[mpich2-commits] r5585 - mpich2/trunk/confdb
    balaji at mcs.anl.gov
    Tue Oct 27 17:57:06 CDT 2009
Author: balaji
Date: 2009-10-27 17:57:06 -0500 (Tue, 27 Oct 2009)
New Revision: 5585
Added:
   mpich2/trunk/confdb/depcomp
   mpich2/trunk/confdb/missing
Log:
Added depcomp and missing to work with autoreconf.
Added: mpich2/trunk/confdb/depcomp
--- mpich2/trunk/confdb/depcomp	                        (rev 0)
+++ mpich2/trunk/confdb/depcomp	2009-10-27 22:57:06 UTC (rev 5585)
@@ -0,0 +1,630 @@
+#! /bin/sh
+# depcomp - compile a program generating dependencies as side-effects
+scriptversion=2009-04-28.21; # UTC
+# Copyright (C) 1999, 2000, 2003, 2004, 2005, 2006, 2007, 2009 Free
+# Software Foundation, Inc.
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program.  If not, see <http://www.gnu.org/licenses/>.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# Originally written by Alexandre Oliva <oliva at dcc.unicamp.br>.
+case $1 in
+     echo "$0: No command.  Try \`$0 --help' for more information." 1>&2
+     exit 1;
+  -h | --h*)
+    cat <<\EOF
+Usage: depcomp [--help] [--version] PROGRAM [ARGS]
+Run PROGRAMS ARGS to compile a file, generating dependencies
+as side-effects.
+Environment variables:
+  depmode     Dependency tracking mode.
+  source      Source file read by `PROGRAMS ARGS'.
+  object      Object file output by `PROGRAMS ARGS'.
+  DEPDIR      directory where to store dependencies.
+  depfile     Dependency file to output.
+  tmpdepfile  Temporary file to use when outputing dependencies.
+  libtool     Whether libtool is used (yes/no).
+Report bugs to <bug-automake at gnu.org>.
+EOF
+    exit $?
+  -v | --v*)
+    echo "depcomp $scriptversion"
+    exit $?
+esac
+if test -z "$depmode" || test -z "$source" || test -z "$object"; then
+  echo "depcomp: Variables source, object and depmode must be set" 1>&2
+  exit 1
+fi
+# Dependencies for sub/bar.o or sub/bar.obj go into sub/.deps/bar.Po.
+depfile=${depfile-`echo "$object" |
+  sed 's|[^\\/]*$|'${DEPDIR-.deps}'/&|;s|\.\([^.]*\)$|.P\1|;s|Pobj$|Po|'`}
+tmpdepfile=${tmpdepfile-`echo "$depfile" | sed 's/\.\([^.]*\)$/.T\1/'`}
+rm -f "$tmpdepfile"
+# Some modes work just like other modes, but use different flags.  We
+# parameterize here, but still list the modes in the big case below,
+# to make depend.m4 easier to write.  Note that we *cannot* use a case
+# here, because this file can only contain one case statement.
+if test "$depmode" = hp; then
+  # HP compiler uses -M and no extra arg.
+  gccflag=-M
+  depmode=gcc
+fi
+if test "$depmode" = dashXmstdout; then
+   # This is just like dashmstdout with a different argument.
+   dashmflag=-xM
+   depmode=dashmstdout
+fi
+cygpath_u="cygpath -u -f -"
+if test "$depmode" = msvcmsys; then
+   # This is just like msvisualcpp but w/o cygpath translation.
+   # Just convert the backslash-escaped backslashes to single forward
+   # slashes to satisfy depend.m4
+   cygpath_u="sed s,\\\\\\\\,/,g"
+   depmode=msvisualcpp
+fi
+case "$depmode" in
+gcc3)
+## gcc 3 implements dependency tracking that does exactly what
+## we want.  Yay!  Note: for some reason libtool 1.4 doesn't like
+## it if -MD -MP comes after the -MF stuff.  Hmm.
+## Unfortunately, FreeBSD c89 acceptance of flags depends upon
+## the command line argument order; so add the flags where they
+## appear in depend2.am.  Note that the slowdown incurred here
+## affects only configure: in makefiles, %FASTDEP% shortcuts this.
+  for arg
+  do
+    case $arg in
+    -c) set fnord "$@" -MT "$object" -MD -MP -MF "$tmpdepfile" "$arg" ;;
+    *)  set fnord "$@" "$arg" ;;
+    esac
+    shift # fnord
+    shift # $arg
+  done
+  stat=$?
