[mpich2-commits] r5583 - mpich2/trunk/confdb
    balaji at mcs.anl.gov
    Tue Oct 27 16:34:17 CDT 2009
Author: balaji
Date: 2009-10-27 16:34:17 -0500 (Tue, 27 Oct 2009)
New Revision: 5583
Added:
   mpich2/trunk/confdb/ltmain.sh
Log:
Added ltmain.sh (version 2.2.6) to work with libtool.
Added: mpich2/trunk/confdb/ltmain.sh
--- mpich2/trunk/confdb/ltmain.sh	                        (rev 0)
+++ mpich2/trunk/confdb/ltmain.sh	2009-10-27 21:34:17 UTC (rev 5583)
@@ -0,0 +1,8406 @@
+# Generated from ltmain.m4sh.
+# ltmain.sh (GNU libtool) 2.2.6
+# Written by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005, 2006, 2007 2008 Free Software Foundation, Inc.
+# This is free software; see the source for copying conditions.  There is NO
+# warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+# GNU Libtool is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# As a special exception to the GNU General Public License,
+# if you distribute this file as part of a program or library that
+# is built using GNU Libtool, you may include this file under the
+# same distribution terms that you use for the rest of that program.
+# GNU Libtool is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with GNU Libtool; see the file COPYING.  If not, a copy
+# can be downloaded from http://www.gnu.org/licenses/gpl.html,
+# or obtained by writing to the Free Software Foundation, Inc.,
+# 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+# Usage: $progname [OPTION]... [MODE-ARG]...
+# Provide generalized library-building support services.
+#     --config             show all configuration variables
+#     --debug              enable verbose shell tracing
+# -n, --dry-run            display commands without modifying any files
+#     --features           display basic configuration information and exit
+#     --mode=MODE          use operation mode MODE
+#     --preserve-dup-deps  don't remove duplicate dependency libraries
+#     --quiet, --silent    don't print informational messages
+#     --tag=TAG            use configuration variables from tag TAG
+# -v, --verbose            print informational messages (default)
+#     --version            print version information
+# -h, --help               print short or long help message
+# MODE must be one of the following:
+#       clean              remove files from the build directory
+#       compile            compile a source file into a libtool object
+#       execute            automatically set library path, then run a program
+#       finish             complete the installation of libtool libraries
+#       install            install libraries or executables
+#       link               create a library or an executable
+#       uninstall          remove libraries from an installed directory
+# MODE-ARGS vary depending on the MODE.
+# Try `$progname --help --mode=MODE' for a more detailed description of MODE.
+# When reporting a bug, please describe a test case to reproduce it and
+# include the following information:
+#       host-triplet:	$host
+#       shell:		$SHELL
+#       compiler:		$LTCC
+#       compiler flags:		$LTCFLAGS
+#       linker:		$LD (gnu? $with_gnu_ld)
+#       $progname:		(GNU libtool) 2.2.6
+#       automake:		$automake_version
+#       autoconf:		$autoconf_version
+# Report bugs to <bug-libtool at gnu.org>.
+PROGRAM=ltmain.sh
+PACKAGE=libtool
+VERSION=2.2.6
+TIMESTAMP=""
+package_revision=1.3012
+# Be Bourne compatible
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '${1+"$@"}'='"$@"'
+  setopt NO_GLOB_SUBST
+else
+  case `(set -o) 2>/dev/null` in *posix*) set -o posix;; esac
+fi
+BIN_SH=xpg4; export BIN_SH # for Tru64
+DUALCASE=1; export DUALCASE # for MKS sh
+# NLS nuisances: We save the old values to restore during execute mode.
+# Only set LANG and LC_ALL to C if already set.
+# These must not be set unconditionally because not all systems understand
+# e.g. LANG=C (notably SCO).
+lt_user_locale=
+lt_safe_locale=
+for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
+do
+  eval "if test \"\${$lt_var+set}\" = set; then
+          save_$lt_var=\$$lt_var
+          $lt_var=C
+	  export $lt_var
+	  lt_user_locale=\"$lt_var=\\\$save_\$lt_var; \$lt_user_locale\"
+	  lt_safe_locale=\"$lt_var=C; \$lt_safe_locale\"
+	fi"
+done
+$lt_unset CDPATH
+: ${CP="cp -f"}
+: ${ECHO="echo"}
+: ${EGREP="/usr/bin/grep -E"}
+: ${FGREP="/usr/bin/grep -F"}
+: ${GREP="/usr/bin/grep"}
+: ${LN_S="ln -s"}
+: ${MAKE="make"}
+: ${MKDIR="mkdir"}
+: ${MV="mv -f"}
+: ${RM="rm -f"}
+: ${SED="/opt/local/bin/gsed"}
+: ${SHELL="${CONFIG_SHELL-/bin/sh}"}
+: ${Xsed="$SED -e 1s/^X//"}
+# Global variables:
+EXIT_SUCCESS=0
+EXIT_FAILURE=1
+EXIT_MISMATCH=63  # $? = 63 is used to indicate version mismatch to missing.
+EXIT_SKIP=77	  # $? = 77 is used to indicate a skipped test to automake.
+exit_status=$EXIT_SUCCESS
+# Make sure IFS has a sensible default
+lt_nl='
+IFS=" 	$lt_nl"
+dirname="s,/[^/]*$,,"
+basename="s,^.*/,,"
+# func_dirname_and_basename file append nondir_replacement
+# perform func_basename and func_dirname in a single function
+# call:
+#   dirname:  Compute the dirname of FILE.  If nonempty,
+#             add APPEND to the result, otherwise set result
+#             to NONDIR_REPLACEMENT.
+#             value returned in "$func_dirname_result"
+#   basename: Compute filename of FILE.
+#             value retuned in "$func_basename_result"
+# Implementation must be kept synchronized with func_dirname
+# and func_basename. For efficiency, we do not delegate to
+# those functions but instead duplicate the functionality here.
+func_dirname_and_basename ()
+  # Extract subdirectory from the argument.
+  func_dirname_result=`$ECHO "X${1}" | $Xsed -e "$dirname"`
+  if test "X$func_dirname_result" = "X${1}"; then
+    func_dirname_result="${3}"
+  else
+    func_dirname_result="$func_dirname_result${2}"
+  fi
+  func_basename_result=`$ECHO "X${1}" | $Xsed -e "$basename"`
+# Generated shell functions inserted here.
+# Work around backward compatibility issue on IRIX 6.5. On IRIX 6.4+, sh
+# is ksh but when the shell is invoked as "sh" and the current value of
+# the _XPG environment variable is not equal to 1 (one), the special
+# positional parameter $0, within a function call, is the name of the
+# function.
+progpath="$0"
+# The name of this program:
+# In the unlikely event $progname began with a '-', it would play havoc with
+# func_echo (imagine progname=-n), so we prepend ./ in that case:
+func_dirname_and_basename "$progpath"
+progname=$func_basename_result
+case $progname in
+  -*) progname=./$progname ;;
+esac
+# Make sure we have an absolute path for reexecution:
+case $progpath in
+  [\\/]*|[A-Za-z]:\\*) ;;
+     progdir=$func_dirname_result
+     progdir=`cd "$progdir" && pwd`
+     progpath="$progdir/$progname"
+     save_IFS="$IFS"
+     IFS=:
+     for progdir in $PATH; do
+       IFS="$save_IFS"
+       test -x "$progdir/$progname" && break
+     done
+     IFS="$save_IFS"
+     test -n "$progdir" || progdir=`pwd`
+esac
+# Sed substitution that helps us do robust quoting.  It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed="${SED}"' -e 1s/^X//'
+sed_quote_subst='s/\([`"$\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\(["`\\]\)/\\\1/g'
+# Re-`\' parameter expansions in output of double_quote_subst that were
+# `\'-ed in input to the same.  If an odd number of `\' preceded a '$'
+# in input to double_quote_subst, that '$' was protected from expansion.
+# Since each input `\' is now two `\'s, look for any number of runs of
+# four `\'s followed by two `\'s and then a '$'.  `\' that '$'.
+bs='\\'
+bs2='\\\\'
+bs4='\\\\\\\\'
+dollar='\$'
+sed_double_backslash="\
+  s/$bs4/&\\
+/g
+  s/^$bs2$dollar/$bs&/
+  s/\\([^$bs]\\)$bs2$dollar/\\1$bs2$bs$dollar/g
+  s/\n//g"
+# Standard options:
+opt_dry_run=false
+opt_help=false
+opt_quiet=false
+opt_verbose=false
+opt_warning=:
+# func_echo arg...
+# Echo program name prefixed message, along with the current mode
+# name if it has been set yet.
+func_echo ()
+    $ECHO "$progname${mode+: }$mode: $*"
+# func_verbose arg...
+# Echo program name prefixed message in verbose mode only.
+func_verbose ()
+    $opt_verbose && func_echo ${1+"$@"}
+    # A bug in bash halts the script if the last line of a function
+    # fails when set -e is in force, so we need another command to
+    # work around that:
+# func_error arg...
+# Echo program name prefixed message to standard error.
+func_error ()
+    $ECHO "$progname${mode+: }$mode: "${1+"$@"} 1>&2
+# func_warning arg...
+# Echo program name prefixed warning message to standard error.
+func_warning ()
+    $opt_warning && $ECHO "$progname${mode+: }$mode: warning: "${1+"$@"} 1>&2
+    # bash bug again:
+# func_fatal_error arg...
+# Echo program name prefixed message to standard error, and exit.
+func_fatal_error ()
+    func_error ${1+"$@"}
+    exit $EXIT_FAILURE
+# func_fatal_help arg...
+# Echo program name prefixed message to standard error, followed by
+# a help hint, and exit.
+func_fatal_help ()
+    func_fatal_error "$help"
+help="Try \`$progname --help' for more information."  ## default
+# func_grep expression filename
+# Check whether EXPRESSION matches any line of FILENAME, without output.
+func_grep ()
+    $GREP "$1" "$2" >/dev/null 2>&1
+# func_mkdir_p directory-path
+# Make sure the entire path to DIRECTORY-PATH is available.
+func_mkdir_p ()
+    my_directory_path="$1"
+    my_dir_list=
+    if test -n "$my_directory_path" && test "$opt_dry_run" != ":"; then
+      # Protect directory names starting with `-'
+      case $my_directory_path in
+        -*) my_directory_path="./$my_directory_path" ;;
+      esac
+      # While some portion of DIR does not yet exist...
+      while test ! -d "$my_directory_path"; do
+        # ...make a list in topmost first order.  Use a colon delimited
+	# list incase some portion of path contains whitespace.
+        my_dir_list="$my_directory_path:$my_dir_list"
+        # If the last portion added has no slash in it, the list is done
+        case $my_directory_path in */*) ;; *) break ;; esac
+        # ...otherwise throw away the child directory and loop
+        my_directory_path=`$ECHO "X$my_directory_path" | $Xsed -e "$dirname"`
+      done
+      my_dir_list=`$ECHO "X$my_dir_list" | $Xsed -e 's,:*$,,'`
+      save_mkdir_p_IFS="$IFS"; IFS=':'
+      for my_dir in $my_dir_list; do
+	IFS="$save_mkdir_p_IFS"
+        # mkdir can fail with a `File exist' error if two processes
+        # try to create one of the directories concurrently.  Don't
+        # stop in that case!
+        $MKDIR "$my_dir" 2>/dev/null || :
+      done
+      # Bail out if we (or some other process) failed to create a directory.
+      test -d "$my_directory_path" || \
+        func_fatal_error "Failed to create \`$1'"
+    fi
+# func_mktempdir [string]
+# Make a temporary directory that won't clash with other running
+# libtool processes, and avoids race conditions if possible.  If
+# given, STRING is the basename for that directory.
+func_mktempdir ()
+    my_template="${TMPDIR-/tmp}/${1-$progname}"
+    if test "$opt_dry_run" = ":"; then
+      # Return a directory name, but don't create it in dry-run mode
+      my_tmpdir="${my_template}-$$"
+    else
+      # If mktemp works, use that first and foremost
+      my_tmpdir=`mktemp -d "${my_template}-XXXXXXXX" 2>/dev/null`
+      if test ! -d "$my_tmpdir"; then
+        # Failing that, at least try and use $RANDOM to avoid a race
+        my_tmpdir="${my_template}-${RANDOM-0}$$"
+        save_mktempdir_umask=`umask`
+        umask 0077
+        $MKDIR "$my_tmpdir"
+        umask $save_mktempdir_umask
+      fi
+      # If we're not in dry-run mode, bomb out on failure
+      test -d "$my_tmpdir" || \
+        func_fatal_error "cannot create temporary directory \`$my_tmpdir'"
+    fi
+    $ECHO "X$my_tmpdir" | $Xsed
+# func_quote_for_eval arg
+# Aesthetically quote ARG to be evaled later.
+# This function returns two values: FUNC_QUOTE_FOR_EVAL_RESULT
+# is double-quoted, suitable for a subsequent eval, whereas
+# FUNC_QUOTE_FOR_EVAL_UNQUOTED_RESULT has merely all characters
+# which are still active within double quotes backslashified.
+func_quote_for_eval ()
+    case $1 in
+	func_quote_for_eval_unquoted_result=`$ECHO "X$1" | $Xsed -e "$sed_quote_subst"` ;;
+        func_quote_for_eval_unquoted_result="$1" ;;
+    esac
+    case $func_quote_for_eval_unquoted_result in
+      # Double-quote args containing shell metacharacters to delay
+      # word splitting, command substitution and and variable
+      # expansion for a subsequent eval.
+      # Many Bourne shells cannot handle close brackets correctly
+      # in scan sets, so we specify it separately.
+        func_quote_for_eval_result="\"$func_quote_for_eval_unquoted_result\""
+        func_quote_for_eval_result="$func_quote_for_eval_unquoted_result"
+    esac
+# func_quote_for_expand arg
+# Aesthetically quote ARG to be evaled later; same as above,
+# but do not quote variable references.
+func_quote_for_expand ()
+    case $1 in
+	my_arg=`$ECHO "X$1" | $Xsed \
+	    -e "$double_quote_subst" -e "$sed_double_backslash"` ;;
+        my_arg="$1" ;;
+    esac
+    case $my_arg in
+      # word splitting and command substitution for a subsequent eval.
+        my_arg="\"$my_arg\""
+    esac
+    func_quote_for_expand_result="$my_arg"
+# func_show_eval cmd [fail_exp]
+# Unless opt_silent is true, then output CMD.  Then, if opt_dryrun is
+# not true, evaluate CMD.  If the evaluation of CMD fails, and FAIL_EXP
+# is given, then evaluate it.
+func_show_eval ()
+    my_cmd="$1"
+    my_fail_exp="${2-:}"
+    ${opt_silent-false} || {
+      func_quote_for_expand "$my_cmd"
+      eval "func_echo $func_quote_for_expand_result"
+    if ${opt_dry_run-false}; then :; else
+      eval "$my_cmd"
+      my_status=$?
+      if test "$my_status" -eq 0; then :; else
+	eval "(exit $my_status); $my_fail_exp"
+      fi
+    fi
+# func_show_eval_locale cmd [fail_exp]
+# is given, then evaluate it.  Use the saved locale for evaluation.
+func_show_eval_locale ()
+    my_cmd="$1"
+      eval "$lt_user_locale
+	    $my_cmd"
+      my_status=$?
+      eval "$lt_safe_locale"
+      fi
+    fi
+# func_version
+# Echo version message to standard output and exit.
+func_version ()
+    $SED -n '/^# '$PROGRAM' (GNU /,/# warranty; / {
+        s/^# //
+	s/^# *$//
+        s/\((C)\)[ 0-9,-]*\( [1-9][0-9]*\)/\1\2/
+        p
+     }' < "$progpath"
+     exit $?
+# func_usage
+# Echo short help message to standard output and exit.
+func_usage ()
+    $SED -n '/^# Usage:/,/# -h/ {
+        s/^# //
+	s/^# *$//
+	s/\$progname/'$progname'/
+	p
+    }' < "$progpath"
+    $ECHO
+    $ECHO "run \`$progname --help | more' for full usage"
+    exit $?
+# func_help
+# Echo long help message to standard output and exit.
+func_help ()
+    $SED -n '/^# Usage:/,/# Report bugs to/ {
+        s/^# //
+	s/^# *$//
+	s*\$progname*'$progname'*
+	s*\$host*'"$host"'*
+	s*\$SHELL*'"$SHELL"'*
+	s*\$LTCC*'"$LTCC"'*
+	s*\$LTCFLAGS*'"$LTCFLAGS"'*
+	s*\$LD*'"$LD"'*
+	s/\$with_gnu_ld/'"$with_gnu_ld"'/
+	s/\$automake_version/'"`(automake --version) 2>/dev/null |$SED 1q`"'/
+	s/\$autoconf_version/'"`(autoconf --version) 2>/dev/null |$SED 1q`"'/
+	p
+     }' < "$progpath"
+    exit $?
+# func_missing_arg argname
+# Echo program name prefixed message to standard error and set global
+# exit_cmd.
+func_missing_arg ()
+    func_error "missing argument for $1"
+    exit_cmd=exit
+exit_cmd=:
+# Check that we have a working $ECHO.
+if test "X$1" = X--no-reexec; then
+  # Discard the --no-reexec flag, and continue.
+  shift
+elif test "X$1" = X--fallback-echo; then
+  # Avoid inline document here, it may be left over
+elif test "X`{ $ECHO '\t'; } 2>/dev/null`" = 'X\t'; then
+  # Yippee, $ECHO works!
+else
+  # Restart under the correct shell, and then maybe $ECHO will work.
+  exec $SHELL "$progpath" --no-reexec ${1+"$@"}
+fi
+if test "X$1" = X--fallback-echo; then
+  # used as fallback echo
+  shift
+  cat <<EOF
+EOF
+  exit $EXIT_SUCCESS
+fi
+magic="%%%MAGIC variable%%%"
+magic_exe="%%%MAGIC EXE variable%%%"
+# Global variables.
+# $mode is unset
+nonopt=
+execute_dlfiles=
+preserve_args=
+lo2o="s/\\.lo\$/.${objext}/"
+o2lo="s/\\.${objext}\$/.lo/"
+extracted_archives=
+extracted_serial=0
+opt_dry_run=false
+opt_duplicate_deps=false
+opt_silent=false
+opt_debug=:
+# If this variable is set in any of the actions, the command in it
+# will be execed at the end.  This prevents here-documents from being
+# left over by shells.
+exec_cmd=
+# func_fatal_configuration arg...
+# a configuration failure hint, and exit.
+func_fatal_configuration ()
+    func_error "See the $PACKAGE documentation for more information."
+    func_fatal_error "Fatal configuration error."
+# func_config
+# Display the configuration for all the tags in this script.
+func_config ()
+    re_begincf='^# ### BEGIN LIBTOOL'
+    re_endcf='^# ### END LIBTOOL'
+    # Default configuration.
+    $SED "1,/$re_begincf CONFIG/d;/$re_endcf CONFIG/,\$d" < "$progpath"
+    # Now print the configurations for the tags.
+    for tagname in $taglist; do
+      $SED -n "/$re_begincf TAG CONFIG: $tagname\$/,/$re_endcf TAG CONFIG: $tagname\$/p" < "$progpath"
+    done
+    exit $?
+# func_features
+# Display the features supported by this script.
+func_features ()
+    $ECHO "host: $host"
+    if test "$build_libtool_libs" = yes; then
+      $ECHO "enable shared libraries"
+    else
+      $ECHO "disable shared libraries"
+    fi
+    if test "$build_old_libs" = yes; then
+      $ECHO "enable static libraries"
+    else
+      $ECHO "disable static libraries"
+    fi
+    exit $?
+# func_enable_tag tagname
+# Verify that TAGNAME is valid, and either flag an error and exit, or
+# enable the TAGNAME tag.  We also add TAGNAME to the global $taglist
+# variable here.
+func_enable_tag ()
+  # Global variable:
+  tagname="$1"
+  re_begincf="^# ### BEGIN LIBTOOL TAG CONFIG: $tagname\$"
+  re_endcf="^# ### END LIBTOOL TAG CONFIG: $tagname\$"
+  sed_extractcf="/$re_begincf/,/$re_endcf/p"
+  # Validate tagname.
+  case $tagname in
+    *[!-_A-Za-z0-9,/]*)
+      func_fatal_error "invalid tag name: $tagname"
+  esac
+  # Don't test for the "default" C tag, as we know it's
+  # there but not specially marked.
+  case $tagname in
+    CC) ;;
+      if $GREP "$re_begincf" "$progpath" >/dev/null 2>&1; then
+	taglist="$taglist $tagname"
+	# Evaluate the configuration.  Be careful to quote the path
+	# and the sed script, to avoid splitting on whitespace, but
+	# also don't use non-portable quotes within backquotes within
+	# quotes we have to do it in 2 steps:
+	extractedcf=`$SED -n -e "$sed_extractcf" < "$progpath"`
+	eval "$extractedcf"
+      else
+	func_error "ignoring unknown tag $tagname"
+      fi
+  esac
+# Parse options once, thoroughly.  This comes as soon as possible in
+# the script to make things like `libtool --version' happen quickly.
+  # Shorthand for --mode=foo, only valid as the first argument
+  case $1 in
+  clean|clea|cle|cl)
+    shift; set dummy --mode clean ${1+"$@"}; shift
+  compile|compil|compi|comp|com|co|c)
+    shift; set dummy --mode compile ${1+"$@"}; shift
+  execute|execut|execu|exec|exe|ex|e)
+    shift; set dummy --mode execute ${1+"$@"}; shift
+  finish|finis|fini|fin|fi|f)
+    shift; set dummy --mode finish ${1+"$@"}; shift
+  install|instal|insta|inst|ins|in|i)
+    shift; set dummy --mode install ${1+"$@"}; shift
+  link|lin|li|l)
+    shift; set dummy --mode link ${1+"$@"}; shift
+  uninstall|uninstal|uninsta|uninst|unins|unin|uni|un|u)
+    shift; set dummy --mode uninstall ${1+"$@"}; shift
+  esac
+  # Parse non-mode specific arguments:
+  while test "$#" -gt 0; do
+    opt="$1"
+    shift
+    case $opt in
+      --config)		func_config					;;
+      --debug)		preserve_args="$preserve_args $opt"
+			func_echo "enabling shell trace mode"
+			opt_debug='set -x'
+			$opt_debug
+      -dlopen)		test "$#" -eq 0 && func_missing_arg "$opt" && break
+			execute_dlfiles="$execute_dlfiles $1"
+			shift
+      --dry-run | -n)	opt_dry_run=:					;;
+      --features)       func_features					;;
+      --finish)		mode="finish"					;;
+      --mode)		test "$#" -eq 0 && func_missing_arg "$opt" && break
+			case $1 in
+			  # Valid mode arguments:
+			  clean)	;;
+			  compile)	;;
+			  execute)	;;
+			  finish)	;;
+			  install)	;;
+			  link)		;;
+			  relink)	;;
+			  uninstall)	;;
+			  # Catch anything else as an error
+			  *) func_error "invalid argument for $opt"
+			     exit_cmd=exit
+			     break
+		        esac
+			mode="$1"
+			shift
+      --preserve-dup-deps)
+			opt_duplicate_deps=:				;;
+      --quiet|--silent)	preserve_args="$preserve_args $opt"
+			opt_silent=:
+      --verbose| -v)	preserve_args="$preserve_args $opt"
+			opt_silent=false
+      --tag)		test "$#" -eq 0 && func_missing_arg "$opt" && break
+			preserve_args="$preserve_args $opt $1"
+			func_enable_tag "$1"	# tagname is set here
+			shift
+      # Separate optargs to long options:
+      -dlopen=*|--mode=*|--tag=*)
+			func_opt_split "$opt"
+			set dummy "$func_opt_split_opt" "$func_opt_split_arg" ${1+"$@"}
+			shift
+      -\?|-h)		func_usage					;;
+      --help)		opt_help=:					;;
+      --version)	func_version					;;
+      -*)		func_fatal_help "unrecognized option \`$opt'"	;;
+      *)		nonopt="$opt"
+			break
+    esac
+  done
+  case $host in
+    *cygwin* | *mingw* | *pw32* | *cegcc*)
+      # don't eliminate duplications in $postdeps and $predeps
+      opt_duplicate_compiler_generated_deps=:
+      opt_duplicate_compiler_generated_deps=$opt_duplicate_deps
+  esac
+  # Having warned about all mis-specified options, bail out if
+  # anything was wrong.
+  $exit_cmd $EXIT_FAILURE
+# func_check_version_match
+# Ensure that we are using m4 macros, and libtool script from the same
+# release of libtool.
+func_check_version_match ()
+  if test "$package_revision" != "$macro_revision"; then
+    if test "$VERSION" != "$macro_version"; then
+      if test -z "$macro_version"; then
+        cat >&2 <<_LT_EOF
+$progname: Version mismatch error.  This is $PACKAGE $VERSION, but the
+$progname: definition of this LT_INIT comes from an older release.
+$progname: You should recreate aclocal.m4 with macros from $PACKAGE $VERSION
+$progname: and run autoconf again.
+_LT_EOF
+      else
+        cat >&2 <<_LT_EOF
+$progname: definition of this LT_INIT comes from $PACKAGE $macro_version.
+_LT_EOF
+      fi
+    else
+      cat >&2 <<_LT_EOF
+$progname: Version mismatch error.  This is $PACKAGE $VERSION, revision $package_revision,
+$progname: but the definition of this LT_INIT comes from revision $macro_revision.
+$progname: You should recreate aclocal.m4 with macros from revision $package_revision
+$progname: of $PACKAGE $VERSION and run autoconf again.
+_LT_EOF
+    fi
+    exit $EXIT_MISMATCH
+  fi
+##    Main.    ##
+$opt_help || {
+  # Sanity checks first:
+  func_check_version_match
+  if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
+    func_fatal_configuration "not configured to build any kind of library"
+  fi
+  test -z "$mode" && func_fatal_error "error: you must specify a MODE."
+  # Darwin sucks
+  eval std_shrext=\"$shrext_cmds\"
+  # Only execute mode is allowed to have -dlopen flags.
+  if test -n "$execute_dlfiles" && test "$mode" != execute; then
+    func_error "unrecognized option \`-dlopen'"
+    $ECHO "$help" 1>&2
+  fi
+  # Change the help message to a mode-specific one.
+  generic_help="$help"
+  help="Try \`$progname --help --mode=$mode' for more information."
+# func_lalib_p file
+# True iff FILE is a libtool `.la' library or `.lo' object file.
+# This function is only a basic sanity check; it will hardly flush out
+# determined imposters.
+func_lalib_p ()
+    test -f "$1" &&
+      $SED -e 4q "$1" 2>/dev/null \
+        | $GREP "^# Generated by .*$PACKAGE" > /dev/null 2>&1
+# func_lalib_unsafe_p file
+# This function implements the same check as func_lalib_p without
+# resorting to external programs.  To this end, it redirects stdin and
+# closes it afterwards, without saving the original file descriptor.
+# As a safety measure, use it only where a negative result would be
+# fatal anyway.  Works if `file' does not exist.
+func_lalib_unsafe_p ()
+    lalib_p=no
+    if test -f "$1" && test -r "$1" && exec 5<&0 <"$1"; then
+	for lalib_p_l in 1 2 3 4
+	do
+	    read lalib_p_line
+	    case "$lalib_p_line" in
+		\#\ Generated\ by\ *$PACKAGE* ) lalib_p=yes; break;;
+	    esac
+	done
+	exec 0<&5 5<&-
+    fi
+    test "$lalib_p" = yes
+# func_ltwrapper_script_p file
+# True iff FILE is a libtool wrapper script
+func_ltwrapper_script_p ()
+    func_lalib_p "$1"
+# func_ltwrapper_executable_p file
+# True iff FILE is a libtool wrapper executable
+func_ltwrapper_executable_p ()
+    func_ltwrapper_exec_suffix=
+    case $1 in
+    *.exe) ;;
+    *) func_ltwrapper_exec_suffix=.exe ;;
+    esac
+    $GREP "$magic_exe" "$1$func_ltwrapper_exec_suffix" >/dev/null 2>&1
+# func_ltwrapper_scriptname file
+# Assumes file is an ltwrapper_executable
+# uses $file to determine the appropriate filename for a
+# temporary ltwrapper_script.
+func_ltwrapper_scriptname ()
+    func_ltwrapper_scriptname_result=""
+    if func_ltwrapper_executable_p "$1"; then
+	func_dirname_and_basename "$1" "" "."
