[mpich2-commits] r4124 - in mpich2/trunk/src/pm/hydra: . bootstrap/fork bootstrap/slurm bootstrap/ssh include pm/central utils utils/launch utils/plpa
balaji at mcs.anl.gov balaji at mcs.anl.gov
Wed Mar 18 18:47:34 CDT 2009
Author: balaji
Date: 2009-03-18 18:47:33 -0500 (Wed, 18 Mar 2009)
New Revision: 4124
Added:
   mpich2/trunk/src/pm/hydra/include/plpa.h
   mpich2/trunk/src/pm/hydra/include/plpa_internal.h
   mpich2/trunk/src/pm/hydra/utils/launch/bind.c
   mpich2/trunk/src/pm/hydra/utils/plpa/
   mpich2/trunk/src/pm/hydra/utils/plpa/LICENSE
   mpich2/trunk/src/pm/hydra/utils/plpa/Makefile.sm
   mpich2/trunk/src/pm/hydra/utils/plpa/plpa_api_probe.c
   mpich2/trunk/src/pm/hydra/utils/plpa/plpa_dispatch.c
   mpich2/trunk/src/pm/hydra/utils/plpa/plpa_map.c
   mpich2/trunk/src/pm/hydra/utils/plpa/plpa_runtime.c
Modified:
   mpich2/trunk/src/pm/hydra/bootstrap/fork/fork_launch.c
   mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c
   mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
   mpich2/trunk/src/pm/hydra/configure.in
   mpich2/trunk/src/pm/hydra/include/hydra_utils.h
   mpich2/trunk/src/pm/hydra/pm/central/proxy.c
   mpich2/trunk/src/pm/hydra/utils/Makefile.sm
   mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm
   mpich2/trunk/src/pm/hydra/utils/launch/launch.c
Log:
First draft of the process-binding code (ticket #457).
Modified: mpich2/trunk/src/pm/hydra/bootstrap/fork/fork_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/fork/fork_launch.c	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/bootstrap/fork/fork_launch.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -40,7 +40,8 @@
             /* The stdin pointer will be some value for process_id 0;
              * for everyone else, it's NULL. */
             status = HYDU_Create_process(client_arg, (process_id == 0 ? &handle.in : NULL),
-                                         &partition->out, &partition->err, &partition->pid);
+                                         &partition->out, &partition->err, &partition->pid,
+                                         -1);
             HYDU_ERR_POP(status, "create process returned error\n");
             for (arg = 0; client_arg[arg]; arg++)
Modified: mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -56,7 +56,8 @@
+                                         -1);
             if (status != HYD_SUCCESS) {
                 HYDU_Error_printf("bootstrap spawn process returned error\n");
                 goto fn_fail;
Modified: mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -60,7 +60,8 @@
+                                         -1);
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/configure.in	2009-03-18 23:47:33 UTC (rev 4124)
@@ -35,7 +35,7 @@
 CFLAGS=$save_cflags
 dnl Check if the necessary headers are available
-AC_CHECK_HEADERS(unistd.h stdlib.h string.h strings.h stdarg.h sys/types.h sys/socket.h)
+AC_CHECK_HEADERS(unistd.h stdlib.h string.h strings.h stdarg.h sys/types.h sys/socket.h sched.h)
 # Check for special types
 AC_TYPE_SIZE_T
@@ -145,9 +145,22 @@
 AC_MSG_CHECKING(warnings)
 AC_MSG_RESULT($WARNINGS)
 if test "$WARNINGS" = "yes"; then
-   AC_DEFINE(ENABLE_WARNINGS,1,[Define if warnings enabled])
+   AC_DEFINE(ENABLE_WARNINGS,1,[Define if warnings are enabled])
 fi
+dnl Process Binding
+AC_ARG_ENABLE(g, [  --enable-process-binding       Process Binding],
+		 [ PROC_BINDING=$enableval ],
+		 [ PROC_BINDING=no ])
+AC_MSG_CHECKING(process binding)
+AC_MSG_RESULT($PROC_BINDING)
+if test "$PROC_BINDING" = "yes"; then
+   AC_DEFINE(PROC_BINDING,1,[Define if process binding is enabled])
+   plpa_makefile="utils/plpa/Makefile"
+   all_utils="${all_utils} plpa"
+fi
+AC_SUBST(all_utils)
 dnl Check if __func__ is defined by the compiler
 AC_MSG_CHECKING([whether the compiler allows __func__])
 rm -f conftest.c
@@ -294,6 +307,7 @@
 	utils/sock/Makefile \
 	utils/string/Makefile \
 	utils/timer/Makefile \
+	${plpa_makefile} \
 	launcher/Makefile \
 	launcher/utils/Makefile \
 	launcher/${hydra_launcher}/Makefile \
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-03-18 23:47:33 UTC (rev 4124)
@@ -67,11 +67,18 @@
 HYD_Status HYDU_Append_wdir(char **client_arg, char *wdir);
 HYD_Status HYDU_Dump_args(char **args);
 void HYDU_Free_args(char **args);
-HYD_Status HYDU_Create_process(char **client_arg, int *in, int *out, int *err, int *pid);
+HYD_Status HYDU_Create_process(char **client_arg, int *in, int *out, int *err, int *pid,
+                               int core);
 HYD_Status HYDU_Get_base_path(char *execname, char **path);
 HYD_Status HYDU_Chdir(const char *dir);
+#if defined PROC_BINDING
+#include "plpa.h"
+#include "plpa_internal.h"
+#endif /* PROC_BINDING */
+HYD_Status HYDU_bind_process(int core);
 /* Memory utilities */
 #define HYDU_NUM_JOIN_STR 100
Added: mpich2/trunk/src/pm/hydra/include/plpa.h
--- mpich2/trunk/src/pm/hydra/include/plpa.h	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/include/plpa.h	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,298 @@
+/* -*- c -*-
+ * Copyright (c) 2004-2005 The Trustees of Indiana University.
+ *                         All rights reserved.
+ * Copyright (c) 2004-2005 The Regents of the University of California.
+ * Copyright (c) 2006-2008 Cisco, Inc.  All rights reserved.
+ * $COPYRIGHT$
+ * Additional copyrights may follow
+ * $HEADER$
+ * Some notes about the declarations and definitions in this file:
+ * This file is a mix of internal and public declarations.
+ * Applications are warned against using the internal types; they are
+ * subject to change with no warning.
+ * The PLPA_NAME() and PLPA_NAME_CAPS() macros are used for prefixing
+ * the PLPA type names, enum names, and symbol names when embedding
+ * PLPA.  When not embedding, the default prefix is "plpa_" (or
+ * "PLPA_" when using PLPA_NAME_CAPS()).  Hence, if you see a
+ * declaration like this:
+ * int PLPA_NAME(foo)(void);
+ * It's a function named plpa_foo() that returns an int and takes no
+ * arguments when building PLPA as a standalone library.  It's a
+ * function with a different prefix than "plpa_" when the
+ * --enable-included-mode and --with-plpa-symbol-prefix options are
+ * supplied to PLPA's configure script.
+ * Note that this header file differentiates between a
+ * processor/socket/core ID and a processor/socket/core number.  The
+ * "ID" is the integer that is used by Linux to identify that entity.
+ * These integers may or may not be contiguous.  The "number" is a
+ * contiguous set of integers starting with 0 and going to (count-1),
+ * where (count) is the number of processors, sockets, and cores
+ * (where the count of cores is dependent upon the socket).  Hence,
+ * "number" is a human convenience, and "ID" is the actual Linux
+ * identifier.
