[mpich-discuss] BLCR library - Restart Problem
Darius Buntinas
buntinas at mcs.anl.gov
Mon Sep 24 15:06:39 CDT 2012
Assuming the variables (like CKPT_PATH) are right, this looks correct.
What's NUM_NODES set to? How many nodes in $hosts? What's CK_NUM set to?
-d
On Sep 24, 2012, at 2:59 PM, Mehmet Kurt wrote:
> Hi,
> Is there any reason that might cause such a behavior?
> Thank you,
> Mehmet
> From: Mehmet Kurt
> Sent: Thursday, September 20, 2012 2:46 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: RE: [mpich-discuss] BLCR library - Restart Problem
> I use a script file for both initial run and restart.
> This is the command I use for initial run:
> /home/kurt/mpich2-blcr-install/bin/mpiexec -env MPICH_ASYNC_PROGRESS 1 -disable-auto-cleanup -ckpointlib blcr -ckpoint-prefix ${CKPT_PATH} -f $hosts -np ${NUM_NODES} ./md ${FREQUENCY} ${FAILING_IT}
> And, this is for restart:
> /home/kurt/mpich2-blcr-install/bin/mpiexec -env MPICH_ASYNC_PROGRESS 1 -disable-auto-cleanup -ckpointlib blcr -ckpoint-prefix ${CKPT_PATH} -ckpoint-num ${CK_NUM} -f $hosts -np ${NUM_NODES}
> Mehmet
> From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] on behalf of Darius Buntinas [buntinas at mcs.anl.gov]
> Sent: Thursday, September 20, 2012 2:18 PM
> Subject: Re: [mpich-discuss] BLCR library - Restart Problem
> Can you send us the command lines you used for the initial run and when restarting?
> Thanks,
> -d
> On Sep 20, 2012, at 12:36 PM, Mehmet Kurt wrote:
>> Hello,
>> I'm using BLCR checkpointing library with mpich2-1.4.1p1.
>> I have no problem with checkpointing my application, but when I want to restart it with the same set of nodes, nothing happens; it just hangs there.
>> I connected the same node, which restarts the application by mpiexec, from another terminal. after running "top" command I saw that it
>> creates a <DEFUNCT> process for my executable.
>> Any ideas about what can cause this behavior?
>> Thank you,
>> Mehmet Can Kurt
>> Graduate Student
>> Computer Engineering Department
>> Ohio State University
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
