[mpich2-commits] r4137 - mpich2/trunk/src/mpi/coll
goodell at mcs.anl.gov
Thu Mar 19 21:47:27 CDT 2009
Author: goodell
Date: 2009-03-19 21:47:27 -0500 (Thu, 19 Mar 2009)
New Revision: 4137
Added:
mpich2/trunk/src/mpi/coll/oputil.h
Modified:
mpich2/trunk/src/mpi/coll/opband.c
mpich2/trunk/src/mpi/coll/opbor.c
mpich2/trunk/src/mpi/coll/opbxor.c
mpich2/trunk/src/mpi/coll/opland.c
mpich2/trunk/src/mpi/coll/oplor.c
mpich2/trunk/src/mpi/coll/oplxor.c
mpich2/trunk/src/mpi/coll/opmax.c
mpich2/trunk/src/mpi/coll/opmin.c
mpich2/trunk/src/mpi/coll/opprod.c
mpich2/trunk/src/mpi/coll/opsum.c
Log:
Refactor predefined reduction operations.
This version should greatly reduce the chances of a copy-paste error creeping
into the code and should make adding new predefined reduction types easier.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/mpi/coll/opband.c
--- mpich2/trunk/src/mpi/coll/opband.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opband.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,218 +6,74 @@
#include "mpiimpl.h"
+#include "oputil.h"
- * In MPI-1, this operation is valid only for C integer, Fortran integer,
- * and byte data items (4.9.2 Predefined reduce operations)
+ * In MPI-2.1, this operation is valid only for C integer, Fortran integer,
+ * and byte types (5.9.2 Predefined reduce operations)
#ifndef MPIR_LBAND
#define MPIR_LBAND(a,b) ((a)&(b))
#endif
-void MPIR_BAND (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_BAND
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+void MPIR_BAND (
+ void *invec,
+ void *inoutvec,
+ int *Len,
MPI_Datatype *type )
- static const char FCNAME[] = "MPIR_BAND";
int i, len = *Len;
switch (*type) {
-#ifdef HAVE_FORTRAN_BINDING
- case MPI_LOGICAL: case MPI_INTEGER: {
- MPI_Fint * restrict a = (MPI_Fint *)inoutvec;
- MPI_Fint * restrict b = (MPI_Fint *)invec;
- for ( i=0; i<len; i++ )
- a[i] = MPIR_LBAND(a[i],b[i]);
- break;
+#undef MPIR_OP_TYPE_MACRO
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LBAND)
+ /* no semicolons by necessity */
+ MPIR_OP_TYPE_GROUP(C_INTEGER)
+ MPIR_OP_TYPE_GROUP(FORTRAN_INTEGER)
+ MPIR_OP_TYPE_GROUP(BYTE)
+ /* extra types that are not required to be supported by the MPI Standard */
+ MPIR_OP_TYPE_GROUP(C_INTEGER_EXTRA)
+ MPIR_OP_TYPE_GROUP(FORTRAN_INTEGER_EXTRA)
+ MPIR_OP_TYPE_GROUP(BYTE_EXTRA)
+ /* --BEGIN ERROR HANDLING-- */
+ default: {
+ MPIU_THREADPRIV_DECL;
+ MPIU_THREADPRIV_GET;
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BAND" );
+ break;
+ /* --END ERROR HANDLING-- */
-#endif
-#ifdef MPIR_INTEGER1_CTYPE
- case MPI_INTEGER1: {
- MPIR_INTEGER1_CTYPE * restrict a = (MPIR_INTEGER1_CTYPE *)inoutvec;
- MPIR_INTEGER1_CTYPE * restrict b = (MPIR_INTEGER1_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_INTEGER2_CTYPE
- case MPI_INTEGER2: {
- MPIR_INTEGER2_CTYPE * restrict a = (MPIR_INTEGER2_CTYPE *)inoutvec;
- MPIR_INTEGER2_CTYPE * restrict b = (MPIR_INTEGER2_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_INTEGER4_CTYPE
- case MPI_INTEGER4: {
- MPIR_INTEGER4_CTYPE * restrict a = (MPIR_INTEGER4_CTYPE *)inoutvec;
- MPIR_INTEGER4_CTYPE * restrict b = (MPIR_INTEGER4_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_INTEGER8_CTYPE
- case MPI_INTEGER8: {
- MPIR_INTEGER8_CTYPE * restrict a = (MPIR_INTEGER8_CTYPE *)inoutvec;
- MPIR_INTEGER8_CTYPE * restrict b = (MPIR_INTEGER8_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_INTEGER16_CTYPE
- case MPI_INTEGER16: {
- MPIR_INTEGER16_CTYPE * restrict a = (MPIR_INTEGER16_CTYPE *)inoutvec;
- MPIR_INTEGER16_CTYPE * restrict b = (MPIR_INTEGER16_CTYPE *)invec;
- break;
-#endif
- case MPI_INT: {
- int * restrict a = (int *)inoutvec;
- int * restrict b = (int *)invec;
- break;
- case MPI_UNSIGNED: {
- unsigned * restrict a = (unsigned *)inoutvec;
- unsigned * restrict b = (unsigned *)invec;
- break;
- case MPI_LONG: {
- long * restrict a = (long *)inoutvec;
- long * restrict b = (long *)invec;
- break;
-#if defined(HAVE_LONG_LONG_INT)
- case MPI_LONG_LONG: {
- /* case MPI_LONG_LONG_INT: defined to be the same as long_long */
- long long * restrict a = (long long *)inoutvec;
- long long * restrict b = (long long *)invec;
- break;
-#endif
- case MPI_UNSIGNED_LONG: {
- unsigned long * restrict a = (unsigned long *)inoutvec;
- unsigned long * restrict b = (unsigned long *)invec;
- break;
- case MPI_SHORT: {
- short * restrict a = (short *)inoutvec;
