[mpich2-commits] r4091 - in mpich2/trunk/src/pm/hydra: demux include launcher/mpiexec pm/central utils/launch utils/sock utils/string
balaji at mcs.anl.gov
Mon Mar 16 14:13:18 CDT 2009
Author: balaji
Date: 2009-03-16 14:13:17 -0500 (Mon, 16 Mar 2009)
New Revision: 4091
Modified:
mpich2/trunk/src/pm/hydra/demux/demux.c
mpich2/trunk/src/pm/hydra/include/hydra_utils.h
mpich2/trunk/src/pm/hydra/launcher/mpiexec/callback.c
mpich2/trunk/src/pm/hydra/pm/central/proxy_cb.c
mpich2/trunk/src/pm/hydra/utils/launch/launch.c
mpich2/trunk/src/pm/hydra/utils/sock/sock.c
mpich2/trunk/src/pm/hydra/utils/string/string.c
Log:
Use strerror where available for better error information.
Modified: mpich2/trunk/src/pm/hydra/demux/demux.c
--- mpich2/trunk/src/pm/hydra/demux/demux.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/demux/demux.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -139,7 +139,8 @@
status = HYD_SUCCESS;
goto fn_exit;
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "poll error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "poll error (%s)\n",
+ HYDU_String_error(errno));
break;
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-16 19:13:17 UTC (rev 4091)
@@ -100,6 +100,7 @@
HYD_Status HYDU_String_alloc_and_join(char **strlist, char **strjoin);
HYD_Status HYDU_String_break(char *str, char **str1, char **str2);
HYD_Status HYDU_String_int_to_str(int x, char **str);
+char *HYDU_String_error(int error);
/* Signal utilities */
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/callback.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/callback.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/callback.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -20,13 +20,13 @@
/* Write output to fd 1 */
status = HYDU_Sock_stdout_cb(fd, events, 1, &closed);
- HYDU_ERR_SETANDJUMP2(status, status, "stdout callback error on fd %d (errno: %d)\n",
- fd, errno);
+ HYDU_ERR_SETANDJUMP2(status, status, "stdout callback error on fd %d: %s\n",
+ fd, HYDU_String_error(errno));
if (closed) {
status = HYD_CSI_Close_fd(fd);
- HYDU_ERR_SETANDJUMP2(status, status, "socket close error on fd %d (errno: %d)\n",
- fd, errno);
+ HYDU_ERR_SETANDJUMP2(status, status, "socket close error on fd %d: %s\n",
goto fn_exit;
@@ -48,13 +48,13 @@
/* Write output to fd 2 */
status = HYDU_Sock_stdout_cb(fd, events, 2, &closed);
- HYDU_ERR_SETANDJUMP2(status, status, "stdout callback error on %d (errno: %d)\n",
- fd, errno)
+ HYDU_ERR_SETANDJUMP2(status, status, "stdout callback error on %d (%s)\n",
if (closed) {
- fd, errno);
+ HYDU_ERR_SETANDJUMP2(status, status, "socket close error on fd %d (%s)\n",
goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/pm/central/proxy_cb.c
--- mpich2/trunk/src/pm/hydra/pm/central/proxy_cb.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/pm/central/proxy_cb.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -34,8 +34,8 @@
else { /* We got a command from mpiexec */
count = read(fd, &cmd, HYD_TMPBUF_SIZE);
if (count < 0) {
- HYDU_ERR_SETANDJUMP2(status, HYD_SOCK_ERROR, "read error on %d (errno: %d)\n",
- fd, errno);
+ HYDU_ERR_SETANDJUMP2(status, HYD_SOCK_ERROR, "read error on %d (%s)\n",
else if (count == 0) {
/* The connection has closed */
Modified: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -14,13 +14,16 @@
HYDU_FUNC_ENTER();
if (in && (pipe(inpipe) < 0))
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "pipe error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "pipe error (%s)\n",
if (out && (pipe(outpipe) < 0))
if (err && (pipe(errpipe) < 0))
/* Fork off the process */
tpid = fork();
@@ -28,27 +31,24 @@
close(outpipe[0]);
close(1);
if (dup2(outpipe[1], 1) < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "dup2 error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "dup2 error (%s)\n",
close(errpipe[0]);
close(2);
if (dup2(errpipe[1], 2) < 0)
close(inpipe[1]);
close(0);
if (in && (dup2(inpipe[0], 0) < 0))
if (execvp(client_arg[0], client_arg) < 0) {
- if (errno == ENOENT) {
- HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR,
- "execvp error: file %s not found\n", client_arg[0]);
- else {
- "execvp error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR, "execvp error (%s)\n",
else { /* Parent process */
Modified: mpich2/trunk/src/pm/hydra/utils/sock/sock.c
--- mpich2/trunk/src/pm/hydra/utils/sock/sock.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/utils/sock/sock.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -45,8 +45,8 @@
