[mpich2-commits] r7654 - in mpich2/trunk/src/pm/hydra/ui: include mpich utils
balaji at mcs.anl.gov
Mon Jan 3 07:05:20 CST 2011
Author: balaji
Date: 2011-01-03 07:05:20 -0600 (Mon, 03 Jan 2011)
New Revision: 7654
Modified:
mpich2/trunk/src/pm/hydra/ui/include/ui.h
mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
Log:
Allow users to redirect stdout/stderr to separate files. Fixes ticket
#1131.
Modified: mpich2/trunk/src/pm/hydra/ui/include/ui.h
--- mpich2/trunk/src/pm/hydra/ui/include/ui.h 2011-01-03 13:04:35 UTC (rev 7653)
+++ mpich2/trunk/src/pm/hydra/ui/include/ui.h 2011-01-03 13:05:20 UTC (rev 7654)
@@ -9,6 +9,8 @@
struct HYD_ui_info {
char *prepend_regex;
+ char *outfile_regex;
+ char *errfile_regex;
extern struct HYD_ui_info HYD_ui_info;
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2011-01-03 13:04:35 UTC (rev 7653)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2011-01-03 13:05:20 UTC (rev 7654)
@@ -109,7 +109,9 @@
printf(" -ppn processes per node\n");
printf(" -profile turn on internal profiling\n");
printf(" -prepend-rank prepend rank to output\n");
- printf(" -prepend-regex prepend regex to output\n");
+ printf(" -prepend-regex prepend regex to output\n");
+ printf(" -outfile-regex direct stdout to file\n");
+ printf(" -errfile-regex direct stderr to file\n");
printf
(" -nameserver name server information (host:port format)\n");
printf(" -disable-auto-cleanup don't cleanup processes on error\n");
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-01-03 13:04:35 UTC (rev 7653)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-01-03 13:05:20 UTC (rev 7654)
@@ -280,19 +280,24 @@
static HYD_status prepend_rank_fn(char *arg, char ***argv)
- return HYDU_set_str(arg, argv, &HYD_ui_info.prepend_regex, "[%r]");
+ return HYDU_set_str(arg, argv, &HYD_ui_info.prepend_regex, "[%r] ");
-static void prepend_regex_help_fn(void)
+static void regex_info(void)
- printf("\n");
- printf("-prepend-regex: Prepend this regular expression to stdout and stderr\n");
printf(" Regular expressions can include:\n");
printf(" %%r: Process rank\n");
printf(" %%g: Process group ID\n");
printf(" %%p: Proxy ID\n");
printf(" %%h: Hostname\n");
+static void prepend_regex_help_fn(void)
printf("\n");
+ printf("-prepend-regex: Prepend this regular expression to stdout and stderr\n");
+ regex_info();
+ printf("\n");
static HYD_status prepend_regex_fn(char *arg, char ***argv)
@@ -300,6 +305,30 @@
return HYDU_set_str_and_incr(arg, argv, &HYD_ui_info.prepend_regex);
+static void outfile_regex_help_fn(void)
+ printf("\n");
+ printf("-outfile-regex: Send stdout to this file\n\n");
+ regex_info();
+static HYD_status outfile_regex_fn(char *arg, char ***argv)
+ return HYDU_set_str_and_incr(arg, argv, &HYD_ui_info.outfile_regex);
+static void errfile_regex_help_fn(void)
+ printf("\n");
+ printf("-errfile-regex: Send stderr to this file\n\n");
+ regex_info();
+static HYD_status errfile_regex_fn(char *arg, char ***argv)
+ return HYDU_set_str_and_incr(arg, argv, &HYD_ui_info.errfile_regex);
static void wdir_help_fn(void)
printf("\n");
@@ -933,6 +962,8 @@
{"prepend-rank", prepend_rank_fn, prepend_rank_help_fn},
{"l", prepend_rank_fn, prepend_rank_help_fn},
{"prepend-regex", prepend_regex_fn, prepend_regex_help_fn},
+ {"outfile-regex", outfile_regex_fn, outfile_regex_help_fn},
+ {"errfile-regex", errfile_regex_fn, errfile_regex_help_fn},
{"wdir", wdir_fn, wdir_help_fn},
{"configfile", config_fn, config_help_fn},
