[mpich2-commits] r8045 - in mpich2/branches/release/mpich2-1.3.x: . confdb maint src/mpid src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src src/pm/hydra src/pm/hydra/examples src/pm/hydra/include src/pm/hydra/pm src/pm/hydra/tools src/pm/hydra/tools/bootstrap/external src/pm/hydra/tools/bootstrap/src src/pm/hydra/ui src/pm/hydra/utils
balaji at mcs.anl.gov
Thu Feb 24 17:24:32 CST 2011
Author: balaji
Date: 2011-02-24 17:24:32 -0600 (Thu, 24 Feb 2011)
New Revision: 8045
Modified:
mpich2/branches/release/mpich2-1.3.x/
mpich2/branches/release/mpich2-1.3.x/CHANGES
mpich2/branches/release/mpich2-1.3.x/confdb/
mpich2/branches/release/mpich2-1.3.x/maint/Version
mpich2/branches/release/mpich2-1.3.x/src/mpid/
mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils/
mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
Merging r8044 from trunk
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
- /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/coll-err-ret:7771-7802
/mpich2/branches/dev/error-return:7662-7670
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8
016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040
/mpich2/trunk/test/mpi/rma:7960
+ /mpich2/branches/dev/ckpt:5050
016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040,8044
Modified: mpich2/branches/release/mpich2-1.3.x/CHANGES
--- mpich2/branches/release/mpich2-1.3.x/CHANGES 2011-02-24 23:23:56 UTC (rev 8044)
+++ mpich2/branches/release/mpich2-1.3.x/CHANGES 2011-02-24 23:24:32 UTC (rev 8045)
@@ -1,4 +1,63 @@
+ Changes in 1.3.3
+ # OVERALL: Improvements to fault tolerance for collective
+ operations. Thanks to Rui Wang @ ICT for reporting several of these
+ issues.
+ # OVERALL: Improvements to the universe size detection. Thanks to
+ Yauheni Zelenko for reporting this issue.
+ # OVERALL: Bug fixes for Fortran attributes on some systems. Thanks
+ to Nicolai Stange for reporting this issue.
+ # PM/PMI: Support for a manual "none" launcher in Hydra to allow for
+ higher-level tools to be built on top of Hydra. Thanks to Justin
+ Wozniak for reporting this issue, for providing several patches for
+ the fix, and testing it.
+ # PM/PMI: Bug fixes in Hydra to handle non-uniform layouts of hosts
+ better. Thanks to the MVAPICH group at OSU for reporting this issue
+ and testing it.
+ # PM/PMI: Bug fixes in Hydra to handle cases where only a subset of
+ the available launchers or resource managers are compiled
+ in. Thanks to Satish Balay @ Argonne for reporting this issue.
+ # PM/PMI: Support for a different username to be provided for each
+ host; this only works for launchers that support this (such as
+ SSH).
+ # PM/PMI: Bug fixes for using Hydra on AIX machines. Thanks to
+ Kitrick Sheets @ NCSA for reporting this issue and providing the
+ first draft of the patch.
+ # PM/PMI: Bug fixes in memory allocation/management for environment
+ variables that was showing up on older platforms. Thanks to Steven
+ Sutphen for reporting the issue and providing detailed analysis to
+ track down the bug.
+ # PM/PMI: Added support for providing a configuration file to pick
+ the default options for Hydra. Thanks to Saurabh T. for reporting
+ the issues with the current implementation and working with us to
+ improve this option.
+ # PM/PMI: Improvements to the error code returned by Hydra.
+ # TEST SUITE: Several new tests for MPI RMA operations.
+ # Several other minor bug fixes, memory leak fixes, and code cleanup.
+ A full list of changes is available using:
+ svn log -r7838:HEAD https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.3.3rc1
+ ... or at the following link:
+ https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.3.3rc1?action=follow_copy&rev=HEAD&stop_rev=7838&mode=follow_copy
Changes in 1.3.2
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
- /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/coll-err-ret/confdb:7771-7802
/mpich2/branches/dev/error-return/confdb:7662-7670
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010
-8012,8016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040
+ /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
-8012,8016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040,8044
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
- /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/coll-err-ret/maint/Version:7771-7802
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7447,7604,7671,7674,7683,7685,7687,7701-7702,7720,7722
+ /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7676-7678,7681,7684,7686,7688,7690-7692,7694,7696,7700,7705,7707-7710,7712,7714,7719,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-8024,8026,8028,8030-8031,8033,8038,8040,8044
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid
- /mpich2/branches/dev/ckpt/src/mpid:5050
/mpich2/branches/dev/ckpt2/src/mpid:5057-6537
/mpich2/branches/dev/coll-err-ret/src/mpid:7771-7802
/mpich2/branches/dev/error-return/src/mpid:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid:5661-5730
/mpich2/branches/dev/lapi/src/mpid:5817
/mpich2/branches/dev/wintcp_async_progress/src/mpid:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid:5406
/mpich2/trunk/src/mpid:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-80
+ /mpich2/branches/dev/ckpt/src/mpid:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
- /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/coll-err-ret/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7771-7802
/mpich2/branches/dev/error-return/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7405-7603,7662-7670
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,
+ /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
- /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/coll-err-ret/src/mpl/src/mplstr.c:7771-7802
/mpich2/branches/dev/error-return/src/mpl/src/mplstr.c:7662-7670
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,
+ /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra
- /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra:7771-7802*
/mpich2/branches/dev/error-return/src/pm/hydra:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra:5406
/mpich2/trunk/src/pm/hydra:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671*,7674*,7676-7678,7681,7683*,7684,7685*,7686,7687*,7688,7690-7692,7694,7696,7700,7701-7702*,7705,7707-7710,7712,7714,7719,7720*,7722*,7724-7725*,7728-7729*,7733*,7735-7737*,7739*,7741*,7744-7748*,7751-7754*,7758-7759*,7761-7762*,7766*,7772*,7774*,7779-7781*,7788*,7793*,7799-7801*,7803*,7807-7808*,7811*,7813*,7815-7816*,7819*,7821*,7829-7831*,7833*,7835-7837*,7839-7843*,7852*,7858*,7860*,7862*,7866*,7872-7874*,7879-7880*,7882*,7884*,7886-7888*,7890*,7895*,7897*,7899*,7903-7904*,7906*,7908*,7910*,7912*,7931-7932*,7937-7944*,7946*,7953-7954*,7956-7957*,7960*,7968*,7971*,
7975*,7979*,7981*,7988*,7991-7992*,7994*,7996*,8001*,8003*,8005-8008*,8010-8012*,8016*,8018-8019*,8021*,8023-8024*,8026*,8028*,8030-8031*,8033*,8038*,8040*
+ /mpich2/branches/dev/ckpt/src/pm/hydra:5050
7975*,7979*,7981*,7988*,7991-7992*,7994*,7996*,8001*,8003*,8005-8008*,8010-8012*,8016*,8018-8019*,8021*,8023-8024*,8026*,8028*,8030-8031*,8033*,8038*,8040*,8044*
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
- /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/Makefile.am:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/Makefile.am:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/Makefile.am:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/Makefile.am:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/Makefile.am:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/Makefile.am:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/Makefile.am:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/Makefile.am:5406
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8
+ /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
