[mpich2-commits] r7763 - in mpich2/branches/release/mpich2-1.3.x: . confdb maint src/mpid src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src src/pm/hydra src/pm/hydra/examples src/pm/hydra/include src/pm/hydra/pm src/pm/hydra/pm/pmiserv src/pm/hydra/tools src/pm/hydra/tools/bootstrap/external src/pm/hydra/tools/bootstrap/include src/pm/hydra/tools/bootstrap/src src/pm/hydra/tools/bootstrap/utils src/pm/hydra/ui src/pm/hydra/utils
balaji at mcs.anl.gov
Wed Jan 19 18:00:15 CST 2011
Author: balaji
Date: 2011-01-19 18:00:15 -0600 (Wed, 19 Jan 2011)
New Revision: 7763
Added:
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_query_jobid.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_job_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_job_id.c
Modified:
mpich2/branches/release/mpich2-1.3.x/README.vin
mpich2/branches/release/mpich2-1.3.x/confdb/
mpich2/branches/release/mpich2-1.3.x/maint/Version
mpich2/branches/release/mpich2-1.3.x/src/mpid/
mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.h
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_cb.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_utils.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/Makefile.mk
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external.h
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_init.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/include/bsci.h.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/Makefile.mk
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/Makefile.mk
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu.h
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils/
mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
Merge r7758, r7759, r7761 and r7762 from trunk.
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
- /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/error-return:7662-7670
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt:5050
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Modified: mpich2/branches/release/mpich2-1.3.x/README.vin
--- mpich2/branches/release/mpich2-1.3.x/README.vin 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/README.vin 2011-01-20 00:00:15 UTC (rev 7763)
@@ -746,54 +746,71 @@
The features described in this section should be considered
experimental. Which means that they have not been fully tested, and
-the behavior may change in future releases.
+the behavior may change in future releases. The below notes are some
+guidelines on what can be expected in this feature:
-Communication failures in MPICH2 are not fatal errors. This means
-that if the user sets the error handler to MPI_ERRORS_RETURN, MPICH2
-will return an appropriate error code in the event of a communication
-failure. When a process detects a failure when communicating with
-another process, it will consider that other process as having failed
-and will no longer attempt to communicate with that process. The user
-can, however, continue making communication calls to other processes.
-Any outstanding send or receive operations to a failed process, or
-wildcard receives (i.e., with MPI_ANY_SOURCE) posted to communicators
-with a failed process, will be immediately completed with an
-appropriate error code.
+ - ERROR RETURNS: Communication failures in MPICH2 are not fatal
+ errors. This means that if the user sets the error handler to
+ MPI_ERRORS_RETURN, MPICH2 will return an appropriate error code in
+ the event of a communication failure. When a process detects a
+ failure when communicating with another process, it will consider
+ the other process as having failed and will no longer attempt to
+ communicate with that process. The user can, however, continue
+ making communication calls to other processes. Any outstanding
+ send or receive operations to a failed process, or wildcard
+ receives (i.e., with MPI_ANY_SOURCE) posted to communicators with a
+ failed process, will be immediately completed with an appropriate
+ error code.
-Collectives performed on a communicator with a failed process will not
-hang, however, the results of the operation are undefined. Some, but
-not necessarily all, processes may return an error. Specifically,
-the collective on some process might not return an error, but the
-result may still be invalid.
+ - COLLECTIVES: For collective operations performed on communicators
+ with a failed process, the collective would return an error on
+ some, but not necessarily all processes. A collective call
+ returning MPI_SUCCESS on a given process means that the part of the
+ collective performed by that process has been successful.
-If used with the hydra process manager, hydra will detect failed
-processes and notify the MPICH2 library. Users can query the list of
-failed processes using the MPICH_ATTR_FAILED_PROCESSES predefined
-attribute on MPI_COMM_WORLD. The attribute value is an integer array
-containing the ranks of the failed processes. The array is terminated
-by MPI_PROC_NULL. The user needs to declare the following extern in
-order to use the attribute:
- extern int MPICH_ATTR_FAILED_PROCESSES;
+ MPICH2 release specific note: There is currently a bug in MPICH2
+ that might cause the collective operation to return
+ MPI_SUCCESS on a process even if data is corrupted on that
+ process.
