[mpich2-commits] r4136 - mpich2/trunk/confdb
balaji at mcs.anl.gov
Thu Mar 19 21:46:24 CDT 2009
Author: balaji
Date: 2009-03-19 21:46:22 -0500 (Thu, 19 Mar 2009)
New Revision: 4136
Removed:
mpich2/trunk/confdb/compiler_info.txt
mpich2/trunk/confdb/makestrip
Modified:
mpich2/trunk/confdb/config.guess
mpich2/trunk/confdb/config.sub
mpich2/trunk/confdb/install-sh
Log:
Removing some unnecessary files and updating some more to autoconf-2.62.
Deleted: mpich2/trunk/confdb/compiler_info.txt
--- mpich2/trunk/confdb/compiler_info.txt 2009-03-20 01:57:54 UTC (rev 4135)
+++ mpich2/trunk/confdb/compiler_info.txt 2009-03-20 02:46:22 UTC (rev 4136)
@@ -1,11 +0,0 @@
-# Currently just miscellaneous information
-gcc optimizations:
-x86 -mcpu=pentium -march=pentium or pentiumpro
-IBM -mcpu=powerpc or power2 or power
-SPARC -mcpu=v8 or v9 (Ultra SPARC)
-Intel i32 compiler useful switches:
--cm
--Vaxlib
-<compilerpath>/ia32/lib/icrt.link ???
Modified: mpich2/trunk/confdb/config.guess
--- mpich2/trunk/confdb/config.guess 2009-03-20 01:57:54 UTC (rev 4135)
+++ mpich2/trunk/confdb/config.guess 2009-03-20 02:46:22 UTC (rev 4136)
@@ -1,9 +1,10 @@
#! /bin/sh
# Attempt to guess a canonical system name.
# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
+# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008
+# Free Software Foundation, Inc.
-timestamp='2005-03-24'
+timestamp='2008-03-12'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -17,13 +18,15 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
+# 02110-1301, USA.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
# configuration script generated by Autoconf, you may include it under
# the same distribution terms that you use for the rest of that program.
# Originally written by Per Bothner <per at bothner.com>.
# Please send patches to <config-patches at gnu.org>. Submit a context
# diff and a properly formatted ChangeLog entry.
@@ -53,8 +56,8 @@
GNU config.guess ($timestamp)
Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
-Free Software Foundation, Inc.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -66,11 +69,11 @@
while test $# -gt 0 ; do
case $1 in
--time-stamp | --time* | -t )
- echo "$timestamp" ; exit 0 ;;
+ echo "$timestamp" ; exit ;;
--version | -v )
- echo "$version" ; exit 0 ;;
+ echo "$version" ; exit ;;
--help | --h* | -h )
- echo "$usage"; exit 0 ;;
+ echo "$usage"; exit ;;
-- ) # Stop option processing
shift; break ;;
- ) # Use stdin as input.
@@ -104,7 +107,7 @@
trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
: ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
{ test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
{ tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
{ echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
@@ -123,7 +126,7 @@
,,*) CC_FOR_BUILD=$CC ;;
,*,*) CC_FOR_BUILD=$HOST_CC ;;
-esac ;'
+esac ; set_cc_for_build= ;'
# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
# (ghazi at noc.rutgers.edu 1994-08-24)
@@ -158,6 +161,7 @@
arm*) machine=arm-unknown ;;
sh3el) machine=shl-unknown ;;
sh3eb) machine=sh-unknown ;;
+ sh5el) machine=sh5le-unknown ;;
*) machine=${UNAME_MACHINE_ARCH}-unknown ;;
esac
# The Operating System including object format, if it has switched
@@ -196,55 +200,23 @@
# contains redundant information, the shorter form:
# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
echo "${machine}-${os}${release}"
- exit 0 ;;
- amd64:OpenBSD:*:*)
- echo x86_64-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- amiga:OpenBSD:*:*)
- echo m68k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- cats:OpenBSD:*:*)
- echo arm-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- hp300:OpenBSD:*:*)
- exit 0 ;;
- luna88k:OpenBSD:*:*)
- echo m88k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- mac68k:OpenBSD:*:*)
- exit 0 ;;
- macppc:OpenBSD:*:*)
- echo powerpc-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- mvme68k:OpenBSD:*:*)
- exit 0 ;;
- mvme88k:OpenBSD:*:*)
- exit 0 ;;
- mvmeppc:OpenBSD:*:*)
- exit 0 ;;
- sgi:OpenBSD:*:*)
- echo mips64-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- sun3:OpenBSD:*:*)
- exit 0 ;;
+ exit ;;
*:OpenBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
+ UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
+ echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
+ exit ;;
*:ekkoBSD:*:*)
echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ *:SolidBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-solidbsd${UNAME_RELEASE}
+ exit ;;
macppc:MirBSD:*:*)
- echo powerppc-unknown-mirbsd${UNAME_RELEASE}
- exit 0 ;;
+ echo powerpc-unknown-mirbsd${UNAME_RELEASE}
+ exit ;;
*:MirBSD:*:*)
echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
alpha:OSF1:*:*)
case $UNAME_RELEASE in
*4.0)
@@ -297,40 +269,43 @@
# A Xn.n version is an unreleased experimental baselevel.
# 1.2 uses "1.2" for uname -r.
echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- exit 0 ;;
+ exit ;;
Alpha\ *:Windows_NT*:*)
# How do we know it's Interix rather than the generic POSIX subsystem?
# Should we change UNAME_MACHINE based on the output of uname instead
# of the specific Alpha model?
echo alpha-pc-interix
- exit 0 ;;
+ exit ;;
21064:Windows_NT:50:3)
echo alpha-dec-winnt3.5
- exit 0 ;;
+ exit ;;
Amiga*:UNIX_System_V:4.0:*)
echo m68k-unknown-sysv4
- exit 0;;
+ exit ;;
*:[Aa]miga[Oo][Ss]:*:*)
echo ${UNAME_MACHINE}-unknown-amigaos
- exit 0 ;;
+ exit ;;
*:[Mm]orph[Oo][Ss]:*:*)
echo ${UNAME_MACHINE}-unknown-morphos
- exit 0 ;;
+ exit ;;
*:OS/390:*:*)
echo i370-ibm-openedition
- exit 0 ;;
+ exit ;;
*:z/VM:*:*)
echo s390-ibm-zvmoe
- exit 0 ;;
+ exit ;;
*:OS400:*:*)
echo powerpc-ibm-os400
- exit 0 ;;
+ exit ;;
arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
echo arm-acorn-riscix${UNAME_RELEASE}
- exit 0;;
+ exit ;;
+ arm:riscos:*:*|arm:RISCOS:*:*)
+ echo arm-unknown-riscos
+ exit ;;
SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
echo hppa1.1-hitachi-hiuxmpp
- exit 0;;
+ exit ;;
Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
# akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
if test "`(/bin/universe) 2>/dev/null`" = att ; then
@@ -338,32 +313,32 @@
else
echo pyramid-pyramid-bsd
fi
- exit 0 ;;
+ exit ;;
NILE*:*:*:dcosx)
echo pyramid-pyramid-svr4
- exit 0 ;;
+ exit ;;
DRS?6000:unix:4.0:6*)
echo sparc-icl-nx6
- exit 0 ;;
+ exit ;;
DRS?6000:UNIX_SV:4.2*:7* | DRS?6000:isis:4.2*:7*)
case `/usr/bin/uname -p` in
- sparc) echo sparc-icl-nx7 && exit 0 ;;
+ sparc) echo sparc-icl-nx7; exit ;;
esac ;;
sun4H:SunOS:5.*:*)
echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- i86pc:SunOS:5.*:*)
+ exit ;;
+ i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
sun4*:SunOS:6*:*)
# According to config.sub, this is the proper way to canonicalize
# SunOS6. Hard to guess exactly what SunOS6 will be like, but
# it's likely to be more like Solaris than SunOS4.
echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
sun4*:SunOS:*:*)
case "`/usr/bin/arch -k`" in
Series*|S4*)
@@ -372,10 +347,10 @@
esac
# Japanese Language versions have a version number like `4.1.3-JL'.
echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
- exit 0 ;;
+ exit ;;
sun3*:SunOS:*:*)
echo m68k-sun-sunos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
sun*:*:4.2BSD:*)
UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
@@ -387,10 +362,10 @@
echo sparc-sun-sunos${UNAME_RELEASE}
esac
- exit 0 ;;
+ exit ;;
aushp:SunOS:*:*)