+  if test $stat -eq 0; then :
+  else
+    rm -f "$tmpdepfile"
+    exit $stat
+  fi
+  mv "$tmpdepfile" "$depfile"
+gcc)
+## There are various ways to get dependency output from gcc.  Here's
+## why we pick this rather obscure method:
+## - Don't want to use -MD because we'd like the dependencies to end
+##   up in a subdir.  Having to rename by hand is ugly.
+##   (We might end up doing this anyway to support other compilers.)
+## - The DEPENDENCIES_OUTPUT environment variable makes gcc act like
+##   -MM, not -M (despite what the docs say).
+## - Using -M directly means running the compiler twice (even worse
+##   than renaming).
+  if test -z "$gccflag"; then
+    gccflag=-MD,
+  fi
+  "$@" -Wp,"$gccflag$tmpdepfile"
+  stat=$?
+  else
+    exit $stat
+  fi
+  rm -f "$depfile"
+  echo "$object : \\" > "$depfile"
+  alpha=ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz
+## The second -e expression handles DOS-style file names with drive letters.
+  sed -e 's/^[^:]*: / /' \
+      -e 's/^['$alpha']:\/[^:]*: / /' < "$tmpdepfile" >> "$depfile"
+## This next piece of magic avoids the `deleted header file' problem.
+## The problem is that when a header file which appears in a .P file
+## is deleted, the dependency causes make to die (because there is
+## typically no way to rebuild the header).  We avoid this by adding
+## dummy dependencies for each header file.  Too bad gcc doesn't do
+## this for us directly.
+  tr ' ' '
+' < "$tmpdepfile" |
+## Some versions of gcc put a space before the `:'.  On the theory
+## that the space means something, we add a space to the output as
+## well.
+## Some versions of the HPUX 10.20 sed can't process this invocation
+## correctly.  Breaking it into two sed invocations is a workaround.
+    sed -e 's/^\\$//' -e '/^$/d' -e '/:$/d' | sed -e 's/$/ :/' >> "$depfile"
+hp)
+  # This case exists only to let depend.m4 do its work.  It works by
+  # looking at the text of this script.  This case will never be run,
+  # since it is checked for above.
+  exit 1
+sgi)
+  if test "$libtool" = yes; then
+    "$@" "-Wp,-MDupdate,$tmpdepfile"
+  else
+    "$@" -MDupdate "$tmpdepfile"
+  fi
+  stat=$?
+  else
+    exit $stat
+  fi
+  rm -f "$depfile"
+  if test -f "$tmpdepfile"; then  # yes, the sourcefile depend on other files
+    # Clip off the initial element (the dependent).  Don't try to be
+    # clever and replace this with sed code, as IRIX sed won't handle
+    # lines with more than a fixed number of characters (4096 in
+    # IRIX 6.2 sed, 8192 in IRIX 6.5).  We also remove comment lines;
+    # the IRIX cc adds comments like `#:fec' to the end of the
+    # dependency line.
+    tr ' ' '
+' < "$tmpdepfile" \
+    | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' | \
+    tr '
+' ' ' >> "$depfile"
+    echo >> "$depfile"
+    # The second pass generates a dummy entry for each header file.
+    tr ' ' '
+   | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' -e 's/$/:/' \
+   >> "$depfile"
+  else
+    # The sourcefile does not contain any dependencies, so just
+    # store a dummy comment line, to avoid errors with the Makefile
+    # "include basename.Plo" scheme.
+    echo "#dummy" > "$depfile"
+  fi
+aix)
+  # The C for AIX Compiler uses -M and outputs the dependencies
+  # in a .u file.  In older versions, this file always lives in the
+  # current directory.  Also, the AIX compiler puts `$object:' at the
+  # start of each line; $object doesn't have directory information.
+  # Version 6 uses the directory in both cases.
+  dir=`echo "$object" | sed -e 's|/[^/]*$|/|'`
+  test "x$dir" = "x$object" && dir=
+  base=`echo "$object" | sed -e 's|^.*/||' -e 's/\.o$//' -e 's/\.lo$//'`
+    tmpdepfile1=$dir$base.u
+    tmpdepfile2=$base.u
+    tmpdepfile3=$dir.libs/$base.u
+    "$@" -Wc,-M
+  else
+    tmpdepfile2=$dir$base.u
+    tmpdepfile3=$dir$base.u
+    "$@" -M
+  fi
+  stat=$?
