[mpich2-commits] r7937 - mpich2/trunk/src/pm/hydra/tools/bootstrap/external
balaji at mcs.anl.gov balaji at mcs.anl.gov
Fri Feb 11 17:34:03 CST 2011
Author: balaji
Date: 2011-02-11 17:34:03 -0600 (Fri, 11 Feb 2011)
New Revision: 7937
Modified:
   mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c
Log:
Cleanup the launcher-specific code to find the right executable and
move it to utility functions to make the main launch code more
readable.
No reviewer.
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c	2011-02-11 16:11:25 UTC (rev 7936)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c	2011-02-11 23:34:03 UTC (rev 7937)
@@ -12,6 +12,91 @@
 static int fd_stdout, fd_stderr;
+/* We use the following priority order for the executable path: (1)
+ * user-specified; (2) search in path; (3) Hard-coded location */
+static HYD_status ssh_get_path(char **path)
+    if (HYDT_bsci_info.launcher_exec)
+        *path = HYDU_strdup(HYDT_bsci_info.launcher_exec);
+    if (*path == NULL)
+        *path = HYDU_find_full_path("ssh");
+        *path = HYDU_strdup("/usr/bin/ssh");
+    return HYD_SUCCESS;
+static HYD_status rsh_get_path(char **path)
+        *path = HYDU_find_full_path("rsh");
+        *path = HYDU_strdup("/usr/bin/rsh");
+static HYD_status lsf_get_path(char **path)
+    char *bin_dir = NULL;
+    int length;
+    HYD_status status = HYD_SUCCESS;
+    if (*path == NULL) {
+        MPL_env2str("LSF_BINDIR", (const char **) &bin_dir);
+        if (bin_dir) {
+            length = strlen(bin_dir) + 2 + strlen("blaunch");
+            HYDU_MALLOC(*path, char *, length, status);
+            MPL_snprintf(*path, length, "%s/blaunch", bin_dir);
+        *path = HYDU_find_full_path("blaunch");
+        *path = HYDU_strdup("/usr/bin/blaunch");
+  fn_exit:
+    return status;
+  fn_fail:
+    goto fn_exit;
+static HYD_status sge_get_path(char **path)
+    char *sge_root = NULL, *arc = NULL;
+    int length;
+        MPL_env2str("SGE_ROOT", (const char **) &sge_root);
+        MPL_env2str("ARC", (const char **) &arc);
+        if (sge_root && arc) {
+            length = strlen(sge_root) + strlen("/bin/") + strlen(arc) + 1 + strlen("qrsh") + 1;
+            MPL_snprintf(*path, length, "%s/bin/%s/qrsh", sge_root, arc);
+        *path = HYDU_find_full_path("qrsh");
+        *path = HYDU_strdup("/usr/bin/qrsh");
+  fn_exit:
+    return status;
+  fn_fail:
+    goto fn_exit;
 HYD_status HYDT_bscd_external_launch_procs(char **args, struct HYD_node *node_list,
                                            int *control_fd)
@@ -27,69 +112,31 @@
     HYDU_FUNC_ENTER();
-    /* We use the following priority order for the executable path:
-     * (1) user-specified; (2) search in path; (3) Hard-coded
-     * location */
-    if (HYDT_bsci_info.launcher_exec)
-        path = HYDU_strdup(HYDT_bsci_info.launcher_exec);
     if (!strcmp(HYDT_bsci_info.launcher, "ssh")) {
-        if (!path)
-            path = HYDU_find_full_path("ssh");
-        if (!path)
-            path = HYDU_strdup("/usr/bin/ssh");
+        status = ssh_get_path(&path);
+        HYDU_ERR_POP(status, "unable to get path to the ssh executable\n");
     else if (!strcmp(HYDT_bsci_info.launcher, "rsh")) {
-        if (!path)
-            path = HYDU_find_full_path("rsh");
-        if (!path)
-            path = HYDU_strdup("/usr/bin/rsh");
+        status = rsh_get_path(&path);
+        HYDU_ERR_POP(status, "unable to get path to the rsh executable\n");
+    else if (!strcmp(HYDT_bsci_info.launcher, "fork")) {
+        /* fork is not an external launcher */
     else if (!strcmp(HYDT_bsci_info.launcher, "lsf")) {
-        char *bin_dir = NULL;
-        int length;
-        MPL_env2str("LSF_BINDIR", (const char **) &bin_dir);
-        if (bin_dir) {
-            length = strlen(bin_dir) + 2 + strlen("blaunch");
-            HYDU_MALLOC(path, char *, length, status);
-            MPL_snprintf(path, length, "%s/blaunch", bin_dir);
-        if (!path)
-            path = HYDU_find_full_path("blaunch");
-        if (!path)
-            path = HYDU_strdup("/usr/bin/blaunch");
+        status = lsf_get_path(&path);
+        HYDU_ERR_POP(status, "unable to get path to the blaunch executable\n");
     else if (!strcmp(HYDT_bsci_info.launcher, "sge")) {
-        char *sge_root = NULL, *arc = NULL;
-        int length;
-        MPL_env2str("SGE_ROOT", (const char **) &sge_root);
-        MPL_env2str("ARC", (const char **) &arc);
-        if (sge_root && arc) {
-            length = strlen(sge_root) + strlen("/bin/") + strlen(arc) + 1 + strlen("qrsh") + 1;
-            MPL_snprintf(path, length, "%s/bin/%s/qrsh", sge_root, arc);
-        if (!path)
-            path = HYDU_find_full_path("qrsh");
-        if (!path)
-            path = HYDU_strdup("/usr/bin/qrsh");
+        status = sge_get_path(&path);
+        HYDU_ERR_POP(status, "unable to get path to the qrsh executable\n");
     idx = 0;
     if (path)
         targs[idx++] = HYDU_strdup(path);
+    targs[idx] = NULL;
-    MPL_env2str("HYDRA_LAUNCH_EXTRA_ARGS", (const char **) &extra_arg_list);
-    if (extra_arg_list) {
-        extra_arg = strtok(extra_arg_list, " ");
-        while (extra_arg) {
-            targs[idx++] = HYDU_strdup(extra_arg);
-            extra_arg = strtok(NULL, " ");
     /* Allow X forwarding only if explicitly requested */
         if (HYDT_bsci_info.enablex == 1)
@@ -107,6 +154,15 @@
         targs[idx++] = HYDU_strdup("-V");
+    MPL_env2str("HYDRA_LAUNCH_EXTRA_ARGS", (const char **) &extra_arg_list);
+    if (extra_arg_list) {
+        extra_arg = strtok(extra_arg_list, " ");
+        while (extra_arg) {
+            targs[idx++] = HYDU_strdup(extra_arg);
+            extra_arg = strtok(NULL, " ");
     host_idx = idx++;   /* Hostname will come here */
     targs[host_idx] = NULL;
More information about the mpich2-commits mailing list