+#ifndef PLPA_H
+#define PLPA_H
+/* Absolutely must not include <sched.h> here or it will generate
+   conflicts. */
+/* For memset() */
+#include <string.h>
+/* For pid_t and size_t */
+#include <sys/types.h>
+ * Internal types
+/* If we're building PLPA itself, <plpa_config.h> will have already
+   been included.  But <plpa_config.h> is a private header file; it is
+   not installed into $includedir.  Hence, applications including
+   <plpa.h> will not have included <plpa_config.h> (this is by
+   design).  So include just enough information here to allow us to
+   continue. */
+#ifndef PLPA_CONFIG_H
+/* The PLPA symbol prefix */
+#define PLPA_SYM_PREFIX plpa_
+/* The PLPA symbol prefix in all caps */
+#define PLPA_SYM_PREFIX_CAPS PLPA_
+#endif
+/* Preprocessors are fun -- the double inderection is unfortunately
+   necessary. */
+#define PLPA_MUNGE_NAME(a, b) PLPA_MUNGE_NAME2(a, b)
+#define PLPA_MUNGE_NAME2(a, b) a ## b
+#define PLPA_NAME(name) PLPA_MUNGE_NAME(PLPA_SYM_PREFIX, name)
+#define PLPA_NAME_CAPS(name) PLPA_MUNGE_NAME(PLPA_SYM_PREFIX_CAPS, name)
+ * Public type
+/* Values that can be returned from plpa_api_probe() */
+typedef enum {
+    /* Sentinel value */
+    PLPA_NAME_CAPS(PROBE_UNSET),
+    /* sched_setaffinity syscall available */
+    PLPA_NAME_CAPS(PROBE_OK),
+    /* syscall unavailable/unimplemented */
+    PLPA_NAME_CAPS(PROBE_NOT_SUPPORTED),
+    /* we experienced some strange failure that the user should report */
+    PLPA_NAME_CAPS(PROBE_UNKNOWN)
+} PLPA_NAME(api_type_t);
+ * Internal types
+/* Internal PLPA bitmask type.  This type should not be used by
+   external applications! */
+typedef unsigned long int PLPA_NAME(bitmask_t);
+#define PLPA_BITMASK_T_NUM_BITS (sizeof(PLPA_NAME(bitmask_t)) * 8)
+#define PLPA_BITMASK_CPU_MAX 1024
+#define PLPA_BITMASK_NUM_ELEMENTS (PLPA_BITMASK_CPU_MAX / PLPA_BITMASK_T_NUM_BITS)
+ * Public type
+/* Public type for the PLPA cpu set. */
+typedef struct { PLPA_NAME(bitmask_t) bitmask[PLPA_BITMASK_NUM_ELEMENTS]; } PLPA_NAME(cpu_set_t);
+ * Internal macros
+/* Internal macro for identifying the byte in a bitmask array.  This
+   macro should not be used by external applications! */
+#define PLPA_CPU_BYTE(num) ((num) / PLPA_BITMASK_T_NUM_BITS)
+/* Internal macro for identifying the bit in a bitmask array.  This
+#define PLPA_CPU_BIT(num) ((num) % PLPA_BITMASK_T_NUM_BITS)
+ * Public macros
+/* Public macro to zero out a PLPA cpu set (analogous to the FD_ZERO()
+   macro; see select(2)). */
+#define PLPA_CPU_ZERO(cpuset) \
+    memset((cpuset), 0, sizeof(PLPA_NAME(cpu_set_t)))
+/* Public macro to set a bit in a PLPA cpu set (analogous to the
+   FD_SET() macro; see select(2)). */
+#define PLPA_CPU_SET(num, cpuset) \
+    (cpuset)->bitmask[PLPA_CPU_BYTE(num)] |= ((PLPA_NAME(bitmask_t))1 << PLPA_CPU_BIT(num))
+/* Public macro to clear a bit in a PLPA cpu set (analogous to the
+   FD_CLR() macro; see select(2)). */
+#define PLPA_CPU_CLR(num, cpuset) \
+    (cpuset)->bitmask[PLPA_CPU_BYTE(num)] &= ~((PLPA_NAME(bitmask_t))1 << PLPA_CPU_BIT(num))
+/* Public macro to test if a bit is set in a PLPA cpu set (analogous
+   to the FD_ISSET() macro; see select(2)). */
+#define PLPA_CPU_ISSET(num, cpuset) \
+    (0 != (((cpuset)->bitmask[PLPA_CPU_BYTE(num)]) & ((PLPA_NAME(bitmask_t))1 << PLPA_CPU_BIT(num))))
+ * Public functions
+/* Setup PLPA internals.  This function is optional; it will be
+   automatically invoked by all the other API functions if you do not
+   invoke it explicitly.  Returns 0 upon success. */
+int PLPA_NAME(init)(void);
+/* Check what API is on this machine.  If api_type returns
+   PLPA_PROBE_OK, then PLPA can function properly on this machine.
+   Returns 0 upon success. */
+int PLPA_NAME(api_probe)(PLPA_NAME(api_type_t) *api_type);
+/* Set processor affinity.  Use the PLPA_CPU_* macros to set the
+   cpuset value.  The same rules and restrictions about pid apply as
+   they do for the sched_setaffinity(2) system call.  Bits set in the
+   CPU mask correspond to Linux processor IDs.  Returns 0 upon
+   success. */
+int PLPA_NAME(sched_setaffinity)(pid_t pid, size_t cpusetsize,
+                                 const PLPA_NAME(cpu_set_t) *cpuset);
+/* Get processor affinity.  Use the PLPA_CPU_* macros to analyze the
+   returned value of cpuset.  The same rules and restrictions about
+   pid apply as they do for the sched_getaffinity(2) system call.
+   Bits set in the CPU mask corresopnd to Linux processor IDs.
+int PLPA_NAME(sched_getaffinity)(pid_t pid, size_t cpusetsize,
+                                 PLPA_NAME(cpu_set_t) *cpuset);
+/* Return whether topology information is available (i.e.,
+   plpa_map_to_*, plpa_max_*).  The topology functions will be
+   available if supported == 1 and the function returns 0. */
+int PLPA_NAME(have_topology_information)(int *supported);
+/* Map (socket_id,core_id) tuple to virtual processor ID.  processor_id is
+   then suitable for use with the PLPA_CPU_* macros, probably leading
+   to a call to plpa_sched_setaffinity().  Returns 0 upon success. */
+int PLPA_NAME(map_to_processor_id)(int socket_id, int core_id,
+                                   int *processor_id);
+/* Map processor_id to (socket_id,core_id) tuple.  The processor_id input is
+   usually obtained from the return from the plpa_sched_getaffinity()
+   call, using PLPA_CPU_ISSET to find individual bits in the map that
+   were set/unset.  plpa_map_to_socket_core() can map the bit indexes
+   to a socket/core tuple.  Returns 0 upon success. */
+int PLPA_NAME(map_to_socket_core)(int processor_id,
+                                  int *socket_id, int *core_id);
+/* This function is deprecated and will disappear in a future release.
+   It is exactly equivalent to calling
+   plpa_get_processor_data(PLPA_COUNT_ALL, num_processors,
+   max_processor_id). */
+int PLPA_NAME(get_processor_info)(int *num_processors, int *max_processor_id);
+/* Typedefs for specifying which processors / sockets / cores to count
+   in get_processor_data() and get_processor_id() */
+typedef enum {
+    /* Only count online processors */
+    PLPA_NAME_CAPS(COUNT_ONLINE),
+    /* Only count offline processors */
+    PLPA_NAME_CAPS(COUNT_OFFLINE),
+    /* Count all processors (online and offline) */
+    PLPA_NAME_CAPS(COUNT_ALL)
+} PLPA_NAME(count_specification_t);
+/* Returns both the number of processors in a system and the maximum
+   Linux virtual processor ID (because it may be higher than the
+   number of processors if there are "holes" in the available Linux
+   virtual processor IDs).  The count_spec argument specifies whether
+   to count all processors, only online processors, or only offline
+   processors.  Returns 0 upon success.  */
+int PLPA_NAME(get_processor_data)(PLPA_NAME(count_specification_t) count_spec,
+                                  int *num_processors, int *max_processor_id);
+/* Returns the Linux processor ID for the Nth processor.  For example,
+   if the Linux processor IDs have "holes", use this function to say
+   "give me the Linux processor ID of the 4th processor."  count_spec
+   specifies whether to count online, offline, or all processors when
+   looking for the processor_num'th processor.  Returns 0 upon
+   success. */
+int PLPA_NAME(get_processor_id)(int processor_num,
+                                PLPA_NAME(count_specification_t) count_spec,
+/* Check to see if a given Linux processor ID exists / is online.
