[mpich2-commits] r5530 - in mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc: . config doc include include/hwloc include/private src tests tests/linux utils
balaji at mcs.anl.gov balaji at mcs.anl.gov
Thu Oct 22 10:32:53 CDT 2009
Author: balaji
Date: 2009-10-22 10:32:53 -0500 (Thu, 22 Oct 2009)
New Revision: 5530
Added:
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/hwloc.dtd
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_shared_cache_covering_obj.c
Removed:
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/ibverbs.h
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/lstopo.dtd
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_cache_covering_obj.c
Modified:
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/README
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/VERSION
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/distscript.csh
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/configure.ac
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/Makefile.am
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/doxygen-config.cfg.in
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/hwloc.doxy
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/Makefile.am
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc.h
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/cpuset.h
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/helper.h
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/private/private.h
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/Makefile.am
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/cpuset.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-linux.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-osf.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-synthetic.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-xml.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/traversal.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/Makefile.am
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/ibverbs.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/linux/16em64t-4s2c2t.xml.tar.gz.output
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/lstopo_xml.sh.in
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/Makefile.am
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-distrib.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-mask.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-cairo.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-draw.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-xml.c
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo.c
Log:
Update hwloc to the 0.9.1rc2 release. This fixes a bunch of issues
with strict compilation.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/README
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/README	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/README	2009-10-22 15:32:53 UTC (rev 5530)
@@ -34,10 +34,10 @@
 hwloc offers a programming interface for manipulating topologies and objects.
 It also brings a powerful cpu bitmap API that is used to describe topology
-objects location on physical/logical processors. See the Programming Interface
-interface below. It may also be used to binding applications onto certain cores
-or memory nodes. Several utility programs are also provided to ease
-command-line manipulation of topology objects, binding of processes, ...
+objects location on physical/logical processors. See the Programming interface
+below. It may also be used to binding applications onto certain cores or memory
+nodes. Several utility programs are also provided to ease command-line
+manipulation of topology objects, binding of processes, ...
 Installation
@@ -150,7 +150,7 @@
    L1(32KB) + Core#2 + P#3
    L1(32KB) + Core#3 + P#7
-Programming Interface
+Programming interface
 The basic interface is available in hwloc.h . It mostly offers low-level
 routines for advanced programmers that want to manually manipulate objects and
@@ -307,5 +307,5 @@
-Generated on Thu Oct 8 16:51:28 2009 for Hardware Locality (hwloc) by  doxygen
+Generated on Fri Oct 16 14:19:12 2009 for Hardware Locality (hwloc) by  doxygen
 1.6.1
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/VERSION
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/VERSION	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/VERSION	2009-10-22 15:32:53 UTC (rev 5530)
@@ -16,7 +16,7 @@
 # requirement is that it must be entirely printable ASCII characters
 # and have no white space.
-greek=rc1
+greek=rc2
 # If want_svn=1, then the SVN r number will be included in the overall
 # hwloc version number in some form.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/distscript.csh
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/distscript.csh	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/distscript.csh	2009-10-22 15:32:53 UTC (rev 5530)
@@ -18,8 +18,13 @@
 # $HEADER$
+set builddir="`pwd`"
 set srcdir="$1"
-set builddir="`pwd`"
+cd "$srcdir"
+set srcdir=`pwd`
+cd "$builddir"
 set distdir="$builddir/$2"
 set HWLOC_VERSION="$3"
 set HWLOC_SVN_VERSION="$4"
@@ -32,10 +37,20 @@
     exit 1
 endif
+if ("$srcdir" != "$builddir") then
+    set vpath=1
+    set vpath_msg=yes
+else
+    set vpath=0
+    set vpath_msg=no
+endif
 # We can catch some hard (but possible) to do mistakes by looking at
 # our tree's revision number, but only if we are in the source tree.
 # Otherwise, use what configure told us, at the cost of allowing one
-# or two corner cases in (but otherwise VPATH builds won't work)
+# or two corner cases in (but otherwise VPATH builds won't work).
 set svn_r=$HWLOC_SVN_VERSION
 if (-d .svn) then
     set svn_r="r`svnversion .`"
@@ -46,6 +61,9 @@
 Creating hwloc distribution
 In directory: `pwd`
+Srcdir: $srcdir
+Builddir: $builddir
+VPATH: $vpath_msg
 Version: $HWLOC_VERSION
 Started: $start
@@ -74,33 +92,73 @@
     touch -r "${srcdir}/VERSION" "${distdir}/VERSION"
     echo "*** Updated VERSION file with SVN r number"
 else
-    echo "*** Did NOT updated VERSION file with SVN r number"
+    echo "*** Did NOT update VERSION file with SVN r number"
 endif
-# Force the generation of new doxygen documentation
+# VPATH builds only work if the srcdir has valid docs already built.
+# If we're VPATH and the srcdir doesn't have valid docs, then fail.
-cd doc
-rm -rf doxygen-doc
-make
-if ($status != 0) then
-    echo ERROR: generating doxygen docs failed
-    echo ERROR: cannot continue
+if ($vpath == 1 && ! -d $srcdir/doc/doxygen-doc) then
+    echo "*** This is a VPATH 'make dist', but the srcdir does not already"
+    echo "*** have a doxygen-doc tree built.  hwloc's config/distscript.csh"
+    echo "*** the docs to be built in the srcdir before executing 'make"
+    echo "*** dist' in a VPATH build."
     exit 1
 endif
-cp -rpf doxygen-doc ../$distdir/doc
-make readme
-    echo ERROR: generating new README failed
-    exit 1
+# If we're not VPATH, force the generation of new doxygen documentation
+if ($vpath == 0) then
+    # Not VPATH
+    echo "*** Making new doxygen documentation (doxygen-doc tree)"
+    echo "*** Directory: srcdir: $srcdir, distdir: $distdir, pwd: `pwd`"
+    cd doc
+    # We're still in the src tree, so kill any previous doxygen-docs
+    # tree and make a new one.
+    chmod -R a=rwx doxygen-doc
+    rm -rf doxygen-doc
+    make
+    if ($status != 0) then
+        echo ERROR: generating doxygen docs failed
+        echo ERROR: cannot continue
+        exit 1
+    endif
+    # Remove generate latex kruft; no need to ship that.
+    echo "*** Remove generated latex kruft: `pwd`"
+    cd doxygen-doc/latex
+    rm -f *.aux *.toc *.idx *.ind *.ilg *.log *.out
+    cd ../..
+    # Make new README file
+    echo "*** Making new README"
+    make readme
+        echo ERROR: generating new README failed
+        exit 1
+    endif
+else
+    echo "*** This is a VPATH build; assuming that the doxygen docs and REAME"
+    echo "*** are current in the srcdir (i.e., we'll just copy those)"
 endif
-cd ..
-cp -pf README $distdir
+echo "*** Copying doxygen-doc tree to dist..."
+echo "*** Directory: srcdir: $srcdir, distdir: $distdir, pwd: `pwd`"
+chmod -R a=rwx $distdir/doc/doxygen-doc
+echo rm -rf $distdir/doc/doxygen-doc
+rm -rf $distdir/doc/doxygen-doc
+echo cp -rpf $srcdir/doc/doxygen-doc $distdir/doc
+cp -rpf $srcdir/doc/doxygen-doc $distdir/doc
+echo "*** Copying new README"
+ls -lf $distdir/README
+cp -pf $srcdir/README $distdir
 # VERY IMPORTANT: Now go into the new distribution tree #
@@ -149,6 +207,7 @@
                 echo " - WARNING: Got bad config.sub from ftp.gnu.org (not executable)"
             else
                 echo " - Got good config.guess and config.sub from ftp.gnu.org"
+                chmod +w ../config.sub ../config.guess
                 cp config.sub config.guess ..
                 set happy=1
             endif
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/configure.ac
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/configure.ac	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/configure.ac	2009-10-22 15:32:53 UTC (rev 5530)
@@ -19,7 +19,7 @@
 AC_CANONICAL_SYSTEM
 AC_CONFIG_SRCDIR([src/topology.c])
-AM_INIT_AUTOMAKE([1.10 foreign -Wall -Werror])
+AM_INIT_AUTOMAKE([1.10 dist-bzip2 foreign tar-ustar -Wall -Werror])
 # Make configure depend on the VERSION file, since it's used in AC_INIT
@@ -223,6 +223,7 @@
 AM_PROG_CC_C_O
 AC_PROG_CC_C99
 AC_PROG_LN_S
+AC_PROG_INSTALL
 AC_PROG_MKDIR_P
 AC_PROG_EGREP
 PKG_CHECK_EXISTS
@@ -430,8 +431,6 @@
 AC_CHECK_FUNCS([openat], [have_openat=yes])
 AM_CONDITIONAL([HAVE_OPENAT], [test "x$have_openat" = "xyes"])
-AC_FUNC_ALLOCA
 AC_CHECK_DECL([numa_bitmask_alloc], [have_linux_libnuma=yes], [],
 	      [#include <numa.h>])
 AM_CONDITIONAL([HAVE_LINUX_LIBNUMA], [test "x$have_linux_libnuma" = "xyes"])
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/Makefile.am
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/Makefile.am	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/Makefile.am	2009-10-22 15:32:53 UTC (rev 5530)
@@ -36,6 +36,9 @@
         images/hagrid.png \
         images/diagram.fig \
         www.open-mpi.org.cfg \
+        www.open-mpi.org-css.inc \
+        www.open-mpi.org-footer.inc \
+        www.open-mpi.org-header.inc \
         $(image_built_sources) \
         $(DOX_HTML_DIR) $(DOX_MAN_DIR) $(DOX_LATEX_DIR) $(DOX_TAG)
@@ -51,8 +54,10 @@
        $(top_srcdir)/include/hwloc.h \
        $(top_srcdir)/include/hwloc/helper.h \
        $(top_srcdir)/include/hwloc/cpuset.h \
+       $(top_srcdir)/include/hwloc/linux.h \
        $(top_srcdir)/include/hwloc/linux-libnuma.h \
-       $(top_srcdir)/include/hwloc/glibc-sched.h
+       $(top_srcdir)/include/hwloc/glibc-sched.h \
+       $(top_srcdir)/include/hwloc/openfabrics-verbs.h
 # Create the images that we need for the PDF output and the HTML
@@ -88,7 +93,7 @@
 if BUILD_DOXYGEN
 $(DOX_TAG): $(BUILT_SOURCES) $(dox_inputs)
-	$(RM) -r $(DOX_DIR)
+	rm -fr $(DOX_DIR)
 	$(DOXYGEN) $(DOX_CONFIG)
 	-sed -i -e 's/__hwloc_restrict/restrict/g;s/\\_\\-\\_\\-hwloc\\_\\-restrict/restrict/g;s/__inline/inline/g;s/\\_\\-\\_\\-inline/inline/g' $(DOX_DIR)/html/*.html $(DOX_DIR)/latex/*.tex $(DOX_DIR)/man/man3/*.3