+	func_stripname '' '.exe' "$func_basename_result"
+	func_ltwrapper_scriptname_result="$func_dirname_result/$objdir/${func_stripname_result}_ltshwrapper"
+    fi
+# func_ltwrapper_p file
+# True iff FILE is a libtool wrapper script or wrapper executable
+func_ltwrapper_p ()
+    func_ltwrapper_script_p "$1" || func_ltwrapper_executable_p "$1"
+# func_execute_cmds commands fail_cmd
+# Execute tilde-delimited COMMANDS.
+# If FAIL_CMD is given, eval that upon failure.
+# FAIL_CMD may read-access the current command in variable CMD!
+func_execute_cmds ()
+    $opt_debug
+    save_ifs=$IFS; IFS='~'
+    for cmd in $1; do
+      IFS=$save_ifs
+      eval cmd=\"$cmd\"
+      func_show_eval "$cmd" "${2-:}"
+    done
+    IFS=$save_ifs
+# func_source file
+# Source FILE, adding directory component if necessary.
+# Note that it is not necessary on cygwin/mingw to append a dot to
+# FILE even if both FILE and FILE.exe exist: automatic-append-.exe
+# behavior happens only for exec(3), not for open(2)!  Also, sourcing
+# `FILE.' does not work on cygwin managed mounts.
+func_source ()
+    $opt_debug
+    case $1 in
+    */* | *\\*)	. "$1" ;;
+    *)		. "./$1" ;;
+    esac
+# func_infer_tag arg
+# Infer tagged configuration to use if any are available and
+# if one wasn't chosen via the "--tag" command line option.
+# Only attempt this if the compiler in the base compile
+# command doesn't match the default compiler.
+# arg is usually of the form 'gcc ...'
+func_infer_tag ()
+    $opt_debug
+    if test -n "$available_tags" && test -z "$tagname"; then
+      CC_quoted=
+      for arg in $CC; do
+        func_quote_for_eval "$arg"
+	CC_quoted="$CC_quoted $func_quote_for_eval_result"
+      done
+      case $@ in
+      # Blanks in the command may have been stripped by the calling shell,
+      # but not from the CC environment variable when configure was run.
+      " $CC "* | "$CC "* | " `$ECHO $CC` "* | "`$ECHO $CC` "* | " $CC_quoted"* | "$CC_quoted "* | " `$ECHO $CC_quoted` "* | "`$ECHO $CC_quoted` "*) ;;
+      # Blanks at the start of $base_compile will cause this to fail
+      # if we don't check for them as well.
+	for z in $available_tags; do
+	  if $GREP "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$progpath" > /dev/null; then
+	    eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $progpath`"
+	    CC_quoted=
+	      # Double-quote args containing other shell metacharacters.
+	    done
+	    case "$@ " in
+	      # The compiler in the base compile command matches
+	      # the one in the tagged configuration.
+	      # Assume this is the tagged configuration we want.
+	      tagname=$z
+	      break
+	    esac
+	  fi
+	done
+	# If $tagname still isn't set, then no tagged configuration
+	# was found and let the user know that the "--tag" command
+	# line option must be used.
+	if test -z "$tagname"; then
+	  func_echo "unable to infer tagged configuration"
+	  func_fatal_error "specify a tag with \`--tag'"
+#	else
+#	  func_verbose "using $tagname tagged configuration"
+	fi
+      esac
+    fi
+# func_write_libtool_object output_name pic_name nonpic_name
+# Create a libtool object file (analogous to a ".la" file),
+# but don't create it if we're doing a dry run.
+func_write_libtool_object ()
+    write_libobj=${1}
+      write_lobj=\'${2}\'
+    else
+      write_lobj=none
+    fi
+      write_oldobj=\'${3}\'
+    else
+      write_oldobj=none
+    fi
+    $opt_dry_run || {
+      cat >${write_libobj}T <<EOF
+# $write_libobj - a libtool object file
+# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
+# Please DO NOT delete this file!
+# It is necessary for linking the library.
+# Name of the PIC object.
+pic_object=$write_lobj
+# Name of the non-PIC object
+non_pic_object=$write_oldobj
+EOF
+      $MV "${write_libobj}T" "${write_libobj}"
+# func_mode_compile arg...
+func_mode_compile ()
+    $opt_debug
+    # Get the compilation command and the source file.
+    base_compile=
+    srcfile="$nonopt"  #  always keep a non-empty value in "srcfile"
+    suppress_opt=yes
+    suppress_output=
+    arg_mode=normal
+    libobj=
+    later=
+    pie_flag=
+    for arg
+    do
+      case $arg_mode in
+      arg  )
+	# do not "continue".  Instead, add this to base_compile
+	lastarg="$arg"
+	arg_mode=normal
+      target )
+	libobj="$arg"
+	arg_mode=normal
+	continue
+      normal )
+	# Accept any command-line options.
+	case $arg in
+	-o)
+	  test -n "$libobj" && \
+	    func_fatal_error "you cannot specify \`-o' more than once"
+	  arg_mode=target
+	  continue
+	-pie | -fpie | -fPIE)
+          pie_flag="$pie_flag $arg"
+	  continue
+	-shared | -static | -prefer-pic | -prefer-non-pic)
+	  later="$later $arg"
+	  continue
+	-no-suppress)
+	  suppress_opt=no
+	  continue
+	-Xcompiler)
+	  arg_mode=arg  #  the next one goes into the "base_compile" arg list
+	  continue      #  The current "srcfile" will either be retained or
+	  ;;            #  replaced later.  I would guess that would be a bug.
+	-Wc,*)
+	  func_stripname '-Wc,' '' "$arg"
+	  args=$func_stripname_result
+	  lastarg=
+	  save_ifs="$IFS"; IFS=','
+	  for arg in $args; do
+	    IFS="$save_ifs"
+	    lastarg="$lastarg $func_quote_for_eval_result"
+	  done
+	  IFS="$save_ifs"
+	  func_stripname ' ' '' "$lastarg"
+	  lastarg=$func_stripname_result
+	  # Add the arguments to base_compile.
+	  base_compile="$base_compile $lastarg"
+	  continue
+	  # Accept the current argument as the source file.
+	  # The previous "srcfile" becomes the current argument.
+	  lastarg="$srcfile"
+	  srcfile="$arg"
+	esac  #  case $arg
+      esac    #  case $arg_mode
+      # Aesthetically quote the previous argument.
+      func_quote_for_eval "$lastarg"
+      base_compile="$base_compile $func_quote_for_eval_result"
+    done # for arg
+    case $arg_mode in
+    arg)
+      func_fatal_error "you must specify an argument for -Xcompile"
+    target)
+      func_fatal_error "you must specify a target with \`-o'"
+      # Get the name of the library object.
+      test -z "$libobj" && {
+	func_basename "$srcfile"
+	libobj="$func_basename_result"
+    esac
+    # Recognize several different file suffixes.
+    # If the user specifies -o file.o, it is replaced with file.lo
+    case $libobj in
+    *.[cCFSifmso] | \
+    *.ada | *.adb | *.ads | *.asm | \
+    *.c++ | *.cc | *.ii | *.class | *.cpp | *.cxx | \
+    *.[fF][09]? | *.for | *.java | *.obj | *.sx)
+      func_xform "$libobj"
+      libobj=$func_xform_result
+    esac
+    case $libobj in
+    *.lo) func_lo2o "$libobj"; obj=$func_lo2o_result ;;
+      func_fatal_error "cannot determine name of library object from \`$libobj'"
+    esac
+    func_infer_tag $base_compile
+    for arg in $later; do
+      case $arg in
+      -shared)
+	test "$build_libtool_libs" != yes && \
+	  func_fatal_configuration "can not build a shared library"
+	build_old_libs=no
+	continue
+      -static)
+	build_libtool_libs=no
+	build_old_libs=yes
+	continue
+      -prefer-pic)
+	pic_mode=yes
+	continue
+      -prefer-non-pic)
+	pic_mode=no
+	continue
+      esac
+    done
+    func_quote_for_eval "$libobj"
+    test "X$libobj" != "X$func_quote_for_eval_result" \
+      && $ECHO "X$libobj" | $GREP '[]~#^*{};<>?"'"'"'	 &()|`$[]' \
+      && func_warning "libobj name \`$libobj' may not contain shell special characters."
+    func_dirname_and_basename "$obj" "/" ""
+    objname="$func_basename_result"
+    xdir="$func_dirname_result"
+    lobj=${xdir}$objdir/$objname
+    test -z "$base_compile" && \
+      func_fatal_help "you must specify a compilation command"
+    # Delete any leftover library objects.
+      removelist="$obj $lobj $libobj ${libobj}T"
+    else
+      removelist="$lobj $libobj ${libobj}T"
+    fi
+    # On Cygwin there's no "real" PIC flag so we must build both object types
+    case $host_os in
+    cygwin* | mingw* | pw32* | os2* | cegcc*)
+      pic_mode=default
+    esac
+    if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
+      # non-PIC code in shared libraries is not supported
+      pic_mode=default
+    fi
+    # Calculate the filename of the output object if compiler does
+    # not support -o with -c
+    if test "$compiler_c_o" = no; then
+      output_obj=`$ECHO "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
+      lockfile="$output_obj.lock"
+    else
+      output_obj=
+      need_locks=no
+      lockfile=
+    fi
+    # Lock this critical section if it is needed
+    # We use this script file to make the link, it avoids creating a new file
+    if test "$need_locks" = yes; then
+      until $opt_dry_run || ln "$progpath" "$lockfile" 2>/dev/null; do
+	func_echo "Waiting for $lockfile to be removed"
+	sleep 2
+      done
+    elif test "$need_locks" = warn; then
+      if test -f "$lockfile"; then
+	$ECHO "\
+*** ERROR, $lockfile exists and contains:
+`cat $lockfile 2>/dev/null`
+This indicates that another process is trying to use the same
+temporary object file, and libtool could not work around it because
+your compiler does not support \`-c' and \`-o' together.  If you
+repeat this compilation, it may succeed, by chance, but you had better
+avoid parallel builds (make -j) in this platform, or get a better
+compiler."
+	$opt_dry_run || $RM $removelist
+      fi
+      removelist="$removelist $output_obj"
+      $ECHO "$srcfile" > "$lockfile"
+    fi
+    removelist="$removelist $lockfile"
+    trap '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE' 1 2 15
+    if test -n "$fix_srcfile_path"; then
+      eval srcfile=\"$fix_srcfile_path\"
+    fi
+    func_quote_for_eval "$srcfile"
+    qsrcfile=$func_quote_for_eval_result
+    # Only build a PIC object if we are building libtool libraries.
+      # Without this assignment, base_compile gets emptied.
+      fbsd_hideous_sh_bug=$base_compile
+      if test "$pic_mode" != no; then
+	command="$base_compile $qsrcfile $pic_flag"
+      else
+	# Don't build PIC code
+	command="$base_compile $qsrcfile"
+      fi
+      func_mkdir_p "$xdir$objdir"
+      if test -z "$output_obj"; then
+	# Place PIC objects in $objdir
+	command="$command -o $lobj"
+      fi
+      func_show_eval_locale "$command"	\
+          'test -n "$output_obj" && $RM $removelist; exit $EXIT_FAILURE'
+      if test "$need_locks" = warn &&
+	 test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
+	$ECHO "\
+*** ERROR, $lockfile contains:
+but it should contain:
+$srcfile
+compiler."
+      fi
+      # Just move the object if needed, then go on to compile the next one
+      if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
+	func_show_eval '$MV "$output_obj" "$lobj"' \
+	  'error=$?; $opt_dry_run || $RM $removelist; exit $error'
+      fi
+      # Allow error messages only from the first compilation.
+      if test "$suppress_opt" = yes; then
+	suppress_output=' >/dev/null 2>&1'
+      fi
+    fi
+    # Only build a position-dependent object if we build old libraries.
+      if test "$pic_mode" != yes; then
+	command="$base_compile $qsrcfile$pie_flag"
+      else
+      fi
+      if test "$compiler_c_o" = yes; then
+	command="$command -o $obj"
+      fi
+      # Suppress compiler output if we already did a PIC compilation.
+      command="$command$suppress_output"
+        '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE'
+	$ECHO "\
+$srcfile
+compiler."
+      fi
+      if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
+	func_show_eval '$MV "$output_obj" "$obj"' \
+      fi
+    fi
+    $opt_dry_run || {
+      func_write_libtool_object "$libobj" "$objdir/$objname" "$objname"
+      # Unlock the critical section if it was locked
+      if test "$need_locks" != no; then
+	removelist=$lockfile
+        $RM "$lockfile"
+      fi
+$opt_help || {
+test "$mode" = compile && func_mode_compile ${1+"$@"}
+func_mode_help ()
+    # We need to display help for each of the modes.
+    case $mode in
+        # Generic help is extracted from the usage comments
+        # at the start of this file.
+        func_help
+      clean)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
+Remove files from the build directory.
+RM is the name of the program to use to delete files associated with each FILE
+(typically \`/bin/rm').  RM-OPTIONS are options (such as \`-f') to be passed
+to RM.
+If FILE is a libtool library, object or program, all the files associated
+with it are deleted. Otherwise, only FILE itself is deleted using RM."
+      compile)
+      $ECHO \
+"Usage: $progname [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
+Compile a source file into a libtool library object.
+This mode accepts the following additional options:
+  -o OUTPUT-FILE    set the output file name to OUTPUT-FILE
+  -no-suppress      do not suppress compiler output for multiple passes
+  -prefer-pic       try to building PIC objects only
+  -prefer-non-pic   try to building non-PIC objects only
+  -shared           do not build a \`.o' file suitable for static linking
+  -static           only build a \`.o' file suitable for static linking
+COMPILE-COMMAND is a command to be used in creating a \`standard' object file
+from the given SOURCEFILE.
+The output file name is determined by removing the directory component from
+SOURCEFILE, then substituting the C source code suffix \`.c' with the
+library object suffix, \`.lo'."
+      execute)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=execute COMMAND [ARGS]...
+Automatically set library path, then run a program.
+  -dlopen FILE      add the directory containing FILE to the library path
+This mode sets the library path environment variable according to \`-dlopen'
+flags.
+If any of the ARGS are libtool executable wrappers, then they are translated
+into their corresponding uninstalled binary, and any of their required library
+directories are added to the library path.
+Then, COMMAND is executed, with ARGS as arguments."
+      finish)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=finish [LIBDIR]...
+Complete the installation of libtool libraries.
+Each LIBDIR is a directory that contains libtool libraries.
+The commands that this mode executes may require superuser privileges.  Use
+the \`--dry-run' option if you just want to see what would be executed."
+      install)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=install INSTALL-COMMAND...
+Install executables or libraries.
+INSTALL-COMMAND is the installation command.  The first component should be
+either the \`install' or \`cp' program.
+The following components of INSTALL-COMMAND are treated specially:
+  -inst-prefix PREFIX-DIR  Use PREFIX-DIR as a staging area for installation
+The rest of the components are interpreted as arguments to that command (only
+BSD-compatible install options are recognized)."
+      link)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=link LINK-COMMAND...
+Link object files or libraries together to form another library, or to
+create an executable program.
+LINK-COMMAND is a command using the C compiler that you would use to create
+a program from several object files.
+The following components of LINK-COMMAND are treated specially:
+  -all-static       do not do any dynamic linking at all
+  -avoid-version    do not add a version suffix if possible
+  -dlopen FILE      \`-dlpreopen' FILE if it cannot be dlopened at runtime
+  -dlpreopen FILE   link in FILE and add its symbols to lt_preloaded_symbols
+  -export-dynamic   allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
+  -export-symbols SYMFILE
+                    try to export only the symbols listed in SYMFILE
+  -export-symbols-regex REGEX
+                    try to export only the symbols matching REGEX
+  -LLIBDIR          search LIBDIR for required installed libraries
+  -lNAME            OUTPUT-FILE requires the installed library libNAME
+  -module           build a library that can dlopened
+  -no-fast-install  disable the fast-install mode
+  -no-install       link a not-installable executable
+  -no-undefined     declare that a library does not refer to external symbols
+  -o OUTPUT-FILE    create OUTPUT-FILE from the specified objects
+  -objectlist FILE  Use a list of object files found in FILE to specify objects
+  -precious-files-regex REGEX
+                    don't remove output files matching REGEX
+  -release RELEASE  specify package release information
+  -rpath LIBDIR     the created library will eventually be installed in LIBDIR
+  -R[ ]LIBDIR       add LIBDIR to the runtime path of programs and libraries
+  -shared           only do dynamic linking of libtool libraries
+  -shrext SUFFIX    override the standard shared library file extension
+  -static           do not do any dynamic linking of uninstalled libtool libraries
+  -static-libtool-libs
+                    do not do any dynamic linking of libtool libraries
+  -version-info CURRENT[:REVISION[:AGE]]
+                    specify library version info [each variable defaults to 0]
+  -weak LIBNAME     declare that the target provides the LIBNAME interface
+All other options (arguments beginning with \`-') are ignored.
+Every other argument is treated as a filename.  Files ending in \`.la' are
+treated as uninstalled libtool libraries, other files are standard or library
+object files.
+If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
+only library objects (\`.lo' files) may be specified, and \`-rpath' is
+required, except when creating a convenience library.
+If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
+using \`ar' and \`ranlib', or on Windows using \`lib'.
+If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
+is created, otherwise an executable program is created."
+      uninstall)
+        $ECHO \
+"Usage: $progname [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
+Remove libraries from an installation directory.
+to RM.
+If FILE is a libtool library, all the files associated with it are deleted.
+Otherwise, only FILE itself is deleted using RM."
+        func_fatal_help "invalid operation mode \`$mode'"
+    esac
+    $ECHO
+    $ECHO "Try \`$progname --help' for more information about other modes."
+    exit $?
+  # Now that we've collected a possible --mode arg, show help if necessary
+  $opt_help && func_mode_help
+# func_mode_execute arg...
+func_mode_execute ()
+    $opt_debug
+    # The first argument is the command name.
+    cmd="$nonopt"
+    test -z "$cmd" && \
+      func_fatal_help "you must specify a COMMAND"
+    # Handle -dlopen flags immediately.
+    for file in $execute_dlfiles; do
+      test -f "$file" \
+	|| func_fatal_help "\`$file' is not a file"
+      dir=
+      case $file in
+      *.la)
+	# Check to see that this really is a libtool archive.
+	func_lalib_unsafe_p "$file" \
+	  || func_fatal_help "\`$lib' is not a valid libtool archive"
+	# Read the libtool library.
+	dlname=
+	library_names=
+	func_source "$file"
+	# Skip this library if it cannot be dlopened.
+	if test -z "$dlname"; then
+	  # Warn if it was a shared library.
+	  test -n "$library_names" && \
+	    func_warning "\`$file' was not linked with \`-export-dynamic'"
+	  continue
+	fi
+	func_dirname "$file" "" "."
+	dir="$func_dirname_result"
+	if test -f "$dir/$objdir/$dlname"; then
+	  dir="$dir/$objdir"
+	else
+	  if test ! -f "$dir/$dlname"; then
+	    func_fatal_error "cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'"
+	  fi
+	fi
+      *.lo)
+	# Just add the directory containing the .lo file.
+	func_warning "\`-dlopen' is ignored for non-libtool libraries and objects"
+	continue
+      esac
+      # Get the absolute pathname.
+      absdir=`cd "$dir" && pwd`
+      test -n "$absdir" && dir="$absdir"
+      # Now add the directory to shlibpath_var.
+      if eval "test -z \"\$$shlibpath_var\""; then
+	eval "$shlibpath_var=\"\$dir\""
+      else
+	eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
+      fi
+    done
+    # This variable tells wrapper scripts just to set shlibpath_var
+    # rather than running their programs.
+    libtool_execute_magic="$magic"
+    # Check if any of the arguments is a wrapper script.
+    args=
+    for file
+    do
+      case $file in
+	# Do a test to see if this is really a libtool program.
+	if func_ltwrapper_script_p "$file"; then
+	  # Transform arg to wrapped name.
+	  file="$progdir/$program"
+	elif func_ltwrapper_executable_p "$file"; then
+	  func_ltwrapper_scriptname "$file"
+	  func_source "$func_ltwrapper_scriptname_result"
+	fi
+      esac
+      # Quote arguments (to preserve shell metacharacters).
+      func_quote_for_eval "$file"
+      args="$args $func_quote_for_eval_result"
+    done
+    if test "X$opt_dry_run" = Xfalse; then
+      if test -n "$shlibpath_var"; then
+	# Export the shlibpath_var.
+	eval "export $shlibpath_var"
+      fi
+      # Restore saved environment variables
+      for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
+      do
+	eval "if test \"\${save_$lt_var+set}\" = set; then
+                $lt_var=\$save_$lt_var; export $lt_var
+	      else
+		$lt_unset $lt_var
+	      fi"
+      done
+      # Now prepare to actually exec the command.
+      exec_cmd="\$cmd$args"
+    else
+      # Display what would be done.
+	eval "\$ECHO \"\$shlibpath_var=\$$shlibpath_var\""
+	$ECHO "export $shlibpath_var"
+      fi
+      $ECHO "$cmd$args"
+    fi
+test "$mode" = execute && func_mode_execute ${1+"$@"}
+# func_mode_finish arg...
+func_mode_finish ()
+    $opt_debug
+    libdirs="$nonopt"
+    admincmds=
+    if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
+      for dir
+      do
+	libdirs="$libdirs $dir"
+      done
+      for libdir in $libdirs; do
+	if test -n "$finish_cmds"; then
+	  # Do each command in the finish commands.
+	  func_execute_cmds "$finish_cmds" 'admincmds="$admincmds
+'"$cmd"'"'
+	fi
+	if test -n "$finish_eval"; then
+	  # Do the single finish_eval.
+	  eval cmds=\"$finish_eval\"
+	  $opt_dry_run || eval "$cmds" || admincmds="$admincmds
+       $cmds"
+	fi
+      done
+    fi
+    # Exit here if they wanted silent mode.
+    $opt_silent && exit $EXIT_SUCCESS
+    $ECHO "X----------------------------------------------------------------------" | $Xsed
+    $ECHO "Libraries have been installed in:"
+      $ECHO "   $libdir"
+    done
+    $ECHO
+    $ECHO "If you ever happen to want to link against installed libraries"
+    $ECHO "in a given directory, LIBDIR, you must either use libtool, and"
+    $ECHO "specify the full pathname of the library, or use the \`-LLIBDIR'"
+    $ECHO "flag during linking and do at least one of the following:"
+      $ECHO "   - add LIBDIR to the \`$shlibpath_var' environment variable"
+      $ECHO "     during execution"
+    fi
+    if test -n "$runpath_var"; then
+      $ECHO "   - add LIBDIR to the \`$runpath_var' environment variable"
+      $ECHO "     during linking"
+    fi
+    if test -n "$hardcode_libdir_flag_spec"; then
+      libdir=LIBDIR
+      eval flag=\"$hardcode_libdir_flag_spec\"
+      $ECHO "   - use the \`$flag' linker flag"
+    fi
+    if test -n "$admincmds"; then
+      $ECHO "   - have your system administrator run these commands:$admincmds"
+    fi
+    if test -f /etc/ld.so.conf; then
+      $ECHO "   - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
+    fi
+    $ECHO
+    $ECHO "See any operating system documentation about shared libraries for"
+    case $host in
+      solaris2.[6789]|solaris2.1[0-9])
+        $ECHO "more information, such as the ld(1), crle(1) and ld.so(8) manual"
+	$ECHO "pages."
+        $ECHO "more information, such as the ld(1) and ld.so(8) manual pages."
+    esac
+test "$mode" = finish && func_mode_finish ${1+"$@"}
+# func_mode_install arg...
+func_mode_install ()
+    $opt_debug
+    # There may be an optional sh(1) argument at the beginning of
+    # install_prog (especially on Windows NT).
+    if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
+       # Allow the use of GNU shtool's install command.
+       $ECHO "X$nonopt" | $GREP shtool >/dev/null; then
+      # Aesthetically quote it.
+      func_quote_for_eval "$nonopt"
+      install_prog="$func_quote_for_eval_result "
+      arg=$1
+      shift
+    else
+      install_prog=
+      arg=$nonopt
+    fi
+    # The real first argument should be the name of the installation program.
+    install_prog="$install_prog$func_quote_for_eval_result"
+    # We need to accept at least all the BSD install flags.
+    dest=
+    files=
+    opts=
+    prev=
+    install_type=
+    isdir=no
+    stripme=
+    for arg
+    do
+      if test -n "$dest"; then
+	files="$files $dest"
+	dest=$arg
+	continue
+      fi
+      case $arg in
+      -d) isdir=yes ;;
+      -f)
+	case " $install_prog " in
+	*[\\\ /]cp\ *) ;;
+	*) prev=$arg ;;
+	esac
+      -g | -m | -o)
+	prev=$arg
+      -s)
+	stripme=" -s"
+	continue
+	# If the previous option needed an argument, then skip it.
+	if test -n "$prev"; then
+	  prev=
+	else
+	  dest=$arg
+	  continue
+	fi
+      esac
+      # Aesthetically quote the argument.
+      install_prog="$install_prog $func_quote_for_eval_result"
+    done
+    test -z "$install_prog" && \
+      func_fatal_help "you must specify an install program"
+    test -n "$prev" && \
+      func_fatal_help "the \`$prev' option requires an argument"
+    if test -z "$files"; then
+      if test -z "$dest"; then
+	func_fatal_help "no file or destination specified"
+      else
+	func_fatal_help "you must specify a destination"
+      fi
+    fi
+    # Strip any trailing slash from the destination.
+    func_stripname '' '/' "$dest"
+    dest=$func_stripname_result
+    # Check to see that the destination is a directory.
+    test -d "$dest" && isdir=yes
+    if test "$isdir" = yes; then
+      destdir="$dest"
+      destname=
+    else
+      func_dirname_and_basename "$dest" "" "."
+      destdir="$func_dirname_result"
+      destname="$func_basename_result"
+      # Not a directory, so check to see that there is only one file specified.
+      set dummy $files; shift
+      test "$#" -gt 1 && \
+	func_fatal_help "\`$dest' is not a directory"
+    fi
+    case $destdir in
+    [\\/]* | [A-Za-z]:[\\/]*) ;;
+      for file in $files; do
+	case $file in
+	*.lo) ;;
+	  func_fatal_help "\`$destdir' must be an absolute directory name"
+	esac
+      done
+    esac
+    # This variable tells wrapper scripts just to set variables rather
+    # than running their programs.
+    libtool_install_magic="$magic"
+    staticlibs=
+    future_libdirs=
+    current_libdirs=
+      # Do each installation.
+      case $file in
+      *.$libext)
+	# Do the static libraries later.
+	staticlibs="$staticlibs $file"
+      *.la)
+	  || func_fatal_help "\`$file' is not a valid libtool archive"
+	library_names=
+	old_library=
+	relink_command=
+	# Add the libdir to current_libdirs if it is the destination.
+	if test "X$destdir" = "X$libdir"; then
+	  case "$current_libdirs " in
+	  *" $libdir "*) ;;
+	  *) current_libdirs="$current_libdirs $libdir" ;;
+	  esac
+	else
+	  # Note the libdir as a future libdir.
+	  case "$future_libdirs " in
+	  *" $libdir "*) ;;
+	  *) future_libdirs="$future_libdirs $libdir" ;;
+	  esac
+	fi
+	func_dirname "$file" "/" ""
+	dir="$dir$objdir"
+	if test -n "$relink_command"; then
+	  # Determine the prefix the user has applied to our future dir.
+	  inst_prefix_dir=`$ECHO "X$destdir" | $Xsed -e "s%$libdir\$%%"`
+	  # Don't allow the user to place us outside of our expected
+	  # location b/c this prevents finding dependent libraries that
+	  # are installed to the same prefix.
+	  # At present, this check doesn't affect windows .dll's that
+	  # are installed into $libdir/../bin (currently, that works fine)
+	  # but it's something to keep an eye on.
+	  test "$inst_prefix_dir" = "$destdir" && \
+	    func_fatal_error "error: cannot install \`$file' to a directory not ending in $libdir"
+	  if test -n "$inst_prefix_dir"; then
+	    # Stick the inst_prefix_dir data into the link command.
+	    relink_command=`$ECHO "X$relink_command" | $Xsed -e "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
+	  else
+	    relink_command=`$ECHO "X$relink_command" | $Xsed -e "s%@inst_prefix_dir@%%"`
+	  fi
+	  func_warning "relinking \`$file'"
+	  func_show_eval "$relink_command" \
+	    'func_fatal_error "error: relink \`$file'\'' with the above command before installing it"'
+	fi
+	# See the names of the shared library.
+	set dummy $library_names; shift
+	if test -n "$1"; then
+	  realname="$1"
+	  shift
+	  srcname="$realname"
+	  test -n "$relink_command" && srcname="$realname"T
+	  # Install the shared library and build the symlinks.