-Note that hydra by default will abort the entire application when any
-process terminates before calling MPI_Finalize. In order to allow
-an application to continue running despite failed processes, you'll
-need to pass the -disable-auto-cleanup option to mpiexec.
+ - PROCESS MANAGER: If used with the hydra process manager, hydra will
+ detect failed processes and notify the MPICH2 library. Users can
+ query the list of failed processes using the
+ MPICH_ATTR_FAILED_PROCESSES predefined attribute on MPI_COMM_WORLD.
+ The attribute value is an integer array containing the ranks of the
+ failed processes. The array is terminated by MPI_PROC_NULL.
-Unsupported feature: In the current implementation (version 1.3.2),
-hydra notifies the MPICH2 library of failed processes by sending a
-SIGUSR1 signal. The application can catch this signal to be notified
-of failed processes. If the application replaces the library's signal
-handler with its own, the application must be sure to call the
-library's handler from it's own handler. The MPICH_ATTR_FAILED_
-PROCESSES attribute is not updated in the signal handler immediately,
-so the application must call a function like MPI_Iprobe() in order to
-allow the library to process the notification. Note that you cannot
-call MPI function from inside a signal handler (which admittedly makes
-this difficult to use). This feature may not be (probably won't be)
-supported in future releases, so portable applications should not use
-it.
+ MPICH2 release specific note: The user needs to declare the
+ following extern within the application in order to use the
+ attribute (this ideally should be added to mpi.h, but has not
+ been done so, to preserve ABI compatibility in the 1.3.x
+ release series):
+ extern int MPICH_ATTR_FAILED_PROCESSES;
+ Note that hydra by default will abort the entire application when
+ any process terminates before calling MPI_Finalize. In order to
+ allow an application to continue running despite failed processes,
+ you will need to pass the -disable-auto-cleanup option to mpiexec.
+ - FAILURE NOTIFICATION: THIS IS AN UNSUPPORTED FEATURE AND WILL
+ ALMOST CERTAINLY CHANGE IN THE FUTURE!
+ In the current release, hydra notifies the MPICH2 library of failed
+ processes by sending a SIGUSR1 signal. The application can catch
+ this signal to be notified of failed processes. If the application
+ replaces the library's signal handler with its own, the application
+ must be sure to call the library's handler from it's own
+ handler. Note that you cannot call any MPI function from inside a
+ signal handler.
+ In future releases, the plan is to provide a call such as
+ MPIX_Failure_notification that will allow the user to register a
+ callback function that will be called on process failures. This
+ mechanism has not been added yet to preserve ABI compatibility in
+ the 1.3.x release series.
