[mpich2-commits] r5454 - in mpich2/trunk/src/pm/hydra: include	pm/pmiserv rmk/src ui/mpiexec ui/utils
    balaji at mcs.anl.gov
    Wed Oct 14 06:35:36 CDT 2009
Author: balaji
Date: 2009-10-14 06:35:35 -0500 (Wed, 14 Oct 2009)
New Revision: 5454
Modified:
   mpich2/trunk/src/pm/hydra/include/hydra.h
   mpich2/trunk/src/pm/hydra/include/hydra_base.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v1.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_finalize.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
   mpich2/trunk/src/pm/hydra/rmk/src/rmki_init.c.in
   mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
Log:
Organize the proxy parameters to allow for better structure sharing
between the UI and the proxies.
Modified: mpich2/trunk/src/pm/hydra/include/hydra.h
--- mpich2/trunk/src/pm/hydra/include/hydra.h	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/include/hydra.h	2009-10-14 11:35:35 UTC (rev 5454)
@@ -12,34 +12,22 @@
 #include "hydra_utils.h"
 struct HYD_Handle_ {
+    struct HYD_User_global user_global;
     char *base_path;
     int proxy_port;
-    HYD_Launch_mode_t launch_mode;
-    char *bootstrap;
     char *css;
     char *rmk;
-    char *binding;
-    char *bindlib;
-    char *ckpointlib;
     int ckpoint_int;
-    char *ckpoint_prefix;
-    int ckpoint_restart;
-    int debug;
     int print_rank_map;
     int print_all_exitcodes;
-    int enablex;
     int pm_env;
-    char *wdir;
     int ranks_per_proc;
-    char *bootstrap_exec;
-    struct HYD_Env_global global_env;
      HYD_Status(*stdin_cb) (int fd, HYD_Event_t events, void *userp);
      HYD_Status(*stdout_cb) (int fd, HYD_Event_t events, void *userp);
      HYD_Status(*stderr_cb) (int fd, HYD_Event_t events, void *userp);
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-14 11:35:35 UTC (rev 5454)
@@ -55,11 +55,6 @@
 #define HYDRA_MAX_PATH 4096
-#if defined MANUAL_EXTERN_ENVIRON
-extern char **environ;
-#endif /* MANUAL_EXTERN_ENVIRON */
 /* sockets required headers */
 #include <poll.h>
 #include <fcntl.h>
@@ -71,26 +66,44 @@
 #include <sys/socket.h>
 #endif
-#if defined(HAVE_PUTENV) && defined(NEEDS_PUTENV_DECL)
-extern int putenv(char *string);
-#endif
-#if defined(NEEDS_GETHOSTNAME_DECL)
-int gethostname(char *name, size_t len);
-#endif
 #define HYD_DEFAULT_PROXY_PORT 9899
 #define HYD_STDOUT  (1)
 #define HYD_STDIN   (2)
-typedef unsigned short HYD_Event_t;
 #define HYD_TMPBUF_SIZE (64 * 1024)
 #define HYD_TMP_STRLEN  1024
 #define HYD_NUM_TMP_STRINGS 200
+#if !defined HAVE_PTHREAD_H
+#error "pthread.h needed"
+#else
+#include <pthread.h>
+#endif
+#define dprintf(...)
+#ifndef ATTRIBUTE
+#ifdef HAVE_GCC_ATTRIBUTE
+#define ATTRIBUTE(a_) __attribute__(a_)
+#else
+#endif
+#endif
+#define PROXY_IS_ACTIVE(proxy, total_procs) \
+    ((proxy)->segment_list->start_pid <= (total_procs))
+#define FORALL_ACTIVE_PROXIES(proxy, proxy_list)    \
+    for ((proxy) = (proxy_list); (proxy) && (proxy)->active; (proxy) = (proxy)->next)
+#define FORALL_PROXIES(proxy, proxy_list)    \
+    for ((proxy) = (proxy_list); (proxy); (proxy) = (proxy)->next)
+#if defined MANUAL_EXTERN_ENVIRON
+extern char **environ;
+#endif /* MANUAL_EXTERN_ENVIRON */
 /* Status information */
 typedef enum {
     HYD_SUCCESS = 0,
@@ -101,7 +114,6 @@
     HYD_INTERNAL_ERROR
 } HYD_Status;
 /* Proxy type */
 typedef enum {
     HYD_LAUNCH_UNSET,
@@ -114,7 +126,16 @@
     HYD_LAUNCH_PERSISTENT
 } HYD_Launch_mode_t;
+#if defined(HAVE_PUTENV) && defined(NEEDS_PUTENV_DECL)
+extern int putenv(char *string);
+#endif
+#if defined(NEEDS_GETHOSTNAME_DECL)
+int gethostname(char *name, size_t len);
+#endif
+typedef unsigned short HYD_Event_t;
 /* Environment information */
 typedef struct HYD_Env {
     char *env_name;
@@ -141,31 +162,6 @@
     char      *prop;
-#if !defined HAVE_PTHREAD_H
-#error "pthread.h needed"
-#else
-#include <pthread.h>
-#endif
-#define dprintf(...)
-#ifndef ATTRIBUTE
-#ifdef HAVE_GCC_ATTRIBUTE
-#define ATTRIBUTE(a_) __attribute__(a_)
-#else
-#endif
-#endif
-#define PROXY_IS_ACTIVE(proxy, total_procs) \
-    ((proxy)->segment_list->start_pid <= (total_procs))
-#define FORALL_ACTIVE_PROXIES(proxy, proxy_list)    \
-    for ((proxy) = (proxy_list); (proxy) && (proxy)->active; (proxy) = (proxy)->next)
-#define FORALL_PROXIES(proxy, proxy_list)    \
-    for ((proxy) = (proxy_list); (proxy); (proxy) = (proxy)->next)
 /* List of contiguous segments of processes on a proxy */
 struct HYD_Proxy_segment {
     int start_pid;
@@ -222,4 +218,27 @@
     struct HYD_Exec_info *next;
+/* Global user parameters */
+struct HYD_User_global {
+    /* Bootstrap server */
+    char *bootstrap;
+    char *bootstrap_exec;
+    /* Process binding */
+    char *binding;
+    char *bindlib;
+    /* Checkpoint restart */
+    char *ckpointlib;
+    char *ckpoint_prefix;
+    int ckpoint_restart;
+    /* Other random parameters */
+    int enablex;
+    int debug;
+    char *wdir;
+    HYD_Launch_mode_t launch_mode;
+    struct HYD_Env_global global_env;
 #endif /* HYDRA_BASE_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v1.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v1.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v1.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -51,7 +51,7 @@
     tmp[i++] = HYDU_int_to_str(rank);
     tmp[i++] = HYDU_strdup("\ncmd=set debug=");
-    tmp[i++] = HYDU_int_to_str(HYD_handle.debug);
+    tmp[i++] = HYDU_int_to_str(HYD_handle.user_global.debug);
     tmp[i++] = HYDU_strdup("\n");
     tmp[i++] = NULL;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -25,17 +25,17 @@
          * are, we will just wait for more events. */
         out_count = 0;
         err_count = 0;
-        for (i = 0; i < HYD_PMCD_pmi_proxy_params.exec_proc_count; i++) {
-            if (HYD_PMCD_pmi_proxy_params.out[i] != -1)
+        for (i = 0; i < HYD_PMCD_pmi_proxy_params.local.process_count; i++) {
+            if (HYD_PMCD_pmi_proxy_params.downstream.out[i] != -1)
                 out_count++;
-            if (HYD_PMCD_pmi_proxy_params.err[i] != -1)
+            if (HYD_PMCD_pmi_proxy_params.downstream.err[i] != -1)
                 err_count++;
             if (out_count && err_count)
                 break;
-        if (HYD_PMCD_pmi_proxy_params.procs_are_launched) {
+        if (HYD_PMCD_pmi_proxy_params.local.procs_are_launched) {
             if (out_count == 0)
                 close(HYD_PMCD_pmi_proxy_params.upstream.out);
@@ -49,21 +49,21 @@
     do {
-        if (HYD_PMCD_pmi_proxy_params.procs_are_launched == 0)
+        if (HYD_PMCD_pmi_proxy_params.local.procs_are_launched == 0)
             break;
         pid = waitpid(-1, &ret_status, 0);
         /* Find the pid and mark it as complete. */
         if (pid > 0)
-                if (HYD_PMCD_pmi_proxy_params.pid[i] == pid)
-                    HYD_PMCD_pmi_proxy_params.exit_status[i] = ret_status;
+                if (HYD_PMCD_pmi_proxy_params.downstream.pid[i] == pid)
+                    HYD_PMCD_pmi_proxy_params.downstream.exit_status[i] = ret_status;
         /* Check how many more processes are pending */
         count = 0;
-            if (HYD_PMCD_pmi_proxy_params.exit_status[i] == -1) {
+            if (HYD_PMCD_pmi_proxy_params.downstream.exit_status[i] == -1) {
                 count++;
                 break;
@@ -96,20 +96,20 @@
     HYDU_ERR_POP(status, "bad parameters passed to the proxy\n");
     /* Process launching only happens in the runtime case over here */
-    if (HYD_PMCD_pmi_proxy_params.proxy.launch_mode == HYD_LAUNCH_RUNTIME) {
+    if (HYD_PMCD_pmi_proxy_params.user_global.launch_mode == HYD_LAUNCH_RUNTIME) {
         HYD_PMCD_pmi_proxy_params.upstream.out = 1;
         HYD_PMCD_pmi_proxy_params.upstream.err = 2;
         HYD_PMCD_pmi_proxy_params.upstream.in = 0;
         /* Connect back upstream and the socket to a demux engine */
-        status = HYDU_sock_connect(HYD_PMCD_pmi_proxy_params.proxy.server_name,
-                                   HYD_PMCD_pmi_proxy_params.proxy.server_port,
+        status = HYDU_sock_connect(HYD_PMCD_pmi_proxy_params.upstream.server_name,
+                                   HYD_PMCD_pmi_proxy_params.upstream.server_port,
                                    &HYD_PMCD_pmi_proxy_params.upstream.control);
         HYDU_ERR_POP(status, "unable to connect to the main server\n");
         status = HYDU_sock_write(HYD_PMCD_pmi_proxy_params.upstream.control,
-                                 &HYD_PMCD_pmi_proxy_params.proxy.proxy_id,
-                                 sizeof(HYD_PMCD_pmi_proxy_params.proxy.proxy_id));
+                                 &HYD_PMCD_pmi_proxy_params.local.id,