 endif
@@ -105,7 +110,7 @@
 # is necessary.
 $(DOX_A4PDF): $(DOX_TAG)
 	cd $(DOX_LATEX_DIR); \
-	$(RM) *.aux *.toc *.idx *.ind *.ilg *.log *.out; \
+	rm -f *.aux *.toc *.idx *.ind *.ilg *.log *.out; \
 	cp refman.tex a4-refman.tex; \
 	$(PDFLATEX) a4-refman.tex; \
 	$(MAKEINDEX) a4-refman.idx; \
@@ -125,7 +130,7 @@
 # to make suitable for US letter.
 $(DOX_LETTERPDF): $(DOX_TAG)
 	sed -e 's/a4paper/letterpaper/g' -e 's/\\usepackage{a4wide}//' refman.tex > letter-refman.tex; \
 	$(PDFLATEX) letter-refman.tex; \
 	$(MAKEINDEX) letter-refman.idx; \
@@ -257,13 +262,15 @@
         $(DOX_MAN_DIR)/man3/hwloc_get_obj_inside_cpuset_by_depth.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_obj_by_type.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_obj_by_depth.3 \
-        $(DOX_MAN_DIR)/man3/hwloc_get_cache_covering_obj.3 \
+        $(DOX_MAN_DIR)/man3/hwloc_get_shared_cache_covering_obj.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_system_obj.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_type_depth.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_nbobjs_by_type.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_nbobjs_by_depth.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_type_or_above_depth.3 \
         $(DOX_MAN_DIR)/man3/hwloc_get_type_or_below_depth.3 \
+        $(DOX_MAN_DIR)/man3/hwloc_ibv_get_device_cpuset.3 \
+        $(DOX_MAN_DIR)/man3/hwloc_linux_parse_cpumap_file.3 \
         $(DOX_MAN_DIR)/man3/hwloc_obj.3 \
         $(DOX_MAN_DIR)/man3/hwloc_obj_attr_u.3 \
         $(DOX_MAN_DIR)/man3/hwloc_obj_attr_u_hwloc_cache_attr_s.3 \
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/doxygen-config.cfg.in
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/doxygen-config.cfg.in	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/doxygen-config.cfg.in	2009-10-22 15:32:53 UTC (rev 5530)
@@ -10,7 +10,9 @@
 		@top_srcdir@/include/hwloc/helper.h \
 		@top_srcdir@/include/hwloc/cpuset.h \
 		@top_srcdir@/include/hwloc/glibc-sched.h \
-		@top_srcdir@/include/hwloc/linux-libnuma.h
+		@top_srcdir@/include/hwloc/linux.h \
+		@top_srcdir@/include/hwloc/linux-libnuma.h \
+		@top_srcdir@/include/hwloc/openfabrics-verbs.h
 EXAMPLE_PATH   = @top_srcdir@/doc
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/hwloc.doxy
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/hwloc.doxy	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/doc/hwloc.doxy	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
  * Copyright © 2009 CNRS, INRIA, Université Bordeaux 1
+ * Copyright © 2009 Cisco Systems, Inc.  All rights reserved.
  * See COPYING in top-level directory.
@@ -199,12 +200,14 @@
 that it contains. These cpusets may be used for \ref hwlocality_binding.
 hwloc offers an extensive cpuset manipulation interface in hwloc/cpuset.h .
-Moreover, hwloc also comes with additional helpers for interoperability
-with several commonly used environments. For Linux, some specific helpers
-are available in hwloc/linux.h , and hwloc/linux-libnuma.h if using libnuma.
-On glibc-based systems, additional helpers are available in hwloc/glibc-sched.h .
-For systems with the Infiniband Verbs library, some dedicated helpers are
-provided in hwloc/ibverbs.h .
+Moreover, hwloc also comes with additional helpers for
+interoperability with several commonly used environments.  For Linux,
+some specific helpers are available in hwloc/linux.h , and
+hwloc/linux-libnuma.h if using libnuma.  On glibc-based systems,
+additional helpers are available in hwloc/glibc-sched.h .  For Linux
+systems with the OpenFabrics verbs library, some dedicated helpers are
+provided in hwloc/openfabrics-verbs.h (this helper file is not yet
+useful on non-Linux systems with the OpenFabrics verbs library).
 To precisely define the vocabulary used by hwloc, a \ref glossary is
 available and should probably be read first.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/Makefile.am
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/Makefile.am	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/Makefile.am	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,10 +1,11 @@
 # Copyright 2009 INRIA, Université Bordeaux 1
+# Copyright 2009 Cisco Systems, Inc.  All rights reserved.
 include $(top_srcdir)/hwloc.am
 include_HEADERS = hwloc.h
 include_hwlocdir = $(includedir)/hwloc
-include_hwloc_HEADERS = hwloc/cpuset.h hwloc/helper.h hwloc/ibverbs.h
+include_hwloc_HEADERS = hwloc/cpuset.h hwloc/helper.h hwloc/openfabrics-verbs.h
 nodist_include_hwloc_HEADERS = hwloc/config.h
 noinst_HEADERS = private/private.h private/debug.h private/cpuset.h
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/cpuset.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/cpuset.h	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/cpuset.h	2009-10-22 15:32:53 UTC (rev 5530)
@@ -26,7 +26,8 @@
 /** \brief
  * Set of CPUs represented as an opaque pointer to an internal bitmask.
-typedef struct hwloc_opaque_cpuset_s * hwloc_cpuset_t;
+typedef struct hwloc_cpuset_s * hwloc_cpuset_t;
+typedef const struct hwloc_cpuset_s * hwloc_const_cpuset_t;
@@ -57,14 +58,14 @@
  * \return the number of character that were actually written if not truncating,
  * or that would have been written  (not including the ending \\0).
-int hwloc_cpuset_snprintf(char * __hwloc_restrict buf, size_t buflen, hwloc_cpuset_t set);
+int hwloc_cpuset_snprintf(char * __hwloc_restrict buf, size_t buflen, hwloc_const_cpuset_t set);
 /** \brief Stringify a cpuset into a newly allocated string.
  * (not including the ending \\0).
-int hwloc_cpuset_asprintf(char ** strp, hwloc_cpuset_t set);
+int hwloc_cpuset_asprintf(char ** strp, hwloc_const_cpuset_t set);
 /** \brief Parse a cpuset string.
@@ -90,10 +91,10 @@
 void hwloc_cpuset_from_ith_ulong(hwloc_cpuset_t set, int i, unsigned long mask);
 /** \brief Convert the beginning part of CPU set \p set into unsigned long \p mask */
-unsigned long hwloc_cpuset_to_ulong(hwloc_cpuset_t set);
+unsigned long hwloc_cpuset_to_ulong(hwloc_const_cpuset_t set);
 /** \brief Convert the \p i -th subset of CPU set \p set into unsigned long mask */
-unsigned long hwloc_cpuset_to_ith_ulong(hwloc_cpuset_t set, int i);
+unsigned long hwloc_cpuset_to_ith_ulong(hwloc_const_cpuset_t set, int i);
 /** \brief Clear CPU set \p set and set CPU \p cpu */
 void hwloc_cpuset_cpu(hwloc_cpuset_t set, unsigned cpu);
@@ -111,40 +112,40 @@
 void hwloc_cpuset_clr(hwloc_cpuset_t set, unsigned cpu);
 /** \brief Test whether CPU \p cpu is part of set \p set */
-int hwloc_cpuset_isset(hwloc_cpuset_t set, unsigned cpu);
+int hwloc_cpuset_isset(hwloc_const_cpuset_t set, unsigned cpu);
 /** \brief Test whether set \p set is zero */
-int hwloc_cpuset_iszero(hwloc_cpuset_t set);
+int hwloc_cpuset_iszero(hwloc_const_cpuset_t set);
 /** \brief Test whether set \p set is full */
-int hwloc_cpuset_isfull(hwloc_cpuset_t set);
+int hwloc_cpuset_isfull(hwloc_const_cpuset_t set);
 /** \brief Test whether set \p set1 is equal to set \p set2 */
-int hwloc_cpuset_isequal (hwloc_cpuset_t set1, hwloc_cpuset_t set2);
+int hwloc_cpuset_isequal (hwloc_const_cpuset_t set1, hwloc_const_cpuset_t set2);
 /** \brief Test whether sets \p set1 and \p set2 intersects */
-int hwloc_cpuset_intersects (hwloc_cpuset_t set1, hwloc_cpuset_t set2);
+int hwloc_cpuset_intersects (hwloc_const_cpuset_t set1, hwloc_const_cpuset_t set2);
 /** \brief Test whether set \p sub_set is part of set \p super_set */
-int hwloc_cpuset_isincluded (hwloc_cpuset_t sub_set, hwloc_cpuset_t super_set);
+int hwloc_cpuset_isincluded (hwloc_const_cpuset_t sub_set, hwloc_const_cpuset_t super_set);
 /** \brief Or set \p modifier_set into set \p set */
-void hwloc_cpuset_orset (hwloc_cpuset_t set, hwloc_cpuset_t modifier_set);
+void hwloc_cpuset_orset (hwloc_cpuset_t set, hwloc_const_cpuset_t modifier_set);
 /** \brief And set \p modifier_set into set \p set */
-void hwloc_cpuset_andset (hwloc_cpuset_t set, hwloc_cpuset_t modifier_set);
+void hwloc_cpuset_andset (hwloc_cpuset_t set, hwloc_const_cpuset_t modifier_set);
 /** \brief Clear set \p modifier_set out of set \p set */
-void hwloc_cpuset_clearset (hwloc_cpuset_t set, hwloc_cpuset_t modifier_set);
+void hwloc_cpuset_clearset (hwloc_cpuset_t set, hwloc_const_cpuset_t modifier_set);
 /** \brief Xor set \p set with set \p modifier_set */
-void hwloc_cpuset_xorset (hwloc_cpuset_t set, hwloc_cpuset_t modifier_set);
+void hwloc_cpuset_xorset (hwloc_cpuset_t set, hwloc_const_cpuset_t modifier_set);
 /** \brief Compute the first CPU (least significant bit) in CPU set \p set */
-int hwloc_cpuset_first(hwloc_cpuset_t set);
+int hwloc_cpuset_first(hwloc_const_cpuset_t set);
 /** \brief Compute the last CPU (most significant bit) in CPU set \p set */
-int hwloc_cpuset_last(hwloc_cpuset_t set);
+int hwloc_cpuset_last(hwloc_const_cpuset_t set);
 /** \brief Keep a single CPU among those set in CPU set \p set
@@ -159,17 +160,17 @@
  * Smaller least significant bit is smaller.
  * The empty CPU set is considered higher than anything.
-int hwloc_cpuset_compar_first(hwloc_cpuset_t set1, hwloc_cpuset_t set2);
+int hwloc_cpuset_compar_first(hwloc_const_cpuset_t set1, hwloc_const_cpuset_t set2);
 /** \brief Compar CPU sets \p set1 and \p set2 using their last bits.
