[mpich2-commits] r4056 - in mpich2/trunk/src/binding: cxx f77 f90
gropp at mcs.anl.gov
Fri Mar 13 10:32:32 CDT 2009
Author: gropp
Date: 2009-03-13 10:32:31 -0500 (Fri, 13 Mar 2009)
New Revision: 4056
Modified:
mpich2/trunk/src/binding/cxx/buildiface
mpich2/trunk/src/binding/f77/buildiface
mpich2/trunk/src/binding/f90/binding.sub
Log:
Enhanced the interface builders to handle multiple comments in a function prototype line
Modified: mpich2/trunk/src/binding/cxx/buildiface
--- mpich2/trunk/src/binding/cxx/buildiface 2009-03-13 15:30:30 UTC (rev 4055)
+++ mpich2/trunk/src/binding/cxx/buildiface 2009-03-13 15:32:31 UTC (rev 4056)
@@ -1380,7 +1380,7 @@
// MPICH_DONT_INCLUDE_STDIO_H is another escape hatch for us, just like
// MPICH_IGNORE_CXX_SEEK. If we encounter a wacky environment or user in the
-// wild that doesn't want our workaround and/or the stdio.h header, then we can
+// wild that does not want our workaround and/or the stdio.h header, then we can
// offer them a way out.
#ifndef MPICH_DONT_INCLUDE_STDIO_H
// ensure that we have SEEK_* defined
@@ -3171,6 +3171,14 @@
#$mpi_routine{name} = args;
while (<FD>) {
if (/\/\*\s*End Prototypes/ ) { last; }
+ $origline = $_;
+ while (/(.*)\/\*(.*?)\*\/(.*)/) {
+ my $removed = $2;
+ $_ = $1.$3;
+ if ($2 =~ /\/\*/) {
+ print STDERR "Error in processing comment within interface file $filename in line $origline";
if (/^int\s+MPI_([A-Z][a-z0-9_]*)\s*\((.*)/) {
$routine_name = $1;
$args = $2;
@@ -3934,7 +3942,15 @@
print $OUTFD "const $name v$count$array";
else {
- print $OUTFD "const $lparm v$count";
+ # Only add if a const is not already present
+ if ($lparm =~ /^\s*const/) {
+ # No need to add const
+ print $OUTFD "$lparm v$count";
+ else {
+ print $OUTFD "const $lparm v$count";
+ print "const added to $lparm, argument $count for $routine(class $class)\n" if $debug;
# We have to explicitly remove the cast
Modified: mpich2/trunk/src/binding/f77/buildiface
--- mpich2/trunk/src/binding/f77/buildiface 2009-03-13 15:30:30 UTC (rev 4055)
+++ mpich2/trunk/src/binding/f77/buildiface 2009-03-13 15:32:31 UTC (rev 4056)
@@ -3029,6 +3029,8 @@
$filename = "statusf2c.c";
open ($OUTFD, ">$filename.new" ) || die "Cannot open $filename.new\n";
$files[$#files+1] = $filename;
+ # Status_f2c and c2f will need to have const added before the input
+ # argument for MPI 2.2
print $OUTFD "
/* -*- Mode: C; c-basic-offset:4 ; -*- */
@@ -3228,8 +3230,15 @@
&SkipCPPIfdef( FD );
- # Remove any comments
- s/\/\*.*\*\///g;
+ # Remove any comments; check for problems
+ $origline = $_;
+ my $removed = $2;
+ $_ = $1.$3;
+ print STDERR "Error in processing comment within interface file $prototype_file in line $origline";
if (/^int\s+$routine_prefix($routine_pattern)\s*\((.*)/) {
$routine_name = $1;
@@ -3367,8 +3376,15 @@
# First, find the values that we need
while (<MPIFD>) {
$linecount++;
- s/\/\*.*\*\///g;
+ $origline = $_;
+ my $removed = $2;
+ $_ = $1.$3;
# We should also skip #ifndef xxx, for some xxx.
if (/^#\s*ifndef\s+(\w*)/) {
Modified: mpich2/trunk/src/binding/f90/binding.sub
--- mpich2/trunk/src/binding/f90/binding.sub 2009-03-13 15:30:30 UTC (rev 4055)
+++ mpich2/trunk/src/binding/f90/binding.sub 2009-03-13 15:32:31 UTC (rev 4056)
@@ -28,7 +28,14 @@
# Read each one
while (<FD>) {
- s/\/\*.*\*\///g;
+ $origline = $_;
+ my $removed = $2;
+ $_ = $1.$3;
print $_ if $debug;
if (/\/\*\s*End Prototypes/) { last; }
More information about the mpich2-commits