+	  func_show_eval "$install_prog $dir/$srcname $destdir/$realname" \
+	      'exit $?'
+	  tstripme="$stripme"
+	  case $host_os in
+	  cygwin* | mingw* | pw32* | cegcc*)
+	    case $realname in
+	    *.dll.a)
+	      tstripme=""
+	    esac
+	  esac
+	  if test -n "$tstripme" && test -n "$striplib"; then
+	    func_show_eval "$striplib $destdir/$realname" 'exit $?'
+	  fi
+	  if test "$#" -gt 0; then
+	    # Delete the old symlinks, and create new ones.
+	    # Try `ln -sf' first, because the `ln' binary might depend on
+	    # the symlink we replace!  Solaris /bin/ln does not understand -f,
+	    # so we also need to try rm && ln -s.
+	    for linkname
+	    do
+	      test "$linkname" != "$realname" \
+		&& func_show_eval "(cd $destdir && { $LN_S -f $realname $linkname || { $RM $linkname && $LN_S $realname $linkname; }; })"
+	    done
+	  fi
+	  # Do each command in the postinstall commands.
+	  lib="$destdir/$realname"
+	  func_execute_cmds "$postinstall_cmds" 'exit $?'
+	fi
+	# Install the pseudo-library for information purposes.
+	func_basename "$file"
+	name="$func_basename_result"
+	instname="$dir/$name"i
+	func_show_eval "$install_prog $instname $destdir/$name" 'exit $?'
+	# Maybe install the static library, too.
+	test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
+      *.lo)
+	# Install (i.e. copy) a libtool object.
+	# Figure out destination file name, if it wasn't already specified.
+	if test -n "$destname"; then
+	  destfile="$destdir/$destname"
+	else
+	  destfile="$func_basename_result"
+	  destfile="$destdir/$destfile"
+	fi
+	# Deduce the name of the destination old-style object file.
+	case $destfile in
+	*.lo)
+	  func_lo2o "$destfile"
+	  staticdest=$func_lo2o_result
+	*.$objext)
+	  staticdest="$destfile"
+	  destfile=
+	  func_fatal_help "cannot copy a libtool object to \`$destfile'"
+	esac
+	# Install the libtool object if requested.
+	test -n "$destfile" && \
+	  func_show_eval "$install_prog $file $destfile" 'exit $?'
+	# Install the old object if enabled.
+	  # Deduce the name of the old-style object file.
+	  func_lo2o "$file"
+	  staticobj=$func_lo2o_result
+	  func_show_eval "$install_prog \$staticobj \$staticdest" 'exit $?'
+	fi
+	else
+	fi
+	# If the file is missing, and there is a .exe on the end, strip it
+	# because it is most likely a libtool script we actually want to
+	# install
+	stripped_ext=""
+	case $file in
+	  *.exe)
+	    if test ! -f "$file"; then
+	      func_stripname '' '.exe' "$file"
+	      file=$func_stripname_result
+	      stripped_ext=".exe"
+	    fi
+	esac
+	case $host in
+	*cygwin* | *mingw*)
+	    if func_ltwrapper_executable_p "$file"; then
+	      wrapper=$func_ltwrapper_scriptname_result
+	    else
+	      wrapper=$func_stripname_result
+	    fi
+	    wrapper=$file
+	esac
+	if func_ltwrapper_script_p "$wrapper"; then
+	  notinst_deplibs=
+	  relink_command=
+	  func_source "$wrapper"
+	  # Check the variables that should have been set.
+	  test -z "$generated_by_libtool_version" && \
+	    func_fatal_error "invalid libtool wrapper script \`$wrapper'"
+	  finalize=yes
+	  for lib in $notinst_deplibs; do
+	    # Check to see that each library is installed.
+	    libdir=
+	    if test -f "$lib"; then
+	      func_source "$lib"
+	    fi
+	    libfile="$libdir/"`$ECHO "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
+	    if test -n "$libdir" && test ! -f "$libfile"; then
+	      func_warning "\`$lib' has not been installed in \`$libdir'"
+	      finalize=no
+	    fi
+	  done
+	  relink_command=
+	  outputname=
+	  if test "$fast_install" = no && test -n "$relink_command"; then
+	    $opt_dry_run || {
+	      if test "$finalize" = yes; then
+	        tmpdir=`func_mktempdir`
+		func_basename "$file$stripped_ext"
+		file="$func_basename_result"
+	        outputname="$tmpdir/$file"
+	        # Replace the output file specification.
+	        relink_command=`$ECHO "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
+	        $opt_silent || {
+	          func_quote_for_expand "$relink_command"
+	        if eval "$relink_command"; then :
+	          else
+		  func_error "error: relink \`$file' with the above command before installing it"
+		  $opt_dry_run || ${RM}r "$tmpdir"
+		  continue
+	        fi
+	        file="$outputname"
+	      else
+	        func_warning "cannot relink \`$file'"
+	      fi
+	  else
+	    # Install the binary that we compiled earlier.
+	    file=`$ECHO "X$file$stripped_ext" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
+	  fi
+	fi
+	# remove .exe since cygwin /usr/bin/install will append another
+	# one anyway
+	case $install_prog,$host in
+	*/usr/bin/install*,*cygwin*)
+	  case $file:$destfile in
+	  *.exe:*.exe)
+	    # this is ok
+	  *.exe:*)
+	    destfile=$destfile.exe
+	  *:*.exe)
+	    func_stripname '' '.exe' "$destfile"
+	    destfile=$func_stripname_result
+	  esac
+	esac
+	func_show_eval "$install_prog\$stripme \$file \$destfile" 'exit $?'
+	$opt_dry_run || if test -n "$outputname"; then
+	  ${RM}r "$tmpdir"
+	fi
+      esac
+    done
+    for file in $staticlibs; do
+      # Set up the ranlib parameters.
+      oldlib="$destdir/$name"
+      func_show_eval "$install_prog \$file \$oldlib" 'exit $?'
+      if test -n "$stripme" && test -n "$old_striplib"; then
+	func_show_eval "$old_striplib $oldlib" 'exit $?'
+      fi
+      func_execute_cmds "$old_postinstall_cmds" 'exit $?'
+    done
+    test -n "$future_libdirs" && \
+      func_warning "remember to run \`$progname --finish$future_libdirs'"
+    if test -n "$current_libdirs"; then
+      # Maybe just do a dry run.
+      $opt_dry_run && current_libdirs=" -n$current_libdirs"
+      exec_cmd='$SHELL $progpath $preserve_args --finish$current_libdirs'
+    else
+    fi
+test "$mode" = install && func_mode_install ${1+"$@"}
+# func_generate_dlsyms outputname originator pic_p
+# Extract symbols from dlprefiles and create ${outputname}S.o with
+# a dlpreopen symbol table.
+func_generate_dlsyms ()
+    $opt_debug
+    my_outputname="$1"
+    my_originator="$2"
+    my_pic_p="${3-no}"
+    my_prefix=`$ECHO "$my_originator" | sed 's%[^a-zA-Z0-9]%_%g'`
+    my_dlsyms=
+    if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
+      if test -n "$NM" && test -n "$global_symbol_pipe"; then
+	my_dlsyms="${my_outputname}S.c"
+      else
+	func_error "not configured to extract global symbols from dlpreopened files"
+      fi
+    fi
+    if test -n "$my_dlsyms"; then
+      case $my_dlsyms in
+      *.c)
+	# Discover the nlist of each of the dlfiles.
+	nlist="$output_objdir/${my_outputname}.nm"
+	func_show_eval "$RM $nlist ${nlist}S ${nlist}T"
+	# Parse the name list into a source file.
+	func_verbose "creating $output_objdir/$my_dlsyms"
+	$opt_dry_run || $ECHO > "$output_objdir/$my_dlsyms" "\
+/* $my_dlsyms - symbol resolution table for \`$my_outputname' dlsym emulation. */
+/* Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION */
+#ifdef __cplusplus
+extern \"C\" {
+#endif
+/* External symbol declarations for the compiler. */\
+	if test "$dlself" = yes; then
+	  func_verbose "generating symbol list for \`$output'"
+	  $opt_dry_run || echo ': @PROGRAM@ ' > "$nlist"
+	  # Add our own program objects to the symbol list.
+	  progfiles=`$ECHO "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+	  for progfile in $progfiles; do
+	    func_verbose "extracting global C symbols from \`$progfile'"
+	    $opt_dry_run || eval "$NM $progfile | $global_symbol_pipe >> '$nlist'"
+	  done
+	  if test -n "$exclude_expsyms"; then
+	    $opt_dry_run || {
+	      eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
+	      eval '$MV "$nlist"T "$nlist"'
+	  fi
+	  if test -n "$export_symbols_regex"; then
+	    $opt_dry_run || {
+	      eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
+	  fi
+	  # Prepare the list of exported symbols
+	  if test -z "$export_symbols"; then
+	    export_symbols="$output_objdir/$outputname.exp"
+	    $opt_dry_run || {
+	      $RM $export_symbols
+	      eval "${SED} -n -e '/^: @PROGRAM@ $/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
+	      case $host in
+	      *cygwin* | *mingw* | *cegcc* )
+                eval "echo EXPORTS "'> "$output_objdir/$outputname.def"'
+                eval 'cat "$export_symbols" >> "$output_objdir/$outputname.def"'
+	      esac
+	  else
+	    $opt_dry_run || {
+	      eval "${SED} -e 's/\([].[*^$]\)/\\\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$outputname.exp"'
+	      eval '$GREP -f "$output_objdir/$outputname.exp" < "$nlist" > "$nlist"T'
+	      case $host in
+	        *cygwin | *mingw* | *cegcc* )
+	          eval 'cat "$nlist" >> "$output_objdir/$outputname.def"'
+	      esac
+	  fi
+	fi
+	for dlprefile in $dlprefiles; do
+	  func_verbose "extracting global C symbols from \`$dlprefile'"
+	  func_basename "$dlprefile"
+	  $opt_dry_run || {
+	    eval '$ECHO ": $name " >> "$nlist"'
+	    eval "$NM $dlprefile 2>/dev/null | $global_symbol_pipe >> '$nlist'"
+	done
+	$opt_dry_run || {
+	  # Make sure we have at least an empty file.
+	  test -f "$nlist" || : > "$nlist"
+	    $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
+	    $MV "$nlist"T "$nlist"
+	  fi
+	  # Try sorting and uniquifying the output.
+	  if $GREP -v "^: " < "$nlist" |
+	      if sort -k 3 </dev/null >/dev/null 2>&1; then
+		sort -k 3
+	      else
+		sort +2
+	      fi |
+	      uniq > "$nlist"S; then
+	  else
+	    $GREP -v "^: " < "$nlist" > "$nlist"S
+	  fi
+	  if test -f "$nlist"S; then
+	    eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$my_dlsyms"'
+	  else
+	    $ECHO '/* NONE */' >> "$output_objdir/$my_dlsyms"
+	  fi
+	  $ECHO >> "$output_objdir/$my_dlsyms" "\
+/* The mapping between symbol names and symbols.  */
+typedef struct {
+  const char *name;
+  void *address;
+} lt_dlsymlist;
+	  case $host in
+/* DATA imports from DLLs on WIN32 con't be const, because
+   runtime relocations are performed -- see ld's documentation
+   on pseudo-relocs.  */"
+	    lt_dlsym_const= ;;
+	  *osf5*)
+	    echo >> "$output_objdir/$my_dlsyms" "\
+/* This system does not cope well with relocations in const data */"
+	    lt_dlsym_const=const ;;
+	  esac
+extern $lt_dlsym_const lt_dlsymlist
+lt_${my_prefix}_LTX_preloaded_symbols[];
+$lt_dlsym_const lt_dlsymlist
+lt_${my_prefix}_LTX_preloaded_symbols[] =
+  { \"$my_originator\", (void *) 0 },"
+	  case $need_lib_prefix in
+	  no)
+	    eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$my_dlsyms"
+	    eval "$global_symbol_to_c_name_address_lib_prefix" < "$nlist" >> "$output_objdir/$my_dlsyms"
+	  esac
+  {0, (void *) 0}
+/* This works around a problem in FreeBSD linker */
+#ifdef FREEBSD_WORKAROUND
+static const void *lt_preloaded_setup() {
+  return lt_${my_prefix}_LTX_preloaded_symbols;
+#endif
+#ifdef __cplusplus
+#endif\
+	} # !$opt_dry_run
+	pic_flag_for_symtable=
+	case "$compile_command " in
+	*" -static "*) ;;
+	  case $host in
+	  # compiling the symbol table file with pic_flag works around
+	  # a FreeBSD bug that causes programs to crash when -lm is
+	  # linked before any other PIC object.  But we must not use
+	  # pic_flag when linking with -static.  The problem exists in
+	  # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
+	  *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
+	    pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND" ;;
+	  *-*-hpux*)
+	    pic_flag_for_symtable=" $pic_flag"  ;;
+	    if test "X$my_pic_p" != Xno; then
+	    fi
+	  esac
+	esac
+	symtab_cflags=
+	for arg in $LTCFLAGS; do
+	  case $arg in
+	  -pie | -fpie | -fPIE) ;;
+	  *) symtab_cflags="$symtab_cflags $arg" ;;
+	  esac
+	done
+	# Now compile the dynamic symbol file.
+	func_show_eval '(cd $output_objdir && $LTCC$symtab_cflags -c$no_builtin_flag$pic_flag_for_symtable "$my_dlsyms")' 'exit $?'
+	# Clean up the generated files.
+	func_show_eval '$RM "$output_objdir/$my_dlsyms" "$nlist" "${nlist}S" "${nlist}T"'
+	# Transform the symbol file into the correct name.
+	symfileobj="$output_objdir/${my_outputname}S.$objext"
+	case $host in
+	  if test -f "$output_objdir/$my_outputname.def"; then
+	    compile_command=`$ECHO "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
+	    finalize_command=`$ECHO "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
+	  else
+	    compile_command=`$ECHO "X$compile_command" | $Xsed -e "s%@SYMFILE@%$symfileobj%"`
+	    finalize_command=`$ECHO "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$symfileobj%"`
+	  fi
+	esac
+	func_fatal_error "unknown suffix for \`$my_dlsyms'"
+      esac
+    else
+      # We keep going just in case the user didn't refer to
+      # lt_preloaded_symbols.  The linker will fail if global_symbol_pipe
+      # really was required.
+      # Nullify the symbol file.
+      compile_command=`$ECHO "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
+      finalize_command=`$ECHO "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
+    fi
+# func_win32_libid arg
+# return the library type of file 'arg'
+# Need a lot of goo to handle *both* DLLs and import libs
+# Has to be a shell function in order to 'eat' the argument
+# that is supplied when $file_magic_command is called.
+func_win32_libid ()
+  $opt_debug
+  win32_libid_type="unknown"
+  win32_fileres=`file -L $1 2>/dev/null`
+  case $win32_fileres in
+  *ar\ archive\ import\ library*) # definitely import
+    win32_libid_type="x86 archive import"
+  *ar\ archive*) # could be an import, or static
+    if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null |
+       $EGREP 'file format pe-i386(.*architecture: i386)?' >/dev/null ; then
+      win32_nmres=`eval $NM -f posix -A $1 |
+	$SED -n -e '
+	    1,100{
+		/ I /{
+		    s,.*,import,
+		    p
+		    q
+      case $win32_nmres in
+      import*)  win32_libid_type="x86 archive import";;
+      *)        win32_libid_type="x86 archive static";;
+      esac
+    fi
+  *DLL*)
+    win32_libid_type="x86 DLL"
+  *executable*) # but shell scripts are "executable" too...
+    *MS\ Windows\ PE\ Intel*)
+    esac
+  esac
+  $ECHO "$win32_libid_type"
+# func_extract_an_archive dir oldlib
+func_extract_an_archive ()
+    $opt_debug
+    f_ex_an_ar_dir="$1"; shift
+    f_ex_an_ar_oldlib="$1"
+    func_show_eval "(cd \$f_ex_an_ar_dir && $AR x \"\$f_ex_an_ar_oldlib\")" 'exit $?'
+    if ($AR t "$f_ex_an_ar_oldlib" | sort | sort -uc >/dev/null 2>&1); then
+    else
+      func_fatal_error "object name conflicts in archive: $f_ex_an_ar_dir/$f_ex_an_ar_oldlib"
+    fi
+# func_extract_archives gentop oldlib ...
+func_extract_archives ()
+    $opt_debug
+    my_gentop="$1"; shift
+    my_oldlibs=${1+"$@"}
+    my_oldobjs=""
+    my_xlib=""
+    my_xabs=""
+    my_xdir=""
+    for my_xlib in $my_oldlibs; do
+      # Extract the objects.
+      case $my_xlib in
+	[\\/]* | [A-Za-z]:[\\/]*) my_xabs="$my_xlib" ;;
+	*) my_xabs=`pwd`"/$my_xlib" ;;
+      esac
+      func_basename "$my_xlib"
+      my_xlib="$func_basename_result"
+      my_xlib_u=$my_xlib
+      while :; do
+        case " $extracted_archives " in
+	*" $my_xlib_u "*)
+	  func_arith $extracted_serial + 1
+	  extracted_serial=$func_arith_result
+	  my_xlib_u=lt$extracted_serial-$my_xlib ;;
+	*) break ;;
+	esac
+      done
+      extracted_archives="$extracted_archives $my_xlib_u"
+      my_xdir="$my_gentop/$my_xlib_u"
+      func_mkdir_p "$my_xdir"
+      case $host in
+      *-darwin*)
+	func_verbose "Extracting $my_xabs"
+	# Do not bother doing anything if just a dry run
+	$opt_dry_run || {
+	  darwin_orig_dir=`pwd`
+	  cd $my_xdir || exit $?
+	  darwin_archive=$my_xabs
+	  darwin_curdir=`pwd`
+	  darwin_base_archive=`basename "$darwin_archive"`
+	  darwin_arches=`$LIPO -info "$darwin_archive" 2>/dev/null | $GREP Architectures 2>/dev/null || true`
+	  if test -n "$darwin_arches"; then
+	    darwin_arches=`$ECHO "$darwin_arches" | $SED -e 's/.*are://'`
+	    darwin_arch=
+	    func_verbose "$darwin_base_archive has multiple architectures $darwin_arches"
+	    for darwin_arch in  $darwin_arches ; do
+	      func_mkdir_p "unfat-$$/${darwin_base_archive}-${darwin_arch}"
+	      $LIPO -thin $darwin_arch -output "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}" "${darwin_archive}"
+	      cd "unfat-$$/${darwin_base_archive}-${darwin_arch}"
+	      func_extract_an_archive "`pwd`" "${darwin_base_archive}"
+	      cd "$darwin_curdir"
+	      $RM "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}"
+	    done # $darwin_arches
+            ## Okay now we've a bunch of thin objects, gotta fatten them up :)
+	    darwin_filelist=`find unfat-$$ -type f -name \*.o -print -o -name \*.lo -print | $SED -e "$basename" | sort -u`
+	    darwin_file=
+	    darwin_files=
+	    for darwin_file in $darwin_filelist; do
+	      darwin_files=`find unfat-$$ -name $darwin_file -print | $NL2SP`
+	      $LIPO -create -output "$darwin_file" $darwin_files
+	    done # $darwin_filelist
+	    $RM -rf unfat-$$
+	    cd "$darwin_orig_dir"
+	  else
+	    cd $darwin_orig_dir
+	    func_extract_an_archive "$my_xdir" "$my_xabs"
+	  fi # $darwin_arches
+	} # !$opt_dry_run
+      esac
+      my_oldobjs="$my_oldobjs "`find $my_xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
+    done
+    func_extract_archives_result="$my_oldobjs"
+# func_emit_wrapper_part1 [arg=no]
+# Emit the first part of a libtool wrapper script on stdout.
+# For more information, see the description associated with
+# func_emit_wrapper(), below.
+func_emit_wrapper_part1 ()
+	func_emit_wrapper_part1_arg1=no
+	if test -n "$1" ; then
+	  func_emit_wrapper_part1_arg1=$1
+	fi
+	$ECHO "\
+#! $SHELL
+# $output - temporary wrapper script for $objdir/$outputname
+# The $output program cannot be directly executed until all the libtool
+# libraries that it depends on are installed.
+# This wrapper script should never be moved out of the build directory.
+# If it is, it will not operate correctly.
+# Sed substitution that helps us do robust quoting.  It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='${SED} -e 1s/^X//'
+sed_quote_subst='$sed_quote_subst'
+# Be Bourne compatible
+if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on \${1+\"\$@\"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '\${1+\"\$@\"}'='\"\$@\"'
+  setopt NO_GLOB_SUBST
+else
+  case \`(set -o) 2>/dev/null\` in *posix*) set -o posix;; esac
+fi
+BIN_SH=xpg4; export BIN_SH # for Tru64
+DUALCASE=1; export DUALCASE # for MKS sh
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+relink_command=\"$relink_command\"
+# This environment variable determines our operation mode.
+if test \"\$libtool_install_magic\" = \"$magic\"; then
+  # install mode needs the following variables:
+  generated_by_libtool_version='$macro_version'
+  notinst_deplibs='$notinst_deplibs'
+else
+  # When we are sourced in execute mode, \$file and \$ECHO are already set.
+  if test \"\$libtool_execute_magic\" != \"$magic\"; then
+    ECHO=\"$qecho\"
+    file=\"\$0\"
+    # Make sure echo works.
+    if test \"X\$1\" = X--no-reexec; then
+      shift
+    elif test \"X\`{ \$ECHO '\t'; } 2>/dev/null\`\" = 'X\t'; then
+      # Yippee, \$ECHO works!
+    else
+      # Restart under the correct shell, and then maybe \$ECHO will work.
+      exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
+    fi
+  fi\
+	$ECHO "\
+  # Find the directory that this script lives in.
+  thisdir=\`\$ECHO \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
+  test \"x\$thisdir\" = \"x\$file\" && thisdir=.
+  # Follow symbolic links until we get to the real thisdir.
+  file=\`ls -ld \"\$file\" | ${SED} -n 's/.*-> //p'\`
+  while test -n \"\$file\"; do
+    destdir=\`\$ECHO \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
+    # If there was a directory component, then change thisdir.
+    if test \"x\$destdir\" != \"x\$file\"; then
+      case \"\$destdir\" in
+      [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
+      *) thisdir=\"\$thisdir/\$destdir\" ;;
+      esac
+    fi
+    file=\`\$ECHO \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
+    file=\`ls -ld \"\$thisdir/\$file\" | ${SED} -n 's/.*-> //p'\`
+  done
+# end: func_emit_wrapper_part1
+# func_emit_wrapper_part2 [arg=no]
+# Emit the second part of a libtool wrapper script on stdout.
+func_emit_wrapper_part2 ()
+	func_emit_wrapper_part2_arg1=no
+	  func_emit_wrapper_part2_arg1=$1
+	fi
+	$ECHO "\
+  # Usually 'no', except on cygwin/mingw when embedded into
+  # the cwrapper.
+  WRAPPER_SCRIPT_BELONGS_IN_OBJDIR=$func_emit_wrapper_part2_arg1
+  if test \"\$WRAPPER_SCRIPT_BELONGS_IN_OBJDIR\" = \"yes\"; then
+    # special case for '.'
+    if test \"\$thisdir\" = \".\"; then
+      thisdir=\`pwd\`
+    fi
+    # remove .libs from thisdir
+    case \"\$thisdir\" in
+    *[\\\\/]$objdir ) thisdir=\`\$ECHO \"X\$thisdir\" | \$Xsed -e 's%[\\\\/][^\\\\/]*$%%'\` ;;
+    $objdir )   thisdir=. ;;
+    esac
+  fi
+  # Try to get the absolute directory name.
+  absdir=\`cd \"\$thisdir\" && pwd\`
+  test -n \"\$absdir\" && thisdir=\"\$absdir\"
+	if test "$fast_install" = yes; then
+	  $ECHO "\
+  program=lt-'$outputname'$exeext
+  progdir=\"\$thisdir/$objdir\"
+  if test ! -f \"\$progdir/\$program\" ||
+     { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
+       test \"X\$file\" != \"X\$progdir/\$program\"; }; then
+    file=\"\$\$-\$program\"
+    if test ! -d \"\$progdir\"; then
+      $MKDIR \"\$progdir\"
+    else
+      $RM \"\$progdir/\$file\"
+    fi"
+	  $ECHO "\
+    # relink executable if necessary
+    if test -n \"\$relink_command\"; then
+      if relink_command_output=\`eval \$relink_command 2>&1\`; then :
+      else
+	$ECHO \"\$relink_command_output\" >&2
+	exit 1
+      fi
+    fi
+    $MV \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
+    { $RM \"\$progdir/\$program\";
+      $MV \"\$progdir/\$file\" \"\$progdir/\$program\"; }
+  fi"
+	else
+	  $ECHO "\
+  program='$outputname'
+	fi
+	$ECHO "\
+  if test -f \"\$progdir/\$program\"; then"
+	# Export our shlibpath_var if we have one.
+	if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
+	  $ECHO "\
+    # Add our own library path to $shlibpath_var
+    $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
+    # Some systems cannot cope with colon-terminated $shlibpath_var
+    # The second colon is a workaround for a bug in BeOS R4 sed
+    $shlibpath_var=\`\$ECHO \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
+    export $shlibpath_var
+	fi
+	# fixup the dll searchpath if we need to.
+	if test -n "$dllsearchpath"; then
+	  $ECHO "\
+    # Add the dll search path components to the executable PATH
+    PATH=$dllsearchpath:\$PATH
+	fi
+	$ECHO "\
+      # Run the actual program with our arguments.
+	case $host in
+	# Backslashes separate directories on plain windows
+	*-*-mingw | *-*-os2* | *-cegcc*)
+	  $ECHO "\
+      exec \"\$progdir\\\\\$program\" \${1+\"\$@\"}
+	  $ECHO "\
+      exec \"\$progdir/\$program\" \${1+\"\$@\"}
+	esac
+	$ECHO "\
+      \$ECHO \"\$0: cannot exec \$program \$*\" 1>&2
+      exit 1
+    fi
+  else
+    # The program doesn't exist.
+    \$ECHO \"\$0: error: \\\`\$progdir/\$program' does not exist\" 1>&2
+    \$ECHO \"This script is just a wrapper for \$program.\" 1>&2
+    $ECHO \"See the $PACKAGE documentation for more information.\" 1>&2
+    exit 1
+  fi
+fi\
+# end: func_emit_wrapper_part2
+# func_emit_wrapper [arg=no]
+# Emit a libtool wrapper script on stdout.
+# Don't directly open a file because we may want to
+# incorporate the script contents within a cygwin/mingw
+# wrapper executable.  Must ONLY be called from within
+# func_mode_link because it depends on a number of variables
+# set therein.
+# ARG is the value that the WRAPPER_SCRIPT_BELONGS_IN_OBJDIR
+# variable will take.  If 'yes', then the emitted script
+# will assume that the directory in which it is stored is
+# the $objdir directory.  This is a cygwin/mingw-specific
+# behavior.
+func_emit_wrapper ()
+	func_emit_wrapper_arg1=no
+	  func_emit_wrapper_arg1=$1
+	fi
+	# split this up so that func_emit_cwrapperexe_src
+	# can call each part independently.
+	func_emit_wrapper_part1 "${func_emit_wrapper_arg1}"
+	func_emit_wrapper_part2 "${func_emit_wrapper_arg1}"
+# func_to_host_path arg
+# Convert paths to host format when used with build tools.
+# Intended for use with "native" mingw (where libtool itself
+# is running under the msys shell), or in the following cross-
+# build environments:
+#    $build          $host
+#    mingw (msys)    mingw  [e.g. native]
+#    cygwin          mingw
+#    *nix + wine     mingw
+# where wine is equipped with the `winepath' executable.
+# In the native mingw case, the (msys) shell automatically
+# converts paths for any non-msys applications it launches,
+# but that facility isn't available from inside the cwrapper.
+# Similar accommodations are necessary for $host mingw and
+# $build cygwin.  Calling this function does no harm for other
+# $host/$build combinations not listed above.
+# ARG is the path (on $build) that should be converted to
+# the proper representation for $host. The result is stored
+# in $func_to_host_path_result.