+   Returns 0 on success. */
+int PLPA_NAME(get_processor_flags)(int processor_id, int *exists, int *online);
+/* Returns both the number of sockets in the system and the maximum
+   socket ID number (in case there are "holes" in the list of available
+   socket IDs).  Returns 0 upon sucess. */
+int PLPA_NAME(get_socket_info)(int *num_sockets, int *max_socket_id);
+/* Returns the Linux socket ID for the Nth socket.  For example, if
+   the socket IDs have "holes", use this function to say "give me the
+   Linux socket ID of the 2nd socket."  Linux does not specify the
+   socket/core tuple information for offline processors, so a
+   plpa_count_specification_t parameter is not used here.  Returns 0
+   upon success. */
+int PLPA_NAME(get_socket_id)(int socket_num, int *socket_id);
+/* Return both the number of cores and the max code ID for a given
+   socket (in case there are "holes" in the list of available core
+   IDs).  Returns 0 upon success. */
+int PLPA_NAME(get_core_info)(int socket_id, int *num_cores, int *max_core_id);
+/* Given a specific socket, returns the Linux core ID for the Nth
+   core.  For example, if the core IDs have "holes", use this function
+   to say "give me the Linux core ID of the 4th core on socket ID 7."
+   Linux does not specify the socket/core tuple information for
+   offline processors, so a plpa_count_specification_t parameter is
+   not used here.  Returns 0 upon success.  Returns 0 upon success. */
+int PLPA_NAME(get_core_id)(int socket_id, int core_num, int *core_id);
+/* Check to see if a given Linux (socket_id,core_id) tuple exists / is
+   online.  Returns 0 on success. */
+int PLPA_NAME(get_core_flags)(int socket_id, int core_id,
+                              int *exists, int *online);
+/* Typedefs for specifying the cache behavior via
+   plpa_set_cache_behavior() */
+typedef enum {
+    /* Use the cache (default behavior); fills the cache right now if
+       it's not already full */
+    PLPA_NAME_CAPS(CACHE_USE),
+    /* Never use the cache; always look up the information in
+       the kernel */
+    PLPA_NAME_CAPS(CACHE_IGNORE),
+    /* Refresh the cache right now */
+    PLPA_NAME_CAPS(CACHE_REFRESH)
+} PLPA_NAME(cache_behavior_t);
+/* Set PLPA's cache behavior.  Returns 0 upon success. */
+int PLPA_NAME(set_cache_behavior)(PLPA_NAME(cache_behavior_t));
+/* Shut down PLPA.  This function releases resources used by the PLPA.
+   It should be the last PLPA function invoked, or can be used to
+   forcibly cause PLPA to dump its topology cache and re-analyze the
+   underlying system the next time another PLPA function is called.
+   Specifically: it is safe to call plpa_init() (or any other PLPA
+   function) again after plpa_finalized().  Returns 0 upon success. */
+int PLPA_NAME(finalize)(void);
+#endif /* PLPA_H */
Added: mpich2/trunk/src/pm/hydra/include/plpa_internal.h
--- mpich2/trunk/src/pm/hydra/include/plpa_internal.h	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/include/plpa_internal.h	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,30 @@
+/* -*- c -*-
+ * Copyright (c) 2007-2008 Cisco Systems, Inc.  All rights reserved.
+ * $COPYRIGHT$
+ * $HEADER$
+#ifndef PLPA_INTERNAL_H
+#define PLPA_INTERNAL_H
+#include <plpa.h>
+/* Have we initialized yet? */
+extern int PLPA_NAME(initialized);
+/* Cached size of the affinity buffers that the kernel expects */
+extern size_t PLPA_NAME(len);
+/* Setup API type */
+int PLPA_NAME(api_probe_init)(void);
+#endif /* PLPA_INTERNAL_H */
Modified: mpich2/trunk/src/pm/hydra/pm/central/proxy.c
--- mpich2/trunk/src/pm/hydra/pm/central/proxy.c	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/pm/central/proxy.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -78,15 +78,19 @@
             client_args[arg++] = MPIU_Strdup(HYD_Proxy_params.args[j]);
         client_args[arg++] = NULL;
+        /* FIXME: We need to figure out how many total number of
+         * processes are there on this partition, and appropriately
+         * bind them. */
         if ((i + HYD_Proxy_params.pmi_id) == 0) {
             status = HYDU_Create_process(client_args, &HYD_Proxy_params.in,
                                          &HYD_Proxy_params.out[i], &HYD_Proxy_params.err[i],
-                                         &HYD_Proxy_params.pid[i]);
+                                         &HYD_Proxy_params.pid[i], i);
         else {
             status = HYDU_Create_process(client_args, NULL,
-                                         &HYD_Proxy_params.err[i], &HYD_Proxy_params.pid[i]);
+                                         &HYD_Proxy_params.err[i], &HYD_Proxy_params.pid[i],
+                                         i);
         HYDU_ERR_POP(status, "spawn process returned error\n");
Modified: mpich2/trunk/src/pm/hydra/utils/Makefile.sm
--- mpich2/trunk/src/pm/hydra/utils/Makefile.sm	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/utils/Makefile.sm	2009-03-18 23:47:33 UTC (rev 4124)
@@ -4,4 +4,5 @@
 #     See COPYRIGHT in top-level directory.
-SUBDIRS = args dbg env launch signals sock string timer .
+SUBDIRS_all_utils = args dbg env launch signals sock string timer plpa .
+SUBDIRS = args dbg env launch signals sock string timer @all_utils@
\ No newline at end of file
Modified: mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm
--- mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm	2009-03-18 23:47:33 UTC (rev 4124)
@@ -7,7 +7,7 @@
 HYDRA_LIB_PATH = ../../lib
 libhydra_a_DIR = ${HYDRA_LIB_PATH}
-libhydra_a_SOURCES = allocate.c launch.c
+libhydra_a_SOURCES = allocate.c launch.c bind.c
 INCLUDES = -I${abs_srcdir}/../../include \
 	-I${abs_srcdir}/../../../../include \
 	-I../../include \
Added: mpich2/trunk/src/pm/hydra/utils/launch/bind.c
--- mpich2/trunk/src/pm/hydra/utils/launch/bind.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/launch/bind.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,39 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ *  (C) 2008 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+#include "hydra_utils.h"
+    plpa_api_type_t p;
+    plpa_cpu_set_t cpuset;
+    int ret;
+    HYD_Status status = HYD_SUCCESS;
+    HYDU_FUNC_ENTER();
+    if (!((plpa_api_probe(&p) == 0) && (p == PLPA_PROBE_OK)))
+        HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "plpa probe failed\n");
+    PLPA_CPU_ZERO(&cpuset);
+    PLPA_CPU_SET(core, &cpuset);
+    ret = plpa_sched_setaffinity(0, 1, &cpuset);
+    if (ret)
+        HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "plpa setaffinity failed\n");
+  fn_exit:
+    HYDU_FUNC_EXIT();
+    return status;
+  fn_fail:
+    goto fn_exit;
+#else
+    return HYD_SUCCESS;
Modified: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2009-03-18 21:15:10 UTC (rev 4123)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -6,9 +6,10 @@
+                               int *pid, int core)
-    int inpipe[2], outpipe[2], errpipe[2], tpid;
+    int inpipe[2], outpipe[2], errpipe[2], tpid, my_pid;
     HYDU_FUNC_ENTER();
@@ -40,6 +41,11 @@
             HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "dup2 error (%s)\n",
                                  HYDU_String_error(errno));
+        if (core >= 0) {
+            status = HYDU_bind_process(core);
+            HYDU_ERR_POP(status, "bind process failed\n");
         close(inpipe[1]);
         close(0);
         if (in && (dup2(inpipe[0], 0) < 0))
Property changes on: mpich2/trunk/src/pm/hydra/utils/plpa
___________________________________________________________________
   + Makefile
Makefile.in
Added: mpich2/trunk/src/pm/hydra/utils/plpa/LICENSE
--- mpich2/trunk/src/pm/hydra/utils/plpa/LICENSE	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/LICENSE	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,57 @@
+Copyright (c) 2004-2006 The Trustees of Indiana University and Indiana
+                        University Research and Technology
+                        Corporation.  All rights reserved.
