[mpich2-commits] r7653 - in mpich2/trunk/src/pm/hydra/ui: include mpich utils
balaji at mcs.anl.gov
Mon Jan 3 07:04:35 CST 2011
Author: balaji
Date: 2011-01-03 07:04:35 -0600 (Mon, 03 Jan 2011)
New Revision: 7653
Modified:
mpich2/trunk/src/pm/hydra/ui/include/ui.h
mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
Log:
Generalize the management of 'prepend regex'. Allow a regular
expression to be prepended to the output. -prepend-rank is a subset of
this generalized capability.
Modified: mpich2/trunk/src/pm/hydra/ui/include/ui.h
--- mpich2/trunk/src/pm/hydra/ui/include/ui.h 2011-01-03 13:03:34 UTC (rev 7652)
+++ mpich2/trunk/src/pm/hydra/ui/include/ui.h 2011-01-03 13:04:35 UTC (rev 7653)
@@ -8,7 +8,7 @@
#define UI_H_INCLUDED
struct HYD_ui_info {
- int prepend_rank;
+ char *prepend_regex;
extern struct HYD_ui_info HYD_ui_info;
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2011-01-03 13:03:34 UTC (rev 7652)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2011-01-03 13:04:35 UTC (rev 7653)
@@ -109,6 +109,7 @@
printf(" -ppn processes per node\n");
printf(" -profile turn on internal profiling\n");
printf(" -prepend-rank prepend rank to output\n");
+ printf(" -prepend-regex prepend regex to output\n");
printf
(" -nameserver name server information (host:port format)\n");
printf(" -disable-auto-cleanup don't cleanup processes on error\n");
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-01-03 13:03:34 UTC (rev 7652)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-01-03 13:04:35 UTC (rev 7653)
@@ -280,9 +280,26 @@
static HYD_status prepend_rank_fn(char *arg, char ***argv)
- return HYDU_set_int(arg, argv, &HYD_ui_info.prepend_rank, 1);
+ return HYDU_set_str(arg, argv, &HYD_ui_info.prepend_regex, "[%r]");
+static void prepend_regex_help_fn(void)
+ printf("\n");
+ printf("-prepend-regex: Prepend this regular expression to stdout and stderr\n");
+ printf(" Regular expressions can include:\n");
+ printf(" %%r: Process rank\n");
+ printf(" %%g: Process group ID\n");
+ printf(" %%p: Proxy ID\n");
+ printf(" %%h: Hostname\n");
+ printf("\n");
+static HYD_status prepend_regex_fn(char *arg, char ***argv)
+ return HYDU_set_str_and_incr(arg, argv, &HYD_ui_info.prepend_regex);
static void wdir_help_fn(void)
printf("\n");
@@ -915,6 +932,7 @@
{"profile", profile_fn, profile_help_fn},
{"prepend-rank", prepend_rank_fn, prepend_rank_help_fn},
{"l", prepend_rank_fn, prepend_rank_help_fn},
+ {"prepend-regex", prepend_regex_fn, prepend_regex_help_fn},
{"wdir", wdir_fn, wdir_help_fn},
{"configfile", config_fn, config_help_fn},
@@ -1000,9 +1018,6 @@
if (HYD_ui_mpich_info.ranks_per_proc == -1)
HYD_ui_mpich_info.ranks_per_proc = 1;
- if (HYD_ui_info.prepend_rank == -1)
- HYD_ui_info.prepend_rank = 0;
if (HYD_server_info.enable_profiling == -1)
HYD_server_info.enable_profiling = 0;
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c 2011-01-03 13:03:34 UTC (rev 7652)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c 2011-01-03 13:04:35 UTC (rev 7653)
@@ -37,7 +37,7 @@
HYD_server_info.num_pmi_calls = 0;
#endif /* ENABLE_PROFILING */
- HYD_ui_info.prepend_rank = -1;
+ HYD_ui_info.prepend_regex = NULL;
void HYD_uiu_free_params(void)
@@ -68,6 +68,9 @@
if (HYD_server_info.pg_list.next)
HYDU_free_pg_list(HYD_server_info.pg_list.next);
+ if (HYD_ui_info.prepend_regex)
+ HYDU_FREE(HYD_ui_info.prepend_regex);
/* Re-initialize everything to default values */
HYD_uiu_init_params();
@@ -143,66 +146,110 @@
return;
-HYD_status HYD_uiu_stdout_cb(int pgid, int proxy_id, int rank, void *_buf, int buflen)
+static HYD_status stdoe_cb(int fd, int pgid, int proxy_id, int rank, void *_buf, int buflen)
- int sent, closed, mark, i;