+func_to_host_path ()
+  func_to_host_path_result="$1"
+    case $host in
+      *mingw* )
+        lt_sed_naive_backslashify='s|\\\\*|\\|g;s|/|\\|g;s|\\|\\\\|g'
+        case $build in
+          *mingw* ) # actually, msys
+            # awkward: cmd appends spaces to result
+            lt_sed_strip_trailing_spaces="s/[ ]*\$//"
+            func_to_host_path_tmp1=`( cmd //c echo "$1" |\
+              $SED -e "$lt_sed_strip_trailing_spaces" ) 2>/dev/null || echo ""`
+            func_to_host_path_result=`echo "$func_to_host_path_tmp1" |\
+              $SED -e "$lt_sed_naive_backslashify"`
+          *cygwin* )
+            func_to_host_path_tmp1=`cygpath -w "$1"`
+            # Unfortunately, winepath does not exit with a non-zero
+            # error code, so we are forced to check the contents of
+            # stdout. On the other hand, if the command is not
+            # found, the shell will set an exit code of 127 and print
+            # *an error message* to stdout. So we must check for both
+            # error code of zero AND non-empty stdout, which explains
+            # the odd construction:
+            func_to_host_path_tmp1=`winepath -w "$1" 2>/dev/null`
+            if test "$?" -eq 0 && test -n "${func_to_host_path_tmp1}"; then
+            else
+              # Allow warning below.
+              func_to_host_path_result=""
+            fi
+        esac
+        if test -z "$func_to_host_path_result" ; then
+          func_error "Could not determine host path corresponding to"
+          func_error "  '$1'"
+          func_error "Continuing, but uninstalled executables may not work."
+          # Fallback:
+        fi
+    esac
+  fi
+# end: func_to_host_path
+# func_to_host_pathlist arg
+# Convert pathlists to host format when used with build tools.
+# See func_to_host_path(), above. This function supports the
+# following $build/$host combinations (but does no harm for
+# combinations not listed here):
+#    $build          $host
+#    cygwin          mingw
+# Path separators are also converted from $build format to
+# $host format. If ARG begins or ends with a path separator
+# character, it is preserved (but converted to $host format)
+# on output.
+# ARG is a pathlist (on $build) that should be converted to
+# the proper representation on $host. The result is stored
+# in $func_to_host_pathlist_result.
+func_to_host_pathlist ()
+  func_to_host_pathlist_result="$1"
+    case $host in
+      *mingw* )
+        # Remove leading and trailing path separator characters from
+        # ARG. msys behavior is inconsistent here, cygpath turns them
+        # into '.;' and ';.', and winepath ignores them completely.
+        func_to_host_pathlist_tmp2="$1"
+        # Once set for this call, this variable should not be
+        # reassigned. It is used in tha fallback case.
+        func_to_host_pathlist_tmp1=`echo "$func_to_host_pathlist_tmp2" |\
+          $SED -e 's|^:*||' -e 's|:*$||'`
+        case $build in
+          *mingw* ) # Actually, msys.
+            # Awkward: cmd appends spaces to result.
+            func_to_host_pathlist_tmp2=`( cmd //c echo "$func_to_host_pathlist_tmp1" |\
+            func_to_host_pathlist_result=`echo "$func_to_host_pathlist_tmp2" |\
+          *cygwin* )
+            func_to_host_pathlist_tmp2=`cygpath -w -p "$func_to_host_pathlist_tmp1"`
+            # unfortunately, winepath doesn't convert pathlists
+            func_to_host_pathlist_result=""
+            func_to_host_pathlist_oldIFS=$IFS
+            IFS=:
+            for func_to_host_pathlist_f in $func_to_host_pathlist_tmp1 ; do
+              IFS=$func_to_host_pathlist_oldIFS
+              if test -n "$func_to_host_pathlist_f" ; then
+                func_to_host_path "$func_to_host_pathlist_f"
+                if test -n "$func_to_host_path_result" ; then
+                  if test -z "$func_to_host_pathlist_result" ; then
+                    func_to_host_pathlist_result="$func_to_host_path_result"
+                  else
+                    func_to_host_pathlist_result="$func_to_host_pathlist_result;$func_to_host_path_result"
+                  fi
+                fi
+              fi
+              IFS=:
+            done
+        esac
+          func_error "Could not determine the host path(s) corresponding to"
+          # Fallback. This may break if $1 contains DOS-style drive
+          # specifications. The fix is not to complicate the expression
+          # below, but for the user to provide a working wine installation
+          # with winepath so that path translation in the cross-to-mingw
+          # case works properly.
+          lt_replace_pathsep_nix_to_dos="s|:|;|g"
+          func_to_host_pathlist_result=`echo "$func_to_host_pathlist_tmp1" |\
+            $SED -e "$lt_replace_pathsep_nix_to_dos"`
+        fi
+        # Now, add the leading and trailing path separators back
+        case "$1" in
+          :* ) func_to_host_pathlist_result=";$func_to_host_pathlist_result"
+        esac
+        case "$1" in
+          *: ) func_to_host_pathlist_result="$func_to_host_pathlist_result;"
+        esac
+    esac
+  fi
+# end: func_to_host_pathlist
+# func_emit_cwrapperexe_src
+# emit the source code for a wrapper executable on stdout
+# Must ONLY be called from within func_mode_link because
+# it depends on a number of variable set therein.
+func_emit_cwrapperexe_src ()
+	cat <<EOF
+/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
+   Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
+   The $output program cannot be directly executed until all the libtool
+   libraries that it depends on are installed.
+   This wrapper executable should never be moved out of the build directory.
+   If it is, it will not operate correctly.
+   Currently, it simply execs the wrapper *script* "$SHELL $output",
+   but could eventually absorb all of the scripts functionality and
+   exec $objdir/$outputname directly.
+EOF
+	    cat <<"EOF"
+#include <stdio.h>
+#include <stdlib.h>
+#ifdef _MSC_VER
+# include <direct.h>
+# include <process.h>
+# include <io.h>
+# define setmode _setmode
+#else
+# include <unistd.h>
+# include <stdint.h>
+# ifdef __CYGWIN__
+#  include <io.h>
+#  define HAVE_SETENV
+#  ifdef __STRICT_ANSI__
+char *realpath (const char *, char *);
+int putenv (char *);
+int setenv (const char *, const char *, int);
+#  endif
+# endif
+#endif
+#include <malloc.h>
+#include <stdarg.h>
+#include <assert.h>
+#include <string.h>
+#include <ctype.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <sys/stat.h>
+#if defined(PATH_MAX)
+# define LT_PATHMAX PATH_MAX
+#elif defined(MAXPATHLEN)
+# define LT_PATHMAX MAXPATHLEN
+#else
+# define LT_PATHMAX 1024
+#endif
+#ifndef S_IXOTH
+# define S_IXOTH 0
+#endif
+#ifndef S_IXGRP
+# define S_IXGRP 0
+#endif
+#ifdef _MSC_VER
+# define S_IXUSR _S_IEXEC
+# define stat _stat
+# ifndef _INTPTR_T_DEFINED
+#  define intptr_t int
+# endif
+#endif
+#ifndef DIR_SEPARATOR
+# define DIR_SEPARATOR '/'
+# define PATH_SEPARATOR ':'
+#endif
+#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
+  defined (__OS2__)
+# define HAVE_DOS_BASED_FILE_SYSTEM
+# define FOPEN_WB "wb"
+# ifndef DIR_SEPARATOR_2
+#  define DIR_SEPARATOR_2 '\\'
+# endif
+# ifndef PATH_SEPARATOR_2
+#  define PATH_SEPARATOR_2 ';'
+# endif
+#endif
+#ifndef DIR_SEPARATOR_2
+# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
+#else /* DIR_SEPARATOR_2 */
+# define IS_DIR_SEPARATOR(ch) \
+	(((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
+#endif /* DIR_SEPARATOR_2 */
+#ifndef PATH_SEPARATOR_2
+# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR)
+#else /* PATH_SEPARATOR_2 */
+# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR_2)
+#endif /* PATH_SEPARATOR_2 */
+#ifdef __CYGWIN__
+#endif
+#ifndef FOPEN_WB
+# define FOPEN_WB "w"
+#endif
+#ifndef _O_BINARY
+# define _O_BINARY 0
+#endif
+#define XMALLOC(type, num)      ((type *) xmalloc ((num) * sizeof(type)))
+#define XFREE(stale) do { \
+  if (stale) { free ((void *) stale); stale = 0; } \
+} while (0)
+#undef LTWRAPPER_DEBUGPRINTF
+#if defined DEBUGWRAPPER
+# define LTWRAPPER_DEBUGPRINTF(args) ltwrapper_debugprintf args
+static void
+ltwrapper_debugprintf (const char *fmt, ...)
+    va_list args;
+    va_start (args, fmt);
+    (void) vfprintf (stderr, fmt, args);
+    va_end (args);
+#else
+#endif
+const char *program_name = NULL;
+void *xmalloc (size_t num);
+char *xstrdup (const char *string);
+const char *base_name (const char *name);
+char *find_executable (const char *wrapper);
+char *chase_symlinks (const char *pathspec);
+int make_executable (const char *path);
+int check_executable (const char *path);
+char *strendzap (char *str, const char *pat);
+void lt_fatal (const char *message, ...);
+void lt_setenv (const char *name, const char *value);
+char *lt_extend_str (const char *orig_value, const char *add, int to_end);
+void lt_opt_process_env_set (const char *arg);
+void lt_opt_process_env_prepend (const char *arg);
+void lt_opt_process_env_append (const char *arg);
+int lt_split_name_value (const char *arg, char** name, char** value);
+void lt_update_exe_path (const char *name, const char *value);
+void lt_update_lib_path (const char *name, const char *value);
+static const char *script_text_part1 =
+EOF
+	    func_emit_wrapper_part1 yes |
+	        $SED -e 's/\([\\"]\)/\\\1/g' \
+	             -e 's/^/  "/' -e 's/$/\\n"/'
+	    echo ";"
+	    cat <<EOF
+static const char *script_text_part2 =
+EOF
+	    func_emit_wrapper_part2 yes |
+	    echo ";"
+	    cat <<EOF
+const char * MAGIC_EXE = "$magic_exe";
+const char * LIB_PATH_VARNAME = "$shlibpath_var";
+EOF
+              func_to_host_pathlist "$temp_rpath"
+	      cat <<EOF
+const char * LIB_PATH_VALUE   = "$func_to_host_pathlist_result";
+EOF
+	    else
+	      cat <<"EOF"
+const char * LIB_PATH_VALUE   = "";
+EOF
+	    fi
+              func_to_host_pathlist "$dllsearchpath:"
+	      cat <<EOF
+const char * EXE_PATH_VARNAME = "PATH";
+const char * EXE_PATH_VALUE   = "$func_to_host_pathlist_result";
+EOF
+	    else
+	      cat <<"EOF"
+const char * EXE_PATH_VARNAME = "";
+const char * EXE_PATH_VALUE   = "";
+EOF
+	    fi
+	      cat <<EOF
+const char * TARGET_PROGRAM_NAME = "lt-$outputname"; /* hopefully, no .exe */
+EOF
+	    else
+	      cat <<EOF
+const char * TARGET_PROGRAM_NAME = "$outputname"; /* hopefully, no .exe */
+EOF
+	    fi
+	    cat <<"EOF"
+#define LTWRAPPER_OPTION_PREFIX         "--lt-"
+#define LTWRAPPER_OPTION_PREFIX_LENGTH  5
+static const size_t opt_prefix_len         = LTWRAPPER_OPTION_PREFIX_LENGTH;
+static const char *ltwrapper_option_prefix = LTWRAPPER_OPTION_PREFIX;
+static const char *dumpscript_opt       = LTWRAPPER_OPTION_PREFIX "dump-script";
+static const size_t env_set_opt_len     = LTWRAPPER_OPTION_PREFIX_LENGTH + 7;
+static const char *env_set_opt          = LTWRAPPER_OPTION_PREFIX "env-set";
+  /* argument is putenv-style "foo=bar", value of foo is set to bar */
+static const size_t env_prepend_opt_len = LTWRAPPER_OPTION_PREFIX_LENGTH + 11;
+static const char *env_prepend_opt      = LTWRAPPER_OPTION_PREFIX "env-prepend";
+  /* argument is putenv-style "foo=bar", new value of foo is bar${foo} */
+static const size_t env_append_opt_len  = LTWRAPPER_OPTION_PREFIX_LENGTH + 10;
+static const char *env_append_opt       = LTWRAPPER_OPTION_PREFIX "env-append";
+  /* argument is putenv-style "foo=bar", new value of foo is ${foo}bar */
+int
+main (int argc, char *argv[])
+  char **newargz;
+  int  newargc;
+  char *tmp_pathspec;
+  char *actual_cwrapper_path;
+  char *actual_cwrapper_name;
+  char *target_name;
+  char *lt_argv_zero;
+  intptr_t rval = 127;
+  int i;
+  program_name = (char *) xstrdup (base_name (argv[0]));
+  LTWRAPPER_DEBUGPRINTF (("(main) argv[0]      : %s\n", argv[0]));
+  LTWRAPPER_DEBUGPRINTF (("(main) program_name : %s\n", program_name));
+  /* very simple arg parsing; don't want to rely on getopt */
+  for (i = 1; i < argc; i++)
+      if (strcmp (argv[i], dumpscript_opt) == 0)
+EOF
+	    case "$host" in
+	      *mingw* | *cygwin* )
+		# make stdout use "unix" line endings
+		echo "          setmode(1,_O_BINARY);"
+	      esac
+	    cat <<"EOF"
+	  printf ("%s", script_text_part1);
+	  printf ("%s", script_text_part2);
+	  return 0;
+  newargz = XMALLOC (char *, argc + 1);
+  tmp_pathspec = find_executable (argv[0]);
+  if (tmp_pathspec == NULL)
+    lt_fatal ("Couldn't find %s", argv[0]);
+  LTWRAPPER_DEBUGPRINTF (("(main) found exe (before symlink chase) at : %s\n",
+			  tmp_pathspec));
+  actual_cwrapper_path = chase_symlinks (tmp_pathspec);
+  LTWRAPPER_DEBUGPRINTF (("(main) found exe (after symlink chase) at : %s\n",
+			  actual_cwrapper_path));
+  XFREE (tmp_pathspec);
+  actual_cwrapper_name = xstrdup( base_name (actual_cwrapper_path));
+  strendzap (actual_cwrapper_path, actual_cwrapper_name);
+  /* wrapper name transforms */
+  strendzap (actual_cwrapper_name, ".exe");
+  tmp_pathspec = lt_extend_str (actual_cwrapper_name, ".exe", 1);
+  XFREE (actual_cwrapper_name);
+  actual_cwrapper_name = tmp_pathspec;
+  tmp_pathspec = 0;
+  /* target_name transforms -- use actual target program name; might have lt- prefix */
+  target_name = xstrdup (base_name (TARGET_PROGRAM_NAME));
+  strendzap (target_name, ".exe");
+  tmp_pathspec = lt_extend_str (target_name, ".exe", 1);
+  XFREE (target_name);
+  target_name = tmp_pathspec;
+  tmp_pathspec = 0;
+  LTWRAPPER_DEBUGPRINTF (("(main) libtool target name: %s\n",
+			  target_name));
+EOF
+	    cat <<EOF
+  newargz[0] =
+    XMALLOC (char, (strlen (actual_cwrapper_path) +
+		    strlen ("$objdir") + 1 + strlen (actual_cwrapper_name) + 1));
+  strcpy (newargz[0], actual_cwrapper_path);
+  strcat (newargz[0], "$objdir");
+  strcat (newargz[0], "/");
+EOF
+	    cat <<"EOF"
+  /* stop here, and copy so we don't have to do this twice */
+  tmp_pathspec = xstrdup (newargz[0]);
+  /* do NOT want the lt- prefix here, so use actual_cwrapper_name */
+  strcat (newargz[0], actual_cwrapper_name);
+  /* DO want the lt- prefix here if it exists, so use target_name */
+  lt_argv_zero = lt_extend_str (tmp_pathspec, target_name, 1);
+  tmp_pathspec = NULL;
+EOF
+	    case $host_os in
+	      mingw*)
+	    cat <<"EOF"
+    char* p;
+    while ((p = strchr (newargz[0], '\\')) != NULL)
+	*p = '/';
+    while ((p = strchr (lt_argv_zero, '\\')) != NULL)
+	*p = '/';
+EOF
+	    esac
+	    cat <<"EOF"
+  XFREE (actual_cwrapper_path);
+  lt_setenv ("BIN_SH", "xpg4"); /* for Tru64 */
+  lt_setenv ("DUALCASE", "1");  /* for MSK sh */
+  lt_update_lib_path (LIB_PATH_VARNAME, LIB_PATH_VALUE);
+  lt_update_exe_path (EXE_PATH_VARNAME, EXE_PATH_VALUE);
+  newargc=0;
+      if (strncmp (argv[i], env_set_opt, env_set_opt_len) == 0)
+          if (argv[i][env_set_opt_len] == '=')
+              const char *p = argv[i] + env_set_opt_len + 1;
+              lt_opt_process_env_set (p);
+          else if (argv[i][env_set_opt_len] == '\0' && i + 1 < argc)
+              lt_opt_process_env_set (argv[++i]); /* don't copy */
+          else
+            lt_fatal ("%s missing required argument", env_set_opt);
+          continue;
+      if (strncmp (argv[i], env_prepend_opt, env_prepend_opt_len) == 0)
+          if (argv[i][env_prepend_opt_len] == '=')
+              const char *p = argv[i] + env_prepend_opt_len + 1;
+              lt_opt_process_env_prepend (p);
+          else if (argv[i][env_prepend_opt_len] == '\0' && i + 1 < argc)
+              lt_opt_process_env_prepend (argv[++i]); /* don't copy */
+          else
+            lt_fatal ("%s missing required argument", env_prepend_opt);
+          continue;
+      if (strncmp (argv[i], env_append_opt, env_append_opt_len) == 0)
+          if (argv[i][env_append_opt_len] == '=')
+              const char *p = argv[i] + env_append_opt_len + 1;
+              lt_opt_process_env_append (p);
+          else if (argv[i][env_append_opt_len] == '\0' && i + 1 < argc)
+              lt_opt_process_env_append (argv[++i]); /* don't copy */
+          else
+            lt_fatal ("%s missing required argument", env_append_opt);
+          continue;
+      if (strncmp (argv[i], ltwrapper_option_prefix, opt_prefix_len) == 0)
+          /* however, if there is an option in the LTWRAPPER_OPTION_PREFIX
+             namespace, but it is not one of the ones we know about and
+             have already dealt with, above (inluding dump-script), then
+             report an error. Otherwise, targets might begin to believe
+             they are allowed to use options in the LTWRAPPER_OPTION_PREFIX
+             namespace. The first time any user complains about this, we'll
+             need to make LTWRAPPER_OPTION_PREFIX a configure-time option
+             or a configure.ac-settable value.
+          lt_fatal ("Unrecognized option in %s namespace: '%s'",
+                    ltwrapper_option_prefix, argv[i]);
+      /* otherwise ... */
+      newargz[++newargc] = xstrdup (argv[i]);
+  newargz[++newargc] = NULL;
+  LTWRAPPER_DEBUGPRINTF     (("(main) lt_argv_zero : %s\n", (lt_argv_zero ? lt_argv_zero : "<NULL>")));
+  for (i = 0; i < newargc; i++)
+      LTWRAPPER_DEBUGPRINTF (("(main) newargz[%d]   : %s\n", i, (newargz[i] ? newargz[i] : "<NULL>")));
+EOF
+	    case $host_os in
+	      mingw*)
+		cat <<"EOF"
+  /* execv doesn't actually work on mingw as expected on unix */
+  rval = _spawnv (_P_WAIT, lt_argv_zero, (const char * const *) newargz);
+  if (rval == -1)
+      /* failed to start process */
+      LTWRAPPER_DEBUGPRINTF (("(main) failed to launch target \"%s\": errno = %d\n", lt_argv_zero, errno));
+      return 127;
+  return rval;
+EOF
+		cat <<"EOF"
+  execv (lt_argv_zero, newargz);
+  return rval; /* =127, but avoids unused variable warning */
+EOF
+	    esac
+	    cat <<"EOF"
+void *
+xmalloc (size_t num)
+  void *p = (void *) malloc (num);
+  if (!p)
+    lt_fatal ("Memory exhausted");
+  return p;
+char *
+xstrdup (const char *string)
+  return string ? strcpy ((char *) xmalloc (strlen (string) + 1),
+			  string) : NULL;
+const char *
+base_name (const char *name)
+  const char *base;
+#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
+  /* Skip over the disk name in MSDOS pathnames. */
+  if (isalpha ((unsigned char) name[0]) && name[1] == ':')
+    name += 2;
+#endif
+  for (base = name; *name; name++)
+    if (IS_DIR_SEPARATOR (*name))
+      base = name + 1;
+  return base;
+int
+check_executable (const char *path)
+  struct stat st;
+  LTWRAPPER_DEBUGPRINTF (("(check_executable)  : %s\n",
+			  path ? (*path ? path : "EMPTY!") : "NULL!"));
+  if ((!path) || (!*path))
+    return 0;
+  if ((stat (path, &st) >= 0)
+      && (st.st_mode & (S_IXUSR | S_IXGRP | S_IXOTH)))
+    return 1;
+  else
+    return 0;
+int
+make_executable (const char *path)
+  int rval = 0;
+  struct stat st;
+  LTWRAPPER_DEBUGPRINTF (("(make_executable)   : %s\n",
+    return 0;
+  if (stat (path, &st) >= 0)
+      rval = chmod (path, st.st_mode | S_IXOTH | S_IXGRP | S_IXUSR);
+  return rval;
+/* Searches for the full path of the wrapper.  Returns
+   newly allocated full path name if found, NULL otherwise
+   Does not chase symlinks, even on platforms that support them.
+char *
+find_executable (const char *wrapper)
+  int has_slash = 0;
+  const char *p;
+  const char *p_next;
+  /* static buffer for getcwd */
+  char tmp[LT_PATHMAX + 1];
+  int tmp_len;
+  char *concat_name;
+  LTWRAPPER_DEBUGPRINTF (("(find_executable)   : %s\n",
+			  wrapper ? (*wrapper ? wrapper : "EMPTY!") : "NULL!"));
+  if ((wrapper == NULL) || (*wrapper == '\0'))
+    return NULL;
+  /* Absolute path? */
+  if (isalpha ((unsigned char) wrapper[0]) && wrapper[1] == ':')
+      concat_name = xstrdup (wrapper);
+      if (check_executable (concat_name))
+	return concat_name;
+      XFREE (concat_name);
+  else
+#endif
+      if (IS_DIR_SEPARATOR (wrapper[0]))
+#endif
+  for (p = wrapper; *p; p++)
+    if (*p == '/')
+	has_slash = 1;
+	break;
+  if (!has_slash)
+      /* no slashes; search PATH */
+      const char *path = getenv ("PATH");
+      if (path != NULL)
+	  for (p = path; *p; p = p_next)
+	      const char *q;
+	      size_t p_len;
+	      for (q = p; *q; q++)
+		if (IS_PATH_SEPARATOR (*q))
+		  break;
+	      p_len = q - p;
+	      p_next = (*q == '\0' ? q : q + 1);
+	      if (p_len == 0)
+		  /* empty path: current directory */
+		  if (getcwd (tmp, LT_PATHMAX) == NULL)
+		    lt_fatal ("getcwd failed");
+		  tmp_len = strlen (tmp);
+		  concat_name =
+		    XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
+		  memcpy (concat_name, tmp, tmp_len);
+		  concat_name[tmp_len] = '/';
+		  strcpy (concat_name + tmp_len + 1, wrapper);
+	      else
+		  concat_name =
+		    XMALLOC (char, p_len + 1 + strlen (wrapper) + 1);
+		  memcpy (concat_name, p, p_len);
+		  concat_name[p_len] = '/';
+		  strcpy (concat_name + p_len + 1, wrapper);
+      /* not found in PATH; assume curdir */
+  /* Relative path | not found in path: prepend cwd */
+  concat_name = XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
+  return NULL;
+char *
+chase_symlinks (const char *pathspec)
+#ifndef S_ISLNK
+  return xstrdup (pathspec);
+#else
+  char buf[LT_PATHMAX];
+  struct stat s;
+  char *tmp_pathspec = xstrdup (pathspec);
+  char *p;
+  int has_symlinks = 0;
+  while (strlen (tmp_pathspec) && !has_symlinks)
+      LTWRAPPER_DEBUGPRINTF (("checking path component for symlinks: %s\n",
+			      tmp_pathspec));
+      if (lstat (tmp_pathspec, &s) == 0)
+	  if (S_ISLNK (s.st_mode) != 0)
+	      has_symlinks = 1;
+	      break;
+	  /* search backwards for last DIR_SEPARATOR */
+	  p = tmp_pathspec + strlen (tmp_pathspec) - 1;
+	  while ((p > tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
+	    p--;
+	  if ((p == tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
+	      /* no more DIR_SEPARATORS left */
+	      break;
+	  *p = '\0';
+      else
+	  char *errstr = strerror (errno);
+	  lt_fatal ("Error accessing file %s (%s)", tmp_pathspec, errstr);
+  if (!has_symlinks)
+  tmp_pathspec = realpath (pathspec, buf);
+  if (tmp_pathspec == 0)
+      lt_fatal ("Could not follow symlinks for %s", pathspec);
+  return xstrdup (tmp_pathspec);
+#endif
+char *
+strendzap (char *str, const char *pat)
+  size_t len, patlen;
+  assert (str != NULL);
+  assert (pat != NULL);
+  len = strlen (str);
+  patlen = strlen (pat);
+  if (patlen <= len)
+      str += len - patlen;
+      if (strcmp (str, pat) == 0)
+	*str = '\0';
+  return str;
+static void
+lt_error_core (int exit_status, const char *mode,
+	       const char *message, va_list ap)
+  fprintf (stderr, "%s: %s: ", program_name, mode);
+  vfprintf (stderr, message, ap);
+  fprintf (stderr, ".\n");
+  if (exit_status >= 0)
+    exit (exit_status);
+void
+lt_fatal (const char *message, ...)
+  va_list ap;
+  va_start (ap, message);
+  lt_error_core (EXIT_FAILURE, "FATAL", message, ap);
+  va_end (ap);
+void
+lt_setenv (const char *name, const char *value)
+  LTWRAPPER_DEBUGPRINTF (("(lt_setenv) setting '%s' to '%s'\n",
+                          (name ? name : "<NULL>"),
+                          (value ? value : "<NULL>")));
+#ifdef HAVE_SETENV
+    /* always make a copy, for consistency with !HAVE_SETENV */
+    char *str = xstrdup (value);
+    setenv (name, str, 1);
+#else
+    int len = strlen (name) + 1 + strlen (value) + 1;
+    char *str = XMALLOC (char, len);
+    sprintf (str, "%s=%s", name, value);
+    if (putenv (str) != EXIT_SUCCESS)
+        XFREE (str);
+#endif
+char *
+lt_extend_str (const char *orig_value, const char *add, int to_end)
+  char *new_value;
+  if (orig_value && *orig_value)
+      int orig_value_len = strlen (orig_value);
+      int add_len = strlen (add);
+      new_value = XMALLOC (char, add_len + orig_value_len + 1);
+      if (to_end)
+          strcpy (new_value, orig_value);
+          strcpy (new_value + orig_value_len, add);
+      else
+          strcpy (new_value, add);
+          strcpy (new_value + add_len, orig_value);
+  else
+      new_value = xstrdup (add);
+  return new_value;
+int
+lt_split_name_value (const char *arg, char** name, char** value)
+  const char *p;
+  int len;
+  if (!arg || !*arg)
+    return 1;
+  p = strchr (arg, (int)'=');
+  if (!p)
+    return 1;
+  *value = xstrdup (++p);
+  len = strlen (arg) - strlen (*value);
+  *name = XMALLOC (char, len);
+  strncpy (*name, arg, len-1);
+  (*name)[len - 1] = '\0';
+  return 0;
+void
+lt_opt_process_env_set (const char *arg)
+  char *name = NULL;
+  char *value = NULL;
+  if (lt_split_name_value (arg, &name, &value) != 0)
+      XFREE (name);
+      XFREE (value);
+      lt_fatal ("bad argument for %s: '%s'", env_set_opt, arg);
+  lt_setenv (name, value);
+  XFREE (name);
+  XFREE (value);
+void
+lt_opt_process_env_prepend (const char *arg)
+  char *new_value = NULL;
+      XFREE (name);
+      XFREE (value);
+      lt_fatal ("bad argument for %s: '%s'", env_prepend_opt, arg);
+  new_value = lt_extend_str (getenv (name), value, 0);
+  lt_setenv (name, new_value);
+  XFREE (new_value);
+  XFREE (name);
+  XFREE (value);
+void
+lt_opt_process_env_append (const char *arg)
+      XFREE (name);
+      XFREE (value);
+      lt_fatal ("bad argument for %s: '%s'", env_append_opt, arg);
+  new_value = lt_extend_str (getenv (name), value, 1);
+  XFREE (name);
+  XFREE (value);
+void
+lt_update_exe_path (const char *name, const char *value)
+  LTWRAPPER_DEBUGPRINTF (("(lt_update_exe_path) modifying '%s' by prepending '%s'\n",
+  if (name && *name && value && *value)
+      char *new_value = lt_extend_str (getenv (name), value, 0);
+      /* some systems can't cope with a ':'-terminated path #' */
+      int len = strlen (new_value);
+      while (((len = strlen (new_value)) > 0) && IS_PATH_SEPARATOR (new_value[len-1]))
+          new_value[len-1] = '\0';
+void
+lt_update_lib_path (const char *name, const char *value)
+  LTWRAPPER_DEBUGPRINTF (("(lt_update_lib_path) modifying '%s' by prepending '%s'\n",
+EOF
+# end: func_emit_cwrapperexe_src
+# func_mode_link arg...