- short * restrict b = (short *)invec;
- break;
- case MPI_UNSIGNED_SHORT: {
- unsigned short * restrict a = (unsigned short *)inoutvec;
- unsigned short * restrict b = (unsigned short *)invec;
- break;
- case MPI_CHAR:
- case MPI_CHARACTER:
-#endif
- char * restrict a = (char *)inoutvec;
- char * restrict b = (char *)invec;
- break;
- case MPI_SIGNED_CHAR: {
- signed char * restrict a = (signed char *)inoutvec;
- signed char * restrict b = (signed char *)invec;
- break;
- case MPI_UNSIGNED_CHAR: {
- unsigned char * restrict a = (unsigned char *)inoutvec;
- unsigned char * restrict b = (unsigned char *)invec;
- break;
- case MPI_BYTE: {
- break;
- /* --BEGIN ERROR HANDLING-- */
- default: {
- MPIU_THREADPRIV_DECL;
- MPIU_THREADPRIV_GET;
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BAND" );
- break;
- /* --END ERROR HANDLING-- */
+#undef FUNCNAME
+#define FUNCNAME MPIR_BAND_check_dtype
+#undef FCNAME
int MPIR_BAND_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_BAND_check_dtype";
switch (type) {
-#endif
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_BYTE:
-/* The length type can be provided without Fortran, so we do so */
-#endif
-#endif
-#endif
-#endif
-#endif
- return MPI_SUCCESS;
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BAND" );
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) case (mpi_type_):
+ return MPI_SUCCESS;
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BAND" );
Modified: mpich2/trunk/src/mpi/coll/opbor.c
--- mpich2/trunk/src/mpi/coll/opbor.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opbor.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,218 +6,74 @@
+ * and byte data items (5.9.2 Predefined reduce operations)
#ifndef MPIR_LBOR
#define MPIR_LBOR(a,b) ((a)|(b))
#endif
-void MPIR_BOR (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_BOR
+#undef FCNAME
+void MPIR_BOR (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_BOR";
int i, len = *Len;
switch (*type) {
- a[i] = MPIR_LBOR(a[i],b[i]);
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LBOR)
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BOR" );
+ break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_INT: {
- int * restrict a = (int *)inoutvec; int * restrict b = (int *)invec;
- break;
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_BYTE: {
- break;
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BOR" );
- break;
+#undef FUNCNAME
+#undef FCNAME
int MPIR_BOR_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_BOR_check_dtype";
switch (type) {
-#endif
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_BYTE:
-#endif
-#endif
-#endif
-#endif
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BOR" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BOR" );
Modified: mpich2/trunk/src/mpi/coll/opbxor.c
--- mpich2/trunk/src/mpi/coll/opbxor.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opbxor.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,218 +6,73 @@
#ifndef MPIR_LBXOR
#define MPIR_LBXOR(a,b) ((a)^(b))
#endif
-void MPIR_BXOR (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_BXOR
+#undef FCNAME
+void MPIR_BXOR (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_BXOR";
int i, len = *Len;
switch (*type) {
- a[i] = MPIR_LBXOR(a[i],b[i]);
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_INT: {
- break;
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_BYTE: {
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LBXOR)
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BXOR" );
- break;
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BXOR" );
+ break;
+#undef FUNCNAME
+#undef FCNAME
int MPIR_BXOR_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_BXOR_check_dtype";
switch (type) {
-#endif
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_BYTE:
-#endif
-#endif
-#endif
-#endif
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BXOR" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_BXOR" );
Modified: mpich2/trunk/src/mpi/coll/opland.c
--- mpich2/trunk/src/mpi/coll/opland.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opland.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,302 +6,107 @@
#include "mpi_fortlogical.h"
#endif
- * In MPI-1, this operation is valid only for C integer, Fortran logical
- * data items (4.9.2 Predefined reduce operations)
+ * In MPI-2.1, this operation is valid only for C integer and Logical