echo sparc-auspex-sunos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
# The situation for MiNT is a little confusing. The machine name
# can be virtually everything (everything which is not
# "atarist" or "atariste" at least should have a processor
@@ -401,40 +376,40 @@
# be no problem.
atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
echo m68k-atari-mint${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
- exit 0 ;;
+ exit ;;
*falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
- exit 0 ;;
+ exit ;;
milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
echo m68k-milan-mint${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
echo m68k-hades-mint${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
echo m68k-unknown-mint${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
m68k:machten:*:*)
echo m68k-apple-machten${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
powerpc:machten:*:*)
echo powerpc-apple-machten${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
RISC*:Mach:*:*)
echo mips-dec-mach_bsd4.3
- exit 0 ;;
+ exit ;;
RISC*:ULTRIX:*:*)
echo mips-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
VAX*:ULTRIX*:*:*)
echo vax-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
2020:CLIX:*:* | 2430:CLIX:*:*)
echo clipper-intergraph-clix${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
mips:*:*:UMIPS | mips:*:*:RISCos)
eval $set_cc_for_build
sed 's/^ //' << EOF >$dummy.c
@@ -458,32 +433,33 @@
exit (-1);
EOF
- $CC_FOR_BUILD -o $dummy $dummy.c \
- && $dummy `echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` \
- && exit 0
+ $CC_FOR_BUILD -o $dummy $dummy.c &&
+ dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
+ SYSTEM_NAME=`$dummy $dummyarg` &&
+ { echo "$SYSTEM_NAME"; exit; }
echo mips-mips-riscos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
Motorola:PowerMAX_OS:*:*)
echo powerpc-motorola-powermax
- exit 0 ;;
+ exit ;;
Motorola:*:4.3:PL8-*)
echo powerpc-harris-powermax
- exit 0 ;;
+ exit ;;
Night_Hawk:*:*:PowerMAX_OS | Synergy:PowerMAX_OS:*:*)
- exit 0 ;;
+ exit ;;
Night_Hawk:Power_UNIX:*:*)
echo powerpc-harris-powerunix
- exit 0 ;;
+ exit ;;
m88k:CX/UX:7*:*)
echo m88k-harris-cxux7
- exit 0 ;;
+ exit ;;
m88k:*:4*:R4*)
echo m88k-motorola-sysv4
- exit 0 ;;
+ exit ;;
m88k:*:3*:R3*)
echo m88k-motorola-sysv3
- exit 0 ;;
+ exit ;;
AViiON:dgux:*:*)
# DG/UX returns AViiON for all architectures
UNAME_PROCESSOR=`/usr/bin/uname -p`
@@ -499,29 +475,29 @@
else
echo i586-dg-dgux${UNAME_RELEASE}
fi
- exit 0 ;;
+ exit ;;
M88*:DolphinOS:*:*) # DolphinOS (SVR3)
echo m88k-dolphin-sysv3
- exit 0 ;;
+ exit ;;
M88*:*:R3*:*)
# Delta 88k system running SVR3
- exit 0 ;;
+ exit ;;
XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
echo m88k-tektronix-sysv3
- exit 0 ;;
+ exit ;;
Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
echo m68k-tektronix-bsd
- exit 0 ;;
+ exit ;;
*:IRIX*:*:*)
echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
- exit 0 ;;
+ exit ;;
????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
- echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
- exit 0 ;; # Note that: echo "'`uname -s`'" gives 'AIX '
+ echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
+ exit ;; # Note that: echo "'`uname -s`'" gives 'AIX '
i*86:AIX:*:*)
echo i386-ibm-aix
- exit 0 ;;
+ exit ;;
ia64:AIX:*:*)
if [ -x /usr/bin/oslevel ] ; then
IBM_REV=`/usr/bin/oslevel`
@@ -529,7 +505,7 @@
IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
fi
echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
- exit 0 ;;
+ exit ;;
*:AIX:2:3)
if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
@@ -544,15 +520,19 @@
exit(0);
EOF
- $CC_FOR_BUILD -o $dummy $dummy.c && $dummy && exit 0
- echo rs6000-ibm-aix3.2.5
+ if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
+ then
+ echo "$SYSTEM_NAME"
+ else
+ echo rs6000-ibm-aix3.2.5
+ fi
elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
echo rs6000-ibm-aix3.2.4
else
fi
- exit 0 ;;
- *:AIX:*:[45])
+ exit ;;
+ *:AIX:*:[456])
IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
IBM_ARCH=rs6000
@@ -565,28 +545,28 @@
fi
echo ${IBM_ARCH}-ibm-aix${IBM_REV}
- exit 0 ;;
+ exit ;;
*:AIX:*:*)
echo rs6000-ibm-aix
- exit 0 ;;
+ exit ;;
ibmrt:4.4BSD:*|romp-ibm:BSD:*)
echo romp-ibm-bsd4.4
- exit 0 ;;
+ exit ;;
ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
- exit 0 ;; # report: romp-ibm BSD 4.3
+ exit ;; # report: romp-ibm BSD 4.3
*:BOSX:*:*)
echo rs6000-bull-bosx
- exit 0 ;;
+ exit ;;
DPX/2?00:B.O.S.:*:*)
echo m68k-bull-sysv3
- exit 0 ;;
+ exit ;;
9000/[34]??:4.3bsd:1.*:*)
echo m68k-hp-bsd
- exit 0 ;;
+ exit ;;
hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
echo m68k-hp-bsd4.4
- exit 0 ;;
+ exit ;;
9000/[34678]??:HP-UX:*:*)
HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
case "${UNAME_MACHINE}" in
@@ -648,9 +628,19 @@
esac
if [ ${HP_ARCH} = "hppa2.0w" ]
then
- # avoid double evaluation of $set_cc_for_build
- test -n "$CC_FOR_BUILD" || eval $set_cc_for_build
- if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E -) | grep __LP64__ >/dev/null
+ eval $set_cc_for_build
+ # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
+ # 32-bit code. hppa64-hp-hpux* has the same kernel and a compiler
+ # generating 64-bit code. GNU and HP use different nomenclature:
+ # $ CC_FOR_BUILD=cc ./config.guess
+ # => hppa2.0w-hp-hpux11.23
+ # $ CC_FOR_BUILD="cc +DA2.0w" ./config.guess
+ # => hppa64-hp-hpux11.23
+ if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
+ grep __LP64__ >/dev/null
then
HP_ARCH="hppa2.0w"
else
@@ -658,11 +648,11 @@
fi
fi
echo ${HP_ARCH}-hp-hpux${HPUX_REV}
- exit 0 ;;
+ exit ;;
ia64:HP-UX:*:*)
echo ia64-hp-hpux${HPUX_REV}
- exit 0 ;;
+ exit ;;
3050*:HI-UX:*:*)
@@ -690,161 +680,192 @@
exit (0);
EOF
+ $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
echo unknown-hitachi-hiuxwe2
- exit 0 ;;
+ exit ;;
9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
echo hppa1.1-hp-bsd
- exit 0 ;;
+ exit ;;
9000/8??:4.3bsd:*:*)
echo hppa1.0-hp-bsd
- exit 0 ;;
+ exit ;;
*9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
echo hppa1.0-hp-mpeix
- exit 0 ;;
+ exit ;;
hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
echo hppa1.1-hp-osf
- exit 0 ;;
+ exit ;;
hp8??:OSF1:*:*)
echo hppa1.0-hp-osf
- exit 0 ;;
+ exit ;;
i*86:OSF1:*:*)
if [ -x /usr/sbin/sysversion ] ; then
echo ${UNAME_MACHINE}-unknown-osf1mk
else
fi
- exit 0 ;;
+ exit ;;
parisc*:Lites*:*:*)
echo hppa1.1-hp-lites
- exit 0 ;;
+ exit ;;
C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
echo c1-convex-bsd
- exit 0 ;;
+ exit ;;
C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
if getsysinfo -f scalar_acc
then echo c32-convex-bsd
else echo c2-convex-bsd
fi
- exit 0 ;;
+ exit ;;
C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
echo c34-convex-bsd
- exit 0 ;;
+ exit ;;
C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
echo c38-convex-bsd
- exit 0 ;;
+ exit ;;
C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
echo c4-convex-bsd
- exit 0 ;;
+ exit ;;
CRAY*Y-MP:*:*:*)
echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
CRAY*[A-Z]90:*:*:*)
echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
| sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
-e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
-e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
CRAY*TS:*:*:*)
echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
CRAY*T3E:*:*:*)
echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
CRAY*SV1:*:*:*)
echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
*:UNICOS/mp:*:*)
echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
+ exit ;;
F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit 0 ;;
+ exit ;;
5000:UNIX_System_V:4.*:*)
FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit 0 ;;
+ exit ;;
i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
sparc*:BSD/OS:*:*)
echo sparc-unknown-bsdi${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:BSD/OS:*:*)
echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:FreeBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit 0 ;;
+ case ${UNAME_MACHINE} in
+ pc98)
+ echo i386-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ amd64)
+ echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ esac
+ exit ;;
i*:CYGWIN*:*)
echo ${UNAME_MACHINE}-pc-cygwin
- exit 0 ;;
- i*:MINGW*:*)
+ exit ;;
+ *:MINGW*:*)
echo ${UNAME_MACHINE}-pc-mingw32
- exit 0 ;;
+ exit ;;
+ i*:windows32*:*)
+ # uname -m includes "-pc" on this system.