+  else
+    rm -f "$tmpdepfile1" "$tmpdepfile2" "$tmpdepfile3"
+    exit $stat
+  fi
+  for tmpdepfile in "$tmpdepfile1" "$tmpdepfile2" "$tmpdepfile3"
+  do
+    test -f "$tmpdepfile" && break
+  done
+    # Each line is of the form `foo.o: dependent.h'.
+    # Do two passes, one to just change these to
+    # `$object: dependent.h' and one to simply `dependent.h:'.
+    sed -e "s,^.*\.[a-z]*:,$object:," < "$tmpdepfile" > "$depfile"
+    # That's a tab and a space in the [].
+    sed -e 's,^.*\.[a-z]*:[	 ]*,,' -e 's,$,:,' < "$tmpdepfile" >> "$depfile"
+  else
+  fi
+icc)
+  # Intel's C compiler understands `-MD -MF file'.  However on
+  #    icc -MD -MF foo.d -c -o sub/foo.o sub/foo.c
+  # ICC 7.0 will fill foo.d with something like
+  #    foo.o: sub/foo.c
+  #    foo.o: sub/foo.h
+  # which is wrong.  We want:
+  #    sub/foo.o: sub/foo.c
+  #    sub/foo.o: sub/foo.h
+  #    sub/foo.c:
+  #    sub/foo.h:
+  # ICC 7.1 will output
+  #    foo.o: sub/foo.c sub/foo.h
+  # and will wrap long lines using \ :
+  #    foo.o: sub/foo.c ... \
+  #     sub/foo.h ... \
+  "$@" -MD -MF "$tmpdepfile"
+  stat=$?
+  else
+    exit $stat
+  fi
+  rm -f "$depfile"
+  # Each line is of the form `foo.o: dependent.h',
+  # or `foo.o: dep1.h dep2.h \', or ` dep3.h dep4.h \'.
+  sed "s,^[^:]*:,$object :," < "$tmpdepfile" > "$depfile"
+  # Some versions of the HPUX 10.20 sed can't process this invocation
+  # correctly.  Breaking it into two sed invocations is a workaround.
+  sed 's,^[^:]*: \(.*\)$,\1,;s/^\\$//;/^$/d;/:$/d' < "$tmpdepfile" |
+    sed -e 's/$/ :/' >> "$depfile"
+hp2)
+  # The "hp" stanza above does not work with aCC (C++) and HP's ia64
+  # compilers, which have integrated preprocessors.  The correct option
+  # to use with these is +Maked; it writes dependencies to a file named
+  # 'foo.d', which lands next to the object file, wherever that
+  # happens to be.
+  # Much of this is similar to the tru64 case; see comments there.
+    tmpdepfile1=$dir$base.d
+    tmpdepfile2=$dir.libs/$base.d
+    "$@" -Wc,+Maked
+  else
+    tmpdepfile2=$dir$base.d
+    "$@" +Maked
+  fi
+  stat=$?
+  else
+     exit $stat
+  fi
+  do
+  done
+    sed -e "s,^.*\.[a-z]*:,$object:," "$tmpdepfile" > "$depfile"
+    # Add `dependent.h:' lines.
+    sed -ne '2,${
+	       s/^ *//
+	       s/ \\*$//
+	       s/$/:/
+	       p
+	     }' "$tmpdepfile" >> "$depfile"
+  else
+  fi
+  rm -f "$tmpdepfile" "$tmpdepfile2"
+tru64)
+   # The Tru64 compiler uses -MD to generate dependencies as a side
+   # effect.  `cc -MD -o foo.o ...' puts the dependencies into `foo.o.d'.
+   # At least on Alpha/Redhat 6.1, Compaq CCC V6.2-504 seems to put
+   # dependencies in `foo.d' instead, so we check for that too.
+   # Subdirectories are respected.
+      # With Tru64 cc, shared objects can also be used to make a
+      # static library.  This mechanism is used in libtool 1.4 series to
+      # handle both shared and static libraries in a single compilation.
+      # With libtool 1.4, dependencies were output in $dir.libs/$base.lo.d.