+Copyright (c) 2004-2005 The Regents of the University of California.
+                        All rights reserved.
+Copyright (c) 2007      Cisco Systems, Inc.  All rights reserved.
+Portions copyright:
+Copyright (c) 2004-2005  The University of Tennessee and The University
+                         of Tennessee Research Foundation.  All rights
+                         reserved.
+Copyright (c) 2004-2005  High Performance Computing Center Stuttgart,
+                         University of Stuttgart.  All rights reserved.
+Copyright (c) 2006, 2007 Advanced Micro Devices, Inc.
+$COPYRIGHT$
+Additional copyrights may follow
+$HEADER$
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are
+met:
+- Redistributions of source code must retain the above copyright
+  notice, this list of conditions and the following disclaimer.
+- Redistributions in binary form must reproduce the above copyright
+  notice, this list of conditions and the following disclaimer listed
+  in this license in the documentation and/or other materials
+  provided with the distribution.
+- Neither the name of the copyright holders nor the names of its
+  contributors may be used to endorse or promote products derived from
+  this software without specific prior written permission.
+The copyright holders provide no reassurances that the source code
+provided does not infringe any patent, copyright, or any other
+intellectual property rights of third parties.  The copyright holders
+disclaim any liability to any recipient for claims brought against
+recipient by any third party for infringement of that parties
+intellectual property rights.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Added: mpich2/trunk/src/pm/hydra/utils/plpa/Makefile.sm
--- mpich2/trunk/src/pm/hydra/utils/plpa/Makefile.sm	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/Makefile.sm	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,14 @@
+# -*- Mode: Makefile; -*-
+# (C) 2008 by Argonne National Laboratory.
+#     See COPYRIGHT in top-level directory.
+HYDRA_LIB_PATH = ../../lib
+libhydra_a_DIR = ${HYDRA_LIB_PATH}
+libhydra_a_SOURCES = plpa_api_probe.c plpa_dispatch.c plpa_map.c plpa_runtime.c
+INCLUDES = -I${abs_srcdir}/../../include \
+	-I${abs_srcdir}/../../../../include \
+	-I../../include \
+	-I../../../../include
Added: mpich2/trunk/src/pm/hydra/utils/plpa/plpa_api_probe.c
--- mpich2/trunk/src/pm/hydra/utils/plpa/plpa_api_probe.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/plpa_api_probe.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,89 @@
+/* -*- c -*-
+ * Copyright (c) 2007-2008 Cisco, Inc.  All rights reserved.
+ * $COPYRIGHT$
+ * $HEADER$
+#include "plpa.h"
+#include <errno.h>
+#include <sys/syscall.h>
+#include <unistd.h>
+/* Cache, just to make things a little more efficient */
+static PLPA_NAME(api_type_t) cache = PLPA_NAME_CAPS(PROBE_UNSET);
+/* The len value we find - not in public header, but used by the lib */
+size_t PLPA_NAME(len) = 0;
+    PLPA_NAME(cpu_set_t) mask;
+    int rc;
+    size_t len;
+    for (len = sizeof(mask); len != 0; len >>= 1) {
+        rc = syscall(__NR_sched_getaffinity, 0, len, &mask);
+        if (rc >= 0) {
+            /* OK, kernel is happy with a get().  Validate w/ a set(). */
+            /* Note that kernel may have told us the "proper" size */
+            size_t tmp = (0 != rc) ? ((size_t) rc) : len;
+            /* Pass mask=NULL, expect errno==EFAULT if tmp was OK
+               as a length */
+            rc = syscall(__NR_sched_setaffinity, 0, tmp, NULL);
+            if ((rc < 0) && (errno == EFAULT)) {
+                cache = PLPA_NAME_CAPS(PROBE_OK);
+                PLPA_NAME(len) = tmp;
+                rc = 0;
+                break;
+        if (errno == ENOSYS) {
+            break; /* No point in looping */
+    if (rc >= 0) {
+        /* OK */
+    } else if (errno == ENOSYS) {
+        /* Kernel returns ENOSYS because there is no support for
+           processor affinity */
+        cache = PLPA_NAME_CAPS(PROBE_NOT_SUPPORTED);
+    } else {
+        /* Unknown! */
+        cache = PLPA_NAME_CAPS(PROBE_UNKNOWN);
+    return 0;
+    int ret;
+    /* Check to see that we're initialized */
+    if (!PLPA_NAME(initialized)) {
+        if (0 != (ret = PLPA_NAME(init)())) {
+            return ret;
+    /* Check for bozo arguments */
+    if (NULL == api_type) {
+        return EINVAL;
+    /* All done */
+    *api_type = cache;
+    return 0;
Added: mpich2/trunk/src/pm/hydra/utils/plpa/plpa_dispatch.c
--- mpich2/trunk/src/pm/hydra/utils/plpa/plpa_dispatch.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/plpa_dispatch.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,192 @@
+/* -*- c -*-
+ * Copyright (c) 2004-2006 The Trustees of Indiana University.
+ * $COPYRIGHT$
+ * $HEADER$
+#include "plpa.h"
+#include <errno.h>
+ * Call the kernel's setaffinity, massaging the user's input
+ * parameters as necessary
+    int ret;
+    size_t i;
+    PLPA_NAME(cpu_set_t) tmp;
+    PLPA_NAME(api_type_t) api;
+            return ret;
+    if (NULL == cpuset) {
+        return EINVAL;
+    /* Probe the API type */
+    if (0 != (ret = PLPA_NAME(api_probe)(&api))) {
+        return ret;
+    switch (api) {
+    case PLPA_NAME_CAPS(PROBE_OK):
+        /* This shouldn't happen, but check anyway */
+        if (cpusetsize > sizeof(*cpuset)) {
+            return EINVAL;
+        /* If the user-supplied bitmask is smaller than what the
+           kernel wants, zero out a temporary buffer of the size that
+           the kernel wants and copy the user-supplied bitmask to the
+           lower part of the temporary buffer.  This could be done
+           more efficiently, but we're looking for clarity/simplicity
+           of code here -- this is not intended to be
+           performance-critical. */
+        if (cpusetsize < PLPA_NAME(len)) {
+            memset(&tmp, 0, sizeof(tmp));
+            for (i = 0; i < cpusetsize * 8; ++i) {
+                if (PLPA_CPU_ISSET(i, cpuset)) {
+                    PLPA_CPU_SET(i, &tmp);
+        /* If the user-supplied bitmask is larger than what the kernel
+           will accept, scan it and see if there are any set bits in
+           the part larger than what the kernel will accept.  If so,
+           return EINVAL.  Otherwise, copy the part that the kernel
+           will accept into a temporary and use that.  Again,
+           efficinency is not the issue of this code -- clarity is. */
+        else if (cpusetsize > PLPA_NAME(len)) {
+            for (i = PLPA_NAME(len) * 8; i < cpusetsize * 8; ++i) {
+                    return EINVAL;
+            /* No upper-level bits are set, so now copy over the bits
+               that the kernel will look at */
+            for (i = 0; i < PLPA_NAME(len) * 8; ++i) {
+        /* Otherwise, the user supplied a buffer that is exactly the
+           right size.  Just for clarity of code, copy the user's
+           buffer into the temporary and use that. */
+        else {
+            memcpy(&tmp, cpuset, cpusetsize);
+        /* Now do the syscall */
+        ret = syscall(__NR_sched_setaffinity, pid, PLPA_NAME(len), &tmp);
+        /* Return 0 upon success.  According to
+           http://www.open-mpi.org/community/lists/plpa-users/2006/02/0016.php,
+           all the kernel implementations return >= 0 upon success. */
+        return (ret >= 0) ? 0 : ret;
+        break;
+    case PLPA_NAME_CAPS(PROBE_NOT_SUPPORTED):
+        /* Process affinity not supported here */
+        return ENOSYS;
+        break;
+    default:
+        /* Something went wrong */
+        /* JMS: would be good to have something other than EINVAL here
+           -- suggestions? */
+        return EINVAL;
+        break;
+ * Call the kernel's getaffinity, massaging the user's input
+    int ret;
+            return ret;
+        return EINVAL;
+        return ret;
+    switch (api) {
+        if (PLPA_NAME(len) > sizeof(*cpuset)) {
+            return EINVAL;
+        /* If the user supplied a buffer that is too small, then don't
+           even bother */
+            return EINVAL;
+        /* Now we know that the user's buffer is >= the size required
+           by the kernel.  If it's >, then zero it out so that the
+           bits at the top are cleared (since they won't be set by the
+           kernel) */
+        if (cpusetsize > PLPA_NAME(len)) {
+            memset(cpuset, 0, cpusetsize);
+        ret = syscall(__NR_sched_getaffinity, pid, PLPA_NAME(len), cpuset);
+        break;
+        return ENOSYS;
+        break;
+    default:
+        return EINVAL;
+        break;
Added: mpich2/trunk/src/pm/hydra/utils/plpa/plpa_map.c
--- mpich2/trunk/src/pm/hydra/utils/plpa/plpa_map.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/plpa_map.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,1066 @@
+ * Portions of this file originally contributed by Advanced Micro
+ * Devices, Inc.  See notice below.