+func_mode_link ()
+    $opt_debug
+    case $host in
+    *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
+      # It is impossible to link a dll without this setting, and
+      # we shouldn't force the makefile maintainer to figure out
+      # which system we are compiling for in order to pass an extra
+      # flag for every libtool invocation.
+      # allow_undefined=no
+      # FIXME: Unfortunately, there are problems with the above when trying
+      # to make a dll which has undefined symbols, in which case not
+      # even a static library is built.  For now, we need to specify
+      # -no-undefined on the libtool link line when we can be certain
+      # that all symbols are satisfied, otherwise we get a static library.
+      allow_undefined=yes
+    esac
+    libtool_args=$nonopt
+    base_compile="$nonopt $@"
+    compile_command=$nonopt
+    finalize_command=$nonopt
+    compile_rpath=
+    finalize_rpath=
+    compile_shlibpath=
+    finalize_shlibpath=
+    convenience=
+    old_convenience=
+    deplibs=
+    old_deplibs=
+    compiler_flags=
+    linker_flags=
+    dllsearchpath=
+    lib_search_path=`pwd`
+    inst_prefix_dir=
+    new_inherited_linker_flags=
+    avoid_version=no
+    dlfiles=
+    dlprefiles=
+    dlself=no
+    export_dynamic=no
+    export_symbols=
+    export_symbols_regex=
+    generated=
+    libobjs=
+    ltlibs=
+    module=no
+    no_install=no
+    objs=
+    non_pic_objects=
+    precious_files_regex=
+    prefer_static_libs=no
+    preload=no
+    prev=
+    prevarg=
+    release=
+    rpath=
+    xrpath=
+    perm_rpath=
+    temp_rpath=
+    thread_safe=no
+    vinfo=
+    vinfo_number=no
+    weak_libs=
+    single_module="${wl}-single_module"
+    func_infer_tag $base_compile
+    # We need to know -static, to get the right output filenames.
+    for arg
+    do
+      case $arg in
+      -shared)
+	test "$build_libtool_libs" != yes && \
+	  func_fatal_configuration "can not build a shared library"
+	build_old_libs=no
+	break
+      -all-static | -static | -static-libtool-libs)
+	case $arg in
+	-all-static)
+	  if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
+	    func_warning "complete static linking is impossible in this configuration"
+	  fi
+	  if test -n "$link_static_flag"; then
+	    dlopen_self=$dlopen_self_static
+	  fi
+	  prefer_static_libs=yes
+	-static)
+	  if test -z "$pic_flag" && test -n "$link_static_flag"; then
+	  fi
+	  prefer_static_libs=built
+	-static-libtool-libs)
+	  fi
+	esac
+	build_libtool_libs=no
+	build_old_libs=yes
+	break
+      esac
+    done
+    # See if our shared archives depend on static archives.
+    test -n "$old_archive_from_new_cmds" && build_old_libs=yes
+    # Go through the arguments, transforming them on the way.
+    while test "$#" -gt 0; do
+      arg="$1"
+      shift
+      func_quote_for_eval "$arg"
+      qarg=$func_quote_for_eval_unquoted_result
+      func_append libtool_args " $func_quote_for_eval_result"
+      # If the previous option needs an argument, assign it.
+	case $prev in
+	output)
+	  func_append compile_command " @OUTPUT@"
+	  func_append finalize_command " @OUTPUT@"
+	esac
+	case $prev in
+	dlfiles|dlprefiles)
+	  if test "$preload" = no; then
+	    # Add the symbol object into the linking commands.
+	    func_append compile_command " @SYMFILE@"
+	    func_append finalize_command " @SYMFILE@"
+	    preload=yes
+	  fi
+	  case $arg in
+	  *.la | *.lo) ;;  # We handle these cases below.
+	  force)
+	    if test "$dlself" = no; then
+	      dlself=needless
+	      export_dynamic=yes
+	    fi
+	    prev=
+	    continue
+	  self)
+	    if test "$prev" = dlprefiles; then
+	      dlself=yes
+	    elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
+	      dlself=yes
+	    else
+	      dlself=needless
+	    fi
+	    prev=
+	    continue
+	    if test "$prev" = dlfiles; then
+	      dlfiles="$dlfiles $arg"
+	    else
+	      dlprefiles="$dlprefiles $arg"
+	    fi
+	    prev=
+	    continue
+	  esac
+	expsyms)
+	  export_symbols="$arg"
+	  test -f "$arg" \
+	    || func_fatal_error "symbol file \`$arg' does not exist"
+	  prev=
+	  continue
+	expsyms_regex)
+	  export_symbols_regex="$arg"
+	  prev=
+	  continue
+	framework)
+	  case $host in
+	    *-*-darwin*)
+	      case "$deplibs " in
+		*" $qarg.ltframework "*) ;;
+		*) deplibs="$deplibs $qarg.ltframework" # this is fixed later
+	      esac
+	  esac
+	  prev=
+	  continue
+	inst_prefix)
+	  inst_prefix_dir="$arg"
+	  prev=
+	  continue
+	objectlist)
+	  if test -f "$arg"; then
+	    save_arg=$arg
+	    moreargs=
+	    for fil in `cat "$save_arg"`
+	    do
+#	      moreargs="$moreargs $fil"
+	      arg=$fil
+	      # A libtool-controlled object.
+	      # Check to see that this really is a libtool object.
+	      if func_lalib_unsafe_p "$arg"; then
+		pic_object=
+		non_pic_object=
+		# Read the .lo file
+		func_source "$arg"
+		if test -z "$pic_object" ||
+		   test -z "$non_pic_object" ||
+		   test "$pic_object" = none &&
+		   test "$non_pic_object" = none; then
+		  func_fatal_error "cannot find name of object for \`$arg'"
+		fi
+		# Extract subdirectory from the argument.
+		func_dirname "$arg" "/" ""
+		xdir="$func_dirname_result"
+		if test "$pic_object" != none; then
+		  # Prepend the subdirectory the object is found in.
+		  pic_object="$xdir$pic_object"
+		    if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
+		      dlfiles="$dlfiles $pic_object"
+		      prev=
+		      continue
+		    else
+		      # If libtool objects are unsupported, then we need to preload.
+		      prev=dlprefiles
+		    fi
+		  fi
+		  # CHECK ME:  I think I busted this.  -Ossama
+		    # Preload the old-style object.
+		    dlprefiles="$dlprefiles $pic_object"
+		    prev=
+		  fi
+		  # A PIC object.
+		  func_append libobjs " $pic_object"
+		  arg="$pic_object"
+		fi
+		# Non-PIC object.
+		if test "$non_pic_object" != none; then
+		  non_pic_object="$xdir$non_pic_object"
+		  # A standard non-PIC object
+		  func_append non_pic_objects " $non_pic_object"
+		  if test -z "$pic_object" || test "$pic_object" = none ; then
+		    arg="$non_pic_object"
+		  fi
+		else
+		  # If the PIC object exists, use it instead.
+		  # $xdir was prepended to $pic_object above.
+		  non_pic_object="$pic_object"
+		fi
+	      else
+		# Only an error if not doing a dry-run.
+		if $opt_dry_run; then
+		  func_lo2o "$arg"
+		  pic_object=$xdir$objdir/$func_lo2o_result
+		  non_pic_object=$xdir$func_lo2o_result
+	        else
+		  func_fatal_error "\`$arg' is not a valid libtool object"
+		fi
+	      fi
+	    done
+	  else
+	    func_fatal_error "link input file \`$arg' does not exist"
+	  fi
+	  arg=$save_arg
+	  prev=
+	  continue
+	precious_regex)
+	  precious_files_regex="$arg"
+	  prev=
+	  continue
+	release)
+	  release="-$arg"
+	  prev=
+	  continue
+	rpath | xrpath)
+	  # We need an absolute path.
+	  case $arg in
+	    func_fatal_error "only absolute run-paths are allowed"
+	  esac
+	  if test "$prev" = rpath; then
+	    case "$rpath " in
+	    *" $arg "*) ;;
+	    *) rpath="$rpath $arg" ;;
+	    esac
+	  else
+	    case "$xrpath " in
+	    *" $arg "*) ;;
+	    *) xrpath="$xrpath $arg" ;;
+	    esac
+	  fi
+	  prev=
+	  continue
+	shrext)
+	  shrext_cmds="$arg"
+	  prev=
+	  continue
+	weak)
+	  weak_libs="$weak_libs $arg"
+	  prev=
+	  continue
+	xcclinker)
+	  linker_flags="$linker_flags $qarg"
+	  compiler_flags="$compiler_flags $qarg"
+	  prev=
+	  func_append compile_command " $qarg"
+	  func_append finalize_command " $qarg"
+	  continue
+	xcompiler)
+	  prev=
+	  continue
+	xlinker)
+	  compiler_flags="$compiler_flags $wl$qarg"
+	  prev=
+	  func_append compile_command " $wl$qarg"
+	  func_append finalize_command " $wl$qarg"
+	  continue
+	  eval "$prev=\"\$arg\""
+	  prev=
+	  continue
+	esac
+      fi # test -n "$prev"
+      prevarg="$arg"
+      case $arg in
+      -all-static)
+	  # See comment for -static flag below, for more details.
+	  func_append compile_command " $link_static_flag"
+	  func_append finalize_command " $link_static_flag"
+	fi
+	continue
+      -allow-undefined)
+	# FIXME: remove this flag sometime in the future.
+	func_fatal_error "\`-allow-undefined' must not be used because it is the default"
+      -avoid-version)
+	avoid_version=yes
+	continue
+      -dlopen)
+	prev=dlfiles
+	continue
+      -dlpreopen)
+	prev=dlprefiles
+	continue
+      -export-dynamic)
+	continue
+      -export-symbols | -export-symbols-regex)
+	if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
+	  func_fatal_error "more than one -exported-symbols argument is not allowed"
+	fi
+	if test "X$arg" = "X-export-symbols"; then
+	  prev=expsyms
+	else
+	  prev=expsyms_regex
+	fi
+	continue
+      -framework)
+	prev=framework
+	continue
+      -inst-prefix-dir)
+	prev=inst_prefix
+	continue
+      # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
+      # so, if we see these flags be careful not to treat them like -L
+      -L[A-Z][A-Z]*:*)
+	case $with_gcc/$host in
+	no/*-*-irix* | /*-*-irix*)
+	  func_append compile_command " $arg"
+	  func_append finalize_command " $arg"
+	esac
+	continue
+      -L*)
+	func_stripname '-L' '' "$arg"
+	dir=$func_stripname_result
+	if test -z "$dir"; then
+	    func_fatal_error "require no space between \`-L' and \`$1'"
+	  else
+	    func_fatal_error "need path for \`-L' option"
+	  fi
+	fi
+	case $dir in
+	  absdir=`cd "$dir" && pwd`
+	  test -z "$absdir" && \
+	    func_fatal_error "cannot determine absolute directory name of \`$dir'"
+	  dir="$absdir"
+	esac
+	*" -L$dir "*) ;;
+	  deplibs="$deplibs -L$dir"
+	  lib_search_path="$lib_search_path $dir"
+	esac
+	case $host in
+	  testbindir=`$ECHO "X$dir" | $Xsed -e 's*/lib$*/bin*'`
+	  case :$dllsearchpath: in
+	  *":$dir:"*) ;;
+	  ::) dllsearchpath=$dir;;
+	  *) dllsearchpath="$dllsearchpath:$dir";;
+	  esac
+	  *":$testbindir:"*) ;;
+	  ::) dllsearchpath=$testbindir;;
+	  *) dllsearchpath="$dllsearchpath:$testbindir";;
+	  esac
+	esac
+	continue
+      -l*)
+	if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
+	  case $host in
+	  *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-beos* | *-cegcc*)
+	    # These systems don't actually have a C or math library (as such)
+	    continue
+	  *-*-os2*)
+	    # These systems don't actually have a C library (as such)
+	    test "X$arg" = "X-lc" && continue
+	  *-*-openbsd* | *-*-freebsd* | *-*-dragonfly*)
+	    # Do not include libc due to us having libc/libc_r.
+	  *-*-rhapsody* | *-*-darwin1.[012])
+	    # Rhapsody C and math libraries are in the System framework
+	    deplibs="$deplibs System.ltframework"
+	    continue
+	  *-*-sco3.2v5* | *-*-sco5v6*)
+	    # Causes problems with __ctype
+	  *-*-sysv4.2uw2* | *-*-sysv5* | *-*-unixware* | *-*-OpenUNIX*)
+	    # Compiler inserts libc in the correct place for threads to work
+	  esac
+	elif test "X$arg" = "X-lc_r"; then
+	 case $host in
+	   # Do not include libc_r directly, use -pthread flag.
+	   continue
+	 esac
+	fi
+	deplibs="$deplibs $arg"
+	continue
+      -module)
+	module=yes
+	continue
+      # Tru64 UNIX uses -model [arg] to determine the layout of C++
+      # classes, name mangling, and exception handling.
+      # Darwin uses the -arch flag to determine output architecture.
+      -model|-arch|-isysroot)
+	compiler_flags="$compiler_flags $arg"
+	prev=xcompiler
+	continue
+      -mt|-mthreads|-kthread|-Kthread|-pthread|-pthreads|--thread-safe|-threads)
+	case "$new_inherited_linker_flags " in
+	    *" $arg "*) ;;
+	    * ) new_inherited_linker_flags="$new_inherited_linker_flags $arg" ;;
+	esac
+	continue
+      -multi_module)
+	single_module="${wl}-multi_module"
+	continue
+      -no-fast-install)
+	fast_install=no
+	continue
+      -no-install)
+	case $host in
+	*-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-darwin* | *-cegcc*)
+	  # The PATH hackery in wrapper scripts is required on Windows
+	  # and Darwin in order for the loader to find any dlls it needs.
+	  func_warning "\`-no-install' is ignored for $host"
+	  func_warning "assuming \`-no-fast-install' instead"
+	  fast_install=no
+	*) no_install=yes ;;
+	esac
+	continue
+      -no-undefined)
+	allow_undefined=no
+	continue
+      -objectlist)
+	prev=objectlist
+	continue
+      -o) prev=output ;;
+      -precious-files-regex)
+	prev=precious_regex
+	continue
+      -release)
+	prev=release
+	continue
+      -rpath)
+	prev=rpath
+	continue
+      -R)
+	prev=xrpath
+	continue
+      -R*)
+	func_stripname '-R' '' "$arg"
+	case $dir in
+	[\\/]* | [A-Za-z]:[\\/]*) ;;
+	esac
+	*" $dir "*) ;;
+	*) xrpath="$xrpath $dir" ;;
+	esac
+	continue
+      -shared)
+	# The effects of -shared are defined in a previous loop.
+	continue
+      -shrext)
+	prev=shrext
+	continue
+      -static | -static-libtool-libs)
+	# The effects of -static are defined in a previous loop.
+	# We used to do the same as -all-static on platforms that
+	# didn't have a PIC flag, but the assumption that the effects
+	# would be equivalent was wrong.  It would break on at least
+	# Digital Unix and AIX.
+	continue
+      -thread-safe)
+	thread_safe=yes
+	continue
+      -version-info)
+	prev=vinfo
+	continue
+      -version-number)
+	prev=vinfo
+	vinfo_number=yes
+	continue
+      -weak)
+        prev=weak
+	continue
+      -Wc,*)
+	func_stripname '-Wc,' '' "$arg"
+	args=$func_stripname_result
+	arg=
+	save_ifs="$IFS"; IFS=','
+	for flag in $args; do
+	  IFS="$save_ifs"
+          func_quote_for_eval "$flag"
+	  arg="$arg $wl$func_quote_for_eval_result"
+	  compiler_flags="$compiler_flags $func_quote_for_eval_result"
+	done
+	IFS="$save_ifs"
+	func_stripname ' ' '' "$arg"
+	arg=$func_stripname_result
+      -Wl,*)
+	func_stripname '-Wl,' '' "$arg"
+	arg=
+	  IFS="$save_ifs"
+	  compiler_flags="$compiler_flags $wl$func_quote_for_eval_result"
+	  linker_flags="$linker_flags $func_quote_for_eval_result"
+	done
+	IFS="$save_ifs"
+      -Xcompiler)
+	prev=xcompiler
+	continue
+      -Xlinker)
+	prev=xlinker
+	continue
+      -XCClinker)
+	prev=xcclinker
+	continue
+      # -msg_* for osf cc
+      -msg_*)
+	arg="$func_quote_for_eval_result"
+      # -64, -mips[0-9] enable 64-bit mode on the SGI compiler
+      # -r[0-9][0-9]* specifies the processor on the SGI compiler
+      # -xarch=*, -xtarget=* enable 64-bit mode on the Sun compiler
+      # +DA*, +DD* enable 64-bit mode on the HP compiler
+      # -q* pass through compiler args for the IBM compiler
+      # -m*, -t[45]*, -txscale* pass through architecture-specific
+      # compiler args for GCC
+      # -F/path gives path to uninstalled frameworks, gcc on darwin
+      # -p, -pg, --coverage, -fprofile-* pass through profiling flag for GCC
+      # @file GCC response files
+      -64|-mips[0-9]|-r[0-9][0-9]*|-xarch=*|-xtarget=*|+DA*|+DD*|-q*|-m*| \
+      -t[45]*|-txscale*|-p|-pg|--coverage|-fprofile-*|-F*|@*)
+        continue
+      # Some other compiler flag.
+      *.$objext)
+	# A standard object.
+	objs="$objs $arg"
+      *.lo)
+	  pic_object=
+	  non_pic_object=
+	  fi
+		prev=
+		continue
+	      else
+		prev=dlprefiles
+	      fi
+	    fi
+	      prev=
+	    fi
+	    # A PIC object.
+	    arg="$pic_object"
+	  fi
+	  # Non-PIC object.
+	    fi
+	  else
+	  fi
+	else
+	    func_lo2o "$arg"
+	  else
+	  fi
+	fi
+      *.$libext)
+	# An archive.
+	old_deplibs="$old_deplibs $arg"
+	continue
+      *.la)
+	# A libtool-controlled library.
+	  # This library was specified with -dlopen.
+	  prev=
+	elif test "$prev" = dlprefiles; then
+	  # The library was specified with -dlpreopen.
+	  prev=
+	else
+	fi
+	continue
+      # Some other compiler argument.
+	# Unknown arguments in both finalize_command and compile_command need
+	# to be aesthetically quoted because they are evaled later.
+      esac # arg
+      # Now actually substitute the argument into the commands.
+      if test -n "$arg"; then
+      fi
+    done # argument parsing loop
+    test -n "$prev" && \
+      func_fatal_help "the \`$prevarg' option requires an argument"
+    if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
+      eval arg=\"$export_dynamic_flag_spec\"
+    fi
+    oldlibs=
+    # calculate the name of the file, without its directory
+    func_basename "$output"
+    outputname="$func_basename_result"
+    libobjs_save="$libobjs"
+    if test -n "$shlibpath_var"; then
+      # get the directories listed in $shlibpath_var
+      eval shlib_search_path=\`\$ECHO \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
+    else
+      shlib_search_path=
+    fi
+    eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
+    eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
+    func_dirname "$output" "/" ""
+    output_objdir="$func_dirname_result$objdir"
+    # Create the object directory.
+    func_mkdir_p "$output_objdir"
+    # Determine the type of output
+    case $output in
+      func_fatal_help "you must specify an output file"
+    *.$libext) linkmode=oldlib ;;
+    *.lo | *.$objext) linkmode=obj ;;
+    *.la) linkmode=lib ;;
+    *) linkmode=prog ;; # Anything else should be a program.
+    esac
+    specialdeplibs=
+    libs=
+    # Find all interdependent deplibs by searching for libraries
+    # that are linked more than once (e.g. -la -lb -la)
+    for deplib in $deplibs; do
+      if $opt_duplicate_deps ; then
+	case "$libs " in
+	*" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
+	esac
+      fi
+      libs="$libs $deplib"
+    done
+    if test "$linkmode" = lib; then
+      libs="$predeps $libs $compiler_lib_search_path $postdeps"
+      # Compute libraries that are listed more than once in $predeps
+      # $postdeps and mark them as special (i.e., whose duplicates are
+      # not to be eliminated).
+      pre_post_deps=
+      if $opt_duplicate_compiler_generated_deps; then
+	for pre_post_dep in $predeps $postdeps; do
+	  case "$pre_post_deps " in
+	  *" $pre_post_dep "*) specialdeplibs="$specialdeplibs $pre_post_deps" ;;
+	  esac
+	  pre_post_deps="$pre_post_deps $pre_post_dep"
+	done
+      fi
+      pre_post_deps=
+    fi
+    deplibs=
+    newdependency_libs=
+    newlib_search_path=
+    need_relink=no # whether we're linking any uninstalled libtool libraries
+    notinst_deplibs= # not-installed libtool libraries
+    notinst_path= # paths that contain not-installed libtool libraries
+    case $linkmode in
+    lib)
+	passes="conv dlpreopen link"
+	for file in $dlfiles $dlprefiles; do
+	  case $file in
+	  *.la) ;;
+	    func_fatal_help "libraries can \`-dlopen' only libtool libraries: $file"
+	  esac
+	done
+    prog)
+	compile_deplibs=
+	finalize_deplibs=
+	alldeplibs=no
+	newdlfiles=
+	newdlprefiles=
+	passes="conv scan dlopen dlpreopen link"
+    *)  passes="conv"
+    esac
+    for pass in $passes; do
+      # The preopen pass in lib mode reverses $deplibs; put it back here
+      # so that -L comes before libs that need it for instance...
+      if test "$linkmode,$pass" = "lib,link"; then
+	## FIXME: Find the place where the list is rebuilt in the wrong
+	##        order, and fix it there properly
+        tmp_deplibs=
+	  tmp_deplibs="$deplib $tmp_deplibs"
+	done
+	deplibs="$tmp_deplibs"
+      fi
+      if test "$linkmode,$pass" = "lib,link" ||
+	 test "$linkmode,$pass" = "prog,scan"; then
+	libs="$deplibs"
+	deplibs=
+      fi
+      if test "$linkmode" = prog; then
+	case $pass in
+	dlopen) libs="$dlfiles" ;;
+	dlpreopen) libs="$dlprefiles" ;;
+	link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
+	esac
+      fi
+      if test "$linkmode,$pass" = "lib,dlpreopen"; then
+	# Collect and forward deplibs of preopened libtool libs
+	for lib in $dlprefiles; do
+	  # Ignore non-libtool-libs
+	  dependency_libs=
+	  case $lib in
+	  *.la)	func_source "$lib" ;;
+	  esac
+	  # Collect preopened libtool deplibs, except any this library
+	  # has declared as weak libs
+	  for deplib in $dependency_libs; do
+            deplib_base=`$ECHO "X$deplib" | $Xsed -e "$basename"`
+	    case " $weak_libs " in
+	    *" $deplib_base "*) ;;
+	    *) deplibs="$deplibs $deplib" ;;
+	    esac
+	  done
+	done
+	libs="$dlprefiles"
+      fi
+      if test "$pass" = dlopen; then
+	# Collect dlpreopened libraries
+	save_deplibs="$deplibs"
+	deplibs=
+      fi
+      for deplib in $libs; do
+	lib=
+	found=no
+	case $deplib in
+	  if test "$linkmode,$pass" = "prog,link"; then
+	    compile_deplibs="$deplib $compile_deplibs"
+	    finalize_deplibs="$deplib $finalize_deplibs"
+	  else
+	    compiler_flags="$compiler_flags $deplib"
+	    if test "$linkmode" = lib ; then
+		    *" $deplib "*) ;;
+		    * ) new_inherited_linker_flags="$new_inherited_linker_flags $deplib" ;;
+		esac
+	    fi
+	  fi
+	  continue
+	-l*)
+	  if test "$linkmode" != lib && test "$linkmode" != prog; then
+	    func_warning "\`-l' is ignored for archives/objects"
+	    continue
+	  fi
+	  func_stripname '-l' '' "$deplib"
+	  name=$func_stripname_result
+	    searchdirs="$newlib_search_path $lib_search_path $compiler_lib_search_dirs $sys_lib_search_path $shlib_search_path"
+	  else
+	    searchdirs="$newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path"
+	  fi
+	  for searchdir in $searchdirs; do
+	    for search_ext in .la $std_shrext .so .a; do
+	      # Search the libtool library
+	      lib="$searchdir/lib${name}${search_ext}"
+	      if test -f "$lib"; then
+		if test "$search_ext" = ".la"; then
+		  found=yes
+		else
+		  found=no
+		fi
+		break 2
+	      fi
+	    done
+	  done
+	  if test "$found" != yes; then
+	    # deplib doesn't seem to be a libtool library
+	    else
+	      deplibs="$deplib $deplibs"
+	      test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
+	    fi
+	    continue
+	  else # deplib is a libtool library
+	    # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
+	    # We need to do some special things here, and not later.
+	    if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
+	      case " $predeps $postdeps " in
+	      *" $deplib "*)
+		if func_lalib_p "$lib"; then
+		  library_names=
+		  old_library=
+		  func_source "$lib"
+		  for l in $old_library $library_names; do
+		    ll="$l"
+		  done
+		  if test "X$ll" = "X$old_library" ; then # only static version available
+		    found=no
+		    func_dirname "$lib" "" "."
+		    ladir="$func_dirname_result"
+		    lib=$ladir/$old_library
+		    else
+		    fi
+		    continue
+		  fi
+		fi
+	      esac
+	    fi
+	  fi
+	  ;; # -l
+	*.ltframework)
+	  else
+		    *" $deplib "*) ;;
+		esac
+	    fi
+	  fi
+	  continue
+	-L*)
+	  case $linkmode in
+	  lib)
+	    test "$pass" = conv && continue
+	    newdependency_libs="$deplib $newdependency_libs"
+	    func_stripname '-L' '' "$deplib"
+	    newlib_search_path="$newlib_search_path $func_stripname_result"
+	  prog)
+	    if test "$pass" = conv; then
+	      continue
+	    fi
+	    if test "$pass" = scan; then
+	    else
+	    fi
+	    func_warning "\`-L' is ignored for archives/objects"
+	  esac # linkmode
+	  continue
+	  ;; # -L
+	-R*)
+	  if test "$pass" = link; then
+	    func_stripname '-R' '' "$deplib"
+	    # Make sure the xrpath contains only unique directories.
+	    *" $dir "*) ;;
+	    esac
+	  fi
+	  continue
+	*.la) lib="$deplib" ;;
+	*.$libext)
+	    continue
+	  fi
+	  case $linkmode in
+	  lib)
+	    # Linking convenience modules into shared libraries is allowed,
+	    # but linking other static libraries is non-portable.
+	    case " $dlpreconveniencelibs " in
+	    *" $deplib "*) ;;
+	      valid_a_lib=no
+	      case $deplibs_check_method in
+		match_pattern*)
+		  set dummy $deplibs_check_method; shift
+		  match_pattern_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
+		  if eval "\$ECHO \"X$deplib\"" 2>/dev/null | $Xsed -e 10q \
+		    | $EGREP "$match_pattern_regex" > /dev/null; then
+		    valid_a_lib=yes
+		  fi
+		pass_all)
+		  valid_a_lib=yes
+	      esac
+	      if test "$valid_a_lib" != yes; then
+		$ECHO
+		$ECHO "*** Warning: Trying to link with static lib archive $deplib."
+		$ECHO "*** I have the capability to make that library automatically link in when"
+		$ECHO "*** you link to this library.  But I can only do this if you have a"
+		$ECHO "*** shared version of the library, which you do not appear to have"
+		$ECHO "*** because the file extensions .$libext of this argument makes me believe"
+		$ECHO "*** that it is just a static archive that I should not use here."
+	      else
+		$ECHO
+		$ECHO "*** Warning: Linking the shared library $output against the"
+		$ECHO "*** static library $deplib is not portable!"