+ * types (5.9.2 Predefined reduce operations)
#ifndef MPIR_LLAND
#define MPIR_LLAND(a,b) ((a)&&(b))
#endif
-void MPIR_LAND (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_LAND
+#undef FCNAME
+void MPIR_LAND (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_LAND";
int i, len = *Len;
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_LLAND(a[i],b[i]);
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LLAND)
+ /* MPI_LOGICAL requires special handling (MPIR_{TO,FROM}_FLOG) */
+#if defined(HAVE_FORTRAN_BINDING)
+# undef MPIR_OP_TYPE_MACRO_HAVE_FORTRAN
+# define MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(mpi_type_, c_type_) \
+ case (mpi_type_): { \
+ c_type_ * restrict a = (c_type_ *)inoutvec; \
+ c_type_ * restrict b = (c_type_ *)invec; \
+ for (i=0; i<len; i++) \
+ a[i] = MPIR_TO_FLOG(MPIR_LLAND(MPIR_FROM_FLOG(a[i]), \
+ MPIR_FROM_FLOG(b[i]))); \
+ break; \
- break;
- case MPI_LONG: {
- break;
- break;
+ /* expand logicals (which may include MPI_C_BOOL, a non-Fortran type) */
+ MPIR_OP_TYPE_GROUP(LOGICAL)
+ /* now revert _HAVE_FORTRAN macro to default */
+# define MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(mpi_type_, c_type_) MPIR_OP_TYPE_MACRO(mpi_type_, c_type_)
+#else
+ /* if we don't have Fortran support then we don't have to jump through
+ any hoops, simply expand the group */
#endif
- break;
+ /* We previously supported floating point types, although I question
+ their utility in logical boolean ops [goodell@ 2009-03-16] */
+ MPIR_OP_TYPE_GROUP(FLOATING_POINT)
+ MPIR_OP_TYPE_GROUP(FLOATING_POINT_EXTRA)
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LAND" );
+ break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- /* FIXME: This assume C float = Fortran real */
- case MPI_REAL:
-#endif
- float * restrict a = (float *)inoutvec;
- float * restrict b = (float *)invec;
- a[i] = (float)MPIR_LLAND(a[i],b[i]);
- break;
- case MPI_DOUBLE:
- /* FIXME: This assume C double = Fortran double precision */
- case MPI_DOUBLE_PRECISION:
-#endif
- double * restrict a = (double *)inoutvec;
- double * restrict b = (double *)invec;
- break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
-#ifdef MPIR_REAL4_CTYPE
- case MPI_REAL4: {
- MPIR_REAL4_CTYPE * restrict a = (MPIR_REAL4_CTYPE *)inoutvec;
- MPIR_REAL4_CTYPE * restrict b = (MPIR_REAL4_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_REAL8_CTYPE
- case MPI_REAL8: {
- MPIR_REAL8_CTYPE * restrict a = (MPIR_REAL8_CTYPE *)inoutvec;
- MPIR_REAL8_CTYPE * restrict b = (MPIR_REAL8_CTYPE *)invec;
- break;
-#endif
-#ifdef MPIR_REAL16_CTYPE
- case MPI_REAL16: {
- MPIR_REAL16_CTYPE * restrict a = (MPIR_REAL16_CTYPE *)inoutvec;
- MPIR_REAL16_CTYPE * restrict b = (MPIR_REAL16_CTYPE *)invec;
- break;
-#endif
-#if defined(HAVE_LONG_DOUBLE)
- case MPI_LONG_DOUBLE: {
- long double * restrict a = (long double *)inoutvec;
- long double * restrict b = (long double *)invec;
- break;
-#endif
- case MPI_LOGICAL: {
- for (i=0; i<len; i++)
- a[i] = MPIR_TO_FLOG(MPIR_LLAND(MPIR_FROM_FLOG(a[i]),
- MPIR_FROM_FLOG(b[i])));
- break;
- case MPI_INTEGER: {
- break;
-#endif
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LAND" );
- break;
+#undef FUNCNAME
+#undef FCNAME
int MPIR_LAND_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_LAND_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
- case MPI_LOGICAL:
- case MPI_INTEGER:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LAND" );
+ MPIR_OP_TYPE_GROUP(LOGICAL) /* no special handling needed in check_dtype code */
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LAND" );
Modified: mpich2/trunk/src/mpi/coll/oplor.c
--- mpich2/trunk/src/mpi/coll/oplor.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/oplor.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,301 +6,107 @@
#endif
#ifndef MPIR_LLOR
#define MPIR_LLOR(a,b) ((a)||(b))
#endif
-void MPIR_LOR (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_LOR
+#undef FCNAME
+void MPIR_LOR (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_LOR";
int i, len = *Len;
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_LLOR(a[i],b[i]);
- break;
- break;
- case MPI_LONG: {
- break;
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LLOR)
+ a[i] = MPIR_TO_FLOG(MPIR_LLOR(MPIR_FROM_FLOG(a[i]), \
+ break; \
+#else
#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- a[i] = (float)MPIR_LLOR(a[i],b[i]);