+                                 sizeof(HYD_PMCD_pmi_proxy_params.local.id));
         HYDU_ERR_POP(status, "unable to send the proxy ID to the server\n");
         status = HYD_DMX_register_fd(1, &HYD_PMCD_pmi_proxy_params.upstream.control,
@@ -122,8 +122,8 @@
         /* Send the exit status upstream */
-                                 HYD_PMCD_pmi_proxy_params.exit_status,
-                                 HYD_PMCD_pmi_proxy_params.exec_proc_count * sizeof(int));
+                                 HYD_PMCD_pmi_proxy_params.downstream.exit_status,
+                                 HYD_PMCD_pmi_proxy_params.local.process_count * sizeof(int));
         HYDU_ERR_POP(status, "unable to return exit status upstream\n");
         status = HYD_DMX_deregister_fd(HYD_PMCD_pmi_proxy_params.upstream.control);
@@ -136,7 +136,7 @@
     else {      /* Persistent mode */
         status = HYDU_sock_listen(&listenfd, NULL,
-                                  (uint16_t *) & HYD_PMCD_pmi_proxy_params.proxy.server_port);
+                                  (uint16_t *) & HYD_PMCD_pmi_proxy_params.upstream.server_port);
         HYDU_ERR_POP(status, "unable to listen on socket\n");
         /* Register the listening socket with the demux engine */
@@ -144,7 +144,7 @@
                                      HYD_PMCD_pmi_proxy_control_connect_cb);
         HYDU_ERR_POP(status, "unable to register fd\n");
-        if (HYD_PMCD_pmi_proxy_params.proxy.launch_mode == HYD_LAUNCH_BOOT) {
+        if (HYD_PMCD_pmi_proxy_params.user_global.launch_mode == HYD_LAUNCH_BOOT) {
             /* Spawn a persistent daemon proxy and exit parent proxy */
             status = HYDU_fork_and_exit(-1);
             HYDU_ERR_POP(status, "Error spawning persistent proxy\n");
@@ -159,11 +159,11 @@
             /* If processes had been launched and terminated, find the
              * exit status, return it and cleanup everything. */
                                          sizeof(int));
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-14 11:35:35 UTC (rev 5454)
@@ -12,56 +12,55 @@
 #include "pmi_common.h"
 struct HYD_PMCD_pmi_proxy_params {
-    /* Proxy details */
     struct {
+        int global_core_count;
+        /* PMI */
+        char *pmi_port_str;
+    } system_global; /* Global system parameters */
+    struct {
+        /* Upstream server contact information */
         char *server_name;
         int server_port;
-        int proxy_id;
-        char *bootstrap;
-        int enablex;
-        int debug;
-    } proxy;
-    char *wdir;
-    char *pmi_port_str;
+        int out;
+        int err;
+        int in;
+        int control;
+    } upstream;
-    char *binding;
-    char *bindlib;
+    /* Currently our downstream only consists of actual MPI
+     * processes */
+    struct {
+        int *out;
+        int *err;
+        int in;
-    char *ckpointlib;
+        int *pid;
+        int *exit_status;
+    } downstream;
+    /* Proxy details */
+    struct {
+        int  id;
+        int  core_count;
+        int  process_count;
-    int global_core_count;
-    int proxy_core_count;
-    int exec_proc_count;
+        /* Flag to tell whether the processes are launched */
+        int  procs_are_launched;
-    int procs_are_launched;
+        /* stdin related variables */
+        int stdin_buf_offset;
+        int stdin_buf_count;
+        char stdin_tmp_buf[HYD_TMPBUF_SIZE];
+    } local;
     /* Process segmentation information for this proxy */
     struct HYD_Proxy_segment *segment_list;
     struct HYD_Proxy_exec *exec_list;
-    struct {
-        int out;
-        int err;
-        int in;
-        int control;
-    } upstream;
-    int *pid;
-    int *out;
-    int *err;
-    int *exit_status;
-    int in;
-    int stdin_buf_offset;
-    int stdin_buf_count;
-    char stdin_tmp_buf[HYD_TMPBUF_SIZE];
 extern struct HYD_PMCD_pmi_proxy_params HYD_PMCD_pmi_proxy_params;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -135,9 +135,9 @@
         status = HYD_DMX_deregister_fd(fd);
         HYDU_ERR_POP(status, "unable to deregister fd\n");
-            if (HYD_PMCD_pmi_proxy_params.out[i] == fd)
-                HYD_PMCD_pmi_proxy_params.out[i] = -1;
+            if (HYD_PMCD_pmi_proxy_params.downstream.out[i] == fd)
+                HYD_PMCD_pmi_proxy_params.downstream.out[i] = -1;
         close(fd);
@@ -166,9 +166,9 @@
-            if (HYD_PMCD_pmi_proxy_params.err[i] == fd)
-                HYD_PMCD_pmi_proxy_params.err[i] = -1;
+            if (HYD_PMCD_pmi_proxy_params.downstream.err[i] == fd)
+                HYD_PMCD_pmi_proxy_params.downstream.err[i] = -1;
         close(fd);
@@ -189,11 +189,11 @@
     HYDU_FUNC_ENTER();
-    status = HYDU_sock_stdin_cb(HYD_PMCD_pmi_proxy_params.in, events,
+    status = HYDU_sock_stdin_cb(HYD_PMCD_pmi_proxy_params.downstream.in, events,
                                 HYD_PMCD_pmi_proxy_params.upstream.in,
-                                HYD_PMCD_pmi_proxy_params.stdin_tmp_buf,
-                                &HYD_PMCD_pmi_proxy_params.stdin_buf_count,
-                                &HYD_PMCD_pmi_proxy_params.stdin_buf_offset, &closed);
+                                HYD_PMCD_pmi_proxy_params.local.stdin_tmp_buf,
+                                &HYD_PMCD_pmi_proxy_params.local.stdin_buf_count,
+                                &HYD_PMCD_pmi_proxy_params.local.stdin_buf_offset, &closed);
     HYDU_ERR_POP(status, "stdin callback error\n");
     if (closed) {
@@ -202,8 +202,8 @@
         close(HYD_PMCD_pmi_proxy_params.upstream.in);
-        close(HYD_PMCD_pmi_proxy_params.in);
-        HYD_PMCD_pmi_proxy_params.in = -1;
+        close(HYD_PMCD_pmi_proxy_params.downstream.in);
+        HYD_PMCD_pmi_proxy_params.downstream.in = -1;
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -15,34 +15,35 @@
     HYD_Status status = HYD_SUCCESS;
-    HYD_PMCD_pmi_proxy_params.proxy.server_name = NULL;
-    HYD_PMCD_pmi_proxy_params.proxy.server_port = -1;
-    HYD_PMCD_pmi_proxy_params.proxy.launch_mode = HYD_LAUNCH_UNSET;
-    HYD_PMCD_pmi_proxy_params.proxy.proxy_id = -1;
-    HYD_PMCD_pmi_proxy_params.proxy.bootstrap = NULL;
-    HYD_PMCD_pmi_proxy_params.proxy.bootstrap_exec = NULL;
-    HYD_PMCD_pmi_proxy_params.proxy.debug = 0;
-    HYD_PMCD_pmi_proxy_params.proxy.enablex = -1;
+    HYD_PMCD_pmi_proxy_params.user_global.bootstrap = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.launch_mode = HYD_LAUNCH_UNSET;
-    HYD_PMCD_pmi_proxy_params.wdir = NULL;
-    HYD_PMCD_pmi_proxy_params.pmi_port_str = NULL;
-    HYD_PMCD_pmi_proxy_params.binding = NULL;
-    HYD_PMCD_pmi_proxy_params.bindlib = NULL;
+    HYD_PMCD_pmi_proxy_params.upstream.server_name = NULL;
+    HYD_PMCD_pmi_proxy_params.upstream.server_port = -1;
+    HYD_PMCD_pmi_proxy_params.local.id = -1;
+    HYD_PMCD_pmi_proxy_params.user_global.debug = 0;
+    HYD_PMCD_pmi_proxy_params.user_global.enablex = -1;
-    HYD_PMCD_pmi_proxy_params.ckpointlib = NULL;
-    HYD_PMCD_pmi_proxy_params.ckpoint_prefix = NULL;
-    HYD_PMCD_pmi_proxy_params.ckpoint_restart = 0;
+    HYD_PMCD_pmi_proxy_params.user_global.wdir = NULL;
+    HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.binding = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.bindlib = NULL;
-    HYD_PMCD_pmi_proxy_params.global_env.system = NULL;
-    HYD_PMCD_pmi_proxy_params.global_env.user = NULL;
-    HYD_PMCD_pmi_proxy_params.global_env.inherited = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.ckpointlib = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.ckpoint_restart = 0;
-    HYD_PMCD_pmi_proxy_params.global_core_count = 0;
-    HYD_PMCD_pmi_proxy_params.proxy_core_count = 0;
-    HYD_PMCD_pmi_proxy_params.exec_proc_count = 0;
+    HYD_PMCD_pmi_proxy_params.user_global.global_env.system = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.global_env.user = NULL;
+    HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited = NULL;
-    HYD_PMCD_pmi_proxy_params.procs_are_launched = 0;
+    HYD_PMCD_pmi_proxy_params.system_global.global_core_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.core_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.process_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.procs_are_launched = 0;
     HYD_PMCD_pmi_proxy_params.segment_list = NULL;
     HYD_PMCD_pmi_proxy_params.exec_list = NULL;
@@ -51,15 +52,15 @@
     HYD_PMCD_pmi_proxy_params.upstream.in = -1;
     HYD_PMCD_pmi_proxy_params.upstream.control = -1;
-    HYD_PMCD_pmi_proxy_params.pid = NULL;
-    HYD_PMCD_pmi_proxy_params.out = NULL;
-    HYD_PMCD_pmi_proxy_params.err = NULL;
-    HYD_PMCD_pmi_proxy_params.exit_status = NULL;