+ License Agreement
+ Copyright (c) 2006, 2007 Advanced Micro Devices, Inc.
+ Redistribution and use in any form of this material and any product
+ thereof including software in source or binary forms, along with any
+ related documentation, with or without modification ("this material"),
+ is permitted provided that the following conditions are met:
+ + Redistributions of source code of any software must retain the above
+ copyright notice and all terms of this license as part of the code.
+ + Redistributions in binary form of any software must reproduce the
+ above copyright notice and all terms of this license in any related
+ documentation and/or other materials.
+ + Neither the names nor trademarks of Advanced Micro Devices, Inc. or
+ any copyright holders or contributors may be used to endorse or
+ promote products derived from this material without specific prior
+ written permission.
+ + Notice about U.S. Government restricted rights: This material is
+ provided with "RESTRICTED RIGHTS." Use, duplication or disclosure by
+ the U.S. Government is subject to the full extent of restrictions set
+ forth in FAR52.227 and DFARS252.227 et seq., or any successor or
+ applicable regulations. Use of this material by the U.S. Government
+ constitutes acknowledgment of the proprietary rights of Advanced Micro
+ Devices, Inc.
+ and any copyright holders and contributors.
+ + In no event shall anyone redistributing or accessing or using this
+ material commence or participate in any arbitration or legal action
+ relating to this material against Advanced Micro Devices, Inc. or any
+ copyright holders or contributors. The foregoing shall survive any
+ expiration or termination of this license or any agreement or access
+ or use related to this material.
+ + ANY BREACH OF ANY TERM OF THIS LICENSE SHALL RESULT IN THE IMMEDIATE
+ REVOCATION OF ALL RIGHTS TO REDISTRIBUTE, ACCESS OR USE THIS MATERIAL.
+ THIS MATERIAL IS PROVIDED BY ADVANCED MICRO DEVICES, INC. AND ANY
+ COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" IN ITS CURRENT CONDITION
+ AND WITHOUT ANY REPRESENTATIONS, GUARANTEE, OR WARRANTY OF ANY KIND OR
+ IN ANY WAY RELATED TO SUPPORT, INDEMNITY, ERROR FREE OR UNINTERRUPTED
+ OPERATION, OR THAT IT IS FREE FROM DEFECTS OR VIRUSES.  ALL
+ OBLIGATIONS ARE HEREBY DISCLAIMED - WHETHER EXPRESS, IMPLIED, OR
+ STATUTORY - INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED WARRANTIES OF
+ TITLE, MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, ACCURACY,
+ COMPLETENESS, OPERABILITY, QUALITY OF SERVICE, OR NON-INFRINGEMENT. IN
+ NO EVENT SHALL ADVANCED MICRO DEVICES, INC. OR ANY COPYRIGHT HOLDERS
+ OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ SPECIAL, PUNITIVE, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ USE, REVENUE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
+ CAUSED OR BASED ON ANY THEORY OF LIABILITY ARISING IN ANY WAY RELATED
+ TO THIS MATERIAL, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ THE ENTIRE AND AGGREGATE LIABILITY OF ADVANCED MICRO DEVICES, INC. AND
+ ANY COPYRIGHT HOLDERS AND CONTRIBUTORS SHALL NOT EXCEED TEN DOLLARS
+ (US $10.00). ANYONE REDISTRIBUTING OR ACCESSING OR USING THIS MATERIAL
+ ACCEPTS THIS ALLOCATION OF RISK AND AGREES TO RELEASE ADVANCED MICRO
+ DEVICES, INC. AND ANY COPYRIGHT HOLDERS AND CONTRIBUTORS FROM ANY AND
+ ALL LIABILITIES, OBLIGATIONS, CLAIMS, OR DEMANDS IN EXCESS OF TEN
+ DOLLARS (US $10.00). THE FOREGOING ARE ESSENTIAL TERMS OF THIS LICENSE
+ AND, IF ANY OF THESE TERMS ARE CONSTRUED AS UNENFORCEABLE, FAIL IN
+ ESSENTIAL PURPOSE, OR BECOME VOID OR DETRIMENTAL TO ADVANCED MICRO
+ DEVICES, INC. OR ANY COPYRIGHT HOLDERS OR CONTRIBUTORS FOR ANY REASON,
+ THEN ALL RIGHTS TO REDISTRIBUTE, ACCESS OR USE THIS MATERIAL SHALL
+ TERMINATE IMMEDIATELY. MOREOVER, THE FOREGOING SHALL SURVIVE ANY
+ EXPIRATION OR TERMINATION OF THIS LICENSE OR ANY AGREEMENT OR ACCESS
+ OR USE RELATED TO THIS MATERIAL.
+ NOTICE IS HEREBY PROVIDED, AND BY REDISTRIBUTING OR ACCESSING OR USING
+ THIS MATERIAL SUCH NOTICE IS ACKNOWLEDGED, THAT THIS MATERIAL MAY BE
+ SUBJECT TO RESTRICTIONS UNDER THE LAWS AND REGULATIONS OF THE UNITED
+ STATES OR OTHER COUNTRIES, WHICH INCLUDE BUT ARE NOT LIMITED TO, U.S.
+ EXPORT CONTROL LAWS SUCH AS THE EXPORT ADMINISTRATION REGULATIONS AND
+ NATIONAL SECURITY CONTROLS AS DEFINED THEREUNDER, AS WELL AS STATE
+ DEPARTMENT CONTROLS UNDER THE U.S. MUNITIONS LIST. THIS MATERIAL MAY
+ NOT BE USED, RELEASED, TRANSFERRED, IMPORTED, EXPORTED AND/OR RE-
+ EXPORTED IN ANY MANNER PROHIBITED UNDER ANY APPLICABLE LAWS, INCLUDING
+ U.S. EXPORT CONTROL LAWS REGARDING SPECIFICALLY DESIGNATED PERSONS,
+ COUNTRIES AND NATIONALS OF COUNTRIES SUBJECT TO NATIONAL SECURITY
+ CONTROLS.