- break;
- case MPI_DOUBLE:
- /* FIXME : This assumes Fortran double precision == C double */
-#endif
- break;
- break;
-#endif
- a[i] = MPIR_TO_FLOG(MPIR_LLOR(MPIR_FROM_FLOG(a[i]),
- break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LOR" );
- break;
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LOR" );
+ break;
+#undef FUNCNAME
+#undef FCNAME
int MPIR_LOR_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_LOR_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
- case MPI_LOGICAL:
- case MPI_INTEGER:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LOR" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LOR" );
Modified: mpich2/trunk/src/mpi/coll/oplxor.c
--- mpich2/trunk/src/mpi/coll/oplxor.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/oplxor.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,302 +6,107 @@
#endif
#ifndef MPIR_LLXOR
#define MPIR_LLXOR(a,b) (((a)&&(!b))||((!a)&&(b)))
#endif
-void MPIR_LXOR (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_LXOR
+#undef FCNAME
+void MPIR_LXOR (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_LXOR";
int i, len = *Len;
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_LLXOR(a[i],b[i]);
- break;
- break;
- case MPI_LONG: {
- break;
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LLXOR)
+ a[i] = MPIR_TO_FLOG(MPIR_LLXOR(MPIR_FROM_FLOG(a[i]), \
+ break; \
+#else
#endif
- break;
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LXOR" );
+ break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
- /* FIXME: This assumes C float = Fortran real */
-#endif
- a[i] = (float)MPIR_LLXOR(a[i],b[i]);
- break;
- case MPI_DOUBLE:
- /* FIXME: This assumes C double = Fortran double precision */
-#endif
- double * restrict a = (double *)inoutvec; double * restrict b = (double *)invec;
- break;
- break;
-#endif
- a[i] = MPIR_TO_FLOG(MPIR_LLXOR(MPIR_FROM_FLOG(a[i]),
- break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LXOR" );
- break;
+#undef FUNCNAME
+#undef FCNAME
int MPIR_LXOR_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_LXOR_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
- case MPI_LOGICAL:
- case MPI_INTEGER:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LXOR" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_LXOR" );
Modified: mpich2/trunk/src/mpi/coll/opmax.c
--- mpich2/trunk/src/mpi/coll/opmax.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opmax.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,287 +6,70 @@
- * and floating point data items (4.9.2 Predefined reduce operations)
+ * and floating point types (5.9.2 Predefined reduce operations)
-void MPIR_MAXF(
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_MAXF
+#undef FCNAME
+void MPIR_MAXF(
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_MAXF";
int i, len = *Len;
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_MAX(a[i],b[i]);
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_MAX)
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MAX" );
+ break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- unsigned int * restrict a = (unsigned int *)inoutvec;
- unsigned int * restrict b = (unsigned int *)invec;
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- break;
- case MPI_DOUBLE:
-#endif
- break;
- break;
-#endif
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MAX" );
- break;
+#undef FUNCNAME
+#define FUNCNAME MPIR_MAXF_check_dtype
+#undef FCNAME
int MPIR_MAXF_check_dtype( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_MAXF_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_INTEGER:
-#endif
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MAX" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MAX" );
Modified: mpich2/trunk/src/mpi/coll/opmin.c
--- mpich2/trunk/src/mpi/coll/opmin.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opmin.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,287 +6,69 @@
-void MPIR_MINF (
- void *invec,
- void *inoutvec,
- int *Len,
- MPI_Datatype *type )
+#undef FUNCNAME
+#define FUNCNAME MPIR_MINF
+#undef FCNAME
+void MPIR_MINF (
+ void *invec,
+ void *inoutvec,
+ int *Len,
+ MPI_Datatype *type )
- static const char FCNAME[] = "MPIR_MINF";
int i, len = *Len;
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_MIN(a[i],b[i]);
- break;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_MIN)
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MIN" );
