[mpich2-commits] r7938 - mpich2/trunk/src/pm/hydra/utils/sock
balaji at mcs.anl.gov balaji at mcs.anl.gov
Fri Feb 11 17:34:09 CST 2011
Author: balaji
Date: 2011-02-11 17:34:09 -0600 (Fri, 11 Feb 2011)
New Revision: 7938
Modified:
   mpich2/trunk/src/pm/hydra/utils/sock/sock.c
Log:
Cleanup code and error messages for the case where the proxy is not
able to connect to the main server.
No reviewer.
Modified: mpich2/trunk/src/pm/hydra/utils/sock/sock.c
--- mpich2/trunk/src/pm/hydra/utils/sock/sock.c	2011-02-11 23:34:03 UTC (rev 7937)
+++ mpich2/trunk/src/pm/hydra/utils/sock/sock.c	2011-02-11 23:34:09 UTC (rev 7938)
@@ -18,6 +18,37 @@
     struct fwd_hash *next;
+static char localhost[MAX_HOSTNAME_LEN] = { 0 };
+static char shortlocal[MAX_HOSTNAME_LEN] = { 0 };
+static HYD_status sock_localhost_init(void)
+    static int init = 1;
+    int i;
+    HYD_status status = HYD_SUCCESS;
+    if (init) {
+        init = 0;
+        status = HYDU_gethostname(localhost);
+        HYDU_ERR_POP(status, "unable to get local hostname\n");
+        strcpy(shortlocal, localhost);
+        for (i = 0; shortlocal[i]; i++) {
+            if (shortlocal[i] == '.') {
+                shortlocal[i] = 0;
+                break;
+  fn_exit:
+    return status;
+  fn_fail:
+    goto fn_exit;
 HYD_status HYDU_sock_listen(int *listen_fd, char *port_range, uint16_t * port)
     struct sockaddr_in sa;
@@ -148,9 +179,12 @@
      * return an error, but only print a warning message. The upper
      * layer can decide what to do with the return status. */
     if (connect(*fd, (struct sockaddr *) &sa, sizeof(sa)) < 0) {
-        HYDU_error_printf("connect error (%s)\n", HYDU_strerror(errno));
-        status = HYD_SOCK_ERROR;
-        goto fn_fail;
+        status = sock_localhost_init();
+        HYDU_ERR_POP(status, "unable to initialize sock local information\n");
+        HYDU_ERR_SETANDJUMP(status, HYD_SOCK_ERROR,
+                            "unable to connect from \"%s\" to \"%s\" (%s)\n",
+                            localhost, host, HYDU_strerror(errno));
     /* Disable nagle */
@@ -463,9 +497,6 @@
     char *ip1 = NULL, *ip2 = NULL;
     char buf1[INET_ADDRSTRLEN], buf2[INET_ADDRSTRLEN];
     struct sockaddr_in *sa_ptr, sa;
-    static int init = 1;
-    static char localhost[MAX_HOSTNAME_LEN] = { 0 };
-    static char shortlocal[MAX_HOSTNAME_LEN] = { 0 };
     char shorthost[MAX_HOSTNAME_LEN] = { 0 };
     int i;
@@ -516,21 +547,9 @@
 #endif
     /* Direct comparison of host names */
-    if (init) {
-        init = 0;
-        status = HYDU_gethostname(localhost);
-        HYDU_ERR_POP(status, "unable to get local hostname\n");
-        strcpy(shortlocal, localhost);
-        for (i = 0; shortlocal[i]; i++) {
-            if (shortlocal[i] == '.') {
-                shortlocal[i] = 0;
-                break;
     if (!strcmp(host, localhost)) {
         *is_local = 1;
         goto fn_exit;
More information about the mpich2-commits mailing list
