[mpich2-commits] r4055 - in mpich2/trunk/src/mpi/romio: . adio/ad_lustre adio/common adio/include
robl at mcs.anl.gov
robl at mcs.anl.gov
Fri Mar 13 10:30:30 CDT 2009
Author: robl
Date: 2009-03-13 10:30:30 -0500 (Fri, 13 Mar 2009)
New Revision: 4055
Added:
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_aggregate.c
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrcoll.c
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c
Modified:
mpich2/trunk/src/mpi/romio/adio/ad_lustre/Makefile.in
mpich2/trunk/src/mpi/romio/adio/ad_lustre/README
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.c
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.h
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_hints.c
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_open.c
mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_rwcontig.c
mpich2/trunk/src/mpi/romio/adio/common/ad_write_coll.c
mpich2/trunk/src/mpi/romio/adio/include/adioi.h
mpich2/trunk/src/mpi/romio/configure.in
Log:
The improved Lustre driver, contributed by Sun with help from Weikuan Yu.
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/Makefile.in
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/Makefile.in 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/Makefile.in 2009-03-13 15:30:30 UTC (rev 4055)
@@ -16,8 +16,10 @@
@VPATH@
AD_LUSTRE_OBJECTS = ad_lustre.o ad_lustre_open.o \
- ad_lustre_rwcontig.o ad_lustre_hints.o
+ ad_lustre_rwcontig.o ad_lustre_wrcoll.o ad_lustre_wrstr.o \
+ ad_lustre_hints.o ad_lustre_aggregate.o
default: $(LIBNAME)
@if [ "@ENABLE_SHLIB@" != "none" ] ; then \
$(MAKE) $(SHLIBNAME).la ;\
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/README
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/README 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/README 2009-03-13 15:30:30 UTC (rev 4055)
@@ -5,6 +5,23 @@
o To post the code for ParColl (Partitioned collective IO)
+V05:
+Improved data redistribution
+ o Improve I/O pattern identification. Besides checking interleaving,
+ if request I/O size is small, collective I/O will be performed.
+ The hint bigsize can be used to define the req size value.
+ o Provide hint CO for load balancing to control the number of
+ IO clients for each OST
+ o Produce stripe-contiguous I/O pattern that Lustre prefers
+ o Reduce the collective overhead by hints contig_data and
+ samesize to remove unnecessary MPI_Alltoall()
+ o Control read-modify-write in data sieving in collective IO
+ by hint ds_in_coll.
+ o Reduce extent lock conflicts by make each OST accessed by one or
+ more constant clients.
V04:
o Direct IO and Lockless IO support
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.c 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1,9 +1,11 @@
/* -*- Mode: C; c-basic-offset:4 ; -*- */
- * Copyright (C) 2001 University of Chicago.
+ * Copyright (C) 2001 University of Chicago.
* See COPYRIGHT notice in top-level directory.
* Copyright (C) 2007 Oak Ridge National Laboratory
+ * Copyright (C) 2008 Sun Microsystems, Lustre group
#include "ad_lustre.h"
@@ -13,12 +15,12 @@
ADIOI_LUSTRE_ReadContig, /* ReadContig */
ADIOI_LUSTRE_WriteContig, /* WriteContig */
ADIOI_GEN_ReadStridedColl, /* ReadStridedColl */
- ADIOI_GEN_WriteStridedColl, /* WriteStridedColl */
+ ADIOI_LUSTRE_WriteStridedColl, /* WriteStridedColl */
ADIOI_GEN_SeekIndividual, /* SeekIndividual */
ADIOI_GEN_Fcntl, /* Fcntl */
ADIOI_LUSTRE_SetInfo, /* SetInfo */
ADIOI_GEN_ReadStrided, /* ReadStrided */
- ADIOI_GEN_WriteStrided, /* WriteStrided */
+ ADIOI_LUSTRE_WriteStrided, /* WriteStrided */
ADIOI_GEN_Close, /* Close */
#if defined(ROMIO_HAVE_WORKING_AIO) && !defined(CRAY_XT_LUSTRE)
ADIOI_GEN_IreadContig, /* IreadContig */
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.h
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.h 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre.h 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1,9 +1,11 @@
- * Copyright (C) 1997 University of Chicago.
+ * Copyright (C) 1997 University of Chicago.
#ifndef AD_UNIX_INCLUDE
@@ -24,7 +26,7 @@
/*#include <fcntl.h>*/
#include <sys/ioctl.h>
-#include "lustre/lustre_user.h"
+#include <lustre/lustre_user.h>
#include "adio.h"
/*#include "adioi.h"*/
@@ -41,24 +43,31 @@
void ADIOI_LUSTRE_Open(ADIO_File fd, int *error_code);
void ADIOI_LUSTRE_Close(ADIO_File fd, int *error_code);
-void ADIOI_LUSTRE_ReadContig(ADIO_File fd, void *buf, int count,
- MPI_Datatype datatype, int file_ptr_type,
- ADIO_Offset offset, ADIO_Status *status, int
- *error_code);
-void ADIOI_LUSTRE_WriteContig(ADIO_File fd, void *buf, int count,
- *error_code);
+void ADIOI_LUSTRE_ReadContig(ADIO_File fd, void *buf, int count,
+ MPI_Datatype datatype, int file_ptr_type,
+ ADIO_Offset offset, ADIO_Status *status,
+ int *error_code);
+void ADIOI_LUSTRE_WriteContig(ADIO_File fd, void *buf, int count,
+ int *error_code);
+void ADIOI_LUSTRE_WriteStrided(ADIO_File fd, void *buf, int count,
+ int *error_code);
void ADIOI_LUSTRE_WriteStridedColl(ADIO_File fd, void *buf, int count,
- *error_code);
+ int *error_code);
void ADIOI_LUSTRE_ReadStridedColl(ADIO_File fd, void *buf, int count,
- *error_code);
+ int *error_code);
+void ADIOI_LUSTRE_ReadStrided(ADIO_File fd, void *buf, int count,
+ int *error_code);
void ADIOI_LUSTRE_Fcntl(ADIO_File fd, int flag, ADIO_Fcntl_t *fcntl_struct,
int *error_code);
void ADIOI_LUSTRE_SetInfo(ADIO_File fd, MPI_Info users_info, int *error_code);
#endif /* End of AD_UNIX_INCLUDE */
Added: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_aggregate.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_aggregate.c (rev 0)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_aggregate.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -0,0 +1,511 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * See COPYRIGHT notice in top-level directory.
+ * Copyright (C) 2007 Oak Ridge National Laboratory
+#include "ad_lustre.h"
+#include "adio_extern.h"
+#undef AGG_DEBUG
+void ADIOI_LUSTRE_Get_striping_info(ADIO_File fd, int ** striping_info_ptr,
+ int mode)
+ int *striping_info = NULL;
+ /* get striping information:
+ * striping_info[0]: stripe_size
+ * striping_info[1]: stripe_count
+ * striping_info[2]: avail_cb_nodes
+ int stripe_size, stripe_count, CO = 1, CO_max = 1, CO_nodes, lflag;
+ int avail_cb_nodes, divisor, nprocs_for_coll = fd->hints->cb_nodes;
+ char *value = (char *) ADIOI_Malloc((MPI_MAX_INFO_VAL + 1) * sizeof(char));
+ /* Get hints value */
+ /* stripe size */
+ stripe_size = fd->hints->striping_unit;
+ /* stripe count */
+ /* stripe_size and stripe_count have been validated in ADIOI_LUSTRE_Open() */
+ stripe_count = fd->hints->striping_factor;
+ /* Calculate the available number of I/O clients, that is
+ * avail_cb_nodes=min(cb_nodes, stripe_count*CO), where
+ * CO=1 by default
+ if (!mode) {
+ /* for collective read,
+ * if "CO" clients access the same OST simultaneously,
+ * the OST disk seek time would be much. So, to avoid this,
+ * it might be better if 1 client only accesses 1 OST.
+ * So, we set CO = 1 to meet the above requirement.
