[mpich2-commits] r5576 - mpich2/trunk/src/pm/hydra/tools/bind/hwloc
    mercierg at mcs.anl.gov
    Tue Oct 27 09:32:57 CDT 2009
Author: mercierg
Date: 2009-10-27 09:32:57 -0500 (Tue, 27 Oct 2009)
New Revision: 5576
Modified:
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.h
Log:
First version of HWLOC bindings file -- Compiles but needs testing.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c	2009-10-27 09:30:47 UTC (rev 5575)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c	2009-10-27 14:32:57 UTC (rev 5576)
@@ -10,26 +10,172 @@
 struct HYDT_bind_info HYDT_bind_info;
+static hwloc_topology_t topology;
 HYD_status HYDT_bind_hwloc_init(HYDT_bind_support_level_t * support_level)
-    HYD_status status = HYD_SUCCESS;
+    int proc,sock,core,thread,i,j;
+    int num_cores = 0;
+    int my_num_cores;
+    int my_num_threads;
+    hwloc_obj_t    obj_sock,obj_core,obj_proc;
+    hwloc_obj_t    prev_obj = NULL;
+    hwloc_cpuset_t cpuset_sock,cpuset_core;
+    HYD_status status = HYD_SUCCESS;
     HYDU_FUNC_ENTER();
+    hwloc_topology_init(&topology);
+    hwloc_topology_load(topology);
-  fn_exit:
+    /* Get the max number of processing elements */
+    HYDT_bind_info.num_procs = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_PROC);
+    HYDU_MALLOC(HYDT_bind_info.topology, struct HYDT_topology *,
+                HYDT_bind_info.num_procs * sizeof(struct HYDT_topology), status);
+    for (i = 0; i < HYDT_bind_info.num_procs; i++) {
+        HYDT_bind_info.topology[i].processor_id = -1;
+        HYDT_bind_info.topology[i].socket_rank = -1;
+        HYDT_bind_info.topology[i].socket_id = -1;
+        HYDT_bind_info.topology[i].core_rank = -1;
+        HYDT_bind_info.topology[i].core_id = -1;
+        HYDT_bind_info.topology[i].thread_rank = -1;
+        HYDT_bind_info.topology[i].thread_id = -1;
+    do{
+	obj_proc = hwloc_get_next_obj_by_type(topology,HWLOC_OBJ_PROC,prev_obj);
+	if (!obj_proc) {
+            /* Unable to get processor ID */
+            HYDU_warn_printf("hwloc get processor id failed\n");
+            if (HYDT_bind_info.topology)
+                HYDU_FREE(HYDT_bind_info.topology);
+            goto fn_fail;
+	HYDT_bind_info.topology[i].processor_id = obj_proc->os_index;
+	prev_obj = obj_proc;
+    }while(prev_obj);
+    /* We have qualified for basic binding support level */
+    *support_level = HYDT_BIND_BASIC;
+    /* Compute the total number of sockets */
+    HYDT_bind_info.num_sockets = hwloc_get_nbobjs_by_type(topology, HWLOC_OBJ_SOCKET);
+    assert(HYDT_bind_info.num_sockets);
+    /* Compute the total number of cores */
+    my_num_cores = hwloc_get_nbobjs_by_type(topology, HWLOC_OBJ_CORE);
+    assert(my_num_cores);
+    /* Compute again the total number of cores */
+    for(i=0; i< HYDT_bind_info.num_sockets ; i++)
+	    obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,i);
+	    num_cores += hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+    /* if this fails, it means that the number of cores */
+    /* per socket is not always the same !*/
+    assert(my_num_cores == num_cores);
+    HYDT_bind_info.num_cores = my_num_cores/HYDT_bind_info.num_sockets;
+    /* Alternate version : We take the amount on socket 0 as the reference */
+    obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,0);
+    HYDT_bind_info.num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,&(obj_sock->cpuset),HWLOC_OBJ_CORE);
+    my_num_threads = HYDT_bind_info.num_procs/my_num_cores;
+    /* Alternate version */
+    HYDT_bind_info.num_threads = HYDT_bind_info.num_procs /
+        (HYDT_bind_info.num_sockets * HYDT_bind_info.num_cores);
+    /* these should be the same */
+    assert(HYDT_bind_info.num_threads == my_num_threads);
+    /* Find the socket and core IDs for all processor IDs */
+    for(sock = 0 ; sock < HYDT_bind_info.num_sockets; sock++)
+	    obj_sock  = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,sock);
+	    cpuset_sock  = obj_sock->cpuset;
+	    num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+	    for(core = 0 ; core < num_cores; core++)
+		    obj_core = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sock,HWLOC_OBJ_CORE,core);
+		    cpuset_core  = obj_core->cpuset;
+		    for (proc = 0; proc < HYDT_bind_info.num_procs; proc++)
+			    if((hwloc_cpuset_isset (cpuset_sock, proc)) &&
+			       (hwloc_cpuset_isset (cpuset_core, proc)))
+				    HYDT_bind_info.topology[proc].socket_id = sock;
+				    HYDT_bind_info.topology[proc].core_id   = core;
+				    thread = -1;
+				    for (j = 0; j < proc; j++)
+					if ((HYDT_bind_info.topology[j].socket_id == sock) &&
+					    (HYDT_bind_info.topology[j].core_id   == core))
+					    thread = HYDT_bind_info.topology[j].thread_id;
+				    thread++;
+				    HYDT_bind_info.topology[proc].thread_id = thread;
+				    HYDT_bind_info.topology[proc].thread_rank = thread;
+				    break;
+    /* Get the rank of each socket ID */
+		if (HYDT_bind_info.topology[proc].socket_id == obj_sock->os_index)
+		    HYDT_bind_info.topology[proc].socket_rank = sock;
+    /* Find the rank of each core ID */
+    for (core = 0; core < my_num_cores ; core++)
+	    obj_core  = hwloc_get_obj_by_type(topology,HWLOC_OBJ_CORE,core);
+		if (HYDT_bind_info.topology[proc].core_id == obj_core->os_index)
+		    HYDT_bind_info.topology[proc].core_rank = core;
+    /* We have qualified for topology-aware binding support level */
+    *support_level = HYDT_BIND_TOPO;
+ fn_exit:
     HYDU_FUNC_EXIT();
     return status;
-  fn_fail:
+ fn_fail:
     goto fn_exit;
 HYD_status HYDT_bind_hwloc_process(int core)
+    hwloc_cpuset_t cpuset = 0;
     HYDU_FUNC_ENTER();
+    /* If the specified core is negative, we just ignore it */
+    if (core < 0)
+        goto fn_exit;
+    hwloc_cpuset_zero(cpuset);
+    hwloc_cpuset_set (cpuset, core % HYDT_bind_info.num_procs);
+    hwloc_set_cpubind(topology,cpuset,HWLOC_CPUBIND_THREAD);
   fn_exit:
     HYDU_FUNC_EXIT();
     return status;
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.h	2009-10-27 09:30:47 UTC (rev 5575)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.h	2009-10-27 14:32:57 UTC (rev 5576)
@@ -7,6 +7,9 @@
 #ifndef BIND_HWLOC_H_INCLUDED
 #define BIND_HWLOC_H_INCLUDED
+#include <hwloc.h>
+#include <assert.h>
 HYD_status HYDT_bind_hwloc_init(HYDT_bind_support_level_t * support_level);
 HYD_status HYDT_bind_hwloc_process(int core);
More information about the mpich2-commits