+    HYD_PMCD_pmi_proxy_params.downstream.out = NULL;
+    HYD_PMCD_pmi_proxy_params.downstream.err = NULL;
+    HYD_PMCD_pmi_proxy_params.downstream.pid = NULL;
+    HYD_PMCD_pmi_proxy_params.downstream.exit_status = NULL;
-    HYD_PMCD_pmi_proxy_params.stdin_buf_offset = 0;
-    HYD_PMCD_pmi_proxy_params.stdin_buf_count = 0;
-    HYD_PMCD_pmi_proxy_params.stdin_tmp_buf[0] = '\0';
+    HYD_PMCD_pmi_proxy_params.local.stdin_buf_offset = 0;
+    HYD_PMCD_pmi_proxy_params.local.stdin_buf_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.stdin_tmp_buf[0] = '\0';
     return status;
@@ -83,7 +84,7 @@
         /* Working directory */
         if (!strcmp(*argv, "--wdir")) {
             argv++;
-            HYD_PMCD_pmi_proxy_params.wdir = HYDU_strdup(*argv);
+            HYD_PMCD_pmi_proxy_params.user_global.wdir = HYDU_strdup(*argv);
             continue;
@@ -91,9 +92,9 @@
         if (!strcmp(*argv, "--pmi-port-str")) {
             argv++;
             if (!strcmp(*argv, "HYDRA_NULL"))
             else
-                HYD_PMCD_pmi_proxy_params.pmi_port_str = HYDU_strdup(*argv);
+                HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str = HYDU_strdup(*argv);
             continue;
@@ -101,9 +102,9 @@
         if (!strcmp(*argv, "--binding")) {
             argv++;
             else
-                HYD_PMCD_pmi_proxy_params.binding = HYDU_strdup(*argv);
+                HYD_PMCD_pmi_proxy_params.user_global.binding = HYDU_strdup(*argv);
             continue;
@@ -111,28 +112,28 @@
         /* Binding library */
         if (!strcmp(*argv, "--bindlib")) {
             argv++;
-            HYD_PMCD_pmi_proxy_params.bindlib = HYDU_strdup(*argv);
+            HYD_PMCD_pmi_proxy_params.user_global.bindlib = HYDU_strdup(*argv);
             continue;
         /* Checkpointing library */
         if (!strcmp(*argv, "--ckpointlib")) {
             argv++;
-            HYD_PMCD_pmi_proxy_params.ckpointlib = HYDU_strdup(*argv);
+            HYD_PMCD_pmi_proxy_params.user_global.ckpointlib = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--ckpoint-prefix")) {
             argv++;
             else
-                HYD_PMCD_pmi_proxy_params.ckpoint_prefix = HYDU_strdup(*argv);
+                HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--ckpoint-restart")) {
-            HYD_PMCD_pmi_proxy_params.ckpoint_restart = 1;
+            HYD_PMCD_pmi_proxy_params.user_global.ckpoint_restart = 1;
             continue;
@@ -161,13 +162,13 @@
                 if (!strcmp(argtype, "--global-inherited-env"))
                     HYDU_append_env_to_list(*env,
-                                            &HYD_PMCD_pmi_proxy_params.global_env.inherited);
+                                            &HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited);
                 else if (!strcmp(argtype, "--global-system-env"))
-                                            &HYD_PMCD_pmi_proxy_params.global_env.system);
+                                            &HYD_PMCD_pmi_proxy_params.user_global.global_env.system);
                 else if (!strcmp(argtype, "--global-user-env"))
-                                            &HYD_PMCD_pmi_proxy_params.global_env.user);
+                                            &HYD_PMCD_pmi_proxy_params.user_global.global_env.user);
                 HYDU_FREE(env);
@@ -178,16 +179,16 @@
         if (!strcmp(*argv, "--genv-prop")) {
             argv++;
             if (strcmp(*argv, "HYDRA_NULL"))
-                HYD_PMCD_pmi_proxy_params.global_env.prop = HYDU_strdup(*argv);
+                HYD_PMCD_pmi_proxy_params.user_global.global_env.prop = HYDU_strdup(*argv);
             else
-                HYD_PMCD_pmi_proxy_params.global_env.prop = NULL;
+                HYD_PMCD_pmi_proxy_params.user_global.global_env.prop = NULL;
             continue;
         /* One-pass Count */
         if (!strcmp(*argv, "--global-core-count")) {
             argv++;
-            HYD_PMCD_pmi_proxy_params.global_core_count = atoi(*argv);
+            HYD_PMCD_pmi_proxy_params.system_global.global_core_count = atoi(*argv);
             continue;
@@ -319,60 +320,60 @@
     while (++argv && *argv) {
         if (!strcmp(*argv, "--launch-mode")) {
             ++argv;
                 (HYD_Launch_mode_t) (unsigned int) atoi(*argv);
             continue;
         if (!strcmp(*argv, "--proxy-port")) {
             ++argv;
-                HYD_PMCD_pmi_proxy_params.proxy.server_name = HYDU_strdup(strtok(*argv, ":"));
-                HYD_PMCD_pmi_proxy_params.proxy.server_port = atoi(strtok(NULL, ":"));
+                HYD_PMCD_pmi_proxy_params.upstream.server_name = HYDU_strdup(strtok(*argv, ":"));
+                HYD_PMCD_pmi_proxy_params.upstream.server_port = atoi(strtok(NULL, ":"));
             else {
-                HYD_PMCD_pmi_proxy_params.proxy.server_port = atoi(*argv);
+                HYD_PMCD_pmi_proxy_params.upstream.server_port = atoi(*argv);
             continue;
         if (!strcmp(*argv, "--proxy-id")) {
             ++argv;
-            HYD_PMCD_pmi_proxy_params.proxy.proxy_id = atoi(*argv);
+            HYD_PMCD_pmi_proxy_params.local.id = atoi(*argv);
             continue;
         if (!strcmp(*argv, "--debug")) {
-            HYD_PMCD_pmi_proxy_params.proxy.debug = 1;
+            HYD_PMCD_pmi_proxy_params.user_global.debug = 1;
             continue;
         if (!strcmp(*argv, "--enable-x")) {
-            HYD_PMCD_pmi_proxy_params.proxy.enablex = 1;
+            HYD_PMCD_pmi_proxy_params.user_global.enablex = 1;
             continue;
         if (!strcmp(*argv, "--disable-x")) {
-            HYD_PMCD_pmi_proxy_params.proxy.enablex = 0;
+            HYD_PMCD_pmi_proxy_params.user_global.enablex = 0;
             continue;
         if (!strcmp(*argv, "--bootstrap")) {
             ++argv;
-            HYD_PMCD_pmi_proxy_params.proxy.bootstrap = HYDU_strdup(*argv);
+            HYD_PMCD_pmi_proxy_params.user_global.bootstrap = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--bootstrap-exec")) {
             ++argv;
-            HYD_PMCD_pmi_proxy_params.proxy.bootstrap_exec = HYDU_strdup(*argv);
+            HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec = HYDU_strdup(*argv);
             continue;
-    status = HYD_BSCI_init(HYD_PMCD_pmi_proxy_params.proxy.bootstrap,
-                           HYD_PMCD_pmi_proxy_params.proxy.bootstrap_exec,
-                           HYD_PMCD_pmi_proxy_params.proxy.enablex,
-                           HYD_PMCD_pmi_proxy_params.proxy.debug);
+    status = HYD_BSCI_init(HYD_PMCD_pmi_proxy_params.user_global.bootstrap,
+                           HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec,
+                           HYD_PMCD_pmi_proxy_params.user_global.enablex,
+                           HYD_PMCD_pmi_proxy_params.user_global.debug);
     HYDU_ERR_POP(status, "proxy unable to initialize bootstrap\n");
-    if (HYD_PMCD_pmi_proxy_params.proxy.proxy_id == -1) {
+    if (HYD_PMCD_pmi_proxy_params.local.id == -1) {
         /* We didn't get a proxy ID during launch; query the
          * bootstrap server for it. */
-        status = HYD_BSCI_query_proxy_id(&HYD_PMCD_pmi_proxy_params.proxy.proxy_id);
+        status = HYD_BSCI_query_proxy_id(&HYD_PMCD_pmi_proxy_params.local.id);
         HYDU_ERR_POP(status, "unable to query bootstrap server for proxy ID\n");
@@ -393,41 +394,41 @@
     HYDU_FUNC_ENTER();
-    if (HYD_PMCD_pmi_proxy_params.proxy.server_name)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.proxy.server_name);
+    if (HYD_PMCD_pmi_proxy_params.upstream.server_name)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.upstream.server_name);
-    if (HYD_PMCD_pmi_proxy_params.proxy.bootstrap)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.proxy.bootstrap);
+    if (HYD_PMCD_pmi_proxy_params.user_global.bootstrap)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.bootstrap);
-    if (HYD_PMCD_pmi_proxy_params.proxy.bootstrap_exec)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.proxy.bootstrap_exec);
+    if (HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec);
-    if (HYD_PMCD_pmi_proxy_params.wdir)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.wdir);
+    if (HYD_PMCD_pmi_proxy_params.user_global.wdir)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.wdir);
-    if (HYD_PMCD_pmi_proxy_params.pmi_port_str)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.pmi_port_str);
+    if (HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str);
-    if (HYD_PMCD_pmi_proxy_params.binding)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.binding);