+ CO = 1;
+ /*XXX: maybe there are other better way for collective read */
+ } else {
+ /* CO_max: the largest number of IO clients for each ost group */
+ CO_max = (nprocs_for_coll - 1)/ stripe_count + 1;
+ /* CO also has been validated in ADIOI_LUSTRE_Open(), >0 */
+ CO = fd->hints->fs_hints.lustre.CO;
+ CO = ADIOI_MIN(CO_max, CO);
+ /* Calculate how many IO clients we need */
+ /* To avoid extent lock conflicts,
+ * avail_cb_nodes should divide (stripe_count*CO) exactly,
+ * so that each OST is accessed by only one or more constant clients. */
+ avail_cb_nodes = ADIOI_MIN(nprocs_for_coll, stripe_count * CO);
+ if (avail_cb_nodes == nprocs_for_coll) {
+ CO_nodes = stripe_count * CO;
+ do {
+ /* find the divisor of CO_nodes */
+ divisor = 1;
+ do {
+ divisor ++;
+ } while (CO_nodes % divisor);
+ CO_nodes = CO_nodes / divisor;
+ /* if stripe_count*CO is a prime number, change nothing */
+ if ((CO_nodes <= avail_cb_nodes) && (CO_nodes != 1)) {
+ avail_cb_nodes = CO_nodes;
+ break;
+ } while (CO_nodes != 1);
+ *striping_info_ptr = (int *) ADIOI_Malloc(3 * sizeof(int));
+ striping_info = *striping_info_ptr;
+ striping_info[0] = stripe_size;
+ striping_info[1] = stripe_count;
+ striping_info[2] = avail_cb_nodes;
+ ADIOI_Free(value);
+int ADIOI_LUSTRE_Calc_aggregator(ADIO_File fd, ADIO_Offset off,
+ ADIO_Offset *len, int *striping_info)
+ int rank_index, rank;
+ ADIO_Offset avail_bytes;
+ int stripe_size = striping_info[0];
+ int avail_cb_nodes = striping_info[2];
+ /* Produce the stripe-contiguous pattern for Lustre */
+ rank_index = (int)((off / stripe_size) % avail_cb_nodes);
+ /* we index into fd_end with rank_index, and fd_end was allocated to be no
+ * bigger than fd->hins->cb_nodes. If we ever violate that, we're
+ * overrunning arrays. Obviously, we should never ever hit this abort
+ if (rank_index >= fd->hints->cb_nodes)
+ MPI_Abort(MPI_COMM_WORLD, 1);
+ avail_bytes = (off / (ADIO_Offset)stripe_size + 1) *
+ (ADIO_Offset)stripe_size - off;
+ if (avail_bytes < *len) {
+ /* this proc only has part of the requested contig. region */
+ *len = avail_bytes;
+ /* map our index to a rank */
+ /* NOTE: FOR NOW WE DON'T HAVE A MAPPING...JUST DO 0..NPROCS_FOR_COLL */
+ rank = fd->hints->ranklist[rank_index];
+ return rank;
+/* ADIOI_LUSTRE_Calc_my_req() - calculate what portions of the access requests
+ * of this process are located in the file domains of various processes
+ * (including this one)
+void ADIOI_LUSTRE_Calc_my_req(ADIO_File fd, ADIO_Offset *offset_list,
+ int *len_list, int contig_access_count,
+ int *striping_info, int nprocs,
+ int *count_my_req_procs_ptr,
+ int **count_my_req_per_proc_ptr,
+ ADIOI_Access ** my_req_ptr,
+ int **buf_idx_ptr)
+ /* Nothing different from ADIOI_Calc_my_req(), except calling
+ * ADIOI_Lustre_Calc_aggregator() instead of the old one */
+ int *count_my_req_per_proc, count_my_req_procs, *buf_idx;
+ int i, l, proc;
+ ADIO_Offset avail_len, rem_len, curr_idx, off;
+ ADIOI_Access *my_req;
+ *count_my_req_per_proc_ptr = (int *) ADIOI_Calloc(nprocs, sizeof(int));
+ count_my_req_per_proc = *count_my_req_per_proc_ptr;
+ /* count_my_req_per_proc[i] gives the no. of contig. requests of this
+ * process in process i's file domain. calloc initializes to zero.
+ * I'm allocating memory of size nprocs, so that I can do an
+ * MPI_Alltoall later on.
+ buf_idx = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* buf_idx is relevant only if buftype_is_contig.
+ * buf_idx[i] gives the index into user_buf where data received
+ * from proc. i should be placed. This allows receives to be done
+ * without extra buffer. This can't be done if buftype is not contig.
+ /* initialize buf_idx to -1 */
+ for (i = 0; i < nprocs; i++)
+ buf_idx[i] = -1;
+ /* one pass just to calculate how much space to allocate for my_req;
+ * contig_access_count was calculated way back in ADIOI_Calc_my_off_len()
+ for (i = 0; i < contig_access_count; i++) {
+ /* short circuit offset/len processing if len == 0
+ * (zero-byte read/write
+ if (len_list[i] == 0)
+ continue;
+ off = offset_list[i];
+ avail_len = len_list[i];
+ /* note: we set avail_len to be the total size of the access.
+ * then ADIOI_LUSTRE_Calc_aggregator() will modify the value to return
+ * the amount that was available.
+ proc = ADIOI_LUSTRE_Calc_aggregator(fd, off, &avail_len, striping_info);
+ count_my_req_per_proc[proc]++;
+ /* figure out how many data is remaining in the access
+ * we'll take care of this data (if there is any)
+ * in the while loop below.
+ rem_len = len_list[i] - avail_len;
+ while (rem_len != 0) {
+ off += avail_len; /* point to first remaining byte */
+ avail_len = rem_len; /* save remaining size, pass to calc */
+ rem_len -= avail_len; /* reduce remaining length by amount from fd */
+ /* now allocate space for my_req, offset, and len */
+ *my_req_ptr = (ADIOI_Access *) ADIOI_Malloc(nprocs * sizeof(ADIOI_Access));
+ my_req = *my_req_ptr;
+ count_my_req_procs = 0;
+ for (i = 0; i < nprocs; i++) {
+ if (count_my_req_per_proc[i]) {
+ my_req[i].offsets = (ADIO_Offset *)
+ ADIOI_Malloc(count_my_req_per_proc[i] *
+ sizeof(ADIO_Offset));
+ my_req[i].lens = (int *) ADIOI_Malloc(count_my_req_per_proc[i] *
+ sizeof(int));
+ count_my_req_procs++;
+ my_req[i].count = 0; /* will be incremented where needed later */
+ /* now fill in my_req */
+ curr_idx = 0;
+ * (zero-byte read/write */
+ continue;
+ /* for each separate contiguous access from this process */
+ if (buf_idx[proc] == -1)
+ buf_idx[proc] = (int) curr_idx;
+ l = my_req[proc].count;
+ curr_idx += (int) avail_len; /* NOTE: Why is curr_idx an int? Fix? */
+ /* store the proc, offset, and len information in an array
+ * of structures, my_req. Each structure contains the
+ * offsets and lengths located in that process's FD,
+ * and the associated count.
+ my_req[proc].offsets[l] = off;
+ my_req[proc].lens[l] = (int) avail_len;
+ my_req[proc].count++;
+ off += avail_len;
+ striping_info);
+ curr_idx += avail_len;
+#ifdef AGG_DEBUG
+ if (count_my_req_per_proc[i] > 0) {
+ FPRINTF(stdout, "data needed from %d (count = %d):\n",
+ i, my_req[i].count);
+ for (l = 0; l < my_req[i].count; l++) {
+ FPRINTF(stdout, " off[%d] = %lld, len[%d] = %d\n",
+ l, my_req[i].offsets[l], l, my_req[i].lens[l]);
+#if 0
+ FPRINTF(stdout, "buf_idx[%d] = 0x%x\n", i, buf_idx[i]);
+#endif
+#endif
+ *count_my_req_procs_ptr = count_my_req_procs;
+ *buf_idx_ptr = buf_idx;
+int ADIOI_LUSTRE_Docollect(ADIO_File fd, int contig_access_count,
+ int *len_list, int nprocs)
+ /* If the processes are non-interleaved, we will check the req_size.
+ * if (avg_req_size > big_req_size) {
+ * docollect = 0;
+ int i, docollect = 1, lflag, big_req_size = 0;
+ ADIO_Offset req_size = 0, total_req_size;
+ int avg_req_size, total_access_count;
+ /* calculate total_req_size and total_access_count */
+ req_size += len_list[i];
+ MPI_Allreduce(&req_size, &total_req_size, 1, MPI_LONG_LONG_INT, MPI_SUM,
+ fd->comm);
+ MPI_Allreduce(&contig_access_count, &total_access_count, 1, MPI_INT, MPI_SUM,
+ fd->comm);
+ /* estimate average req_size */
+ avg_req_size = (int)(total_req_size / total_access_count);
+ /* get hint of big_req_size */
+ big_req_size = fd->hints->fs_hints.lustre.bigsize;
+ /* Don't perform collective I/O if there are big requests */
+ if ((big_req_size > 0) && (avg_req_size > big_req_size))
+ docollect = 0;
+ return docollect;
+void ADIOI_LUSTRE_Calc_others_req(ADIO_File fd, int count_my_req_procs,
+ ADIOI_Access * my_req,
+ int nprocs, int myrank,
+ ADIO_Offset start_offset,
+ ADIO_Offset end_offset,
+ int *count_others_req_procs_ptr,
+ ADIOI_Access ** others_req_ptr)
+ /* what requests of other processes will be accessed by this process */
+ /* count_others_req_procs = number of processes whose requests (including
+ * this process itself) will be accessed by this process
+ * count_others_req_per_proc[i] indicates how many separate contiguous
+ * requests of proc. i lie will be accessed by this process.
+ int *count_others_req_per_proc, count_others_req_procs, proc;
+ int i, j, samesize = 0, contiguous = 0;
+ MPI_Request *send_requests, *recv_requests;
+ MPI_Status *statuses;
+ ADIOI_Access *others_req;
+ ADIO_Offset min_st_offset, off, req_len, avail_len, rem_len, *all_lens;
+ /* There are two hints, which could reduce some MPI communication overhead,
+ * if the users knows the I/O pattern and set them correctly. */
+ /* They are
+ * contig_data: if the data are contiguous,
+ * we don't need to do MPI_Alltoall().
