[mpich2-commits] r7734 - in mpich2/branches/release/mpich2-1.3.x: . confdb maint src/mpid src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src src/pm/hydra src/pm/hydra/examples src/pm/hydra/include src/pm/hydra/pm src/pm/hydra/tools src/pm/hydra/tools/bootstrap/external src/pm/hydra/tools/bootstrap/src src/pm/hydra/tools/bootstrap/utils src/pm/hydra/ui src/pm/hydra/utils
buntinas at mcs.anl.gov buntinas at mcs.anl.gov
Mon Jan 17 18:45:53 CST 2011
Author: buntinas
Date: 2011-01-17 18:45:53 -0600 (Mon, 17 Jan 2011)
New Revision: 7734
Modified:
   mpich2/branches/release/mpich2-1.3.x/
   mpich2/branches/release/mpich2-1.3.x/README.vin
   mpich2/branches/release/mpich2-1.3.x/confdb/
   mpich2/branches/release/mpich2-1.3.x/maint/Version
   mpich2/branches/release/mpich2-1.3.x/src/mpid/
   mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
   mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils/
   mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
merged r7733
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
   - /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/error-return:7662-7670
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt:5050
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Modified: mpich2/branches/release/mpich2-1.3.x/README.vin
--- mpich2/branches/release/mpich2-1.3.x/README.vin	2011-01-18 00:43:58 UTC (rev 7733)
+++ mpich2/branches/release/mpich2-1.3.x/README.vin	2011-01-18 00:45:53 UTC (rev 7734)
@@ -32,7 +32,7 @@
 4.  Alternate Process Managers
 5.  Alternate Configure Options
 6.  Testing the MPICH2 installation
-7.  Checkpoint/Restart
+7.  Fault Tolerance
 8.  Environment Variables
 9.  Developer Builds
 10. Installing MPICH2 on windows
@@ -735,13 +735,72 @@
+7. Fault Tolerance
+MPICH2 has some tolerance to process failures, and supports
+checkpointing and restart.
+Tolerance to Process Failures
+The features described in this section should be considered
+experimental.  Which means that they have not been fully tested, and
+the behavior may change in future releases.
+Communication failures in MPICH2 are not fatal errors.  This means
+that if the user sets the error handler to MPI_ERRORS_RETURN, MPICH2
+will return an appropriate error code in the event of a communication
+failure.  When a process detects a failure when communicating with
+another process, it will consider that other process as having failed
+and will no longer attempt to communicate with that process.  The user
+can, however, continue making communication calls to other processes.
+Any outstanding send or receive operations to a failed process, or
+wildcard receives (i.e., with MPI_ANY_SOURCE) posted to communicators
+with a failed process, will be immediately completed with an
+appropriate error code.
+Collectives performed on a communicator with a failed process will not
+hang, however, the results of the operation are undefined.  Some, but
+not necessarily all, processes may return an error.  Specifically,
+the collective on some process might not return an error, but the
+result may still be invalid.
+If used with the hydra process manager, hydra will detect failed
+processes and notify the MPICH2 library.  Users can query the list of
+failed processes using the MPICH_ATTR_FAILED_PROCESSES predefined
+attribute on MPI_COMM_WORLD.  The attribute value is an integer array
+containing the ranks of the failed processes.  The array is terminated
+by MPI_PROC_NULL.  The user needs to declare the following extern in
+order to use the attribute:
+    extern int MPICH_ATTR_FAILED_PROCESSES;
+Note that hydra by default will abort the entire application when any
+process terminates before calling MPI_Finalize.  In order to allow
+an application to continue running despite failed processes, you'll
+need to pass the -disable-auto-cleanup option to mpiexec.
+Unsupported feature: In the current implementation (version 1.3.2),
+hydra notifies the MPICH2 library of failed processes by sending a
+SIGUSR1 signal.  The application can catch this signal to be notified
+of failed processes.  If the application replaces the library's signal
+handler with its own, the application must be sure to call the
+library's handler from it's own handler.  The MPICH_ATTR_FAILED_
+PROCESSES attribute is not updated in the signal handler immediately,
+so the application must call a function like MPI_Iprobe() in order to
+allow the library to process the notification.  Note that you cannot
+call MPI function from inside a signal handler (which admittedly makes
+this difficult to use).  This feature may not be (probably won't be)
+supported in future releases, so portable applications should not use
+it.