+ MOREOVER,
+ THE FOREGOING SHALL SURVIVE ANY EXPIRATION OR TERMINATION OF ANY
+ LICENSE OR AGREEMENT OR ACCESS OR USE RELATED TO THIS MATERIAL.
+ This license forms the entire agreement regarding the subject matter
+ hereof and supersedes all proposals and prior discussions and writings
+ between the parties with respect thereto. This license does not affect
+ any ownership, rights, title, or interest in, or relating to, this
+ material. No terms of this license can be modified or waived, and no
+ breach of this license can be excused, unless done so in a writing
+ signed by all affected parties. Each term of this license is
+ separately enforceable. If any term of this license is determined to
+ be or becomes unenforceable or illegal, such term shall be reformed to
+ the minimum extent necessary in order for this license to remain in
+ effect in accordance with its terms as modified by such reformation.
+ This license shall be governed by and construed in accordance with the
+ laws of the State of Texas without regard to rules on conflicts of law
+ of any state or jurisdiction or the United Nations Convention on the
+ International Sale of Goods. All disputes arising out of this license
+ shall be subject to the jurisdiction of the federal and state courts
+ in Austin, Texas, and all defenses are hereby waived concerning
+ personal jurisdiction and venue of these courts.
+#include "plpa.h"
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <stdio.h>
+#include <dirent.h>
+#include <limits.h>
+#include <errno.h>
+#include <stdlib.h>
+#include <stdbool.h>
+typedef struct tuple_t_ {
+    int processor_id, socket_id, core_id, online;
+} tuple_t;
+static const char *sysfs_mount = "/sys";
+static int supported = 0;
+static int num_processors = -1;
+static int max_processor_id = -1;
+static int num_sockets = -1;
+static int max_socket_id = -1;
+static int *max_core_id = NULL;
+static int *num_cores = NULL;
+static int max_core_id_overall = -1;
+static tuple_t *map_processor_id_to_tuple = NULL;
+static tuple_t **map_tuple_to_processor_id = NULL;
+static PLPA_NAME(cache_behavior_t) cache_behavior = PLPA_NAME_CAPS(CACHE_IGNORE);
+static void clear_cache(void)
+    if (NULL != max_core_id) {
+        free(max_core_id);
+        max_core_id = NULL;
+    if (NULL != num_cores) {
+        free(num_cores);
+        num_cores = NULL;
+    if (NULL != map_processor_id_to_tuple) {
+        free(map_processor_id_to_tuple);
+        map_processor_id_to_tuple = NULL;
+    if (NULL != map_tuple_to_processor_id) {
+        free(map_tuple_to_processor_id);
+        map_tuple_to_processor_id = NULL;
+    num_processors = max_processor_id = -1;
+    num_sockets = max_socket_id = -1;
+    max_core_id_overall = -1;
+static void load_cache(void)
+    int i, j, k, invalid_entry, fd, found_online;
+    char path[PATH_MAX], buf[8];
+    PLPA_NAME(cpu_set_t) valid_processors;
+    PLPA_NAME(cpu_set_t) *cores_on_sockets;
+    int found;
+    DIR *dir;
+    struct dirent dentry, *dentryp = NULL;
+#if PLPA_DEBUG
+    char *temp = getenv("PLPA_SYSFS_MOUNT");
+    if (temp) {
+        sysfs_mount = temp;
+#endif
+    /* Check for the parent directory */
+    sprintf(path, "%s/devices/system/cpu", sysfs_mount);
+    if (access(path, R_OK|X_OK)) {
+        return;
+    dir = opendir(path);
+    if (NULL == dir) {
+        return;
+    /* Catch all entries of format "cpu%d", count them and maintain
+       max_processor_id */
+    num_processors = 0;
+    PLPA_CPU_ZERO(&valid_processors);
+    do {
+        int ret = readdir_r(dir, &dentry, &dentryp);
+        if (0 != ret) {
+            closedir(dir);
+            clear_cache();
+            return;
+        if (dentryp) {
+            int cpuid;
+            ret = sscanf(dentryp->d_name, "cpu%d", &cpuid);
+            if (1 == ret) {
+                ++num_processors;
+                if (cpuid >= PLPA_BITMASK_CPU_MAX) {
+                    closedir(dir);
+                    clear_cache();
+                    return;
+                } else if (cpuid > max_processor_id) {
+                    max_processor_id = cpuid;
+                PLPA_CPU_SET(cpuid, &valid_processors);
+    } while (NULL != dentryp);
+    closedir(dir);
+    /* If we found no processors, then we have no topology info */
+    if (0 == num_processors) {
+        clear_cache();
+        return;
+    /* Malloc space for the first map (processor ID -> tuple).
+       Include enough space for one invalid entry. */
+    map_processor_id_to_tuple = malloc(sizeof(tuple_t) *
+                                       (max_processor_id + 2));
+    if (NULL == map_processor_id_to_tuple) {
+        clear_cache();
+        return;
+    for (i = 0; i <= max_processor_id; ++i) {
+        if (PLPA_CPU_ISSET(i, &valid_processors)) {
+            map_processor_id_to_tuple[i].processor_id = i;
+        } else {
+            map_processor_id_to_tuple[i].processor_id = -1;
+        map_processor_id_to_tuple[i].socket_id = -1;
+        map_processor_id_to_tuple[i].core_id = -1;
+    /* Set the invalid entry */
+    invalid_entry = i;
+    map_processor_id_to_tuple[invalid_entry].processor_id = -1;
+    map_processor_id_to_tuple[invalid_entry].socket_id = -1;
+    map_processor_id_to_tuple[invalid_entry].core_id = -1;
+    /* Build a cached map of (socket,core) tuples */
+    for (found = 0, i = 0; i <= max_processor_id; ++i) {
+        /* Check for invalid processor ID */
+        if (map_processor_id_to_tuple[i].processor_id < 0) {
+            continue;
+        /* Read the "online" state for this processor.  If the online
+           file is not there, then the kernel likely doesn't have
+           hotplug support so just assume that it's online.  Some notes:
+           - the perms on the "online" file are root/600, so only root
+             will see this info
+           - if online is 0, then all the topology files disappear (!)