+ * samesize: if the data req size is same,
+ * we can calculate the offset directly
+ /* hint of contiguous data */
+ contiguous = fd->hints->fs_hints.lustre.contig_data;
+ /* hint of same io size */
+ samesize = fd->hints->fs_hints.lustre.samesize;
+ *others_req_ptr = (ADIOI_Access *) ADIOI_Malloc(nprocs *
+ sizeof(ADIOI_Access));
+ others_req = *others_req_ptr;
+ /* if the data are contiguous, we can calulate the offset and length
+ * of the other requests simply, instead of MPI_Alltoall() */
+ if (contiguous) {
+ others_req[i].count = 0;
+ req_len = end_offset - start_offset + 1;
+ all_lens = (ADIO_Offset *) ADIOI_Malloc(nprocs * sizeof(ADIO_Offset));
+ /* same req size ? */
+ if (samesize == 0) {
+ /* calculate the min_st_offset */
+ MPI_Allreduce(&start_offset, &min_st_offset, 1, MPI_LONG_LONG,
+ MPI_MIN, fd->comm);
+ /* exchange request length */
+ MPI_Allgather(&req_len, 1, ADIO_OFFSET, all_lens, 1, ADIO_OFFSET,
+ fd->comm);
+ } else { /* same request size */
+ /* calculate the 1st request's offset */
+ min_st_offset = start_offset - myrank * req_len;
+ /* assign request length to all_lens[] */
+ for (i = 0; i < nprocs; i ++)
+ all_lens[i] = req_len;
+ if (myrank < avail_cb_nodes) {
+ /* This is a IO client and it will receive data from others */
+ off = min_st_offset;
+ /* calcaulte other_req[i].count */
+ avail_len = all_lens[i];
+ rem_len = avail_len;
+ while (rem_len > 0) {
+ striping_info);
+ if (proc == myrank) {
+ others_req[i].count ++;
+ off += avail_len;
+ /* calculate offset and len for each request */
+ if (others_req[i].count) {
+ others_req[i].offsets = (ADIO_Offset *)
+ ADIOI_Malloc(others_req[i].count *
+ others_req[i].lens = (int *)
+ sizeof(int));
+ others_req[i].mem_ptrs = (MPI_Aint *)
+ sizeof(MPI_Aint));
+ j = 0;
+ striping_info);
+ others_req[i].offsets[j] = off;
+ others_req[i].lens[j] = (int)avail_len;
+ j ++;
+ off += avail_len;
+ ADIOI_Free(all_lens);
+ } else {
+ /* multiple non-contiguous requests */
+ * count_others_req_procs:
+ * number of processes whose requests will be written by
+ * this process (including this process itself)
+ * count_others_req_per_proc[i]:
+ * how many separate contiguous requests of proc[i] will be
+ * written by this process.
+ /* first find out how much to send/recv and from/to whom */
+ count_others_req_per_proc = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ MPI_Alltoall(count_my_req_per_proc, 1, MPI_INT,
+ count_others_req_per_proc, 1, MPI_INT, fd->comm);
+ count_others_req_procs = 0;
+ if (count_others_req_per_proc[i]) {
+ others_req[i].count = count_others_req_per_proc[i];
+ sizeof(int));
+ count_others_req_procs++;
+ } else
+ /* now send the calculated offsets and lengths to respective processes */
+ send_requests = (MPI_Request *) ADIOI_Malloc(2 * (count_my_req_procs + 1) *
+ sizeof(MPI_Request));
+ recv_requests = (MPI_Request *) ADIOI_Malloc(2 * (count_others_req_procs+1)*
+ /* +1 to avoid a 0-size malloc */
+ j = 0;
+ MPI_Irecv(others_req[i].offsets, others_req[i].count,
+ ADIO_OFFSET, i, i + myrank, fd->comm,
+ &recv_requests[j]);
+ j++;
+ MPI_Irecv(others_req[i].lens, others_req[i].count,
+ MPI_INT, i, i + myrank + 1, fd->comm,
+ j++;
+ j = 0;
+ if (my_req[i].count) {
+ MPI_Isend(my_req[i].offsets, my_req[i].count,
+ &send_requests[j]);
+ j++;
+ MPI_Isend(my_req[i].lens, my_req[i].count,
+ j++;
+ statuses = (MPI_Status *)
+ ADIOI_Malloc((1 + 2 * ADIOI_MAX(count_my_req_procs,
+ count_others_req_procs)) *
+ sizeof(MPI_Status));
+ MPI_Waitall(2 * count_my_req_procs, send_requests, statuses);
+ MPI_Waitall(2 * count_others_req_procs, recv_requests, statuses);
+ ADIOI_Free(send_requests);
+ ADIOI_Free(recv_requests);
+ ADIOI_Free(statuses);
+ ADIOI_Free(count_others_req_per_proc);
+ *count_others_req_procs_ptr = count_others_req_procs;
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_hints.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_hints.c 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_hints.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1,9 +1,11 @@
@@ -12,46 +14,60 @@
char *value, *value_in_fd;
- int flag, tmp_val[3], str_factor=-1, str_unit=0, start_iodev=-1;
+ int flag, stripe_val[3], str_factor = -1, str_unit=0, start_iodev=-1;
struct lov_user_md lum = { 0 };
int err, myrank, fd_sys, perm, amode, old_mask;
+ int int_val, tmp_val;
+ static char myname[] = "ADIOI_LUSTRE_SETINFO";
value = (char *) ADIOI_Malloc((MPI_MAX_INFO_VAL+1)*sizeof(char));
if ( (fd->info) == MPI_INFO_NULL) {
- /* This must be part of the open call. can set striping parameters
- if necessary. */
+ /* This must be part of the open call. can set striping parameters
+ if necessary. */
MPI_Info_create(&(fd->info));
MPI_Info_set(fd->info, "direct_read", "false");
MPI_Info_set(fd->info, "direct_write", "false");
fd->direct_read = fd->direct_write = 0;
- /* has user specified striping or server buffering parameters
+ /* initialize lustre hints */
+ MPI_Info_set(fd->info, "romio_lustre_CO", "1");
+ fd->hints->fs_hints.lustre.CO = 1;
+ MPI_Info_set(fd->info, "romio_lustre_bigsize", "0");
+ fd->hints->fs_hints.lustre.bigsize = 0;
+ MPI_Info_set(fd->info, "romio_lustre_ds_in_coll", "enable");
+ fd->hints->fs_hints.lustre.ds_in_coll = ADIOI_HINT_ENABLE;
+ MPI_Info_set(fd->info, "romio_lustre_contig_data", "0");
+ fd->hints->fs_hints.lustre.contig_data = 0;
+ MPI_Info_set(fd->info, "romio_lustre_samesize", "0");
+ fd->hints->fs_hints.lustre.samesize = 0;
+ /* has user specified striping or server buffering parameters
and do they have the same value on all processes? */
if (users_info != MPI_INFO_NULL) {
- MPI_Info_get(users_info, "striping_unit", MPI_MAX_INFO_VAL,
+ /* striping information */
+ MPI_Info_get(users_info, "striping_unit", MPI_MAX_INFO_VAL,
value, &flag);
- if (flag)
+ if (flag)
str_unit=atoi(value);
- MPI_Info_get(users_info, "striping_factor", MPI_MAX_INFO_VAL,
+ MPI_Info_get(users_info, "striping_factor", MPI_MAX_INFO_VAL,
value, &flag);
- if (flag)
+ if (flag)
str_factor=atoi(value);
- MPI_Info_get(users_info, "start_iodevice", MPI_MAX_INFO_VAL,
- value, &flag);
- if (flag)
+ MPI_Info_get(users_info, "romio_lustre_start_iodevice",
+ MPI_MAX_INFO_VAL, value, &flag);
+ if (flag)
start_iodev=atoi(value);
- MPI_Info_get(users_info, "direct_read", MPI_MAX_INFO_VAL,
- value, &flag);
+ /* direct read and write */
+ MPI_Info_get(users_info, "direct_read", MPI_MAX_INFO_VAL,
+ value, &flag);
if (flag && (!strcmp(value, "true") || !strcmp(value, "TRUE"))) {
MPI_Info_set(fd->info, "direct_read", "true");
fd->direct_read = 1;
- MPI_Info_get(users_info, "direct_write", MPI_MAX_INFO_VAL,
+ MPI_Info_get(users_info, "direct_write", MPI_MAX_INFO_VAL,
value, &flag);
MPI_Info_set(fd->info, "direct_write", "true");
@@ -59,22 +75,23 @@
+ /* set striping information with ioctl */
MPI_Comm_rank(fd->comm, &myrank);
if (myrank == 0) {
- tmp_val[0] = str_factor;
- tmp_val[1] = str_unit;
- tmp_val[2] = start_iodev;
+ stripe_val[0] = str_factor;
+ stripe_val[1] = str_unit;
+ stripe_val[2] = start_iodev;
- MPI_Bcast(tmp_val, 3, MPI_INT, 0, fd->comm);
+ MPI_Bcast(stripe_val, 3, MPI_INT, 0, fd->comm);
- if (tmp_val[0] != str_factor
- || tmp_val[1] != str_unit
- || tmp_val[2] != start_iodev) {
+ if (stripe_val[0] != str_factor
+ || stripe_val[1] != str_unit
+ || stripe_val[2] != start_iodev) {
FPRINTF(stderr, "ADIOI_LUSTRE_SetInfo: All keys"
"-striping_factor:striping_unit:start_iodevice "
"need to be identical across all processes\n");
- } else if ((str_factor > 0) || (str_unit > 0) || (start_iodev >= 0)) {
+ } else if ((str_factor > 0) || (str_unit > 0) || (start_iodev >= 0)) {
/* if user has specified striping info, process 0 tries to set it */
if (!myrank) {
if (fd->perm == ADIO_PERM_NULL) {
@@ -100,9 +117,9 @@
amode = amode | O_LOV_DELAY_CREATE | O_CREAT;
fd_sys = open(fd->filename, amode, perm);
- if (fd_sys == -1) {
- if (errno != EEXIST)
- fprintf(stderr,
+ if (fd_sys == -1) {
+ if (errno != EEXIST)
+ fprintf(stderr,
"Failure to open file %s %d %d\n",strerror(errno), amode, perm);
} else {
lum.lmm_magic = LOV_USER_MAGIC;
@@ -112,25 +129,108 @@
lum.lmm_stripe_offset = start_iodev;
err = ioctl(fd_sys, LL_IOC_LOV_SETSTRIPE, &lum);
- if (err == -1 && errno != EEXIST) {
+ if (err == -1 && errno != EEXIST) {
fprintf(stderr, "Failure to set stripe info %s \n", strerror(errno));
close(fd_sys);
} /* End of striping parameters validation */
MPI_Barrier(fd->comm);
- /* set the values for collective I/O and data sieving parameters */
- ADIOI_GEN_SetInfo(fd, users_info, error_code);
- } else {
- /* The file has been opened previously and fd->fd_sys is a valid
- file descriptor. cannot set striping parameters now. */
+ /* get other hint */
+ if (users_info != MPI_INFO_NULL) {
+ /* CO: IO Clients/OST,
+ * to keep the load balancing between clients and OSTs */
+ MPI_Info_get(users_info, "romio_lustre_CO", MPI_MAX_INFO_VAL, value,
+ &flag);
+ if (flag && (int_val = atoi(value)) > 0) {
+ tmp_val = int_val;
+ MPI_Bcast(&tmp_val, 1, MPI_INT, 0, fd->comm);
+ if (tmp_val != int_val) {
+ MPIO_ERR_CREATE_CODE_INFO_NOT_SAME(myname,
+ "romio_lustre_CO",
+ error_code);
+ return;
+ MPI_Info_set(fd->info, "romio_lustre_CO", value);
+ fd->hints->fs_hints.lustre.CO = atoi(value);
+ /* big_req_size:
+ * if the req size is bigger than this,
+ * collective IO may not be performed.