+	      fi
+	    esac
+	    continue
+	  prog)
+	    if test "$pass" != link; then
+	    else
+	    fi
+	    continue
+	  esac # linkmode
+	  ;; # *.$libext
+	*.lo | *.$objext)
+	  elif test "$linkmode" = prog; then
+	    if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
+	      # If there is no dlopen support or we're linking statically,
+	      # we need to preload.
+	      newdlprefiles="$newdlprefiles $deplib"
+	    else
+	      newdlfiles="$newdlfiles $deplib"
+	    fi
+	  fi
+	  continue
+	%DEPLIBS%)
+	  alldeplibs=yes
+	  continue
+	esac # case $deplib
+	if test "$found" = yes || test -f "$lib"; then :
+	else
+	  func_fatal_error "cannot find the library \`$lib' or unhandled argument \`$deplib'"
+	fi
+	# Check to see that this really is a libtool archive.
+	func_lalib_unsafe_p "$lib" \
+	  || func_fatal_error "\`$lib' is not a valid libtool archive"
+	dlname=
+	dlopen=
+	dlpreopen=
+	libdir=
+	library_names=
+	old_library=
+	inherited_linker_flags=
+	# If the library was installed with an old release of libtool,
+	# it will not redefine variables installed, or shouldnotlink
+	installed=yes
+	shouldnotlink=no
+	avoidtemprpath=
+	# Read the .la file
+	# Convert "-framework foo" to "foo.ltframework"
+	if test -n "$inherited_linker_flags"; then
+	  tmp_inherited_linker_flags=`$ECHO "X$inherited_linker_flags" | $Xsed -e 's/-framework \([^ $]*\)/\1.ltframework/g'`
+	  for tmp_inherited_linker_flag in $tmp_inherited_linker_flags; do
+	    case " $new_inherited_linker_flags " in
+	      *" $tmp_inherited_linker_flag "*) ;;
+	      *) new_inherited_linker_flags="$new_inherited_linker_flags $tmp_inherited_linker_flag";;
+	    esac
+	  done
+	fi
+	dependency_libs=`$ECHO "X $dependency_libs" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+	   test "$linkmode,$pass" = "prog,scan" ||
+	   { test "$linkmode" != prog && test "$linkmode" != lib; }; then
+	  test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
+	  test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
+	fi
+	  # Only check for convenience libraries
+	  deplibs="$lib $deplibs"
+	  if test -z "$libdir"; then
+	    if test -z "$old_library"; then
+	      func_fatal_error "cannot find name of link library for \`$lib'"
+	    fi
+	    # It is a libtool convenience library, so add in its objects.
+	    convenience="$convenience $ladir/$objdir/$old_library"
+	    old_convenience="$old_convenience $ladir/$objdir/$old_library"
+	  elif test "$linkmode" != prog && test "$linkmode" != lib; then
+	    func_fatal_error "\`$lib' is not a convenience library"
+	  fi
+	  tmp_libs=
+	      case "$tmp_libs " in
+	      esac
+	    fi
+	    tmp_libs="$tmp_libs $deplib"
+	  done
+	  continue
+	fi # $pass = conv
+	# Get the name of the library we link against.
+	linklib=
+	  linklib="$l"
+	done
+	if test -z "$linklib"; then
+	fi
+	    func_fatal_error "cannot -dlopen a convenience library: \`$lib'"
+	  fi
+	  if test -z "$dlname" ||
+	     test "$dlopen_support" != yes ||
+	     test "$build_libtool_libs" = no; then
+	    # If there is no dlname, no dlopen support or we're linking
+	    # statically, we need to preload.  We also need to preload any
+	    # dependent libraries so libltdl's deplib preloader doesn't
+	    # bomb out in the load deplibs phase.
+	    dlprefiles="$dlprefiles $lib $dependency_libs"
+	  else
+	    newdlfiles="$newdlfiles $lib"
+	  fi
+	  continue
+	fi # $pass = dlopen
+	case $ladir in
+	[\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
+	  abs_ladir=`cd "$ladir" && pwd`
+	  if test -z "$abs_ladir"; then
+	    func_warning "cannot determine absolute directory name of \`$ladir'"
+	    func_warning "passing it literally to the linker, although it might fail"
+	    abs_ladir="$ladir"
+	  fi
+	esac
+	func_basename "$lib"
+	laname="$func_basename_result"
+	# Find the relevant object directory and library name.
+	if test "X$installed" = Xyes; then
+	  if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
+	    func_warning "library \`$lib' was moved."
+	    dir="$ladir"
+	    absdir="$abs_ladir"
+	    libdir="$abs_ladir"
+	  else
+	    dir="$libdir"
+	    absdir="$libdir"
+	  fi
+	  test "X$hardcode_automatic" = Xyes && avoidtemprpath=yes
+	else
+	  if test ! -f "$ladir/$objdir/$linklib" && test -f "$abs_ladir/$linklib"; then
+	    dir="$ladir"
+	    # Remove this search path later
+	    notinst_path="$notinst_path $abs_ladir"
+	  else
+	    dir="$ladir/$objdir"
+	    absdir="$abs_ladir/$objdir"
+	  fi
+	fi # $installed = yes
+	func_stripname 'lib' '.la' "$laname"
+	# This library was specified with -dlpreopen.
+	if test "$pass" = dlpreopen; then
+	  if test -z "$libdir" && test "$linkmode" = prog; then
+	    func_fatal_error "only libraries may -dlpreopen a convenience library: \`$lib'"
+	  fi
+	  # Prefer using a static library (so that no silly _DYNAMIC symbols
+	  # are required to link).
+	  if test -n "$old_library"; then
+	    newdlprefiles="$newdlprefiles $dir/$old_library"
+	    # Keep a list of preopened convenience libraries to check
+	    # that they are being used correctly in the link pass.
+	    test -z "$libdir" && \
+		dlpreconveniencelibs="$dlpreconveniencelibs $dir/$old_library"
+	  # Otherwise, use the dlname, so that lt_dlopen finds it.
+	  elif test -n "$dlname"; then
+	    newdlprefiles="$newdlprefiles $dir/$dlname"
+	  else
+	    newdlprefiles="$newdlprefiles $dir/$linklib"
+	  fi
+	fi # $pass = dlpreopen
+	  # Link the convenience library
+	    deplibs="$dir/$old_library $deplibs"
+	  elif test "$linkmode,$pass" = "prog,link"; then
+	    compile_deplibs="$dir/$old_library $compile_deplibs"
+	    finalize_deplibs="$dir/$old_library $finalize_deplibs"
+	  else
+	    deplibs="$lib $deplibs" # used for prog,scan pass
+	  fi
+	  continue
+	fi
+	if test "$linkmode" = prog && test "$pass" != link; then
+	  newlib_search_path="$newlib_search_path $ladir"
+	  linkalldeplibs=no
+	  if test "$link_all_deplibs" != no || test -z "$library_names" ||
+	    linkalldeplibs=yes
+	  fi
+	  tmp_libs=
+	    case $deplib in
+	    -L*) func_stripname '-L' '' "$deplib"
+	    esac
+	    # Need to link against all dependency_libs?
+	    if test "$linkalldeplibs" = yes; then
+	    else
+	      # Need to hardcode shared library paths
+	      # or/and link against static libraries
+	    fi
+	      esac
+	    fi
+	  done # for deplib
+	  continue
+	fi # $linkmode = prog...
+	  if test -n "$library_names" &&
+	     { { test "$prefer_static_libs" = no ||
+	         test "$prefer_static_libs,$installed" = "built,yes"; } ||
+	       test -z "$old_library"; }; then
+	    # We need to hardcode the library path
+	    if test -n "$shlibpath_var" && test -z "$avoidtemprpath" ; then
+	      # Make sure the rpath contains only unique directories.
+	      case "$temp_rpath:" in
+	      *"$absdir:"*) ;;
+	      *) temp_rpath="$temp_rpath$absdir:" ;;
+	      esac
+	    fi
+	    # Hardcode the library path.
+	    # Skip directories that are in the system default run-time
+	    # search path.
+	    case " $sys_lib_dlsearch_path " in
+	    *" $absdir "*) ;;
+	      case "$compile_rpath " in
+	      *" $absdir "*) ;;
+	      *) compile_rpath="$compile_rpath $absdir"
+	      esac
+	    esac
+	    *" $libdir "*) ;;
+	      case "$finalize_rpath " in
+	      *" $libdir "*) ;;
+	      *) finalize_rpath="$finalize_rpath $libdir"
+	      esac
+	    esac
+	  fi # $linkmode,$pass = prog,link...
+	  if test "$alldeplibs" = yes &&
+	     { test "$deplibs_check_method" = pass_all ||
+	       { test "$build_libtool_libs" = yes &&
+		 test -n "$library_names"; }; }; then
+	    # We only need to search for static libraries
+	    continue
+	  fi
+	fi
+	link_static=no # Whether the deplib will be linked statically
+	use_static_libs=$prefer_static_libs
+	if test "$use_static_libs" = built && test "$installed" = yes; then
+	  use_static_libs=no
+	fi
+	   { test "$use_static_libs" = no || test -z "$old_library"; }; then
+	  case $host in
+	  *cygwin* | *mingw* | *cegcc*)
+	      # No point in relinking DLLs because paths are not encoded
+	      notinst_deplibs="$notinst_deplibs $lib"
+	      need_relink=no
+	    if test "$installed" = no; then
+	      need_relink=yes
+	    fi
+	  esac
+	  # This is a shared library
+	  # Warn about portability, can't link against -module's on some
+	  # systems (darwin).  Don't bleat about dlopened modules though!
+	  dlopenmodule=""
+	  for dlpremoduletest in $dlprefiles; do
+	    if test "X$dlpremoduletest" = "X$lib"; then
+	      dlopenmodule="$dlpremoduletest"
+	      break
+	    fi
+	  done
+	  if test -z "$dlopenmodule" && test "$shouldnotlink" = yes && test "$pass" = link; then
+	    $ECHO
+	      $ECHO "*** Warning: Linking the executable $output against the loadable module"
+	    else
+	      $ECHO "*** Warning: Linking the shared library $output against the loadable module"
+	    fi
+	    $ECHO "*** $linklib is not portable!"
+	  fi
+	  if test "$linkmode" = lib &&
+	     test "$hardcode_into_libs" = yes; then
+	    # search path.
+	    *" $absdir "*) ;;
+	      *" $absdir "*) ;;
+	      esac
+	    esac
+	    *" $libdir "*) ;;
+	      *" $libdir "*) ;;
+	      esac
+	    esac
+	  fi
+	  if test -n "$old_archive_from_expsyms_cmds"; then
+	    # figure out the soname
+	    set dummy $library_names
+	    shift
+	    realname="$1"
+	    shift
+	    libname=`eval "\\$ECHO \"$libname_spec\""`
+	    # use dlname if we got it. it's perfectly good, no?
+	    if test -n "$dlname"; then
+	      soname="$dlname"
+	    elif test -n "$soname_spec"; then
+	      # bleh windows
+	      case $host in
+	      *cygwin* | mingw* | *cegcc*)
+	        func_arith $current - $age
+		major=$func_arith_result
+		versuffix="-$major"
+	      esac
+	      eval soname=\"$soname_spec\"
+	    else
+	      soname="$realname"
+	    fi
+	    # Make a new name for the extract_expsyms_cmds to use
+	    soroot="$soname"
+	    func_basename "$soroot"
+	    soname="$func_basename_result"
+	    func_stripname 'lib' '.dll' "$soname"
+	    newlib=libimp-$func_stripname_result.a
+	    # If the library has no export list, then create one now
+	    if test -f "$output_objdir/$soname-def"; then :
+	    else
+	      func_verbose "extracting exported symbol list from \`$soname'"
+	      func_execute_cmds "$extract_expsyms_cmds" 'exit $?'
+	    fi
+	    # Create $newlib
+	    if test -f "$output_objdir/$newlib"; then :; else
+	      func_verbose "generating import library for \`$soname'"
+	      func_execute_cmds "$old_archive_from_expsyms_cmds" 'exit $?'
+	    fi
+	    # make sure the library variables are pointing to the new library
+	    dir=$output_objdir
+	    linklib=$newlib
+	  fi # test -n "$old_archive_from_expsyms_cmds"
+	  if test "$linkmode" = prog || test "$mode" != relink; then
+	    add_shlibpath=
+	    add_dir=
+	    add=
+	    lib_linked=yes
+	    case $hardcode_action in
+	    immediate | unsupported)
+	      if test "$hardcode_direct" = no; then
+		add="$dir/$linklib"
+		case $host in
+		  *-*-sco3.2v5.0.[024]*) add_dir="-L$dir" ;;
+		  *-*-sysv4*uw2*) add_dir="-L$dir" ;;
+		  *-*-sysv5OpenUNIX* | *-*-sysv5UnixWare7.[01].[10]* | \
+		    *-*-unixware7*) add_dir="-L$dir" ;;
+		  *-*-darwin* )
+		    # if the lib is a (non-dlopened) module then we can not
+		    # link against it, someone is ignoring the earlier warnings
+		    if /usr/bin/file -L $add 2> /dev/null |
+			 $GREP ": [^:]* bundle" >/dev/null ; then
+		      if test "X$dlopenmodule" != "X$lib"; then
+			$ECHO "*** Warning: lib $linklib is a module, not a shared library"
+			if test -z "$old_library" ; then
+			  $ECHO
+			  $ECHO "*** And there doesn't seem to be a static archive available"
+			  $ECHO "*** The link will probably fail, sorry"
+			else
+			  add="$dir/$old_library"
+			fi
+		      elif test -n "$old_library"; then
+		      fi
+		    fi
+		esac
+	      elif test "$hardcode_minus_L" = no; then
+		case $host in
+		*-*-sunos*) add_shlibpath="$dir" ;;
+		esac
+		add_dir="-L$dir"
+		add="-l$name"
+	      elif test "$hardcode_shlibpath_var" = no; then
+		add_shlibpath="$dir"
+		add="-l$name"
+	      else
+		lib_linked=no
+	      fi
+	    relink)
+	      if test "$hardcode_direct" = yes &&
+	         test "$hardcode_direct_absolute" = no; then
+	      elif test "$hardcode_minus_L" = yes; then
+		add_dir="-L$dir"
+		# Try looking first in the location we're being installed to.
+		if test -n "$inst_prefix_dir"; then
+		  case $libdir in
+		      add_dir="$add_dir -L$inst_prefix_dir$libdir"
+		  esac
+		fi
+		add="-l$name"
+	      elif test "$hardcode_shlibpath_var" = yes; then
+		add="-l$name"
+	      else
+		lib_linked=no
+	      fi
+	    *) lib_linked=no ;;
+	    esac
+	    if test "$lib_linked" != yes; then
+	      func_fatal_configuration "unsupported hardcode properties"
+	    fi
+	    if test -n "$add_shlibpath"; then
+	      case :$compile_shlibpath: in
+	      *":$add_shlibpath:"*) ;;
+	      *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
+	      esac
+	    fi
+	      test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
+	      test -n "$add" && compile_deplibs="$add $compile_deplibs"
+	    else
+	      test -n "$add_dir" && deplibs="$add_dir $deplibs"
+	      test -n "$add" && deplibs="$add $deplibs"
+	      if test "$hardcode_direct" != yes &&
+		 test "$hardcode_minus_L" != yes &&
+		 test "$hardcode_shlibpath_var" = yes; then
+		case :$finalize_shlibpath: in
+		*":$libdir:"*) ;;
+		*) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
+		esac
+	      fi
+	    fi
+	  fi
+	  if test "$linkmode" = prog || test "$mode" = relink; then
+	    add_shlibpath=
+	    add_dir=
+	    add=
+	    # Finalize command for both is simple: just hardcode it.
+	      add="$libdir/$linklib"
+	      add_dir="-L$libdir"
+	      add="-l$name"
+	      *":$libdir:"*) ;;
+	      esac
+	      add="-l$name"
+	    elif test "$hardcode_automatic" = yes; then
+	      if test -n "$inst_prefix_dir" &&
+		 test -f "$inst_prefix_dir$libdir/$linklib" ; then
+		add="$inst_prefix_dir$libdir/$linklib"
+	      else
+	      fi
+	    else
+	      # We cannot seem to hardcode it, guess we'll fake it.
+		case $libdir in
+		esac
+	      fi
+	      add="-l$name"
+	    fi
+	      test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
+	      test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
+	    else
+	    fi
+	  fi
+	  # Here we assume that one of hardcode_direct or hardcode_minus_L
+	  # is not unsupported.  This is valid on all known static and
+	  # shared platforms.
+	  if test "$hardcode_direct" != unsupported; then
+	    test -n "$old_library" && linklib="$old_library"
+	    compile_deplibs="$dir/$linklib $compile_deplibs"
+	    finalize_deplibs="$dir/$linklib $finalize_deplibs"
+	  else
+	    compile_deplibs="-l$name -L$dir $compile_deplibs"
+	    finalize_deplibs="-l$name -L$dir $finalize_deplibs"
+	  fi
+	elif test "$build_libtool_libs" = yes; then
+	  # Not a shared library
+	  if test "$deplibs_check_method" != pass_all; then
+	    # We're trying link a shared library against a static one
+	    # but the system doesn't support it.
+	    # Just print a warning and add the library to dependency_libs so
+	    # that the program can be linked against the static library.
+	    $ECHO
+	    $ECHO "*** Warning: This system can not link to static lib archive $lib."
+	    $ECHO "*** shared version of the library, which you do not appear to have."
+	    if test "$module" = yes; then
+	      $ECHO "*** But as you try to build a module library, libtool will still create "
+	      $ECHO "*** a static module, that should work as long as the dlopening application"
+	      $ECHO "*** is linked with the -dlopen flag to resolve symbols at runtime."
+	      if test -z "$global_symbol_pipe"; then
+		$ECHO
+		$ECHO "*** However, this would only work if libtool was able to extract symbol"
+		$ECHO "*** lists from a program, using \`nm' or equivalent, but libtool could"
+		$ECHO "*** not find such a program.  So, this module is probably useless."
+		$ECHO "*** \`nm' from GNU binutils and a full rebuild may help."
+	      fi
+	      if test "$build_old_libs" = no; then
+		build_libtool_libs=module
+	      else
+	      fi
+	    fi
+	  else
+	    link_static=yes
+	  fi
+	fi # link shared/static library?
+	  if test -n "$dependency_libs" &&
+	     { test "$hardcode_into_libs" != yes ||
+	       test "$build_old_libs" = yes ||
+	       test "$link_static" = yes; }; then
+	    # Extract -R from dependency_libs
+	    temp_deplibs=
+	    for libdir in $dependency_libs; do
+	      case $libdir in
+	      -R*) func_stripname '-R' '' "$libdir"
+	           temp_xrpath=$func_stripname_result
+		   case " $xrpath " in
+		   *" $temp_xrpath "*) ;;
+		   *) xrpath="$xrpath $temp_xrpath";;
+		   esac;;
+	      *) temp_deplibs="$temp_deplibs $libdir";;
+	      esac
+	    done
+	    dependency_libs="$temp_deplibs"
+	  fi
+	  newlib_search_path="$newlib_search_path $absdir"
+	  # Link against this library
+	  test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
+	  # ... and its dependency_libs
+	  tmp_libs=
+	      esac
+	    fi
+	  done
+	  if test "$link_all_deplibs" != no; then
+	    # Add the search paths of all dependency libraries
+	      case $deplib in
+	      -L*) path="$deplib" ;;
+	      *.la)
+	        func_dirname "$deplib" "" "."
+		dir="$func_dirname_result"
+		case $dir in
+		[\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
+		  if test -z "$absdir"; then
+		    func_warning "cannot determine absolute directory name of \`$dir'"
+		    absdir="$dir"
+		  fi
+		esac
+		if $GREP "^installed=no" $deplib > /dev/null; then
+		case $host in
+		*-*-darwin*)
+		  depdepl=
+		  eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
+		  if test -n "$deplibrary_names" ; then
+		    for tmp in $deplibrary_names ; do
+		      depdepl=$tmp
+		    done
+		    if test -f "$absdir/$objdir/$depdepl" ; then
+		      depdepl="$absdir/$objdir/$depdepl"
+		      darwin_install_name=`${OTOOL} -L $depdepl | awk '{if (NR == 2) {print $1;exit}}'`
+                      if test -z "$darwin_install_name"; then
+                          darwin_install_name=`${OTOOL64} -L $depdepl  | awk '{if (NR == 2) {print $1;exit}}'`
+                      fi
+		      compiler_flags="$compiler_flags ${wl}-dylib_file ${wl}${darwin_install_name}:${depdepl}"
+		      linker_flags="$linker_flags -dylib_file ${darwin_install_name}:${depdepl}"
+		      path=
+		    fi
+		  fi
+		  path="-L$absdir/$objdir"
+		esac
+		else
+		  eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
+		    func_fatal_error "\`$deplib' is not a valid libtool archive"
+		  test "$absdir" != "$libdir" && \
+		    func_warning "\`$deplib' seems to be moved"
+		  path="-L$absdir"
+		fi
+	      esac
+	      case " $deplibs " in
+	      *" $path "*) ;;
+	      *) deplibs="$path $deplibs" ;;
+	      esac
+	    done
+	  fi # link_all_deplibs != no
+	fi # linkmode = lib
+      done # for deplib in $libs
+	if test "$linkmode" = "prog"; then
+	  compile_deplibs="$new_inherited_linker_flags $compile_deplibs"
+	  finalize_deplibs="$new_inherited_linker_flags $finalize_deplibs"
+	else
+	  compiler_flags="$compiler_flags "`$ECHO "X $new_inherited_linker_flags" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+	fi
+      fi
+      dependency_libs="$newdependency_libs"
+	# Link the dlpreopened libraries before other libraries
+	for deplib in $save_deplibs; do
+	done
+      fi
+      if test "$pass" != dlopen; then
+	if test "$pass" != conv; then
+	  # Make sure lib_search_path contains only unique directories.
+	  lib_search_path=
+	  for dir in $newlib_search_path; do
+	    case "$lib_search_path " in
+	    *" $dir "*) ;;
+	    *) lib_search_path="$lib_search_path $dir" ;;
+	    esac
+	  done
+	fi
+	if test "$linkmode,$pass" != "prog,link"; then
+	  vars="deplibs"
+	else
+	  vars="compile_deplibs finalize_deplibs"
+	fi
+	for var in $vars dependency_libs; do
+	  # Add libraries to $var in reverse order
+	  eval tmp_libs=\"\$$var\"
+	  new_libs=
+	  for deplib in $tmp_libs; do
+	    # FIXME: Pedantically, this is the right thing to do, so
+	    #        that some nasty dependency loop isn't accidentally
+	    #        broken:
+	    #new_libs="$deplib $new_libs"
+	    # Pragmatically, this seems to cause very few problems in
+	    # practice:
+	    case $deplib in
+	    -L*) new_libs="$deplib $new_libs" ;;
+	    -R*) ;;
+	      # And here is the reason: when a library appears more
+	      # than once as an explicit dependence of a library, or
+	      # is implicitly linked in more than once by the
+	      # compiler, it is considered special, and multiple
+	      # occurrences thereof are not removed.  Compare this
+	      # with having the same library being listed as a
+	      # dependency of multiple other libraries: in this case,
+	      # we know (pedantically, we assume) the library does not
+	      # need to be listed more than once, so we keep only the
+	      # last copy.  This is not always right, but it is rare
+	      # enough that we require users that really mean to play
+	      # such unportable linking tricks to link the library
+	      # using -Wl,-lname, so that libtool does not consider it
+	      # for duplicate removal.
+	      case " $specialdeplibs " in
+	      *" $deplib "*) new_libs="$deplib $new_libs" ;;
+		case " $new_libs " in
+		*" $deplib "*) ;;
+		*) new_libs="$deplib $new_libs" ;;
+		esac
+	      esac
+	    esac
+	  done
+	  tmp_libs=
+	  for deplib in $new_libs; do
+	    case $deplib in
+	    -L*)
+	      case " $tmp_libs " in
+	      *" $deplib "*) ;;
+	      *) tmp_libs="$tmp_libs $deplib" ;;
+	      esac
+	    esac
+	  done
+	  eval $var=\"$tmp_libs\"
+	done # for var
+      fi
+      # Last step: remove runtime libs from dependency_libs
+      # (they stay in deplibs)
+      tmp_libs=
+      for i in $dependency_libs ; do
+	case " $predeps $postdeps $compiler_lib_search_path " in
+	*" $i "*)
+	  i=""
+	esac
+	if test -n "$i" ; then
+	  tmp_libs="$tmp_libs $i"
+	fi
+      done
+      dependency_libs=$tmp_libs
+    done # for pass
+      dlfiles="$newdlfiles"
+    fi
+    if test "$linkmode" = prog || test "$linkmode" = lib; then
+      dlprefiles="$newdlprefiles"
+    fi
+    case $linkmode in
+    oldlib)
+      if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
+	func_warning "\`-dlopen' is ignored for archives"
+      fi
+      case " $deplibs" in
+      *\ -l* | *\ -L*)
+	func_warning "\`-l' and \`-L' are ignored for archives" ;;
+      esac
+      test -n "$rpath" && \
+	func_warning "\`-rpath' is ignored for archives"
+      test -n "$xrpath" && \
+	func_warning "\`-R' is ignored for archives"
+      test -n "$vinfo" && \
+	func_warning "\`-version-info/-version-number' is ignored for archives"
+      test -n "$release" && \
+	func_warning "\`-release' is ignored for archives"
+      test -n "$export_symbols$export_symbols_regex" && \
+	func_warning "\`-export-symbols' is ignored for archives"
+      # Now set the variables for building old libraries.
+      oldlibs="$output"
+      objs="$objs$old_deplibs"
+    lib)
+      # Make sure we only generate libraries of the form `libNAME.la'.
+      case $outputname in
+      lib*)
+	func_stripname 'lib' '.la' "$outputname"
+	eval shared_ext=\"$shrext_cmds\"
+	eval libname=\"$libname_spec\"
+	test "$module" = no && \
+	  func_fatal_help "libtool library \`$output' must begin with \`lib'"
+	if test "$need_lib_prefix" != no; then
+	  # Add the "lib" prefix for modules if required
+	  func_stripname '' '.la' "$outputname"
+	else
+	  libname=$func_stripname_result
+	fi
+      esac
+      if test -n "$objs"; then
+	  func_fatal_error "cannot build libtool library \`$output' from non-libtool objects on this host:$objs"
+	else
+	  $ECHO
+	  $ECHO "*** Warning: Linking the shared library $output against the non-libtool"
+	  $ECHO "*** objects $objs is not portable!"
+	  libobjs="$libobjs $objs"
+	fi
+      fi
+      test "$dlself" != no && \
+	func_warning "\`-dlopen self' is ignored for libtool libraries"
+      set dummy $rpath
+      shift
+      test "$#" -gt 1 && \
+	func_warning "ignoring multiple \`-rpath's for a libtool library"
+      install_libdir="$1"
+      oldlibs=
+      if test -z "$rpath"; then
+	if test "$build_libtool_libs" = yes; then
+	  # Building a libtool convenience library.
+	  # Some compilers have problems with a `.al' extension so
+	  # convenience libraries should have the same extension an
+	  # archive normally would.
+	  oldlibs="$output_objdir/$libname.$libext $oldlibs"
+	  build_libtool_libs=convenience
+	fi
+	  func_warning "\`-version-info/-version-number' is ignored for convenience libraries"
+	  func_warning "\`-release' is ignored for convenience libraries"
+      else
+	# Parse the version information argument.
+	save_ifs="$IFS"; IFS=':'
+	set dummy $vinfo 0 0 0
+	shift
+	IFS="$save_ifs"
+	test -n "$7" && \
+	  func_fatal_help "too many parameters to \`-version-info'"
+	# convert absolute version numbers to libtool ages
+	# this retains compatibility with .la files and attempts
+	# to make the code below a bit more comprehensible
+	case $vinfo_number in
+	yes)
+	  number_major="$1"
+	  number_minor="$2"
+	  number_revision="$3"
+	  # There are really only two kinds -- those that
+	  # use the current revision as the major version
+	  # and those that subtract age and use age as
+	  # a minor version.  But, then there is irix
+	  # which has an extra 1 added just for fun
+	  case $version_type in
+	  darwin|linux|osf|windows|none)
+	    func_arith $number_major + $number_minor
+	    current=$func_arith_result
+	    age="$number_minor"
+	    revision="$number_revision"
+	  freebsd-aout|freebsd-elf|sunos)
+	    current="$number_major"
+	    revision="$number_minor"
+	    age="0"
+	  irix|nonstopux)
+	    lt_irix_increment=no
+	  esac
+	no)
+	  current="$1"
+	  revision="$2"
+	  age="$3"
+	esac
+	# Check that each of the things are valid numbers.