+             -- so PLPA needs to compensate for that
+        found_online = 0;
+        sprintf(path, "%s/devices/system/cpu/cpu%d/online",
+                sysfs_mount, i);
+        fd = open(path, O_RDONLY);
+        memset(buf, 0, sizeof(buf));
+        if (fd >= 0 && read(fd, buf, sizeof(buf) - 1) > 0) {
+            found_online = 1;
+            sscanf(buf, "%d", &(map_processor_id_to_tuple[i].online));
+        } else {
+            map_processor_id_to_tuple[i].online = 1;
+        if (fd >= 0) {
+            close(fd);
+        /* Core ID */
+        sprintf(path, "%s/devices/system/cpu/cpu%d/topology/core_id",
+                sysfs_mount, i);
+        if (fd >= 0) {
+            if (read(fd, buf, sizeof(buf) - 1) > 0) {
+                sscanf(buf, "%d", &(map_processor_id_to_tuple[i].core_id));
+            } else {
+            close(fd);
+        /* Special case: we didn't find the core_id file, but we *did*
+           find the online file and the processor is offline -- then
+           just mark the core ID as "unknown" and keep going (because
+           if a processor is offline, the core_id file won't exist --
+           grumble) */
+        else if (found_online && 0 == map_processor_id_to_tuple[i].online) {
+        /* Socket ID */
+        sprintf(path,
+                "%s/devices/system/cpu/cpu%d/topology/physical_package_id",
+                sysfs_mount, i);
+        if (fd >= 0) {
+                sscanf(buf, "%d", &(map_processor_id_to_tuple[i].socket_id));
+            close(fd);
+            found = 1;
+        /* Special case: we didn't find the socket_id file, but we
+           *did* find the online file and the processor is offline --
+           then just mark the socket ID as "unknown" and keep going
+           (because if a processor is offline, the socket_id file won't
+           exist -- grumble) */
+        /* Keep a running tab on the max socket number */
+        if (map_processor_id_to_tuple[i].socket_id > max_socket_id) {
+            max_socket_id = map_processor_id_to_tuple[i].socket_id;
+    /* If we didn't find any core_id/physical_package_id's, then we
+       don't have the topology info */
+    if (!found) {
+        clear_cache();
+        return;
+    /* Now that we know the max number of sockets, allocate some
+       arrays */
+    max_core_id = malloc(sizeof(int) * (max_socket_id + 1));
+    if (NULL == max_core_id) {
+        clear_cache();
+        return;
+    num_cores = malloc(sizeof(int) * (max_socket_id + 1));
+    if (NULL == num_cores) {
+        clear_cache();
+        return;
+    for (i = 0; i <= max_socket_id; ++i) {
+        num_cores[i] = -1;
+        max_core_id[i] = -1;
+    /* Find the max core number on each socket */
+        if (map_processor_id_to_tuple[i].processor_id < 0 ||
+            map_processor_id_to_tuple[i].socket_id < 0) {
+            continue;
+        if (map_processor_id_to_tuple[i].core_id >
+            max_core_id[map_processor_id_to_tuple[i].socket_id]) {
+            max_core_id[map_processor_id_to_tuple[i].socket_id] =
+                map_processor_id_to_tuple[i].core_id;
+        if (max_core_id[map_processor_id_to_tuple[i].socket_id] >
+            max_core_id_overall) {
+                max_core_id[map_processor_id_to_tuple[i].socket_id];
+    /* Go through and count the number of unique sockets found.  It
+       may not be the same as max_socket_id because there may be
+       "holes" -- e.g., sockets 0 and 3 are used, but sockets 1 and 2
+       are empty. */
+    for (j = i = 0; i <= max_socket_id; ++i) {
+        if (max_core_id[i] >= 0) {
+            ++j;
+    if (j > 0) {
+        num_sockets = j;
+    /* Count how many cores are available on each socket.  This may
+       not be the same as max_core_id[socket_num] if there are
+       "holes".  I don't know if holes can happen (i.e., if specific
+       cores can be taken offline), but what the heck... */
+    cores_on_sockets = malloc(sizeof(PLPA_NAME(cpu_set_t)) *
+                              (max_socket_id + 1));
+    if (NULL == cores_on_sockets) {
+        clear_cache();
+        return;
+        PLPA_CPU_ZERO(&(cores_on_sockets[i]));
+        if (map_processor_id_to_tuple[i].socket_id >= 0) {
+            PLPA_CPU_SET(map_processor_id_to_tuple[i].core_id,
+                         &(cores_on_sockets[map_processor_id_to_tuple[i].socket_id]));
+        int count = 0;
+        for (j = 0; j <= max_core_id[i]; ++j) {
+            if (PLPA_CPU_ISSET(j, &(cores_on_sockets[i]))) {
+                ++count;
+        if (count > 0) {
+            num_cores[i] = count;
+    free(cores_on_sockets);
+    /* Now go through and build the map in the other direction:
+       (socket,core) => processor_id.  This map simply points to
+       entries in the other map (i.e., it's by reference instead of by
+       value). */
+    map_tuple_to_processor_id = malloc(sizeof(tuple_t *) *
+                                       ((max_socket_id + 1) *
+                                        (max_core_id_overall + 1)));
+    if (NULL == map_tuple_to_processor_id) {
+        clear_cache();
+        return;
+    /* Compute map */
+        for (j = 0; j <= max_core_id_overall; ++j) {
+            tuple_t **tuple_ptr = &map_tuple_to_processor_id[
+                                   i * (max_core_id_overall + 1) + j];
+            /* Default to the invalid entry in the other map, meaning
+               that this (socket,core) combination doesn't exist
+               (e.g., the core number does not exist in this socket,
+               although it does exist in other sockets). */
+            *tuple_ptr = &map_processor_id_to_tuple[invalid_entry];
+            /* See if this (socket,core) tuple exists in the other
+               map.  If so, set this entry to point to it (overriding
+               the invalid entry default). */
+            for (k = 0; k <= max_processor_id; ++k) {
+                if (map_processor_id_to_tuple[k].socket_id == i &&
+                    map_processor_id_to_tuple[k].core_id == j) {
+                    *tuple_ptr = &map_processor_id_to_tuple[k];
+#if defined(PLPA_DEBUG) && PLPA_DEBUG
+                    printf("Creating map [%d]: (socket %d, core %d) -> ID %d\n",
+                           i * (max_core_id_overall + 1) + j,
+                           i, j, k);
+#endif
+                    break;
+    supported = 1;
+static int cache_action(void)
+    switch (cache_behavior) {
+    case PLPA_NAME_CAPS(CACHE_USE):
+            load_cache();
+        break;
+    case PLPA_NAME_CAPS(CACHE_IGNORE):
+        clear_cache();
+        load_cache();
+        break;
+    default:
+        return EINVAL;
+    return 0;
+/* Return whether this kernel supports topology information or not */
+int PLPA_NAME(have_topology_information)(int *supported_arg)
+    int ret;
+    /* Initialize if not already done so */
+            return ret;
+    if (NULL == supported_arg) {
+        return EINVAL;
+    *supported_arg = supported;
+    return 0;
+    int ret;
+            return ret;
+    /* If this system doesn't support mapping, sorry Charlie */
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == processor_id) {
+        return EINVAL;
+    /* Check cache behavior */
+    if (0 != (ret = cache_action())) {
+        return ret;
+    /* Check for some invalid entries */
+    if (socket_id < 0 || socket_id > max_socket_id ||
+        core_id < 0 || core_id > max_core_id[socket_id]) {
+        return ENOENT;
+    /* If the mapping returns -1, then this is a non-existent
+       socket/core combo (even though they fall within the max socket
+       / max core overall values) */
+    ret = map_tuple_to_processor_id[socket_id * (max_core_id_overall + 1) +
+                                    core_id]->processor_id;
+    if (-1 == ret) {
+        return ENOENT;
+    /* Ok, all should be good -- return the mapping */
+    *processor_id = ret;
+    return 0;
+    int ret;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == socket_id || NULL == core_id) {
+        return EINVAL;
+        return ret;
+    if (processor_id < 0 || processor_id > max_processor_id ||
+        map_processor_id_to_tuple[processor_id].processor_id < 0) {
+        return ENOENT;
+    ret = map_processor_id_to_tuple[processor_id].socket_id;
+    if (-1 == ret) {
+        return ENOENT;
+    *socket_id = ret;
+    *core_id = map_processor_id_to_tuple[processor_id].core_id;
+    return 0;
+/* Deprecated function */
+int PLPA_NAME(get_processor_info)(int *num_processors_arg,
+                                  int *max_processor_id_arg)
+    return PLPA_NAME(get_processor_data)(PLPA_NAME_CAPS(COUNT_ALL),
