[mpich2-commits] r4123 - in mpich2/trunk/test/mpi: . errors errors/faults
gropp at mcs.anl.gov
Wed Mar 18 16:15:10 CDT 2009
Author: gropp
Date: 2009-03-18 16:15:10 -0500 (Wed, 18 Mar 2009)
New Revision: 4123
Added:
mpich2/trunk/test/mpi/errors/faults/
mpich2/trunk/test/mpi/errors/faults/Makefile.sm
mpich2/trunk/test/mpi/errors/faults/pt2ptf1.c
mpich2/trunk/test/mpi/errors/faults/testlist
Modified:
mpich2/trunk/test/mpi/configure.in
mpich2/trunk/test/mpi/errors/Makefile.sm
mpich2/trunk/test/mpi/errors/testlist.in
Log:
Added an optional test for handling of faults in MPI programs - MPICH2 fails this, but now there is something to test
Modified: mpich2/trunk/test/mpi/configure.in
--- mpich2/trunk/test/mpi/configure.in 2009-03-18 20:15:18 UTC (rev 4122)
+++ mpich2/trunk/test/mpi/configure.in 2009-03-18 21:15:10 UTC (rev 4123)
@@ -67,6 +67,8 @@
,enable_spawn=yes)
AC_ARG_ENABLE(checkerrors,
[--enable-checkerrors - Add some tests for checking for errors in user programs],,enable_checkerrors=default)
+AC_ARG_ENABLE(checkfaults,
+[--enable-checkfaults - Add some tests for checking on handling of faults in user programs],,enable_checkfaults=no)
AC_ARG_ENABLE(fast,
[--enable-fast - Indicates that the MPI implementation may have been built for fastest operation, such as building without error checking. Has the effect of --enable-checkerrors=no])
AC_ARG_ENABLE(strictmpi,
@@ -248,6 +250,12 @@
AC_DEFINE(HAVE_MPI_WIN_CREATE,1,[Define if MPI_Win_create is available])
fi
AC_SUBST(rmadir)
+faultsdir=#
+if test "$enable_checkfaults" = "yes" ; then
+ faultsdir=faults
+fi
+AC_SUBST(faultsdir)
if test "$enable_strictmpi" = "yes" ; then
AC_DEFINE(USE_STRICT_MPI,1,[Define if only operations defined in MPI should be tested])
@@ -1069,6 +1077,7 @@
errors/basic/Makefile \
errors/coll/Makefile \
errors/comm/Makefile \
+ errors/faults/Makefile \
errors/group/Makefile \
errors/pt2pt/Makefile \
errors/rma/Makefile \
Modified: mpich2/trunk/test/mpi/errors/Makefile.sm
--- mpich2/trunk/test/mpi/errors/Makefile.sm 2009-03-18 20:15:18 UTC (rev 4122)
+++ mpich2/trunk/test/mpi/errors/Makefile.sm 2009-03-18 21:15:10 UTC (rev 4123)
@@ -1,5 +1,5 @@
SUBDIRS_otherlangs = cxx f77 f90
-SUBDIRS = attr coll comm group pt2pt rma spawn topo io @otherlangs@ basic
+SUBDIRS = attr coll comm group pt2pt rma spawn topo io @otherlangs@ basic faults
testing:
../runtests -srcdir=$(srcdir) -tests=testlist \
Added: mpich2/trunk/test/mpi/errors/faults/Makefile.sm
--- mpich2/trunk/test/mpi/errors/faults/Makefile.sm (rev 0)
+++ mpich2/trunk/test/mpi/errors/faults/Makefile.sm 2009-03-18 21:15:10 UTC (rev 4123)
@@ -0,0 +1,14 @@
+INCLUDES = -I../../include -I${top_srcdir}/include
+LDADD = ../../util/mtest.o
+DEPADD = @MPILIBLOC@ ../../util/mtest.o
+smvar_do_sharedlibs = 0
+pt2ptf1_SOURCES = pt2ptf1.c
+../../util/mtest.o:
+ (cd ../../util && make mtest.o)
+testing:
+ ../../runtests -srcdir=$(srcdir) -tests=testlist \
+ -mpiexec=$(bindir)/mpiexec \
+ -xmlfile=summary.xml
Added: mpich2/trunk/test/mpi/errors/faults/pt2ptf1.c
--- mpich2/trunk/test/mpi/errors/faults/pt2ptf1.c (rev 0)
+++ mpich2/trunk/test/mpi/errors/faults/pt2ptf1.c 2009-03-18 21:15:10 UTC (rev 4123)
@@ -0,0 +1,52 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2009 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#include "mpi.h"
+#include <stdio.h>
+#include "mpitest.h"
+static char MTEST_Descrip[] = "Test err in status return, using truncated \
+messages for MPI_Testall";
+int main( int argc, char *argv[] )
+ int wrank, wsize, rank, size, color;
+ int i, j, tmp;
+ MPI_Comm newcomm;
+ MPI_Init( &argc, &argv );
+ MPI_Comm_size( MPI_COMM_WORLD, &wsize );
+ MPI_Comm_rank( MPI_COMM_WORLD, &wrank );
+ /* Color is 0 or 1; 1 will be the processes that "fault" */
+ color = (wrank > 0) && (wrank <= wsize/2);
+ MPI_Comm_split( MPI_COMM_WORLD, color, wrank, &newcomm );
+ MPI_Barrier( MPI_COMM_WORLD );
+ if (color) {
+ /* Simulate a fault on some processes */
+ exit(1);
+ /* Can we still use newcomm? */
+ MPI_Comm_size( newcomm, &size );
+ MPI_Comm_rank( newcomm, &rank );
+ for (j=0; j<rank; j++) {
+ MPI_Recv( &tmp, 1, MPI_INT, j, 0, newcomm, MPI_STATUS_IGNORE );
+ for (j=rank+1; j<size; j++) {
+ MPI_Send( &rank, 1, MPI_INT, j, 0, newcomm );
+ MPI_Comm_free( &newcomm );
+ MPI_Finalize();
+ printf( " No Errors\n" );
+ return 0;
Added: mpich2/trunk/test/mpi/errors/faults/testlist
--- mpich2/trunk/test/mpi/errors/faults/testlist (rev 0)
+++ mpich2/trunk/test/mpi/errors/faults/testlist 2009-03-18 21:15:10 UTC (rev 4123)
@@ -0,0 +1 @@
+pt2ptf1 4
\ No newline at end of file
Modified: mpich2/trunk/test/mpi/errors/testlist.in
--- mpich2/trunk/test/mpi/errors/testlist.in 2009-03-18 20:15:18 UTC (rev 4122)
+++ mpich2/trunk/test/mpi/errors/testlist.in 2009-03-18 21:15:10 UTC (rev 4123)
@@ -10,3 +10,4 @@
@f77dir@
@cxxdir@
@f90dir@
+ at faultsdir@
More information about the mpich2-commits