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c 2011-01-03 13:04:35 UTC (rev 7653)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c 2011-01-03 13:05:20 UTC (rev 7654)
@@ -9,6 +9,12 @@
#include "ui.h"
#include "uiu.h"
+static struct stdoe_fd {
+ int fd;
+ char *regex;
+ struct stdoe_fd *next;
+} *stdoe_fd_list = NULL;
void HYD_uiu_init_params(void)
HYDU_init_user_global(&HYD_server_info.user_global);
@@ -38,10 +44,16 @@
#endif /* ENABLE_PROFILING */
HYD_ui_info.prepend_regex = NULL;
+ HYD_ui_info.outfile_regex = NULL;
+ HYD_ui_info.errfile_regex = NULL;
+ stdoe_fd_list = NULL;
void HYD_uiu_free_params(void)
+ struct stdoe_fd *tmp, *run;
HYDU_finalize_user_global(&HYD_server_info.user_global);
if (HYD_server_info.base_path)
@@ -71,6 +83,19 @@
if (HYD_ui_info.prepend_regex)
HYDU_FREE(HYD_ui_info.prepend_regex);
+ if (HYD_ui_info.outfile_regex)
+ HYDU_FREE(HYD_ui_info.outfile_regex);
+ if (HYD_ui_info.errfile_regex)
+ HYDU_FREE(HYD_ui_info.errfile_regex);
+ for (run = stdoe_fd_list; run;) {
+ close(run->fd);
+ tmp = run->next;
+ HYDU_FREE(run);
+ run = tmp;
/* Re-initialize everything to default values */
HYD_uiu_init_params();
@@ -146,12 +171,11 @@
return;
-static HYD_status stdoe_cb(int fd, int pgid, int proxy_id, int rank, void *_buf, int buflen)
+static HYD_status resolve_regex_string(const char *regex, char **str, int pgid, int proxy_id,
+ int rank)
- int sent, closed, mark, i, offset;
- char *buf = (char *) _buf;
- char *prepend, *tprepend;
- char *s_rank, *s_pgid, *s_proxy_id, *s_host, *s;
+ int offset, i;
+ char *tstr, *s_rank, *s_pgid, *s_proxy_id, *s_host, *s;
struct HYD_pg *pg;
struct HYD_proxy *proxy;
char *tmp[HYD_NUM_TMP_STRINGS];
@@ -159,88 +183,139 @@
HYDU_FUNC_ENTER();
- if (HYD_ui_info.prepend_regex == NULL) {
- status = HYDU_sock_write(fd, buf, buflen, &sent, &closed);
- HYDU_ERR_POP(status, "unable to write data to stdout/stderr\n");
- HYDU_ASSERT(!closed, status);
- else {
- tprepend = prepend = HYDU_strdup(HYD_ui_info.prepend_regex);
+ tstr = *str = HYDU_strdup(regex);
- offset = 0;
- i = 0;
- do {
- s_rank = strstr(prepend, "%r");
- s_pgid = strstr(prepend, "%g");
- s_proxy_id = strstr(prepend, "%p");
- s_host = strstr(prepend, "%h");
+ offset = 0;
+ i = 0;
+ do {
+ s_rank = strstr(*str, "%r");
+ s_pgid = strstr(*str, "%g");
+ s_proxy_id = strstr(*str, "%p");
+ s_host = strstr(*str, "%h");
- s = s_rank;
- if (s == NULL || (s_pgid && s_pgid < s))
- s = s_pgid;
- if (s == NULL || (s_proxy_id && s_proxy_id < s))
- s = s_proxy_id;
- if (s == NULL || (s_host && s_host < s))
- s = s_host;
+ s = s_rank;
+ if (s == NULL || (s_pgid && s_pgid < s))
+ s = s_pgid;
+ if (s == NULL || (s_proxy_id && s_proxy_id < s))
+ s = s_proxy_id;
+ if (s == NULL || (s_host && s_host < s))
+ s = s_host;
- if (s)
- *s = 0;
+ if (s)
+ *s = 0;
- tmp[i++] = HYDU_strdup(prepend);
+ tmp[i++] = HYDU_strdup(*str);
- if (s) {
- if (s[1] == 'r') {
- HYDU_MALLOC(tmp[i], char *, HYD_TMP_STRLEN, status);
- MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", rank);
- else if (s[1] == 'g') {
- MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", pgid);
- else if (s[1] == 'p') {
- MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", proxy_id);
- else if (s[1] == 'h') {
- for (pg = &HYD_server_info.pg_list; pg; pg = pg->next)
- if (pg->pgid == pgid)
- break;
- HYDU_ASSERT(pg, status);
+ if (s) {
+ if (s[1] == 'r') {
+ HYDU_MALLOC(tmp[i], char *, HYD_TMP_STRLEN, status);