+	case $current in
+	0|[1-9]|[1-9][0-9]|[1-9][0-9][0-9]|[1-9][0-9][0-9][0-9]|[1-9][0-9][0-9][0-9][0-9]) ;;
+	  func_error "CURRENT \`$current' must be a nonnegative integer"
+	  func_fatal_error "\`$vinfo' is not valid version information"
+	esac
+	case $revision in
+	  func_error "REVISION \`$revision' must be a nonnegative integer"
+	esac
+	case $age in
+	  func_error "AGE \`$age' must be a nonnegative integer"
+	esac
+	if test "$age" -gt "$current"; then
+	  func_error "AGE \`$age' is greater than the current interface number \`$current'"
+	fi
+	# Calculate the version variables.
+	major=
+	versuffix=
+	verstring=
+	none) ;;
+	darwin)
+	  # Like Linux, but with the current version available in
+	  # verstring for coding it into the library header
+	  major=.$func_arith_result
+	  versuffix="$major.$age.$revision"
+	  # Darwin ld doesn't like 0 for these options...
+	  func_arith $current + 1
+	  minor_current=$func_arith_result
+	  xlcverstring="${wl}-compatibility_version ${wl}$minor_current ${wl}-current_version ${wl}$minor_current.$revision"
+	  verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
+	freebsd-aout)
+	  major=".$current"
+	  versuffix=".$current.$revision";
+	freebsd-elf)
+	  major=".$current"
+	  versuffix=".$current"
+	irix | nonstopux)
+	  if test "X$lt_irix_increment" = "Xno"; then
+	  else
+	    func_arith $current - $age + 1
+	  fi
+	    nonstopux) verstring_prefix=nonstopux ;;
+	    *)         verstring_prefix=sgi ;;
+	  esac
+	  verstring="$verstring_prefix$major.$revision"
+	  # Add in all the interfaces that we are compatible with.
+	  loop=$revision
+	  while test "$loop" -ne 0; do
+	    func_arith $revision - $loop
+	    iface=$func_arith_result
+	    func_arith $loop - 1
+	    loop=$func_arith_result
+	    verstring="$verstring_prefix$major.$iface:$verstring"
+	  done
+	  # Before this point, $major must not contain `.'.
+	  major=.$major
+	  versuffix="$major.$revision"
+	linux)
+	osf)
+	  versuffix=".$current.$age.$revision"
+	  verstring="$current.$age.$revision"
+	  loop=$age
+	    func_arith $current - $loop
+	    verstring="$verstring:${iface}.0"
+	  done
+	  # Make executables depend on our current version.
+	  verstring="$verstring:${current}.0"
+	qnx)
+	  major=".$current"
+	sunos)
+	  major=".$current"
+	windows)
+	  # Use '-' rather than '.', since we only want one
+	  # extension on DOS 8.3 filesystems.
+	  func_fatal_configuration "unknown library version type \`$version_type'"
+	esac
+	# Clear the version info if we defaulted, and they specified a release.
+	if test -z "$vinfo" && test -n "$release"; then
+	  major=
+	  darwin)
+	    # we can't check for "0.0" in archive_cmds due to quoting
+	    # problems, so we reset it completely
+	    verstring=
+	    verstring="0.0"
+	  esac
+	  if test "$need_version" = no; then
+	    versuffix=
+	  else
+	    versuffix=".0.0"
+	  fi
+	fi
+	# Remove version info from name if versioning should be avoided
+	if test "$avoid_version" = yes && test "$need_version" = no; then
+	  major=
+	  versuffix=
+	  verstring=""
+	fi
+	# Check to see if the archive will have undefined symbols.
+	if test "$allow_undefined" = yes; then
+	  if test "$allow_undefined_flag" = unsupported; then
+	    func_warning "undefined symbols not allowed in $host shared libraries"
+	  fi
+	else
+	  # Don't allow undefined symbols.
+	  allow_undefined_flag="$no_undefined_flag"
+	fi
+      fi
+      func_generate_dlsyms "$libname" "$libname" "yes"
+      libobjs="$libobjs $symfileobj"
+      test "X$libobjs" = "X " && libobjs=
+      if test "$mode" != relink; then
+	# Remove our outputs, but don't remove object files since they
+	# may have been created when compiling PIC objects.
+	removelist=
+	tempremovelist=`$ECHO "$output_objdir/*"`
+	for p in $tempremovelist; do
+	  case $p in
+	    *.$objext | *.gcno)
+	    $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
+	       if test "X$precious_files_regex" != "X"; then
+		 if $ECHO "$p" | $EGREP -e "$precious_files_regex" >/dev/null 2>&1
+		 then
+		   continue
+		 fi
+	       fi
+	       removelist="$removelist $p"
+	  esac
+	done
+	test -n "$removelist" && \
+	  func_show_eval "${RM}r \$removelist"
+      fi
+      if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
+	oldlibs="$oldlibs $output_objdir/$libname.$libext"
+	# Transform .lo files to .o files.
+	oldobjs="$objs "`$ECHO "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
+      fi
+      # Eliminate all temporary directories.
+      #for path in $notinst_path; do
+      #	lib_search_path=`$ECHO "X$lib_search_path " | $Xsed -e "s% $path % %g"`
+      #	deplibs=`$ECHO "X$deplibs " | $Xsed -e "s% -L$path % %g"`
+      #	dependency_libs=`$ECHO "X$dependency_libs " | $Xsed -e "s% -L$path % %g"`
+      #done
+      if test -n "$xrpath"; then
+	# If the user specified any rpath flags, then add them.
+	temp_xrpath=
+	for libdir in $xrpath; do
+	  temp_xrpath="$temp_xrpath -R$libdir"
+	  *" $libdir "*) ;;
+	  *) finalize_rpath="$finalize_rpath $libdir" ;;
+	  esac
+	done
+	if test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
+	  dependency_libs="$temp_xrpath $dependency_libs"
+	fi
+      fi
+      # Make sure dlfiles contains only unique files that won't be dlpreopened
+      old_dlfiles="$dlfiles"
+      dlfiles=
+      for lib in $old_dlfiles; do
+	case " $dlprefiles $dlfiles " in
+	*" $lib "*) ;;
+	*) dlfiles="$dlfiles $lib" ;;
+	esac
+      done
+      # Make sure dlprefiles contains only unique files
+      old_dlprefiles="$dlprefiles"
+      dlprefiles=
+      for lib in $old_dlprefiles; do
+	case "$dlprefiles " in
+	*" $lib "*) ;;
+	*) dlprefiles="$dlprefiles $lib" ;;
+	esac
+      done
+	if test -n "$rpath"; then
+	  case $host in
+	  *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos* | *-cegcc*)
+	    # these systems don't actually have a c library (as such)!
+	    # Rhapsody C library is in the System framework
+	  *-*-netbsd*)
+	    # Don't link with libc until the a.out ld.so is fixed.
+	    # Add libc to deplibs on all other systems if necessary.
+	    if test "$build_libtool_need_lc" = "yes"; then
+	      deplibs="$deplibs -lc"
+	    fi
+	  esac
+	fi
+	# Transform deplibs into only deplibs that can be linked in shared.
+	name_save=$name
+	libname_save=$libname
+	release_save=$release
+	versuffix_save=$versuffix
+	major_save=$major
+	# I'm not sure if I'm treating the release correctly.  I think
+	# release should show up in the -l (ie -lgmp5) so we don't want to
+	# add it in twice.  Is that correct?
+	release=""
+	versuffix=""
+	major=""
+	newdeplibs=
+	droppeddeps=no
+	pass_all)
+	  # Don't check for shared/static.  Everything works.
+	  # This might be a little naive.  We might want to check
+	  # whether the library exists or not.  But this is on
+	  # osf3 & osf4 and I'm not really sure... Just
+	  # implementing what was already the behavior.
+	  newdeplibs=$deplibs
+	test_compile)
+	  # This code stresses the "libraries are programs" paradigm to its
+	  # limits. Maybe even breaks it.  We compile a program, linking it
+	  # against the deplibs as a proxy for the library.  Then we can check
+	  # whether they linked in statically or dynamically with ldd.
+	  $opt_dry_run || $RM conftest.c
+	  cat > conftest.c <<EOF
+	  int main() { return 0; }
+EOF
+	  if $LTCC $LTCFLAGS -o conftest conftest.c $deplibs; then
+	    ldd_output=`ldd conftest`
+	    for i in $deplibs; do
+	      case $i in
+	      -l*)
+		func_stripname -l '' "$i"
+		  *" $i "*)
+		    newdeplibs="$newdeplibs $i"
+		    i=""
+		  esac
+		fi
+		  deplib_matches=`eval "\\$ECHO \"$library_names_spec\""`
+		  set dummy $deplib_matches; shift
+		  deplib_match=$1
+		  if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
+		  else
+		    droppeddeps=yes
+		    $ECHO
+		    $ECHO "*** Warning: dynamic linker does not accept needed library $i."
+		    $ECHO "*** shared version of the library, which I believe you do not have"
+		    $ECHO "*** because a test_compile did reveal that the linker did not use it for"
+		    $ECHO "*** its dynamic dependency list that programs get resolved with at runtime."
+		  fi
+		fi
+	      esac
+	    done
+	  else
+	    # Error occurred in the first compile.  Let's try to salvage
+	    # the situation: Compile a separate program for each library.
+	      case $i in
+	      -l*)
+		if $LTCC $LTCFLAGS -o conftest conftest.c $i; then
+		    *" $i "*)
+		      i=""
+		    esac
+		  fi
+		    deplib_match=$1
+		    else
+		      droppeddeps=yes
+		      $ECHO
+		      $ECHO "*** because a test_compile did reveal that the linker did not use this one"
+		      $ECHO "*** as a dynamic dependency that programs can get resolved with at runtime."
+		    fi
+		  fi
+		else
+		  droppeddeps=yes
+		  $ECHO
+		  $ECHO "*** Warning!  Library $i is needed by this library but I was not able to"
+		  $ECHO "*** make it link in!  You will probably need to install it or some"
+		  $ECHO "*** library that it depends on before this library will be fully"
+		  $ECHO "*** functional.  Installing it before continuing would be even better."
+		fi
+	      esac
+	    done
+	  fi
+	file_magic*)
+	  file_magic_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
+	  for a_deplib in $deplibs; do
+	    case $a_deplib in
+	    -l*)
+	      func_stripname -l '' "$a_deplib"
+		*" $a_deplib "*)
+		  newdeplibs="$newdeplibs $a_deplib"
+		  a_deplib=""
+		esac
+	      fi
+	      if test -n "$a_deplib" ; then
+		for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
+		  potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
+		  for potent_lib in $potential_libs; do
+		      # Follow soft links.
+		      if ls -lLd "$potent_lib" 2>/dev/null |
+			 $GREP " -> " >/dev/null; then
+			continue
+		      fi
+		      # The statement above tries to avoid entering an
+		      # endless loop below, in case of cyclic links.
+		      # We might still enter an endless loop, since a link
+		      # loop can be closed while we follow links,
+		      # but so what?
+		      potlib="$potent_lib"
+		      while test -h "$potlib" 2>/dev/null; do
+			potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
+			case $potliblink in
+			[\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
+			*) potlib=`$ECHO "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
+			esac
+		      done
+		      if eval $file_magic_cmd \"\$potlib\" 2>/dev/null |
+			 $SED -e 10q |
+			 $EGREP "$file_magic_regex" > /dev/null; then
+			a_deplib=""
+			break 2
+		      fi
+		  done
+		done
+	      fi
+		droppeddeps=yes
+		$ECHO
+		$ECHO "*** Warning: linker path does not have real file for library $a_deplib."
+		$ECHO "*** because I did check the linker path looking for a file starting"
+		if test -z "$potlib" ; then
+		  $ECHO "*** with $libname but no candidates were found. (...for file magic test)"
+		else
+		  $ECHO "*** with $libname and none of the candidates passed a file format test"
+		  $ECHO "*** using a file magic. Last file checked: $potlib"
+		fi
+	      fi
+	      # Add a -L argument.
+	    esac
+	  done # Gone through all deplibs.
+	match_pattern*)
+	    case $a_deplib in
+	    -l*)
+		*" $a_deplib "*)
+		  a_deplib=""
+		esac
+	      fi
+		    potlib="$potent_lib" # see symlink-check above in file_magic test
+		    if eval "\$ECHO \"X$potent_lib\"" 2>/dev/null | $Xsed -e 10q | \
+		       $EGREP "$match_pattern_regex" > /dev/null; then
+		      a_deplib=""
+		      break 2
+		    fi
+		  done
+		done
+	      fi
+		droppeddeps=yes
+		$ECHO
+		  $ECHO "*** with $libname but no candidates were found. (...for regex pattern test)"
+		else
+		  $ECHO "*** using a regex pattern. Last file checked: $potlib"
+		fi
+	      fi
+	    esac
+	none | unknown | *)
+	  newdeplibs=""
+	  tmp_deplibs=`$ECHO "X $deplibs" | $Xsed \
+	      -e 's/ -lc$//' -e 's/ -[LR][^ ]*//g'`
+	    for i in $predeps $postdeps ; do
+	      # can't use Xsed below, because $i might contain '/'
+	      tmp_deplibs=`$ECHO "X $tmp_deplibs" | $Xsed -e "s,$i,,"`
+	    done
+	  fi
+	  if $ECHO "X $tmp_deplibs" | $Xsed -e 's/[	 ]//g' |
+	     $GREP . >/dev/null; then
+	    $ECHO
+	    if test "X$deplibs_check_method" = "Xnone"; then
+	      $ECHO "*** Warning: inter-library dependencies are not supported in this platform."
+	    else
+	      $ECHO "*** Warning: inter-library dependencies are not known to be supported."
+	    fi
+	    $ECHO "*** All declared inter-library dependencies are being dropped."
+	    droppeddeps=yes
+	  fi
+	esac
+	versuffix=$versuffix_save
+	major=$major_save
+	release=$release_save
+	libname=$libname_save
+	name=$name_save
+	case $host in
+	  # On Rhapsody replace the C library with the System framework
+	  newdeplibs=`$ECHO "X $newdeplibs" | $Xsed -e 's/ -lc / System.ltframework /'`
+	esac
+	if test "$droppeddeps" = yes; then
+	    $ECHO
+	    $ECHO "*** Warning: libtool could not satisfy all declared inter-library"
+	    $ECHO "*** dependencies of module $libname.  Therefore, libtool will create"
+	    $ECHO "*** a static module, that should work as long as the dlopening"
+	    $ECHO "*** application is linked with the -dlopen flag."
+	      $ECHO
+	    fi
+	      oldlibs="$output_objdir/$libname.$libext"
+	    else
+	    fi
+	  else
+	    $ECHO "*** The inter-library dependencies that have been dropped here will be"
+	    $ECHO "*** automatically added whenever a program is linked with this library"
+	    $ECHO "*** or is declared to -dlopen it."
+	    if test "$allow_undefined" = no; then
+	      $ECHO
+	      $ECHO "*** Since this library must not contain undefined symbols,"
+	      $ECHO "*** because either the platform does not support them or"
+	      $ECHO "*** it was explicitly requested with -no-undefined,"
+	      $ECHO "*** libtool will only create a static version of it."
+	      else
+	      fi
+	    fi
+	  fi
+	fi
+	# Done checking deplibs!
+	deplibs=$newdeplibs
+      fi
+      # Time to change all our "foo.ltframework" stuff back to "-framework foo"
+      case $host in
+	*-*-darwin*)
+	  newdeplibs=`$ECHO "X $newdeplibs" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+	  new_inherited_linker_flags=`$ECHO "X $new_inherited_linker_flags" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+	  deplibs=`$ECHO "X $deplibs" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+      esac
+      # move library search paths that coincide with paths to not yet
+      # installed libraries to the beginning of the library search list
+      new_libs=
+      for path in $notinst_path; do
+	*" -L$path/$objdir "*) ;;
+	    new_libs="$new_libs -L$path/$objdir" ;;
+	  esac
+	esac
+      done
+	case $deplib in
+	-L*)
+	  *" $deplib "*) ;;
+	  *) new_libs="$new_libs $deplib" ;;
+	  esac
+	esac
+      done
+      deplibs="$new_libs"
+      # All the library-specific variables (install_libdir is set above).
+      library_names=
+      old_library=
+      dlname=
+      # Test again, we may have decided not to build it any more
+	if test "$hardcode_into_libs" = yes; then
+	  # Hardcode the library paths
+	  hardcode_libdirs=
+	  dep_rpath=
+	  rpath="$finalize_rpath"
+	  test "$mode" != relink && rpath="$compile_rpath$rpath"
+	  for libdir in $rpath; do
+	    if test -n "$hardcode_libdir_flag_spec"; then
+	      if test -n "$hardcode_libdir_separator"; then
+		if test -z "$hardcode_libdirs"; then
+		  hardcode_libdirs="$libdir"
+		else
+		  # Just accumulate the unique libdirs.
+		  case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
+		  *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
+		    hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
+		  esac
+		fi
+	      else
+		eval flag=\"$hardcode_libdir_flag_spec\"
+		dep_rpath="$dep_rpath $flag"
+	      fi
+	    elif test -n "$runpath_var"; then
+	      case "$perm_rpath " in
+	      *" $libdir "*) ;;
+	      *) perm_rpath="$perm_rpath $libdir" ;;
+	      esac
+	    fi
+	  done
+	  # Substitute the hardcoded libdirs into the rpath.
+	  if test -n "$hardcode_libdir_separator" &&
+	     test -n "$hardcode_libdirs"; then
+	    libdir="$hardcode_libdirs"
+	    if test -n "$hardcode_libdir_flag_spec_ld"; then
+	      eval dep_rpath=\"$hardcode_libdir_flag_spec_ld\"
+	    else
+	      eval dep_rpath=\"$hardcode_libdir_flag_spec\"
+	    fi
+	  fi
+	  if test -n "$runpath_var" && test -n "$perm_rpath"; then
+	    # We should set the runpath_var.
+	    rpath=
+	    for dir in $perm_rpath; do
+	      rpath="$rpath$dir:"
+	    done
+	    eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
+	  fi
+	  test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
+	fi
+	shlibpath="$finalize_shlibpath"
+	test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
+	if test -n "$shlibpath"; then
+	  eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
+	fi
+	# Get the real and link names of the library.
+	eval library_names=\"$library_names_spec\"
+	shift
+	realname="$1"
+	shift
+	if test -n "$soname_spec"; then
+	else
+	fi
+	if test -z "$dlname"; then
+	  dlname=$soname
+	fi
+	lib="$output_objdir/$realname"
+	linknames=
+	for link
+	do
+	  linknames="$linknames $link"
+	done
+	# Use standard objects if they are pic
+	test -z "$pic_flag" && libobjs=`$ECHO "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+	delfiles=
+	if test -n "$export_symbols" && test -n "$include_expsyms"; then
+	  $opt_dry_run || cp "$export_symbols" "$output_objdir/$libname.uexp"
+	  export_symbols="$output_objdir/$libname.uexp"
+	  delfiles="$delfiles $export_symbols"
+	fi
+	orig_export_symbols=
+	case $host_os in
+	cygwin* | mingw* | cegcc*)
+	  if test -n "$export_symbols" && test -z "$export_symbols_regex"; then
+	    # exporting using user supplied symfile
+	    if test "x`$SED 1q $export_symbols`" != xEXPORTS; then
+	      # and it's NOT already a .def file. Must figure out
+	      # which of the given symbols are data symbols and tag
+	      # them as such. So, trigger use of export_symbols_cmds.
+	      # export_symbols gets reassigned inside the "prepare
+	      # the list of exported symbols" if statement, so the
+	      # include_expsyms logic still works.
+	      orig_export_symbols="$export_symbols"
+	      export_symbols=
+	      always_export_symbols=yes
+	    fi
+	  fi
+	esac
+	# Prepare the list of exported symbols
+	if test -z "$export_symbols"; then
+	  if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
+	    func_verbose "generating symbol list for \`$libname.la'"
+	    export_symbols="$output_objdir/$libname.exp"
+	    $opt_dry_run || $RM $export_symbols
+	    cmds=$export_symbols_cmds
+	    save_ifs="$IFS"; IFS='~'
+	    for cmd in $cmds; do
+	      IFS="$save_ifs"
+	      eval cmd=\"$cmd\"
+	      func_len " $cmd"
+	      len=$func_len_result
+	      if test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
+		func_show_eval "$cmd" 'exit $?'
+		skipped_export=false
+	      else
+		# The command line is too long to execute in one step.
+		func_verbose "using reloadable object file for export list..."
+		skipped_export=:
+		# Break out early, otherwise skipped_export may be
+		# set to false by a later but shorter cmd.
+		break
+	      fi
+	    done
+	    IFS="$save_ifs"
+	    if test -n "$export_symbols_regex" && test "X$skipped_export" != "X:"; then
+	      func_show_eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
+	      func_show_eval '$MV "${export_symbols}T" "$export_symbols"'
+	    fi
+	  fi
+	fi
+	  tmp_export_symbols="$export_symbols"
+	  test -n "$orig_export_symbols" && tmp_export_symbols="$orig_export_symbols"
+	  $opt_dry_run || eval '$ECHO "X$include_expsyms" | $Xsed | $SP2NL >> "$tmp_export_symbols"'
+	fi
+	if test "X$skipped_export" != "X:" && test -n "$orig_export_symbols"; then
+	  # The given exports_symbols file has to be filtered, so filter it.
+	  func_verbose "filter symbol list for \`$libname.la' to tag DATA exports"
+	  # FIXME: $output_objdir/$libname.filter potentially contains lots of
+	  # 's' commands which not all seds can handle. GNU sed should be fine
+	  # though. Also, the filter scales superlinearly with the number of
+	  # global variables. join(1) would be nice here, but unfortunately
+	  # isn't a blessed tool.
+	  $opt_dry_run || $SED -e '/[ ,]DATA/!d;s,\(.*\)\([ \,].*\),s|^\1$|\1\2|,' < $export_symbols > $output_objdir/$libname.filter
+	  delfiles="$delfiles $export_symbols $output_objdir/$libname.filter"
+	  export_symbols=$output_objdir/$libname.def
+	  $opt_dry_run || $SED -f $output_objdir/$libname.filter < $orig_export_symbols > $export_symbols
+	fi
+	tmp_deplibs=
+	for test_deplib in $deplibs; do
+	  case " $convenience " in
+	  *" $test_deplib "*) ;;
+	    tmp_deplibs="$tmp_deplibs $test_deplib"
+	  esac
+	done
+	if test -n "$convenience"; then
+	  if test -n "$whole_archive_flag_spec" &&
+	    test "$compiler_needs_object" = yes &&
+	    test -z "$libobjs"; then
+	    # extract the archives, so we have objects to list.
+	    # TODO: could optimize this to just extract one archive.
+	    whole_archive_flag_spec=
+	  fi
+	  if test -n "$whole_archive_flag_spec"; then
+	    save_libobjs=$libobjs
+	    eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
+	  else
+	    gentop="$output_objdir/${outputname}x"
+	    generated="$generated $gentop"
+	    func_extract_archives $gentop $convenience
+	    libobjs="$libobjs $func_extract_archives_result"
+	  fi
+	fi
+	if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
+	  eval flag=\"$thread_safe_flag_spec\"
+	  linker_flags="$linker_flags $flag"
+	fi
+	# Make a backup of the uninstalled library when relinking
+	if test "$mode" = relink; then
+	  $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}U && $MV $realname ${realname}U)' || exit $?
+	fi
+	# Do each of the archive commands.
+	if test "$module" = yes && test -n "$module_cmds" ; then
+	  if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
+	    eval test_cmds=\"$module_expsym_cmds\"
+	    cmds=$module_expsym_cmds
+	  else
+	    eval test_cmds=\"$module_cmds\"
+	    cmds=$module_cmds
+	  fi
+	else
+	  if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
+	    eval test_cmds=\"$archive_expsym_cmds\"
+	    cmds=$archive_expsym_cmds
+	  else
+	    eval test_cmds=\"$archive_cmds\"
+	    cmds=$archive_cmds
+	  fi
+	fi
+	   func_len " $test_cmds" &&
+	   len=$func_len_result &&
+	   test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
+	else
+	  # The command line is too long to link in one step, link piecewise
+	  # or, if using GNU ld and skipped_export is not :, use a linker
+	  # script.
+	  # Save the value of $output and $libobjs because we want to
+	  # use them later.  If we have whole_archive_flag_spec, we
+	  # want to use save_libobjs as it was before
+	  # whole_archive_flag_spec was expanded, because we can't
+	  # assume the linker understands whole_archive_flag_spec.
+	  # This may have to be revisited, in case too many
+	  # convenience libraries get linked in and end up exceeding
+	  # the spec.
+	  if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
+	  fi
+	  save_output=$output
+	  output_la=`$ECHO "X$output" | $Xsed -e "$basename"`
+	  # Clear the reloadable object creation command queue and
+	  # initialize k to one.
+	  test_cmds=
+	  concat_cmds=
+	  objlist=
+	  last_robj=
+	  k=1
+	  if test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "$with_gnu_ld" = yes; then
+	    output=${output_objdir}/${output_la}.lnkscript
+	    func_verbose "creating GNU ld script: $output"
+	    $ECHO 'INPUT (' > $output
+	    for obj in $save_libobjs
+	    do
+	      $ECHO "$obj" >> $output
+	    done
+	    $ECHO ')' >> $output
+	    delfiles="$delfiles $output"
+	  elif test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "X$file_list_spec" != X; then
+	    func_verbose "creating linker input file list: $output"
+	    : > $output
+	    set x $save_libobjs
+	    shift
+	    firstobj=
+	    if test "$compiler_needs_object" = yes; then
+	      firstobj="$1 "
+	      shift
+	    fi
+	    for obj
+	    do
+	    done
+	    output=$firstobj\"$file_list_spec$output\"
+	  else
+	    if test -n "$save_libobjs"; then
+	      func_verbose "creating reloadable object files..."
+	      output=$output_objdir/$output_la-${k}.$objext
+	      eval test_cmds=\"$reload_cmds\"
+	      len0=$func_len_result
+	      len=$len0
+	      # Loop over the list of objects to be linked.
+	      do
+		func_len " $obj"
+		func_arith $len + $func_len_result
+		len=$func_arith_result
+		if test "X$objlist" = X ||
+		   test "$len" -lt "$max_cmd_len"; then
+		  func_append objlist " $obj"
+		else
+		  # The command $test_cmds is almost too long, add a
+		  # command to the queue.
+		  if test "$k" -eq 1 ; then
+		    # The first file doesn't have a previous command to add.
+		    eval concat_cmds=\"$reload_cmds $objlist $last_robj\"
+		  else
+		    # All subsequent reloadable object files will link in
+		    # the last one created.
+		    eval concat_cmds=\"\$concat_cmds~$reload_cmds $objlist $last_robj~\$RM $last_robj\"
+		  fi
+		  last_robj=$output_objdir/$output_la-${k}.$objext
+		  func_arith $k + 1
+		  k=$func_arith_result
+		  objlist=$obj
+		  func_len " $last_robj"
+		  func_arith $len0 + $func_len_result
+		fi
+	      done
+	      # Handle the remaining objects by creating one last
+	      # reloadable object file.  All subsequent reloadable object
+	      # files will link in the last one created.
+	      test -z "$concat_cmds" || concat_cmds=$concat_cmds~
+	      eval concat_cmds=\"\${concat_cmds}$reload_cmds $objlist $last_robj\"
+	      if test -n "$last_robj"; then
+	        eval concat_cmds=\"\${concat_cmds}~\$RM $last_robj\"
+	      fi
+	    else
+	      output=
+	    fi
+	    if ${skipped_export-false}; then
+	      libobjs=$output
+	      # Append the command to create the export file.
+	      eval concat_cmds=\"\$concat_cmds$export_symbols_cmds\"
+		eval concat_cmds=\"\$concat_cmds~\$RM $last_robj\"
+	      fi
+	    fi
+	    test -n "$save_libobjs" &&
+	      func_verbose "creating a temporary reloadable object file: $output"
+	    # Loop through the commands generated above and execute them.
+	    for cmd in $concat_cmds; do
+	      IFS="$save_ifs"
+	      $opt_silent || {
+		  func_quote_for_expand "$cmd"
+		  eval "func_echo $func_quote_for_expand_result"
+	      $opt_dry_run || eval "$cmd" || {
+		lt_exit=$?
+		# Restore the uninstalled library and exit
+		  ( cd "$output_objdir" && \
+		    $RM "${realname}T" && \
+		    $MV "${realname}U" "$realname" )
+		fi
+		exit $lt_exit
+	    done
+	    IFS="$save_ifs"
+	    if test -n "$export_symbols_regex" && ${skipped_export-false}; then
+	    fi
+	  fi
+	    fi
+	    if test -n "$orig_export_symbols"; then
+	    fi
+	  fi
+	  libobjs=$output
+	  # Restore the value of output.