+      # With libtool 1.5 this exception was removed, and libtool now
+      # generates 2 separate objects for the 2 libraries.  These two
+      # compilations output dependencies in $dir.libs/$base.o.d and
+      # in $dir$base.o.d.  We have to check for both files, because
+      # one of the two compilations can be disabled.  We should prefer
+      # $dir$base.o.d over $dir.libs/$base.o.d because the latter is
+      # automatically cleaned when .libs/ is deleted, while ignoring
+      # the former would cause a distcleancheck panic.
+      tmpdepfile1=$dir.libs/$base.lo.d   # libtool 1.4
+      tmpdepfile2=$dir$base.o.d          # libtool 1.5
+      tmpdepfile3=$dir.libs/$base.o.d    # libtool 1.5
+      tmpdepfile4=$dir.libs/$base.d      # Compaq CCC V6.2-504
+      "$@" -Wc,-MD
+   else
+      tmpdepfile1=$dir$base.o.d
+      tmpdepfile3=$dir$base.d
+      tmpdepfile4=$dir$base.d
+      "$@" -MD
+   fi
+   stat=$?
+   else
+      rm -f "$tmpdepfile1" "$tmpdepfile2" "$tmpdepfile3" "$tmpdepfile4"
+      exit $stat
+   fi
+   for tmpdepfile in "$tmpdepfile1" "$tmpdepfile2" "$tmpdepfile3" "$tmpdepfile4"
+   do
+   done
+   else
+   fi
+#nosideeffect)
+  # This comment above is used by automake to tell side-effect
+  # dependency tracking mechanisms from slower ones.
+dashmstdout)
+  # Important note: in order to support this mode, a compiler *must*
+  # always write the preprocessed file to stdout, regardless of -o.
+  "$@" || exit $?
+  # Remove the call to Libtool.
+    while test "X$1" != 'X--mode=compile'; do
+      shift
+    done
+    shift
+  fi
+  # Remove `-o $object'.
+  IFS=" "
+  for arg
+  do
+    case $arg in
+    -o)
+      shift
+    $object)
+      shift
+      set fnord "$@" "$arg"
+      shift # fnord
+      shift # $arg
+    esac
+  done
+  test -z "$dashmflag" && dashmflag=-M
+  # Require at least two characters before searching for `:'
+  # in the target name.  This is to cope with DOS-style filenames:
+  # a dependency such as `c:/foo/bar' could be seen as target `c' otherwise.
+  "$@" $dashmflag |
+    sed 's:^[  ]*[^: ][^:][^:]*\:[    ]*:'"$object"'\: :' > "$tmpdepfile"
+  rm -f "$depfile"
+  cat < "$tmpdepfile" > "$depfile"
+  tr ' ' '
+' < "$tmpdepfile" | \
+dashXmstdout)
+  # This case only exists to satisfy depend.m4.  It is never actually
+  # run, as this mode is specially recognized in the preamble.
+  exit 1
+makedepend)
+  "$@" || exit $?
+  # Remove any Libtool call
+      shift
+    done
+    shift
+  fi
+  # X makedepend
+  shift
+  cleared=no eat=no
+  for arg
+  do
+    case $cleared in
+    no)
+      set ""; shift
+      cleared=yes ;;
+    esac
+    if test $eat = yes; then
+      eat=no
+      continue
+    fi
+    case "$arg" in
+    -D*|-I*)
+      set fnord "$@" "$arg"; shift ;;
+    # Strip any option that makedepend may not understand.  Remove
+    # the object too, otherwise makedepend will parse it as a source file.
+    -arch)
+      eat=yes ;;
+    -*|$object)
+    esac
+  done
+  obj_suffix=`echo "$object" | sed 's/^.*\././'`
+  touch "$tmpdepfile"
+  ${MAKEDEPEND-makedepend} -o"$obj_suffix" -f"$tmpdepfile" "$@"
+  rm -f "$depfile"
+  sed '1,2d' "$tmpdepfile" | tr ' ' '
+  rm -f "$tmpdepfile" "$tmpdepfile".bak
+cpp)
+  # always write the preprocessed file to stdout.
+  "$@" || exit $?
+      shift
+    done
+    shift
+  fi
+  IFS=" "
+  for arg
+  do
+    case $arg in
+    -o)
+      shift
+    $object)
+      shift
+      shift # fnord
+      shift # $arg
+    esac
+  done
+  "$@" -E |
+    sed -n -e '/^# [0-9][0-9]* "\([^"]*\)".*/ s:: \1 \\:p' \
+       -e '/^#line [0-9][0-9]* "\([^"]*\)".*/ s:: \1 \\:p' |
+    sed '$ s: \\$::' > "$tmpdepfile"
+  rm -f "$depfile"
+  cat < "$tmpdepfile" >> "$depfile"
+  sed < "$tmpdepfile" '/^$/d;s/^ //;s/ \\$//;s/$/ :/' >> "$depfile"
+msvisualcpp)
+  "$@" || exit $?