+ MPI_Info_get(users_info, "romio_lustre_bigsize", MPI_MAX_INFO_VAL, value,
+ &flag);
+ "romio_lustre_bigsize",
+ error_code);
+ return;
+ MPI_Info_set(fd->info, "romio_lustre_bigsize", value);
+ fd->hints->fs_hints.lustre.bigsize = atoi(value);
+ /* ds_in_coll: disable data sieving in collective IO */
+ MPI_Info_get(users_info, "romio_lustre_ds_in_coll", MPI_MAX_INFO_VAL,
+ value, &flag);
+ if (flag && (!strcmp(value, "disable") ||
+ !strcmp(value, "DISABLE"))) {
+ tmp_val = int_val = 2;
+ MPI_Bcast(&tmp_val, 2, MPI_INT, 0, fd->comm);
+ "romio_lustre_ds_in_coll",
+ error_code);
+ return;
+ MPI_Info_set(fd->info, "romio_lustre_ds_in_coll", "disable");
+ fd->hints->fs_hints.lustre.ds_in_coll = ADIOI_HINT_DISABLE;
+ /* contig_data: whether the request data are contiguous */
+ MPI_Info_get(users_info, "romio_lustre_contig_data", MPI_MAX_INFO_VAL,
+ value, &flag);
+ if (flag && (!strcmp(value, "yes") ||
+ !strcmp(value, "YES"))) {
+ tmp_val = int_val = 1;
+ "romio_lustre_contig_data",
+ error_code);
+ return;
+ MPI_Info_set(fd->info, "romio_lustre_contig_data", "yes");
+ fd->hints->fs_hints.lustre.contig_data = 1;
+ /* same_io_size: whether the req size is same */
+ MPI_Info_get(users_info, "romio_lustre_samesize", MPI_MAX_INFO_VAL,
+ value, &flag);
+ "romio_lustre_samesize",
+ error_code);
+ return;
+ MPI_Info_set(fd->info, "romio_lustre_samesize", "yes");
+ fd->hints->fs_hints.lustre.samesize = 1;
+ /* set the values for collective I/O and data sieving parameters */
+ ADIOI_GEN_SetInfo(fd, users_info, error_code);
if (ADIOI_Direct_read) fd->direct_read = 1;
if (ADIOI_Direct_write) fd->direct_write = 1;
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_open.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_open.c 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_open.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1,9 +1,11 @@
@@ -51,14 +53,17 @@
err = ioctl(fd->fd_sys, LL_IOC_LOV_GETSTRIPE, (void *) &lum);
if (!err) {
+ fd->hints->striping_unit = lum.lmm_stripe_size;
sprintf(value, "%d", lum.lmm_stripe_size);
MPI_Info_set(fd->info, "striping_unit", value);
+ fd->hints->striping_factor = lum.lmm_stripe_count;
sprintf(value, "%d", lum.lmm_stripe_count);
MPI_Info_set(fd->info, "striping_factor", value);
+ fd->hints->fs_hints.lustre.start_iodevice = lum.lmm_stripe_offset;
sprintf(value, "%d", lum.lmm_stripe_offset);
- MPI_Info_set(fd->info, "start_iodevice", value);
+ MPI_Info_set(fd->info, "romio_lustre_start_iodevice", value);
ADIOI_Free(value);
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_rwcontig.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_rwcontig.c 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_rwcontig.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1,9 +1,11 @@
#define _XOPEN_SOURCE 600
@@ -136,10 +138,23 @@
if (err == -1) goto ioerr;
- if (io_mode)
+ if (io_mode) {
+#ifdef ADIOI_MPE_LOGGING
+ MPE_Log_event(ADIOI_MPE_write_a, 0, NULL);
+#endif
err = write(fd->fd_sys, buf, len);
- else
+ MPE_Log_event(ADIOI_MPE_write_b, 0, NULL);
+#endif
+ } else {
+ MPE_Log_event(ADIOI_MPE_read_a, 0, NULL);
+#endif
err = read(fd->fd_sys, buf, len);
+ MPE_Log_event(ADIOI_MPE_read_b, 0, NULL);
+#endif
} else {
err = ADIOI_LUSTRE_Directio(fd, buf, len, offset, io_mode);
Added: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrcoll.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrcoll.c (rev 0)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrcoll.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -0,0 +1,936 @@
+/* prototypes of functions used for collective writes only. */
+static void ADIOI_LUSTRE_Exch_and_write(ADIO_File fd, void *buf,
+ MPI_Datatype datatype, int nprocs,
+ int myrank,
+ ADIOI_Access *others_req,
+ ADIOI_Access *my_req,
+ ADIO_Offset *offset_list,
+ int *len_list,
+ int contig_access_count,
+ int * striping_info,
+ int *buf_idx, int *error_code);
+static void ADIOI_LUSTRE_Fill_send_buffer(ADIO_File fd, void *buf,
+ ADIOI_Flatlist_node * flat_buf,
+ char **send_buf,
+ ADIO_Offset * offset_list,
+ int *len_list, int *send_size,
+ MPI_Request * requests,
+ int *sent_to_proc, int nprocs,
+ int myrank, int contig_access_count,
+ int *send_buf_idx,
+ int *curr_to_proc,
+ int *done_to_proc, int iter,
+ MPI_Aint buftype_extent);
+static void ADIOI_LUSTRE_W_Exchange_data(ADIO_File fd, void *buf,
+ char *write_buf,
+ int *recv_size, ADIO_Offset off,
+ int size, int *count,
+ int *start_pos, int *partial_recv,
+ int myrank, int buftype_is_contig,
+ ADIOI_Access * others_req,
+ int *done_to_proc, int *hole,
+ int iter, MPI_Aint buftype_extent,
+void ADIOI_Heap_merge(ADIOI_Access * others_req, int *count,
+ ADIO_Offset * srt_off, int *srt_len, int *start_pos,
+ int nprocs, int nprocs_recv, int total_elements);
+void ADIOI_LUSTRE_WriteStridedColl(ADIO_File fd, void *buf, int count,
+ int file_ptr_type, ADIO_Offset offset,
+ ADIO_Status * status, int *error_code)
+ /* Uses a generalized version of the extended two-phase method described
+ * in "An Extended Two-Phase Method for Accessing Sections of
+ * Out-of-Core Arrays", Rajeev Thakur and Alok Choudhary,
+ * Scientific Programming, (5)4:301--317, Winter 1996.
+ * http://www.mcs.anl.gov/home/thakur/ext2ph.ps
+ /* array of nprocs access structures, one for each other process has
+ this process's request */
+ whose request is written by this process. */
+ int i, filetype_is_contig, nprocs, myrank, do_collect = 0;
+ int contig_access_count = 0, buftype_is_contig, interleave_count = 0;
+ int *count_my_req_per_proc, count_my_req_procs, count_others_req_procs;
+ ADIO_Offset orig_fp, start_offset, end_offset, off;
+ ADIO_Offset *offset_list = NULL, *st_offsets = NULL, *end_offsets = NULL;
+ int *buf_idx = NULL, *len_list = NULL, *striping_info = NULL;
+ int old_error, tmp_error;
+ MPI_Comm_size(fd->comm, &nprocs);
+ MPI_Comm_rank(fd->comm, &myrank);
+ orig_fp = fd->fp_ind;
+ /* IO patten identification if cb_write isn't disabled */
+ if (fd->hints->cb_write != ADIOI_HINT_DISABLE) {
+ /* For this process's request, calculate the list of offsets and
+ lengths in the file and determine the start and end offsets. */
+ /* Note: end_offset points to the last byte-offset that will be accessed.
+ * e.g., if start_offset=0 and 100 bytes to be read, end_offset=99
+ ADIOI_Calc_my_off_len(fd, count, datatype, file_ptr_type, offset,
+ &offset_list, &len_list, &start_offset,
+ &end_offset, &contig_access_count);
+ /* each process communicates its start and end offsets to other
+ * processes. The result is an array each of start and end offsets
+ * stored in order of process rank.
+ st_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs * sizeof(ADIO_Offset));
+ end_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs * sizeof(ADIO_Offset));
+ MPI_Allgather(&start_offset, 1, ADIO_OFFSET, st_offsets, 1,
+ ADIO_OFFSET, fd->comm);
+ MPI_Allgather(&end_offset, 1, ADIO_OFFSET, end_offsets, 1,
+ /* are the accesses of different processes interleaved? */
+ for (i = 1; i < nprocs; i++)
+ if ((st_offsets[i] < end_offsets[i-1]) &&
+ (st_offsets[i] <= end_offsets[i]))
+ interleave_count++;
+ /* This is a rudimentary check for interleaving, but should suffice
+ for the moment. */
+ /* Two typical access patterns can benefit from collective write.
+ * 1) the processes are interleaved, and
+ * 2) the req size is small.