+ echo ${UNAME_MACHINE}-mingw32
+ exit ;;
i*:PW*:*)
echo ${UNAME_MACHINE}-pc-pw32
- exit 0 ;;
- x86:Interix*:[34]*)
- echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
- exit 0 ;;
+ exit ;;
+ *:Interix*:[3456]*)
+ x86)
+ echo i586-pc-interix${UNAME_RELEASE}
+ exit ;;
+ EM64T | authenticamd)
+ echo x86_64-unknown-interix${UNAME_RELEASE}
+ exit ;;
+ IA64)
+ echo ia64-unknown-interix${UNAME_RELEASE}
+ exit ;;
+ esac ;;
[345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
echo i${UNAME_MACHINE}-pc-mks
- exit 0 ;;
+ exit ;;
i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
# It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
# UNAME_MACHINE based on the output of uname instead of i386?
- exit 0 ;;
+ exit ;;
i*:UWIN*:*)
echo ${UNAME_MACHINE}-pc-uwin
- exit 0 ;;
- amd64:CYGWIN*:*:*)
+ exit ;;
+ amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
echo x86_64-unknown-cygwin
- exit 0 ;;
+ exit ;;
p*:CYGWIN*:*)
echo powerpcle-unknown-cygwin
- exit 0 ;;
+ exit ;;
prep*:SunOS:5.*:*)
echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
*:GNU:*:*)
# the GNU system
echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
- exit 0 ;;
+ exit ;;
*:GNU/*:*:*)
# other systems with GNU libc and userland
echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
- exit 0 ;;
+ exit ;;
i*86:Minix:*:*)
echo ${UNAME_MACHINE}-pc-minix
- exit 0 ;;
+ exit ;;
arm*:Linux:*:*)
+ if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep -q __ARM_EABI__
+ then
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ else
+ echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+ fi
+ exit ;;
+ avr32*:Linux:*:*)
- exit 0 ;;
+ exit ;;
cris:Linux:*:*)
echo cris-axis-linux-gnu
- exit 0 ;;
+ exit ;;
crisv32:Linux:*:*)
echo crisv32-axis-linux-gnu
- exit 0 ;;
+ exit ;;
frv:Linux:*:*)
echo frv-unknown-linux-gnu
- exit 0 ;;
+ exit ;;
ia64:Linux:*:*)
- exit 0 ;;
+ exit ;;
m32r*:Linux:*:*)
- exit 0 ;;
+ exit ;;
m68*:Linux:*:*)
- exit 0 ;;
+ exit ;;
mips:Linux:*:*)
@@ -861,8 +882,12 @@
#endif
#endif
EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
- test x"${CPU}" != x && echo "${CPU}-unknown-linux-gnu" && exit 0
+ eval "`$CC_FOR_BUILD -E $dummy.c 2>/dev/null | sed -n '
+ /^CPU/{
+ s: ::g
+ p
+ test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
mips64:Linux:*:*)
@@ -880,15 +905,22 @@
#endif
#endif
EOF
+ /^CPU/{
+ s: ::g
+ p
+ or32:Linux:*:*)
+ echo or32-unknown-linux-gnu
+ exit ;;
ppc:Linux:*:*)
echo powerpc-unknown-linux-gnu
- exit 0 ;;
+ exit ;;
ppc64:Linux:*:*)
echo powerpc64-unknown-linux-gnu
- exit 0 ;;
+ exit ;;
alpha:Linux:*:*)
case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
EV5) UNAME_MACHINE=alphaev5 ;;
@@ -902,7 +934,7 @@
objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
- exit 0 ;;
+ exit ;;
parisc:Linux:*:* | hppa:Linux:*:*)
# Look for CPU level
case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
@@ -910,25 +942,31 @@
PA8*) echo hppa2.0-unknown-linux-gnu ;;
*) echo hppa-unknown-linux-gnu ;;
esac
- exit 0 ;;
+ exit ;;
parisc64:Linux:*:* | hppa64:Linux:*:*)
echo hppa64-unknown-linux-gnu
- exit 0 ;;
+ exit ;;
s390:Linux:*:* | s390x:Linux:*:*)
echo ${UNAME_MACHINE}-ibm-linux
- exit 0 ;;
+ exit ;;
sh64*:Linux:*:*)
- exit 0 ;;
+ exit ;;
sh*:Linux:*:*)
- exit 0 ;;
+ exit ;;
sparc:Linux:*:* | sparc64:Linux:*:*)
- exit 0 ;;
+ exit ;;
+ vax:Linux:*:*)
+ echo ${UNAME_MACHINE}-dec-linux-gnu
+ exit ;;
x86_64:Linux:*:*)
echo x86_64-unknown-linux-gnu
- exit 0 ;;
+ exit ;;
+ xtensa*:Linux:*:*)
+ exit ;;
i*86:Linux:*:*)
# The BFD linker knows what the default object file format is, so
# first see if it will tell us. cd to the root directory to prevent
@@ -946,15 +984,15 @@
a.out-i386-linux)
echo "${UNAME_MACHINE}-pc-linux-gnuaout"
- exit 0 ;;
+ exit ;;
coff-i386)
echo "${UNAME_MACHINE}-pc-linux-gnucoff"
- exit 0 ;;
+ exit ;;
# Either a pre-BFD a.out linker (linux-gnuoldld) or
# one that does not give us useful --help.
echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
- exit 0 ;;
+ exit ;;
esac
# Determine whether the default compiler is a.out or elf
@@ -971,7 +1009,7 @@
LIBC=gnulibc1
# endif
#else
- #ifdef __INTEL_COMPILER
+ #if defined(__INTEL_COMPILER) || defined(__PGI) || defined(__SUNPRO_C) || defined(__SUNPRO_CC)
LIBC=gnu
#else
LIBC=gnuaout
@@ -981,16 +1019,23 @@
LIBC=dietlibc
#endif
EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
- test x"${LIBC}" != x && echo "${UNAME_MACHINE}-pc-linux-${LIBC}" && exit 0
- test x"${TENTATIVE}" != x && echo "${TENTATIVE}" && exit 0
+ /^LIBC/{
+ s: ::g
+ p
+ test x"${LIBC}" != x && {
+ echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+ exit
+ test x"${TENTATIVE}" != x && { echo "${TENTATIVE}"; exit; }
i*86:DYNIX/ptx:4*:*)
# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
# earlier versions are messed up and put the nodename in both
# sysname and nodename.
echo i386-sequent-sysv4
- exit 0 ;;
+ exit ;;
i*86:UNIX_SV:4.2MP:2.*)
# Unixware is an offshoot of SVR4, but it has its own version
# number series starting with 2...
@@ -998,27 +1043,27 @@
# I just have to hope. -- rms.
# Use sysv4.2uw... so that sysv4* matches it.
echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
- exit 0 ;;
+ exit ;;
i*86:OS/2:*:*)
# If we were able to find `uname', then EMX Unix compatibility
# is probably installed.
echo ${UNAME_MACHINE}-pc-os2-emx
- exit 0 ;;
+ exit ;;
i*86:XTS-300:*:STOP)
echo ${UNAME_MACHINE}-unknown-stop
- exit 0 ;;
+ exit ;;
i*86:atheos:*:*)
echo ${UNAME_MACHINE}-unknown-atheos
- exit 0 ;;
- i*86:syllable:*:*)
+ exit ;;
+ i*86:syllable:*:*)
echo ${UNAME_MACHINE}-pc-syllable
- exit 0 ;;
+ exit ;;
i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
echo i386-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
i*86:*DOS:*:*)
echo ${UNAME_MACHINE}-pc-msdosdjgpp
- exit 0 ;;
+ exit ;;
i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
@@ -1026,15 +1071,16 @@
else
echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
fi
- exit 0 ;;
- i*86:*:5:[78]*)
+ exit ;;
+ i*86:*:5:[678]*)
+ # UnixWare 7.x, OpenUNIX and OpenServer 6.
case `/bin/uname -X | grep "^Machine"` in
*486*) UNAME_MACHINE=i486 ;;
*Pentium) UNAME_MACHINE=i586 ;;
*Pent*|*Celeron) UNAME_MACHINE=i686 ;;
esac
echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
- exit 0 ;;
+ exit ;;
i*86:*:3.2:*)
if test -f /usr/options/cb.name; then
UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
@@ -1052,73 +1098,73 @@
else
echo ${UNAME_MACHINE}-pc-sysv32
fi
- exit 0 ;;
+ exit ;;
pc:*:*:*)
# Left here for compatibility:
# uname -m prints for DJGPP always 'pc', but it prints nothing about
# the processor, so we play safe by assuming i386.
echo i386-pc-msdosdjgpp
- exit 0 ;;
+ exit ;;
Intel:Mach:3*:*)
echo i386-pc-mach3
- exit 0 ;;
+ exit ;;
paragon:*:*:*)
echo i860-intel-osf1
- exit 0 ;;
+ exit ;;
i860:*:4.*:*) # i860-SVR4
if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
else # Add other i860-SVR4 vendors below as they are discovered.
echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
fi
- exit 0 ;;
+ exit ;;
mini*:CTIX:SYS*5:*)
# "miniframe"
echo m68010-convergent-sysv
- exit 0 ;;
+ exit ;;
mc68k:UNIX:SYSTEM5:3.51m)
echo m68k-convergent-sysv
- exit 0 ;;
+ exit ;;
M680?0:D-NIX:5.3:*)
echo m68k-diab-dnix
- exit 0 ;;
+ exit ;;
M68*:*:R3V[5678]*:*)
- test -r /sysV68 && echo 'm68k-motorola-sysv' && exit 0 ;;
+ test -r /sysV68 && { echo 'm68k-motorola-sysv'; exit; } ;;
3[345]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0 | SDS2:*:4.0:3.0 | SHG2:*:4.0:3.0 | S7501*:*:4.0:3.0)
OS_REL=''
test -r /etc/.relid \
&& OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
/bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && echo i486-ncr-sysv4.3${OS_REL} && exit 0
+ && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
- && echo i586-ncr-sysv4.3${OS_REL} && exit 0 ;;
+ && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- && echo i486-ncr-sysv4 && exit 0 ;;
+ && { echo i486-ncr-sysv4; exit; } ;;
m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
echo m68k-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
mc68030:UNIX_System_V:4.*:*)
echo m68k-atari-sysv4
- exit 0 ;;
+ exit ;;
TSUNAMI:LynxOS:2.*:*)
echo sparc-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
rs6000:LynxOS:2.*:*)
echo rs6000-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
echo powerpc-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
SM[BE]S:UNIX_SV:*:*)
echo mips-dde-sysv${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
RM*:ReliantUNIX-*:*:*)
echo mips-sni-sysv4
- exit 0 ;;
+ exit ;;
RM*:SINIX-*:*:*)
echo mips-sni-sysv4
- exit 0 ;;
+ exit ;;
*:SINIX-*:*:*)
if uname -p 2>/dev/null >/dev/null ; then
UNAME_MACHINE=`(uname -p) 2>/dev/null`
@@ -1126,69 +1172,84 @@
else
echo ns32k-sni-sysv
fi
- exit 0 ;;
+ exit ;;
PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
# says <Richard.M.Bartel at ccMail.Census.GOV>
echo i586-unisys-sysv4
- exit 0 ;;
+ exit ;;
*:UNIX_System_V:4*:FTX*)
# From Gerald Hewes <hewes at openmarket.com>.
# How about differentiating between stratus architectures? -djm
echo hppa1.1-stratus-sysv4
- exit 0 ;;
+ exit ;;
*:*:*:FTX*)
# From seanf at swdc.stratus.com.
echo i860-stratus-sysv4
- exit 0 ;;
+ exit ;;
+ i*86:VOS:*:*)
+ # From Paul.Green at stratus.com.
+ echo ${UNAME_MACHINE}-stratus-vos
+ exit ;;
*:VOS:*:*)
echo hppa1.1-stratus-vos
- exit 0 ;;
+ exit ;;
mc68*:A/UX:*:*)
echo m68k-apple-aux${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
news*:NEWS-OS:6*:*)
echo mips-sony-newsos6
- exit 0 ;;
+ exit ;;
R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
if [ -d /usr/nec ]; then
echo mips-nec-sysv${UNAME_RELEASE}
else
echo mips-unknown-sysv${UNAME_RELEASE}
fi
- exit 0 ;;
+ exit ;;
BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
echo powerpc-be-beos
- exit 0 ;;
+ exit ;;
BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
echo powerpc-apple-beos
- exit 0 ;;
+ exit ;;
BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
echo i586-pc-beos
- exit 0 ;;
+ exit ;;
+ BePC:Haiku:*:*) # Haiku running on Intel PC compatible.
+ echo i586-pc-haiku
+ exit ;;
SX-4:SUPER-UX:*:*)
echo sx4-nec-superux${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
SX-5:SUPER-UX:*:*)
echo sx5-nec-superux${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
SX-6:SUPER-UX:*:*)
echo sx6-nec-superux${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ SX-7:SUPER-UX:*:*)
+ echo sx7-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-8:SUPER-UX:*:*)
+ echo sx8-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-8R:SUPER-UX:*:*)
+ echo sx8r-nec-superux${UNAME_RELEASE}
+ exit ;;
Power*:Rhapsody:*:*)
echo powerpc-apple-rhapsody${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:Rhapsody:*:*)
echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:Darwin:*:*)
UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
case $UNAME_PROCESSOR in
- *86) UNAME_PROCESSOR=i686 ;;
unknown) UNAME_PROCESSOR=powerpc ;;
esac
echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:procnto*:*:* | *:QNX:[0123456789]*:*)
if test "$UNAME_PROCESSOR" = "x86"; then
@@ -1196,25 +1257,25 @@
UNAME_MACHINE=pc
fi
echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:QNX:*:4*)
echo i386-pc-qnx
- exit 0 ;;
+ exit ;;
NSE-?:NONSTOP_KERNEL:*:*)
echo nse-tandem-nsk${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
NSR-?:NONSTOP_KERNEL:*:*)
echo nsr-tandem-nsk${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:NonStop-UX:*:*)
echo mips-compaq-nonstopux
- exit 0 ;;
+ exit ;;
BS2000:POSIX*:*:*)
echo bs2000-siemens-sysv
- exit 0 ;;
+ exit ;;
DS/*:UNIX_System_V:*:*)
echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:Plan9:*:*)
# "uname -m" is not consistent, so use $cputype instead. 386
# is converted to i386 for consistency with other x86
@@ -1225,41 +1286,47 @@
UNAME_MACHINE="$cputype"
fi
echo ${UNAME_MACHINE}-unknown-plan9
- exit 0 ;;
+ exit ;;
*:TOPS-10:*:*)
echo pdp10-unknown-tops10
- exit 0 ;;
+ exit ;;
*:TENEX:*:*)
echo pdp10-unknown-tenex
- exit 0 ;;
+ exit ;;
KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
echo pdp10-dec-tops20
- exit 0 ;;
+ exit ;;
XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
echo pdp10-xkl-tops20
- exit 0 ;;
+ exit ;;
*:TOPS-20:*:*)
echo pdp10-unknown-tops20
- exit 0 ;;
+ exit ;;
*:ITS:*:*)
echo pdp10-unknown-its
- exit 0 ;;
+ exit ;;
SEI:*:*:SEIUX)
echo mips-sei-seiux${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
*:DragonFly:*:*)
echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit 0 ;;
+ exit ;;
*:*VMS:*:*)
- A*) echo alpha-dec-vms && exit 0 ;;
- I*) echo ia64-dec-vms && exit 0 ;;
- V*) echo vax-dec-vms && exit 0 ;;
+ A*) echo alpha-dec-vms ; exit ;;
+ I*) echo ia64-dec-vms ; exit ;;
+ V*) echo vax-dec-vms ; exit ;;
esac ;;
*:XENIX:*:SysV)
echo i386-pc-xenix
- exit 0 ;;
+ exit ;;
+ i*86:skyos:*:*)
+ echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
+ exit ;;
+ i*86:rdos:*:*)
+ echo ${UNAME_MACHINE}-pc-rdos
+ exit ;;
esac
#echo '(No uname command or uname output not recognized.)' 1>&2
@@ -1291,7 +1358,7 @@
#endif
#if defined (__arm) && defined (__acorn) && defined (__unix)
- printf ("arm-acorn-riscix"); exit (0);
+ printf ("arm-acorn-riscix\n"); exit (0);
#endif
#if defined (hp300) && !defined (hpux)
@@ -1380,11 +1447,12 @@
EOF
-$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && $dummy && exit 0
+$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit 0; }
+test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
# Convex versions that predate uname can use getsysinfo(1)
@@ -1393,22 +1461,22 @@
case `getsysinfo -f cpu_type` in
c1*)
echo c1-convex-bsd
- exit 0 ;;
+ exit ;;
c2*)
fi
- exit 0 ;;
+ exit ;;
c34*)
echo c34-convex-bsd
- exit 0 ;;
+ exit ;;
c38*)
echo c38-convex-bsd
- exit 0 ;;
+ exit ;;
c4*)
echo c4-convex-bsd
- exit 0 ;;
+ exit ;;
esac
fi
@@ -1419,9 +1487,9 @@
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
+ http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
and
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
+ http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
If the version you run ($0) is already up to date, please
send the following data and any information you think might be
Modified: mpich2/trunk/confdb/config.sub
--- mpich2/trunk/confdb/config.sub 2009-03-20 01:57:54 UTC (rev 4135)
+++ mpich2/trunk/confdb/config.sub 2009-03-20 02:46:22 UTC (rev 4136)
@@ -1,9 +1,10 @@
#! /bin/sh
# Configuration validation subroutine script.
-timestamp='2005-02-10'
+timestamp='2008-03-26'
# This file is (in principle) common to ALL GNU software.
# The presence of a machine in this file suggests that SOME GNU software
@@ -21,14 +22,15 @@
-# Boston, MA 02111-1307, USA.
+# 02110-1301, USA.
@@ -70,8 +72,8 @@
version="\
GNU config.sub ($timestamp)
@@ -83,11 +85,11 @@
case $1 in
--version | -v )
shift; break ;;
@@ -99,7 +101,7 @@
*local*)
# First pass through any local machine types.
echo $1
- exit 0;;
+ exit ;;
break ;;
@@ -118,8 +120,9 @@
# Here we must recognize all the valid KERNEL-OS combinations.
maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
case $maybe_os in
- nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
- kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
+ nto-qnx* | linux-gnu* | linux-dietlibc | linux-newlib* | linux-uclibc* | \
+ uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | \
+ storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -170,6 +173,10 @@
-hiux*)
os=-hiuxwe2
+ -sco6)
+ os=-sco5v6
+ basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
-sco5)
os=-sco3.2v5
@@ -186,6 +193,10 @@
# Don't forget version if it is 3.2v4 or newer.
+ -sco5v6*)
+ # Don't forget version if it is 3.2v4 or newer.
