[mpich2-commits] r5531 - in mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc: include/hwloc tests
balaji at mcs.anl.gov
Thu Oct 22 11:35:20 CDT 2009
Author: balaji
Date: 2009-10-22 11:35:20 -0500 (Thu, 22 Oct 2009)
New Revision: 5531
Added:
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/openfabrics-verbs.h
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/openfabrics-verbs.c
Log:
Missed two files in hwloc from the 0.9.1rc2 release because of my
git-svn setup inexperience.
Added: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/openfabrics-verbs.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/openfabrics-verbs.h (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/openfabrics-verbs.h 2009-10-22 16:35:20 UTC (rev 5531)
@@ -0,0 +1,66 @@
+ * Copyright © 2009 CNRS, INRIA, Université Bordeaux 1
+ * Copyright © 2009 Cisco Systems, Inc. All rights reserved.
+ * See COPYING in top-level directory.
+/** \file
+ * \brief Macros to help interaction between hwloc and OpenFabrics
+ * verbs.
+ * Applications that use both hwloc and OpenFabrics verbs may want to
+ * include this file so as to get topology information for OpenFabrics
+ * hardware.
+#ifndef HWLOC_OPENFABRICS_VERBS_H
+#define HWLOC_OPENFABRICS_VERBS_H
+#include <hwloc.h>
+#include <hwloc/linux.h>
+#include <infiniband/verbs.h>
+/** \defgroup hwloc_openfabrics OpenFabrics-Specific Functions
+/** \brief Get the CPU set of logical processors that are physically
+ * close to device \p ibdev.
+ * For the given OpenFabrics device \p ibdev, read the corresponding
+ * kernel-provided cpumap file and return the corresponding CPU set.
+ * This function is currently only implemented in a meaningful way for
+ * Linux; other systems will simply get a full cpuset.
+static __inline hwloc_cpuset_t
+hwloc_ibv_get_device_cpuset(struct ibv_device *ibdev)
+#if defined(LINUX_SYS)
+ /* If we're on Linux, use the verbs-provided sysfs mechanism to
+ get the local cpus */
+#define HWLOC_OPENFABRICS_VERBS_SYSFS_PATH_MAX 128
+ char path[HWLOC_OPENFABRICS_VERBS_SYSFS_PATH_MAX];
+ FILE *sysfile = NULL;
+ hwloc_cpuset_t set;
+ sprintf(path, "/sys/class/infiniband/%s/device/local_cpus",
+ ibv_get_device_name(ibdev));
+ sysfile = fopen(path, "r");
+ if (!sysfile)
+ return NULL;
+ set = hwloc_linux_parse_cpumap_file(sysfile);
+ fclose(sysfile);
+ return set;
+#else
+ /* Non-Linux systems simply get a full cpuset */
+ return hwloc_cpuset_dup(hwloc_get_system_obj(topology)->cpuset);
+#endif
+#endif /* HWLOC_OPENFABRICS_VERBS_H */
Added: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/openfabrics-verbs.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/openfabrics-verbs.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/openfabrics-verbs.c 2009-10-22 16:35:20 UTC (rev 5531)
@@ -0,0 +1,49 @@
+#include <stdio.h>
+#include <assert.h>
+#include <hwloc.h>
+#include <private/config.h>
+#include <hwloc/openfabrics-verbs.h>
+/* check the ibverbs helpers */
+int main(int argc, char **argv)
+ struct ibv_device **dev_list, *dev;
+ int count, i;
+ dev_list = ibv_get_device_list(&count);
+ if (!dev_list) {
+ fprintf(stderr, "ibv_get_device_list failed\n");
+ return 0;
+ printf("ibv_get_device_list found %d devices\n", count);
+ for(i=0; i<count; i++) {
+ dev = dev_list[i];
+ set = hwloc_ibv_get_device_cpuset(dev);
+ if (!set) {
+ printf("failed to get cpuset for device %d (%s)\n",
+ i, ibv_get_device_name(dev));
+ } else {
+ char *cpuset_string = NULL;
+ hwloc_cpuset_asprintf(&cpuset_string, set);
+ printf("got cpuset %s for device %d (%s)\n",
+ cpuset_string, i, ibv_get_device_name(dev));
+ free(cpuset_string);
+ hwloc_cpuset_free(set);
+ ibv_free_device_list(dev_list);
+ return 0;
More information about the mpich2-commits
