[mpich2-commits] r5586 - mpich2/trunk/confdb
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Oct 27 17:57:07 CDT 2009
Author: balaji
Date: 2009-10-27 17:57:07 -0500 (Tue, 27 Oct 2009)
New Revision: 5586
Modified:
   mpich2/trunk/confdb/config.guess
   mpich2/trunk/confdb/config.sub
Log:
Update config.guess to the latest version.
Modified: mpich2/trunk/confdb/config.guess
--- mpich2/trunk/confdb/config.guess	2009-10-27 22:57:06 UTC (rev 5585)
+++ mpich2/trunk/confdb/config.guess	2009-10-27 22:57:07 UTC (rev 5586)
@@ -4,7 +4,7 @@
 #   2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008
 #   Free Software Foundation, Inc.
-timestamp='2008-03-12'
+timestamp='2009-04-27'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -324,6 +324,9 @@
 	case `/usr/bin/uname -p` in
 	    sparc) echo sparc-icl-nx7; exit ;;
 	esac ;;
+    s390x:SunOS:*:*)
+	echo ${UNAME_MACHINE}-ibm-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	exit ;;
     sun4H:SunOS:5.*:*)
 	echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
@@ -331,7 +334,20 @@
 	echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
     i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
-	echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	eval $set_cc_for_build
+	SUN_ARCH="i386"
+	# If there is a compiler, see if it is configured for 64-bit objects.
+	# Note that the Sun cc does not turn __LP64__ into 1 like gcc does.
+	# This test works for both compilers.
+	if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+	    if (echo '#ifdef __amd64'; echo IS_64BIT_ARCH; echo '#endif') | \
+		(CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+		grep IS_64BIT_ARCH >/dev/null
+	    then
+		SUN_ARCH="x86_64"
+	    fi
+	fi
+	echo ${SUN_ARCH}-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
     sun4*:SunOS:6*:*)
 	# According to config.sub, this is the proper way to canonicalize
@@ -796,7 +812,7 @@
 	    x86)
 		echo i586-pc-interix${UNAME_RELEASE}
 		exit ;;
-	    EM64T | authenticamd)
+	    EM64T | authenticamd | genuineintel)
 		echo x86_64-unknown-interix${UNAME_RELEASE}
 		exit ;;
 	    IA64)
@@ -935,6 +951,9 @@
 	if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
 	echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
 	exit ;;
+    padre:Linux:*:*)
+	echo sparc-unknown-linux-gnu
+	exit ;;
     parisc:Linux:*:* | hppa:Linux:*:*)
 	# Look for CPU level
 	case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
@@ -985,9 +1004,6 @@
 	  a.out-i386-linux)
 		echo "${UNAME_MACHINE}-pc-linux-gnuaout"
 		exit ;;
-	  coff-i386)
-		echo "${UNAME_MACHINE}-pc-linux-gnucoff"
-		exit ;;
 		# Either a pre-BFD a.out linker (linux-gnuoldld) or
 		# one that does not give us useful --help.
@@ -1102,8 +1118,11 @@
     pc:*:*:*)
 	# Left here for compatibility:
         # uname -m prints for DJGPP always 'pc', but it prints nothing about
-        # the processor, so we play safe by assuming i386.
-	echo i386-pc-msdosdjgpp
+        # the processor, so we play safe by assuming i586.
+	# Note: whatever this is, it MUST be the same as what config.sub
+	# prints for the "djgpp" host, or else GDB configury will decide that
+	# this is a cross-build.
+	echo i586-pc-msdosdjgpp
         exit ;;
     Intel:Mach:3*:*)
 	echo i386-pc-mach3
@@ -1141,6 +1160,16 @@
     3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
         /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
           && { echo i486-ncr-sysv4; exit; } ;;
+    NCR*:*:4.2:* | MPRAS*:*:4.2:*)
+	OS_REL='.3'
+	test -r /etc/.relid \
+	    && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
+	/bin/uname -p 2>/dev/null | grep 86 >/dev/null \
+	    && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
+	/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
+	    && { echo i586-ncr-sysv4.3${OS_REL}; exit; }
+	/bin/uname -p 2>/dev/null | /bin/grep pteron >/dev/null \
+	    && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
     m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
 	echo m68k-unknown-lynxos${UNAME_RELEASE}
 	exit ;;
@@ -1327,6 +1356,9 @@
     i*86:rdos:*:*)
 	echo ${UNAME_MACHINE}-pc-rdos
 	exit ;;
+    i*86:AROS:*:*)
+	echo ${UNAME_MACHINE}-pc-aros
+	exit ;;
 esac
 #echo '(No uname command or uname output not recognized.)' 1>&2
Modified: mpich2/trunk/confdb/config.sub
--- mpich2/trunk/confdb/config.sub	2009-10-27 22:57:06 UTC (rev 5585)
+++ mpich2/trunk/confdb/config.sub	2009-10-27 22:57:07 UTC (rev 5586)
@@ -4,7 +4,7 @@
-timestamp='2008-03-26'
+timestamp='2009-04-17'