-sco*)
os=-sco3.2v2
@@ -230,22 +241,27 @@
| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
| am33_2.0 \
- | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+ | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr | avr32 \
+ | bfin \
| c4x | clipper \
| d10v | d30v | dlx | dsp16xx \
- | fr30 | frv \
+ | fido | fr30 | frv \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
| i370 | i860 | i960 | ia64 \
| ip2k | iq2000 \
- | m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
+ | m32c | m32r | m32rle | m68000 | m68k | m88k \
+ | maxq | mb | microblaze | mcore | mep | metag \
| mips | mipsbe | mipseb | mipsel | mipsle \
| mips16 \
| mips64 | mips64el \
+ | mips64octeon | mips64octeonel \
+ | mips64orion | mips64orionel \
+ | mips64r5900 | mips64r5900el \
| mips64vr | mips64vrel \
- | mips64orion | mips64orionel \
| mips64vr4100 | mips64vr4100el \
| mips64vr4300 | mips64vr4300el \
| mips64vr5000 | mips64vr5000el \
+ | mips64vr5900 | mips64vr5900el \
| mipsisa32 | mipsisa32el \
| mipsisa32r2 | mipsisa32r2el \
| mipsisa64 | mipsisa64el \
@@ -254,20 +270,24 @@
| mipsisa64sr71k | mipsisa64sr71kel \
| mipstx39 | mipstx39el \
| mn10200 | mn10300 \
+ | mt \
| msp430 \
+ | nios | nios2 \
| ns16k | ns32k \
- | openrisc | or32 \
+ | or32 \
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
| pyramid \
- | sh | sh[1234] | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+ | score \
+ | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
| sh64 | sh64le \
- | sparc | sparc64 | sparc86x | sparclet | sparclite | sparcv8 | sparcv9 | sparcv9b \
- | strongarm \
+ | sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
+ | sparcv8 | sparcv9 | sparcv9b | sparcv9v \
+ | spu | strongarm \
| tahoe | thumb | tic4x | tic80 | tron \
| v850 | v850e \
| we32k \
- | x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
+ | x86 | xc16x | xscale | xscalee[bl] | xstormy16 | xtensa \
| z8k)
basic_machine=$basic_machine-unknown
@@ -278,6 +298,9 @@
m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+ ms1)
+ basic_machine=mt-unknown
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
@@ -297,28 +320,31 @@
| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
| arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* \
- | bs2000-* \
+ | avr-* | avr32-* \
+ | bfin-* | bs2000-* \
| c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
| clipper-* | craynv-* | cydra-* \
| d10v-* | d30v-* | dlx-* \
| elxsi-* \
- | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+ | f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
| h8300-* | h8500-* \
| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
| i*86-* | i860-* | i960-* | ia64-* \
| ip2k-* | iq2000-* \
- | m32r-* | m32rle-* \
+ | m32c-* | m32r-* | m32rle-* \
| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* \
+ | m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
| mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
| mips16-* \
| mips64-* | mips64el-* \
+ | mips64octeon-* | mips64octeonel-* \
+ | mips64orion-* | mips64orionel-* \
+ | mips64r5900-* | mips64r5900el-* \
| mips64vr-* | mips64vrel-* \
- | mips64orion-* | mips64orionel-* \
| mips64vr4100-* | mips64vr4100el-* \
| mips64vr4300-* | mips64vr4300el-* \
| mips64vr5000-* | mips64vr5000el-* \
+ | mips64vr5900-* | mips64vr5900el-* \
| mipsisa32-* | mipsisa32el-* \
| mipsisa32r2-* | mipsisa32r2el-* \
| mipsisa64-* | mipsisa64el-* \
@@ -327,27 +353,34 @@
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
| mipstx39-* | mipstx39el-* \
| mmix-* \
+ | mt-* \
| msp430-* \
+ | nios-* | nios2-* \
| none-* | np1-* | ns16k-* | ns32k-* \
| orion-* \
| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
| pyramid-* \
| romp-* | rs6000-* \
- | sh-* | sh[1234]-* | sh[23]e-* | sh[34]eb-* | shbe-* \
+ | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc86x-* | sparclet-* | sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+ | sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
+ | sparclite-* \
+ | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | strongarm-* | sv1-* | sx?-* \
| tahoe-* | thumb-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+ | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* | tile-* \
| tron-* \
| v850-* | v850e-* | vax-* \
| we32k-* \
- | x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
- | xstormy16-* | xtensa-* \
+ | x86-* | x86_64-* | xc16x-* | xps100-* | xscale-* | xscalee[bl]-* \
+ | xstormy16-* | xtensa*-* \
| ymp-* \
| z8k-*)
+ # Recognize the basic CPU types without company name, with glob match.
+ xtensa*)
+ basic_machine=$basic_machine-unknown
# Recognize the various machine names and aliases which stand
# for a CPU type and a company and sometimes even an OS.
386bsd)
@@ -418,6 +451,14 @@
basic_machine=ns32k-sequent
os=-dynix
+ blackfin)
+ basic_machine=bfin-unknown
+ os=-linux
+ blackfin-*)
+ basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
c90)
basic_machine=c90-cray
os=-unicos
@@ -450,8 +491,8 @@
basic_machine=craynv-cray
os=-unicosmp
- cr16c)
- basic_machine=cr16c-unknown
+ cr16)
+ basic_machine=cr16-unknown
os=-elf
crds | unos)
@@ -643,6 +684,14 @@
basic_machine=m68k-isi
os=-sysv
+ m68knommu)
+ basic_machine=m68k-unknown
+ os=-linux
+ m68knommu-*)
+ basic_machine=m68k-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
m88k-omron*)
basic_machine=m88k-omron
@@ -658,6 +707,10 @@
basic_machine=i386-pc
os=-mingw32
+ mingw32ce)
+ basic_machine=arm-unknown
+ os=-mingw32ce
miniframe)
basic_machine=m68000-convergent
@@ -683,6 +736,9 @@
os=-msdos
+ ms1-*)
+ basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
mvs)
basic_machine=i370-ibm
os=-mvs
@@ -758,9 +814,8 @@
basic_machine=hppa1.1-oki
os=-proelf
- or32 | or32-*)
+ openrisc | openrisc-*)
basic_machine=or32-unknown
- os=-coff
os400)
basic_machine=powerpc-ibm
@@ -782,6 +837,14 @@
basic_machine=i860-intel
os=-osf
+ parisc)
+ basic_machine=hppa-unknown
+ os=-linux
+ parisc-*)
+ basic_machine=hppa-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
pbd)
basic_machine=sparc-tti
@@ -791,6 +854,12 @@
pc532 | pc532-*)
basic_machine=ns32k-pc532
+ pc98)
+ basic_machine=i386-pc
+ pc98-*)
+ basic_machine=i386-`echo $basic_machine | sed 's/^[^-]*-//'`
pentium | p5 | k5 | k6 | nexgen | viac3)
basic_machine=i586-pc
@@ -847,6 +916,10 @@
basic_machine=i586-unknown
os=-pw32
+ rdos)
+ os=-rdos
rom68k)
basic_machine=m68k-rom68k
os=-coff
@@ -873,6 +946,10 @@
sb1el)
basic_machine=mipsisa64sb1el-unknown
+ sde)
+ basic_machine=mipsisa32-sde
+ os=-elf
sei)
basic_machine=mips-sei
os=-seiux
@@ -884,6 +961,9 @@
basic_machine=sh-hitachi
os=-hms
+ sh5el)
+ basic_machine=sh5le-unknown
sh64)
basic_machine=sh64-unknown
@@ -973,6 +1053,10 @@
basic_machine=tic6x-unknown
os=-coff
+ tile*)
+ basic_machine=tile-unknown
+ os=-linux-gnu
tx39)
basic_machine=mipstx39-unknown
@@ -1086,13 +1170,10 @@
we32k)
basic_machine=we32k-att
- sh3 | sh4 | sh[34]eb | sh[1234]le | sh[23]ele)
+ sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
basic_machine=sh-unknown
- sh64)
- basic_machine=sh64-unknown
- sparc | sparcv8 | sparcv9 | sparcv9b)
+ sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
basic_machine=sparc-sun
cydra)
@@ -1165,20 +1246,23 @@
| -aos* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
+ | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
+ | -openbsd* | -solidbsd* \
| -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
| -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
| -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
| -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
| -chorusos* | -chorusrdb* \
| -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -mingw32* | -linux-gnu* | -linux-newlib* | -linux-uclibc* \
+ | -uxpv* | -beos* | -mpeix* | -udk* \
| -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
| -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
| -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
| -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
| -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
- | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly*)
+ | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
+ | -skyos* | -haiku* | -rdos* | -toppers* | -drops*)