+    if (HYD_PMCD_pmi_proxy_params.user_global.binding)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.binding);
-    if (HYD_PMCD_pmi_proxy_params.bindlib)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.bindlib);
+    if (HYD_PMCD_pmi_proxy_params.user_global.bindlib)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.bindlib);
-    if (HYD_PMCD_pmi_proxy_params.ckpointlib)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.ckpointlib);
+    if (HYD_PMCD_pmi_proxy_params.user_global.ckpointlib)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.ckpointlib);
-    if (HYD_PMCD_pmi_proxy_params.ckpoint_prefix)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.ckpoint_prefix);
+    if (HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix);
-    if (HYD_PMCD_pmi_proxy_params.global_env.system)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.system);
+    if (HYD_PMCD_pmi_proxy_params.user_global.global_env.system)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.user_global.global_env.system);
-    if (HYD_PMCD_pmi_proxy_params.global_env.user)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.user);
+    if (HYD_PMCD_pmi_proxy_params.user_global.global_env.user)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.user_global.global_env.user);
-    if (HYD_PMCD_pmi_proxy_params.global_env.inherited)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.inherited);
+    if (HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited);
     if (HYD_PMCD_pmi_proxy_params.segment_list) {
         segment = HYD_PMCD_pmi_proxy_params.segment_list;
@@ -450,17 +451,17 @@
-    if (HYD_PMCD_pmi_proxy_params.pid)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.pid);
+    if (HYD_PMCD_pmi_proxy_params.downstream.pid)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.downstream.pid);
-    if (HYD_PMCD_pmi_proxy_params.out)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.out);
+    if (HYD_PMCD_pmi_proxy_params.downstream.out)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.downstream.out);
-    if (HYD_PMCD_pmi_proxy_params.err)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.err);
+    if (HYD_PMCD_pmi_proxy_params.downstream.err)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.downstream.err);
-    if (HYD_PMCD_pmi_proxy_params.exit_status)
-        HYDU_FREE(HYD_PMCD_pmi_proxy_params.exit_status);
+    if (HYD_PMCD_pmi_proxy_params.downstream.exit_status)
+        HYDU_FREE(HYD_PMCD_pmi_proxy_params.downstream.exit_status);
     /* Reinitialize all params to set everything to "NULL" or
      * equivalent. */
@@ -536,54 +537,54 @@
     HYDU_FUNC_ENTER();
     for (segment = HYD_PMCD_pmi_proxy_params.segment_list; segment; segment = segment->next)
-        HYD_PMCD_pmi_proxy_params.proxy_core_count += segment->proc_count;
+        HYD_PMCD_pmi_proxy_params.local.core_count += segment->proc_count;
     for (exec = HYD_PMCD_pmi_proxy_params.exec_list; exec; exec = exec->next)
-        HYD_PMCD_pmi_proxy_params.exec_proc_count += exec->proc_count;
+        HYD_PMCD_pmi_proxy_params.local.process_count += exec->proc_count;
-    HYDU_MALLOC(pmi_ids, int *, HYD_PMCD_pmi_proxy_params.exec_proc_count * sizeof(int), status);
+    HYDU_MALLOC(pmi_ids, int *, HYD_PMCD_pmi_proxy_params.local.process_count * sizeof(int), status);
         pmi_ids[i] = HYDU_local_to_global_id(i,
-                                             HYD_PMCD_pmi_proxy_params.proxy_core_count,
+                                             HYD_PMCD_pmi_proxy_params.local.core_count,
                                              HYD_PMCD_pmi_proxy_params.segment_list,
-                                             HYD_PMCD_pmi_proxy_params.global_core_count);
+                                             HYD_PMCD_pmi_proxy_params.system_global.global_core_count);
-    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.out, int *,
-                HYD_PMCD_pmi_proxy_params.exec_proc_count * sizeof(int), status);
-    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.err, int *,
-    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.pid, int *,
-    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.exit_status, int *,
+    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.downstream.out, int *,
+                HYD_PMCD_pmi_proxy_params.local.process_count * sizeof(int), status);
+    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.downstream.err, int *,
+    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.downstream.pid, int *,
+    HYDU_MALLOC(HYD_PMCD_pmi_proxy_params.downstream.exit_status, int *,
     /* Initialize the exit status */
-        HYD_PMCD_pmi_proxy_params.exit_status[i] = -1;
+        HYD_PMCD_pmi_proxy_params.downstream.exit_status[i] = -1;
-    status = HYDU_bind_init(HYD_PMCD_pmi_proxy_params.binding,
-                            HYD_PMCD_pmi_proxy_params.bindlib);
+    status = HYDU_bind_init(HYD_PMCD_pmi_proxy_params.user_global.binding,
+                            HYD_PMCD_pmi_proxy_params.user_global.bindlib);
     HYDU_ERR_POP(status, "unable to initialize process binding\n");
-    status = HYDU_ckpoint_init(HYD_PMCD_pmi_proxy_params.ckpointlib,
-                               HYD_PMCD_pmi_proxy_params.ckpoint_prefix);
+    status = HYDU_ckpoint_init(HYD_PMCD_pmi_proxy_params.user_global.ckpointlib,
+                               HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix);
     HYDU_ERR_POP(status, "unable to initialize checkpointing\n");
-    if (HYD_PMCD_pmi_proxy_params.ckpoint_restart) {
-        status = HYDU_env_create(&env, "PMI_PORT", HYD_PMCD_pmi_proxy_params.pmi_port_str);
+    if (HYD_PMCD_pmi_proxy_params.user_global.ckpoint_restart) {
+        status = HYDU_env_create(&env, "PMI_PORT", HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str);
         HYDU_ERR_POP(status, "unable to create env\n");
         /* Restart the proxy.  Specify stdin fd only if pmi_id 0 is in this proxy. */
-        status = HYDU_ckpoint_restart(env, HYD_PMCD_pmi_proxy_params.exec_proc_count,
+        status = HYDU_ckpoint_restart(env, HYD_PMCD_pmi_proxy_params.local.process_count,
                                       pmi_ids,
-                                      pmi_ids[0] ? NULL : &HYD_PMCD_pmi_proxy_params.in,
-                                      HYD_PMCD_pmi_proxy_params.out,
-                                      HYD_PMCD_pmi_proxy_params.err);
+                                      pmi_ids[0] ? NULL :
+                                      &HYD_PMCD_pmi_proxy_params.downstream.in,
+                                      HYD_PMCD_pmi_proxy_params.downstream.out,
+                                      HYD_PMCD_pmi_proxy_params.downstream.err);
         HYDU_ERR_POP(status, "checkpoint restart failure\n");
         goto fn_spawn_complete;
@@ -602,24 +603,24 @@
         /* Global inherited env */
         if ((exec->env_prop && !strcmp(exec->env_prop, "all")) ||
-            (!exec->env_prop && !strcmp(HYD_PMCD_pmi_proxy_params.global_env.prop, "all"))) {
-            for (env = HYD_PMCD_pmi_proxy_params.global_env.inherited; env; env = env->next) {
+            (!exec->env_prop && !strcmp(HYD_PMCD_pmi_proxy_params.user_global.global_env.prop, "all"))) {
+            for (env = HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited; env; env = env->next) {
                 status = HYDU_append_env_to_list(*env, &prop_env);
                 HYDU_ERR_POP(status, "unable to add env to list\n");
         else if ((exec->env_prop && !strncmp(exec->env_prop, "list", strlen("list"))) ||
                  (!exec->env_prop &&
-                  !strncmp(HYD_PMCD_pmi_proxy_params.global_env.prop, "list",
+                  !strncmp(HYD_PMCD_pmi_proxy_params.user_global.global_env.prop, "list",
                            strlen("list")))) {
             if (exec->env_prop)
                 list = HYDU_strdup(exec->env_prop + strlen("list:"));
             else
-                list = HYDU_strdup(HYD_PMCD_pmi_proxy_params.global_env.prop + strlen("list:"));
+                list = HYDU_strdup(HYD_PMCD_pmi_proxy_params.user_global.global_env.prop + strlen("list:"));
             envstr = strtok(list, ",");
             while (envstr) {
-                env = HYDU_env_lookup(envstr, HYD_PMCD_pmi_proxy_params.global_env.inherited);
+                env = HYDU_env_lookup(envstr, HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited);
                 if (env) {
@@ -629,7 +630,7 @@
         /* Next priority order is the global user env */
-        for (env = HYD_PMCD_pmi_proxy_params.global_env.user; env; env = env->next) {
