[mpich2-commits] r4092 - in mpich2/trunk: maint src/packaging src/packaging/spec
balaji at mcs.anl.gov
Mon Mar 16 15:22:47 CDT 2009
Author: balaji
Date: 2009-03-16 15:22:47 -0500 (Mon, 16 Mar 2009)
New Revision: 4092
Added:
mpich2/trunk/src/packaging/spec/
mpich2/trunk/src/packaging/spec/README
mpich2/trunk/src/packaging/spec/fedora.spec.in
Modified:
mpich2/trunk/maint/updatefiles
Log:
Adding the first draft of the Fedora spec file contributed by Deji
Akingunola. Thanks!
Modified: mpich2/trunk/maint/updatefiles
--- mpich2/trunk/maint/updatefiles 2009-03-16 19:13:17 UTC (rev 4091)
+++ mpich2/trunk/maint/updatefiles 2009-03-16 20:22:47 UTC (rev 4092)
@@ -754,6 +754,11 @@
VERSION=`cat maint/Version`
sed -e "s/%VERSION%/${VERSION}/g" README.vin > README
+BASIC_VERSION=`expr $VERSION : '\([0-9]*\.[0-9]*[\.]*[0-9]*\)[a-zA-Z]*[0-9]*'`
+VERSION_EXT=`expr $VERSION : '[0-9]*\.[0-9]*[\.]*[0-9]*\([a-zA-Z]*[0-9]*\)'`
+sed -e "s/%BASIC_VERSION%/${BASIC_VERSION}/g" -e "s/%VERSION_EXT%/${VERSION_EXT}/g" \
+ src/packaging/spec/fedora.spec.in > src/packaging/spec/fedora.spec
# The following must be the last statements executed
if [ -n "$error_summary" ] ; then
Property changes on: mpich2/trunk/src/packaging/spec
___________________________________________________________________
+ *.spec
Added: mpich2/trunk/src/packaging/spec/README
--- mpich2/trunk/src/packaging/spec/README (rev 0)
+++ mpich2/trunk/src/packaging/spec/README 2009-03-16 20:22:47 UTC (rev 4092)
@@ -0,0 +1,5 @@
+This directory contains the spec file for building MPICH2 SRPMS on
+the Fedora Linux distribution.
+Thanks to Deji Akingunola (dakingun at gmail.com) for contributing and
+maintaining this file.
Added: mpich2/trunk/src/packaging/spec/fedora.spec.in
--- mpich2/trunk/src/packaging/spec/fedora.spec.in (rev 0)
+++ mpich2/trunk/src/packaging/spec/fedora.spec.in 2009-03-16 20:22:47 UTC (rev 4092)
@@ -0,0 +1,323 @@
+Summary: A high-performance implementation of MPI
+Name: mpich2
+Version: %BASIC_VERSION%
+Release: %VERSION_EXT%
+License: MIT
+Group: Development/Libraries
+URL: http://www.mcs.anl.gov/research/projects/mpich2
+Source: http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/%{version}%{release}/src/%{name}-%{version}%{release}.tar.gz
+BuildRoot: %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
+BuildRequires: libXt-devel, e2fsprogs-devel
+BuildRequires: java-devel, gcc-gfortran
+BuildRequires: emacs-common, perl, python
+Requires: %{name}-libs = %{version}-%{release}
+Requires: python
+Requires(post): chkconfig
+Requires(preun):chkconfig
+#Requires chkconfig for /usr/sbin/alternatives
+%description
+MPICH2 is a high-performance and widely portable implementation of the
+MPI standard. This release has all MPI-2.1 functions and features
+required by the standard with the exeption of support for the
+"external32" portable I/O format.
+The mpich2 binaries in Fedora were configured to use the default
+process manager 'MPD' using the default device 'ch3'. The ch3 device
+was configured with support for the nemesis channel that allows for
+shared-memory and TCP/IP sockets based communication.