+ int sent, closed, mark, i, offset;
char *buf = (char *) _buf;
+ char *prepend, *tprepend;
+ char *s_rank, *s_pgid, *s_proxy_id, *s_host, *s;
+ struct HYD_pg *pg;
+ struct HYD_proxy *proxy;
+ char *tmp[HYD_NUM_TMP_STRINGS];
HYD_status status = HYD_SUCCESS;
HYDU_FUNC_ENTER();
- if (HYD_ui_info.prepend_rank == 0) {
- status = HYDU_sock_write(STDOUT_FILENO, buf, buflen, &sent, &closed);
- HYDU_ERR_POP(status, "unable to write data to stdout\n");
+ if (HYD_ui_info.prepend_regex == NULL) {
+ status = HYDU_sock_write(fd, buf, buflen, &sent, &closed);
+ HYDU_ERR_POP(status, "unable to write data to stdout/stderr\n");
HYDU_ASSERT(!closed, status);
else {
- mark = 0;
- for (i = 0; i < buflen; i++) {
- if (buf[i] == '\n' || i == buflen - 1) {
- HYDU_dump_noprefix(stdout, "[%d] ", rank);
- status = HYDU_sock_write(STDOUT_FILENO, (const void *) &buf[mark],
- i - mark + 1, &sent, &closed);
- HYDU_ASSERT(!closed, status);
- mark = i + 1;
+ tprepend = prepend = HYDU_strdup(HYD_ui_info.prepend_regex);
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
+ offset = 0;
+ i = 0;
+ do {
+ s_rank = strstr(prepend, "%r");
+ s_pgid = strstr(prepend, "%g");
+ s_proxy_id = strstr(prepend, "%p");
+ s_host = strstr(prepend, "%h");
- fn_fail:
- goto fn_exit;
+ s = s_rank;
+ if (s == NULL || (s_pgid && s_pgid < s))
+ s = s_pgid;
+ if (s == NULL || (s_proxy_id && s_proxy_id < s))
+ s = s_proxy_id;
+ if (s == NULL || (s_host && s_host < s))
+ s = s_host;
-HYD_status HYD_uiu_stderr_cb(int pgid, int proxy_id, int rank, void *_buf, int buflen)
- char *buf = (char *) _buf;
- HYD_status status = HYD_SUCCESS;
+ if (s)
+ *s = 0;
- HYDU_FUNC_ENTER();
+ tmp[i++] = HYDU_strdup(prepend);
- status = HYDU_sock_write(STDERR_FILENO, buf, buflen, &sent, &closed);
- HYDU_ERR_POP(status, "unable to write data to stderr\n");
- else {
+ if (s) {
+ if (s[1] == 'r') {
+ HYDU_MALLOC(tmp[i], char *, HYD_TMP_STRLEN, status);
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", rank);
+ else if (s[1] == 'g') {
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", pgid);
+ else if (s[1] == 'p') {
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", proxy_id);
+ else if (s[1] == 'h') {
+ for (pg = &HYD_server_info.pg_list; pg; pg = pg->next)
+ if (pg->pgid == pgid)
+ break;
+ HYDU_ASSERT(pg, status);
+ for (proxy = pg->proxy_list; proxy; proxy = proxy->next)
+ if (proxy->proxy_id == proxy_id)
+ break;
+ HYDU_ASSERT(proxy, status);
+ MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%s", proxy->node.hostname);
+ else {
+ HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR,
+ "unrecognized prepend regex\n");
+ i++;
+ prepend = s + 2;
+ else
+ prepend = NULL;
+ } while (prepend);
+ tmp[i++] = NULL;
+ status = HYDU_str_alloc_and_join(tmp, &prepend);
+ HYDU_ERR_POP(status, "unable to join strings\n");
+ HYDU_free_strlist(tmp);
mark = 0;
- HYDU_dump_noprefix(stderr, "[%d] ", rank);
- status = HYDU_sock_write(STDERR_FILENO, (const void *) &buf[mark],
+ if (fd == STDOUT_FILENO) {
+ HYDU_dump_noprefix(stdout, "%s ", prepend);
+ else if (fd == STDERR_FILENO) {
+ HYDU_dump_noprefix(stderr, "%s ", prepend);
+ status = HYDU_sock_write(fd, (const void *) &buf[mark], i - mark + 1,
+ &sent, &closed);
mark = i + 1;
+ HYDU_FREE(tprepend);
fn_exit:
@@ -212,3 +259,13 @@
fn_fail:
goto fn_exit;
+HYD_status HYD_uiu_stdout_cb(int pgid, int proxy_id, int rank, void *buf, int buflen)
+ return stdoe_cb(STDOUT_FILENO, pgid, proxy_id, rank, buf, buflen);
+HYD_status HYD_uiu_stderr_cb(int pgid, int proxy_id, int rank, void *buf, int buflen)
+ return stdoe_cb(STDERR_FILENO, pgid, proxy_id, rank, buf, buflen);
More information about the mpich2-commits