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", rank);
+ else if (s[1] == 'g') {
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", pgid);
+ else if (s[1] == 'p') {
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", proxy_id);
+ else if (s[1] == 'h') {
+ for (pg = &HYD_server_info.pg_list; pg; pg = pg->next)
+ if (pg->pgid == pgid)
+ break;
+ HYDU_ASSERT(pg, status);
- for (proxy = pg->proxy_list; proxy; proxy = proxy->next)
- if (proxy->proxy_id == proxy_id)
- break;
- HYDU_ASSERT(proxy, status);
+ for (proxy = pg->proxy_list; proxy; proxy = proxy->next)
+ if (proxy->proxy_id == proxy_id)
+ break;
+ HYDU_ASSERT(proxy, status);
- MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%s", proxy->node.hostname);
- else {
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR,
- "unrecognized prepend regex\n");
- i++;
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%s", proxy->node.hostname);
+ else {
+ HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "unrecognized regex\n");
+ i++;
- prepend = s + 2;
+ *str = s + 2;
+ else
+ *str = NULL;
+ } while (*str);
+ tmp[i++] = NULL;
+ status = HYDU_str_alloc_and_join(tmp, str);
+ HYDU_ERR_POP(status, "unable to join strings\n");
+ HYDU_free_strlist(tmp);
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
+static HYD_status stdoe_cb(int _fd, int pgid, int proxy_id, int rank, void *_buf, int buflen)
+ int fd = _fd;
+ char *regex_resolve, *regex = NULL;
+ int sent, closed, mark, i;
+ char *buf = (char *) _buf, *prepend;
+ HYD_status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ regex = (_fd == STDOUT_FILENO) ? HYD_ui_info.outfile_regex :
+ (_fd == STDERR_FILENO) ? HYD_ui_info.errfile_regex : NULL;
+ if (regex) {
+ /* See if the regex already exists */
+ status = resolve_regex_string(regex, ®ex_resolve, pgid, proxy_id, rank);
+ for (run = stdoe_fd_list; run; run = run->next)
+ if (!strcmp(run->regex, regex_resolve))
+ break;
+ if (run) {
+ fd = run->fd;
+ HYDU_FREE(regex_resolve);
+ else {
+ HYDU_MALLOC(tmp, struct stdoe_fd *, sizeof(struct stdoe_fd), status);
+ tmp->regex = regex_resolve;
+ tmp->fd = open(tmp->regex, O_RDWR | O_CREAT, S_IRUSR | S_IWUSR);
+ HYDU_ASSERT(tmp->fd >= 0, status);
+ tmp->next = NULL;
+ if (stdoe_fd_list == NULL)
+ stdoe_fd_list = tmp;
+ else {
+ for (run = stdoe_fd_list; run->next; run = run->next);
+ run->next = tmp;
- else
- prepend = NULL;
- } while (prepend);
- tmp[i++] = NULL;
- status = HYDU_str_alloc_and_join(tmp, &prepend);
- HYDU_ERR_POP(status, "unable to join strings\n");
- HYDU_free_strlist(tmp);
+ fd = tmp->fd;
+ if (HYD_ui_info.prepend_regex == NULL) {
+ status = HYDU_sock_write(fd, buf, buflen, &sent, &closed);
+ HYDU_ERR_POP(status, "unable to write data to stdout/stderr\n");
+ HYDU_ASSERT(!closed, status);
+ else {
+ status = resolve_regex_string(HYD_ui_info.prepend_regex, &prepend, pgid, proxy_id,
+ rank);
+ HYDU_ERR_POP(status, "error resolving regex\n");
mark = 0;
for (i = 0; i < buflen; i++) {
if (buf[i] == '\n' || i == buflen - 1) {
- if (fd == STDOUT_FILENO) {
- HYDU_dump_noprefix(stdout, "%s ", prepend);
- else if (fd == STDERR_FILENO) {
- HYDU_dump_noprefix(stderr, "%s ", prepend);
+ status = HYDU_sock_write(fd, (const void *) prepend, strlen(prepend), &sent,
+ &closed);
status = HYDU_sock_write(fd, (const void *) &buf[mark], i - mark + 1,
&sent, &closed);
@@ -249,7 +324,7 @@
- HYDU_FREE(tprepend);
+ HYDU_FREE(prepend);
fn_exit:
More information about the mpich2-commits