 # This file is (in principle) common to ALL GNU software.
 # The presence of a machine in this file suggests that SOME GNU software
@@ -122,6 +122,7 @@
 case $maybe_os in
   nto-qnx* | linux-gnu* | linux-dietlibc | linux-newlib* | linux-uclibc* | \
   uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | \
+  kopensolaris*-gnu* | \
   storm-chaos* | os2-emx* | rtmk-nova*)
     os=-$maybe_os
     basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -249,6 +250,7 @@
 	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
 	| i370 | i860 | i960 | ia64 \
 	| ip2k | iq2000 \
+	| lm32 \
 	| m32c | m32r | m32rle | m68000 | m68k | m88k \
 	| maxq | mb | microblaze | mcore | mep | metag \
 	| mips | mipsbe | mipseb | mipsel | mipsle \
@@ -270,6 +272,7 @@
 	| mipsisa64sr71k | mipsisa64sr71kel \
 	| mipstx39 | mipstx39el \
 	| mn10200 | mn10300 \
+	| moxie \
 	| mt \
 	| msp430 \
 	| nios | nios2 \
@@ -279,7 +282,7 @@
 	| powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
 	| pyramid \
 	| score \
-	| sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
+	| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
 	| sh64 | sh64le \
 	| sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
 	| sparcv8 | sparcv9 | sparcv9b | sparcv9v \
@@ -288,7 +291,7 @@
 	| v850 | v850e \
 	| we32k \
 	| x86 | xc16x | xscale | xscalee[bl] | xstormy16 | xtensa \
-	| z8k)
+	| z8k | z80)
 		basic_machine=$basic_machine-unknown
 	m6811 | m68hc11 | m6812 | m68hc12)
@@ -331,6 +334,7 @@
 	| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
 	| i*86-* | i860-* | i960-* | ia64-* \
 	| ip2k-* | iq2000-* \
+	| lm32-* \
 	| m32c-* | m32r-* | m32rle-* \
 	| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
 	| m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
@@ -362,7 +366,7 @@
 	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
 	| pyramid-* \
 	| romp-* | rs6000-* \
-	| sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
+	| sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
 	| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
 	| sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
 	| sparclite-* \
@@ -375,7 +379,7 @@
 	| x86-* | x86_64-* | xc16x-* | xps100-* | xscale-* | xscalee[bl]-* \
 	| xstormy16-* | xtensa*-* \
 	| ymp-* \
-	| z8k-*)
+	| z8k-* | z80-*)
 	# Recognize the basic CPU types without company name, with glob match.
 	xtensa*)
@@ -443,6 +447,10 @@
 		basic_machine=m68k-apollo
 		os=-bsd
+	aros)
+		basic_machine=i386-pc
+		os=-aros
 	aux)
 		basic_machine=m68k-apple
 		os=-aux
@@ -463,6 +471,10 @@
 		basic_machine=c90-cray
 		os=-unicos
+        cegcc)
+		basic_machine=arm-unknown
+		os=-cegcc
 	convex-c1)
 		basic_machine=c1-convex
 		os=-bsd
@@ -530,6 +542,10 @@
 		basic_machine=m88k-motorola
 		os=-sysv3
+	dicos)
+		basic_machine=i686-pc
+		os=-dicos
 	djgpp)
 		basic_machine=i586-pc
 		os=-msdosdjgpp
@@ -1132,6 +1148,10 @@
 		basic_machine=z8k-unknown
 		os=-sim
+	z80-*-coff)
+		basic_machine=z80-unknown
+		os=-sim
 	none)
 		basic_machine=none-none
 		os=-none
@@ -1170,7 +1190,7 @@
 	we32k)
 		basic_machine=we32k-att
-	sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
+	sh[1234] | sh[24]a | sh[24]aeb | sh[34]eb | sh[1234]le | sh[23]ele)
 		basic_machine=sh-unknown
 	sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
@@ -1242,8 +1262,9 @@
 	-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
 	      | -*vms* | -sco* | -esix* | -isc* | -aix* | -sunos | -sunos[34]*\
 	      | -hpux* | -unos* | -osf* | -luna* | -dgux* | -solaris* | -sym* \
+	      | -kopensolaris* \
 	      | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
-	      | -aos* \
+	      | -aos* | -aros* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
 	      | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
 	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
@@ -1252,7 +1273,7 @@
 	      | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
 	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
-	      | -chorusos* | -chorusrdb* \
+	      | -chorusos* | -chorusrdb* | -cegcc* \
 	      | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
 	      | -mingw32* | -linux-gnu* | -linux-newlib* | -linux-uclibc* \
 	      | -uxpv* | -beos* | -mpeix* | -udk* \
@@ -1392,6 +1413,9 @@
 	-zvmoe)
 		os=-zvmoe
+	-dicos*)
+		os=-dicos
 	-none)
More information about the mpich2-commits mailing list