- /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/README:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/README:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/README:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/README:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/README:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/README:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/README:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/README:5406
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-8
+ /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
- /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/autogen.sh:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/autogen.sh:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/autogen.sh:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/autogen.sh:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/autogen.sh:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/autogen.sh:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/autogen.sh:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/autogen.sh:5406
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,80
+ /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/configure.in:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/configure.in:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/configure.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/configure.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/configure.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/configure.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/configure.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/configure.in:5406
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,
+ /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples
- /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/examples:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/examples:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/examples:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/examples:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/examples:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/examples:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/examples:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/examples:5406
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023
+ /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/hydra-doxygen.cfg.in:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/hydra-doxygen.cfg.in:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/hydra-doxygen.cfg.in:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/hydra-doxygen.cfg.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/hydra-doxygen.cfg.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/hydra-doxygen.cfg.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/hydra-doxygen.cfg.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/hydra-doxygen.cfg.in:5406
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-80
+ /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include
- /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/include:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/include:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/include:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/include:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/include:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/include:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/include:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/include:5406
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-
+ /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
- /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/mpich2prereq:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/mpich2prereq:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/mpich2prereq:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/mpich2prereq:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/mpich2prereq:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/mpich2prereq:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/mpich2prereq:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/mpich2prereq:5406
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,
+ /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm
- /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/pm:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/pm:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/pm:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/pm:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/pm:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/pm:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/pm:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/pm:5406
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-8024,
+ /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools
- /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/tools:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/tools:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/tools:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/tools:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/tools:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/tools:5406
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-80
+ /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
- /mpich2/branches/dev/coll-err-ret/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-
+ /mpich2/branches/dev/coll-err-ret/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7771-7802
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
- /mpich2/branches/dev/coll-err-ret/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8
+ /mpich2/branches/dev/coll-err-ret/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7771-7802
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui
- /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/ui:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/ui:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/ui:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/ui:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/ui:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/ui:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/ui:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/ui:5406
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-8024,
+ /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils
- /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/utils:5057-6537
/mpich2/branches/dev/coll-err-ret/src/pm/hydra/utils:7771-7802
/mpich2/branches/dev/error-return/src/pm/hydra/utils:7662-7670
/mpich2/branches/dev/ftb/src/pm/hydra/utils:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/utils:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/utils:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/utils:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/utils:5406
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7931-7932,7937-7944,7946,7953-7954,7956-7957,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005-8008,8010-8012,8016,8018-8019,8021,8023-80
+ /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
- /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/coll-err-ret/winconfigure.wsf:7771-7802
/mpich2/branches/dev/error-return/winconfigure.wsf:7662-7670
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/test/mpi/rma/winconfigure.wsf:7960
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7604,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654,7658-7659,7663,7665,7668,7671,7674,7676-7678,7681,7683-7688,7690-7692,7694,7696,7700-7702,7705,7707-7710,7712,7714,7719-7720,7722,7724-7725,7728-7729,7733,7735-7737,7739,7741,7744-7748,7751-7754,7758-7759,7761-7762,7766,7772,7774,7779-7781,7788,7793,7799-7801,7803,7807-7808,7811,7813,7815-7816,7819,7821,7829-7831,7833,7835-7837,7839-7843,7852,7858,7860,7862,7866,7872-7874,7879-7880,7882,7884,7886-7888,7890,7895,7897,7899,7903-7904,7906,7908,7910,7912,7921-7923,7925-7926,7929,7931-7932,7935,7937-7944,7946,7953-7954,7956-7958,7960,7968,7971,7975,7979,7981,7988,7991-7992,7994,7996,8001,8003,8005
+ /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
More information about the mpich2-commits