*listen_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
if (*listen_fd < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "cannot open socket (errno: %d)\n",
- errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "cannot open socket (%s)\n",
if (setsockopt(*listen_fd, IPPROTO_TCP, TCP_NODELAY, &one, sizeof(int)) < 0)
HYDU_ERR_SETANDJUMP(status, HYD_SOCK_ERROR, "cannot set TCP_NODELAY\n");
@@ -70,7 +70,8 @@
/* If the address is in use, we should try the next
* port. Otherwise, it's an error. */
if (errno != EADDRINUSE)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "bind error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "bind error (%s)\n",
else /* We got a port */
break;
@@ -81,7 +82,8 @@
HYDU_ERR_SETANDJUMP(status, HYD_SOCK_ERROR, "no port to bind\n");
if (listen(*listen_fd, -1) < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "listen error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "listen error (%s)\n",
/* We asked for any port, so we need to find out which port we
* actually got. */
@@ -89,8 +91,8 @@
socklen_t sinlen = sizeof(sa);
if (getsockname(*listen_fd, (struct sockaddr *) &sa, &sinlen) < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "getsockname error (errno: %d)\n",
- errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "getsockname error (%s)\n",
*port = ntohs(sa.sin_port);
@@ -119,20 +121,20 @@
ht = gethostbyname(host);
if (ht == NULL)
HYDU_ERR_SETANDJUMP1(status, HYD_INVALID_PARAM,
- "unable to get host address (errno: %d)\n", errno);
+ "unable to get host address (%s)\n", HYDU_String_error(errno));
memcpy(&sa.sin_addr, ht->h_addr_list[0], ht->h_length);
/* Create a socket and set the required options */
*fd = socket(AF_INET, SOCK_STREAM, 0);
if (*fd < 0)
- errno);
/* Not being able to connect is not an error in all cases. So we
* return an error, but only print a warning message. The upper
* layer can decide what to do with the return status. */
if (connect(*fd, (struct sockaddr *) &sa, sizeof(sa)) < 0) {
- HYDU_Warn_printf("connect error (errno: %d)\n", errno);
+ HYDU_Warn_printf("connect error (%s)\n", HYDU_String_error(errno));
status = HYD_SOCK_ERROR;
goto fn_fail;
@@ -154,7 +156,8 @@
*fd = accept(listen_fd, 0, 0);
if (*fd < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "accept error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "accept error (%s)\n",
fn_exit:
HYDU_FUNC_EXIT();
@@ -186,7 +189,8 @@
else if (n < 0) {
if (errno == EINTR)
continue;
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read error (%s)\n",
*linelen += n;
@@ -229,7 +233,8 @@
} while (*count < 0 && errno == EINTR);
if (*count < 0)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read errno (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read errno (%s)\n",
fn_exit:
HYDU_FUNC_EXIT();
@@ -255,7 +260,8 @@
} while (n < 0 && errno == EINTR);
if (n < maxsize)
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "write error (errno: %d)\n", errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "write error (%s)\n",
fn_exit:
HYDU_FUNC_EXIT();
@@ -278,7 +284,8 @@
if (n < maxsize)
fn_exit:
HYDU_FUNC_EXIT();
@@ -345,8 +352,8 @@
count = read(fd, buf, HYD_TMPBUF_SIZE);
if (count < 0) {
- fd, errno);
@@ -358,8 +365,8 @@
while (written != count) {
ret = write(stdout_fd, buf + written, count - written);
if (ret < 0 && errno != EAGAIN)
- HYDU_ERR_SETANDJUMP2(status, HYD_SOCK_ERROR, "write errnor on %d (errno: %d)\n",
- stdout_fd, errno);
+ HYDU_ERR_SETANDJUMP2(status, HYD_SOCK_ERROR, "write error on %d (%s)\n",
+ stdout_fd, HYDU_String_error(errno));
if (ret > 0)
written += ret;
@@ -391,8 +398,8 @@
if (*buf_count) {
count = write(fd, buf + *buf_offset, *buf_count);
if (count < 0)
- "write error on %d (errno: %d)\n", fd, errno)
*buf_offset += count;
*buf_count -= count;
break;
@@ -407,8 +414,8 @@
break;
- HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read error on 0 (errno: %d)\n",
- errno);
+ HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "read error on 0 (%s)\n",
Modified: mpich2/trunk/src/pm/hydra/utils/string/string.c
--- mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-16 18:20:16 UTC (rev 4090)
+++ mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-16 19:13:17 UTC (rev 4091)
@@ -95,3 +95,17 @@
fn_fail:
goto fn_exit;
+ char *str;
+#if defined HAVE_STRERROR
+ str = strerror(error);
+#else
+ str = MPIU_Strdup("errno: %d", error);
+#endif /* HAVE_STRERROR */
+ return str;
More information about the mpich2-commits
