[mpich2-commits] r7733 - mpich2/trunk
buntinas at mcs.anl.gov buntinas at mcs.anl.gov
Mon Jan 17 18:43:58 CST 2011
Author: buntinas
Date: 2011-01-17 18:43:58 -0600 (Mon, 17 Jan 2011)
New Revision: 7733
Modified:
   mpich2/trunk/README.vin
Log:
Added documentation on fault tolerance features in README.  This should resolve ticket #1142
Modified: mpich2/trunk/README.vin
--- mpich2/trunk/README.vin	2011-01-14 23:10:43 UTC (rev 7732)
+++ mpich2/trunk/README.vin	2011-01-18 00:43:58 UTC (rev 7733)
@@ -32,7 +32,7 @@
 4.  Alternate Process Managers
 5.  Alternate Configure Options
 6.  Testing the MPICH2 installation
-7.  Checkpoint/Restart
+7.  Fault Tolerance
 8.  Environment Variables
 9.  Developer Builds
 10. Installing MPICH2 on windows
@@ -735,13 +735,72 @@
+7. Fault Tolerance
+MPICH2 has some tolerance to process failures, and supports
+checkpointing and restart.
+Tolerance to Process Failures
+The features described in this section should be considered
+experimental.  Which means that they have not been fully tested, and
+the behavior may change in future releases.
+Communication failures in MPICH2 are not fatal errors.  This means
+that if the user sets the error handler to MPI_ERRORS_RETURN, MPICH2
+will return an appropriate error code in the event of a communication
+failure.  When a process detects a failure when communicating with
+another process, it will consider that other process as having failed
+and will no longer attempt to communicate with that process.  The user
+can, however, continue making communication calls to other processes.
+Any outstanding send or receive operations to a failed process, or
+wildcard receives (i.e., with MPI_ANY_SOURCE) posted to communicators
+with a failed process, will be immediately completed with an
+appropriate error code.
+Collectives performed on a communicator with a failed process will not
+hang, however, the results of the operation are undefined.  Some, but
+not necessarily all, processes may return an error.  Specifically,
+the collective on some process might not return an error, but the
+result may still be invalid.
+If used with the hydra process manager, hydra will detect failed
+processes and notify the MPICH2 library.  Users can query the list of
+failed processes using the MPICH_ATTR_FAILED_PROCESSES predefined
+attribute on MPI_COMM_WORLD.  The attribute value is an integer array
+containing the ranks of the failed processes.  The array is terminated
+by MPI_PROC_NULL.  The user needs to declare the following extern in
+order to use the attribute:
+    extern int MPICH_ATTR_FAILED_PROCESSES;
+Note that hydra by default will abort the entire application when any
+process terminates before calling MPI_Finalize.  In order to allow
+an application to continue running despite failed processes, you'll
+need to pass the -disable-auto-cleanup option to mpiexec.
+Unsupported feature: In the current implementation (version 1.3.2),
+hydra notifies the MPICH2 library of failed processes by sending a
+SIGUSR1 signal.  The application can catch this signal to be notified
+of failed processes.  If the application replaces the library's signal
+handler with its own, the application must be sure to call the
+library's handler from it's own handler.  The MPICH_ATTR_FAILED_
+PROCESSES attribute is not updated in the signal handler immediately,
+so the application must call a function like MPI_Iprobe() in order to
+allow the library to process the notification.  Note that you cannot
+call MPI function from inside a signal handler (which admittedly makes
+this difficult to use).  This feature may not be (probably won't be)
+supported in future releases, so portable applications should not use
+it.
+Checkpoint and Restart
 MPICH2 supports checkpointing and restart fault-tolerance using BLCR.
-Configuration
+CONFIGURATION
 First, you need to have BLCR version 0.8.2 or later installed on your
 machine.  If it's installed in the default system location, add the
 following two options to your configure command:
@@ -769,8 +828,8 @@
 Note, checkpointing is only supported with the Hydra process manager.
-Verifying Checkpointing Support
+VERIFYING CHECKPOINTING SUPPORT
 Make sure MPICH2 is correctly configured with BLCR. You can do this
 using:
@@ -779,8 +838,8 @@
 This should display 'BLCR' under 'Checkpointing libraries available'.
-Checkpointing the Application
+CHECKPOINTING THE APPLICATION
 There are two ways to cause the application to checkpoint. You can ask
 mpiexec to periodically checkpoint the application using the mpiexec
 option -ckpoint-interval (seconds):
More information about the mpich2-commits mailing list