+        for (env = HYD_PMCD_pmi_proxy_params.user_global.global_env.user; env; env = env->next) {
@@ -641,15 +642,16 @@
         /* Highest priority is the system env */
-        for (env = HYD_PMCD_pmi_proxy_params.global_env.system; env; env = env->next) {
+        for (env = HYD_PMCD_pmi_proxy_params.user_global.global_env.system; env; env = env->next) {
         /* Set the PMI port string to connect to. We currently just
          * use the global PMI port. */
-        if (HYD_PMCD_pmi_proxy_params.pmi_port_str) {
+        if (HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str) {
+                                     HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str);
@@ -658,11 +660,11 @@
         for (i = 0; i < exec->proc_count; i++) {
             pmi_id = HYDU_local_to_global_id(process_id,
                 str = HYDU_int_to_str(pmi_id);
                 status = HYDU_env_create(&env, "PMI_ID", str);
@@ -671,7 +673,7 @@
-            if (chdir(HYD_PMCD_pmi_proxy_params.wdir) < 0)
+            if (chdir(HYD_PMCD_pmi_proxy_params.user_global.wdir) < 0)
                 HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR,
                                      "unable to change wdir (%s)\n", HYDU_strerror(errno));
@@ -682,27 +684,29 @@
             core = HYDU_bind_get_core_id(process_id);
             if (pmi_id == 0) {
                 status = HYDU_create_process(client_args, prop_env,
-                                             &HYD_PMCD_pmi_proxy_params.in,
-                                             &HYD_PMCD_pmi_proxy_params.out[process_id],
-                                             &HYD_PMCD_pmi_proxy_params.err[process_id],
-                                             &HYD_PMCD_pmi_proxy_params.pid[process_id], core);
+                                             &HYD_PMCD_pmi_proxy_params.downstream.out[process_id],
+                                             &HYD_PMCD_pmi_proxy_params.downstream.err[process_id],
+                                             &HYD_PMCD_pmi_proxy_params.downstream.pid[process_id],
+                                             core);
                 status = HYDU_sock_set_nonblock(HYD_PMCD_pmi_proxy_params.upstream.in);
                 HYDU_ERR_POP(status, "unable to set upstream stdin fd to nonblocking\n");
-                stdin_fd = HYD_PMCD_pmi_proxy_params.in;
+                stdin_fd = HYD_PMCD_pmi_proxy_params.downstream.in;
                 status = HYD_DMX_register_fd(1, &stdin_fd, HYD_STDIN, NULL,
                                              HYD_PMCD_pmi_proxy_stdin_cb);
             else {
                 status = HYDU_create_process(client_args, prop_env, NULL,
+                                             core);
             HYDU_ERR_POP(status, "create process returned error\n");
@@ -715,18 +719,18 @@
 fn_spawn_complete:
     /* Everything is spawned, register the required FDs  */
-    status = HYD_DMX_register_fd(HYD_PMCD_pmi_proxy_params.exec_proc_count,
+    status = HYD_DMX_register_fd(HYD_PMCD_pmi_proxy_params.local.process_count,
                                  HYD_STDOUT, NULL, HYD_PMCD_pmi_proxy_stdout_cb);
-                                 HYD_PMCD_pmi_proxy_params.err,
+                                 HYD_PMCD_pmi_proxy_params.downstream.err,
                                  HYD_STDOUT, NULL, HYD_PMCD_pmi_proxy_stderr_cb);
     /* Indicate that the processes have been launched */
-    HYD_PMCD_pmi_proxy_params.procs_are_launched = 1;
+    HYD_PMCD_pmi_proxy_params.local.procs_are_launched = 1;
   fn_exit:
     HYDU_FUNC_EXIT();
@@ -744,10 +748,10 @@
     HYDU_FUNC_ENTER();
     /* Send the kill signal to all processes */
-        if (HYD_PMCD_pmi_proxy_params.pid[i] != -1) {
-            kill(HYD_PMCD_pmi_proxy_params.pid[i], SIGTERM);
-            kill(HYD_PMCD_pmi_proxy_params.pid[i], SIGKILL);
+        if (HYD_PMCD_pmi_proxy_params.downstream.pid[i] != -1) {
+            kill(HYD_PMCD_pmi_proxy_params.downstream.pid[i], SIGTERM);
+            kill(HYD_PMCD_pmi_proxy_params.downstream.pid[i], SIGKILL);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_finalize.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_finalize.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_finalize.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -20,7 +20,7 @@
     status = HYD_PMCD_pmi_finalize();
     HYDU_ERR_POP(status, "unable to finalize process manager utils\n");
-    if (HYD_handle.launch_mode == HYD_LAUNCH_RUNTIME) {
+    if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_RUNTIME) {
         status = HYD_BSCI_finalize();
         HYDU_ERR_POP(status, "unable to finalize bootstrap server\n");
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -169,20 +169,20 @@
     else
         proxy_args[arg++] = HYDU_int_to_str(HYD_handle.proxy_port);
-    if (HYD_handle.debug)
+    if (HYD_handle.user_global.debug)
         proxy_args[arg++] = HYDU_strdup("--debug");
-    if (HYD_handle.enablex != -1) {
+    if (HYD_handle.user_global.enablex != -1) {
         proxy_args[arg++] = HYDU_strdup("--enable-x");
-        proxy_args[arg++] = HYDU_int_to_str(HYD_handle.enablex);
+        proxy_args[arg++] = HYDU_int_to_str(HYD_handle.user_global.enablex);
     proxy_args[arg++] = HYDU_strdup("--bootstrap");
-    proxy_args[arg++] = HYDU_strdup(HYD_handle.bootstrap);
+    proxy_args[arg++] = HYDU_strdup(HYD_handle.user_global.bootstrap);
-    if (HYD_handle.bootstrap_exec) {
+    if (HYD_handle.user_global.bootstrap_exec) {
         proxy_args[arg++] = HYDU_strdup("--bootstrap-exec");
-        proxy_args[arg++] = HYDU_strdup(HYD_handle.bootstrap_exec);
+        proxy_args[arg++] = HYDU_strdup(HYD_handle.user_global.bootstrap_exec);
     proxy_args[arg++] = NULL;
@@ -209,11 +209,11 @@
     /* Create the arguments list for each proxy */
     process_id = 0;
     FORALL_ACTIVE_PROXIES(proxy, HYD_handle.proxy_list) {
-        for (inherited_env_count = 0, env = HYD_handle.global_env.inherited; env;
+        for (inherited_env_count = 0, env = HYD_handle.user_global.global_env.inherited; env;
              env = env->next, inherited_env_count++);
-        for (user_env_count = 0, env = HYD_handle.global_env.user; env;
+        for (user_env_count = 0, env = HYD_handle.user_global.global_env.user; env;
              env = env->next, user_env_count++);
-        for (system_env_count = 0, env = HYD_handle.global_env.system; env;
+        for (system_env_count = 0, env = HYD_handle.user_global.global_env.system; env;
              env = env->next, system_env_count++);
         for (segment_count = 0, segment = proxy->segment_list; segment;
@@ -244,7 +244,7 @@
         proxy->exec_args[arg++] = HYDU_int_to_str(HYD_handle.global_core_count);
         proxy->exec_args[arg++] = HYDU_strdup("--wdir");
-        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.wdir);
+        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.wdir);
         proxy->exec_args[arg++] = HYDU_strdup("--pmi-port-str");
         if (HYD_handle.pm_env)
@@ -253,31 +253,31 @@
             proxy->exec_args[arg++] = HYDU_strdup("HYDRA_NULL");
         proxy->exec_args[arg++] = HYDU_strdup("--binding");
-        if (HYD_handle.binding)
-            proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.binding);
+        if (HYD_handle.user_global.binding)
+            proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.binding);
         else
         proxy->exec_args[arg++] = HYDU_strdup("--bindlib");
-        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.bindlib);
+        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.bindlib);
         proxy->exec_args[arg++] = HYDU_strdup("--ckpointlib");
-        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.ckpointlib);
+        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.ckpointlib);
         proxy->exec_args[arg++] = HYDU_strdup("--ckpoint-prefix");
-        if (HYD_handle.ckpoint_prefix)
-            proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.ckpoint_prefix);
+        if (HYD_handle.user_global.ckpoint_prefix)
+            proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.ckpoint_prefix);
         else
-        if (HYD_handle.ckpoint_restart)
+        if (HYD_handle.user_global.ckpoint_restart)
             proxy->exec_args[arg++] = HYDU_strdup("--ckpoint-restart");
         proxy->exec_args[arg++] = HYDU_strdup("--global-inherited-env");
-        for (i = 0, env = HYD_handle.global_env.inherited; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.user_global.global_env.inherited; env; env = env->next, i++);
