[mpich2-commits] r6759 - mpich2/trunk
goodell at mcs.anl.gov goodell at mcs.anl.gov
Fri May 28 15:12:40 CDT 2010
Author: goodell
Date: 2010-05-28 15:12:40 -0500 (Fri, 28 May 2010)
New Revision: 6759
Modified:
   mpich2/trunk/configure.in
Log:
fix bug that made OPA mandatory even for ch3:sock
Pass --with-atomic-primitives=auto_allow_emulation to the OPA configure
unless the user specifies a particular value.
This is a regression introduced in r6223, between 1.2.1p1 and 1.3a1.
Reviewed by balaji at .
Modified: mpich2/trunk/configure.in
--- mpich2/trunk/configure.in	2010-05-28 20:12:38 UTC (rev 6758)
+++ mpich2/trunk/configure.in	2010-05-28 20:12:40 UTC (rev 6759)
@@ -1005,7 +1005,19 @@
     EXTERNAL_SRC_DIRS="$EXTERNAL_SRC_DIRS src/openpa"
     CPPFLAGS="$CPPFLAGS -I${use_top_srcdir}/src/openpa/src -I${master_top_builddir}/src/openpa/src"
-    PAC_CONFIG_SUBDIR(src/openpa,,AC_ERROR(OpenPA configure failed))
+    # OPA defaults to "auto", but in MPICH2 we want "auto_allow_emulation" to
+    # easily permit using channels like ch3:sock that don't care about atomics
+    AC_ARG_WITH([atomic-primitives],
+                [AS_HELP_STRING([--with-atomic-primitives],
+                                [Force OPA to use a specific atomic primitives
+                                 implementation.  See the src/openpa directory
+                                 for more info.])],
+                [],[with_atomic_primitives=not_specified])
+    opa_subdir_args=""
+    if test "$with_atomic_primitives" = "not_specified" ; then
+        opa_subdir_args="--with-atomic-primitives=auto_allow_emulation"
+    fi
+    PAC_CONFIG_SUBDIR_ARGS([src/openpa],[$opa_subdir_args],[],[AC_ERROR([OpenPA configure failed])])
     PAC_PREPEND_FLAG([-lopa],[WRAPPER_LIBS])
     other_install_dirs="$other_install_dirs src/openpa"
More information about the mpich2-commits mailing list