+The Fedora builds also include support for using '/usr/sbin/alternatives'
+and/or the 'module environment' to select which MPI implementation to use
+when multiple implementations are installed.
+%package devel
+Summary: Development files for mpich2
+Requires: %{name} = %{version}-%{release}
+Requires: pkgconfig
+Requires: gcc-gfortran
+Requires(post): /usr/sbin/alternatives
+Requires(preun):/usr/sbin/alternatives
+%description devel
+Contains development headers and libraries for mpich2
+%package libs
+Summary: Libraries and configuration files for mpich2
+%description libs
+Contains the arch dependent libraries and their build configuration for mpich2
+# We only compile with gcc, but other people may want other compilers.
+# Set the compiler here.
+%{!?opt_cc: %define opt_cc gcc}
+%{!?opt_fc: %define opt_fc gfortran}
+# Optional CFLAGS to use with the specific compiler...gcc doesn't need any,
+# so uncomment and undefine to NOT use
+%{!?opt_cc_cflags: %define opt_cc_cflags %{optflags}}
+%{!?opt_fc_fflags: %define opt_fc_fflags %{optflags}}
+%ifarch %{ix86} x86_64
+%define selected_channels ch3:nemesis
+%else
+%define selected_channels ch3:sock
+%endif
+%ifarch x86_64 ia64 ppc64 s390x sparc64
+%define mode 64
+%define priority 41
+%else
+%define mode 32
+%define priority 40
+%endif
+%ifarch x86_64
+%define XFLAGS -fPIC
+%endif
+%prep
+%setup -q -n %{name}-%{version}b1
+%configure \
+ --enable-sharedlibs=gcc \
+ --with-device=%{selected_channels} \
+ --sysconfdir=%{_sysconfdir}/%{name}-%{mode} \
+ --includedir=%{_includedir}/%{name} \
+ --libdir=%{_libdir}/%{name} \
+ --datadir=%{_datadir}/%{name} \
+ --docdir=%{_docdir}/%{name}-%{version} \
+ --htmldir=%{_docdir}/%{name}-%{version}/www \
+ --with-java=%{_sysconfdir}/alternatives/java_sdk \
+ F90=%{opt_fc} \
+ F77=%{opt_fc} \
+ CFLAGS="%{?opt_cc_cflags} %{?XFLAGS}" \
+ CXXFLAGS="%{optflags} %{?XFLAGS}" \
+ F90FLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
+ FFLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
+ LDFLAGS='-Wl,-z,noexecstack'
+%build
+#make %{?_smp_mflags} doesn't work
+make
+%install
+rm -rf %{buildroot}
+make DESTDIR=%{buildroot} install
+## Resolve clashes with LAM/OPENMP: mpicxx mpicc mpif77 mpif90 mpiexec mpirun
+rm -f %{buildroot}%{_bindir}/{mpiexec,mpirun,mpdrun}
+mv %{buildroot}%{_mandir}/man1/{,mp-}mpiexec.1
+pushd %{buildroot}%{_bindir}/
+ln -s mpiexec.py mpdrun
+popd
+for b in mpicxx mpicc mpif77 mpif90; do
+ mv %{buildroot}%{_bindir}/$b %{buildroot}%{_bindir}/mp%{mode}-$b;
+ mv %{buildroot}%{_mandir}/man1/$b.1 %{buildroot}%{_mandir}/man1/mp-$b.1;
+done
+## Setup the executables for environment module
+mkdir -p %{buildroot}%{_datadir}/%{name}/bin%{mode}
+ ln -s ../../../bin/mp%{mode}-$b %{buildroot}%{_datadir}/%{name}/bin%{mode}/$b
+done
+for ex in mpiexec mpirun; do
+ ln -s ../../../bin/mpiexec.py %{buildroot}%{_datadir}/%{name}/bin%{mode}/$ex
+done
+mv %{buildroot}%{_libdir}/%{name}/pkgconfig %{buildroot}%{_libdir}/
+chmod -x %{buildroot}%{_libdir}/pkgconfig/*.pc
+# Adjust the default module PATH for our changes
+sed -i 's#bin#bin'%{mode}'#' %{buildroot}%{_datadir}/%{name}/%{name}.module
+# Manually copy doc file here instead of the %files section to prevent the rpm