# Remember, each alternative MUST END IN *, to match a version number.
-qnx*)
@@ -1196,7 +1280,7 @@
os=`echo $os | sed -e 's|nto|nto-qnx|'`
-sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
- | -windows* | -osx | -abug | -netware* | -os9* | -beos* \
+ | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
| -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
-mac*)
@@ -1330,6 +1414,12 @@
# system, and we'll never get to this point.
case $basic_machine in
+ score-*)
+ os=-elf
+ spu-*)
+ os=-elf
*-acorn)
os=-riscix1.2
@@ -1339,9 +1429,9 @@
arm*-semi)
os=-aout
- c4x-* | tic4x-*)
- os=-coff
+ c4x-* | tic4x-*)
+ os=-coff
# This must come before the *-dec entry.
pdp10-*)
os=-tops20
@@ -1367,6 +1457,9 @@
m68*-cisco)
os=-aout
+ mep-*)
+ os=-elf
mips*-cisco)
os=-elf
@@ -1385,6 +1478,9 @@
*-be)
os=-beos
+ *-haiku)
+ os=-haiku
*-ibm)
os=-aix
@@ -1556,7 +1652,7 @@
esac
echo $basic_machine$os
-exit 0
+exit
# Local variables:
# eval: (add-hook 'write-file-hooks 'time-stamp)
Modified: mpich2/trunk/confdb/install-sh
--- mpich2/trunk/confdb/install-sh 2009-03-20 01:57:54 UTC (rev 4135)
+++ mpich2/trunk/confdb/install-sh 2009-03-20 02:46:22 UTC (rev 4136)
@@ -1,251 +1,519 @@
#!/bin/sh
# install - install a program, script, or datafile
-# This comes from X11R5 (mit/util/scripts/install.sh).
+scriptversion=2006-12-25.00
+# This originates from X11R5 (mit/util/scripts/install.sh), which was
+# later released in X11R6 (xc/config/util/install.sh) with the
+# following copyright and license.
-# Copyright 1991 by the Massachusetts Institute of Technology
+# Copyright (C) 1994 X Consortium
-# Permission to use, copy, modify, distribute, and sell this software and its
-# documentation for any purpose is hereby granted without fee, provided that
-# the above copyright notice appear in all copies and that both that
-# copyright notice and this permission notice appear in supporting
-# documentation, and that the name of M.I.T. not be used in advertising or
-# publicity pertaining to distribution of the software without specific,
-# written prior permission. M.I.T. makes no representations about the
-# suitability of this software for any purpose. It is provided "as is"
-# without express or implied warranty.
+# Permission is hereby granted, free of charge, to any person obtaining a copy
+# of this software and associated documentation files (the "Software"), to
+# deal in the Software without restriction, including without limitation the
+# rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
+# sell copies of the Software, and to permit persons to whom the Software is
+# furnished to do so, subject to the following conditions:
+# The above copyright notice and this permission notice shall be included in
+# all copies or substantial portions of the Software.
+# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+# X CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN
+# AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNEC-
+# TION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+# Except as contained in this notice, the name of the X Consortium shall not
+# be used in advertising or otherwise to promote the sale, use or other deal-
+# ings in this Software without prior written authorization from the X Consor-
+# tium.
+# FSF changes to this file are in the public domain.
# Calling this script install-sh is preferred over install.sh, to prevent
# `make' implicit rules from creating a file called install from it
# when there is no Makefile.
# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
+# from scratch.
+nl='
+IFS=" "" $nl"
# set DOITPROG to echo to test this script
# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
+doit=${DOITPROG-}
+if test -z "$doit"; then
+ doit_exec=exec
+else
+ doit_exec=$doit
+fi
+# Put in absolute file names if you don't have them in your path;
+# or use environment vars.
-# put in absolute paths if you don't have them in your path; or use env. vars.
+chgrpprog=${CHGRPPROG-chgrp}
+chmodprog=${CHMODPROG-chmod}
+chownprog=${CHOWNPROG-chown}
+cmpprog=${CMPPROG-cmp}
+cpprog=${CPPROG-cp}
+mkdirprog=${MKDIRPROG-mkdir}
+mvprog=${MVPROG-mv}
+rmprog=${RMPROG-rm}
+stripprog=${STRIPPROG-strip}
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
+posix_glob='?'
+initialize_posix_glob='
+ test "$posix_glob" != "?" || {
+ if (set -f) 2>/dev/null; then
+ posix_glob=
+ else
+ posix_glob=:
+ fi
-transformbasename=""
-transform_arg=""
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=""
-chgrpcmd=""
-stripcmd=""
+posix_mkdir=
+# Desired mode of installed file.
+mode=0755
+chgrpcmd=
+chmodcmd=$chmodprog
+chowncmd=
+mvcmd=$mvprog
rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=""
-dst=""
-dir_arg=""
+stripcmd=
-while [ x"$1" != x ]; do
- case $1 in
- -c) instcmd="$cpprog"
- shift
- continue;;
+src=
+dst=
+dir_arg=
+dst_arg=
- -d) dir_arg=true
- shift
- continue;;
+copy_on_change=false
+no_target_directory=
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
+usage="\
+Usage: $0 [OPTION]... [-T] SRCFILE DSTFILE
+ or: $0 [OPTION]... SRCFILES... DIRECTORY
+ or: $0 [OPTION]... -t DIRECTORY SRCFILES...
+ or: $0 [OPTION]... -d DIRECTORIES...
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
+In the 1st form, copy SRCFILE to DSTFILE.
+In the 2nd and 3rd, copy all SRCFILES to DIRECTORY.
+In the 4th, create DIRECTORIES.
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
+Options:
+ --help display this help and exit.
+ --version display version info and exit.
- -s) stripcmd="$stripprog"
- shift
- continue;;
+ -c (ignored)
+ -C install only if different (preserve the last data modification time)
+ -d create directories instead of installing files.
+ -g GROUP $chgrpprog installed files to GROUP.
+ -m MODE $chmodprog installed files to MODE.
+ -o USER $chownprog installed files to USER.
+ -s $stripprog installed files.
+ -t DIRECTORY install into DIRECTORY.
+ -T report an error if DSTFILE is a directory.
- -t=*) transformarg=`echo $1 | sed 's/-t=//'`
- shift
- continue;;
+Environment variables override the default commands:
+ CHGRPPROG CHMODPROG CHOWNPROG CMPPROG CPPROG MKDIRPROG MVPROG
+ RMPROG STRIPPROG
- -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
- shift
- continue;;
+while test $# -ne 0; do
+ case $1 in
+ -c) ;;
- *) if [ x"$src" = x ]
- then
- src=$1
- else
- # this colon is to work around a 386BSD /bin/sh bug
- dst=$1
- fi
- shift
- continue;;
- esac
+ -C) copy_on_change=true;;
+ -d) dir_arg=true;;
+ -g) chgrpcmd="$chgrpprog $2"
+ shift;;
+ --help) echo "$usage"; exit $?;;
+ -m) mode=$2
+ case $mode in
+ echo "$0: invalid mode: $mode" >&2
+ exit 1;;
+ esac
+ shift;;
+ -o) chowncmd="$chownprog $2"
+ shift;;
+ -s) stripcmd=$stripprog;;
+ -t) dst_arg=$2
+ shift;;
+ -T) no_target_directory=true;;
+ --version) echo "$0 $scriptversion"; exit $?;;
+ --) shift
+ break;;
+ -*) echo "$0: invalid option: $1" >&2
+ exit 1;;
+ *) break;;
+ esac
+ shift
done
-if [ x"$src" = x ]
-then
- echo "install: no input file specified"
- exit 1
-else
+if test $# -ne 0 && test -z "$dir_arg$dst_arg"; then
+ # When -d is used, all remaining arguments are directories to create.
+ # When -t is used, the destination is already specified.
+ # Otherwise, the last argument is the destination. Remove it from $@.
+ for arg
+ do
+ if test -n "$dst_arg"; then
+ # $@ is not empty: it contains at least $arg.
+ set fnord "$@" "$dst_arg"
+ shift # fnord
+ fi
+ shift # arg
+ dst_arg=$arg
+ done
fi
-if [ x"$dir_arg" != x ]; then
- dst=$src
- src=""
- if [ -d $dst ]; then
- instcmd=:
- chmodcmd=""
- else
- instcmd=$mkdirprog
- fi
-else
+if test $# -eq 0; then
+ if test -z "$dir_arg"; then
+ echo "$0: no input file specified." >&2
+ exit 1
+ fi
+ # It's OK to call `install-sh -d' without argument.
+ # This can happen when creating conditional directories.
+ exit 0
+fi
-# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-# might cause directories to be created, which would be especially bad
-# if $src (and thus $dsttmp) contains '*'.
+if test -z "$dir_arg"; then
+ trap '(exit $?); exit' 1 2 13 15
- if [ -f $src -o -d $src ]
- then
- else
- echo "install: $src does not exist"
- exit 1
- fi
- if [ x"$dst" = x ]
- then
- echo "install: no destination specified"
- exit 1
- else
- fi
+ # Set umask so as not to create temps with too-generous modes.
+ # However, 'strip' requires both read and write access to temps.
+ case $mode in
+ # Optimize common cases.