+ if (interleave_count > 0) {
+ do_collect = 1;
+ } else {
+ do_collect = ADIOI_LUSTRE_Docollect(fd, contig_access_count,
+ len_list, nprocs);
+ ADIOI_Datatype_iscontig(datatype, &buftype_is_contig);
+ /* Decide if collective I/O should be done */
+ if ((!do_collect && fd->hints->cb_write == ADIOI_HINT_AUTO) ||
+ fd->hints->cb_write == ADIOI_HINT_DISABLE) {
+ int filerange_is_contig = 0;
+ /* use independent accesses */
+ ADIOI_Free(offset_list);
+ ADIOI_Free(len_list);
+ ADIOI_Free(st_offsets);
+ ADIOI_Free(end_offsets);
+ fd->fp_ind = orig_fp;
+ ADIOI_Datatype_iscontig(fd->filetype, &filetype_is_contig);
+ if (buftype_is_contig && filetype_is_contig) {
+ if (file_ptr_type == ADIO_EXPLICIT_OFFSET) {
+ off = fd->disp + (fd->etype_size) * offset;
+ ADIO_WriteContig(fd, buf, count, datatype,
+ ADIO_EXPLICIT_OFFSET,
+ off, status, error_code);
+ } else
+ ADIO_WriteContig(fd, buf, count, datatype, ADIO_INDIVIDUAL,
+ 0, status, error_code);
+ } else {
+ ADIO_WriteStrided(fd, buf, count, datatype, file_ptr_type,
+ offset, status, error_code);
+ return;
+ /* Get Lustre hints information */
+ ADIOI_LUSTRE_Get_striping_info(fd, &striping_info, 1);
+ /* calculate what portions of the access requests of this process are
+ * located in which process
+ ADIOI_LUSTRE_Calc_my_req(fd, offset_list, len_list, contig_access_count,
+ striping_info, nprocs, &count_my_req_procs,
+ &count_my_req_per_proc, &my_req, &buf_idx);
+ /* based on everyone's my_req, calculate what requests of other processes
+ * will be accessed by this process.
+ * count_others_req_procs = number of processes whose requests (including
+ * requests of proc. i will be accessed by this process.
+ ADIOI_LUSTRE_Calc_others_req(fd, count_my_req_procs,
+ count_my_req_per_proc,
+ my_req, nprocs, myrank,
+ start_offset, end_offset, striping_info,
+ &count_others_req_procs, &others_req);
+ ADIOI_Free(count_my_req_per_proc);
+ /* exchange data and write in sizes of no more than stripe_size. */
+ ADIOI_LUSTRE_Exch_and_write(fd, buf, datatype, nprocs, myrank,
+ others_req, my_req,
+ offset_list, len_list, contig_access_count,
+ striping_info, buf_idx, error_code);
+ /* If this collective write is followed by an independent write,
+ * it's possible to have those subsequent writes on other processes
+ * race ahead and sneak in before the read-modify-write completes.
+ * We carry out a collective communication at the end here so no one
+ * can start independent i/o before collective I/O completes.
+ * need to do some gymnastics with the error codes so that if something
+ * went wrong, all processes report error, but if a process has a more
+ * specific error code, we can still have that process report the
+ * additional information */
+ old_error = *error_code;
+ if (*error_code != MPI_SUCCESS)
+ *error_code = MPI_ERR_IO;
+ /* optimization: if only one process performing i/o, we can perform
+ * a less-expensive Bcast */
+ MPE_Log_event(ADIOI_MPE_postwrite_a, 0, NULL);
+#endif
+ if (fd->hints->cb_nodes == 1)
+ MPI_Bcast(error_code, 1, MPI_INT,
+ fd->hints->ranklist[0], fd->comm);
+ else {
+ tmp_error = *error_code;
+ MPI_Allreduce(&tmp_error, error_code, 1, MPI_INT,
+ MPI_MAX, fd->comm);
+ MPE_Log_event(ADIOI_MPE_postwrite_b, 0, NULL);
+#endif
+ if ((old_error != MPI_SUCCESS) && (old_error != MPI_ERR_IO))
+ *error_code = old_error;
+ if (!buftype_is_contig)
+ ADIOI_Delete_flattened(datatype);
+ /* free all memory allocated for collective I/O */
+ /* free others_req */
+ ADIOI_Free(others_req[i].offsets);
+ ADIOI_Free(others_req[i].lens);
+ ADIOI_Free(others_req[i].mem_ptrs);
+ ADIOI_Free(others_req);
+ /* free my_req here */
+ ADIOI_Free(my_req[i].offsets);
+ ADIOI_Free(my_req[i].lens);
+ ADIOI_Free(my_req);
+ ADIOI_Free(buf_idx);
+ ADIOI_Free(striping_info);
+#ifdef HAVE_STATUS_SET_BYTES
+ if (status) {
+ int bufsize, size;
+ /* Don't set status if it isn't needed */
+ MPI_Type_size(datatype, &size);
+ bufsize = size * count;
+ MPIR_Status_set_bytes(status, datatype, bufsize);
+ /* This is a temporary way of filling in status. The right way is to
+ * keep track of how much data was actually written during collective I/O.
+#endif
+ fd->fp_sys_posn = -1; /* set it to null. */
+/* If successful, error_code is set to MPI_SUCCESS. Otherwise an error
+ * code is created and returned in error_code.
+ int myrank, ADIOI_Access *others_req,
+ int *striping_info, int *buf_idx,
+ int *error_code)
+ /* Send data to appropriate processes and write in sizes of no more
+ * than lustre stripe_size.
+ * The idea is to reduce the amount of extra memory required for
+ * collective I/O. If all data were written all at once, which is much
+ * easier, it would require temp space more than the size of user_buf,
+ * which is often unacceptable. For example, to write a distributed
+ * array to a file, where each local array is 8Mbytes, requiring
+ * at least another 8Mbytes of temp space is unacceptable.
+ int hole, i, j, m, flag, ntimes = 1 , max_ntimes, buftype_is_contig;
+ ADIO_Offset st_loc = -1, end_loc = -1, min_st_loc, max_end_loc;
+ ADIO_Offset off, req_off, send_off, iter_st_off, *off_list;
+ ADIO_Offset max_size, step_size = 0;
+ int real_size, req_len, send_len;
+ int *recv_curr_offlen_ptr, *recv_count, *recv_size;
+ int *send_curr_offlen_ptr, *send_size;
+ int *partial_recv, *sent_to_proc, *recv_start_pos;
+ int *send_buf_idx, *curr_to_proc, *done_to_proc;
+ char *write_buf = NULL;
+ MPI_Status status;
+ ADIOI_Flatlist_node *flat_buf = NULL;
+ MPI_Aint buftype_extent;
+ int stripe_size = striping_info[0], avail_cb_nodes = striping_info[2];
+ int data_sieving = 0;
+ *error_code = MPI_SUCCESS; /* changed below if error */
+ /* only I/O errors are currently reported */
+ /* calculate the number of writes of stripe size to be done.
+ * That gives the no. of communication phases as well.
+ * Note:
+ * Because we redistribute data in stripe-contiguous pattern for Lustre,
+ * each process has the same no. of communication phases.
+ st_loc = others_req[i].offsets[0];
+ end_loc = others_req[i].offsets[0];
+ break;
+ for (j = 0; j < others_req[i].count; j++) {
+ st_loc = ADIOI_MIN(st_loc, others_req[i].offsets[j]);
+ end_loc = ADIOI_MAX(end_loc, (others_req[i].offsets[j] +
+ others_req[i].lens[j] - 1));
+ /* this process does no writing. */
+ if ((st_loc == -1) && (end_loc == -1))
+ ntimes = 0;
+ MPI_Allreduce(&end_loc, &max_end_loc, 1, MPI_LONG_LONG_INT, MPI_MAX, fd->comm);
+ /* avoid min_st_loc be -1 */
+ if (st_loc == -1)
+ st_loc = max_end_loc;
+ MPI_Allreduce(&st_loc, &min_st_loc, 1, MPI_LONG_LONG_INT, MPI_MIN, fd->comm);
+ /* align downward */
+ min_st_loc -= min_st_loc % (ADIO_Offset)stripe_size;
+ /* Each time, only avail_cb_nodes number of IO clients perform IO,
+ * so, step_size=avail_cb_nodes*stripe_size IO will be performed at most,
+ * and ntimes=whole_file_portion/step_size
+ step_size = (ADIO_Offset) avail_cb_nodes * stripe_size;
+ max_ntimes = (int)((max_end_loc - min_st_loc) / step_size + 1);
+ if (ntimes)
+ write_buf = (char *) ADIOI_Malloc(stripe_size);
+ /* calculate the start offset for each iteration */
+ off_list = (ADIO_Offset *) ADIOI_Malloc(max_ntimes * sizeof(ADIO_Offset));
+ for (m = 0; m < max_ntimes; m ++)
+ off_list[m] = max_end_loc;
+ for (j = 0; j < others_req[i].count; j ++) {
+ req_off = others_req[i].offsets[j];
+ m = (int)((req_off - min_st_loc) / step_size);
+ off_list[m] = ADIOI_MIN(off_list[m], req_off);
+ recv_curr_offlen_ptr = (int *) ADIOI_Calloc(nprocs, sizeof(int));
+ send_curr_offlen_ptr = (int *) ADIOI_Calloc(nprocs, sizeof(int));
+ /* their use is explained below. calloc initializes to 0. */
+ recv_count = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* to store count of how many off-len pairs per proc are satisfied
+ in an iteration. */
+ send_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* total size of data to be sent to each proc. in an iteration.
