ default_collops[i] = ops;
+ /* now the intercomm table */
+ MPIU_CHKPMEM_CALLOC(ops, struct MPID_Collops *, sizeof(struct MPID_Collops), mpi_errno, "default intercomm collops");
+ /* intracomm defaults */
+ ops->Ibcast = NULL;
+ ic_default_collops = ops;
+ /* run after MPID_Finalize to permit collective usage during finalize */
+ MPIR_Add_finalize(cleanup_default_collops, NULL, MPIR_FINALIZE_CALLBACK_PRIO - 1);
+ MPIU_CHKPMEM_COMMIT();
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ MPIU_CHKPMEM_REAP();
+ goto fn_exit;
+/* Initializes the coll_fns field of comm to a sensible default. It may re-use
+ * an existing structure, so any override by a lower level should _not_ change
+ * any of the fields but replace the coll_fns object instead.
+ * NOTE: for now we only initialize nonblocking collective routines, since the
+ * blocking collectives all contain fallback logic that correctly handles NULL
+ * override functions. */
+#undef FUNCNAME
+#define FUNCNAME set_collops
+#undef FCNAME
+static int set_collops(MPID_Comm *comm)
+ static int initialized = FALSE;
+ if (comm->coll_fns != NULL)
+ goto fn_exit;
+ if (unlikely(!initialized)) {
+ mpi_errno = init_default_collops();
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ initialized = TRUE;
+ if (comm->comm_kind == MPID_INTRACOMM) {
+ /* FIXME MT what protects access to this structure and ic_default_collops? */
+ comm->coll_fns = default_collops[comm->hierarchy_kind];
+ else { /* intercomm */
+ comm->coll_fns = ic_default_collops;
+ comm->coll_fns->ref_count++;
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
/* Provides a hook for the top level functions to perform some manipulation on a
communicator just before it is given to the application level.
For example, we create sub-communicators for SMP-aware collectives at this
step. */
+#undef FUNCNAME
+#define FUNCNAME MPIR_Comm_commit
+#undef FCNAME
int MPIR_Comm_commit(MPID_Comm *comm)
@@ -274,6 +408,9 @@
&comm->node_comm->vcr[i] );
+ mpi_errno = set_collops(comm->node_comm);
MPID_Dev_comm_create_hook( comm->node_comm );
/* don't call MPIR_Comm_commit here */
@@ -303,6 +440,9 @@
&comm->node_roots_comm->vcr[i] );
+ mpi_errno = set_collops(comm->node_roots_comm);
MPID_Dev_comm_create_hook( comm->node_roots_comm );
@@ -311,6 +451,12 @@
fn_exit:
+ if (!mpi_errno) {
+ /* catch all of the early-bail, non-error cases */
+ mpi_errno = set_collops(comm);
if (external_procs != NULL)
MPIU_Free(external_procs);
if (local_procs != NULL)
@@ -1039,6 +1185,8 @@
MPIU_THREAD_CS_EXIT(MPI_OBJ, comm_ptr);
+ /* FIXME do we want to copy coll_fns here? */
/* Notify the device of the new communicator */
MPID_Dev_comm_create_hook(newcomm_ptr);
mpi_errno = MPIR_Comm_commit(newcomm_ptr);
@@ -1103,6 +1251,14 @@
destroyed */
MPID_Dev_comm_destroy_hook(comm_ptr);
+ /* release our reference to the collops structure, comes after the
+ * destroy_hook to allow the device to manage these vtables in a custom
+ * fashion */
+ if (comm_ptr->coll_fns && --comm_ptr->coll_fns->ref_count == 0) {
+ MPIU_Free(comm_ptr->coll_fns);
+ comm_ptr->coll_fns = NULL;
/* Free the VCRT */
mpi_errno = MPID_VCRT_Release(comm_ptr->vcrt, isDisconnect);
if (mpi_errno != MPI_SUCCESS) {
More information about the mpich2-commits
