[mpich2-commits] r4186 - in mpich2/trunk: . doc/faq doc/mpich2 doc/notes/agent doc/pmi maint src/binding/cxx src/binding/f77 src/binding/f90
balaji at mcs.anl.gov
Wed Mar 25 10:43:14 CDT 2009
Author: balaji
Date: 2009-03-25 10:43:14 -0500 (Wed, 25 Mar 2009)
New Revision: 4186
Modified:
mpich2/trunk/doc/faq/faqbuild
mpich2/trunk/doc/mpich2/sm2dot
mpich2/trunk/doc/notes/agent/sm2dot
mpich2/trunk/doc/pmi/manextract
mpich2/trunk/maint/checkmake
mpich2/trunk/maint/extracterrmsgs
mpich2/trunk/maint/extractparms
mpich2/trunk/maint/parse.sub
mpich2/trunk/maint/parsetest
mpich2/trunk/maint/testpmpi
mpich2/trunk/maint/update_windows_version
mpich2/trunk/mpich2-doxygen.in
mpich2/trunk/src/binding/cxx/buildiface
mpich2/trunk/src/binding/cxx/cov2html.in
mpich2/trunk/src/binding/cxx/cxxtodecl
mpich2/trunk/src/binding/f77/buildiface
mpich2/trunk/src/binding/f90/binding.sub
mpich2/trunk/src/binding/f90/buildiface
Log:
Use "/usr/bin/env perl" instead of "/usr/bin/perl" for portability.
Reviewed by goodell.
Modified: mpich2/trunk/doc/faq/faqbuild
--- mpich2/trunk/doc/faq/faqbuild 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/doc/faq/faqbuild 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl -w
+#! /usr/bin/env perl -w
# Create an FAQ from a single source file. Handles both LaTeX and HTML output
# The file uses structured comments to provide information needed to create
Modified: mpich2/trunk/doc/mpich2/sm2dot
--- mpich2/trunk/doc/mpich2/sm2dot 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/doc/mpich2/sm2dot 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#!/usr/bin/perl
+#!/usr/bin/env perl
# sm2dot
Modified: mpich2/trunk/doc/notes/agent/sm2dot
--- mpich2/trunk/doc/notes/agent/sm2dot 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/doc/notes/agent/sm2dot 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#!/usr/bin/perl
# sm2dot
Modified: mpich2/trunk/doc/pmi/manextract
--- mpich2/trunk/doc/pmi/manextract 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/doc/pmi/manextract 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
# This script extracts the text blocks from a source file and creates a
# simple text block out of them.
Modified: mpich2/trunk/maint/checkmake
--- mpich2/trunk/maint/checkmake 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/checkmake 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# A simple check of the make output when developing
Modified: mpich2/trunk/maint/extracterrmsgs
--- mpich2/trunk/maint/extracterrmsgs 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/extracterrmsgs 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# (Tested with -w; 10/5/04)
# Find the parse.sub routine.
Modified: mpich2/trunk/maint/extractparms
--- mpich2/trunk/maint/extractparms 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/extractparms 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
# (Tested with -w; 2/23/07)
Modified: mpich2/trunk/maint/parse.sub
--- mpich2/trunk/maint/parse.sub 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/parse.sub 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# File of useful routines use to process the MPI source files. This is
# included by routines that process parameters and error messages, along with
Modified: mpich2/trunk/maint/parsetest
--- mpich2/trunk/maint/parsetest 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/parsetest 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
require "maint/parse.sub";
Modified: mpich2/trunk/maint/testpmpi
--- mpich2/trunk/maint/testpmpi 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/testpmpi 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
$routine_prefix = "MPI_";
Modified: mpich2/trunk/maint/update_windows_version
--- mpich2/trunk/maint/update_windows_version 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/maint/update_windows_version 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
$version = "";
$filename = "mpich2i.vdproj";
Modified: mpich2/trunk/mpich2-doxygen.in
--- mpich2/trunk/mpich2-doxygen.in 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/mpich2-doxygen.in 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1070,7 +1070,7 @@
# The PERL_PATH should be the absolute path and name of the perl script
# interpreter (i.e. the result of `which perl').
-PERL_PATH = /usr/bin/perl
+PERL_PATH = @PERL@
# Configuration options related to the dot tool
Modified: mpich2/trunk/src/binding/cxx/buildiface
--- mpich2/trunk/src/binding/cxx/buildiface 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/cxx/buildiface 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# This file builds candidate interface files from the descriptions in
# mpi.h
Modified: mpich2/trunk/src/binding/cxx/cov2html.in
--- mpich2/trunk/src/binding/cxx/cov2html.in 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/cxx/cov2html.in 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# -*- Mode:perl ; -*-
# This file converts a coverate data file, produced by the simple coverage
Modified: mpich2/trunk/src/binding/cxx/cxxtodecl
--- mpich2/trunk/src/binding/cxx/cxxtodecl 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/cxx/cxxtodecl 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# Class mapping
%ShortClassName = ( "Info" => "info",
"Win" => "win",
Modified: mpich2/trunk/src/binding/f77/buildiface
--- mpich2/trunk/src/binding/f77/buildiface 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/f77/buildiface 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
# mpi.h
Modified: mpich2/trunk/src/binding/f90/binding.sub
--- mpich2/trunk/src/binding/f90/binding.sub 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/f90/binding.sub 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
-#! /usr/bin/perl
# This file contains common routines for reading a file of function prototypes
# (such as mpi.h) and extracting the function prototypes.
Modified: mpich2/trunk/src/binding/f90/buildiface
--- mpich2/trunk/src/binding/f90/buildiface 2009-03-25 14:40:18 UTC (rev 4185)
+++ mpich2/trunk/src/binding/f90/buildiface 2009-03-25 15:43:14 UTC (rev 4186)
@@ -1,4 +1,4 @@
# binding.sub provides the routines for reading the prototype file
# and extracting the function definitions.
require "binding.sub";
More information about the mpich2-commits