+ Of size nprocs so that I can use MPI_Alltoall later. */
+ recv_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* total size of data to be recd. from each proc. in an iteration. */
+ sent_to_proc = (int *) ADIOI_Calloc(nprocs, sizeof(int));
+ /* amount of data sent to each proc so far. Used in
+ ADIOI_Fill_send_buffer. initialized to 0 here. */
+ send_buf_idx = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ curr_to_proc = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ done_to_proc = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* Above three are used in ADIOI_Fill_send_buffer */
+ recv_start_pos = (int *) ADIOI_Malloc(nprocs * sizeof(int));
+ /* used to store the starting value of recv_curr_offlen_ptr[i] in
+ this iteration */
+ if (!buftype_is_contig) {
+ ADIOI_Flatten_datatype(datatype);
+ flat_buf = ADIOI_Flatlist;
+ while (flat_buf->type != datatype)
+ flat_buf = flat_buf->next;
+ MPI_Type_extent(datatype, &buftype_extent);
+ /* I need to check if there are any outstanding nonblocking writes to
+ * the file, which could potentially interfere with the writes taking
+ * place in this collective write call. Since this is not likely to be
+ * common, let me do the simplest thing possible here: Each process
+ * completes all pending nonblocking operations before completing.
+ /*ADIOI_Complete_async(error_code);
+ if (*error_code != MPI_SUCCESS) return;
+ MPI_Barrier(fd->comm);
+ iter_st_off = min_st_loc;
+ /* Although we have recognized the data according to OST index,
+ * a read-modify-write will be done if there is a hole between the data.
+ * For example: if blocksize=60, xfersize=30 and stripe_size=100,
+ * then rank0 will collect data [0, 30] and [60, 90] then write. There
+ * is a hole in [30, 60], which will cause a read-modify-write in [0, 90].
+ * To reduce its impact on the performance, we can disable data sieving
+ * by hint "ds_in_coll".
+ /* check the hint for data sieving */
+ data_sieving = fd->hints->fs_hints.lustre.ds_in_coll;
+ for (m = 0; m < max_ntimes; m++) {
+ /* go through all others_req and my_req to check which will be received
+ * and sent in this iteration.
+ /* Note that MPI guarantees that displacements in filetypes are in
+ monotonically nondecreasing order and that, for writes, the
+ filetypes cannot specify overlapping regions in the file. This
+ simplifies implementation a bit compared to reads. */
+ off = start offset in the file for the data to be written in
+ this iteration
+ iter_st_off = start offset of this iteration
+ real_size = size of data written (bytes) corresponding to off
+ max_size = possible maximum size of data written in this iteration
+ req_off = offset in the file for a particular contiguous request minus
+ what was satisfied in previous iteration
+ send_off = offset the request needed by other processes in this iteration
+ req_len = size corresponding to req_off
+ send_len = size corresponding to send_off
+ /* first calculate what should be communicated */
+ recv_count[i] = recv_size[i] = send_size[i] = 0;
+ off = off_list[m];
+ max_size = ADIOI_MIN(step_size, max_end_loc - iter_st_off + 1);
+ real_size = (int) ADIOI_MIN((off / stripe_size + 1) * stripe_size - off,
+ end_loc - off + 1);
+ for (j = send_curr_offlen_ptr[i]; j < my_req[i].count; j++) {
+ send_off = my_req[i].offsets[j];
+ send_len = my_req[i].lens[j];
+ if (send_off < iter_st_off + max_size) {
+ send_size[i] += send_len;
+ } else {
+ break;
+ send_curr_offlen_ptr[i] = j;
+ recv_start_pos[i] = recv_curr_offlen_ptr[i];
+ for (j = recv_curr_offlen_ptr[i]; j < others_req[i].count; j++) {
+ req_len = others_req[i].lens[j];
+ if (req_off < iter_st_off + max_size) {
+ recv_count[i]++;
+ MPI_Address(write_buf + req_off - off,
+ &(others_req[i].mem_ptrs[j]));
+ recv_size[i] += req_len;
+ } else {
+ break;
+ recv_curr_offlen_ptr[i] = j;
+ /* use variable "hole" to pass data_sieving flag into W_Exchange_data */
+ hole = data_sieving;
+ ADIOI_LUSTRE_W_Exchange_data(fd, buf, write_buf, flat_buf, offset_list,
+ len_list, send_size, recv_size, off, real_size,
+ recv_count, recv_start_pos, partial_recv,
+ sent_to_proc, nprocs, myrank,
+ buftype_is_contig, contig_access_count,
+ striping_info, others_req, send_buf_idx,
+ curr_to_proc, done_to_proc, &hole, m,
+ buftype_extent, buf_idx, error_code);
+ goto over;
+ flag = 0;
+ if (recv_count[i]) {
+ flag = 1;
+ break;
+ if (flag) {
+ /* check whether to do data sieving */
+ if(data_sieving == ADIOI_HINT_ENABLE) {
+ ADIO_WriteContig(fd, write_buf, real_size, MPI_BYTE,
+ ADIO_EXPLICIT_OFFSET, off, &status,
+ error_code);
+ } else {
+ /* if there is no hole, write data in one time;
+ * otherwise, write data in several times */
+ if (!hole) {
+ error_code);
+ } else {
+ if (others_req[i].offsets[j] < off + real_size &&
+ others_req[i].offsets[j] >= off) {
+ write_buf + others_req[i].offsets[j] - off,
+ others_req[i].lens[j],
+ MPI_BYTE, ADIO_EXPLICIT_OFFSET,
+ others_req[i].offsets[j], &status,
+ error_code);
+ goto over;
+ goto over;
+ iter_st_off += max_size;
+over:
+ if (ntimes)
+ ADIOI_Free(write_buf);
+ ADIOI_Free(recv_curr_offlen_ptr);
+ ADIOI_Free(send_curr_offlen_ptr);
+ ADIOI_Free(recv_count);
+ ADIOI_Free(send_size);
+ ADIOI_Free(recv_size);
+ ADIOI_Free(sent_to_proc);
+ ADIOI_Free(recv_start_pos);
+ ADIOI_Free(send_buf_idx);
+ ADIOI_Free(curr_to_proc);
+ ADIOI_Free(done_to_proc);
+ ADIOI_Free(off_list);
+/* Sets error_code to MPI_SUCCESS if successful, or creates an error code
+ * in the case of error.
+ char *write_buf,
+ int *curr_to_proc, int *done_to_proc,
+ int *hole, int iter,
+ MPI_Aint buftype_extent,
+ int i, j, nprocs_recv, nprocs_send, err;
+ char **send_buf = NULL;
+ MPI_Request *requests, *send_req;
+ MPI_Datatype *recv_types;
+ MPI_Status *statuses, status;
+ int *srt_len, sum, sum_recv;
+ ADIO_Offset *srt_off;
+ int data_sieving = *hole;
+ static char myname[] = "ADIOI_W_EXCHANGE_DATA";
+ /* create derived datatypes for recv */
+ nprocs_recv = 0;
+ if (recv_size[i])
+ nprocs_recv++;
+ recv_types = (MPI_Datatype *) ADIOI_Malloc((nprocs_recv + 1) *
+ sizeof(MPI_Datatype));
+ j = 0;
+ if (recv_size[i]) {
+ MPI_Type_hindexed(count[i],
+ &(others_req[i].lens[start_pos[i]]),
+ &(others_req[i].mem_ptrs[start_pos[i]]),
+ MPI_BYTE, recv_types + j);
+ /* absolute displacements; use MPI_BOTTOM in recv */
+ MPI_Type_commit(recv_types + j);
+ j++;
+ /* To avoid a read-modify-write,
+ * check if there are holes in the data to be written.
+ * For this, merge the (sorted) offset lists others_req using a heap-merge.
+ sum = 0;
+ sum += count[i];
+ srt_off = (ADIO_Offset *) ADIOI_Malloc((sum + 1) * sizeof(ADIO_Offset));
+ srt_len = (int *) ADIOI_Malloc((sum + 1) * sizeof(int));
+ ADIOI_Heap_merge(others_req, count, srt_off, srt_len, start_pos,
+ nprocs, nprocs_recv, sum);
+ /* check if there are any holes */
+ *hole = 0;
+ for (i = 0; i < sum - 1; i++) {
+ if (srt_off[i] + srt_len[i] < srt_off[i + 1]) {
+ *hole = 1;
+ break;
+ /* In some cases (see John Bent ROMIO REQ # 835), an odd interaction
+ * between aggregation, nominally contiguous regions, and cb_buffer_size
+ * should be handled with a read-modify-write (otherwise we will write out
+ * more data than we receive from everyone else (inclusive), so override
+ * hole detection
+ if (*hole == 0) {
+ sum_recv = 0;
+ sum_recv += recv_size[i];
+ if (size > sum_recv)
+ *hole = 1;
+ if (data_sieving == ADIOI_HINT_ENABLE && nprocs_recv && *hole) {
+ ADIO_ReadContig(fd, write_buf, size, MPI_BYTE,
+ ADIO_EXPLICIT_OFFSET, off, &status, &err);
+ // --BEGIN ERROR HANDLING--
+ if (err != MPI_SUCCESS) {
+ *error_code = MPIO_Err_create_code(err,
+ MPIR_ERR_RECOVERABLE,
+ myname, __LINE__,
+ MPI_ERR_IO,
+ "**ioRMWrdwr", 0);
+ ADIOI_Free(recv_types);
+ ADIOI_Free(srt_off);
+ ADIOI_Free(srt_len);
+ return;
+ // --END ERROR HANDLING--
+ nprocs_send = 0;
+ if (send_size[i])
+ nprocs_send++;
+ if (fd->atomicity) {
+ /* bug fix from Wei-keng Liao and Kenin Coloma */
+ requests = (MPI_Request *) ADIOI_Malloc((nprocs_send + 1) *
+ send_req = requests;
+ } else {
+ requests = (MPI_Request *) ADIOI_Malloc((nprocs_send + nprocs_recv + 1)*
+ /* post receives */
+ j = 0;
+ MPI_Irecv(MPI_BOTTOM, 1, recv_types[j], i,
+ myrank + i + 100 * iter, fd->comm, requests + j);
+ j++;
+ send_req = requests + nprocs_recv;
+ /* post sends.