+ break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- break;
- case MPI_DOUBLE:
-#endif
- break;
- break;
-#endif
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MIN" );
- break;
+#undef FUNCNAME
+#define FUNCNAME MPIR_MINF_check_dtype
+#undef FCNAME
int MPIR_MINF_check_dtype ( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_MINF_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_INTEGER:
-#endif
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MIN" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_MIN" );
Modified: mpich2/trunk/src/mpi/coll/opprod.c
--- mpich2/trunk/src/mpi/coll/opprod.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opprod.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,383 +6,93 @@
- * floating point, and complex data items (4.9.2 Predefined reduce operations)
+ * Floating point, and Complex types (5.9.2 Predefined reduce operations)
#define MPIR_LPROD(a,b) ((a)*(b))
-void MPIR_PROD (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_PROD
+#undef FCNAME
+void MPIR_PROD (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_PROD";
int i, len = *Len;
-#if defined(HAVE_FORTRAN_BINDING) || defined(HAVE_CXX_COMPLEX)
- typedef struct {
- float re;
- float im;
- } s_complex;
- typedef struct {
- double re;
- double im;
- } d_complex;
-#endif
-#if defined(HAVE_LONG_DOUBLE) && defined(HAVE_CXX_COMPLEX)
- typedef struct {
- long double re;
- long double im;
- } ld_complex;
-#endif
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_LPROD(a[i],b[i]);
- break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- break;
- case MPI_DOUBLE:
-#endif
- break;
- break;
-#endif
- case MPI_COMPLEX8:
- case MPI_COMPLEX: {
- s_complex * restrict a = (s_complex *)inoutvec;
- s_complex * restrict b = (s_complex *)invec;
- for ( i=0; i<len; i++ ) {
- s_complex c;
- c.re = a[i].re; c.im = a[i].im;
- a[i].re = c.re*b[i].re - c.im*b[i].im;
- a[i].im = c.im*b[i].re + c.re*b[i].im;
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LPROD)
+ /* complex multiplication is slightly different than scalar multiplication */
+ /* adding the C99 {float,double} _Complex types will require redefining an additional macro */
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) \
+ for ( i=0; i<len; i++ ) { \
+ c_type_ c; \
+ c.re = a[i].re; c.im = a[i].im; \
+ a[i].re = c.re*b[i].re - c.im*b[i].im; \
+ a[i].im = c.im*b[i].re + c.re*b[i].im; \
+ break; \
- break;
- case MPI_COMPLEX16:
- case MPI_DOUBLE_COMPLEX: {
- d_complex * restrict a = (d_complex *)inoutvec;
- d_complex * restrict b = (d_complex *)invec;
- d_complex c;
+ MPIR_OP_TYPE_GROUP(COMPLEX)
+ MPIR_OP_TYPE_GROUP(COMPLEX_EXTRA)
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_PROD" );
+ break;
- break;
-#endif /* HAVE_FORTRAN_BINDING */
-#ifdef HAVE_CXX_COMPLEX
- case MPIR_CXX_COMPLEX_VALUE: {
- s_complex const * restrict b = (s_complex *)invec;
- s_complex c;
- break;
- case MPIR_CXX_DOUBLE_COMPLEX_VALUE: {
- d_complex const * restrict b = (d_complex *)invec;
- d_complex c;
- break;
-#ifdef HAVE_LONG_DOUBLE
- case MPIR_CXX_LONG_DOUBLE_COMPLEX_VALUE: {
- ld_complex * restrict a = (ld_complex *)inoutvec;
- ld_complex const * restrict b = (ld_complex *)invec;
- ld_complex c;
- break;
-#endif /* HAVE_LONG_DOUBLE */
-#endif /* HAVE_CXX_COMPLEX */
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_PROD" );
- break;
-int MPIR_PROD_check_dtype ( MPI_Datatype type )
+#undef FUNCNAME
+#define FUNCNAME MPIR_PROD_check_dtype
+#undef FCNAME
+int MPIR_PROD_check_dtype( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_PROD_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_INTEGER:
-#endif
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
- case MPI_COMPLEX:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
- case MPI_COMPLEX32:
-#endif
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_PROD" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_PROD" );
Modified: mpich2/trunk/src/mpi/coll/opsum.c
--- mpich2/trunk/src/mpi/coll/opsum.c 2009-03-20 02:46:22 UTC (rev 4136)
+++ mpich2/trunk/src/mpi/coll/opsum.c 2009-03-20 02:47:27 UTC (rev 4137)
@@ -6,379 +6,91 @@
- * In MPI-2, it is valid for more operations.
- * Of particular interest are the C++ operations that may not correspond
- * to C or Fortran counterparts. MPI::COMPLEX (C++ Complex) (and the long
- * version) may fall into this category.