+	  output=$save_output
+	  if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
+	  fi
+	  # Expand the library linking commands again to reset the
+	  # value of $libobjs for piecewise linking.
+	    else
+	      cmds=$module_cmds
+	    fi
+	  else
+	    else
+	    fi
+	  fi
+	fi
+	if test -n "$delfiles"; then
+	  # Append the command to remove temporary files to $cmds.
+	  eval cmds=\"\$cmds~\$RM $delfiles\"
+	fi
+	# Add any objects from preloaded convenience libraries
+	if test -n "$dlprefiles"; then
+	  func_extract_archives $gentop $dlprefiles
+	fi
+	  IFS="$save_ifs"
+	  eval cmd=\"$cmd\"
+	  $opt_silent || {
+	    lt_exit=$?
+	    fi
+	    exit $lt_exit
+	done
+	IFS="$save_ifs"
+	  $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}T && $MV $realname ${realname}T && $MV ${realname}U $realname)' || exit $?
+	    if test -z "$whole_archive_flag_spec"; then
+	      func_show_eval '${RM}r "$gentop"'
+	    fi
+	  fi
+	  exit $EXIT_SUCCESS
+	fi
+	# Create links to the real library.
+	for linkname in $linknames; do
+	  if test "$realname" != "$linkname"; then
+	    func_show_eval '(cd "$output_objdir" && $RM "$linkname" && $LN_S "$realname" "$linkname")' 'exit $?'
+	  fi
+	done
+	# If -module or -export-dynamic was specified, set the dlname.
+	if test "$module" = yes || test "$export_dynamic" = yes; then
+	  # On all known operating systems, these are identical.
+	  dlname="$soname"
+	fi
+      fi
+    obj)
+	func_warning "\`-dlopen' is ignored for objects"
+      fi
+      *\ -l* | *\ -L*)
+	func_warning "\`-l' and \`-L' are ignored for objects" ;;
+      esac
+	func_warning "\`-rpath' is ignored for objects"
+	func_warning "\`-R' is ignored for objects"
+	func_warning "\`-version-info' is ignored for objects"
+	func_warning "\`-release' is ignored for objects"
+      case $output in
+      *.lo)
+	test -n "$objs$old_deplibs" && \
+	  func_fatal_error "cannot build library object \`$output' from non-libtool objects"
+	libobj=$output
+	func_lo2o "$libobj"
+	obj=$func_lo2o_result
+	libobj=
+	obj="$output"
+      esac
+      # Delete the old objects.
+      $opt_dry_run || $RM $obj $libobj
+      # Objects from convenience libraries.  This assumes
+      # single-version convenience libraries.  Whenever we create
+      # different ones for PIC/non-PIC, this we'll have to duplicate
+      # the extraction.
+      reload_conv_objs=
+      gentop=
+      # reload_cmds runs $LD directly, so let us get rid of
+      # -Wl from whole_archive_flag_spec and hope we can get by with
+      # turning comma into space..
+      wl=
+	  eval tmp_whole_archive_flags=\"$whole_archive_flag_spec\"
+	  reload_conv_objs=$reload_objs\ `$ECHO "X$tmp_whole_archive_flags" | $Xsed -e 's|,| |g'`
+	else
+	  gentop="$output_objdir/${obj}x"
+	  reload_conv_objs="$reload_objs $func_extract_archives_result"
+	fi
+      fi
+      # Create the old-style object.
+      reload_objs="$objs$old_deplibs "`$ECHO "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
+      output="$obj"
+      func_execute_cmds "$reload_cmds" 'exit $?'
+      # Exit if we aren't doing a library object file.
+      if test -z "$libobj"; then
+	if test -n "$gentop"; then
+	fi
+      fi
+      if test "$build_libtool_libs" != yes; then
+	fi
+	# Create an invalid libtool object if no PIC, so that we don't
+	# accidentally link it into a program.
+	# $show "echo timestamp > $libobj"
+	# $opt_dry_run || eval "echo timestamp > $libobj" || exit $?
+      fi
+      if test -n "$pic_flag" || test "$pic_mode" != default; then
+	# Only do commands if we really have different PIC objects.
+	reload_objs="$libobjs $reload_conv_objs"
+	output="$libobj"
+      fi
+      fi
+    prog)
+      case $host in
+	*cygwin*) func_stripname '' '.exe' "$output"
+	          output=$func_stripname_result.exe;;
+      esac
+	func_warning "\`-version-info' is ignored for programs"
+	func_warning "\`-release' is ignored for programs"
+      test "$preload" = yes \
+        && test "$dlopen_support" = unknown \
+	&& test "$dlopen_self" = unknown \
+	&& test "$dlopen_self_static" = unknown && \
+	  func_warning "\`LT_INIT([dlopen])' not used. Assuming no dlopen support."
+      case $host in
+      *-*-rhapsody* | *-*-darwin1.[012])
+	# On Rhapsody replace the C library is the System framework
+	compile_deplibs=`$ECHO "X $compile_deplibs" | $Xsed -e 's/ -lc / System.ltframework /'`
+	finalize_deplibs=`$ECHO "X $finalize_deplibs" | $Xsed -e 's/ -lc / System.ltframework /'`
+      esac
+      case $host in
+      *-*-darwin*)
+	# Don't allow lazy linking, it breaks C++ global constructors
+	# But is supposedly fixed on 10.4 or later (yay!).
+	if test "$tagname" = CXX ; then
+	  case ${MACOSX_DEPLOYMENT_TARGET-10.0} in
+	    10.[0123])
+	      compile_command="$compile_command ${wl}-bind_at_load"
+	      finalize_command="$finalize_command ${wl}-bind_at_load"
+	  esac
+	fi
+	compile_deplibs=`$ECHO "X $compile_deplibs" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+	finalize_deplibs=`$ECHO "X $finalize_deplibs" | $Xsed -e 's% \([^ $]*\).ltframework% -framework \1%g'`
+      esac
+      new_libs=
+	  case " $compile_deplibs " in
+	  esac
+	esac
+      done
+      for deplib in $compile_deplibs; do
+	case $deplib in
+	-L*)
+	  *" $deplib "*) ;;
+	  esac
+	esac
+      done
+      compile_deplibs="$new_libs"
+      compile_command="$compile_command $compile_deplibs"
+      finalize_command="$finalize_command $finalize_deplibs"
+      if test -n "$rpath$xrpath"; then
+	for libdir in $rpath $xrpath; do
+	  # This is the magic to use -rpath.
+	  *" $libdir "*) ;;
+	  esac
+	done
+      fi
+      # Now hardcode the library paths
+      rpath=
+      hardcode_libdirs=
+      for libdir in $compile_rpath $finalize_rpath; do
+	    else
+	      esac
+	    fi
+	  else
+	    rpath="$rpath $flag"
+	  fi
+	  *" $libdir "*) ;;
+	  esac
+	fi
+	case $host in
+	*-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
+	  testbindir=`${ECHO} "$libdir" | ${SED} -e 's*/lib$*/bin*'`
+	  case :$dllsearchpath: in
+	  *":$libdir:"*) ;;
+	  ::) dllsearchpath=$libdir;;
+	  *) dllsearchpath="$dllsearchpath:$libdir";;
+	  esac
+	  *":$testbindir:"*) ;;
+	  ::) dllsearchpath=$testbindir;;
+	  *) dllsearchpath="$dllsearchpath:$testbindir";;
+	  esac
+	esac
+      done
+	eval rpath=\" $hardcode_libdir_flag_spec\"
+      fi
+      compile_rpath="$rpath"
+      rpath=
+      hardcode_libdirs=
+      for libdir in $finalize_rpath; do
+	    else
+	      esac
+	    fi
+	  else
+	  fi
+	  case "$finalize_perm_rpath " in
+	  *" $libdir "*) ;;
+	  *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
+	  esac
+	fi
+      done
+      fi
+      finalize_rpath="$rpath"
+      if test -n "$libobjs" && test "$build_old_libs" = yes; then
+	# Transform all the library objects into standard objects.
+	compile_command=`$ECHO "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+	finalize_command=`$ECHO "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+      fi
+      func_generate_dlsyms "$outputname" "@PROGRAM@" "no"
+      # template prelinking step
+      if test -n "$prelink_cmds"; then
+	func_execute_cmds "$prelink_cmds" 'exit $?'
+      fi
+      wrappers_required=yes
+      case $host in
+      *cygwin* | *mingw* )
+          wrappers_required=no
+        fi
+      *cegcc)
+        # Disable wrappers for cegcc, we are cross compiling anyway.
+        if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
+        fi
+      esac
+      if test "$wrappers_required" = no; then
+	# Replace the output file specification.
+	compile_command=`$ECHO "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
+	link_command="$compile_command$compile_rpath"
+	# We have no uninstalled library dependencies, so finalize right now.
+	exit_status=0
+	func_show_eval "$link_command" 'exit_status=$?'
+	# Delete the generated files.
+	if test -f "$output_objdir/${outputname}S.${objext}"; then
+	  func_show_eval '$RM "$output_objdir/${outputname}S.${objext}"'
+	fi
+	exit $exit_status
+      fi
+      if test -n "$compile_shlibpath$finalize_shlibpath"; then
+	compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
+      fi
+      if test -n "$finalize_shlibpath"; then
+	finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
+      fi
+      compile_var=
+      finalize_var=
+      if test -n "$runpath_var"; then
+	if test -n "$perm_rpath"; then
+	  rpath=
+	  done
+	  compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
+	fi
+	if test -n "$finalize_perm_rpath"; then
+	  rpath=
+	  for dir in $finalize_perm_rpath; do
+	  done
+	  finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
+	fi
+      fi
+      if test "$no_install" = yes; then
+	# We don't need to create a wrapper script.
+	link_command="$compile_var$compile_command$compile_rpath"
+	link_command=`$ECHO "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
+	# Delete the old output file.
+	$opt_dry_run || $RM $output
+	# Link the executable and exit
+	func_show_eval "$link_command" 'exit $?'
+      fi
+      if test "$hardcode_action" = relink; then
+	# Fast installation is not supported
+	relink_command="$finalize_var$finalize_command$finalize_rpath"
+	func_warning "this platform does not like uninstalled shared libraries"
+	func_warning "\`$output' will be relinked during installation"
+      else
+	if test "$fast_install" != no; then
+	  link_command="$finalize_var$compile_command$finalize_rpath"
+	  if test "$fast_install" = yes; then
+	    relink_command=`$ECHO "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
+	  else
+	    # fast_install is set to needless
+	    relink_command=
+	  fi
+	else
+	fi
+      fi
+      link_command=`$ECHO "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
+      # Delete the old output files.
+      $opt_dry_run || $RM $output $output_objdir/$outputname $output_objdir/lt-$outputname
+      # Now create the wrapper script.
+      func_verbose "creating $output"
+      # Quote the relink command for shipping.
+      if test -n "$relink_command"; then
+	# Preserve any variables that may affect compiler behavior
+	for var in $variables_saved_for_relink; do
+	  if eval test -z \"\${$var+set}\"; then
+	    relink_command="{ test -z \"\${$var+set}\" || $lt_unset $var || { $var=; export $var; }; }; $relink_command"
+	  elif eval var_value=\$$var; test -z "$var_value"; then
+	    relink_command="$var=; export $var; $relink_command"
+	  else
+	    func_quote_for_eval "$var_value"
+	    relink_command="$var=$func_quote_for_eval_result; export $var; $relink_command"
+	  fi
+	done
+	relink_command="(cd `pwd`; $relink_command)"
+	relink_command=`$ECHO "X$relink_command" | $Xsed -e "$sed_quote_subst"`
+      fi
+      # Quote $ECHO for shipping.
+      if test "X$ECHO" = "X$SHELL $progpath --fallback-echo"; then
+	case $progpath in
+	[\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $progpath --fallback-echo";;
+	*) qecho="$SHELL `pwd`/$progpath --fallback-echo";;
+	esac
+	qecho=`$ECHO "X$qecho" | $Xsed -e "$sed_quote_subst"`
+      else
+	qecho=`$ECHO "X$ECHO" | $Xsed -e "$sed_quote_subst"`
+      fi
+      # Only actually do things if not in dry run mode.
+      $opt_dry_run || {
+	# win32 will think the script is a binary if it has
+	# a .exe suffix, so we strip it off here.
+	case $output in
+	  *.exe) func_stripname '' '.exe' "$output"
+	         output=$func_stripname_result ;;
+	esac
+	# test for cygwin because mv fails w/o .exe extensions
+	case $host in
+	  *cygwin*)
+	    exeext=.exe
+	    func_stripname '' '.exe' "$outputname"
+	    outputname=$func_stripname_result ;;
+	  *) exeext= ;;
+	esac
+	case $host in
+	    func_dirname_and_basename "$output" "" "."
+	    output_name=$func_basename_result
+	    output_path=$func_dirname_result
+	    cwrappersource="$output_path/$objdir/lt-$output_name.c"
+	    cwrapper="$output_path/$output_name.exe"
+	    $RM $cwrappersource $cwrapper
+	    trap "$RM $cwrappersource $cwrapper; exit $EXIT_FAILURE" 1 2 15
+	    func_emit_cwrapperexe_src > $cwrappersource
+	    # The wrapper executable is built using the $host compiler,
+	    # because it contains $host paths and files. If cross-
+	    # compiling, it, like the target executable, must be
+	    # executed on the $host or under an emulation environment.
+	    $opt_dry_run || {
+	      $LTCC $LTCFLAGS -o $cwrapper $cwrappersource
+	      $STRIP $cwrapper
+	    # Now, create the wrapper script for func_source use:
+	    func_ltwrapper_scriptname $cwrapper
+	    $RM $func_ltwrapper_scriptname_result
+	    trap "$RM $func_ltwrapper_scriptname_result; exit $EXIT_FAILURE" 1 2 15
+	    $opt_dry_run || {
+	      # note: this script will not be executed, so do not chmod.
+	      if test "x$build" = "x$host" ; then
+		$cwrapper --lt-dump-script > $func_ltwrapper_scriptname_result
+	      else
+		func_emit_wrapper no > $func_ltwrapper_scriptname_result
+	      fi
+	    $RM $output
+	    trap "$RM $output; exit $EXIT_FAILURE" 1 2 15
+	    func_emit_wrapper no > $output
+	    chmod +x $output
+	esac
+    esac
+    # See if we need to build an old-fashioned archive.
+    for oldlib in $oldlibs; do
+      if test "$build_libtool_libs" = convenience; then
+	oldobjs="$libobjs_save $symfileobj"
+	addlibs="$convenience"
+	build_libtool_libs=no
+      else
+	if test "$build_libtool_libs" = module; then
+	  oldobjs="$libobjs_save"
+	else
+	  oldobjs="$old_deplibs $non_pic_objects"
+	  if test "$preload" = yes && test -f "$symfileobj"; then
+	    oldobjs="$oldobjs $symfileobj"
+	  fi
+	fi
+	addlibs="$old_convenience"
+      fi
+      if test -n "$addlibs"; then
+	func_extract_archives $gentop $addlibs
+	oldobjs="$oldobjs $func_extract_archives_result"
+      fi
+      # Do each command in the archive commands.
+      if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
+	cmds=$old_archive_from_new_cmds
+      else
+	fi
+	# POSIX demands no paths to be encoded in archives.  We have
+	# to avoid creating archives with duplicate basenames if we
+	# might have to extract them afterwards, e.g., when creating a
+	# static archive out of a convenience library, or when linking
+	# the entirety of a libtool archive into another (currently
+	# not supported by libtool).
+	if (for obj in $oldobjs
+	    do
+	      func_basename "$obj"
+	      $ECHO "$func_basename_result"
+	    done | sort | sort -uc >/dev/null 2>&1); then
+	else
+	  $ECHO "copying selected object files to avoid basename conflicts..."
+	  func_mkdir_p "$gentop"
+	  save_oldobjs=$oldobjs
+	  oldobjs=
+	  counter=1
+	  for obj in $save_oldobjs
+	  do
+	    objbase="$func_basename_result"
+	    case " $oldobjs " in
+	    " ") oldobjs=$obj ;;
+	    *[\ /]"$objbase "*)
+	      while :; do
+		# Make sure we don't pick an alternate name that also
+		# overlaps.
+		newobj=lt$counter-$objbase
+		func_arith $counter + 1
+		counter=$func_arith_result
+		*[\ /]"$newobj "*) ;;
+		*) if test ! -f "$gentop/$newobj"; then break; fi ;;
+		esac
+	      done
+	      func_show_eval "ln $obj $gentop/$newobj || cp $obj $gentop/$newobj"
+	      oldobjs="$oldobjs $gentop/$newobj"
+	    *) oldobjs="$oldobjs $obj" ;;
+	    esac
+	  done
+	fi
+	eval cmds=\"$old_archive_cmds\"
+	func_len " $cmds"
+	  cmds=$old_archive_cmds
+	else
+	  # the command line is too long to link in one step, link in parts
+	  func_verbose "using piecewise archive linking..."
+	  save_RANLIB=$RANLIB
+	  RANLIB=:
+	  objlist=
+	  concat_cmds=
+	  oldobjs=
+	  # Is there a better way of finding the last object in the list?
+	  do
+	    last_oldobj=$obj
+	  done
+	  eval test_cmds=\"$old_archive_cmds\"
+	  len=$len0
+	  do
+	    func_len " $obj"
+	    if test "$len" -lt "$max_cmd_len"; then
+	    else
+	      # the above command should be used before it gets too long
+	      oldobjs=$objlist
+	      if test "$obj" = "$last_oldobj" ; then
+		RANLIB=$save_RANLIB
+	      fi
+	      eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
+	      objlist=
+	      len=$len0
+	    fi
+	  done
+	  oldobjs=$objlist
+	  if test "X$oldobjs" = "X" ; then
+	    eval cmds=\"\$concat_cmds\"
+	  else
+	    eval cmds=\"\$concat_cmds~\$old_archive_cmds\"
+	  fi
+	fi
+      fi
+      func_execute_cmds "$cmds" 'exit $?'
+    done
+    test -n "$generated" && \
+      func_show_eval "${RM}r$generated"
+    # Now create the libtool archive.
+    case $output in
+    *.la)
+      old_library=
+      test "$build_old_libs" = yes && old_library="$libname.$libext"
+	else
+	fi
+      done
+      # Quote the link command for shipping.
+      relink_command="(cd `pwd`; $SHELL $progpath $preserve_args --mode=relink $libtool_args @inst_prefix_dir@)"
+      if test "$hardcode_automatic" = yes ; then
+	relink_command=
+      fi
+      # Only create the output if not a dry run.
+      $opt_dry_run || {
+	for installed in no yes; do
+	  if test "$installed" = yes; then
+	    if test -z "$install_libdir"; then
+	      break
+	    fi
+	    output="$output_objdir/$outputname"i
+	    # Replace all uninstalled libtool libraries with the installed ones
+	    newdependency_libs=
+	    for deplib in $dependency_libs; do
+	      case $deplib in
+	      *.la)
+		func_basename "$deplib"
+		name="$func_basename_result"
+		newdependency_libs="$newdependency_libs $libdir/$name"
+	      *) newdependency_libs="$newdependency_libs $deplib" ;;
+	      esac
+	    done
+	    newdlfiles=
+	    for lib in $dlfiles; do
+	      case $lib in
+	      *.la)
+	        func_basename "$lib"
+		eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
+		  func_fatal_error "\`$lib' is not a valid libtool archive"
+		newdlfiles="$newdlfiles $libdir/$name"
+	      *) newdlfiles="$newdlfiles $lib" ;;
+	      esac
+	    done
+	    newdlprefiles=
+	    for lib in $dlprefiles; do
+	      case $lib in
+	      *.la)
+		# Only pass preopened files to the pseudo-archive (for
+		# eventual linking with the app. that links it) if we
+		# didn't already link the preopened objects directly into
+		# the library:
+		test -z "$libdir" && \
+		newdlprefiles="$newdlprefiles $libdir/$name"
+	      esac
+	    done
+	  else
+	    newdlfiles=
+	      case $lib in
+		[\\/]* | [A-Za-z]:[\\/]*) abs="$lib" ;;
+		*) abs=`pwd`"/$lib" ;;
+	      esac
+	      newdlfiles="$newdlfiles $abs"
+	    done
+	    newdlprefiles=
+	      case $lib in
+	      esac
+	      newdlprefiles="$newdlprefiles $abs"
+	    done
+	  fi
+	  $RM $output
+	  # place dlname in correct position for cygwin
+	  tdlname=$dlname
+	  case $host,$output,$installed,$module,$dlname in
+	    *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll | *cegcc*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
+	  esac
+	  $ECHO > $output "\
+# $outputname - a libtool library file
+# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
+# Please DO NOT delete this file!
+# It is necessary for linking the library.
+# The name that we can dlopen(3).
+dlname='$tdlname'
+# Names of this library.
+library_names='$library_names'
+# The name of the static archive.
+old_library='$old_library'
+# Linker flags that can not go in dependency_libs.
+inherited_linker_flags='$new_inherited_linker_flags'
+# Libraries that this one depends upon.
+dependency_libs='$dependency_libs'
+# Names of additional weak libraries provided by this library
+weak_library_names='$weak_libs'
+# Version information for $libname.
+current=$current
+age=$age
+revision=$revision
+# Is this an already installed library?
+installed=$installed
+# Should we warn about portability when linking against -modules?
+shouldnotlink=$module
+# Files to dlopen/dlpreopen
+dlopen='$dlfiles'
+dlpreopen='$dlprefiles'
+# Directory that this library needs to be installed in:
+libdir='$install_libdir'"
+	  if test "$installed" = no && test "$need_relink" = yes; then
+	    $ECHO >> $output "\
+relink_command=\"$relink_command\""
+	  fi
+	done
+      # Do a symbolic link so that the libtool archive can be found in
+      # LD_LIBRARY_PATH before the program is installed.
+      func_show_eval '( cd "$output_objdir" && $RM "$outputname" && $LN_S "../$outputname" "$outputname" )' 'exit $?'
+    esac
+{ test "$mode" = link || test "$mode" = relink; } &&
+    func_mode_link ${1+"$@"}
+# func_mode_uninstall arg...
+func_mode_uninstall ()
+    $opt_debug
+    RM="$nonopt"
+    files=
+    rmforce=
+    exit_status=0
+    # This variable tells wrapper scripts just to set variables rather
+    # than running their programs.
+    libtool_install_magic="$magic"
+    for arg
+    do
+      case $arg in
+      -f) RM="$RM $arg"; rmforce=yes ;;
+      -*) RM="$RM $arg" ;;
+      *) files="$files $arg" ;;
+      esac
+    done
+    test -z "$RM" && \
+      func_fatal_help "you must specify an RM program"
+    rmdirs=
+    origobjdir="$objdir"
+    for file in $files; do
+      func_dirname "$file" "" "."
+      if test "X$dir" = X.; then
+	objdir="$origobjdir"
+      else
+	objdir="$dir/$origobjdir"
+      fi
+      func_basename "$file"
+      test "$mode" = uninstall && objdir="$dir"
+      # Remember objdir for removal later, being careful to avoid duplicates
+      if test "$mode" = clean; then
+	case " $rmdirs " in
+	  *" $objdir "*) ;;
+	  *) rmdirs="$rmdirs $objdir" ;;
+	esac
+      fi
+      # Don't error if the file doesn't exist and rm -f was used.
+      if { test -L "$file"; } >/dev/null 2>&1 ||
+	 { test -h "$file"; } >/dev/null 2>&1 ||
+	 test -f "$file"; then
+      elif test -d "$file"; then
+	exit_status=1
+	continue
+      elif test "$rmforce" = yes; then
+	continue
+      fi
+      rmfiles="$file"
+      case $name in
+      *.la)
+	# Possibly a libtool archive, so verify it.
+	if func_lalib_p "$file"; then
+	  func_source $dir/$name
+	  # Delete the libtool libraries and symlinks.
+	  for n in $library_names; do
+	    rmfiles="$rmfiles $objdir/$n"
+	  done
+	  test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
+	  case "$mode" in
+	  clean)
+	    case "  $library_names " in
+	    # "  " in the beginning catches empty $dlname
+	    *" $dlname "*) ;;
+	    *) rmfiles="$rmfiles $objdir/$dlname" ;;
+	    esac
+	    test -n "$libdir" && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
+	  uninstall)
+	    if test -n "$library_names"; then
+	      # Do each command in the postuninstall commands.
+	      func_execute_cmds "$postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
+	    fi
+	    if test -n "$old_library"; then
+	      # Do each command in the old_postuninstall commands.
+	      func_execute_cmds "$old_postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
+	    fi
+	    # FIXME: should reinstall the best remaining shared library.
+	  esac
+	fi
+      *.lo)
+	# Possibly a libtool object, so verify it.
+	  # Read the .lo file
+	  # Add PIC object to the list of files to remove.
+	  if test -n "$pic_object" &&
+	     test "$pic_object" != none; then
+	    rmfiles="$rmfiles $dir/$pic_object"
+	  fi
+	  # Add non-PIC object to the list of files to remove.
+	  if test -n "$non_pic_object" &&
+	     test "$non_pic_object" != none; then
+	    rmfiles="$rmfiles $dir/$non_pic_object"
+	  fi
+	fi
+	if test "$mode" = clean ; then
+	  noexename=$name
+	  case $file in
+	  *.exe)
+	    func_stripname '' '.exe' "$file"
+	    file=$func_stripname_result
+	    func_stripname '' '.exe' "$name"
+	    noexename=$func_stripname_result
+	    # $file with .exe has already been added to rmfiles,
+	    # add $file without .exe
+	    rmfiles="$rmfiles $file"
+	  esac
+	  # Do a test to see if this is a libtool program.
+	  if func_ltwrapper_p "$file"; then
+	    if func_ltwrapper_executable_p "$file"; then
+	      func_ltwrapper_scriptname "$file"
+	      relink_command=
+	      func_source $func_ltwrapper_scriptname_result
+	      rmfiles="$rmfiles $func_ltwrapper_scriptname_result"
+	    else
+	      relink_command=
+	      func_source $dir/$noexename
+	    fi
+	    # note $name still contains .exe if it was in $file originally
+	    # as does the version of $file that was added into $rmfiles
+	    rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
+	    if test "$fast_install" = yes && test -n "$relink_command"; then
+	      rmfiles="$rmfiles $objdir/lt-$name"
+	    fi
+	    if test "X$noexename" != "X$name" ; then
+	      rmfiles="$rmfiles $objdir/lt-${noexename}.c"
+	    fi
+	  fi
+	fi
+      esac
+      func_show_eval "$RM $rmfiles" 'exit_status=1'
+    done
+    # Try to remove the ${objdir}s in the directories where we deleted files
+    for dir in $rmdirs; do
+      if test -d "$dir"; then
+	func_show_eval "rmdir $dir >/dev/null 2>&1"
+      fi
+    done
+    exit $exit_status
+{ test "$mode" = uninstall || test "$mode" = clean; } &&
+    func_mode_uninstall ${1+"$@"}
+test -z "$mode" && {
+  help="$generic_help"
+  func_fatal_help "you must specify a MODE"
+test -z "$exec_cmd" && \
+  func_fatal_help "invalid operation mode \`$mode'"
+if test -n "$exec_cmd"; then
+  eval exec "$exec_cmd"
+  exit $EXIT_FAILURE
+fi
+exit $exit_status
+# The TAGs below are defined such that we never get into a situation
+# in which we disable both kinds of libraries.  Given conflicting
+# choices, we go for a static library, that is the most portable,
+# since we can't tell whether shared libraries were disabled because
+# the user asked for that or because the platform doesn't support
+# them.  This is particularly important on AIX, because we don't
+# support having both static and shared libraries enabled at the same
+# time on that platform, so we default to a shared-only configuration.
+# If a disable-shared tag is given, we'll fallback to a static-only
+# configuration.  But we'll never go from static-only to shared-only.
+# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
+build_libtool_libs=no
+build_old_libs=yes
+# ### END LIBTOOL TAG CONFIG: disable-shared
+# ### BEGIN LIBTOOL TAG CONFIG: disable-static
+build_old_libs=`case $build_libtool_libs in yes) echo no;; *) echo yes;; esac`
+# ### END LIBTOOL TAG CONFIG: disable-static
+# Local Variables:
+# mode:shell-script
+# sh-indentation:2
+# End:
+# vi:sw=2
Property changes on: mpich2/trunk/confdb/ltmain.sh
___________________________________________________________________
Added: svn:executable
More information about the mpich2-commits