+ * if buftype_is_contig, data can be directly sent from
+ * user buf at location given by buf_idx. else use send_buf.
+ if (buftype_is_contig) {
+ j = 0;
+ if (send_size[i]) {
+ MPI_Isend(((char *) buf) + buf_idx[i], send_size[i],
+ MPI_BYTE, i, myrank + i + 100 * iter, fd->comm,
+ send_req + j);
+ j++;
+ buf_idx[i] += send_size[i];
+ } else if (nprocs_send) {
+ /* buftype is not contig */
+ send_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char *));
+ if (send_size[i])
+ send_buf[i] = (char *) ADIOI_Malloc(send_size[i]);
+ ADIOI_LUSTRE_Fill_send_buffer(fd, buf, flat_buf, send_buf, offset_list,
+ len_list, send_size, send_req,
+ contig_access_count, striping_info,
+ send_buf_idx, curr_to_proc, done_to_proc,
+ iter, buftype_extent);
+ /* the send is done in ADIOI_Fill_send_buffer */
+ j = 0;
+ MPI_Status wkl_status;
+ MPI_Recv(MPI_BOTTOM, 1, recv_types[j], i,
+ myrank + i + 100 * iter, fd->comm, &wkl_status);
+ j++;
+ for (i = 0; i < nprocs_recv; i++)
+ MPI_Type_free(recv_types + i);
+ statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send + 1) *
+ } else {
+ statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send + nprocs_recv + 1) *
+#ifdef NEEDS_MPI_TEST
+ i = 0;
+ while (!i)
+ MPI_Testall(nprocs_send, send_req, &i, statuses);
+ } else {
+ while (!i)
+ MPI_Testall(nprocs_send + nprocs_recv, requests, &i, statuses);
+#else
+ MPI_Waitall(nprocs_send, send_req, statuses);
+ else
+ MPI_Waitall(nprocs_send + nprocs_recv, requests, statuses);
+#endif
+ ADIOI_Free(requests);
+ if (!buftype_is_contig && nprocs_send) {
+ if (send_size[i])
+ ADIOI_Free(send_buf[i]);
+ ADIOI_Free(send_buf);
+#define ADIOI_BUF_INCR \
+ while (buf_incr) { \
+ size_in_buf = ADIOI_MIN(buf_incr, flat_buf_sz); \
+ user_buf_idx += size_in_buf; \
+ flat_buf_sz -= size_in_buf; \
+ if (!flat_buf_sz) { \
+ if (flat_buf_idx < (flat_buf->count - 1)) flat_buf_idx++; \
+ else { \
+ flat_buf_idx = 0; \
+ n_buftypes++; \
+ user_buf_idx = flat_buf->indices[flat_buf_idx] + \
+ n_buftypes*buftype_extent; \
+ flat_buf_sz = flat_buf->blocklens[flat_buf_idx]; \
+ buf_incr -= size_in_buf; \
+#define ADIOI_BUF_COPY \
+ while (size) { \
+ size_in_buf = ADIOI_MIN(size, flat_buf_sz); \
+ memcpy(&(send_buf[p][send_buf_idx[p]]), \
+ ((char *) buf) + user_buf_idx, size_in_buf); \
+ send_buf_idx[p] += size_in_buf; \
+ else { \
+ n_buftypes++; \
+ size -= size_in_buf; \
+ ADIOI_BUF_INCR \
+ char **send_buf,
+ int myrank,
+ /* this function is only called if buftype is not contig */
+ int i, p, flat_buf_idx, size;
+ int flat_buf_sz, buf_incr, size_in_buf, jj, n_buftypes;
+ ADIO_Offset off, len, rem_len, user_buf_idx;
+ /* curr_to_proc[p] = amount of data sent to proc. p that has already
+ * been accounted for so far
+ * done_to_proc[p] = amount of data already sent to proc. p in
+ * previous iterations
+ * user_buf_idx = current location in user buffer
+ * send_buf_idx[p] = current location in send_buf of proc. p
+ send_buf_idx[i] = curr_to_proc[i] = 0;
+ done_to_proc[i] = sent_to_proc[i];
+ jj = 0;
+ user_buf_idx = flat_buf->indices[0];
+ flat_buf_idx = 0;
+ n_buftypes = 0;
+ flat_buf_sz = flat_buf->blocklens[0];
+ /* flat_buf_idx = current index into flattened buftype
+ * flat_buf_sz = size of current contiguous component in flattened buf
+ rem_len = (ADIO_Offset) len_list[i];
+ /*this request may span to more than one process */
+ len = rem_len;
+ /* NOTE: len value is modified by ADIOI_Calc_aggregator() to be no
+ * longer than the single region that processor "p" is responsible
+ * for.
+ p = ADIOI_LUSTRE_Calc_aggregator(fd, off, &len, striping_info);
+ if (send_buf_idx[p] < send_size[p]) {
+ if (curr_to_proc[p] + len > done_to_proc[p]) {
+ if (done_to_proc[p] > curr_to_proc[p]) {
+ size = (int) ADIOI_MIN(curr_to_proc[p] + len -
+ done_to_proc[p],
+ send_size[p] -
+ send_buf_idx[p]);
+ buf_incr = done_to_proc[p] - curr_to_proc[p];
+ ADIOI_BUF_INCR
+ buf_incr = (int) (curr_to_proc[p] + len -
+ done_to_proc[p]);
+ curr_to_proc[p] = done_to_proc[p] + size;
+ ADIOI_BUF_COPY
+ } else {
+ size = (int) ADIOI_MIN(len, send_size[p] -
+ send_buf_idx[p]);
+ buf_incr = (int) len;
+ curr_to_proc[p] += size;
+ ADIOI_BUF_COPY
+ if (send_buf_idx[p] == send_size[p]) {
+ MPI_Isend(send_buf[p], send_size[p], MPI_BYTE, p,
+ myrank + p + 100 * iter, fd->comm,
+ requests + jj);
+ jj++;
+ } else {
+ curr_to_proc[p] += (int) len;
+ ADIOI_BUF_INCR
+ } else {
+ ADIOI_BUF_INCR
+ off += len;
+ rem_len -= len;
+ if (send_size[i])
+ sent_to_proc[i] = curr_to_proc[i];
Added: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c (rev 0)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -0,0 +1,467 @@
+#define ADIOI_BUFFERED_WRITE \
+ if (req_off >= writebuf_off + writebuf_len) { \
+ if (writebuf_len) { \
+ ADIO_WriteContig(fd, writebuf, writebuf_len, MPI_BYTE, \
+ ADIO_EXPLICIT_OFFSET, writebuf_off, &status1, error_code); \
+ if (!(fd->atomicity)) \
+ ADIOI_UNLOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
+ if (*error_code != MPI_SUCCESS) { \
+ *error_code = MPIO_Err_create_code(*error_code, \
+ MPIR_ERR_RECOVERABLE, myname, \
+ __LINE__, MPI_ERR_IO, \
+ "**iowswc", 0); \
+ ADIOI_Free(writebuf); \
+ return; \
+ writebuf_off = req_off; \
+ /* stripe_size alignment */ \
+ writebuf_len = (int) ADIOI_MIN(end_offset - writebuf_off + 1, \
+ (writebuf_off / stripe_size + 1) * \
+ stripe_size - writebuf_off);\
+ ADIOI_WRITE_LOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
+ ADIO_ReadContig(fd, writebuf, writebuf_len, MPI_BYTE, ADIO_EXPLICIT_OFFSET,\
+ writebuf_off, &status1, error_code); \
+ "**iowsrc", 0); \
+ return; \
+ write_sz = (int) ADIOI_MIN(req_len, writebuf_off + writebuf_len - req_off); \
+ memcpy(writebuf + req_off - writebuf_off, (char *)buf + userbuf_off, write_sz);\
+ while (write_sz != req_len) {\
+ "**iowswc", 0); \
+ return; \
+ req_len -= write_sz; \
+ userbuf_off += write_sz; \
+ writebuf_off += writebuf_len; \
+ "**iowsrc", 0); \
+ return; \
+ write_sz = ADIOI_MIN(req_len, writebuf_len); \
+ memcpy(writebuf, (char *)buf + userbuf_off, write_sz);\
+/* this macro is used when filetype is contig and buftype is not contig.
+ it does not do a read-modify-write and does not lock*/
+#define ADIOI_BUFFERED_WRITE_WITHOUT_READ \
+ while (req_len) { \
+ "**iowswc", 0); \
+ return; \
+ ADIO_Offset offset, ADIO_Status * status,
+ int *error_code)
+ /* offset is in units of etype relative to the filetype. */
+ ADIOI_Flatlist_node *flat_buf, *flat_file;
+ int i, j, k, bwr_size, fwr_size = 0, st_index = 0;
+ int bufsize, num, size, sum, n_etypes_in_filetype, size_in_filetype;
+ int n_filetypes, etype_in_filetype;
+ ADIO_Offset abs_off_in_filetype = 0;
+ int filetype_size, etype_size, buftype_size, req_len;
+ MPI_Aint filetype_extent, buftype_extent;
+ int buf_count, buftype_is_contig, filetype_is_contig;
+ ADIO_Offset userbuf_off;
+ ADIO_Offset off, req_off, disp, end_offset = 0, writebuf_off, start_off;
+ char *writebuf;
+ int flag, st_fwr_size, st_n_filetypes, writebuf_len, write_sz;
+ ADIO_Status status1;
+ int new_bwr_size, new_fwr_size;
+ int stripe_size;
+ static char myname[] = "ADIOI_LUSTRE_WriteStrided";
+ int myrank;
+ if (fd->hints->ds_write == ADIOI_HINT_DISABLE) {
+ /* if user has disabled data sieving on writes, use naive
+ * approach instead.