+                                         num_processors_arg,
+                                         max_processor_id_arg);
+                                  int *num_processors_arg,
+    int i, ret;
+    bool match;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+        return ret;
+    if (NULL == max_processor_id_arg || NULL == num_processors_arg) {
+        return EINVAL;
+    /* If we wanted all processors, we're done */
+    if (PLPA_NAME_CAPS(COUNT_ALL) == count_spec) {
+        *num_processors_arg = num_processors;
+        *max_processor_id_arg = max_processor_id;
+    } else {
+        /* Otherwise, count the appropriate type */
+        *num_processors_arg = 0;
+        *max_processor_id_arg = 0;
+            if (map_processor_id_to_tuple[i].processor_id >= 0) {
+                match = false;
+                switch (count_spec) {
+                case PLPA_NAME_CAPS(COUNT_ONLINE):
+                    if (map_processor_id_to_tuple[i].online) {
+                        match = true;
+                    break;
+                case PLPA_NAME_CAPS(COUNT_OFFLINE):
+                    if (!map_processor_id_to_tuple[i].online) {
+                        match = true;
+                    break;
+                default:
+                    /* Just so that compilers don't complain */
+                    break;
+                if (match) {
+                    ++(*num_processors_arg);
+                    if (*max_processor_id_arg <
+                        map_processor_id_to_tuple[i].processor_id) {
+                            map_processor_id_to_tuple[i].processor_id;
+    return 0;
+/* Returns the Linux processor ID for the Nth processor (starting with
+   0). */
+    int ret, i, count;
+    bool match;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+        return EINVAL;
+        return ret;
+    /* Check for out of range params */
+    if (processor_num < 0 || processor_num > num_processors) {
+        return EINVAL;
+    /* Find the processor_num'th processor */
+    for (count = i = 0; i <= max_processor_id; ++i) {
+            match = false;
+                    match = true;
+                break;
+                    match = true;
+                break;
+            case PLPA_NAME_CAPS(COUNT_ALL):
+                match = true;
+                break;
+            if (match) {
+                if (count++ == processor_num) {
+                    *processor_id = map_processor_id_to_tuple[i].processor_id;
+                    return 0;
+    /* Didn't find it */
+    return ENODEV;
+                                   int *exists_arg, int *online_arg)
+    int ret, exists, online;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == exists_arg && NULL == online_arg) {
+        return EINVAL;
+        return ret;
+    if (processor_id < 0 || processor_id > max_processor_id) {
+        return EINVAL;
+    exists = online = 0;
+    if (processor_id == map_processor_id_to_tuple[processor_id].processor_id) {
+        exists = 1;
+        if (map_processor_id_to_tuple[processor_id].online) {
+            online = 1;
+    if (NULL != exists_arg) {
+        *exists_arg = exists;
+    if (NULL != online_arg) {
+        *online_arg = online;
+    return 0;
+/* Return the max socket number */
+int PLPA_NAME(get_socket_info)(int *num_sockets_arg, int *max_socket_id_arg)
+    int ret;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+        return ret;
+    if (NULL == max_socket_id_arg || NULL == num_sockets_arg) {
+        return EINVAL;
+    /* All done */
+    *num_sockets_arg = num_sockets;
+    *max_socket_id_arg = max_socket_id;
+    return 0;
+/* Returns the Linux socket ID for the Nth socket (starting with 0). */
+    int ret, i, j, k, count;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == socket_id) {
+        return EINVAL;
+        return ret;
+    if (socket_num < 0 || socket_num > num_sockets) {
+        return EINVAL;
+    /* Find the socket_num'th socket */
+    for (count = i = 0; i <= max_socket_id; ++i) {
+        /* See if any core in this socket is active.  If so, count
+           this socket */
+            k = i * (max_core_id_overall + 1) + j;
+            if (map_tuple_to_processor_id[k]->processor_id >= 0) {
+                if (count++ == socket_num) {
+                    *socket_id = map_tuple_to_processor_id[k]->socket_id;
+                    return 0;
+                /* Ok, we found one -- skip to the end of this socket */
+                j = max_core_id_overall + 1;
+    return ENODEV;
+/* Return the number of cores in a socket and the max core ID number */
+int PLPA_NAME(get_core_info)(int socket_id, int *num_cores_arg,
+                             int *max_core_id_arg)
+    int ret;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == max_core_id_arg || NULL == num_cores_arg) {
+        return EINVAL;
+        return ret;
+        -1 == max_core_id[socket_id]) {
+        return ENOENT;
+    ret = num_cores[socket_id];
+    if (-1 == ret) {
+        return ENOENT;
+    /* All done */
+    *num_cores_arg = ret;
+    *max_core_id_arg = max_core_id[socket_id];
+    return 0;
+/* Given a specific socket, returns the Linux core ID for the Nth core
+   (starting with 0) */
+    int ret, i, j, count;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+    if (NULL == core_id) {
+        return EINVAL;
+        return ret;
+        core_num < 0 || core_num > max_core_id_overall) {
+        return EINVAL;
+    /* Find the core_num'th core */
+    for (count = i = 0, j = socket_id * (max_core_id_overall + 1);
+         i <= max_core_id_overall; ++i) {
+        if (map_tuple_to_processor_id[j + i]->processor_id >= 0) {
+            if (count++ == core_num) {
+                *core_id = map_tuple_to_processor_id[j + i]->core_id;
+                return 0;
+    return ENODEV;
+    int ret, i, exists, online;
+            return ret;
+    if (!supported) {
+        return ENOSYS;
+        return EINVAL;
+        return ret;
+        core_id < 0 || core_id > max_core_id_overall) {
+        return EINVAL;
+    i = socket_id * (max_core_id_overall + 1) + core_id;
+    if (map_tuple_to_processor_id[i]->processor_id >= 0) {
+        exists = 1;
+        if (map_tuple_to_processor_id[i]->online) {
+            online = 1;
+    return 0;
+/* Set PLPA's caching behavior */
+int PLPA_NAME(set_cache_behavior)(PLPA_NAME(cache_behavior_t) behavior)
+    switch (behavior) {
+        if (PLPA_NAME_CAPS(CACHE_USE) != cache_behavior) {
+            load_cache();
+            cache_behavior = PLPA_NAME_CAPS(CACHE_USE);
+        break;
+        if (PLPA_NAME_CAPS(CACHE_IGNORE) != cache_behavior) {
+            clear_cache();
+            cache_behavior = PLPA_NAME_CAPS(CACHE_IGNORE);
+        break;
+    case PLPA_NAME_CAPS(CACHE_REFRESH):
+            return EINVAL;
+        clear_cache();
+        load_cache();
+        break;
+    default:
+        return EINVAL;
+    return 0;
Added: mpich2/trunk/src/pm/hydra/utils/plpa/plpa_runtime.c
--- mpich2/trunk/src/pm/hydra/utils/plpa/plpa_runtime.c	                        (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/plpa/plpa_runtime.c	2009-03-18 23:47:33 UTC (rev 4124)
@@ -0,0 +1,72 @@
+ * Copyright (c) 2007 Cisco Systems, Inc.  All rights reserved.
+#include "plpa.h"
+#include <errno.h>
+#include <pthread.h>
+/* Global variables */
+int PLPA_NAME(initialized) = 0;
+/* Local variables */
+static int refcount = 0;
+static pthread_mutex_t mutex;
+/* Central clearing point for all parts of PLPA that need to be
+   initialized.  It is erroneous to call this function by more than
+   one thread simultaneously. */
+    int ret;
+    /* If we're already initialized, simply increase the refcount */
+    if (PLPA_NAME(initialized)) {
+        pthread_mutex_lock(&mutex);
+        ++refcount;
+        pthread_mutex_unlock(&mutex);
+        return 0;
+    /* Otherwise, initialize all the sybsystems */
+    if (0 != (ret = pthread_mutex_init(&mutex, NULL)) ||
+        0 != (ret = PLPA_NAME(api_probe_init)()) ||
+        0 != (ret = PLPA_NAME(set_cache_behavior)(PLPA_NAME_CAPS(CACHE_USE)))) {
+        return ret;
+    PLPA_NAME(initialized) = 1;
+    refcount = 1;
+    return 0;
+   shutdown. */
+    int val;
+    /* If we're not initialized, return an error */
+        return ENOENT;
+    /* Decrement and check the refcount.  If it's nonzero, then simply
+       return success. */
+    val = --refcount;
+    if (0 != val) {
+        return 0;
+    /* Ok, we're the last one.  Cleanup. */
+    PLPA_NAME(set_cache_behavior)(PLPA_NAME_CAPS(CACHE_IGNORE));
+    pthread_mutex_destroy(&mutex);
+    PLPA_NAME(initialized) = 0;
+    return 0;
More information about the mpich2-commits mailing list