Checkpoint and Restart
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
- /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/error-return/confdb:7662-7670
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
- /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7447,7604,7671,7674,7683,7685,7687,7701-7702,7720,7722
+ /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid
- /mpich2/branches/dev/ckpt/src/mpid:5050
/mpich2/branches/dev/ckpt2/src/mpid:5057-6537
/mpich2/branches/dev/error-return/src/mpid:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid:5661-5730
/mpich2/branches/dev/lapi/src/mpid:5817
/mpich2/branches/dev/wintcp_async_progress/src/mpid:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid:5406
/mpich2/trunk/src/mpid:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/mpid:5050
/mpich2/trunk/src/mpid:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
- /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/error-return/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
- /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/error-return/src/mpl/src/mplstr.c:7662-7670
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra
- /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra:5406
/mpich2/trunk/src/pm/hydra:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671*,7674*,7676-7678,7681,7683*,7684,7685*,7686,7687*,7688,7690-7692,7694,7696,7700,7701-7702*,7705,7707-7710,7712,7714,7719,7720*,7722*,7724-7725*,7728-7729*,7733*,7735-7737*,7739*,7741*,7744-7748*,7751-7754*
+ /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/trunk/src/pm/hydra:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671*,7674*,7676-7678,7681,7683*,7684,7685*,7686,7687*,7688,7690-7692,7694,7696,7700,7701-7702*,7705,7707-7710,7712,7714,7719,7720*,7722*,7724-7725*,7728-7729*,7733*,7735-7737*,7739*,7741*,7744-7748*,7751-7754*,7758-7759*,7761-7762*
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
- /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/Makefile.am:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/Makefile.am:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/Makefile.am:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/Makefile.am:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/Makefile.am:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/Makefile.am:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/Makefile.am:5406
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
- /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/README:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/README:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/README:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/README:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/README:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/README:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/README:5406
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
- /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/autogen.sh:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/autogen.sh:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/autogen.sh:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/autogen.sh:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/autogen.sh:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/autogen.sh:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/autogen.sh:5406
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/configure.in:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/configure.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/configure.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/configure.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/configure.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/configure.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/configure.in:5406
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples
- /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/examples:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/examples:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/examples:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/examples:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/examples:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/examples:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/examples:5406
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/hydra-doxygen.cfg.in:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/hydra-doxygen.cfg.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/hydra-doxygen.cfg.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/hydra-doxygen.cfg.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/hydra-doxygen.cfg.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/hydra-doxygen.cfg.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/hydra-doxygen.cfg.in:5406
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include
- /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/include:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/include:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/include:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/include:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/include:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/include:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/include:5406
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
- /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/mpich2prereq:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/mpich2prereq:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/mpich2prereq:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/mpich2prereq:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/mpich2prereq:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/mpich2prereq:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/mpich2prereq:5406
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm
- /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/pm:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/pm:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/pm:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/pm:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/pm:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/pm:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/pm:5406
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.c
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.c 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -21,6 +21,7 @@
HYD_pmcd_pmip.system_global.global_core_count = -1;
HYD_pmcd_pmip.system_global.global_process_count = -1;
+ HYD_pmcd_pmip.system_global.jobid = NULL;
HYD_pmcd_pmip.system_global.pmi_port = NULL;
HYD_pmcd_pmip.system_global.pmi_fd = NULL;
HYD_pmcd_pmip.system_global.pmi_rank = -1;
@@ -62,6 +63,9 @@
HYDU_finalize_user_global(&HYD_pmcd_pmip.user_global);
/* System global */
+ if (HYD_pmcd_pmip.system_global.jobid)
+ HYDU_FREE(HYD_pmcd_pmip.system_global.jobid);
if (HYD_pmcd_pmip.system_global.pmi_fd)
HYDU_FREE(HYD_pmcd_pmip.system_global.pmi_fd);
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.h
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.h 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip.h 2011-01-20 00:00:15 UTC (rev 7763)
@@ -16,6 +16,7 @@
struct {
int global_core_count;
int global_process_count;
+ char *jobid;
/* PMI */
char *pmi_fd;
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_cb.c
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -603,6 +603,13 @@
HYDU_ERR_POP(status, "unable to add env to list\n");
+ /* Job ID information */
+ if (HYD_pmcd_pmip.system_global.jobid) {
+ status = HYDU_append_env_to_list("HYDRA_JOBID", HYD_pmcd_pmip.system_global.jobid,
+ &force_env);
+ HYDU_ERR_POP(status, "unable to add env to list\n");
/* Set the interface hostname based on what the user provided */
if (HYD_pmcd_pmip.local.interface_env_name) {
if (HYD_pmcd_pmip.user_global.iface) {
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_utils.c
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_utils.c 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmip_utils.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -468,6 +468,11 @@
HYDU_ERR_POP(status, "unable to query launcher for proxy ID\n");
+ if (HYD_pmcd_pmip.system_global.jobid == NULL) {
+ status = HYDT_bsci_query_jobid(&HYD_pmcd_pmip.system_global.jobid);
+ HYDU_ERR_POP(status, "unable to query launcher for job ID\n");
if (HYD_pmcd_pmip.local.id == -1)
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "proxy ID not available\n");
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools
- /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/tools:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/tools:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/tools:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/tools:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/tools:5406
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/Makefile.mk
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/Makefile.mk 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/Makefile.mk 2011-01-20 00:00:15 UTC (rev 7763)
@@ -9,6 +9,7 @@
$(top_srcdir)/tools/bootstrap/external/external_finalize.c \
$(top_srcdir)/tools/bootstrap/external/external_env.c \
$(top_srcdir)/tools/bootstrap/external/external_query_native_int.c \
+ $(top_srcdir)/tools/bootstrap/external/external_query_jobid.c \
$(top_srcdir)/tools/bootstrap/external/ssh.c \
$(top_srcdir)/tools/bootstrap/external/slurm_launch.c \
$(top_srcdir)/tools/bootstrap/external/slurm_query_node_list.c \
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external.h
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external.h 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external.h 2011-01-20 00:00:15 UTC (rev 7763)
@@ -19,5 +19,6 @@
HYD_status HYDT_bscd_external_launcher_finalize(void);
HYD_status HYDT_bscd_external_query_env_inherit(const char *env_name, int *ret);
HYD_status HYDT_bscd_external_query_native_int(int *ret);
+HYD_status HYDT_bscd_external_query_jobid(char **jobid);
#endif /* EXTERNAL_H_INCLUDED */
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_init.c
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_init.c 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_init.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -33,6 +33,9 @@
if (HYDT_bsci_fns.query_native_int == NULL)
HYDT_bsci_fns.query_native_int = HYDT_bscd_external_query_native_int;
+ if (HYDT_bsci_fns.query_jobid == NULL)
+ HYDT_bsci_fns.query_jobid = HYDT_bscd_external_query_jobid;
HYDU_FUNC_EXIT();
return status;
Copied: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_query_jobid.c (from rev 7762, mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_query_jobid.c)
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_query_jobid.c (rev 0)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/external_query_jobid.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -0,0 +1,34 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2008 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#include "hydra.h"
+#include "bsci.h"
+#include "external.h"
+ const char *tmp_jobid = NULL;
+ HYD_status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ if (!strcmp(HYDT_bsci_info.rmk, "pbs"))
+ MPL_env2str("PBS_JOBID", &tmp_jobid);
+ else if (!strcmp(HYDT_bsci_info.rmk, "slurm"))
+ MPL_env2str("SLURM_JOBID", &tmp_jobid);
+ if (tmp_jobid)
+ *jobid = HYDU_strdup(tmp_jobid);
+ else
+ *jobid = NULL;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
- /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/include/bsci.h.in
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/include/bsci.h.in 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/include/bsci.h.in 2011-01-20 00:00:15 UTC (rev 7763)
@@ -45,6 +45,9 @@
/** \brief Query for node list information */
HYD_status(*query_node_list) (struct HYD_node **node_list);
+ /** \brief Query for job ID information */
+ HYD_status(*query_jobid) (char **jobid);
/** \brief Finalize the RMK */
HYD_status(*rmk_finalize) (void);
@@ -151,6 +154,16 @@
+ * \brief HYDT_bsci_query_jobid - Query for Job ID information
+ * \param[out] jobid Job ID
+ * This function allows the upper layers to query the job ID.