  * Higher most significant bit is higher.
  * The empty CPU set is considered lower than anything.
-int hwloc_cpuset_compar(hwloc_cpuset_t set1, hwloc_cpuset_t set2);
+int hwloc_cpuset_compar(hwloc_const_cpuset_t set1, hwloc_const_cpuset_t set2);
 /** \brief Compute the weight of CPU set \p set */
-int hwloc_cpuset_weight(hwloc_cpuset_t set);
+int hwloc_cpuset_weight(hwloc_const_cpuset_t set);
 /** \brief Loop macro iterating on CPU set \p set
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/helper.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/helper.h	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/helper.h	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -200,13 +201,13 @@
 static __inline hwloc_obj_t
 hwloc_get_obj_inside_cpuset_by_depth (hwloc_topology_t topology, hwloc_cpuset_t set,
-				      unsigned depth, unsigned index)
+				      unsigned depth, unsigned idx)
   int count = 0;
   hwloc_obj_t obj = hwloc_get_obj_by_depth (topology, depth, 0);
   while (obj) {
     if (hwloc_cpuset_isincluded(obj->cpuset, set)) {
-      if (count == index)
+      if (count == idx)
 	return obj;
       count++;
@@ -215,19 +216,19 @@
   return NULL;
-/** \brief Return the \p index -th object of type \p type included in CPU set \p set.
+/** \brief Return the \p idx -th object of type \p type included in CPU set \p set.
  * If there are multiple or no depth for given type, return \c NULL and let the caller
  * fallback to hwloc_get_obj_inside_cpuset_by_depth().
 hwloc_get_obj_inside_cpuset_by_type (hwloc_topology_t topology, hwloc_cpuset_t set,
-				     hwloc_obj_type_t type, unsigned index)
+				     hwloc_obj_type_t type, unsigned idx)
   int depth = hwloc_get_type_depth(topology, type);
   if (depth == HWLOC_TYPE_DEPTH_UNKNOWN || depth == HWLOC_TYPE_DEPTH_MULTIPLE)
     return NULL;
-  return hwloc_get_obj_inside_cpuset_by_depth(topology, set, depth, index);
+  return hwloc_get_obj_inside_cpuset_by_depth(topology, set, depth, idx);
 /** \brief Return the number of objects at depth \p depth included in CPU set \p set. */
@@ -274,7 +275,7 @@
  * \return \c NULL if no child matches.
-static inline hwloc_obj_t
+static __inline hwloc_obj_t
 hwloc_get_child_covering_cpuset (hwloc_topology_t topology, hwloc_cpuset_t set,
 				hwloc_obj_t father)
@@ -291,7 +292,7 @@
  * \return \c NULL if no object matches.
 hwloc_get_obj_covering_cpuset (hwloc_topology_t topology, hwloc_cpuset_t set)
   struct hwloc_obj *current = hwloc_get_system_obj(topology);
@@ -383,7 +384,7 @@
  * \return \c NULL if no cache matches
-hwloc_get_cache_covering_obj (hwloc_topology_t topology, hwloc_obj_t obj)
+hwloc_get_shared_cache_covering_obj (hwloc_topology_t topology, hwloc_obj_t obj)
   hwloc_obj_t current = obj->father;
   while (current) {
Deleted: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/ibverbs.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/ibverbs.h	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc/ibverbs.h	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,46 +0,0 @@
- * Copyright © 2009 CNRS, INRIA, Université Bordeaux 1
- * See COPYING in top-level directory.
-/** \file
- * \brief Macros to help interaction between hwloc and infiniband verbs.
- * Applications that use both hwloc and infiniband verbs may want to include
- * this file so as to get topology information for infiniband hardware.
-#ifndef HWLOC_IBVERBS_H
-#define HWLOC_IBVERBS_H
-#include <hwloc.h>
-#include <hwloc/linux.h>
-#include <infiniband/verbs.h>
-/** \brief Get the CPU set \p set of logical processors that are physicall close to device \p ibdev.
- * For the given infiniband device \p ibdev, read the corresponding kernel-provided cpumap file
- * and store it inside the given CPU set \p set.
-static inline int
-hwloc_ibverbs_get_device_cpuset(struct ibv_device *ibdev, hwloc_cpuset_t *set)
-#define HWLOC_IBVERBS_SYSFS_PATH_MAX 128
-  char path[HWLOC_IBVERBS_SYSFS_PATH_MAX];
-  FILE *sysfile = NULL;
-  sprintf(path, "/sys/class/infiniband/%s/device/local_cpus",
-	  ibv_get_device_name(ibdev));
-  sysfile = fopen(path, "r");
-  if (!sysfile)
-    return -1;
-  hwloc_linux_parse_cpumap_file(sysfile, set);
-  fclose(sysfile);
-  return 0;
-#endif /* HWLOC_IBVERBS_H */
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc.h	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/hwloc.h	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,13 +1,14 @@
 /** \file
  * \brief The hwloc API.
- * See hwloc/cpuset.h for CPU set specific macros
- * See hwloc/helper.h for high-level topology traversal helpers
+ * See hwloc/cpuset.h for CPU set specific macros.
+ * See hwloc/helper.h for high-level topology traversal helpers.
 #ifndef HWLOC_H
@@ -413,7 +414,7 @@
 /** \brief Returns the topology object at index \p index from depth \p depth */
-extern hwloc_obj_t hwloc_get_obj_by_depth (hwloc_topology_t topology, unsigned depth, unsigned index);
+extern hwloc_obj_t hwloc_get_obj_by_depth (hwloc_topology_t topology, unsigned depth, unsigned idx);
 /** \brief Returns the topology object at index \p index with type \p type
@@ -422,14 +423,14 @@
  * and ther caller may fallback to hwloc_get_obj_by_depth().
-hwloc_get_obj_by_type (hwloc_topology_t topology, hwloc_obj_type_t type, unsigned index)
+hwloc_get_obj_by_type (hwloc_topology_t topology, hwloc_obj_type_t type, unsigned idx)
   if (depth == HWLOC_TYPE_DEPTH_UNKNOWN)
     return NULL;
   if (depth == HWLOC_TYPE_DEPTH_MULTIPLE)
     return NULL;
-  return hwloc_get_obj_by_depth(topology, depth, index);
+  return hwloc_get_obj_by_depth(topology, depth, idx);
@@ -448,7 +449,17 @@
 /** \brief Stringify a given topology object into a human-readable form.
- * \return how many characters were actually written (not including the ending \\0). */
+ * Fill string \p string up to \p size characters with the description
+ * of topology object \p obj in topology \p topology.
+ * If \p verbose is set, a longer description is used. Otherwise a
+ * short description is used.
+ * \p indexprefix is used to prefix the \p os_index attribute number of
+ * the object in the description. If \c NULL, the \c # character is used.
+ * \return how many characters were actually written (not including the ending \\0).
 extern int hwloc_obj_snprintf(char * __hwloc_restrict string, size_t size,
 			     hwloc_topology_t topology, hwloc_obj_t obj,
 			     const char * __hwloc_restrict indexprefix, int verbose);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/private/private.h
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/private/private.h	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/include/private/private.h	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -141,7 +142,7 @@
 /** \brief Return a locally-allocated stringified cpuset for printf-like calls. */
-static inline char *
+static __inline char *
 hwloc_cpuset_printf_value(hwloc_cpuset_t cpuset)
   char *buf;
@@ -149,14 +150,14 @@
   return buf;
-static inline struct hwloc_obj *
-hwloc_alloc_setup_object(hwloc_obj_type_t type, signed index)
+static __inline struct hwloc_obj *
+hwloc_alloc_setup_object(hwloc_obj_type_t type, signed idx)
   struct hwloc_obj *obj = malloc(sizeof(*obj));
   assert(obj);
   memset(obj, 0, sizeof(*obj));
   obj->type = type;
-  obj->os_index = index;
+  obj->os_index = idx;
   obj->os_level = -1;
   obj->attr = malloc(sizeof(*obj->attr));
   /* do not allocate the cpuset here, let the caller do it */
@@ -196,4 +197,8 @@
   hwloc_debug("\n");
+/* On some systems, snprintf returns the size of written data, not the actually
+ * required size.  hwloc_snprintf always report the actually required size. */
+int hwloc_snprintf(char *str, size_t size, const char *format, ...);
 #endif /* HWLOC_PRIVATE_H */
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/Makefile.am
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/Makefile.am	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/Makefile.am	2009-10-22 15:32:53 UTC (rev 5530)
@@ -77,6 +77,6 @@
 EXTRA_DIST += topology-darwin.c
 endif !HAVE_DARWIN
-xml_DATA = $(srcdir)/lstopo.dtd
+xml_DATA = $(srcdir)/hwloc.dtd
 xmldir = $(pkgdatadir)
-EXTRA_DIST += lstopo.dtd
+EXTRA_DIST += hwloc.dtd
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/cpuset.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/cpuset.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/cpuset.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,12 +1,17 @@
 #include <private/cpuset.h>
+#include <private/private.h>
+#include <hwloc/cpuset.h>
+#include <stdarg.h>