+ ADIOI_GEN_WriteStrided_naive(fd,
+ buf,
+ count,
+ datatype,
+ file_ptr_type,
+ return;
+ MPI_Type_size(fd->filetype, &filetype_size);
+ if (!filetype_size) {
+ return;
+ MPI_Type_extent(fd->filetype, &filetype_extent);
+ MPI_Type_size(datatype, &buftype_size);
+ etype_size = fd->etype_size;
+ bufsize = buftype_size * count;
+ /* get striping info */
+ /* Different buftype to different filetype */
+ if (!buftype_is_contig && filetype_is_contig) {
+ /* noncontiguous in memory, contiguous in file. */
+ off = (file_ptr_type == ADIO_INDIVIDUAL) ? fd->fp_ind :
+ fd->disp + etype_size * offset;
+ start_off = off;
+ end_offset = start_off + bufsize - 1;
+ writebuf_off = start_off;
+ /* write stripe size buffer each time */
+ writebuf = (char *) ADIOI_Malloc(ADIOI_MIN(bufsize, stripe_size));
+ writebuf_len = (int) ADIOI_MIN(bufsize,
+ /* if atomicity is true, lock the region to be accessed */
+ ADIOI_WRITE_LOCK(fd, start_off, SEEK_SET, bufsize);
+ for (j = 0; j < count; j++) {
+ for (i = 0; i < flat_buf->count; i++) {
+ userbuf_off = j * buftype_extent + flat_buf->indices[i];
+ req_off = off;
+ req_len = flat_buf->blocklens[i];
+ ADIOI_BUFFERED_WRITE_WITHOUT_READ
+ off += flat_buf->blocklens[i];
+ /* write the buffer out finally */
+ error_code);
+ ADIOI_UNLOCK(fd, start_off, SEEK_SET, bufsize);
+ return;
+ if (file_ptr_type == ADIO_INDIVIDUAL)
+ fd->fp_ind = off;
+ } else {
+ /* noncontiguous in file */
+ /* filetype already flattened in ADIO_Open */
+ flat_file = ADIOI_Flatlist;
+ while (flat_file->type != fd->filetype)
+ flat_file = flat_file->next;
+ disp = fd->disp;
+ if (file_ptr_type == ADIO_INDIVIDUAL) {
+ offset = fd->fp_ind; /* in bytes */
+ n_filetypes = -1;
+ flag = 0;
+ while (!flag) {
+ n_filetypes++;
+ for (i = 0; i < flat_file->count; i++) {
+ if (disp + flat_file->indices[i] +
+ (ADIO_Offset) n_filetypes * filetype_extent +
+ flat_file->blocklens[i] >= offset) {
+ st_index = i;
+ fwr_size = (int) (disp + flat_file->indices[i] +
+ filetype_extent +
+ flat_file->blocklens[i] -
+ offset);
+ flag = 1;
+ break;
+ } else {
+ n_etypes_in_filetype = filetype_size / etype_size;
+ n_filetypes = (int) (offset / n_etypes_in_filetype);
+ etype_in_filetype = (int) (offset % n_etypes_in_filetype);
+ size_in_filetype = etype_in_filetype * etype_size;
+ sum = 0;
+ sum += flat_file->blocklens[i];
+ if (sum > size_in_filetype) {
+ st_index = i;
+ fwr_size = sum - size_in_filetype;
+ abs_off_in_filetype = flat_file->indices[i] +
+ size_in_filetype - (sum - flat_file->blocklens[i]);
+ break;
+ /* abs. offset in bytes in the file */
+ offset = disp + (ADIO_Offset) n_filetypes *filetype_extent +
+ abs_off_in_filetype;
+ start_off = offset;
+ /* If the file bytes is actually contiguous, we do not need data sieve at all */
+ if (bufsize <= fwr_size) {
+ req_off = start_off;
+ req_len = bufsize;
+ memset(writebuf, -1, ADIOI_MIN(bufsize, stripe_size));
+ writebuf_off = 0;
+ writebuf_len = 0;
+ userbuf_off = 0;
+ } else {
+ /* Calculate end_offset, the last byte-offset that will be accessed.
+ e.g., if start_offset=0 and 100 bytes to be write, end_offset=99 */
+ st_fwr_size = fwr_size;
+ st_n_filetypes = n_filetypes;
+ i = 0;
+ j = st_index;
+ off = offset;
+ fwr_size = ADIOI_MIN(st_fwr_size, bufsize);
+ while (i < bufsize) {
+ i += fwr_size;
+ end_offset = off + fwr_size - 1;
+ if (j < (flat_file->count - 1))
+ j++;
+ else {
+ j = 0;
+ n_filetypes++;
+ off = disp + flat_file->indices[j] +
+ (ADIO_Offset) n_filetypes * filetype_extent;
+ fwr_size = ADIOI_MIN(flat_file->blocklens[j], bufsize - i);
+ writebuf_off = 0;
+ writebuf_len = 0;
+ writebuf = (char *) ADIOI_Malloc(stripe_size);
+ memset(writebuf, -1, stripe_size);
+ if (buftype_is_contig && !filetype_is_contig) {
+ /* contiguous in memory, noncontiguous in file. should be the most
+ common case. */
+ i = 0;
+ j = st_index;
+ off = offset;
+ n_filetypes = st_n_filetypes;
+ if (fwr_size) {
+ /* TYPE_UB and TYPE_LB can result in
+ fwr_size = 0. save system call in such cases */
+ lseek(fd->fd_sys, off, SEEK_SET);
+ err = write(fd->fd_sys, ((char *) buf) + i, fwr_size);
+ req_off = off;
+ req_len = fwr_size;
+ userbuf_off = i;
+ i += fwr_size;
+ if (off + fwr_size < disp + flat_file->indices[j] +
+ flat_file->blocklens[j] +
+ (ADIO_Offset) n_filetypes * filetype_extent)
+ off += fwr_size;
+ /* did not reach end of contiguous block in filetype.
+ no more I/O needed. off is incremented by fwr_size. */
+ else {
+ j++;
+ else {
+ j = 0;
+ n_filetypes++;
+ bufsize - i);
+ } else {
+ /* noncontiguous in memory as well as in file */
+ k = num = buf_count = 0;
+ i = (int) (flat_buf->indices[0]);
+ j = st_index;
+ off = offset;
+ fwr_size = st_fwr_size;
+ bwr_size = flat_buf->blocklens[0];
+ while (num < bufsize) {
+ size = ADIOI_MIN(fwr_size, bwr_size);
+ if (size) {
+ err = write(fd->fd_sys, ((char *) buf) + i, size);
+ req_off = off;
+ req_len = size;
+ userbuf_off = i;
+ new_fwr_size = fwr_size;
+ new_bwr_size = bwr_size;
+ if (size == fwr_size) {
+ /* reached end of contiguous block in file */
+ if (j < (flat_file->count - 1)) {
+ j++;
+ } else {
+ j = 0;
+ n_filetypes++;
+ new_fwr_size = flat_file->blocklens[j];
+ if (size != bwr_size) {
+ i += size;
+ new_bwr_size -= size;
+ if (size == bwr_size) {
+ /* reached end of contiguous block in memory */
+ k = (k + 1) % flat_buf->count;
+ buf_count++;
+ i = (int) (buftype_extent *
+ (buf_count / flat_buf->count) +
+ flat_buf->indices[k]);
+ new_bwr_size = flat_buf->blocklens[k];
+ if (size != fwr_size) {
+ off += size;
+ new_fwr_size -= size;
+ num += size;
+ fwr_size = new_fwr_size;
+ bwr_size = new_bwr_size;
+ return;
+ fd->fp_ind = off;
+ keep track of how much data was actually written by ADIOI_BUFFERED_WRITE. */
+#endif
Modified: mpich2/trunk/src/mpi/romio/adio/common/ad_write_coll.c
--- mpich2/trunk/src/mpi/romio/adio/common/ad_write_coll.c 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/common/ad_write_coll.c 2009-03-13 15:30:30 UTC (rev 4055)
@@ -46,7 +46,7 @@
int *send_buf_idx, int *curr_to_proc,
-static void ADIOI_Heap_merge(ADIOI_Access *others_req, int *count,
+void ADIOI_Heap_merge(ADIOI_Access *others_req, int *count,
ADIO_Offset *srt_off, int *srt_len, int *start_pos,
@@ -958,7 +958,7 @@
Modified: mpich2/trunk/src/mpi/romio/adio/include/adioi.h
--- mpich2/trunk/src/mpi/romio/adio/include/adioi.h 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/adio/include/adioi.h 2009-03-13 15:30:30 UTC (rev 4055)
@@ -64,6 +64,14 @@
int dtype_read;
int dtype_write;
} pvfs2;
+ struct {
+ int start_iodevice;
+ int CO;
+ int bigsize;
+ int contig_data;
+ int samesize;
+ int ds_in_coll;
+ } lustre;
} fs_hints;
Modified: mpich2/trunk/src/mpi/romio/configure.in
--- mpich2/trunk/src/mpi/romio/configure.in 2009-03-13 11:28:26 UTC (rev 4054)
+++ mpich2/trunk/src/mpi/romio/configure.in 2009-03-13 15:30:30 UTC (rev 4055)
@@ -1123,8 +1123,14 @@
if test -n "$file_system_testfs"; then
AC_DEFINE(ROMIO_TESTFS,1,[Define for ROMIO with TESTFS])
fi
+# Verify presence of lustre/lustre_user.h
if test -n "$file_system_lustre"; then
- AC_DEFINE(ROMIO_LUSTRE,1,[Define for ROMIO with LUSTRE])
+ AC_CHECK_HEADERS(lustre/lustre_user.h,
+ AC_DEFINE(ROMIO_LUSTRE,1,[Define for ROMIO with LUSTRE]),
+ AC_MSG_ERROR([LUSTRE support requested but cannot find lustre/lustre_user.h header file])
fi
if test -n "$file_system_xfs"; then
More information about the mpich2-commits