+      shift
+    done
+    shift
+  fi
+  IFS=" "
+  for arg
+  do
+    case "$arg" in
+    -o)
+      shift
+    $object)
+      shift
+    "-Gm"|"/Gm"|"-Gi"|"/Gi"|"-ZI"|"/ZI")
+	set fnord "$@"
+	shift
+	shift
+	shift
+	shift
+    esac
+  done
+  "$@" -E 2>/dev/null |
+  sed -n '/^#line [0-9][0-9]* "\([^"]*\)"/ s::\1:p' | $cygpath_u | sort -u > "$tmpdepfile"
+  rm -f "$depfile"
+  sed < "$tmpdepfile" -n -e 's% %\\ %g' -e '/^\(.*\)$/ s::	\1 \\:p' >> "$depfile"
+  echo "	" >> "$depfile"
+  sed < "$tmpdepfile" -n -e 's% %\\ %g' -e '/^\(.*\)$/ s::\1\::p' >> "$depfile"
+msvcmsys)
+  exit 1
+none)
+  exec "$@"
+  echo "Unknown depmode $depmode" 1>&2
+  exit 1
+esac
+exit 0
+# Local Variables:
+# mode: shell-script
+# sh-indentation: 2
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "scriptversion="
+# time-stamp-format: "%:y-%02m-%02d.%02H"
+# time-stamp-time-zone: "UTC"
+# time-stamp-end: "; # UTC"
+# End:
Property changes on: mpich2/trunk/confdb/depcomp
___________________________________________________________________
Added: svn:executable
Added: mpich2/trunk/confdb/missing
--- mpich2/trunk/confdb/missing	                        (rev 0)
+++ mpich2/trunk/confdb/missing	2009-10-27 22:57:06 UTC (rev 5585)
@@ -0,0 +1,376 @@
+#! /bin/sh
+# Common stub for a few missing GNU programs while installing.
+# Copyright (C) 1996, 1997, 1999, 2000, 2002, 2003, 2004, 2005, 2006,
+# 2008, 2009 Free Software Foundation, Inc.
+# Originally by Fran,cois Pinard <pinard at iro.umontreal.ca>, 1996.
+if test $# -eq 0; then
+  echo 1>&2 "Try \`$0 --help' for more information"
+  exit 1
+fi
+run=:
+sed_output='s/.* --output[ =]\([^ ]*\).*/\1/p'
+sed_minuso='s/.* -o \([^ ]*\).*/\1/p'
+# In the cases where this matters, `missing' is being run in the
+# srcdir already.
+if test -f configure.ac; then
+  configure_ac=configure.ac
+else
+  configure_ac=configure.in
+fi
+msg="missing on your system"
+case $1 in
+--run)
+  # Try to run requested program, and just exit if it succeeds.
+  run=
+  shift
+  "$@" && exit 0
+  # Exit code 63 means version mismatch.  This often happens
+  # when the user try to use an ancient version of a tool on
+  # a file that requires a minimum version.  In this case we
+  # we should proceed has if the program had been absent, or
+  # if --run hadn't been passed.
+  if test $? = 63; then
+    run=:
+    msg="probably too old"
+  fi
+  -h|--h|--he|--hel|--help)
+    echo "\
+$0 [OPTION]... PROGRAM [ARGUMENT]...
+Handle \`PROGRAM [ARGUMENT]...' for when PROGRAM is missing, or return an
+error status if there is no known handling for PROGRAM.
+Options:
+  -h, --help      display this help and exit
+  -v, --version   output version information and exit
+  --run           try to run the given command, and emulate it if it fails
+Supported PROGRAM values:
+  aclocal      touch file \`aclocal.m4'
+  autoconf     touch file \`configure'
+  autoheader   touch file \`config.h.in'
+  autom4te     touch the output file, or create a stub one
+  automake     touch all \`Makefile.in' files
+  bison        create \`y.tab.[ch]', if possible, from existing .[ch]
+  flex         create \`lex.yy.c', if possible, from existing .c
+  help2man     touch the output file
+  lex          create \`lex.yy.c', if possible, from existing .c
+  makeinfo     touch the output file
+  tar          try tar, gnutar, gtar, then tar without non-portable flags
+  yacc         create \`y.tab.[ch]', if possible, from existing .[ch]
+Version suffixes to PROGRAM as well as the prefixes \`gnu-', \`gnu', and
+\`g' are ignored when checking the name.