         proxy->exec_args[arg++] = HYDU_int_to_str(i);
-        for (env = HYD_handle.global_env.inherited; env; env = env->next) {
+        for (env = HYD_handle.user_global.global_env.inherited; env; env = env->next) {
             status = HYDU_env_to_str(env, &proxy->exec_args[arg++]);
             HYDU_ERR_POP(status, "error converting env to string\n");
@@ -285,10 +285,10 @@
         arg = HYDU_strlist_lastidx(proxy->exec_args);
         proxy->exec_args[arg++] = HYDU_strdup("--global-user-env");
-        for (i = 0, env = HYD_handle.global_env.user; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.user_global.global_env.user; env; env = env->next, i++);
-        for (env = HYD_handle.global_env.user; env; env = env->next) {
+        for (env = HYD_handle.user_global.global_env.user; env; env = env->next) {
@@ -296,10 +296,10 @@
         proxy->exec_args[arg++] = HYDU_strdup("--global-system-env");
-        for (i = 0, env = HYD_handle.global_env.system; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.user_global.global_env.system; env; env = env->next, i++);
-        for (env = HYD_handle.global_env.system; env; env = env->next) {
+        for (env = HYD_handle.user_global.global_env.system; env; env = env->next) {
@@ -307,7 +307,7 @@
         proxy->exec_args[arg++] = HYDU_strdup("--genv-prop");
-        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.global_env.prop);
+        proxy->exec_args[arg++] = HYDU_strdup(HYD_handle.user_global.global_env.prop);
         proxy->exec_args[arg++] = NULL;
         /* Pass the segment information */
@@ -352,7 +352,7 @@
             process_id += exec->proc_count;
-        if (HYD_handle.debug) {
+        if (HYD_handle.user_global.debug) {
             printf("Arguments being passed to proxy %d:\n", proxy_count++);
             HYDU_print_strlist(proxy->exec_args);
             printf("\n");
@@ -385,20 +385,20 @@
     /* Initialize PMI */
     status = create_and_listen_portstr(HYD_PMCD_pmi_connect_cb, &pmi_port_str);
     HYDU_ERR_POP(status, "unable to create PMI port\n");
         HYDU_dump(stdout, "Got a PMI port string of %s\n", pmi_port_str);
     status = HYD_PMCD_pmi_init();
     HYDU_ERR_POP(status, "unable to create process group\n");
         status = create_and_listen_portstr(HYD_PMCD_pmi_serv_control_connect_cb,
                                            &proxy_port_str);
             HYDU_dump(stdout, "Got a proxy port string of %s\n", proxy_port_str);
-        status = fill_in_proxy_args(HYD_handle.launch_mode, proxy_args);
+        status = fill_in_proxy_args(HYD_handle.user_global.launch_mode, proxy_args);
         HYDU_ERR_POP(status, "unable to fill in proxy arguments\n");
         status = fill_in_exec_args();
@@ -407,15 +407,15 @@
         status = HYD_BSCI_launch_procs(proxy_args, "--proxy-id", HYD_handle.proxy_list);
         HYDU_ERR_POP(status, "bootstrap server cannot launch processes\n");
-    else if (HYD_handle.launch_mode == HYD_LAUNCH_BOOT ||
-             HYD_handle.launch_mode == HYD_LAUNCH_BOOT_FOREGROUND) {
+    else if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_BOOT ||
+             HYD_handle.user_global.launch_mode == HYD_LAUNCH_BOOT_FOREGROUND) {
-    else if (HYD_handle.launch_mode == HYD_LAUNCH_SHUTDOWN) {
+    else if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_SHUTDOWN) {
             status = HYDU_sock_connect(proxy->hostname, HYD_handle.proxy_port, &fd);
             if (status != HYD_SUCCESS) {
@@ -431,7 +431,7 @@
             close(fd);
-    else if (HYD_handle.launch_mode == HYD_LAUNCH_PERSISTENT) {
+    else if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_PERSISTENT) {
@@ -497,8 +497,8 @@
     HYDU_FUNC_ENTER();
-    if ((HYD_handle.launch_mode == HYD_LAUNCH_BOOT) ||
-        (HYD_handle.launch_mode == HYD_LAUNCH_SHUTDOWN)) {
+    if ((HYD_handle.user_global.launch_mode == HYD_LAUNCH_BOOT) ||
+        (HYD_handle.user_global.launch_mode == HYD_LAUNCH_SHUTDOWN)) {
     else {
Modified: mpich2/trunk/src/pm/hydra/rmk/src/rmki_init.c.in
--- mpich2/trunk/src/pm/hydra/rmk/src/rmki_init.c.in	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/rmk/src/rmki_init.c.in	2009-10-14 11:35:35 UTC (rev 5454)
@@ -39,8 +39,10 @@
     if (HYD_RMKI_fns.query_node_list == NULL)
         HYD_RMKI_fns.query_node_list = HYD_RMKU_query_node_list;
-    status = HYD_BSCI_init(HYD_handle.bootstrap, HYD_handle.bootstrap_exec, HYD_handle.enablex,
-                           HYD_handle.debug);
+    status = HYD_BSCI_init(HYD_handle.user_global.bootstrap,
+                           HYD_handle.user_global.bootstrap_exec,
+                           HYD_handle.user_global.enablex,
+                           HYD_handle.user_global.debug);
     HYDU_ERR_POP(status, "unable to initialize the bootstrap server\n");
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -12,7 +12,7 @@
 #include "uiu.h"
 #include "demux.h"
-HYD_Handle HYD_handle = { 0 };
+HYD_Handle HYD_handle = { { 0 } };
 static void usage(void)
@@ -161,8 +161,8 @@
      * PERSISTENT modes, only proxys which have an executable are
      * active. In BOOT, BOOT_FOREGROUND and SHUTDOWN modes, all
      * proxys are active. */
-    if (HYD_handle.launch_mode == HYD_LAUNCH_RUNTIME ||
-        HYD_handle.launch_mode == HYD_LAUNCH_PERSISTENT) {
+    if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_RUNTIME ||
+        HYD_handle.user_global.launch_mode == HYD_LAUNCH_PERSISTENT) {
         for (proxy = HYD_handle.proxy_list;
              proxy && (proxy->segment_list->start_pid <= HYD_handle.global_process_count);
              proxy = proxy->next)
@@ -176,7 +176,7 @@
     status = HYD_UIU_merge_exec_info_to_proxy();
     HYDU_ERR_POP(status, "unable to merge exec info\n");
         HYD_UIU_print_params();
     HYDU_time_set(&HYD_handle.start, NULL); /* NULL implies right now */
@@ -185,7 +185,7 @@
     else
         timeout = -1;   /* Set a negative timeout */
     HYDU_time_set(&HYD_handle.timeout, &timeout);
         HYDU_dump(stdout, "Timeout set to %d (-1 means infinite)\n", timeout);
     if (HYD_handle.print_rank_map) {
@@ -220,7 +220,7 @@
      * instead of assuming this. For example, it is possible to have a
      * PM implementation that launches separate "new" proxies on a
      * different port and kills the original proxies using them. */
-    if (HYD_handle.launch_mode == HYD_LAUNCH_SHUTDOWN) {
+    if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_SHUTDOWN) {
         /* Call finalize functions for lower layers to cleanup their resources */
         status = HYD_PMCI_finalize();
         HYDU_ERR_POP(status, "process manager error on finalize\n");
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -65,7 +65,7 @@
     status = HYDU_env_create(&env, env_name, env_value);
     HYDU_ERR_POP(status, "unable to create env struct\n");
-    HYDU_append_env_to_list(*env, &HYD_handle.global_env.user);
+    HYDU_append_env_to_list(*env, &HYD_handle.user_global.global_env.user);
   fn_exit:
     return status;
@@ -79,7 +79,7 @@
     int len;
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.global_env.prop,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.global_env.prop,
                         HYD_INTERNAL_ERROR, "duplicate environment setting\n");
     if (**argv && IS_HELP(**argv)) {
@@ -93,8 +93,8 @@
     len = strlen("list:") + strlen(**argv) + 1;
-    HYDU_MALLOC(HYD_handle.global_env.prop, char *, len, status);
-    HYDU_snprintf(HYD_handle.global_env.prop, len, "list:%s", **argv);
+    HYDU_MALLOC(HYD_handle.user_global.global_env.prop, char *, len, status);
+    HYDU_snprintf(HYD_handle.user_global.global_env.prop, len, "list:%s", **argv);
     (*argv)++;
   fn_exit:
@@ -108,7 +108,7 @@
@@ -118,7 +118,7 @@
         HYDU_ERR_SETANDJUMP(status, HYD_GRACEFUL_ABORT, "");
-    HYD_handle.global_env.prop = HYDU_strdup("none");
+    HYD_handle.user_global.global_env.prop = HYDU_strdup("none");
   fn_exit:
     return status;
@@ -131,7 +131,7 @@
@@ -141,7 +141,7 @@
-    HYD_handle.global_env.prop = HYDU_strdup("all");
+    HYD_handle.user_global.global_env.prop = HYDU_strdup("all");
   fn_exit:
     return status;
@@ -277,7 +277,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.wdir, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.wdir, HYD_INTERNAL_ERROR,
                         "duplicate wdir setting\n");
@@ -286,7 +286,7 @@
-    HYD_handle.wdir = HYDU_strdup(**argv);
+    HYD_handle.user_global.wdir = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -465,7 +465,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.bootstrap, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.bootstrap, HYD_INTERNAL_ERROR,
