[mpich2-commits] r5610 - mpich2/trunk/src/pm/hydra/tools/bind/hwloc
mercierg at mcs.anl.gov
Thu Oct 29 05:03:35 CDT 2009
Author: mercierg
Date: 2009-10-29 05:03:35 -0500 (Thu, 29 Oct 2009)
New Revision: 5610
Modified:
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
Log:
Fix for issues when No Nodes/Socket level is present
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2009-10-29 09:04:06 UTC (rev 5609)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2009-10-29 10:03:35 UTC (rev 5610)
@@ -68,14 +68,20 @@
cpuset_sys = obj_sys->cpuset;
/* Compute the number of sockets per NUMA Node */
- /* FIX ME : We assume that the number of sockets is the same for each node (e.g node 0)!*/
- obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,0);
- HYDT_bind_info.num_sockets = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET);
- /* Compute the number of cores per socket */
- /* FIX ME : We assume that the number of CORES is the same for each SOCKET (e.g sock 0)!*/
- obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,0);
- HYDT_bind_info.num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+ /* FIX ME : We assume that the number of sockets is the same for each node (e.g node 0)!*/
+ obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,0);
+ if(obj_node)
+ HYDT_bind_info.num_sockets = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET);
+ else
+ HYDT_bind_info.num_sockets = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_SOCKET);
+ /* Compute the number of cores per socket */
+ /* FIX ME : We assume that the number of CORES is the same for each SOCKET (e.g sock 0)!*/
+ obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,0);
+ if(obj_node)
+ HYDT_bind_info.num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+ else
+ HYDT_bind_info.num_cores = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE);
HYDT_bind_info.num_threads = (HYDT_bind_info.num_procs/(hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE)));
More information about the mpich2-commits
