[mpich-discuss] Win7 Test Setup
jacobs at gsc.tu-darmstadt.de jacobs at gsc.tu-darmstadt.de
Wed Sep 19 05:30:23 CDT 2012
yes having the same credentials on every VM works, thanks.
I'm having a different problem now. My, on a Win7 64 compiled, executable
won't run on the Virtual XP 64bit Machienes (VirtualBox).
I get the Error Message: "the executable ist not a valid Win32 application"
Since I complie my executable as 64bit and the VMs have XP 64bit it should
work? I'm I missing annything?
Grischa
> Hi,
>  How are you logging on to the VM? The credentials on the host should work
> on the VM (right?).
>  As long as you have the same username (with the same password) valid on
> all the hosts (VMs) your MPI job should run across all the hosts (VMs).
> Regards,
> Jayesh
> From: "Grischa Jacobs" <jacobs at gsc.tu-darmstadt.de>
> To: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, September 18, 2012 11:29:34 AM
> Subject: [mpich-discuss] Win7 Test Setup
> Hi,
> Iam trying to setup a System for getting startet with mpich2 on Windows
> 64bit. So far I'm using Win7 as a host with VirtualBox with more nodes on
> the same Win7 system. I'm using a networkshare mapped to a virtual drive.
> Now I'm not sure how to setup the credentials right so I can scale out
> with the virtual machines. Is it possible to define hosts with their
> credentials in the machine file? What would be a better solution?
> Thanks :-)
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