+Checkpoint and Restart
 MPICH2 supports checkpointing and restart fault-tolerance using BLCR.
-Configuration
+CONFIGURATION
 First, you need to have BLCR version 0.8.2 or later installed on your
 machine.  If it's installed in the default system location, add the
 following two options to your configure command:
@@ -769,8 +828,8 @@
 Note, checkpointing is only supported with the Hydra process manager.
-Verifying Checkpointing Support
+VERIFYING CHECKPOINTING SUPPORT
 Make sure MPICH2 is correctly configured with BLCR. You can do this
 using:
@@ -779,8 +838,8 @@
 This should display 'BLCR' under 'Checkpointing libraries available'.
-Checkpointing the Application
+CHECKPOINTING THE APPLICATION
 There are two ways to cause the application to checkpoint. You can ask
 mpiexec to periodically checkpoint the application using the mpiexec
 option -ckpoint-interval (seconds):
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
   - /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/error-return/confdb:7662-7670
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
   - /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7447,7604,7671,7674,7683,7685,7687,7701-7702,7720,7722
   + /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid
   - /mpich2/branches/dev/ckpt/src/mpid:5050
/mpich2/branches/dev/ckpt2/src/mpid:5057-6537
/mpich2/branches/dev/error-return/src/mpid:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid:5661-5730
/mpich2/branches/dev/lapi/src/mpid:5817
/mpich2/branches/dev/wintcp_async_progress/src/mpid:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid:5406
/mpich2/trunk/src/mpid:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/mpid:5050
/mpich2/trunk/src/mpid:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
   - /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/error-return/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
   - /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/error-return/src/mpl/src/mplstr.c:7662-7670
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra
   - /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra:5406
/mpich2/trunk/src/pm/hydra:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671*,7674*,7676-7678,7681,7683*,7684,7685*,7686,7687*,7688,7690-7692,7694,7696,7700,7701-7702*,7705,7707-7710,7712,7714,7719,7720*,7722*,7724-7725*,7728-7729*
   + /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/trunk/src/pm/hydra:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671*,7674*,7676-7678,7681,7683*,7684,7685*,7686,7687*,7688,7690-7692,7694,7696,7700,7701-7702*,7705,7707-7710,7712,7714,7719,7720*,7722*,7724-7725*,7728-7729*,7733*
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
   - /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/Makefile.am:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/Makefile.am:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/Makefile.am:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/Makefile.am:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/Makefile.am:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/Makefile.am:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/Makefile.am:5406
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
   - /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/README:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/README:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/README:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/README:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/README:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/README:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/README:5406
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
   - /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/autogen.sh:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/autogen.sh:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/autogen.sh:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/autogen.sh:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/autogen.sh:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/autogen.sh:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/autogen.sh:5406
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
   - /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/configure.in:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/configure.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/configure.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/configure.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/configure.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/configure.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/configure.in:5406
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples
   - /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/examples:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/examples:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/examples:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/examples:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/examples:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/examples:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/examples:5406
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
   - /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/hydra-doxygen.cfg.in:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/hydra-doxygen.cfg.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/hydra-doxygen.cfg.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/hydra-doxygen.cfg.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/hydra-doxygen.cfg.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/hydra-doxygen.cfg.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/hydra-doxygen.cfg.in:5406
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include
   - /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/include:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/include:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/include:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/include:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/include:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/include:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/include:5406
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
   - /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/mpich2prereq:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/mpich2prereq:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/mpich2prereq:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/mpich2prereq:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/mpich2prereq:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/mpich2prereq:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/mpich2prereq:5406
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm
   - /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/pm:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/pm:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/pm:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/pm:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/pm:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/pm:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/pm:5406
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools
   - /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/tools:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/tools:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/tools:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/tools:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/tools:5406
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
   - /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
   - /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
   - /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7662-7670
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui
   - /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/ui:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/ui:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/ui:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/ui:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/ui:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/ui:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/ui:5406
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils
   - /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/utils:5057-6537
/mpich2/branches/dev/error-return/src/pm/hydra/utils:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/utils:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/utils:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/utils:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/utils:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/utils:5406
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
   - /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/error-return/winconfigure.wsf:7662-7670
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729
   + /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733
More information about the mpich2-commits mailing list