 #include <stdio.h>
 #include <assert.h>
+#include <errno.h>
 /* overzealous check in debug-mode, not as powerful as valgrind but still useful */
@@ -16,8 +21,42 @@
 #define HWLOC__CPUSET_CHECK(set)
 #endif
+  int ret;
+  va_list ap;
+  static char bin;
-struct hwloc_cpuset_s * hwloc_cpuset_alloc(void);
+  /* Some systems crash on str == NULL */
+  if (!size) {
+    str = &bin;
+    size = 1;
+  va_start(ap, format);
+  ret = vsnprintf(str, size, format, ap);
+  va_end(ap);
+  if (ret >= 0 && ret != size-1)
+    return ret;
+  /* vsnprintf returned size-1 or -1. That could be a system which reports the
+   * written data and not the actually required room. Try increasing buffer
+   * size to get the latter. */
+  do {
+    size *= 2;
+    str = malloc(size);
+    errno = 0;
+    va_end(ap);
+    free(str);
+  } while (ret == size-1 || (ret < 0 && !errno));
+  return ret;
   struct hwloc_cpuset_s * set;
@@ -29,7 +68,6 @@
   return set;
-void hwloc_cpuset_free(struct hwloc_cpuset_s * set);
   HWLOC__CPUSET_CHECK(set);
@@ -40,12 +78,12 @@
   free(set);
-struct hwloc_cpuset_s * hwloc_cpuset_dup(struct hwloc_cpuset_s * old);
+  struct hwloc_cpuset_s * new;
   HWLOC__CPUSET_CHECK(old);
-  struct hwloc_cpuset_s * new;
   new = malloc(sizeof(*new));
   if (new) {
 #ifdef HWLOC_DEBUG
@@ -56,7 +94,6 @@
   return new;
-void hwloc_cpuset_copy(struct hwloc_cpuset_s * dst, struct hwloc_cpuset_s * src);
   HWLOC__CPUSET_CHECK(dst);
@@ -65,16 +102,12 @@
   memcpy(dst, src, sizeof(*dst));
-int hwloc_cpuset_snprintf(char * __hwloc_restrict buf, size_t buflen, const struct hwloc_cpuset_s * __hwloc_restrict set);
-  HWLOC__CPUSET_CHECK(set);
   ssize_t size = buflen;
   char *tmp = buf;
-  int res;
+  int res, ret = 0;
   int needcomma = 0;
-  int missed = 0;
   int i;
   unsigned long accum = 0;
   int accumed = 0;
@@ -84,6 +117,8 @@
   const unsigned long accum_mask = ((1UL << HWLOC_CPUSET_SUBSTRING_SIZE) - 1) << (HWLOC_BITS_PER_LONG - HWLOC_CPUSET_SUBSTRING_SIZE);
 #endif /* HWLOC_BITS_PER_LONG != HWLOC_CPUSET_SUBSTRING_SIZE */
+  HWLOC__CPUSET_CHECK(set);
   /* mark the end in case we do nothing later */
   if (buflen > 0)
     tmp[0] = '\0';
@@ -98,17 +133,20 @@
     if (accum & accum_mask) {
       /* print the whole subset if not empty */
-      res = snprintf(tmp, size, needcomma ? "," HWLOC_PRIxCPUSUBSET : HWLOC_PRIxCPUSUBSET,
+      res = hwloc_snprintf(tmp, size, needcomma ? "," HWLOC_PRIxCPUSUBSET : HWLOC_PRIxCPUSUBSET,
 		     (accum & accum_mask) >> (HWLOC_BITS_PER_LONG - HWLOC_CPUSET_SUBSTRING_SIZE));
       needcomma = 1;
     } else if (i == -1 && accumed == HWLOC_CPUSET_SUBSTRING_SIZE) {
       /* print a single 0 to mark the last subset */
-      res = snprintf(tmp, size, needcomma ? ",0" : "0");
+      res = hwloc_snprintf(tmp, size, needcomma ? ",0" : "0");
     } else if (needcomma) {
-      res = snprintf(tmp, size, ",");
+      res = hwloc_snprintf(tmp, size, ",");
     } else {
       res = 0;
+    if (res < 0)
+      return -1;
+    ret += res;
 #if HWLOC_BITS_PER_LONG == HWLOC_CPUSET_SUBSTRING_SIZE
     accum = 0;
@@ -118,30 +156,29 @@
     accumed -= HWLOC_CPUSET_SUBSTRING_SIZE;
 #endif
-    if (res >= size) {
-      int written = size>0 ? size-1 : 0;
-      missed += res - written;
-      res = written;
+    if (res >= size)
+      res = size>0 ? size - 1 : 0;
     tmp += res;
     size -= res;
-  return tmp-buf+missed;
+  return ret;
-int hwloc_cpuset_asprintf(char ** strp, const struct hwloc_cpuset_s * __hwloc_restrict set);
+  int len;
+  char *buf;
-  int len = hwloc_cpuset_snprintf(NULL, 0, set);
-  char *buf = malloc(len+1);
+  len = hwloc_cpuset_snprintf(NULL, 0, set);
+  buf = malloc(len+1);
   *strp = buf;
   return hwloc_cpuset_snprintf(buf, len+1, set);
-struct hwloc_cpuset_s * hwloc_cpuset_from_string(const char * __hwloc_restrict string);
@@ -194,50 +231,49 @@
   return set;
-void hwloc_cpuset_zero(struct hwloc_cpuset_s * set);
+	int i;
-	int i;
 	for(i=0; i<HWLOC_CPUSUBSET_COUNT; i++)
 		HWLOC_CPUSUBSET_SUBSET(*set,i) = HWLOC_CPUSUBSET_ZERO;
-void hwloc_cpuset_fill(struct hwloc_cpuset_s * set);
+	int i;
-	int i;
 		HWLOC_CPUSUBSET_SUBSET(*set,i) = HWLOC_CPUSUBSET_FULL;
-void hwloc_cpuset_from_ulong(struct hwloc_cpuset_s *set, unsigned long mask);
+	int i;
-	int i;
 	HWLOC_CPUSUBSET_SUBSET(*set,0) = mask;
 	for(i=1; i<HWLOC_CPUSUBSET_COUNT; i++)
-void hwloc_cpuset_from_ith_ulong(struct hwloc_cpuset_s *set, int i, unsigned long mask);
+	int j;
-	int j;
 	HWLOC_CPUSUBSET_SUBSET(*set,i) = mask;
 	for(j=1; j<HWLOC_CPUSUBSET_COUNT; j++)
 		if (j != i)
 			HWLOC_CPUSUBSET_SUBSET(*set,j) = HWLOC_CPUSUBSET_ZERO;
-unsigned long hwloc_cpuset_to_ulong(const struct hwloc_cpuset_s *set);
@@ -245,7 +281,6 @@
 	return HWLOC_CPUSUBSET_SUBSET(*set,0);
-unsigned long hwloc_cpuset_to_ith_ulong(const struct hwloc_cpuset_s *set, int i);
@@ -253,7 +288,6 @@
 	return HWLOC_CPUSUBSET_SUBSET(*set,i);
-void hwloc_cpuset_cpu(struct hwloc_cpuset_s * set, unsigned cpu);
@@ -262,7 +296,6 @@
 	HWLOC_CPUSUBSET_CPUSUBSET(*set,cpu) |= HWLOC_CPUSUBSET_VAL(cpu);
-void hwloc_cpuset_all_but_cpu(struct hwloc_cpuset_s * set, unsigned cpu);
@@ -271,7 +304,6 @@
 	HWLOC_CPUSUBSET_CPUSUBSET(*set,cpu) &= ~HWLOC_CPUSUBSET_VAL(cpu);
-void hwloc_cpuset_set(struct hwloc_cpuset_s * set, unsigned cpu);
@@ -279,17 +311,16 @@
-void hwloc_cpuset_set_range(struct hwloc_cpuset_s * set, unsigned begincpu, unsigned endcpu);
+	int i;
-	int i;
 	for (i=begincpu; i<=endcpu; i++)
 		HWLOC_CPUSUBSET_CPUSUBSET(*set,i) |= HWLOC_CPUSUBSET_VAL(i);
-void hwloc_cpuset_clr(struct hwloc_cpuset_s * set, unsigned cpu);
@@ -297,7 +328,6 @@
-int hwloc_cpuset_isset(const struct hwloc_cpuset_s * set, unsigned cpu);
@@ -305,119 +335,119 @@
 	return (HWLOC_CPUSUBSET_CPUSUBSET(*set,cpu) & HWLOC_CPUSUBSET_VAL(cpu)) != 0;
-int hwloc_cpuset_iszero(const struct hwloc_cpuset_s *set);
+	int i;
-	int i;
 		if (HWLOC_CPUSUBSET_SUBSET(*set,i) != HWLOC_CPUSUBSET_ZERO)
 			return 0;
 	return 1;
-int hwloc_cpuset_isfull(const struct hwloc_cpuset_s *set);
+	int i;
-	int i;
 		if (HWLOC_CPUSUBSET_SUBSET(*set,i) != HWLOC_CPUSUBSET_FULL)
 			return 0;
 	return 1;
-int hwloc_cpuset_isequal (const struct hwloc_cpuset_s *set1, const struct hwloc_cpuset_s *set2);
+	int i;
 	HWLOC__CPUSET_CHECK(set1);
 	HWLOC__CPUSET_CHECK(set2);
-	int i;
 		if (HWLOC_CPUSUBSET_SUBSET(*set1,i) != HWLOC_CPUSUBSET_SUBSET(*set2,i))
 			return 0;
 	return 1;
-int hwloc_cpuset_intersects (const struct hwloc_cpuset_s *set1, const struct hwloc_cpuset_s *set2);
+	int i;
-	int i;
 		if ((HWLOC_CPUSUBSET_SUBSET(*set1,i) & HWLOC_CPUSUBSET_SUBSET(*set2,i)) != HWLOC_CPUSUBSET_ZERO)
 			return 1;
 	return 0;
-int hwloc_cpuset_isincluded (const struct hwloc_cpuset_s *sub_set, const struct hwloc_cpuset_s *super_set);
+	int i;
 	HWLOC__CPUSET_CHECK(sub_set);
 	HWLOC__CPUSET_CHECK(super_set);
-	int i;
 		if (HWLOC_CPUSUBSET_SUBSET(*super_set,i) != (HWLOC_CPUSUBSET_SUBSET(*super_set,i) | HWLOC_CPUSUBSET_SUBSET(*sub_set,i)))
 			return 0;
 	return 1;
-void hwloc_cpuset_orset (struct hwloc_cpuset_s *set, const struct hwloc_cpuset_s *modifier_set);
+	int i;
 	HWLOC__CPUSET_CHECK(modifier_set);
-	int i;
 		HWLOC_CPUSUBSET_SUBSET(*set,i) |= HWLOC_CPUSUBSET_SUBSET(*modifier_set,i);
-void hwloc_cpuset_andset (struct hwloc_cpuset_s *set, const struct hwloc_cpuset_s *modifier_set);
+	int i;
-	int i;
 		HWLOC_CPUSUBSET_SUBSET(*set,i) &= HWLOC_CPUSUBSET_SUBSET(*modifier_set,i);
-void hwloc_cpuset_clearset (struct hwloc_cpuset_s *set, const struct hwloc_cpuset_s *modifier_set);
+	int i;
-	int i;
 		HWLOC_CPUSUBSET_SUBSET(*set,i) &= ~HWLOC_CPUSUBSET_SUBSET(*modifier_set,i);
-void hwloc_cpuset_xorset (struct hwloc_cpuset_s *set, const struct hwloc_cpuset_s *modifier_set);
+	int i;
-	int i;
 		HWLOC_CPUSUBSET_SUBSET(*set,i) ^= HWLOC_CPUSUBSET_SUBSET(*modifier_set,i);
-int hwloc_cpuset_first(const struct hwloc_cpuset_s * set);
+	int i;
-	int i;
 	for(i=0; i<HWLOC_CPUSUBSET_COUNT; i++) {
 		/* subsets are unsigned longs, use ffsl */
 		int _ffs = hwloc_ffsl(HWLOC_CPUSUBSET_SUBSET(*set,i));
@@ -428,12 +458,12 @@
 	return -1;
-int hwloc_cpuset_last(const struct hwloc_cpuset_s * set);
+	int i;
-	int i;
 	for(i=HWLOC_CPUSUBSET_COUNT-1; i>=0; i--) {
 		/* subsets are unsigned longs, use flsl */
 		int _fls = hwloc_flsl(HWLOC_CPUSUBSET_SUBSET(*set,i));
@@ -444,12 +474,12 @@
 	return -1;
-void hwloc_cpuset_singlify(struct hwloc_cpuset_s * set);
+	int i,found = 0;
-	int i,found = 0;
 		if (found) {
@@ -465,13 +495,13 @@
-int hwloc_cpuset_compar_first(const struct hwloc_cpuset_s * set1, const struct hwloc_cpuset_s * set2);