#define MPIR_LSUM(a,b) ((a)+(b))
-void MPIR_SUM (
- void *invec,
- void *inoutvec,
- int *Len,
+#undef FUNCNAME
+#define FUNCNAME MPIR_SUM
+#undef FCNAME
+void MPIR_SUM (
+ void *invec,
+ void *inoutvec,
+ int *Len,
- static const char FCNAME[] = "MPIR_SUM";
int i, len = *Len;
- typedef struct {
- float re;
- float im;
- } s_complex;
- typedef struct {
- double re;
- double im;
- } d_complex;
-#endif
- typedef struct {
- long double re;
- long double im;
- } ld_complex;
-#endif
switch (*type) {
- case MPI_INT: {
- a[i] = MPIR_LSUM(a[i],b[i]);
- break;
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- break;
-#endif
- case MPI_REAL4: {
- break;
-#endif
- case MPI_REAL8: {
- break;
-#endif
- break;
-#endif
- break;
- case MPI_LONG: {
- break;
- break;
-#endif
- break;
- case MPI_SHORT: {
- break;
- break;
- case MPI_CHAR:
-#endif
- break;
- break;
- break;
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- break;
- case MPI_DOUBLE:
-#endif
- break;
- break;
-#endif
- a[i].re = MPIR_LSUM(a[i].re ,b[i].re);
- a[i].im = MPIR_LSUM(a[i].im ,b[i].im);
+#define MPIR_OP_TYPE_MACRO(mpi_type_, c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_, c_type_, MPIR_LSUM)
+ const c_type_ * restrict b = (c_type_ *)invec; \
+ a[i].re = MPIR_LSUM(a[i].re ,b[i].re); \
+ a[i].im = MPIR_LSUM(a[i].im ,b[i].im); \
+ break; \
- break;
+ default: {
+ MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_SUM" );
+ break;
- break;
- /* FIXME: Need complex8, 16, and 32 */
- break;
- break;
- break;
- default: {
- MPIU_THREADPRIV_FIELD(op_errno) = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_SUM" );
- break;
-int MPIR_SUM_check_dtype ( MPI_Datatype type )
+#undef FUNCNAME
+#define FUNCNAME MPIR_SUM_check_dtype
+#undef FCNAME
+int MPIR_SUM_check_dtype( MPI_Datatype type )
- static const char FCNAME[] = "MPIR_SUM_check_dtype";
switch (type) {
- case MPI_INT:
- case MPI_INTEGER:
-#endif
- case MPI_LONG:
-#endif
- case MPI_SHORT:
- case MPI_CHAR:
-#endif
- case MPI_FLOAT:
- case MPI_REAL:
-#endif
- case MPI_DOUBLE:
-#endif
-#endif
- case MPI_COMPLEX:
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
- case MPI_REAL4:
-#endif
- case MPI_REAL8:
-#endif
- case MPI_REAL16:
-#endif
-#endif
- default:
- return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_SUM" );
+ default:
+ return MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP, "**opundefined","**opundefined %s", "MPI_SUM" );
Added: mpich2/trunk/src/mpi/coll/oputil.h
--- mpich2/trunk/src/mpi/coll/oputil.h (rev 0)
+++ mpich2/trunk/src/mpi/coll/oputil.h 2009-03-20 02:47:27 UTC (rev 4137)
@@ -0,0 +1,251 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2009 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+/* The MPI Standard (MPI-2.1, sec 5.9.2) defines which predfined reduction
+ operators are valid by groups of types:
+ C integer
+ Fortran integer
+ Floating point
+ Logical
+ Complex
+ Byte
+ We define an "x-macro" for each type group. Immediately prior to
+ instantiating any of these macros you should define a valid
+ MPIR_OP_TYPE_MACRO(mpi_type_,c_type_). The primary use for this is to expand
+ a given group's list into a sequence of case statements. The macro
+ MPIR_OP_TYPE_REDUCE_CASE is available as a convenience to generate a case
+ block that performs a reduction with the given operator. */
+#if 0 /* sample usage: */
+#define MPIR_OP_TYPE_MACRO(mpi_type_,c_type_) MPIR_OP_TYPE_REDUCE_CASE(mpi_type_,c_type_,MPIR_MAX)
+/* or */
+#define MPIR_OP_TYPE_MACRO(mpi_type_,c_type_) case (mpi_type_):
+MPIR_OP_TYPE_GROUP(C_INTEGER)
+MPIR_OP_TYPE_GROUP(FORTRAN_INTEGER)
+#endif
+/* op_macro_ is a 2-arg macro or function that preforms the reduction
+ operation on a single element */
+#define MPIR_OP_TYPE_REDUCE_CASE(mpi_type_,c_type_,op_macro_) \
+ for ( i=0; i<len; i++ ) \
+ a[i] = op_macro_(a[i],b[i]); \
+ break; \
+/* helps enforce consistent naming */
+#define MPIR_OP_TYPE_GROUP(group) MPIR_OP_TYPE_GROUP_##group
+/* These macros are used to disable non-existent types. They evaluate to
+ nothing if the particular feature test is false, otherwise they evaluate to
+ the standard macro to be expanded like any other type. */
+/* first define all wrapper macros as empty for possibly non-existent types */
