[mpich2-commits] r6760 - mpich2/trunk/src/mpid/ch3/channels/nemesis
goodell at mcs.anl.gov
Fri May 28 15:33:48 CDT 2010
Author: goodell
Date: 2010-05-28 15:33:48 -0500 (Fri, 28 May 2010)
New Revision: 6760
Modified:
mpich2/trunk/src/mpid/ch3/channels/nemesis/configure.in
Log:
simplify check for OPA atomic emulation in nemesis
Uses a define added in r106 of OPA. Now nemesis doesn't need to
use an AC_ARG_WITH matching OPA's argument.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/configure.in
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/configure.in 2010-05-28 20:12:40 UTC (rev 6759)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/configure.in 2010-05-28 20:33:48 UTC (rev 6760)
@@ -246,9 +246,6 @@
# ensure that atomic primitives are available
AC_MSG_CHECKING([for OpenPA atomic primitive availability])
-AC_ARG_WITH(atomic-primitives, [--with-atomic-primitives - set to 'no' to permit
- atomic primitive emulation. See the openpa
- directory for more info.],, with_atomic_primitives=not_specified)
# Double check that we actually have a present and working OpenPA
# configuration. This must be AC_COMPILE_IFELSE instead of the stronger
@@ -288,10 +285,16 @@
],using_emulated_atomics=no,using_emulated_atomics=yes)
if test "$using_emulated_atomics" = "yes" ; then
- if test "$with_atomic_primitives" = "no" ; then
+ AC_PREPROC_IFELSE([
+#include <opa_primitives.h>
+/* may also be undefined in older (pre-r106) versions of OPA */
+#if !defined(OPA_EXPLICIT_EMULATION)
+#error "lock-based emulation was automatic, not explicit"
+#endif
+],[atomics_explicitly_emulated=yes],[atomics_explicitly_emulated=no])
+ if test "$atomics_explicitly_emulated" = "yes" ; then
AC_MSG_RESULT([yes (emulated)])
else
- # error
AC_MSG_RESULT([no])
AC_MSG_ERROR([
The nemesis channel was selected yet no native atomic primitives are
More information about the mpich2-commits
