[mpich-discuss] Win7 Test Setup
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Sep 18 11:55:10 CDT 2012
How are you logging on to the VM? The credentials on the host should work on the VM (right?).
As long as you have the same username (with the same password) valid on all the hosts (VMs) your MPI job should run across all the hosts (VMs).
Jayesh
----- Original Message -----
From: "Grischa Jacobs" <jacobs at gsc.tu-darmstadt.de>
Sent: Tuesday, September 18, 2012 11:29:34 AM
Subject: [mpich-discuss] Win7 Test Setup
Iam trying to setup a System for getting startet with mpich2 on Windows 64bit. So far I'm using Win7 as a host with VirtualBox with more nodes on the same Win7 system. I'm using a networkshare mapped to a virtual drive.
Now I'm not sure how to setup the credentials right so I can scale out with the virtual machines. Is it possible to define hosts with their credentials in the machine file? What would be a better solution?
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