+ *644) cp_umask=133;;
+ *755) cp_umask=22;;
-# If destination is a directory, append the input filename; if your system
-# does not like double slashes in filenames, you may need to add some logic
- if [ -d $dst ]
- then
- dst="$dst"/`basename $src`
- else
- fi
+ *[0-7])
+ if test -z "$stripcmd"; then
+ u_plus_rw=
+ else
+ u_plus_rw='% 200'
+ fi
+ cp_umask=`expr '(' 777 - $mode % 1000 ')' $u_plus_rw`;;
+ u_plus_rw=
+ else
+ u_plus_rw=,u+rw
+ fi
+ cp_umask=$mode$u_plus_rw;;
+ esac
fi
-## this sed command emulates the dirname command
-dstdir=`echo $dst | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
+for src
+do
+ # Protect names starting with `-'.
+ case $src in
+ -*) src=./$src;;
+ esac
-# Make sure that the destination directory exists.
-# this part is taken from Noah Friedman's mkinstalldirs script
+ if test -n "$dir_arg"; then
+ dst=$src
+ dstdir=$dst
+ test -d "$dstdir"
+ dstdir_status=$?
+ else
-# Skip lots of stat calls in the usual case.
-if [ ! -d "$dstdir" ]; then
-defaultIFS='
-IFS="${IFS-${defaultIFS}}"
+ # Waiting for this to be detected by the "$cpprog $src $dsttmp" command
+ # might cause directories to be created, which would be especially bad
+ # if $src (and thus $dsttmp) contains '*'.
+ if test ! -f "$src" && test ! -d "$src"; then
+ echo "$0: $src does not exist." >&2
+ exit 1
+ fi
-oIFS="${IFS}"
-# Some sh's can't handle IFS=/ for some reason.
-IFS='%'
-set - `echo ${dstdir} | sed -e 's@/@%@g' -e 's@^%@/@'`
-IFS="${oIFS}"
+ if test -z "$dst_arg"; then
+ echo "$0: no destination specified." >&2
+ exit 1
+ fi
-pathcomp=''
+ dst=$dst_arg
+ case $dst in
+ -*) dst=./$dst;;
+ esac
-while [ $# -ne 0 ] ; do
- pathcomp="${pathcomp}${1}"
- shift
+ # If destination is a directory, append the input filename; won't work
+ # if double slashes aren't ignored.
+ if test -d "$dst"; then
+ if test -n "$no_target_directory"; then
+ echo "$0: $dst_arg: Is a directory" >&2
+ exit 1
+ fi
+ dstdir=$dst
+ dst=$dstdir/`basename "$src"`
+ dstdir_status=0
+ else
+ # Prefer dirname, but fall back on a substitute if dirname fails.
+ dstdir=`
+ (dirname "$dst") 2>/dev/null ||
+ expr X"$dst" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$dst" : 'X\(//\)[^/]' \| \
+ X"$dst" : 'X\(//\)$' \| \
+ X"$dst" : 'X\(/\)' \| . 2>/dev/null ||
+ echo X"$dst" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'
- if [ ! -d "${pathcomp}" ] ;
- then
- $mkdirprog "${pathcomp}"
+ test -d "$dstdir"
+ dstdir_status=$?
+ fi
+ fi
+ obsolete_mkdir_used=false
+ if test $dstdir_status != 0; then
+ case $posix_mkdir in
+ # Create intermediate dirs using mode 755 as modified by the umask.
+ # This is like FreeBSD 'install' as of 1997-10-28.
+ umask=`umask`
+ case $stripcmd.$umask in
+ *[2367][2367]) mkdir_umask=$umask;;
+ .*0[02][02] | .[02][02] | .[02]) mkdir_umask=22;;
+ *[0-7])
+ mkdir_umask=`expr $umask + 22 \
+ - $umask % 100 % 40 + $umask % 20 \
+ - $umask % 10 % 4 + $umask % 2
+ *) mkdir_umask=$umask,go-w;;
+ esac
+ # With -d, create the new directory with the user-specified mode.
+ # Otherwise, rely on $mkdir_umask.
+ mkdir_mode=-m$mode
else
+ mkdir_mode=
fi
- pathcomp="${pathcomp}/"
-done
-fi
+ posix_mkdir=false
+ case $umask in
+ *[123567][0-7][0-7])
+ # POSIX mkdir -p sets u+wx bits regardless of umask, which
+ # is incompatible with FreeBSD 'install' when (umask & 300) != 0.
+ tmpdir=${TMPDIR-/tmp}/ins$RANDOM-$$
+ trap 'ret=$?; rmdir "$tmpdir/d" "$tmpdir" 2>/dev/null; exit $ret' 0
-then
- $doit $instcmd $dst &&
+ if (umask $mkdir_umask &&
+ exec $mkdirprog $mkdir_mode -p -- "$tmpdir/d") >/dev/null 2>&1
+ then
+ if test -z "$dir_arg" || {
+ # Check for POSIX incompatibilities with -m.
+ # HP-UX 11.23 and IRIX 6.5 mkdir -m -p sets group- or
+ # other-writeable bit of parent directory when it shouldn't.
+ # FreeBSD 6.1 mkdir -m -p sets mode of existing directory.
+ ls_ld_tmpdir=`ls -ld "$tmpdir"`
+ case $ls_ld_tmpdir in
+ d????-?r-*) different_mode=700;;
+ d????-?--*) different_mode=755;;
+ *) false;;
+ esac &&
+ $mkdirprog -m$different_mode -p -- "$tmpdir" && {
+ ls_ld_tmpdir_1=`ls -ld "$tmpdir"`
+ test "$ls_ld_tmpdir" = "$ls_ld_tmpdir_1"
+ then posix_mkdir=:
+ fi
+ rmdir "$tmpdir/d" "$tmpdir"
+ else
+ # Remove any dirs left behind by ancient mkdir implementations.
+ rmdir ./$mkdir_mode ./-p ./-- 2>/dev/null
+ fi
+ trap '' 0;;
+ esac;;
+ esac
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dst; else : ; fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dst; else : ; fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dst; else : ; fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dst; else : ; fi
-else
+ if
+ $posix_mkdir && (
+ umask $mkdir_umask &&
+ $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir"
+ then :
+ else
-# If we're going to rename the final executable, determine the name now.
+ # The umask is ridiculous, or mkdir does not conform to POSIX,
+ # or it failed possibly due to a race condition. Create the
+ # directory the slow way, step by step, checking for races as we go.
- if [ x"$transformarg" = x ]
- then
- dstfile=`basename $dst`
- else
- dstfile=`basename $dst $transformbasename |
- sed $transformarg`$transformbasename
- fi
+ case $dstdir in
+ /*) prefix='/';;
+ -*) prefix='./';;
+ *) prefix='';;
+ esac
-# don't allow the sed command to completely eliminate the filename
+ eval "$initialize_posix_glob"
- if [ x"$dstfile" = x ]
- then
+ oIFS=$IFS
+ IFS=/
+ $posix_glob set -f
+ set fnord $dstdir
+ shift
+ $posix_glob set +f
+ IFS=$oIFS
+ prefixes=
+ for d
+ do
+ test -z "$d" && continue
+ prefix=$prefix$d
+ if test -d "$prefix"; then
+ prefixes=
else
+ if $posix_mkdir; then
+ (umask=$mkdir_umask &&
+ $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir") && break
+ # Don't fail if two instances are running concurrently.
+ test -d "$prefix" || exit 1
+ else
+ case $prefix in
+ *\'*) qprefix=`echo "$prefix" | sed "s/'/'\\\\\\\\''/g"`;;
+ *) qprefix=$prefix;;
+ esac
+ prefixes="$prefixes '$qprefix'"
+ fi
fi
+ prefix=$prefix/
+ done
-# Make a temp file name in the proper directory.
+ if test -n "$prefixes"; then
+ (umask $mkdir_umask &&
+ eval "\$doit_exec \$mkdirprog $prefixes") ||
+ test -d "$dstdir" || exit 1
+ obsolete_mkdir_used=true
+ fi
+ fi
+ fi
- dsttmp=$dstdir/#inst.$$#
+ { test -z "$chowncmd" || $doit $chowncmd "$dst"; } &&
+ { test -z "$chgrpcmd" || $doit $chgrpcmd "$dst"; } &&
+ { test "$obsolete_mkdir_used$chowncmd$chgrpcmd" = false ||
+ test -z "$chmodcmd" || $doit $chmodcmd $mode "$dst"; } || exit 1
+ else
-# Move or copy the file name to the temp name
+ # Make a couple of temp file names in the proper directory.
+ dsttmp=$dstdir/_inst.$$_
+ rmtmp=$dstdir/_rm.$$_
- $doit $instcmd $src $dsttmp &&
+ # Trap to clean up those temp files at exit.
+ trap 'ret=$?; rm -f "$dsttmp" "$rmtmp" && exit $ret' 0
- trap "rm -f ${dsttmp}" 0 &&
+ # Copy the file name to the temp name.
+ (umask $cp_umask && $doit_exec $cpprog "$src" "$dsttmp") &&
-# and set any options; do chmod last to preserve setuid bits
+ # and set any options; do chmod last to preserve setuid bits.
+ # If any of these fail, we abort the whole thing. If we want to
+ # ignore errors from any of these, just make sure not to ignore
+ # errors from the above "$doit $cpprog $src $dsttmp" command.