+	int i;
-	int i;
 		int _ffs1 = hwloc_ffsl(HWLOC_CPUSUBSET_SUBSET(*set1,i));
 		int _ffs2 = hwloc_ffsl(HWLOC_CPUSUBSET_SUBSET(*set2,i));
@@ -486,13 +516,13 @@
 	return 0;
-int hwloc_cpuset_compar(const struct hwloc_cpuset_s * set1, const struct hwloc_cpuset_s * set2);
+	int i;
-	int i;
 		if (HWLOC_CPUSUBSET_SUBSET(*set1,i) == HWLOC_CPUSUBSET_SUBSET(*set2,i))
 			continue;
@@ -501,13 +531,13 @@
 	return 0;
-int hwloc_cpuset_weight(const struct hwloc_cpuset_s * set);
+	int weight = 0;
+	int i;
-	int weight = 0;
-	int i;
 		weight += hwloc_weight_long(HWLOC_CPUSUBSET_SUBSET(*set,i));
 	return weight;
Copied: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/hwloc.dtd (from rev 5527, mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/lstopo.dtd)
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/hwloc.dtd	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/hwloc.dtd	2009-10-22 15:32:53 UTC (rev 5530)
@@ -0,0 +1,12 @@
+<!ELEMENT root (object)+>
+<!ELEMENT object (object)*>
+<!ATTLIST object type (System | Machine | Misc | NUMANode | Socket| Cache | Core | Proc) #REQUIRED>
+<!ATTLIST object os_index CDATA "-1" >
+<!ATTLIST object cpuset CDATA "0" >
+<!ATTLIST object dmi_board_vendor CDATA "" >
+<!ATTLIST object dmi_board_name CDATA "" >
+<!ATTLIST object memory_kB CDATA "0" >
+<!ATTLIST object huge_page_size_kB CDATA "0" >
+<!ATTLIST object huge_page_free CDATA "0" >
+<!ATTLIST object depth CDATA "-1" >
Deleted: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/lstopo.dtd
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/lstopo.dtd	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/lstopo.dtd	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,12 +0,0 @@
-<!ELEMENT root (object)+>
-<!ELEMENT object (object)*>
-<!ATTLIST object type (System | Machine | Misc | NUMANode | Socket| Cache | Core | Proc) #REQUIRED>
-<!ATTLIST object os_index CDATA "-1" >
-<!ATTLIST object cpuset CDATA "0" >
-<!ATTLIST object dmi_board_vendor CDATA "" >
-<!ATTLIST object dmi_board_name CDATA "" >
-<!ATTLIST object memory_kB CDATA "0" >
-<!ATTLIST object huge_page_size_kB CDATA "0" >
-<!ATTLIST object huge_page_free CDATA "0" >
-<!ATTLIST object depth CDATA "-1" >
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-linux.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-linux.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-linux.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -148,14 +149,6 @@
   return hwloc_linux_set_tid_cpubind(topology, 0, hwloc_set, strict);
-static int
-hwloc_linux_set_proc_cpubind(hwloc_topology_t topology, pid_t pid, hwloc_cpuset_t hwloc_set, int strict)
-  /* XXX: doesn't bind all threads of the processus !! */
-  /* Same problem for thisproc */
-  return hwloc_linux_set_tid_cpubind(topology, pid, hwloc_set, strict);
 #if HAVE_DECL_PTHREAD_SETAFFINITY_NP
 #pragma weak pthread_setaffinity_np
@@ -531,45 +524,47 @@
   if (nbnodes <= 1)
     return;
-  hwloc_obj_t nodes[nbnodes];
-  unsigned distances[nbnodes][nbnodes];
-  for (osnode=0; osnode < nbnodes; osnode++)
-      char nodepath[SYSFS_NUMA_NODE_PATH_LEN];
-      hwloc_cpuset_t cpuset;
-      unsigned long size = -1;
-      unsigned long hpfree = -1;
-      sprintf(nodepath, "%s/node%u/cpumap", path, osnode);
-      cpuset = hwloc_parse_cpumap(nodepath, topology->backend_params.sysfs.root_fd);
-      if (!cpuset)
-	continue;
-      /* clear disabled cpus */
-      hwloc_cpuset_clearset(cpuset, admin_disabled_cpus_set);
-      if (hwloc_cpuset_isset(admin_disabled_mems_set, osnode)) {
-	size = 0; hpfree = 0;
-      } else
-	hwloc_sysfs_node_meminfo_info(topology, path, osnode, &size, &hpfree);
-      node = hwloc_alloc_setup_object(HWLOC_OBJ_NODE, osnode);
-      node->cpuset = cpuset;
-      node->attr->node.memory_kB = size;
-      node->attr->node.huge_page_free = hpfree;
-      hwloc_debug_1arg_cpuset("os node %u has cpuset %s\n",
-		 osnode, node->cpuset);
-      hwloc_add_object(topology, node);
-      nodes[osnode] = node;
-      sprintf(nodepath, "%s/node%u/distance", path, osnode);
-      hwloc_parse_node_distance(nodepath, nbnodes, distances[osnode], topology->backend_params.sysfs.root_fd);
-  hwloc_setup_misc_level_from_distances(topology, nbnodes, nodes, distances);
+  /* For convenience, put these declarations inside a block.  Saves us
+     from a bunch of mallocs, particularly with the 2D array. */
+      hwloc_obj_t nodes[nbnodes];
+      unsigned distances[nbnodes][nbnodes];
+      for (osnode=0; osnode < nbnodes; osnode++) {
+          char nodepath[SYSFS_NUMA_NODE_PATH_LEN];
+          hwloc_cpuset_t cpuset;
+          unsigned long size = -1;
+          unsigned long hpfree = -1;
+          sprintf(nodepath, "%s/node%u/cpumap", path, osnode);
+          cpuset = hwloc_parse_cpumap(nodepath, topology->backend_params.sysfs.root_fd);
+          if (!cpuset)
+              continue;
+          /* clear disabled cpus */
+          hwloc_cpuset_clearset(cpuset, admin_disabled_cpus_set);
+          if (hwloc_cpuset_isset(admin_disabled_mems_set, osnode)) {
+              size = 0; hpfree = 0;
+          } else
+              hwloc_sysfs_node_meminfo_info(topology, path, osnode, &size, &hpfree);
+          node = hwloc_alloc_setup_object(HWLOC_OBJ_NODE, osnode);
+          node->cpuset = cpuset;
+          node->attr->node.memory_kB = size;
+          node->attr->node.huge_page_free = hpfree;
+          hwloc_debug_1arg_cpuset("os node %u has cpuset %s\n",
+                                  osnode, node->cpuset);
+          hwloc_add_object(topology, node);
+          nodes[osnode] = node;
+          sprintf(nodepath, "%s/node%u/distance", path, osnode);
+          hwloc_parse_node_distance(nodepath, nbnodes, distances[osnode], topology->backend_params.sysfs.root_fd);
+      hwloc_setup_misc_level_from_distances(topology, nbnodes, nodes, distances);
 /* Look at Linux' /sys/devices/system/cpu/cpu%d/topology/ */
@@ -579,7 +574,7 @@
 #define CPU_TOPOLOGY_STR_LEN 128
-  char string[CPU_TOPOLOGY_STR_LEN];
+  char str[CPU_TOPOLOGY_STR_LEN];
   DIR *dir;
   int i,j;
   FILE *fd;
@@ -607,16 +602,16 @@
       /* check whether the kernel exports topology information for this cpu */
-      sprintf(string, "%s/cpu%lu/topology", path, cpu);
-      if (hwloc_access(string, X_OK, topology->backend_params.sysfs.root_fd) < 0 && errno == ENOENT) {
+      sprintf(str, "%s/cpu%lu/topology", path, cpu);
+      if (hwloc_access(str, X_OK, topology->backend_params.sysfs.root_fd) < 0 && errno == ENOENT) {
 	hwloc_debug("os proc %lu has no accessible %s/cpu%lu/topology\n",
 		   cpu, path, cpu);
 	continue;
       /* check whether this processor is offline */
-      sprintf(string, "%s/cpu%lu/online", path, cpu);
-      fd = hwloc_fopen(string, "r", topology->backend_params.sysfs.root_fd);
+      sprintf(str, "%s/cpu%lu/online", path, cpu);
+      fd = hwloc_fopen(str, "r", topology->backend_params.sysfs.root_fd);
       if (fd) {
 	if (fgets(online, sizeof(online), fd)) {
 	  fclose(fd);
@@ -647,11 +642,11 @@
       /* look at the socket */
       mysocketid = 0; /* shut-up the compiler */
-      sprintf(string, "%s/cpu%d/topology/physical_package_id", path, i);
-      hwloc_parse_sysfs_unsigned(string, &mysocketid, topology->backend_params.sysfs.root_fd);
+      sprintf(str, "%s/cpu%d/topology/physical_package_id", path, i);
+      hwloc_parse_sysfs_unsigned(str, &mysocketid, topology->backend_params.sysfs.root_fd);
-      sprintf(string, "%s/cpu%d/topology/core_siblings", path, i);
-      socketset = hwloc_parse_cpumap(string, topology->backend_params.sysfs.root_fd);
+      sprintf(str, "%s/cpu%d/topology/core_siblings", path, i);
+      socketset = hwloc_parse_cpumap(str, topology->backend_params.sysfs.root_fd);
       assert(socketset);
       hwloc_cpuset_clearset(socketset, admin_disabled_cpus_set);
       assert(hwloc_cpuset_weight(socketset) >= 1);
@@ -668,11 +663,11 @@
       /* look at the core */
       mycoreid = 0; /* shut-up the compiler */
-      sprintf(string, "%s/cpu%d/topology/core_id", path, i);
-      hwloc_parse_sysfs_unsigned(string, &mycoreid, topology->backend_params.sysfs.root_fd);
+      sprintf(str, "%s/cpu%d/topology/core_id", path, i);
+      hwloc_parse_sysfs_unsigned(str, &mycoreid, topology->backend_params.sysfs.root_fd);
-      sprintf(string, "%s/cpu%d/topology/thread_siblings", path, i);
-      coreset = hwloc_parse_cpumap(string, topology->backend_params.sysfs.root_fd);
+      sprintf(str, "%s/cpu%d/topology/thread_siblings", path, i);