+#define MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_COMPLEX8(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_COMPLEX16(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_LONG_LONG(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_LONG_DOUBLE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_INTEGER1_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_INTEGER2_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_INTEGER4_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_INTEGER8_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_INTEGER16_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_REAL4_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_REAL8_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_REAL16_CTYPE(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_CXX_COMPLEX(mpi_type_,c_type_)
+#define MPIR_OP_TYPE_MACRO_HAVE_CXX_LONG_DOUBLE_COMPLEX(mpi_type_,c_type_)
+/* then redefine them to be valid based on other preprocessor definitions */
+# undef MPIR_OP_TYPE_MACRO_HAVE_COMPLEX8
+# undef MPIR_OP_TYPE_MACRO_HAVE_COMPLEX16
+# define MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+/* These two shouldn't really be gated on HAVE_FORTRAN_BINDING alone. There
+ should instead be an individual test like HAVE_LONG_DOUBLE, etc. */
+# define MPIR_OP_TYPE_MACRO_HAVE_COMPLEX8(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+# define MPIR_OP_TYPE_MACRO_HAVE_COMPLEX16(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(HAVE_LONG_LONG_INT)
+# undef MPIR_OP_TYPE_MACRO_HAVE_LONG_LONG
+# define MPIR_OP_TYPE_MACRO_HAVE_LONG_LONG(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(HAVE_LONG_DOUBLE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_LONG_DOUBLE
+# define MPIR_OP_TYPE_MACRO_HAVE_LONG_DOUBLE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+/* Fortran fixed width integer type support */
+#if defined(MPIR_INTEGER1_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_INTEGER1_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_INTEGER1_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_INTEGER2_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_INTEGER2_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_INTEGER2_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_INTEGER4_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_INTEGER4_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_INTEGER4_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_INTEGER8_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_INTEGER8_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_INTEGER8_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_INTEGER16_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_INTEGER16_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_INTEGER16_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+/* Fortran fixed width floating point type support */
+#if defined(MPIR_REAL4_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_REAL4_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_REAL4_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_REAL8_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_REAL8_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_REAL8_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_REAL16_CTYPE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_REAL16_CTYPE
+# define MPIR_OP_TYPE_MACRO_HAVE_REAL16_CTYPE(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+/* C++ complex types */
+#if defined(MPIR_CXX_COMPLEX_VALUE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_CXX_COMPLEX
+# define MPIR_OP_TYPE_MACRO_HAVE_CXX_COMPLEX(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+#if defined(MPIR_CXX_LONG_DOUBLE_COMPLEX_VALUE)
+# undef MPIR_OP_TYPE_MACRO_HAVE_CXX_LONG_DOUBLE_COMPLEX
+# define MPIR_OP_TYPE_MACRO_HAVE_CXX_LONG_DOUBLE_COMPLEX(mpi_type_,c_type_) MPIR_OP_TYPE_MACRO(mpi_type_,c_type_)
+#endif
+/* C types needed to support some of the complex types.
+ FIXME These are a hack in most cases, but they seem to work in practice
+ and it's what we were doing prior to the oputil.h refactoring. */
+typedef struct {
+ float re;
+ float im;
+} s_complex;
+typedef struct {
+ double re;
+ double im;
+} d_complex;
+typedef struct {
+ long double re;
+ long double im;
+} ld_complex;
+#endif