+Send bug reports to <bug-automake at gnu.org>."
+    exit $?
+  -v|--v|--ve|--ver|--vers|--versi|--versio|--version)
+    echo "missing $scriptversion (GNU Automake)"
+    exit $?
+    echo 1>&2 "$0: Unknown \`$1' option"
+    exit 1
+esac
+# normalize program name to check for.
+program=`echo "$1" | sed '
+  s/^gnu-//; t
+  s/^gnu//; t
+  s/^g//; t'`
+# Now exit if we have it, but it failed.  Also exit now if we
+# don't have it and --version was passed (most likely to detect
+# the program).  This is about non-GNU programs, so use $1 not
+# $program.
+case $1 in
+  lex*|yacc*)
+    # Not GNU programs, they don't have --version.
+  tar*)
+    if test -n "$run"; then
+       echo 1>&2 "ERROR: \`tar' requires --run"
+       exit 1
+    elif test "x$2" = "x--version" || test "x$2" = "x--help"; then
+       exit 1
+    fi
+    if test -z "$run" && ($1 --version) > /dev/null 2>&1; then
+       # We have it, but it failed.
+       exit 1
+       # Could not run --version or --help.  This is probably someone
+       # running `$TOOL --version' or `$TOOL --help' to check whether
+       # $TOOL exists and not knowing $TOOL uses missing.
+       exit 1
+    fi
+esac
+# If it does not exist, or fails to run (possibly an outdated version),
+# try to emulate it.
+case $program in
+  aclocal*)
+    echo 1>&2 "\
+WARNING: \`$1' is $msg.  You should only need it if
+         you modified \`acinclude.m4' or \`${configure_ac}'.  You might want
+         to install the \`Automake' and \`Perl' packages.  Grab them from
+         any GNU archive site."
+    touch aclocal.m4
+  autoconf*)
+    echo 1>&2 "\
+         you modified \`${configure_ac}'.  You might want to install the
+         \`Autoconf' and \`GNU m4' packages.  Grab them from any GNU
+         archive site."
+    touch configure
+  autoheader*)
+    echo 1>&2 "\
+         you modified \`acconfig.h' or \`${configure_ac}'.  You might want
+         to install the \`Autoconf' and \`GNU m4' packages.  Grab them
+         from any GNU archive site."
+    files=`sed -n 's/^[ ]*A[CM]_CONFIG_HEADER(\([^)]*\)).*/\1/p' ${configure_ac}`
+    test -z "$files" && files="config.h"
+    touch_files=
+    for f in $files; do
+      case $f in
+      *:*) touch_files="$touch_files "`echo "$f" |
+				       sed -e 's/^[^:]*://' -e 's/:.*//'`;;
+      *) touch_files="$touch_files $f.in";;
+      esac
+    done
+    touch $touch_files
+  automake*)
+    echo 1>&2 "\
+         you modified \`Makefile.am', \`acinclude.m4' or \`${configure_ac}'.
+         You might want to install the \`Automake' and \`Perl' packages.
+         Grab them from any GNU archive site."
+    find . -type f -name Makefile.am -print |
+	   sed 's/\.am$/.in/' |
+	   while read f; do touch "$f"; done
+  autom4te*)
+    echo 1>&2 "\
+WARNING: \`$1' is needed, but is $msg.
+         You might have modified some files without having the
+         proper tools for further handling them.
+         You can get \`$1' as part of \`Autoconf' from any GNU
+         archive site."
+    file=`echo "$*" | sed -n "$sed_output"`
+    test -z "$file" && file=`echo "$*" | sed -n "$sed_minuso"`
+    if test -f "$file"; then
+	touch $file
+    else
+	test -z "$file" || exec >$file
+	echo "#! /bin/sh"
+	echo "# Created by GNU Automake missing as a replacement of"
+	echo "#  $ $@"
+	echo "exit 0"
+	chmod +x $file
+	exit 1
+    fi
+  bison*|yacc*)
+    echo 1>&2 "\
+WARNING: \`$1' $msg.  You should only need it if
+         you modified a \`.y' file.  You may need the \`Bison' package
+         in order for those modifications to take effect.  You can get
+         \`Bison' from any GNU archive site."