+#build script from throwing the other things in there out
+cp -pr CHANGES COPYRIGHT README RELEASE_NOTES %{buildroot}%{_docdir}/%{name}-%{version}/
+cp -pr src/mpe2/README %{buildroot}%{_docdir}/%{name}-%{version}/README.mpe
+# Silence rpmlint
+sed -i '/^#! \//,1 d' %{buildroot}%{_sysconfdir}/%{name}-%{mode}/{mpi*.conf,mpe_help.*}
+#Rename the MPI routine manpages, to avoid conflict with openmpi
+for man in %{buildroot}%{_mandir}/man3/*; do
+ manf=`basename $man .3`
+ mv %{buildroot}%{_mandir}/man3/$manf.3 %{buildroot}%{_mandir}/man4/$manf.4
+ sed s/3/4/1 -i %{buildroot}%{_mandir}/man4/$manf.4
+done
+# The uninstall script that is installed in this directory is not needed in rpm
+# packaging
+rm -rf %{buildroot}%{_sbindir}/mpe*
+find %{buildroot} -type f -name "*.la" -exec rm -f {} ';'
+%clean
+%post
+/usr/sbin/alternatives \
+ --install %{_bindir}/mpirun mpi-run %{_bindir}/mpiexec.py 41 \
+ --slave %{_bindir}/mpiexec mpi-exec %{_bindir}/mpiexec.py \
+ --slave %{_mandir}/man1/mpiexec.1.gz mpi-exec-man \
+ %{_mandir}/man1/mp-mpiexec.1.gz \
+ --slave %{_mandir}/man1/mpif90.1.gz mpif90-man \
+ %{_mandir}/man1/mp-mpif90.1.gz \
+ --slave %{_mandir}/man1/mpif77.1.gz mpif77-man \
+ %{_mandir}/man1/mp-mpif77.1.gz \
+ --slave %{_mandir}/man1/mpicc.1.gz mpicc-man \
+ %{_mandir}/man1/mp-mpicc.1.gz \
+ --slave %{_mandir}/man1/mpic++.1.gz mpic++-man \
+ %{_mandir}/man1/mp-mpicxx.1.gz
+%preun
+/usr/sbin/alternatives --remove mpi-run %{_bindir}/mpiexec.py
+%post devel
+ --install %{_bindir}/mpicc mpicc %{_bindir}/mp%{mode}-mpicc %{priority}\
+ --slave %{_bindir}/mpicxx mpicxx %{_bindir}/mp%{mode}-mpicxx \
+ --slave %{_bindir}/mpif90 mpif90 %{_bindir}/mp%{mode}-mpif90 \
+ --slave %{_bindir}/mpif77 mpif77 %{_bindir}/mp%{mode}-mpif77
+%preun devel
+/usr/sbin/alternatives --remove mpicc %{_bindir}/mp%{mode}-mpicc
+%files
+%defattr(-,root,root,-)
+%{_bindir}/*
+%dir %{_datadir}/%{name}
+%dir %{_datadir}/%{name}/bin%{mode}
+%{_datadir}/%{name}/bin%{mode}/mpiexec
+%{_datadir}/%{name}/bin%{mode}/mpirun
+%exclude %{_bindir}/mp%{mode}-mpicc
+%exclude %{_bindir}/mp%{mode}-mpicxx
+%exclude %{_bindir}/mp%{mode}-mpif90
+%exclude %{_bindir}/mp%{mode}-mpif77
+%doc %{_docdir}/%{name}-%{version}/
+%{_mandir}/man1/*
+%if 0%{?fedora} < 11
+%exclude %{_bindir}/mp*.pyc
+%exclude %{_bindir}/mp*.pyo
+%endif
+%files libs
+%dir %{_libdir}/%{name}
+%{_libdir}/%{name}/*.jar
+%{_libdir}/%{name}/mpe*.o
+%{_libdir}/%{name}/*.so.*
+%config %{_sysconfdir}/%{name}-%{mode}/
+%files devel
+%{_bindir}/mp%{mode}-mpicc
+%{_bindir}/mp%{mode}-mpicxx
+%{_bindir}/mp%{mode}-mpif90
+%{_bindir}/mp%{mode}-mpif77
+%{_includedir}/*
+%{_libdir}/%{name}/*.a
+%{_libdir}/%{name}/trace_rlog/libTraceInput.so
+%{_libdir}/pkgconfig/%{name}-ch3.pc
+%{_datadir}/%{name}/%{name}.module
+%{_datadir}/%{name}/bin%{mode}/mpicc
+%{_datadir}/%{name}/bin%{mode}/mpicxx
+%{_datadir}/%{name}/bin%{mode}/mpif90
+%{_datadir}/%{name}/bin%{mode}/mpif77
+%{_datadir}/%{name}/examples*
+%{_datadir}/%{name}/logfiles/
+%{_mandir}/man4/*.gz
+%doc README.testing README.romio README.developer
+%changelog
+* Mon Mar 16 2009 Deji Akingunola <dakingun at gmail.com> - 1.1-0.1
+- Update for the 1.1 (beta) release
+- Stop building with dllchan, it is not fully supported