+      coreset = hwloc_parse_cpumap(str, topology->backend_params.sysfs.root_fd);
       assert(coreset);
       hwloc_cpuset_clearset(coreset, admin_disabled_cpus_set);
       assert(hwloc_cpuset_weight(coreset) >= 1);
@@ -703,19 +698,18 @@
       for(j=0; j<10; j++) {
 #define SHARED_CPU_MAP_STRLEN 128
 	char mappath[SHARED_CPU_MAP_STRLEN];
-	char string[20]; /* enough for a level number (one digit) or a type (Data/Instruction/Unified) */
+	char str2[20]; /* enough for a level number (one digit) or a type (Data/Instruction/Unified) */
 	struct hwloc_obj *cache;
 	hwloc_cpuset_t cacheset;
 	unsigned long kB = 0;
 	int depth; /* 0 for L1, .... */
-	FILE * fd;
 	/* get the cache level depth */
 	sprintf(mappath, "%s/cpu%d/cache/index%d/level", path, i, j);
 	fd = hwloc_fopen(mappath, "r", topology->backend_params.sysfs.root_fd);
 	if (fd) {
-	  if (fgets(string,sizeof(string), fd))
-	    depth = strtoul(string, NULL, 10)-1;
+	  if (fgets(str2,sizeof(str2), fd))
+	    depth = strtoul(str2, NULL, 10)-1;
 	  else
 	    continue;
 	  fclose(fd);
@@ -726,9 +720,9 @@
 	sprintf(mappath, "%s/cpu%d/cache/index%d/type", path, i, j);
 	if (fd) {
-	  if (fgets(string, sizeof(string), fd)) {
+	  if (fgets(str2, sizeof(str2), fd)) {
 	    fclose(fd);
-	    if (!strncmp(string, "Instruction", 11))
+	    if (!strncmp(str2, "Instruction", 11))
 	      continue;
 	  } else {
 	    fclose(fd);
@@ -741,8 +735,8 @@
 	sprintf(mappath, "%s/cpu%d/cache/index%d/size", path, i, j);
 	if (fd) {
-	    kB = atol(string); /* in kB */
+	    kB = atol(str2); /* in kB */
 	  fclose(fd);
@@ -783,7 +777,7 @@
 	     hwloc_cpuset_t admin_disabled_cpus_set)
   FILE *fd;
-  char string[strlen(PHYSID)+1+9+1+1];
+  char str[strlen(PHYSID)+1+9+1+1];
   char *endptr;
   unsigned proc_physids[] = { [0 ... HWLOC_NBMAXCPUS-1] = -1 };
   unsigned osphysids[] = { [0 ... HWLOC_NBMAXCPUS-1] = -1 };
@@ -812,12 +806,12 @@
   /* Just record information and count number of sockets and cores */
   hwloc_debug("\n\n * Topology extraction from /proc/cpuinfo *\n\n");
-  while (fgets(string,sizeof(string),fd)!=NULL)
+  while (fgets(str,sizeof(str),fd)!=NULL)
 #      define getprocnb_begin(field, var)		     \
-      if ( !strncmp(field,string,strlen(field)))	     \
+      if ( !strncmp(field,str,strlen(field)))	     \
-	char *c = strchr(string, ':')+1;		     \
+	char *c = strchr(str, ':')+1;		     \
 	var = strtoul(c,&endptr,0);			     \
 	if (endptr==c)							\
@@ -864,7 +858,7 @@
 	  (numcores)++;
       getprocnb_end()
-	if (string[strlen(string)-1]!='\n')
+	if (str[strlen(str)-1]!='\n')
 	    fscanf(fd,"%*[^\n]");
 	    getc(fd);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-osf.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-osf.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-osf.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -32,6 +32,7 @@
   cpuset_t cpuset, xor_cpuset;
   radid_t radid;
   int ret = 0;
+  int ret_errno = 0;
   cpusetcreate(&target_cpuset);
   cpuemptyset(target_cpuset);
@@ -58,12 +59,13 @@
   /* radset containing exactly this set of CPUs not found */
-  errno = EXDEV;
+  ret_errno = EXDEV;
 out:
   cpusetdestroy(&target_cpuset);
   cpusetdestroy(&cpuset);
   cpusetdestroy(&xor_cpuset);
+  errno = ret_errno;
   return ret;
@@ -73,7 +75,7 @@
   radset_t radset;
   if (hwloc_cpuset_isequal(hwloc_set, hwloc_get_system_obj(topology)->cpuset)) {
-    if (pthread_rad_detach(thread))
+    if ((errno = pthread_rad_detach(thread)))
       return -1;
     return 0;
@@ -82,10 +84,10 @@
     return -1;
   if (strict) {
-    if (pthread_rad_bind(thread, radset, RAD_INSIST | RAD_WAIT))
+    if ((errno = pthread_rad_bind(thread, radset, RAD_INSIST | RAD_WAIT)))
       return -1;
   } else {
-    if (pthread_rad_attach(thread, radset, RAD_WAIT))
+    if ((errno = pthread_rad_attach(thread, radset, RAD_WAIT)))
       return -1;
   radsetdestroy(&radset);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-synthetic.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-synthetic.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-synthetic.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -20,6 +21,8 @@
   const char *pos, *next_pos;
   unsigned long item, count;
   int i;
+  int cache_depth = 0, misc_depth = 0;
+  int nb_machine_levels = 0, nb_node_levels = 0;
   assert(topology->backend_type == HWLOC_BACKEND_NONE);
@@ -79,9 +82,6 @@
     return -1;
-  int cache_depth = 0, misc_depth = 0;
-  int nb_machine_levels = 0, nb_node_levels = 0;
   for(i=0; i<count; i++) {
     hwloc_obj_type_t type;
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-xml.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-xml.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology-xml.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -28,6 +28,8 @@
   if (!doc)
     return -1;
+  /* TODO: warn if dtd is not hwloc.dtd? */
   topology->backend_params.xml.doc = doc;
   topology->is_thissystem = 0;
   topology->backend_type = HWLOC_BACKEND_XML;
@@ -241,7 +243,7 @@
 	    return;
 	} else {
-	  fprintf(stderr, "ignoring unexpected xml attr type %u\n", node->type);
+	  fprintf(stderr, "ignoring unexpected xml attr type %u\n", attr->type);
@@ -251,7 +253,7 @@
 	  if (attr->children)
 	    hwloc__look_xml_attr(topology, obj, attr->name, attr->children);
 	} else {
@@ -269,7 +271,7 @@
       } else {
 	/* add object */
-	if (obj->type == HWLOC_OBJ_TYPE_MAX) {
+	if (obj->type >= HWLOC_OBJ_TYPE_MAX) {
 	  fprintf(stderr, "ignoring object with invalid type %u\n", obj->type);
 	  free(obj);
 	} else if (obj->type == HWLOC_OBJ_SYSTEM) {
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/topology.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -232,47 +233,51 @@
     return;
-  /* create new misc objects and record their size */
-  hwloc_obj_t groupobjs[nbgroups];
-  unsigned groupsizes[nbgroups];
-  memset(groupsizes, 0, sizeof(groupsizes));
-  for(i=0; i<nbgroups; i++) {
-    /* create the misc object */
-    hwloc_obj_t misc_obj;
-    misc_obj = hwloc_alloc_setup_object(HWLOC_OBJ_MISC, -1);
-    misc_obj->cpuset = hwloc_cpuset_alloc();
-    hwloc_cpuset_zero(misc_obj->cpuset);
-    misc_obj->attr->misc.depth = depth;
-    for (j=0; j<nbobjs; j++)
-      if (groupids[j] == i+1) {
-	hwloc_cpuset_orset(misc_obj->cpuset, objs[j]->cpuset);
-	groupsizes[i]++;
+      hwloc_obj_t groupobjs[nbgroups];
+      unsigned groupsizes[nbgroups];
+      unsigned groupdistances[nbgroups][nbgroups];
+      /* create new misc objects and record their size */
+      memset(groupsizes, 0, sizeof(groupsizes));
+      for(i=0; i<nbgroups; i++) {
+          /* create the misc object */
+          hwloc_obj_t misc_obj;
+          misc_obj = hwloc_alloc_setup_object(HWLOC_OBJ_MISC, -1);
+          misc_obj->cpuset = hwloc_cpuset_alloc();
+          hwloc_cpuset_zero(misc_obj->cpuset);
+          misc_obj->attr->misc.depth = depth;
+          for (j=0; j<nbobjs; j++)
+              if (groupids[j] == i+1) {
+                  hwloc_cpuset_orset(misc_obj->cpuset, objs[j]->cpuset);
+                  groupsizes[i]++;
+          hwloc_debug_1arg_cpuset("adding misc object with %u objects and cpuset %s\n",
+                                  groupsizes[i], misc_obj->cpuset);
+          hwloc_add_object(topology, misc_obj);
+          groupobjs[i] = misc_obj;
-    hwloc_debug_1arg_cpuset("adding misc object with %u objects and cpuset %s\n",
-	       groupsizes[i], misc_obj->cpuset);
-    hwloc_add_object(topology, misc_obj);
-    groupobjs[i] = misc_obj;
-  /* factorize distances */
-  unsigned groupdistances[nbgroups][nbgroups];
-  memset(groupdistances, 0, sizeof(groupdistances));
-  for(i=0; i<nbobjs; i++)
-    for(j=0; j<nbobjs; j++)
-      groupdistances[groupids[i]-1][groupids[j]-1] += distances[i][j];
-    for(j=0; j<nbgroups; j++)
-      groupdistances[i][j] /= groupsizes[i]*groupsizes[j];
+      /* factorize distances */
+      memset(groupdistances, 0, sizeof(groupdistances));
+      for(i=0; i<nbobjs; i++)
+          for(j=0; j<nbobjs; j++)
+              groupdistances[groupids[i]-1][groupids[j]-1] += distances[i][j];
+          for(j=0; j<nbgroups; j++)
+              groupdistances[i][j] /= groupsizes[i]*groupsizes[j];
 #ifdef HWLOC_DEBUG
-  hwloc_debug("group distances:\n");
-      hwloc_debug("%u ", groupdistances[i][j]);
-    hwloc_debug("\n");
+      hwloc_debug("group distances:\n");
+              hwloc_debug("%u ", groupdistances[i][j]);
+          hwloc_debug("\n");
+#endif
+      hwloc__setup_misc_level_from_distances(topology, nbgroups, groupobjs, groupdistances, depth + 1);
