[mpich2-commits] r7766 - mpich2/trunk/src/mpi/coll
buntinas at mcs.anl.gov buntinas at mcs.anl.gov
Thu Jan 20 14:21:35 CST 2011
Author: buntinas
Date: 2011-01-20 14:21:35 -0600 (Thu, 20 Jan 2011)
New Revision: 7766
Modified:
   mpich2/trunk/src/mpi/coll/alltoall.c
   mpich2/trunk/src/mpi/coll/alltoallv.c
   mpich2/trunk/src/mpi/coll/alltoallw.c
Log:
Reverted r7739 r7745 r7746 and r7747.  These were an attempt to eliminate the need to send zero-byte messages in collectives.  However the problem is more subtle that it looks.
Modified: mpich2/trunk/src/mpi/coll/alltoall.c
--- mpich2/trunk/src/mpi/coll/alltoall.c	2011-01-20 03:23:44 UTC (rev 7765)
+++ mpich2/trunk/src/mpi/coll/alltoall.c	2011-01-20 20:21:35 UTC (rev 7766)
@@ -623,10 +623,6 @@
             sendaddr = (char *)sendbuf + dst*sendcount*sendtype_extent;
-        if (sendcount == 0)
-            dst = MPI_PROC_NULL;
-        if (recvcount == 0)
-            src = MPI_PROC_NULL;
         mpi_errno = MPIC_Sendrecv(sendaddr, sendcount, sendtype, dst,
                                   MPIR_ALLTOALL_TAG, recvaddr,
                                   recvcount, recvtype, src,
Modified: mpich2/trunk/src/mpi/coll/alltoallv.c
--- mpich2/trunk/src/mpi/coll/alltoallv.c	2011-01-20 03:23:44 UTC (rev 7765)
+++ mpich2/trunk/src/mpi/coll/alltoallv.c	2011-01-20 20:21:35 UTC (rev 7766)
@@ -67,7 +67,7 @@
 	MPID_Comm *comm_ptr )
     int        comm_size, i, j;
-    MPI_Aint   send_extent, recv_extent, sendtype_size, recvtype_size;
+    MPI_Aint   send_extent, recv_extent;
     int        mpi_errno = MPI_SUCCESS;
     MPI_Status *starray;
     MPI_Status status;
@@ -86,8 +86,6 @@
     /* Get extent of send and recv types */
     MPID_Datatype_get_extent_macro(sendtype, send_extent);
     MPID_Datatype_get_extent_macro(recvtype, recv_extent);
-    MPID_Datatype_get_size_macro(sendtype, sendtype_size);
-    MPID_Datatype_get_size_macro(recvtype, recvtype_size);
     /* check if multiple threads are calling this collective function */
     MPIDU_ERR_CHECK_MULTIPLE_THREADS_ENTER( comm_ptr );
@@ -105,7 +103,7 @@
         for (i = 0; i < comm_size; ++i) {
             /* start inner loop at i to avoid re-exchanging data */
             for (j = i; j < comm_size; ++j) {
-                if (rank == i && (recvcnts[j] * recvtype_size)) {
+                if (rank == i) {
                     /* also covers the (rank == i && rank == j) case */
                     mpi_errno = MPIC_Sendrecv_replace(((char *)recvbuf + rdispls[j]*recv_extent),
                                                       recvcnts[j], recvtype,
@@ -114,7 +112,7 @@
                                                       comm, &status);
                     if (mpi_errno) MPIU_ERR_POP(mpi_errno);
-                else if (rank == j && (recvcnts[i] * recvtype_size)) {
+                else if (rank == j) {
                     /* same as above with i/j args reversed */
                     mpi_errno = MPIC_Sendrecv_replace(((char *)recvbuf + rdispls[i]*recv_extent),
                                                       recvcnts[i], recvtype,
@@ -141,7 +139,7 @@
             /* do the communication -- post ss sends and receives: */
             for ( i=0; i<ss; i++ ) {
                 dst = (rank+i+ii) % comm_size;
-                if (recvcnts[dst] * recvtype_size) {
+                if (recvcnts[dst]) {
                     MPID_Datatype_get_size_macro(recvtype, type_size);
                     if (type_size) {
                         MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
@@ -158,7 +156,7 @@
                 dst = (rank-i-ii+comm_size) % comm_size;
-                if (sendcnts[dst] * sendtype_size) {
+                if (sendcnts[dst]) {
                     MPID_Datatype_get_size_macro(sendtype, type_size);
                     if (type_size) {
                         MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
@@ -230,7 +228,7 @@
     int local_size, remote_size, max_size, i;
     MPI_Status status;
     int src, dst, rank, sendcount, recvcount;
@@ -245,8 +243,6 @@
@@ -279,10 +275,6 @@
             sendcount = sendcnts[dst];
-        if (sendcount * sendtype_size == 0)
-        if (recvcount * recvtype_size == 0)
                                   MPIR_ALLTOALLV_TAG, recvaddr, recvcount,
                                   recvtype, src, MPIR_ALLTOALLV_TAG,
Modified: mpich2/trunk/src/mpi/coll/alltoallw.c
--- mpich2/trunk/src/mpi/coll/alltoallw.c	2011-01-20 03:23:44 UTC (rev 7765)
+++ mpich2/trunk/src/mpi/coll/alltoallw.c	2011-01-20 20:21:35 UTC (rev 7766)
@@ -72,7 +72,6 @@
     int outstanding_requests;
     int ii, ss, bblock;
     int type_size;
-    MPI_Aint size1, size2;
     MPIU_CHKLMEM_DECL(2);
     comm = comm_ptr->handle;
@@ -95,11 +94,7 @@
-                /* Get size of recv types */
-                MPID_Datatype_get_size_macro(recvtypes[i], size1);
-                MPID_Datatype_get_size_macro(recvtypes[j], size2);
-                if (rank == i && (recvcnts[j] * size2)) {
+                if (rank == i) {
                     mpi_errno = MPIC_Sendrecv_replace(((char *)recvbuf + rdispls[j]),
                                                       recvcnts[j], recvtypes[j],
@@ -112,7 +107,7 @@
                         MPIU_ERR_ADD(mpi_errno_ret, mpi_errno);
-                else if (rank == j && (recvcnts[i] * size1)) {
                     mpi_errno = MPIC_Sendrecv_replace(((char *)recvbuf + rdispls[i]),
                                                       recvcnts[i], recvtypes[i],
@@ -267,7 +262,6 @@
     char *sendaddr, *recvaddr;
     MPI_Datatype sendtype, recvtype;
-    MPI_Aint sendtype_size, recvtype_size;
     MPI_Comm comm;
     local_size = comm_ptr->local_size;
@@ -306,13 +300,6 @@
             sendtype = sendtypes[dst];
-        MPID_Datatype_get_size_macro(sendtypes[dst], sendtype_size);
-        MPID_Datatype_get_size_macro(recvtypes[src], recvtype_size);
                                   dst, MPIR_ALLTOALLW_TAG, recvaddr,
More information about the mpich2-commits mailing list
