[mpich-discuss] Error in Checkpointing An MPI application
Manisha Chauhan manisha.chauhan at yahoo.co.in
Fri Sep 21 01:45:38 CDT 2012
Hi all
I want to checkpoint an MPI application using MPICH2 and BLCR tool. But while checkpointing i am getting an error.
I installed BLCR with MPICH2 successfuly. I configured BLCR using command-
./configure --prefix=/home/superusr/manisha/blcr-0.8.3/install
 make
make install
vim .bash_profile
export LD_LIBRARY_PATH="/home/superusr/manisha/blcr-0.8.3/install/lib:$LD_LIBRARY_PATH"
export PATH="/home/superusr/manisha/blcr-0.8.3/install/bin:$PATH"
source .bash_profile
On command prompt Given-
1) /sbin/insmod /home/superusr/manisha/blcr-0.8.3/install/lib/blcr/2.6.32-279.2.1.el6.x86_64/blcr_imports.ko
2) /sbin/insmod /home/superusr/manisha/blcr-0.8.3/install/lib/blcr/2.6.32-279.2.1.el6.x86_64/blcr.ko
Checked Whether BLCR is configured or loaded using command -
 /sbin/lsmod | grep blcr
O/P -
blcr                  114837  0
blcr_imports            9988  1 blcr
Then i configured the hydra module using command-
tar xzf hydra-1.4.1p1.tar.gz
cd hydra
mkdir hydra-install
In /home/superusr/manisha/hydra given configure command-
a. ./configure --prefix=/home/superusr/manisha/hydra/hydra-install --with-hydra-ckpointlib=blcr --with-blcr=/home/superusr/manisha/blcr-0.8.3/install
b. make
c. make install
vim .bash_profile
export LD_LIBRARY_PATH="/home/superusr/manisha/hydra/hydra-install/lib:$LD_LIBRARY_PATH"
export PATH="/home/superusr/manisha/hydra/hydra-install/bin:$PATH"
And then finally i configured MPICH2 using command-
tar xzf mpich2-1.4.1p1.tar.gz
cd mpich2-1.4.1p1
mkdir mpich2-install
In /home/superusr/manisha/mpich2-1.4.1p1 given configure command-
a. ./configure --prefix=/home/superusr/manisha/mpich2-1.4.1p1/mpich2-install --enable-checkpointing --with-blcr=/home/superusr/manisha/blcr-0.8.3/install --with-pm=hydra
b. make
c. make install
vim .bash_profile
export LD_LIBRARY_PATH="/home/superusr/manisha/mpich2-1.4.1p1/mpich2-install/lib:$LD_LIBRARY_PATH"
export PATH="/home/superusr/manisha/mpich2-1.4.1p1/mpich2-install/bin:$PATH"
And set the hydra checkpoint prefix-
vim .bash_profile
export HYDRA_CKPOINT_PREFIX=/home/superusr/Raghu/linpack_10.3.10/benchmarks/mp_linpack/bin_intel/intel64/tmp/app.ckpoint
But when i have given the check pointing command as shown below it gives the error given below -
mpiexec -ckpointlib blcr -ckpoint-prefix /tmp/app.ckpoint -ckpoint-interval 3600 -n 4 ./xhpl_intel64
[cli_2]: Command cmd=put kvsname=kvs_23207_0 key=P0-hostname value=power1.cdacb.in
 failed, reason='duplicate_keyP0-hostname'
[cli_1]: Command cmd=put kvsname=kvs_23207_0 key=P0-hostname value=power1.cdacb.in
[cli_0]: Command cmd=put kvsname=kvs_23207_0 key=r2h0 value=thnum#1$h0#power1.cdacb.in$r0#0$nbc#1$
 failed, reason='duplicate_keyr2h0'
[cli_3]: Command cmd=put kvsname=kvs_23207_0 key=r2h0 value=thnum#1$h0#power1.cdacb.in$r0#0$nbc#1$
[cli_1]: Command cmd=put kvsname=kvs_23207_0 key=P0-businesscard value=fabrics_list#shm$
 failed, reason='duplicate_keyP0-businesscard'
[cli_2]: Command cmd=put kvsname=kvs_23207_0 key=P0-businesscard value=fabrics_list#shm$
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(586)....: Initialization failed
MPID_Init(171)...........: channel initialization failed
MPIDI_CH3_Init(70).......:
MPID_nem_init_ckpt(897)..:
MPIDI_PG_SetConnInfo(668): PMI_KVS_Put returned -1
Please help me resolve this problem.
Thanks & Regards
Manisha Chauhan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120921/d3ad7f19/attachment.html>
