[mpich2-commits] r8044 - mpich2/trunk
balaji at mcs.anl.gov
Thu Feb 24 17:23:56 CST 2011
Author: balaji
Date: 2011-02-24 17:23:56 -0600 (Thu, 24 Feb 2011)
New Revision: 8044
Modified:
mpich2/trunk/CHANGES
Log:
Initial draft of CHANGES for 1.3.3rc1.
Modified: mpich2/trunk/CHANGES
--- mpich2/trunk/CHANGES 2011-02-24 22:40:19 UTC (rev 8043)
+++ mpich2/trunk/CHANGES 2011-02-24 23:23:56 UTC (rev 8044)
@@ -11,6 +11,65 @@
+ Changes in 1.3.3
+ # OVERALL: Improvements to fault tolerance for collective
+ operations. Thanks to Rui Wang @ ICT for reporting several of these
+ issues.
+ # OVERALL: Improvements to the universe size detection. Thanks to
+ Yauheni Zelenko for reporting this issue.
+ # OVERALL: Bug fixes for Fortran attributes on some systems. Thanks
+ to Nicolai Stange for reporting this issue.
+ # PM/PMI: Support for a manual "none" launcher in Hydra to allow for
+ higher-level tools to be built on top of Hydra. Thanks to Justin
+ Wozniak for reporting this issue, for providing several patches for
+ the fix, and testing it.
+ # PM/PMI: Bug fixes in Hydra to handle non-uniform layouts of hosts
+ better. Thanks to the MVAPICH group at OSU for reporting this issue
+ and testing it.
+ # PM/PMI: Bug fixes in Hydra to handle cases where only a subset of
+ the available launchers or resource managers are compiled
+ in. Thanks to Satish Balay @ Argonne for reporting this issue.
+ # PM/PMI: Support for a different username to be provided for each
+ host; this only works for launchers that support this (such as
+ SSH).
+ # PM/PMI: Bug fixes for using Hydra on AIX machines. Thanks to
+ Kitrick Sheets @ NCSA for reporting this issue and providing the
+ first draft of the patch.
+ # PM/PMI: Bug fixes in memory allocation/management for environment
+ variables that was showing up on older platforms. Thanks to Steven
+ Sutphen for reporting the issue and providing detailed analysis to
+ track down the bug.
+ # PM/PMI: Added support for providing a configuration file to pick
+ the default options for Hydra. Thanks to Saurabh T. for reporting
+ the issues with the current implementation and working with us to
+ improve this option.
+ # PM/PMI: Improvements to the error code returned by Hydra.
+ # TEST SUITE: Several new tests for MPI RMA operations.
+ # Several other minor bug fixes, memory leak fixes, and code cleanup.
+ A full list of changes is available using:
+ svn log -r7838:HEAD https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.3.3rc1
+ ... or at the following link:
+ https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.3.3rc1?action=follow_copy&rev=HEAD&stop_rev=7838&mode=follow_copy
Changes in 1.3.2
More information about the mpich2-commits