+/* type group macros
+ Implementation note: it is important that no MPI type show up more than once
+ among all the lists. Otherwise it will be easy to end up with two case
+ statements with the same value, which is erroneous in C. Duplicate C types
+ in this list are not a problem. */
+/* c integer group */
+#define MPIR_OP_TYPE_GROUP_C_INTEGER \
+ MPIR_OP_TYPE_MACRO(MPI_INT, int) \
+ MPIR_OP_TYPE_MACRO(MPI_LONG, long) \
+ MPIR_OP_TYPE_MACRO(MPI_SHORT, short) \
+ MPIR_OP_TYPE_MACRO(MPI_UNSIGNED_SHORT, unsigned short) \
+ MPIR_OP_TYPE_MACRO(MPI_UNSIGNED, unsigned) \
+ MPIR_OP_TYPE_MACRO(MPI_UNSIGNED_LONG, unsigned long) \
+ MPIR_OP_TYPE_MACRO_HAVE_LONG_LONG(MPI_LONG_LONG, long long) \
+ MPIR_OP_TYPE_MACRO_HAVE_LONG_LONG(MPI_UNSIGNED_LONG_LONG, unsigned long long) \
+ MPIR_OP_TYPE_MACRO(MPI_SIGNED_CHAR, signed char) \
+ MPIR_OP_TYPE_MACRO(MPI_UNSIGNED_CHAR, unsigned char)
+/* The MPI Standard doesn't include these types in the C integer group for
+ predefined operations but MPICH2 supports them when possible. */
+#define MPIR_OP_TYPE_GROUP_C_INTEGER_EXTRA \
+ MPIR_OP_TYPE_MACRO(MPI_CHAR, char)
+/* fortran integer group */
+#define MPIR_OP_TYPE_GROUP_FORTRAN_INTEGER \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_INTEGER, MPI_Fint)
+/* The MPI Standard doesn't include these types in the Fortran integer group for
+#define MPIR_OP_TYPE_GROUP_FORTRAN_INTEGER_EXTRA \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_CHARACTER, char) \
+ MPIR_OP_TYPE_MACRO_HAVE_INTEGER1_CTYPE(MPI_INTEGER1, MPIR_INTEGER1_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_INTEGER2_CTYPE(MPI_INTEGER2, MPIR_INTEGER2_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_INTEGER4_CTYPE(MPI_INTEGER4, MPIR_INTEGER4_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_INTEGER8_CTYPE(MPI_INTEGER8, MPIR_INTEGER8_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_INTEGER16_CTYPE(MPI_INTEGER16, MPIR_INTEGER16_CTYPE)
+/* floating point group */
+#define MPIR_OP_TYPE_GROUP_FLOATING_POINT \
+ MPIR_OP_TYPE_MACRO(MPI_FLOAT, float) \
+ MPIR_OP_TYPE_MACRO(MPI_DOUBLE, double) \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_REAL, float) \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_DOUBLE_PRECISION, double) \
+ MPIR_OP_TYPE_MACRO_HAVE_LONG_DOUBLE(MPI_LONG_DOUBLE, long double) \
+/* The MPI Standard doesn't include these types in the floating point group for
+#define MPIR_OP_TYPE_GROUP_FLOATING_POINT_EXTRA \
+ MPIR_OP_TYPE_MACRO_HAVE_REAL4_CTYPE(MPI_REAL4, MPIR_REAL4_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_REAL8_CTYPE(MPI_REAL8, MPIR_REAL8_CTYPE) \
+ MPIR_OP_TYPE_MACRO_HAVE_REAL16_CTYPE(MPI_REAL16, MPIR_REAL16_CTYPE)
+/* logical group */
+/* FIXME Is MPI_Fint really OK here? */
+#define MPIR_OP_TYPE_GROUP_LOGICAL \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_LOGICAL, MPI_Fint)
+#define MPIR_OP_TYPE_GROUP_LOGICAL_EXTRA /* empty, provided for consistency */
+/* complex group */
+#define MPIR_OP_TYPE_GROUP_COMPLEX \
+ MPIR_OP_TYPE_MACRO_HAVE_FORTRAN(MPI_COMPLEX, s_complex)
+#define MPIR_OP_TYPE_GROUP_COMPLEX_EXTRA \
+ MPIR_OP_TYPE_MACRO_HAVE_COMPLEX8(MPI_COMPLEX8, s_complex) \
+ MPIR_OP_TYPE_MACRO_HAVE_COMPLEX16(MPI_COMPLEX16, d_complex) \
+ MPIR_OP_TYPE_MACRO_HAVE_CXX_COMPLEX(MPIR_CXX_COMPLEX_VALUE, s_complex) \
+ MPIR_OP_TYPE_MACRO_HAVE_CXX_COMPLEX(MPIR_CXX_DOUBLE_COMPLEX_VALUE, d_complex) \
+ MPIR_OP_TYPE_MACRO_HAVE_CXX_LONG_DOUBLE_COMPLEX(MPIR_CXX_LONG_DOUBLE_COMPLEX_VALUE, ld_complex)
+/* byte group */
+#define MPIR_OP_TYPE_GROUP_BYTE \
+ MPIR_OP_TYPE_MACRO(MPI_BYTE, unsigned char)
+#define MPIR_OP_TYPE_GROUP_BYTE_EXTRA /* empty, provided for consistency */
+/* convenience macro that just is all non-extra groups concatenated */
+#define MPIR_OP_TYPE_GROUP_ALL_BASIC \
+ MPIR_OP_TYPE_GROUP(C_INTEGER) \
+ MPIR_OP_TYPE_GROUP(FORTRAN_INTEGER) \
+ MPIR_OP_TYPE_GROUP(FLOATING_POINT) \
+ MPIR_OP_TYPE_GROUP(LOGICAL) \
+ MPIR_OP_TYPE_GROUP(COMPLEX) \
+/* this macro includes just the extra type groups */
+#define MPIR_OP_TYPE_GROUP_ALL_EXTRA \
+ MPIR_OP_TYPE_GROUP(C_INTEGER_EXTRA) \
+ MPIR_OP_TYPE_GROUP(FORTRAN_INTEGER_EXTRA) \
+ MPIR_OP_TYPE_GROUP(FLOATING_POINT_EXTRA) \
+ MPIR_OP_TYPE_GROUP(LOGICAL_EXTRA) \
+ MPIR_OP_TYPE_GROUP(COMPLEX_EXTRA) \
More information about the mpich2-commits