-#endif
-  hwloc__setup_misc_level_from_distances(topology, nbgroups, groupobjs, groupdistances, depth + 1);
@@ -1303,6 +1308,8 @@
 int
 hwloc_topology_load (struct hwloc_topology *topology)
+  char *local_env;
   if (topology->is_loaded) {
     hwloc_topology_clear(topology);
     hwloc_topology_setup_defaults(topology);
@@ -1310,17 +1317,21 @@
 #ifdef LINUX_SYS
-  char *fsroot_path_env = getenv("HWLOC_FSROOT");
-  if (fsroot_path_env) {
-    hwloc_backend_exit(topology);
-    hwloc_backend_sysfs_init(topology, fsroot_path_env);
+    char *fsroot_path_env = getenv("HWLOC_FSROOT");
+    if (fsroot_path_env) {
+      hwloc_backend_exit(topology);
+      hwloc_backend_sysfs_init(topology, fsroot_path_env);
 #endif
 #ifdef HAVE_XML
-  char *xmlpath_env = getenv("HWLOC_XMLFILE");
-  if (xmlpath_env) {
-    hwloc_backend_xml_init(topology, xmlpath_env);
+    char *xmlpath_env = getenv("HWLOC_XMLFILE");
+    if (xmlpath_env) {
+      hwloc_backend_xml_init(topology, xmlpath_env);
 #endif
@@ -1334,7 +1345,7 @@
   hwloc_discover(topology);
-  char *local_env = getenv("HWLOC_THISSYSTEM");
+  local_env = getenv("HWLOC_THISSYSTEM");
   if (local_env)
     topology->is_thissystem = atoi(local_env);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/traversal.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/traversal.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/src/traversal.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -33,13 +34,13 @@
 struct hwloc_obj *
-hwloc_get_obj_by_depth (struct hwloc_topology *topology, unsigned depth, unsigned index)
+hwloc_get_obj_by_depth (struct hwloc_topology *topology, unsigned depth, unsigned idx)
   if (depth >= topology->nb_levels)
     return NULL;
-  if (index >= topology->level_nbobjects[depth])
+  if (idx >= topology->level_nbobjects[depth])
     return NULL;
-  return topology->levels[depth][index];
+  return topology->levels[depth][idx];
 int hwloc_get_closest_objs (struct hwloc_topology *topology, struct hwloc_obj *src, struct hwloc_obj **objs, int max)
@@ -171,9 +172,10 @@
 int
 hwloc_obj_snprintf(char *string, size_t size,
-		  struct hwloc_topology *topology, struct hwloc_obj *l, const char *indexprefix, int verbose)
+		  struct hwloc_topology *topology, struct hwloc_obj *l, const char *_indexprefix, int verbose)
   hwloc_obj_type_t type = l->type;
+  const char *indexprefix = _indexprefix ? _indexprefix : "#";
   char os_index[12] = "";
   if (l->os_index != -1)
@@ -182,43 +184,43 @@
   switch (type) {
   case HWLOC_OBJ_SOCKET:
   case HWLOC_OBJ_CORE:
-    return snprintf(string, size, "%s%s", hwloc_obj_type_string(type), os_index);
+    return hwloc_snprintf(string, size, "%s%s", hwloc_obj_type_string(type), os_index);
   case HWLOC_OBJ_MISC:
 	  /* TODO: more pretty presentation? */
-    return snprintf(string, size, "%s%u%s", hwloc_obj_type_string(type), l->attr->misc.depth, os_index);
+    return hwloc_snprintf(string, size, "%s%u%s", hwloc_obj_type_string(type), l->attr->misc.depth, os_index);
   case HWLOC_OBJ_PROC:
-    return snprintf(string, size, "P%s", os_index);
+    return hwloc_snprintf(string, size, "P%s", os_index);
   case HWLOC_OBJ_SYSTEM:
     if (verbose)
-      return snprintf(string, size, "%s(%lu%s HP=%lu*%lukB %s %s)", hwloc_obj_type_string(type),
+      return hwloc_snprintf(string, size, "%s(%lu%s HP=%lu*%lukB %s %s)", hwloc_obj_type_string(type),
 		      hwloc_memory_size_printf_value(l->attr->system.memory_kB),
 		      hwloc_memory_size_printf_unit(l->attr->system.memory_kB),
 		      l->attr->system.huge_page_free, l->attr->system.huge_page_size_kB,
 		      l->attr->system.dmi_board_vendor?l->attr->system.dmi_board_vendor:"",
 		      l->attr->system.dmi_board_name?l->attr->system.dmi_board_name:"");
     else
-      return snprintf(string, size, "%s(%lu%s)", hwloc_obj_type_string(type),
+      return hwloc_snprintf(string, size, "%s(%lu%s)", hwloc_obj_type_string(type),
 		      hwloc_memory_size_printf_unit(l->attr->system.memory_kB));
   case HWLOC_OBJ_MACHINE:
     if (verbose)
 		      hwloc_memory_size_printf_value(l->attr->machine.memory_kB),
 		      hwloc_memory_size_printf_unit(l->attr->machine.memory_kB),
 		      l->attr->machine.huge_page_free, l->attr->machine.huge_page_size_kB,
 		      l->attr->machine.dmi_board_vendor?l->attr->machine.dmi_board_vendor:"",
 		      l->attr->machine.dmi_board_name?l->attr->machine.dmi_board_name:"");
     else
-      return snprintf(string, size, "%s%s(%lu%s)", hwloc_obj_type_string(type), os_index,
+      return hwloc_snprintf(string, size, "%s%s(%lu%s)", hwloc_obj_type_string(type), os_index,
 		      hwloc_memory_size_printf_unit(l->attr->machine.memory_kB));
   case HWLOC_OBJ_NODE:
 		    verbose ? hwloc_obj_type_string(type) : "Node", os_index,
 		    hwloc_memory_size_printf_value(l->attr->node.memory_kB),
 		    hwloc_memory_size_printf_unit(l->attr->node.memory_kB));
   case HWLOC_OBJ_CACHE:
-    return snprintf(string, size, "L%u%s%s(%lu%s)", l->attr->cache.depth,
+    return hwloc_snprintf(string, size, "L%u%s%s(%lu%s)", l->attr->cache.depth,
 		      verbose ? hwloc_obj_type_string(type) : "", os_index,
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/Makefile.am
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/Makefile.am	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/Makefile.am	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,4 +1,5 @@
@@ -11,7 +12,7 @@
 	hwloc_get_largest_objs_inside_cpuset \
 	hwloc_get_next_obj_covering_cpuset \
 	hwloc_get_obj_inside_cpuset \
-	hwloc_get_cache_covering_obj \
+	hwloc_get_shared_cache_covering_obj \
 	hwloc_cpuset_first_last_weight \
 	hwloc_cpuset_singlify \
 	hwloc_type_depth \
@@ -35,9 +36,9 @@
 endif !HAVE_SCHED_SETAFFINITY
 if HAVE_LIBIBVERBS
-check_PROGRAMS += ibverbs
+check_PROGRAMS += openfabrics-verbs
 else !HAVE_LIBIBVERBS
-EXTRA_DIST += ibverbs.c
+EXTRA_DIST += openfabrics-verbs.c
 endif !HAVE_LIBIBVERBS
 TESTS = $(check_PROGRAMS)
@@ -49,7 +50,7 @@
 LIBS = $(top_builddir)/src/libhwloc.la
 linux_libnuma_LDFLAGS = -lnuma
-ibverbs_LDFLAGS = -libverbs
+openfabrics_verbs_LDFLAGS = -libverbs
 if HAVE_WINDOWS
 else
 hwloc_bind_LDFLAGS = -lpthread
Deleted: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_cache_covering_obj.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_cache_covering_obj.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_cache_covering_obj.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,75 +0,0 @@
-#include <hwloc.h>
-#include <stdlib.h>
-#include <stdio.h>
-#include <string.h>
-#include <assert.h>
-/* check hwloc_get_cache_covering_obj() */
-#define SYNTHETIC_TOPOLOGY_DESCRIPTION_SHARED "6 5 4 3 2" /* 736bits wide topology */
-#define SYNTHETIC_TOPOLOGY_DESCRIPTION_NONSHARED "6 5 4 1 2" /* 736bits wide topology */
-int main()
-  hwloc_topology_t topology;
-  hwloc_obj_t obj, cache;
-  hwloc_topology_init(&topology);
-  hwloc_topology_set_synthetic(topology, SYNTHETIC_TOPOLOGY_DESCRIPTION_SHARED);
-  hwloc_topology_load(topology);
-  /* check the cache above a given cpu */
-#define CPUINDEX 180
-  obj = hwloc_get_obj_by_depth(topology, 5, CPUINDEX);
-  assert(obj);
-  cache = hwloc_get_cache_covering_obj(topology, obj);
-  assert(cache);
-  assert(cache->type == HWLOC_OBJ_CACHE);
-  assert(cache->logical_index == CPUINDEX/2/3);
-  assert(hwloc_obj_is_in_subtree(topology, obj, cache));
-  /* check no shared cache above the L2 cache */
-  obj = hwloc_get_obj_by_depth(topology, 3, 0);
-  assert(obj);
-  assert(!cache);
-  /* check no shared cache above the node */
-  obj = hwloc_get_obj_by_depth(topology, 1, 0);
-  assert(obj);
-  assert(!cache);
-  hwloc_topology_destroy(topology);
-  hwloc_topology_set_synthetic(topology, SYNTHETIC_TOPOLOGY_DESCRIPTION_NONSHARED);
-  assert(obj);
-  assert(cache);
-  assert(cache->logical_index == CPUINDEX/2/1);
-  /* check no shared-cache above the core */
-  obj = hwloc_get_obj_by_depth(topology, 4, CPUINDEX/2);
-  assert(obj);
-  assert(!cache);
-  return EXIT_SUCCESS;
Copied: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_shared_cache_covering_obj.c (from rev 5527, mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_cache_covering_obj.c)
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_shared_cache_covering_obj.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/hwloc_get_shared_cache_covering_obj.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -0,0 +1,75 @@
+ * Copyright © 2009 CNRS, INRIA, Université Bordeaux 1
+ * See COPYING in top-level directory.