+ { test -z "$chowncmd" || $doit $chowncmd "$dsttmp"; } &&
+ { test -z "$chgrpcmd" || $doit $chgrpcmd "$dsttmp"; } &&
+ { test -z "$stripcmd" || $doit $stripcmd "$dsttmp"; } &&
+ { test -z "$chmodcmd" || $doit $chmodcmd $mode "$dsttmp"; } &&
-# If any of these fail, we abort the whole thing. If we want to
-# ignore errors from any of these, just make sure not to ignore
-# errors from the above "$doit $instcmd $src $dsttmp" command.
+ # If -C, don't bother to copy if it wouldn't change the file.
+ if $copy_on_change &&
+ old=`LC_ALL=C ls -dlL "$dst" 2>/dev/null` &&
+ new=`LC_ALL=C ls -dlL "$dsttmp" 2>/dev/null` &&
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dsttmp; else :;fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dsttmp; else :;fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dsttmp; else :;fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dsttmp; else :;fi &&
+ eval "$initialize_posix_glob" &&
+ $posix_glob set -f &&
+ set X $old && old=:$2:$4:$5:$6 &&
+ set X $new && new=:$2:$4:$5:$6 &&
+ $posix_glob set +f &&
-# Now rename the file to the real destination.
+ test "$old" = "$new" &&
+ $cmpprog "$dst" "$dsttmp" >/dev/null 2>&1
+ then
+ rm -f "$dsttmp"
+ else
+ # Rename the file to the real destination.
+ $doit $mvcmd -f "$dsttmp" "$dst" 2>/dev/null ||
- $doit $rmcmd -f $dstdir/$dstfile &&
- $doit $mvcmd $dsttmp $dstdir/$dstfile
+ # The rename failed, perhaps because mv can't rename something else
+ # to itself, or perhaps because mv is so ancient that it does not
+ # support -f.
+ # Now remove or move aside any old file at destination location.
+ # We try this two ways since rm can't unlink itself on some
+ # systems and the destination file might be busy for other
+ # reasons. In this case, the final cleanup might fail but the new
+ # file should still install successfully.
+ test ! -f "$dst" ||
+ $doit $rmcmd -f "$dst" 2>/dev/null ||
+ { $doit $mvcmd -f "$dst" "$rmtmp" 2>/dev/null &&
+ { $doit $rmcmd -f "$rmtmp" 2>/dev/null; :; }
+ { echo "$0: cannot unlink or rename $dst" >&2
+ (exit 1); exit 1
-fi &&
+ # Now rename the file to the real destination.
+ $doit $mvcmd "$dsttmp" "$dst"
+ fi || exit 1
+ trap '' 0
+ fi
+done
-exit 0
+# Local variables:
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "scriptversion="
+# time-stamp-format: "%:y-%02m-%02d.%02H"
+# time-stamp-end: "$"
+# End:
Deleted: mpich2/trunk/confdb/makestrip
--- mpich2/trunk/confdb/makestrip 2009-03-20 01:57:54 UTC (rev 4135)
+++ mpich2/trunk/confdb/makestrip 2009-03-20 02:46:22 UTC (rev 4136)
@@ -1,208 +0,0 @@
-#! /usr/local/bin/perl5
-# This script can be used to clean up an automatically generated Makefile or
-# Makefile.in. It removes unused variables. It also tries to remove
-# intermediate empty targets (those with no commands).
-# Based on the following variables, it can:
-$noinstall = 1; # Remove install targets
-$nodots = 1; # Remove .S and .s targets
-$nodist = 1; # Remove distribution targets
-$nophony = 1; # Remove .PHONY:
-$noid = 1; # Remove ID: target
-$notexinfo = 1; # Remove texinfo targets
-$noemptytarg = 0; # Remove empty targets
-# Still to do: intermediate target/dependency compression should ONLY happen
-# for targets in the .PHONY list.
-# targets of the form xxx-yyy are often internal targets, and can be removed
-# as well.
-$debug = 0; # Turn on heavy debugging info
-$read_nextline = 0;
-sub remove_command
- print "In remove command\n" if ($debug);
- while (<MAKEFILE>) {
- if (/^[^ \t]/) {$read_nextline = 1; print "YE!\n" if ($debug); last;}
-sub remove_line
- local ($look_for_vars) = @_;
- print "In remove line\n" if ($debug);
- while (1) {
- &look_for_var_use if ($look_for_vars);
- $var = $_;
- chop $var;
- if ((chop $var) ne "\\") { last; }
- $_ = <MAKEFILE>;
-sub scan_makefile
- $val = 1;
- if ($noinstall && (/^install.*:/ || /^uninstall.*:/)) {
- # Remove install targets
- print "install target\n" if ($debug);
- &remove_command;
- } elsif ($nodots && (/^\.[Ss]\.o/ || /^\.[Ss]\.lo/)) {
- # Remove bogus .s.o targets
- &remove_command;
- } elsif ($nodist && /^dist[-a-zA-Z]*:/) {
- # Remove distribution info
- print "dist targets\n" if ($debug);
- &remove_command;
- } elsif ($noid && /^ID: /) {
- &remove_command;
- } elsif ($notexinfo && (/^info-am:/ || /^info:/ || /^dvi-am:/ || /^dvi:/)){
- &remove_command;
- } else {
- $val = 0;
- return $val;
-# Scan the rest of this line and look for variable uses
-sub look_for_var_use
- $PAT_VAR_USE = '^[^\$]*\$\(([-a-zA-Z0-9-_]*)\)(.*)';
- print "Vars in $_" if ($debug);
- if (/\$\(.*\)/) {
- $line = $_;
- while ( ($var, $Etc) = ($line =~ /$PAT_VAR_USE/o)) {
- $line = $Etc;
- print "Found $var\n" if ($debug);
- # This is really only approximate; we need to construct a
- # dependency tree and eliminate dead trees.
- $variables{$var} ++;
-$PAT_DEP_USE = '^[ \t]*(\S+) (.*)';
-# Scan the rest of this line and look for other dependencies (including
-# continuation lines)
-sub look_for_depends
- my $count, $line;
- $tmp = $_;
- ($targ,$line) = ($tmp =~ /^([^:]*):(.*)/);
- $count = 0;
- print "$targ : $line";
- while ( ($var, $Etc) = ($line =~ /$PAT_DEP_USE/o)) {
- $line = $Etc;
- $count++;
- $targets{$var} ++;
- return $count;
-sub look_for_commands
- $_ = <MAKEFILE>;
- $read_next_line = 0;
- return ($_ ne "\n");
-sub output_target_list
- print "In output targets line $_\n" if ($debug);
- $line = $_;
- ($targ, $line) = ($line =~ /^(\S+):(.*)/); # Chops off the Newline!
- print "$targ: ";
- $line = "$line\n";
- while (1) {
- chop $line;
- $lastchar = chop $line;
- print "last char = $lastchar\n" if ($debug);
- $line = "$line$lastchar";
- print "FOO:$line\n" if ($debug);
- while ( ($dep, $Etc) = ($line =~ /$PAT_DEP_USE/o) ) {
- print "dep = $dep/Etc = $Etc\n" if ($debug);
- if ($dep eq "\\" || $dep eq "\n") { last; }
- if ($targets{$dep} > 1 || $targets{$dep} == 0) { print "$dep " }
- $line = $Etc;
- if ($lastchar ne "\\") { last; }
- $line = <MAKEFILE>;
- print "\n";
-$filename = $ARGV[0];
-$PAT_ASSIGN = '^([a-zA-Z_0-9]*)[ \t]*=';
-$PAT_TARGET = '^([-a-zA-Z_0-9]*):[ \t]*$';
-# Read variable names; keep track of the number of uses
-open( MAKEFILE, "<$filename" ) || die "Could not open $filename\n";
-while ($read_nextline || ($_ = <MAKEFILE>)) {
- print "$_" if ($debug);
- $read_nextline = 0;
- $line = $_;
- if ((($var) = ($line =~ /$PAT_ASSIGN/o)) && $var ne "VPATH" &&
- $var ne "SHELL" ) {
- print "variable assignment\n" if ($debug);
- # Remove variables that are never used
- # But keep special variables: SHELL, VPATH
- $variables{$var} = 0;
- &remove_line(1);
- } elsif (&scan_makefile) {
- } elsif ( ($var) = ($line =~ /$PAT_TARGET/o) ) {
- # target with no dependencies (eventually, also check
- # to see if they have any commands)
- &look_for_var_use;
- $targets{$var} = 1 + &look_for_commands;
- } else {
- # Is there a variable use here?
- print "read_nextline = $read_nextline\n" if ($debug);
-close( MAKEFILE );
-# Now, read the file and remove useless variables
-open( MAKEFILE, "<$filename" );
-$last_blank = 0;
- $line = $_;
- print "variables{$var} = $variables{$var}\n" if ($debug);
- if ($variables{$var} > 0) {
- print $_;
- } else {
- &remove_line(0);
- } elsif ($nophony && /^\.PHONY:/o) {
- # Remove .PHONY: ...
- &remove_line(0);
- } elsif ($noemptytarg && /^[-_0-9A-Za-z]*:/) {
- # process targets
- &output_target_list;
- } elsif ($_ eq "\n" && $last_blank) {
- } else {
- $last_blank = ($_ eq "\n");
- print $_;
More information about the mpich2-commits
