[mpich2-commits] r5609 - mpich2/trunk/src/pm/hydra/tools/bind/hwloc
mercierg at mcs.anl.gov
Thu Oct 29 04:04:06 CDT 2009
Author: mercierg
Date: 2009-10-29 04:04:06 -0500 (Thu, 29 Oct 2009)
New Revision: 5609
Modified:
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
Log:
Fix for the case where no NUMA node is present in the hierarchy
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2009-10-29 02:17:44 UTC (rev 5608)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2009-10-29 09:04:06 UTC (rev 5609)
@@ -82,96 +82,146 @@
bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_NODE);
for (proc = 0; proc < HYDT_bind_info.num_procs; proc++)
- for(node = 0; node < bound ; node++)
- obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,node);
- cpuset_node = obj_node->cpuset;
+ if (bound == 0)
+ for(sock = 0, bound2 = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_SOCKET) ;
+ sock < bound2 ;
+ sock++)
+ obj_sock = obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,sock);
+ cpuset_sock = obj_sock->cpuset;
+ if(hwloc_cpuset_isset (cpuset_sock, HYDT_bind_info.topology[proc].processor_id))
+ for(core = 0, bound3 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE) ;
+ core < bound3;
+ core++)
+ obj_core = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sock,HWLOC_OBJ_CORE,core);
+ cpuset_core = obj_core->cpuset;
+ if (hwloc_cpuset_isset (cpuset_core, HYDT_bind_info.topology[proc].processor_id))
+ int j;
+ /* HYDT_bind_info.topology[proc].node_id = obj_node->os_index;*/
+ HYDT_bind_info.topology[proc].socket_id = obj_sock->os_index;
+ HYDT_bind_info.topology[proc].core_id = obj_core->os_index;
+ thread = -1;
+ for (j = 0; j < proc; j++)
+ /* if ((HYDT_bind_info.topology[j].node_id == obj_node->os_index) &&
+ (HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
+ (HYDT_bind_info.topology[j].core_id == obj_core->os_index))
+ if ((HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
+ thread = HYDT_bind_info.topology[j].thread_id;
+ thread++;
+ HYDT_bind_info.topology[proc].thread_id = thread;
+ HYDT_bind_info.topology[proc].thread_rank = thread;
+ break;
+ else
+ for(node = 0; node < bound ; node++)
+ obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,node);
+ cpuset_node = obj_node->cpuset;
+ if(hwloc_cpuset_isset (cpuset_node, HYDT_bind_info.topology[proc].processor_id))
+ for(sock = 0, bound2 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET) ; sock < bound2 ; sock++)
+ obj_sock = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_node,HWLOC_OBJ_SOCKET,sock);
+ for(core = 0, bound3 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE) ; core < bound3; core+\
+ int j;
- if(hwloc_cpuset_isset (cpuset_node, HYDT_bind_info.topology[proc].processor_id))
- for(sock = 0, bound2 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET) ; sock < bound2 ; sock++)
- obj_sock = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_node,HWLOC_OBJ_SOCKET,sock);
- cpuset_sock = obj_sock->cpuset;
- if(hwloc_cpuset_isset (cpuset_sock, HYDT_bind_info.topology[proc].processor_id))
- for(core = 0, bound3 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE) ; core < bound3; core+\
+ thread = -1;
- obj_core = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sock,HWLOC_OBJ_CORE,core);
- cpuset_core = obj_core->cpuset;
- if (hwloc_cpuset_isset (cpuset_core, HYDT_bind_info.topology[proc].processor_id))
- int j;
- /* HYDT_bind_info.topology[proc].node_id = obj_node->os_index;*/
- HYDT_bind_info.topology[proc].socket_id = obj_sock->os_index;
- HYDT_bind_info.topology[proc].core_id = obj_core->os_index;
- thread = -1;
- for (j = 0; j < proc; j++)
- /* if ((HYDT_bind_info.topology[j].node_id == obj_node->os_index) &&
- (HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
- (HYDT_bind_info.topology[j].core_id == obj_core->os_index))
- if ((HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
- thread = HYDT_bind_info.topology[j].thread_id;
- thread++;
- HYDT_bind_info.topology[proc].thread_id = thread;
- HYDT_bind_info.topology[proc].thread_rank = thread;
- break;
- /* Get the rank of each node ID */
+ thread++;
+ break;
+ /* Get the rank of each node ID */
for(node = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_NODE) ; node < bound ; node++)
- obj_node = hwloc_get_obj_by_type(topology,HWLOC_OBJ_NODE,node);
- for (proc = 0; proc < HYDT_bind_info.num_procs; proc++)
- if (HYDT_bind_info.topology[proc].node_id == obj_node->os_index)
+ obj_node = hwloc_get_obj_by_type(topology,HWLOC_OBJ_NODE,node);
+ for (proc = 0; proc < HYDT_bind_info.num_procs; proc++)
+ if (HYDT_bind_info.topology[proc].node_id == obj_node->os_index)
HYDT_bind_info.topology[proc].node_rank = node;
- /* Get the rank of each socket ID */
- for(sock = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_SOCKET) ; sock < bound; sock++)
- obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,sock);
- if (HYDT_bind_info.topology[proc].socket_id == obj_sock->os_index)
- HYDT_bind_info.topology[proc].socket_rank = sock;
- /* Find the rank of each core ID */
- for (core = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE); core < bound ; core++)
- obj_core = hwloc_get_obj_by_type(topology,HWLOC_OBJ_CORE,core);
- if (HYDT_bind_info.topology[proc].core_id == obj_core->os_index)
- HYDT_bind_info.topology[proc].core_rank = core;
- /* We have qualified for topology-aware binding support level */
- *support_level = HYDT_BIND_TOPO;
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
- fn_fail:
- goto fn_exit;
+ /* Get the rank of each socket ID */
+ for(sock = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_SOCKET) ; sock < bound; sock++)
+ obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,sock);
+ if (HYDT_bind_info.topology[proc].socket_id == obj_sock->os_index)
+ HYDT_bind_info.topology[proc].socket_rank = sock;
+ /* Find the rank of each core ID */
+ for (core = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE); core < bound ; core++)
+ obj_core = hwloc_get_obj_by_type(topology,HWLOC_OBJ_CORE,core);
+ if (HYDT_bind_info.topology[proc].core_id == obj_core->os_index)
+ HYDT_bind_info.topology[proc].core_rank = core;
+ /* We have qualified for topology-aware binding support level */
+ *support_level = HYDT_BIND_TOPO;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
HYD_status HYDT_bind_hwloc_process(int core)
More information about the mpich2-commits