                         "duplicate -bootstrap option\n");
     if (**argv == NULL)
@@ -479,7 +479,7 @@
-    HYD_handle.bootstrap = HYDU_strdup(**argv);
+    HYD_handle.user_global.bootstrap = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -493,7 +493,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.bootstrap_exec, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.bootstrap_exec, HYD_INTERNAL_ERROR,
                         "duplicate -bootstrap-exec option\n");
     if (**argv == NULL)
@@ -507,7 +507,7 @@
-    HYD_handle.bootstrap_exec = HYDU_strdup(**argv);
+    HYD_handle.user_global.bootstrap_exec = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -521,7 +521,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.enablex != -1, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.enablex != -1, HYD_INTERNAL_ERROR,
                         "duplicate -enable-x argument\n");
@@ -532,9 +532,9 @@
     if (!strcmp(arg, "enable-x"))
-        HYD_handle.enablex = 1;
+        HYD_handle.user_global.enablex = 1;
     else
-        HYD_handle.enablex = 0;
+        HYD_handle.user_global.enablex = 0;
   fn_exit:
     return status;
@@ -547,7 +547,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.launch_mode != HYD_LAUNCH_UNSET,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.launch_mode != HYD_LAUNCH_UNSET,
                         HYD_INTERNAL_ERROR, "duplicate launch mode\n");
@@ -560,11 +560,11 @@
     if (!strcmp(arg, "boot-proxies"))
-        HYD_handle.launch_mode = HYD_LAUNCH_BOOT;
+        HYD_handle.user_global.launch_mode = HYD_LAUNCH_BOOT;
     else if (!strcmp(arg, "boot-foreground-proxies"))
-        HYD_handle.launch_mode = HYD_LAUNCH_BOOT_FOREGROUND;
+        HYD_handle.user_global.launch_mode = HYD_LAUNCH_BOOT_FOREGROUND;
     else if (!strcmp(arg, "shutdown-proxies"))
-        HYD_handle.launch_mode = HYD_LAUNCH_SHUTDOWN;
+        HYD_handle.user_global.launch_mode = HYD_LAUNCH_SHUTDOWN;
   fn_exit:
     return status;
@@ -603,7 +603,7 @@
@@ -614,9 +614,9 @@
     if (!strcmp(arg, "use-persistent"))
-        HYD_handle.launch_mode = HYD_LAUNCH_PERSISTENT;
+        HYD_handle.user_global.launch_mode = HYD_LAUNCH_PERSISTENT;
     else
-        HYD_handle.launch_mode = HYD_LAUNCH_RUNTIME;
+        HYD_handle.user_global.launch_mode = HYD_LAUNCH_RUNTIME;
   fn_exit:
     return status;
@@ -735,7 +735,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.binding, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.binding, HYD_INTERNAL_ERROR,
                         "duplicate binding\n");
     if (**argv == NULL)
@@ -754,7 +754,7 @@
-    HYD_handle.binding = HYDU_strdup(**argv);
+    HYD_handle.user_global.binding = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -768,7 +768,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.bindlib, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.bindlib, HYD_INTERNAL_ERROR,
                         "duplicate -bindlib option\n");
     if (**argv == NULL)
@@ -782,7 +782,7 @@
-    HYD_handle.bindlib = HYDU_strdup(**argv);
+    HYD_handle.user_global.bindlib = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -822,7 +822,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.ckpoint_prefix, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.ckpoint_prefix, HYD_INTERNAL_ERROR,
                         "duplicate -ckpoint-prefix option\n");
     if (**argv == NULL)
@@ -834,7 +834,7 @@
-    HYD_handle.ckpoint_prefix = HYDU_strdup(**argv);
+    HYD_handle.user_global.ckpoint_prefix = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -848,7 +848,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.ckpointlib, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.ckpointlib, HYD_INTERNAL_ERROR,
                         "duplicate -ckpointlib option\n");
     if (**argv == NULL)
@@ -862,7 +862,7 @@
-    HYD_handle.ckpointlib = HYDU_strdup(**argv);
+    HYD_handle.user_global.ckpointlib = HYDU_strdup(**argv);
     (*argv)++;
   fn_exit:
@@ -876,7 +876,8 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.ckpoint_restart, HYD_INTERNAL_ERROR, "duplicate restart mode\n");
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.ckpoint_restart,
+                        HYD_INTERNAL_ERROR, "duplicate restart mode\n");
         printf("\n");
@@ -884,7 +885,7 @@
-    HYD_handle.ckpoint_restart = 1;
+    HYD_handle.user_global.ckpoint_restart = 1;
   fn_exit:
     return status;
@@ -897,7 +898,7 @@
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.debug != -1, HYD_INTERNAL_ERROR,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.debug != -1, HYD_INTERNAL_ERROR,
                         "duplicate verbose setting\n");
@@ -906,7 +907,7 @@
-    HYD_handle.debug = 1;
+    HYD_handle.user_global.debug = 1;
   fn_exit:
     return status;
@@ -1110,18 +1111,18 @@
     /* Proxy launch or checkpoint restart */
-        (HYD_handle.launch_mode == HYD_LAUNCH_BOOT_FOREGROUND) ||
+        (HYD_handle.user_global.launch_mode == HYD_LAUNCH_BOOT_FOREGROUND) ||
         /* No environment */
-        HYDU_ERR_CHKANDJUMP(status, HYD_handle.global_env.prop, HYD_INTERNAL_ERROR,
+        HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.global_env.prop, HYD_INTERNAL_ERROR,
                             "env setting not required for booting/shutting proxies\n");
         /* No binding */
                             "binding not allowed while booting/shutting proxies\n");
         /* No executables */
@@ -1130,11 +1131,11 @@
     else {      /* Application launch */
         /* On a checkpoint restart, we set the prefix as the application */
-        if (HYD_handle.ckpoint_restart == 1) {
+        if (HYD_handle.user_global.ckpoint_restart == 1) {
             status = HYD_UIU_get_current_exec_info(&exec_info);
             HYDU_ERR_POP(status, "get_current_exec_info returned error\n");
-            exec_info->exec[0] = HYDU_strdup(HYD_handle.ckpoint_prefix);
+            exec_info->exec[0] = HYDU_strdup(HYD_handle.user_global.ckpoint_prefix);
             exec_info->exec[1] = NULL;
@@ -1167,10 +1168,10 @@
         HYD_handle.print_all_exitcodes = 0;
     tmp = getenv("HYDRA_DEBUG");
-    if (HYD_handle.debug == -1 && tmp)
-        HYD_handle.debug = atoi(tmp) ? 1 : 0;
-    if (HYD_handle.debug == -1)
-        HYD_handle.debug = 0;
+    if (HYD_handle.user_global.debug == -1 && tmp)
+        HYD_handle.user_global.debug = atoi(tmp) ? 1 : 0;
+    if (HYD_handle.user_global.debug == -1)
+        HYD_handle.user_global.debug = 0;
     tmp = getenv("HYDRA_PM_ENV");
     if (HYD_handle.pm_env == -1 && tmp)
@@ -1179,10 +1180,10 @@
         HYD_handle.pm_env = 1;  /* Default is to pass the PM environment */
     tmp = getenv("HYDRA_BOOTSTRAP");
-    if (HYD_handle.bootstrap == NULL && tmp)
-        HYD_handle.bootstrap = HYDU_strdup(tmp);
-    if (HYD_handle.bootstrap == NULL)
-        HYD_handle.bootstrap = HYDU_strdup(HYDRA_DEFAULT_BSS);
+    if (HYD_handle.user_global.bootstrap == NULL && tmp)
+        HYD_handle.user_global.bootstrap = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.bootstrap == NULL)
+        HYD_handle.user_global.bootstrap = HYDU_strdup(HYDRA_DEFAULT_BSS);
     tmp = getenv("HYDRA_CSS");
     if (HYD_handle.css == NULL && tmp)
@@ -1209,61 +1210,61 @@
         HYD_handle.proxy_port = HYD_DEFAULT_PROXY_PORT;
     tmp = getenv("HYDRA_LAUNCH_MODE");
-    if (HYD_handle.launch_mode == HYD_LAUNCH_UNSET && tmp) {
+    if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_UNSET && tmp) {
         if (!strcmp(tmp, "persistent"))
         else if (!strcmp(tmp, "runtime"))
-    if (HYD_handle.launch_mode == HYD_LAUNCH_UNSET)
+    if (HYD_handle.user_global.launch_mode == HYD_LAUNCH_UNSET)
     tmp = getenv("HYDRA_BOOT_FOREGROUND_PROXIES");
         if (atoi(tmp) == 1) {
     tmp = getenv("HYDRA_BOOTSTRAP_EXEC");
-    if (HYD_handle.bootstrap_exec == NULL && tmp)
-        HYD_handle.bootstrap_exec = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.bootstrap_exec == NULL && tmp)
+        HYD_handle.user_global.bootstrap_exec = HYDU_strdup(tmp);
     /* Check environment for setting binding */
     tmp = getenv("HYDRA_BINDING");
-    if (HYD_handle.binding == NULL && tmp)
-        HYD_handle.binding = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.binding == NULL && tmp)
+        HYD_handle.user_global.binding = HYDU_strdup(tmp);
     tmp = getenv("HYDRA_BINDLIB");
-    if (HYD_handle.bindlib == NULL && tmp)
-        HYD_handle.bindlib = HYDU_strdup(tmp);
-    if (HYD_handle.bindlib == NULL && strcmp(HYDRA_DEFAULT_BINDLIB, ""))
-        HYD_handle.bindlib = HYDU_strdup(HYDRA_DEFAULT_BINDLIB);