+    rm -f y.tab.c y.tab.h
+    if test $# -ne 1; then
+        eval LASTARG="\${$#}"
+	case $LASTARG in
+	*.y)
+	    SRCFILE=`echo "$LASTARG" | sed 's/y$/c/'`
+	    if test -f "$SRCFILE"; then
+	         cp "$SRCFILE" y.tab.c
+	    fi
+	    SRCFILE=`echo "$LASTARG" | sed 's/y$/h/'`
+	         cp "$SRCFILE" y.tab.h
+	    fi
+	esac
+    fi
+    if test ! -f y.tab.h; then
+	echo >y.tab.h
+    fi
+    if test ! -f y.tab.c; then
+	echo 'main() { return 0; }' >y.tab.c
+    fi
+  lex*|flex*)
+    echo 1>&2 "\
+         you modified a \`.l' file.  You may need the \`Flex' package
+         \`Flex' from any GNU archive site."
+    rm -f lex.yy.c
+	case $LASTARG in
+	*.l)
+	    SRCFILE=`echo "$LASTARG" | sed 's/l$/c/'`
+	         cp "$SRCFILE" lex.yy.c
+	    fi
+	esac
+    fi
+    if test ! -f lex.yy.c; then
+	echo 'main() { return 0; }' >lex.yy.c
+    fi
+  help2man*)
+    echo 1>&2 "\
+	 you modified a dependency of a manual page.  You may need the
+	 \`Help2man' package in order for those modifications to take
+	 effect.  You can get \`Help2man' from any GNU archive site."
+	touch $file
+    else
+	echo ".ab help2man is required to generate this page"
+	exit $?
+    fi
+  makeinfo*)
+    echo 1>&2 "\
+         you modified a \`.texi' or \`.texinfo' file, or any other file
+         indirectly affecting the aspect of the manual.  The spurious
+         call might also be the consequence of using a buggy \`make' (AIX,
+         DU, IRIX).  You might want to install the \`Texinfo' package or
+         the \`GNU make' package.  Grab either from any GNU archive site."
+    # The file to touch is that specified with -o ...
+    if test -z "$file"; then
+      # ... or it is the one specified with @setfilename ...
+      infile=`echo "$*" | sed 's/.* \([^ ]*\) *$/\1/'`
+      file=`sed -n '
+	/^@setfilename/{
+	  s/.* \([^ ]*\) *$/\1/
+	  p
+	  q
+	}' $infile`
+      # ... or it is derived from the source name (dir/f.texi becomes f.info)
+      test -z "$file" && file=`echo "$infile" | sed 's,.*/,,;s,.[^.]*$,,'`.info
+    fi
+    # If the file does not exist, the user really needs makeinfo;
+    # let's fail without touching anything.
+    test -f $file || exit 1
+    touch $file
+  tar*)
+    shift
+    # We have already tried tar in the generic part.
+    # Look for gnutar/gtar before invocation to avoid ugly error
+    # messages.
+    if (gnutar --version > /dev/null 2>&1); then
+       gnutar "$@" && exit 0
+    fi
+    if (gtar --version > /dev/null 2>&1); then
+       gtar "$@" && exit 0
+    fi
+    firstarg="$1"
+    if shift; then
+	case $firstarg in
+	*o*)
+	    firstarg=`echo "$firstarg" | sed s/o//`
+	    tar "$firstarg" "$@" && exit 0
+	esac
+	case $firstarg in
+	*h*)
+	    firstarg=`echo "$firstarg" | sed s/h//`
+	esac
+    fi
+    echo 1>&2 "\
+WARNING: I can't seem to be able to run \`tar' with the given arguments.
+         You may want to install GNU tar or Free paxutils, or check the
+         command line arguments."
+    exit 1
+    echo 1>&2 "\
+WARNING: \`$1' is needed, and is $msg.
+         proper tools for further handling them.  Check the \`README' file,
+         it often tells you about the needed prerequisites for installing
+         this package.  You may also peek at any GNU archive site, in case
+         some other package would contain this missing \`$1' program."
+    exit 1
+esac
+exit 0
+# Local variables:
+# End:
Property changes on: mpich2/trunk/confdb/missing
More information about the mpich2-commits
