[mpich2-commits] r5453 - in mpich2/trunk/src/pm/hydra: include	pm/pmiserv ui/mpiexec ui/utils utils/launch
    balaji at mcs.anl.gov
    Wed Oct 14 06:35:30 CDT 2009
Author: balaji
Date: 2009-10-14 06:35:29 -0500 (Wed, 14 Oct 2009)
New Revision: 5453
Modified:
   mpich2/trunk/src/pm/hydra/include/hydra_base.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
   mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
Log:
Change variable name to maintain consistency with the other names.
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-14 11:35:29 UTC (rev 5453)
@@ -199,7 +199,7 @@
     int  out;
     int  err;
-    int core_count;
+    int proxy_core_count;
     /* Segment list will contain one-pass of the hosts file */
     struct HYD_Proxy_segment *segment_list;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-14 11:35:29 UTC (rev 5453)
@@ -37,7 +37,7 @@
     struct HYD_Env_global global_env;
     int global_core_count;
-    int core_count;
     int exec_proc_count;
     int procs_are_launched;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-14 11:35:29 UTC (rev 5453)
@@ -38,7 +38,7 @@
     HYD_PMCD_pmi_proxy_params.global_env.inherited = NULL;
     HYD_PMCD_pmi_proxy_params.global_core_count = 0;
-    HYD_PMCD_pmi_proxy_params.core_count = 0;
+    HYD_PMCD_pmi_proxy_params.proxy_core_count = 0;
     HYD_PMCD_pmi_proxy_params.exec_proc_count = 0;
     HYD_PMCD_pmi_proxy_params.procs_are_launched = 0;
@@ -536,9 +536,9 @@
     HYDU_FUNC_ENTER();
     for (segment = HYD_PMCD_pmi_proxy_params.segment_list; segment; segment = segment->next)
-        HYD_PMCD_pmi_proxy_params.core_count += segment->proc_count;
+        HYD_PMCD_pmi_proxy_params.proxy_core_count += segment->proc_count;
     for (exec = HYD_PMCD_pmi_proxy_params.exec_list; exec; exec = exec->next)
@@ -547,7 +547,7 @@
     HYDU_MALLOC(pmi_ids, int *, HYD_PMCD_pmi_proxy_params.exec_proc_count * sizeof(int), status);
     for (i = 0; i < HYD_PMCD_pmi_proxy_params.exec_proc_count; i++) {
         pmi_ids[i] = HYDU_local_to_global_id(i,
-                                             HYD_PMCD_pmi_proxy_params.core_count,
+                                             HYD_PMCD_pmi_proxy_params.proxy_core_count,
                                              HYD_PMCD_pmi_proxy_params.segment_list,
                                              HYD_PMCD_pmi_proxy_params.global_core_count);
@@ -658,7 +658,7 @@
         for (i = 0; i < exec->proc_count; i++) {
             pmi_id = HYDU_local_to_global_id(process_id,
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-14 11:35:29 UTC (rev 5453)
@@ -196,7 +196,7 @@
             for (exec = proxy->exec_list; exec; exec = exec->next) {
                     HYDU_dump(stdout, "%d", HYDU_local_to_global_id(process_id++,
-                                                            proxy->core_count,
+                                                            proxy->proxy_core_count,
                                                             proxy->segment_list,
                                                             HYD_handle.global_core_count));
                     if (i < exec->proc_count - 1)
@@ -273,7 +273,7 @@
             proc_count += exec->proc_count;
         for (i = 0; i < proc_count; i++) {
             if (HYD_handle.print_all_exitcodes) {
-                HYDU_dump(stdout, "[%d]", HYDU_local_to_global_id(i, proxy->core_count,
+                HYDU_dump(stdout, "[%d]", HYDU_local_to_global_id(i, proxy->proxy_core_count,
                 HYDU_dump(stdout, "%d", WEXITSTATUS(proxy->exit_status[i]));
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-14 11:35:29 UTC (rev 5453)
@@ -167,7 +167,7 @@
     HYD_handle.proxy_list->segment_list->start_pid = 0;
     HYD_handle.proxy_list->segment_list->proc_count = num_procs;
-    HYD_handle.proxy_list->core_count += num_procs;
+    HYD_handle.proxy_list->proxy_core_count += num_procs;
     HYD_handle.global_core_count += num_procs;
   fn_exit:
@@ -224,7 +224,7 @@
                 proxy_segment->next->proc_count = num_procs;
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-14 11:35:29 UTC (rev 5453)
@@ -195,7 +195,7 @@
     proxy = HYD_handle.proxy_list;
     exec_info = HYD_handle.exec_info_list;
-    proxy_rem_procs = proxy->core_count;
+    proxy_rem_procs = proxy->proxy_core_count;
     exec_rem_procs = exec_info ? exec_info->process_count : 0;
     while (exec_info) {
         if (exec_rem_procs <= proxy_rem_procs) {
@@ -207,7 +207,7 @@
                 proxy = proxy->next;
                 if (proxy == NULL)
             exec_info = exec_info->next;
@@ -222,7 +222,7 @@
             if (proxy == NULL)
@@ -310,7 +310,7 @@
         HYDU_dump(stdout, "      Proxy ID: %2d\n", i++);
         HYDU_dump(stdout, "      -----------------\n");
         HYDU_dump(stdout, "        Proxy name: %s\n", proxy->hostname);
-        HYDU_dump(stdout, "        Process count: %d\n", proxy->core_count);
+        HYDU_dump(stdout, "        Process count: %d\n", proxy->proxy_core_count);
         HYDU_dump(stdout, "\n");
         HYDU_dump(stdout, "        Proxy segment list:\n");
         HYDU_dump(stdout, "        .......................\n");
Modified: mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
--- mpich2/trunk/src/pm/hydra/utils/launch/allocate.c	2009-10-12 22:16:13 UTC (rev 5452)
+++ mpich2/trunk/src/pm/hydra/utils/launch/allocate.c	2009-10-14 11:35:29 UTC (rev 5453)
@@ -26,7 +26,7 @@
     (*proxy)->exec_args = NULL;
     (*proxy)->segment_list = NULL;
-    (*proxy)->core_count = 0;
+    (*proxy)->proxy_core_count = 0;
     (*proxy)->exit_status = NULL;
     (*proxy)->control_fd = -1;
@@ -174,7 +174,7 @@
         HYDU_ERR_POP(status, "Unable to alloc proxy\n");
         (*proxy_list)->segment_list = segment;
         (*proxy_list)->hostname = HYDU_strdup(hostname);
-        (*proxy_list)->core_count += segment->proc_count;
+        (*proxy_list)->proxy_core_count += segment->proc_count;
     else {
         proxy = *proxy_list;
@@ -188,7 +188,7 @@
                         s = s->next;
                     s->next = segment;
-                proxy->core_count += segment->proc_count;
+                proxy->proxy_core_count += segment->proc_count;
                 break;
             else if (proxy->next == NULL) {
@@ -196,7 +196,7 @@
                 proxy->next->segment_list = segment;
                 proxy->next->hostname = HYDU_strdup(hostname);
-                proxy->next->core_count += segment->proc_count;
+                proxy->next->proxy_core_count += segment->proc_count;
                 break;
             else {
More information about the mpich2-commits