-    if (HYD_handle.bindlib == NULL)
-        HYD_handle.bindlib = HYDU_strdup("none");
+    if (HYD_handle.user_global.bindlib == NULL && tmp)
+        HYD_handle.user_global.bindlib = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.bindlib == NULL && strcmp(HYDRA_DEFAULT_BINDLIB, ""))
+        HYD_handle.user_global.bindlib = HYDU_strdup(HYDRA_DEFAULT_BINDLIB);
+    if (HYD_handle.user_global.bindlib == NULL)
+        HYD_handle.user_global.bindlib = HYDU_strdup("none");
     /* Check environment for checkpointing */
     tmp = getenv("HYDRA_CKPOINTLIB");
-    if (HYD_handle.ckpointlib == NULL && tmp)
-        HYD_handle.ckpointlib = HYDU_strdup(tmp);
-    if (HYD_handle.ckpointlib == NULL && strcmp(HYDRA_DEFAULT_CKPOINTLIB, ""))
-        HYD_handle.ckpointlib = HYDU_strdup(HYDRA_DEFAULT_CKPOINTLIB);
-    if (HYD_handle.ckpointlib == NULL)
-        HYD_handle.ckpointlib = HYDU_strdup("none");
+    if (HYD_handle.user_global.ckpointlib == NULL && tmp)
+        HYD_handle.user_global.ckpointlib = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.ckpointlib == NULL && strcmp(HYDRA_DEFAULT_CKPOINTLIB, ""))
+        HYD_handle.user_global.ckpointlib = HYDU_strdup(HYDRA_DEFAULT_CKPOINTLIB);
+    if (HYD_handle.user_global.ckpointlib == NULL)
+        HYD_handle.user_global.ckpointlib = HYDU_strdup("none");
     tmp = getenv("HYDRA_CKPOINT_PREFIX");
-    if (HYD_handle.ckpoint_prefix == NULL && tmp)
-        HYD_handle.ckpoint_prefix = HYDU_strdup(tmp);
+    if (HYD_handle.user_global.ckpoint_prefix == NULL && tmp)
+        HYD_handle.user_global.ckpoint_prefix = HYDU_strdup(tmp);
     /* Check environment for setting the inherited environment */
     tmp = getenv("HYDRA_ENV");
-    if (HYD_handle.global_env.prop == NULL && tmp)
+    if (HYD_handle.user_global.global_env.prop == NULL && tmp)
             !strcmp(tmp, "all") ? HYDU_strdup("all") : HYDU_strdup("none");
     /* If no global environment is set, use the default */
-    if (HYD_handle.global_env.prop == NULL)
+    if (HYD_handle.user_global.global_env.prop == NULL)
   fn_exit:
     return status;
@@ -1284,7 +1285,7 @@
     HYD_UIU_init_params();
-    status = HYDU_list_inherited_env(&HYD_handle.global_env.inherited);
+    status = HYDU_list_inherited_env(&HYD_handle.user_global.global_env.inherited);
     HYDU_ERR_POP(status, "unable to get the inherited env list\n");
     argv++;
@@ -1323,12 +1324,12 @@
     HYDU_ERR_POP(status, "argument verification failed\n");
     /* Get the base path for the proxy */
-    if (HYD_handle.wdir == NULL) {
-        HYD_handle.wdir = HYDU_getcwd();
-        HYDU_ERR_CHKANDJUMP(status, HYD_handle.wdir == NULL, HYD_INTERNAL_ERROR,
+    if (HYD_handle.user_global.wdir == NULL) {
+        HYD_handle.user_global.wdir = HYDU_getcwd();
+        HYDU_ERR_CHKANDJUMP(status, HYD_handle.user_global.wdir == NULL, HYD_INTERNAL_ERROR,
                             "unable to get current working directory\n");
-    status = HYDU_get_base_path(progname, HYD_handle.wdir, &HYD_handle.base_path);
+    status = HYDU_get_base_path(progname, HYD_handle.user_global.wdir, &HYD_handle.base_path);
     HYDU_ERR_POP(status, "unable to get base path\n");
     status = set_default_values();
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-14 11:35:29 UTC (rev 5453)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-14 11:35:35 UTC (rev 5454)
@@ -12,33 +12,33 @@
     HYD_handle.base_path = NULL;
     HYD_handle.proxy_port = -1;
-    HYD_handle.launch_mode = HYD_LAUNCH_UNSET;
+    HYD_handle.user_global.launch_mode = HYD_LAUNCH_UNSET;
-    HYD_handle.bootstrap = NULL;
+    HYD_handle.user_global.bootstrap = NULL;
     HYD_handle.css = NULL;
     HYD_handle.rmk = NULL;
-    HYD_handle.binding = NULL;
-    HYD_handle.bindlib = NULL;
+    HYD_handle.user_global.binding = NULL;
+    HYD_handle.user_global.bindlib = NULL;
-    HYD_handle.ckpointlib = NULL;
+    HYD_handle.user_global.ckpointlib = NULL;
     HYD_handle.ckpoint_int = -1;
-    HYD_handle.ckpoint_prefix = NULL;
-    HYD_handle.ckpoint_restart = 0;
+    HYD_handle.user_global.ckpoint_prefix = NULL;
+    HYD_handle.user_global.ckpoint_restart = 0;
-    HYD_handle.debug = -1;
+    HYD_handle.user_global.debug = -1;
     HYD_handle.print_rank_map = -1;
     HYD_handle.print_all_exitcodes = -1;
-    HYD_handle.enablex = -1;
+    HYD_handle.user_global.enablex = -1;
     HYD_handle.pm_env = -1;
-    HYD_handle.wdir = NULL;
+    HYD_handle.user_global.wdir = NULL;
     HYD_handle.ranks_per_proc = -1;
-    HYD_handle.bootstrap_exec = NULL;
+    HYD_handle.user_global.bootstrap_exec = NULL;
-    HYD_handle.global_env.inherited = NULL;
-    HYD_handle.global_env.system = NULL;
-    HYD_handle.global_env.user = NULL;
-    HYD_handle.global_env.prop = NULL;
+    HYD_handle.user_global.global_env.inherited = NULL;
+    HYD_handle.user_global.global_env.system = NULL;
+    HYD_handle.user_global.global_env.user = NULL;
+    HYD_handle.user_global.global_env.prop = NULL;
     HYD_handle.stdin_cb = NULL;
     HYD_handle.stdout_cb = NULL;
@@ -62,8 +62,8 @@
     if (HYD_handle.base_path)
         HYDU_FREE(HYD_handle.base_path);
-    if (HYD_handle.bootstrap)
-        HYDU_FREE(HYD_handle.bootstrap);
+    if (HYD_handle.user_global.bootstrap)
+        HYDU_FREE(HYD_handle.user_global.bootstrap);
     if (HYD_handle.css)
         HYDU_FREE(HYD_handle.css);
@@ -71,35 +71,35 @@
     if (HYD_handle.rmk)
         HYDU_FREE(HYD_handle.rmk);
-        HYDU_FREE(HYD_handle.binding);
+        HYDU_FREE(HYD_handle.user_global.binding);
-    if (HYD_handle.bindlib)
-        HYDU_FREE(HYD_handle.bindlib);
+    if (HYD_handle.user_global.bindlib)
+        HYDU_FREE(HYD_handle.user_global.bindlib);
-    if (HYD_handle.ckpointlib)
-        HYDU_FREE(HYD_handle.ckpointlib);
+    if (HYD_handle.user_global.ckpointlib)
+        HYDU_FREE(HYD_handle.user_global.ckpointlib);
-        HYDU_FREE(HYD_handle.ckpoint_prefix);
+        HYDU_FREE(HYD_handle.user_global.ckpoint_prefix);
-    if (HYD_handle.wdir)
-        HYDU_FREE(HYD_handle.wdir);
+    if (HYD_handle.user_global.wdir)
+        HYDU_FREE(HYD_handle.user_global.wdir);
-        HYDU_FREE(HYD_handle.bootstrap_exec);
+        HYDU_FREE(HYD_handle.user_global.bootstrap_exec);
-    if (HYD_handle.global_env.inherited)
-        HYDU_env_free_list(HYD_handle.global_env.inherited);
+    if (HYD_handle.user_global.global_env.inherited)
+        HYDU_env_free_list(HYD_handle.user_global.global_env.inherited);
-    if (HYD_handle.global_env.system)
-        HYDU_env_free_list(HYD_handle.global_env.system);
+    if (HYD_handle.user_global.global_env.system)
+        HYDU_env_free_list(HYD_handle.user_global.global_env.system);
-    if (HYD_handle.global_env.user)
-        HYDU_env_free_list(HYD_handle.global_env.user);
+    if (HYD_handle.user_global.global_env.user)
+        HYDU_env_free_list(HYD_handle.user_global.global_env.user);
-    if (HYD_handle.global_env.prop)
-        HYDU_FREE(HYD_handle.global_env.prop);
+    if (HYD_handle.user_global.global_env.prop)
+        HYDU_FREE(HYD_handle.user_global.global_env.prop);
     if (HYD_handle.exec_info_list)
         HYDU_free_exec_info_list(HYD_handle.exec_info_list);
@@ -254,30 +254,30 @@
     HYDU_dump(stdout, "----------------\n");
     HYDU_dump(stdout, "  Base path: %s\n", HYD_handle.base_path);
     HYDU_dump(stdout, "  Proxy port: %d\n", HYD_handle.proxy_port);
-    HYDU_dump(stdout, "  Bootstrap server: %s\n", HYD_handle.bootstrap);
-    HYDU_dump(stdout, "  Debug level: %d\n", HYD_handle.debug);
-    HYDU_dump(stdout, "  Enable X: %d\n", HYD_handle.enablex);
-    HYDU_dump(stdout, "  Working dir: %s\n", HYD_handle.wdir);
+    HYDU_dump(stdout, "  Bootstrap server: %s\n", HYD_handle.user_global.bootstrap);
+    HYDU_dump(stdout, "  Debug level: %d\n", HYD_handle.user_global.debug);
+    HYDU_dump(stdout, "  Enable X: %d\n", HYD_handle.user_global.enablex);
+    HYDU_dump(stdout, "  Working dir: %s\n", HYD_handle.user_global.wdir);
     HYDU_dump(stdout, "\n");
     HYDU_dump(stdout, "  Global environment:\n");
     HYDU_dump(stdout, "  -------------------\n");
         HYDU_dump(stdout, "    %s=%s\n", env->env_name, env->env_value);
-    if (HYD_handle.global_env.system) {
+    if (HYD_handle.user_global.global_env.system) {
         HYDU_dump(stdout, "  Hydra internal environment:\n");
         HYDU_dump(stdout, "  ---------------------------\n");
-    if (HYD_handle.global_env.user) {
+    if (HYD_handle.user_global.global_env.user) {
         HYDU_dump(stdout, "  User set environment:\n");
         HYDU_dump(stdout, "  ---------------------\n");
More information about the mpich2-commits