+* Mon Mar 09 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-3
+- Drop the ssm channel from ppc* archs, it fails to build
+- Python scripts in bindir and sbindir are no longer bytecompiled (F-11+)
+- Enhance the spec file to support ia64 and sparc
+- Include mpiexec and mpirun (symlinks) in the environment module bindir
+* Fri Mar 06 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-2
+- Fix the source url, pointed out from package review
+- Finally accepted to go into Fedora
+* Sat Oct 24 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.8-1
+- Update to the 1.0.8
+- Configure with the default nemesis channel
+* Fri May 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-5
+- Update the alternate compiler/compiler flags macro to allow overriding it
+ from command-line
+* Wed Apr 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-4
+- Apply patch from Orion Poplawski to silence rpmlint
+* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-3
+- Add a note on the device/channels configuration options used, and
+- Fix logfile listings as suggested by Orion Poplawski (Package review, 171993)
+* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-2
+* Sat Apr 05 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-1
+- Update to 1.0.7
+* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6p1-1
+- Update to 1.0.6p1
+* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6-1
+- New version upgrade
+* Mon Jul 31 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-4
+- Create a -mpi-manpages subpackage for the MPI routines manuals
+* Fri Jul 27 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-3
+- Fix java-gcj-compat BR
+- Handle upgrades in the post scripts
+* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-2
+- Fix typos and make other adjustments arising from Fedora package reviews
+* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-1
+- Patch #4 release
+* Mon Feb 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p2-1
+- Patch #2 release
+* Tue Jan 09 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p1-1
+- New release with manpages
+- Create a -libs subpackage as it's done in Fedora's openmpi to help with
+ multi-libs packaging
+- Disable modules support (until I can properly figure it out)
+* Wed Dec 27 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.5-1
+- New release
+* Sat Nov 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-2
+- Set the java_sdk directory so all java bit work
+* Sat Sep 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-1
+- Update to version 1.0.4p1
+- Cleanup up spec file to use alternatives similarly to FC's openmpi
+* Wed Aug 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4-1
+* Thu May 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-3
+- Add missing BRs (Orion Polawski)
+* Mon Apr 10 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-2
+- Rewrite the spec, borrowing extensively from openmpi's spec by Jason Vas Dias
+- Allows use of environment modules and alternatives
+* Fri Nov 25 2005 Deji Akingunola <dakingun at gmail.com> - 1.0.3-1
+- Update to new version
+* Sat Oct 15 2005 Deji Akingunola <deji.aking at gmail.com> - 1.0.2p1-1
+- Initial package
More information about the mpich2-commits