+#include <hwloc.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <assert.h>
+/* check hwloc_get_shared_cache_covering_obj() */
+#define SYNTHETIC_TOPOLOGY_DESCRIPTION_SHARED "6 5 4 3 2" /* 736bits wide topology */
+#define SYNTHETIC_TOPOLOGY_DESCRIPTION_NONSHARED "6 5 4 1 2" /* 736bits wide topology */
+int main()
+  hwloc_topology_t topology;
+  hwloc_obj_t obj, cache;
+  hwloc_topology_init(&topology);
+  hwloc_topology_set_synthetic(topology, SYNTHETIC_TOPOLOGY_DESCRIPTION_SHARED);
+  hwloc_topology_load(topology);
+  /* check the cache above a given cpu */
+#define CPUINDEX 180
+  obj = hwloc_get_obj_by_depth(topology, 5, CPUINDEX);
+  assert(obj);
+  cache = hwloc_get_shared_cache_covering_obj(topology, obj);
+  assert(cache);
+  assert(cache->type == HWLOC_OBJ_CACHE);
+  assert(cache->logical_index == CPUINDEX/2/3);
+  assert(hwloc_obj_is_in_subtree(topology, obj, cache));
+  /* check no shared cache above the L2 cache */
+  obj = hwloc_get_obj_by_depth(topology, 3, 0);
+  assert(obj);
+  assert(!cache);
+  /* check no shared cache above the node */
+  obj = hwloc_get_obj_by_depth(topology, 1, 0);
+  assert(obj);
+  assert(!cache);
+  hwloc_topology_destroy(topology);
+  hwloc_topology_set_synthetic(topology, SYNTHETIC_TOPOLOGY_DESCRIPTION_NONSHARED);
+  assert(obj);
+  assert(cache);
+  assert(cache->logical_index == CPUINDEX/2/1);
+  /* check no shared-cache above the core */
+  obj = hwloc_get_obj_by_depth(topology, 4, CPUINDEX/2);
+  assert(obj);
+  assert(!cache);
+  return EXIT_SUCCESS;
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/ibverbs.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/ibverbs.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/ibverbs.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -31,7 +31,7 @@
 	     i, ibv_get_device_name(dev));
     } else {
       char *cpuset_string = NULL;
-      hwloc_cpuset_asprintf(&cpuset_string, &set);
+      hwloc_cpuset_asprintf(&cpuset_string, set);
       printf("got cpuset %s for device %d (%s)\n",
 	     cpuset_string, i, ibv_get_device_name(dev));
       free(cpuset_string);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/linux/16em64t-4s2c2t.xml.tar.gz.output
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/linux/16em64t-4s2c2t.xml.tar.gz.output	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/linux/16em64t-4s2c2t.xml.tar.gz.output	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,5 @@
 <?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE root SYSTEM "lstopo.dtd">
+<!DOCTYPE root SYSTEM "hwloc.dtd">
 <root>
   <object type="System" os_index="0" cpuset="0000ffff" dmi_board_vendor="" dmi_board_name="" memory_kB="0" huge_page_free="0" huge_page_size_kB="0">
     <object type="Socket" os_index="0" cpuset="00001111">
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/lstopo_xml.sh.in
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/lstopo_xml.sh.in	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/tests/lstopo_xml.sh.in	2009-10-22 15:32:53 UTC (rev 5530)
@@ -23,7 +23,7 @@
 diff @HWLOC_DIFF_U@ "$srcdir"/linux/16em64t-4s2c2t.xml.tar.gz.output "$file"
 if [ -n "@XMLLINT@" ]
 then
-  cp "$srcdir"/../src/lstopo.dtd "$tmp/"
+  cp "$srcdir"/../src/hwloc.dtd "$tmp/"
   @XMLLINT@ --valid "$file" > /dev/null
 fi
 rm -rf "$tmp"
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/Makefile.am
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/Makefile.am	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/Makefile.am	2009-10-22 15:32:53 UTC (rev 5530)
@@ -27,13 +27,14 @@
 nodist_man_MANS = $(man_pages)
 install-exec-hook: install-man
-	$(RM) $(DESTDIR)$(bindir)/hwloc-ls$(EXEEXT) $(DESTDIR)$(bindir)/hwloc-info$(EXEEXT)
+	rm -f $(DESTDIR)$(bindir)/hwloc-ls$(EXEEXT) $(DESTDIR)$(bindir)/hwloc-info$(EXEEXT)
 	cd $(DESTDIR)$(bindir) && $(LN_S) lstopo$(EXEEXT) hwloc-ls$(EXEEXT) && $(LN_S) lstopo$(EXEEXT) hwloc-info$(EXEEXT)
+	rm -f $(DESTDIR)$(man1dir)/hwloc-ls.1 $(DESTDIR)$(man1dir)/hwloc-info.1
 	cd $(DESTDIR)$(man1dir) && $(LN_S) lstopo.1 hwloc-ls.1 && $(LN_S) lstopo.1 hwloc-info.1
 uninstall-local:
-	$(RM) $(DESTDIR)$(man1dir)/hwloc-ls.1 $(DESTDIR)$(man1dir)/hwloc-info.1
 distclean-local:
 	rm -f $(man_pages)
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-distrib.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-distrib.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-distrib.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -26,7 +26,7 @@
   long n = -1;
   char * synthetic = NULL;
-  char * xmlpath = NULL;
+  const char * xmlpath = NULL;
   int verbose = 0;
   char **orig_argv = argv;
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-mask.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-mask.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/hwloc-mask.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -94,7 +94,7 @@
     while ((proc = hwloc_get_next_obj_covering_cpuset_by_type(topology, set, HWLOC_OBJ_PROC, prev)) != NULL) {
       if (prev)
 	printf(",");
-      printf("%u", proc->os_index);
+      printf("%d", proc->os_index);
       prev = proc;
     printf("\n");
@@ -103,7 +103,7 @@
     while ((node = hwloc_get_next_obj_covering_cpuset_by_type(topology, set, HWLOC_OBJ_NODE, prev)) != NULL) {
       if (prev)
 	printf(",");
-      printf("%u", node->os_index);
+      printf("%d", node->os_index);
       prev = node;
     printf("\n");
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-cairo.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-cairo.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-cairo.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -96,7 +96,7 @@
   cairo_destroy(c);
-static void null(void) {}
+static void null_declare_color (void *output, int r, int g, int b) {}
 #endif /* (CAIRO_HAS_XLIB_SURFACE + CAIRO_HAS_PNG_FUNCTIONS + CAIRO_HAS_PDF_SURFACE + CAIRO_HAS_PS_SURFACE + CAIRO_HAS_SVG_SURFACE) */
@@ -164,7 +164,7 @@
 static struct draw_methods x11_draw_methods = {
   .start = x11_start,
-  .declare_color = (void*) null,
+  .declare_color = null_declare_color,
   .box = topo_cairo_box,
   .line = topo_cairo_line,
   .text = topo_cairo_text,
@@ -276,7 +276,7 @@
 static struct draw_methods png_draw_methods = {
   .start = png_start,
@@ -311,7 +311,7 @@
 static struct draw_methods pdf_draw_methods = {
   .start = pdf_start,
@@ -346,7 +346,7 @@
 static struct draw_methods ps_draw_methods = {
   .start = ps_start,
@@ -381,7 +381,7 @@
 static struct draw_methods svg_draw_methods = {
   .start = svg_start,
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-draw.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-draw.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-draw.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -1,5 +1,6 @@
@@ -188,6 +189,10 @@
 #define RECURSE_RECT_BEGIN(obj, methods, separator, border) \
 RECURSE_BEGIN(obj, border) \
     unsigned obj_maxwidth = 0, obj_maxheight = 0; \
+    unsigned area; \
+    float idealtotheight; \
+    unsigned rows, columns; \
+    float under_ratio, over_ratio; \
     RECURSE_FOR() \
       RECURSE_CALL_FUN(&null_draw_methods); \
       if (height > obj_maxheight) \
@@ -196,20 +201,20 @@
         obj_maxwidth = width; \
     /* Total area for subobjects */ \
-    unsigned area = (obj_maxwidth + (separator)) * (obj_maxheight + (separator)) * numsubobjs; \
+    area = (obj_maxwidth + (separator)) * (obj_maxheight + (separator)) * numsubobjs; \
     /* Ideal total height for spreading that area with RATIO */ \
-    float idealtotheight = sqrt(area/RATIO); \
+    idealtotheight = sqrt(area/RATIO); \
     /* Underestimated number of rows */ \
-    unsigned rows = idealtotheight / (obj_maxheight + (separator)); \
-    unsigned columns = rows ? (numsubobjs + rows - 1) / rows : 1; \
+    rows = idealtotheight / (obj_maxheight + (separator)); \
+    columns = rows ? (numsubobjs + rows - 1) / rows : 1; \
     /* Ratio obtained by underestimation */ \
-    float under_ratio = (float) (columns * (obj_maxwidth + (separator))) / (rows * (obj_maxheight + (separator))); \
+    under_ratio = (float) (columns * (obj_maxwidth + (separator))) / (rows * (obj_maxheight + (separator))); \
     /* try to overestimate too */ \
     rows++; \
     columns = (numsubobjs + rows - 1) / rows; \
     /* Ratio obtained by overestimation */ \
-    float over_ratio = (float) (columns * (obj_maxwidth + (separator))) / (rows * (obj_maxheight + (separator))); \
+    over_ratio = (float) (columns * (obj_maxwidth + (separator))) / (rows * (obj_maxheight + (separator))); \
     /* Did we actually preferred underestimation? (good row/column fit or good ratio) */ \
     if (rows > 1 && prefer_ratio(under_ratio, over_ratio)) { \
       rows--; \
@@ -257,14 +262,14 @@
 #define RECURSE_RECT(obj, methods, separator, border) do {\
   if (obj->arity && obj->children[0]->type == HWLOC_OBJ_NODE) { \
     /* Nodes shouldn't be put with an arbitrary geometry, as NUMA distances may not be that way */ \
-    int vert = prefer_vert(topology, level, output, depth, x, y, separator); \
-    if (vert) \
+    int pvert = prefer_vert(topology, level, output, depth, x, y, separator); \
+    if (pvert) \
       RECURSE_VERT(level, methods, separator, border); \
     else \
       RECURSE_HORIZ(level, methods, separator, border); \
   } else {\
-        RECURSE_CALL_FUN(methods); \
+    RECURSE_CALL_FUN(methods); \
     RECURSE_RECT_END(obj, methods, separator, border); \
 } while (0)
@@ -495,10 +500,11 @@
   if (level->arity > 1 && level->children[0]->type == HWLOC_OBJ_MACHINE) {
     if (vert) {
       unsigned top = 0, bottom = 0;
+      unsigned center;
       RECURSE_BEGIN(level, gridsize)
       RECURSE_FOR()
-	unsigned center = y + totheight + height / 2;
+        center = y + totheight + height / 2;
 	if (!top)
 	  top = center;
 	bottom = center;
@@ -509,10 +515,11 @@
 	methods->line(output, 0, 0, 0, depth, x + mywidth, top, x + mywidth, bottom);
     } else {
       unsigned left = 0, right = 0;
+      unsigned center;
       RECURSE_FOR()
-	unsigned center = x + totwidth + width / 2;
+        center = x + totwidth + width / 2;
 	if (!left)
 	  left = center;
 	right = center;
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-xml.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-xml.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo-xml.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -8,6 +8,7 @@
 #ifdef HAVE_XML
 #include <hwloc.h>
 #include <strings.h>
@@ -100,7 +101,7 @@
   xmlDocSetRootElement(doc, root_node);
   /* Creates a DTD declaration. Isn't mandatory. */
-  dtd = xmlCreateIntSubset(doc, BAD_CAST "root", NULL, BAD_CAST "lstopo.dtd");
+  dtd = xmlCreateIntSubset(doc, BAD_CAST "root", NULL, BAD_CAST "hwloc.dtd");
   output_topology (topology, hwloc_get_system_obj(topology), root_node, verbose_mode);
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo.c	2009-10-22 14:55:56 UTC (rev 5529)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/utils/lstopo.c	2009-10-22 15:32:53 UTC (rev 5530)
@@ -94,7 +94,7 @@
   int ignorecache = 0;
   char * callname;
   char * fsysroot = NULL;
   int opt;
More information about the mpich2-commits mailing list