+HYD_status HYDT_bsci_query_jobid(char **jobid);
* \brief HYDT_bsci_query_usize - Query for the universe size
* \param[out] size Maximum number of processes that can be launched
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/Makefile.mk
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/Makefile.mk 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/Makefile.mk 2011-01-20 00:00:15 UTC (rev 7763)
@@ -8,6 +8,7 @@
$(top_srcdir)/tools/bootstrap/src/bsci_finalize.c \
$(top_srcdir)/tools/bootstrap/src/bsci_launch.c \
$(top_srcdir)/tools/bootstrap/src/bsci_query_node_list.c \
+ $(top_srcdir)/tools/bootstrap/src/bsci_query_job_id.c \
$(top_srcdir)/tools/bootstrap/src/bsci_query_proxy_id.c \
$(top_srcdir)/tools/bootstrap/src/bsci_query_native_int.c \
$(top_srcdir)/tools/bootstrap/src/bsci_usize.c \
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in 2011-01-20 00:00:15 UTC (rev 7763)
@@ -20,6 +20,7 @@
HYDT_bsci_fns.query_native_int = NULL;
HYDT_bsci_fns.query_node_list = NULL;
+ HYDT_bsci_fns.query_jobid = NULL;
HYDT_bsci_fns.rmk_finalize = NULL;
@@ -39,6 +40,8 @@
HYDT_bsci_fns.query_native_int = HYDT_bscu_query_native_int;
if (HYDT_bsci_fns.query_node_list == NULL)
HYDT_bsci_fns.query_node_list = HYDT_bscu_query_node_list;
+ HYDT_bsci_fns.query_jobid = HYDT_bscu_query_jobid;
if (HYDT_bsci_fns.rmk_finalize == NULL)
HYDT_bsci_fns.rmk_finalize = HYDT_bscu_rmk_finalize;
Copied: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_job_id.c (from rev 7759, mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_job_id.c)
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_job_id.c (rev 0)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_job_id.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -0,0 +1,26 @@
+#include "hydra.h"
+#include "bsci.h"
+#include "bscu.h"
+ status = HYDT_bsci_fns.query_jobid(jobid);
+ HYDU_ERR_POP(status, "RMK returned error while querying job ID\n");
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
- /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/Makefile.mk
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/Makefile.mk 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/Makefile.mk 2011-01-20 00:00:15 UTC (rev 7763)
@@ -8,6 +8,7 @@
libhydra_la_SOURCES += $(top_srcdir)/tools/bootstrap/utils/bscu_finalize.c \
$(top_srcdir)/tools/bootstrap/utils/bscu_query_node_list.c \
+ $(top_srcdir)/tools/bootstrap/utils/bscu_query_job_id.c \
$(top_srcdir)/tools/bootstrap/utils/bscu_query_proxy_id.c \
$(top_srcdir)/tools/bootstrap/utils/bscu_query_native_int.c \
$(top_srcdir)/tools/bootstrap/utils/bscu_usize.c \
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu.h
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu.h 2011-01-19 23:58:08 UTC (rev 7762)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu.h 2011-01-20 00:00:15 UTC (rev 7763)
@@ -18,6 +18,7 @@
HYD_status HYDT_bscu_rmk_finalize(void);
HYD_status HYDT_bscu_launcher_finalize(void);
HYD_status HYDT_bscu_query_node_list(struct HYD_node **node_list);
+HYD_status HYDT_bscu_query_jobid(char **jobid);
HYD_status HYDT_bscu_query_usize(int *size);
HYD_status HYDT_bscu_query_proxy_id(int *proxy_id);
HYD_status HYDT_bscu_wait_for_completion(int timeout);
Copied: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_job_id.c (from rev 7759, mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_job_id.c)
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_job_id.c (rev 0)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_job_id.c 2011-01-20 00:00:15 UTC (rev 7763)
@@ -0,0 +1,22 @@
+#include "hydra.h"
+#include "bscu.h"
+ /* We don't know anything about job ID */
+ *jobid = NULL;
+ HYDU_FUNC_EXIT();
+ return status;
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
- /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui
- /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/ui:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/ui:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/ui:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/ui:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/ui:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/ui:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/ui:5406
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils
- /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/utils:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/utils:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/utils:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/utils:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/utils:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/utils:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/utils:5406
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
- /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/error-return/winconfigure.wsf:7662-7670
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754
+ /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762
More information about the mpich2-commits
